Avoid expensive indirect calls in the fast path DMA mapping
operations by directly calling the dma_direct_* ops if we are using
the directly mapped DMA operations.
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Tested-by: Jesper Dangaard Brouer <brouer@redhat.com>
Tested-by: Tony Luck <tony.luck@intel.com>
Remove the dma_ops indirection.
Signed-off-by: Matt Turner <mattst88@gmail.com>
The generic dma_direct implementation does the same thing as the alpha
pci-noop implementation, just with more bells and whistles. And unlike
the current code it at least has a theoretical chance to actually compile.
Pull dma-mapping updates from Christoph Hellwig:
- turn dma_cache_sync into a dma_map_ops instance and remove
implementation that purely are dead because the architecture doesn't
support noncoherent allocations
- add a flag for busses that need DMA configuration (Robin Murphy)
* tag 'dma-mapping-4.15' of git://git.infradead.org/users/hch/dma-mapping:
dma-mapping: turn dma_cache_sync into a dma_map_ops method
sh: make dma_cache_sync a no-op
xtensa: make dma_cache_sync a no-op
unicore32: make dma_cache_sync a no-op
powerpc: make dma_cache_sync a no-op
mn10300: make dma_cache_sync a no-op
microblaze: make dma_cache_sync a no-op
ia64: make dma_cache_sync a no-op
frv: make dma_cache_sync a no-op
x86: make dma_cache_sync a no-op
floppy: consolidate the dummy fd_cacheflush definition
drivers: flag buses which demand DMA configuration
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
After we removed all the dead wood it turns out only two architectures
actually implement dma_cache_sync as a real op: mips and parisc. Add
a cache_sync method to struct dma_map_ops and implement it for the
mips defualt DMA ops, and the parisc pa11 ops.
Note that arm, arc and openrisc support DMA_ATTR_NON_CONSISTENT, but
never provided a functional dma_cache_sync implementations, which
seems somewhat odd.
Reviewed-by: Robin Murphy <robin.murphy@arm.com>
Introduce a new architecture-specific get_arch_dma_ops() function
that takes a struct bus_type * argument. Add get_dma_ops() in
<linux/dma-mapping.h>.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Russell King <linux@armlinux.org.uk>
Cc: x86@kernel.org
Signed-off-by: Doug Ledford <dledford@redhat.com>
Most dma_map_ops structures are never modified. Constify these
structures such that these can be write-protected. This patch
has been generated as follows:
git grep -l 'struct dma_map_ops' |
xargs -d\\n sed -i \
-e 's/struct dma_map_ops/const struct dma_map_ops/g' \
-e 's/const struct dma_map_ops {/struct dma_map_ops {/g' \
-e 's/^const struct dma_map_ops;$/struct dma_map_ops;/' \
-e 's/const const struct dma_map_ops /const struct dma_map_ops /g';
sed -i -e 's/const \(struct dma_map_ops intel_dma_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops intel_dma_ops');
sed -i -e 's/const \(struct dma_map_ops dma_iommu_ops\)/\1/' \
$(git grep -l 'struct dma_map_ops' | grep ^arch/powerpc);
sed -i -e '/^struct vmd_dev {$/,/^};$/ s/const \(struct dma_map_ops[[:blank:]]dma_ops;\)/\1/' \
-e '/^static void vmd_setup_dma_ops/,/^}$/ s/const \(struct dma_map_ops \*dest\)/\1/' \
-e 's/const \(struct dma_map_ops \*dest = \&vmd->dma_ops\)/\1/' \
drivers/pci/host/*.c
sed -i -e '/^void __init pci_iommu_alloc(void)$/,/^}$/ s/dma_ops->/intel_dma_ops./' arch/ia64/kernel/pci-dma.c
sed -i -e 's/static const struct dma_map_ops sn_dma_ops/static struct dma_map_ops sn_dma_ops/' arch/ia64/sn/pci/pci_dma.c
sed -i -e 's/(const struct dma_map_ops \*)//' drivers/misc/mic/bus/vop_bus.c
Cc: x86@kernel.org
The dma-mapping core and the implementations do not change the DMA
attributes passed by pointer. Thus the pointer can point to const data.
However the attributes do not have to be a bitfield. Instead unsigned
long will do fine:
1. This is just simpler. Both in terms of reading the code and setting
attributes. Instead of initializing local attributes on the stack
and passing pointer to it to dma_set_attr(), just set the bits.
2. It brings safeness and checking for const correctness because the
attributes are passed by value.
Semantic patches for this change (at least most of them):
virtual patch
virtual context
@r@
identifier f, attrs;
f(...,
- struct dma_attrs *attrs
+ unsigned long attrs
identifier r.f;
f(...,
- NULL
+ 0
and
// Options: --all-includes
virtual patch
virtual context
@r@
type t;
t f(..., struct dma_attrs *attrs);
identifier r.f;
f(...,
- NULL
+ 0
Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
Acked-by: Mark Salter <msalter@redhat.com> [c6x]
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris]
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm]
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Acked-by: Joerg Roedel <jroedel@suse.de> [iommu]
Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp]
Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core]
Acked-by: David Vrabel <david.vrabel@citrix.com> [xen]
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon]
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k]
Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390]
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32]
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc]
Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu]
Move the generic implementation to <linux/dma-mapping.h> now that all
architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now
that everyone supports them.
