path: root/arch/alpha/Kconfig
2008-03-13alpha: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). Alpha's IOMMU can use it. This removes the check on the boundary size alignment because iommu_is_span_boundary does. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Richard Henderson <rth@twiddle.net> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09ide: introduce HAVE_IDESam Ravnborg
To allow flexible configuration of IDE introduce HAVE_IDE. All archs except arm, um and s390 unconditionally select it. For arm the actual configuration determine if IDE is supported. This is a step towards introducing drivers/Kconfig for arm. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Russell King - ARM Linux <linux@arm.linux.org.uk> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: mark arches that support A.OUT formatDavid Howells
Mark arches that support A.OUT format by including the following in their master Kconfig files: config ARCH_SUPPORTS_AOUT def_bool y This should also be set if the arch provides compatibility A.OUT support for an older arch, for instance x86_64 for i386 or sparc64 for sparc. I've guessed at which arches don't, based on comments in the code, however I'm sure that some of the ones I've marked as 'yes' actually should be 'no'. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-03remove Documentation/smp.txtAdrian Bunk
After seeing the filename I'd have expected something about the implementation of SMP in the Linux kernel - not some notes on kernel configuration and building trivialities noone would search at this place. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alan Cox <alan@redhat.com>
2008-02-03Move Kconfig.instrumentation to arch/Kconfig and init/KconfigMathieu Desnoyers
Move the instrumentation Kconfig to arch/Kconfig for architecture dependent options - oprofile - kprobes and init/Kconfig for architecture independent options - profiling - markers Remove the "Instrumentation Support" menu. Everything moves to "General setup". Delete the kernel/Kconfig.instrumentation file. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-03Add HAVE_OPROFILEMathieu Desnoyers
Linus: On the per-architecture side, I do think it would be better to *not* have internal architecture knowledge in a generic file, and as such a line like depends on X86_32 || IA64 || PPC || S390 || SPARC64 || X86_64 || AVR32 really shouldn't exist in a file like kernel/Kconfig.instrumentation. It would be much better to do depends on ARCH_SUPPORTS_KPROBES in that generic file, and then architectures that do support it would just have a bool ARCH_SUPPORTS_KPROBES default y in *their* architecture files. That would seem to be much more logical, and is readable both for arch maintainers *and* for people who have no clue - and don't care - about which architecture is supposed to support which interface... Changelog: Actually, I know I gave this as the magic incantation, but now that I see it, I realize that I should have told you to just use config ARCH_SUPPORTS_KPROBES def_bool y instead, which is a bit denser. We seem to use both kinds of syntax for these things, but this is really what "def_bool" is there for... Changelog : - Moving to HAVE_*. - Add AVR32 oprofile. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-02-01PCI: Kconfig help: don't refer to the PCI-HOWTOAdrian Bunk
A HOWTO that hasn't been updated for half a dozen years no longer "contains valuable information about which PCI hardware does work under Linux and which doesn't". Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-19Combine instrumentation menus in kernel/Kconfig.instrumentationMathieu Desnoyers
Quoting Randy: "It seems sad that this patch sources Kconfig.marker, a 7-line file, 20-something times. Yes, you (we) don't want to put those 7 lines into 20-something different files, so sourcing is the right thing. However, what you did for avr32 seems more on the right track to me: make _one_ Instrumentation support menu that includes PROFILING, OPROFILE, KPROBES, and MARKERS and then use (source) that in all of the arches." Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11PCI: Only build PCI syscalls on architectures that want themMatthew Wilcox
The PCI syscalls are built on every architecture except X86, but only a few have ever hooked them up. Use a new Kconfig symbol to save a couple of kB on the architectures that have never used the syscalls. Tested on x86 and ia64 only. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-01ALPHA: misc fixesJay Estabrook
1. arch/alpha/Kconfig several adjustments: a) additions to the systems list and cleanup of same b) change limits of NR_CPUS and make dep. on platform Note that MARVEL support is limited to 32 CPUs whan using 42-bit KSEG - one needs 48-bit KSEG to handle up to 64, and we've never supported 48-bit KSEG. 2. include/asm-alpha/core_wildfire.h fix a typo that undoubtedly prevents WILDFIRE support from working Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01ALPHA: support graphics on non-zero PCI domainsJay Estabrook
