path: root/arch/alpha/kernel/srmcons.c
2007-07-16alpha: fix trivial section mismatch warningsSam Ravnborg
Fix the following section mismatch warnings: WARNING: arch/alpha/kernel/built-in.o(.text+0x7c78): Section mismatch: reference to .init.text:init_rtc_irq (between 'common_init_rtc' and 'timer_interrupt') WARNING: arch/alpha/kernel/built-in.o(.text+0x7c7c): Section mismatch: reference to .init.text:init_rtc_irq (between 'common_init_rtc' and 'timer_interrupt') WARNING: arch/alpha/kernel/built-in.o(.data+0x2c30): Section mismatch: reference to .init.text:srm_console_setup (between 'srmcons' and 'tsunami_pci_ops') In all three cases functions marked __init was called outside __init context. So the fix was to just drop the __init attribute. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Meelis Roos <mroos@linux.ee> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fixes and cleanups for earlyprintk aka boot consoleGerd Hoffmann
The console subsystem already has an idea of a boot console, using the CON_BOOT flag. The implementation has some flaws though. The major problem is that presence of a boot console makes register_console() ignore any other console devices (unless explicitly specified on the kernel command line). This patch fixes the console selection code to *not* consider a boot console a full-featured one, so the first non-boot console registering will become the default console instead. This way the unregister call for the boot console in the register_console() function actually triggers and the handover from the boot console to the real console device works smoothly. Added a printk for the handover, so you know which console device the output goes to when the boot console stops printing messages. The disable_early_printk() call is obsolete with that patch, explicitly disabling the early console isn't needed any more as it works automagically with that patch. I've walked through the tree, dropped all disable_early_printk() instances found below arch/ and tagged the consoles with CON_BOOT if needed. The code is tested on x86, sh (thanks to Paul) and mips (thanks to Ralf). Changes to last version: Rediffed against -rc3, adapted to mips cleanups by Ralf, fixed "udbg-immortal" cmd line arg on powerpc. Signed-off-by: Gerd Hoffmann <kraxel@exsuse.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Andi Kleen <ak@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07srmcons: fix kmalloc(GFP_KERNEL) inside spinlockAndrew Morton
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=8341 Cc: <matthias.kaehlcke@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-02[PATCH] const struct tty_operationsJeff Dike
As part of an SMP cleanliness pass over UML, I consted a bunch of structures in order to not have to document their locking. One of these structures was a struct tty_operations. In order to const it in UML without introducing compiler complaints, the declaration of tty_set_operations needs to be changed, and then all of its callers need to be fixed. This patch declares all struct tty_operations in the tree as const. In all cases, they are static and used only as input to tty_set_operations. As an extra check, I ran an i386 allyesconfig build which produced no extra warnings. 53 drivers are affected. I checked the history of a bunch of them, and in most cases, there have been only a handful of maintenance changes in the last six months. serial_core.c was the busiest one that I looked at. Signed-off-by: Jeff Dike <jdike@addtoit.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