[valentinrothberg@gmail.com: remove leftovers in Kconfig]
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Helge Deller <deller@gmx.de>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Sebastian Ott <sebott@linux.vnet.ibm.com>
Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com>
Almost everyone implements dma_set_mask the same way, although some time
that's hidden in ->set_dma_mask methods.
This patch consolidates those into a common implementation that either
calls ->set_dma_mask if present or otherwise uses the default
implementation. Some architectures used to only call ->set_dma_mask
after the initial checks, and those instance have been fixed to do the
full work. h8300 implemented dma_set_mask bogusly as a no-ops and has
been fixed.
Unfortunately some architectures overload unrelated semantics like changing
the dma_ops into it so we still need to allow for an architecture override
for now.
[jcmvbkbc@gmail.com: fix xtensa]
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Andy Shevchenko <andy.shevchenko@gmail.com>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Most architectures just call into ->dma_supported, but some also return 1
if the method is not present, or 0 if no dma ops are present (although
that should never happeb). Consolidate this more broad version into
common code.
Also fix h8300 which inorrectly always returned 0, which would have been
a problem if it's dma_set_mask implementation wasn't a similarly buggy
noop.
As a few architectures have much more elaborate implementations, we
still allow for arch overrides.
Currently there are three valid implementations of dma_mapping_error:
(1) call ->mapping_error
(2) check for a hardcoded error code
(3) always return 0
This patch provides a common implementation that calls ->mapping_error
if present, then checks for DMA_ERROR_CODE if defined or otherwise
returns 0.
Most architectures do not support non-coherent allocations and either
define dma_{alloc,free}_noncoherent to their coherent versions or stub
them out.
Openrisc uses dma_{alloc,free}_attrs to implement them, and only Mips
implements them directly.
This patch moves the Openrisc version to common code, and handles the
DMA_ATTR_NON_CONSISTENT case in the mips dma_map_ops instance.
Note that actual non-coherent allocations require a dma_cache_sync
implementation, so if non-coherent allocations didn't work on
an architecture before this patch they still won't work after it.
Since 2009 we have a nice asm-generic header implementing lots of DMA API
functions for architectures using struct dma_map_ops, but unfortunately
it's still missing a lot of APIs that all architectures still have to
duplicate.
This series consolidates the remaining functions, although we still need
arch opt outs for two of them as a few architectures have very
non-standard implementations.
This patch (of 5):
The coherent DMA allocator works the same over all architectures supporting
dma_map operations.
This patch consolidates them and converges the minor differences:
- the debug_dma helpers are now called from all architectures, including
those that were previously missing them
- dma_alloc_from_coherent and dma_release_from_coherent are now always
called from the generic alloc/free routines instead of the ops
dma-mapping-common.h always includes dma-coherent.h to get the defintions
for them, or the stubs if the architecture doesn't support this feature
- checks for ->alloc / ->free presence are removed. There is only one
magic instead of dma_map_ops without them (mic_dma_ops) and that one
is x86 only anyway.
Besides that only x86 needs special treatment to replace a default devices
if none is passed and tweak the gfp_flags. An optional arch hook is provided
for that.
[linux@roeck-us.net: fix build]
Adapt core Alpha architecture code for dma_map_ops changes: replace
alloc/free_coherent with generic alloc/free methods.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Matt Turner <mattst88@gmail.com>
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <linux-arch@vger.kernel.org>
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
This converts Alpha to use include/linux/pci-dma-compat.h. Alpha is the
only architecutre that implements the PCI DMA API in the own way. That
makes it difficult to implement the generic DMA API via the PCI bus
specific DMA API.
The generic DMA API calls the PCI DMA API implementation in
arch/alpha/kernel/pci_iommu.c on non Jensen systems. It calls the DMA API
in arch/alpha/kernel/pci-noop.c on Jensen systems.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Greg KH <greg@kroah.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
dma_sync_single_for_cpu/for_device supports a partial sync so there is no
point to have dma_sync_single_range (also dma_sync_single was obsoleted
long ago, replaced with dma_sync_single_for_cpu/for_device).
There is no user of dma_sync_single_range() in mainline and only Alpha
architecture supports dma_sync_single_range(). So it's unlikely that
someone out of the tree uses it.
- jensen build: fix conflicting declarations for pci_alloc_consistent()
and undefined virt_to_phys();
- SMP: arch/alpha/kernel/smp.c:124: warning: passing argument 2
of '__cpu_test_and_set' discards qualifiers from pointer target type
Interestingly, this only happens with gcc-4.2; gcc <= 4.1 and gcc-4.3
are OK. Fixed with extra assignment.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Sam Ravnborg did the build-test that the direct header file move works,
I'm just committing it.
This is a pure move:
mkdir arch/alpha/include
git mv include/asm-alpha arch/alpha/include/asm
with no other changes.
Requested-and-tested-by: Sam Ravnborg <sam@ravnborg.org>