This code replaces earlier and incomplete handling of graphics on non-zero PCI domains (aka hoses or peer PCI buses). An option (CONFIG_VGA_HOSE) is set TRUE if configuring a GENERIC kernel, or a kernel for MARVEL, TITAN, or TSUNAMI machines, as these are the machines whose SRM consoles are capable of configuring and handling graphics options on non-zero hoses. All other machines have the option set FALSE. A routine, "find_console_vga_hose()", is used to find the graphics device which the machine's firmware believes is the console device, and it sets a global (pci_vga_hose) for later use in managing access to the device. This is called in "init_arch" on TITAN and TSUNAMI machines; MARVEL machines use a custom version of this routine because of extra complexity. A routine, "locate_and_init_vga()", is used to find the graphics device and set a global (pci_vga_hose) for later use in managing access to the device, in the case where "find_console_vga_hose" has failed. Various adjustments are made to the ioremap and ioportmap routines for detecting and translating "legacy" VGA register and memory references to the real PCI domain. [akpm@linux-foundation.org: don't statically init bss] [akpm@linux-foundation.org: build fix] Signed-off-by: Jay Estabrook <jay.estabrook@hp.com> Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Set CONFIG_ZONE_DMA for arches with GENERIC_ISA_DMAChristoph Lameter
As Andi pointed out: CONFIG_GENERIC_ISA_DMA only disables the ISA DMA channel management. Other functionality may still expect GFP_DMA to provide memory below 16M. So we need to make sure that CONFIG_ZONE_DMA is set independent of CONFIG_GENERIC_ISA_DMA. Undo the modifications to mm/Kconfig where we made ZONE_DMA dependent on GENERIC_ISA_DMA and set theses explicitly in each arches Kconfig. Reviews must occur for each arch in order to determine if ZONE_DMA can be switched off. It can only be switched off if we know that all devices supported by a platform are capable of performing DMA transfers to all of memory (Some arches already support this: uml, avr32, sh sh64, parisc and IA64/Altix). In order to switch ZONE_DMA off conditionally, one would have to establish a scheme by which one can assure that no drivers are enabled that are only capable of doing I/O to a part of memory, or one needs to provide an alternate means of performing an allocation from a specific range of memory (like provided by alloc_pages_range()) and insure that all drivers use that call. In that case the arches alloc_dma_coherent() may need to be modified to call alloc_pages_range() instead of relying on GFP_DMA. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] LOG2: Implement a general integer log2 facility in the kernelDavid Howells
This facility provides three entry points: ilog2() Log base 2 of unsigned long ilog2_u32() Log base 2 of u32 ilog2_u64() Log base 2 of u64 These facilities can either be used inside functions on dynamic data: int do_something(long q) { ...; y = ilog2(x) ...; } Or can be used to statically initialise global variables with constant values: unsigned n = ilog2(27); When performing static initialisation, the compiler will report "error: initializer element is not constant" if asked to take a log of zero or of something not reducible to a constant. They treat negative numbers as unsigned. When not dealing with a constant, they fall back to using fls() which permits them to use arch-specific log calculation instructions - such as BSR on x86/x86_64 or SCAN on FRV - if available. [akpm@osdl.org: MMC fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Howells <dhowells@redhat.com> Cc: Wojtek Kaniewski <wojtekka@toxygen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix an arch/alpha/Kconfig typoMatt LaPlante
2006-09-26[PATCH] alpha: Fix ALPHA_EV56 dependencies typoFernando J. Pereda
There appears to be a typo in the EV56 config option. NORITAKE and PRIMO are be able to set a variation of either. Signed-off-by: Daniel Drake <dsd@gentoo.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-12[PATCH] alpha: generic hweight build fixRandy Dunlap
From: Randy Dunlap <rdunlap@xenotime.net> According to include/asm-alpha/bitops.h, only ALPHA_EV67 has hardware hweight support, so ALPHA_EV6 needs to use GENERIC_HWEIGHT. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Ernst Herzberg <earny@net4u.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Configurable NODES_SHIFTYasunori Goto
Current implementations define NODES_SHIFT in include/asm-xxx/numnodes.h for each arch. Its definition is sometimes configurable. Indeed, ia64 defines 5 NODES_SHIFT values in the current git tree. But it looks a bit messy. SGI-SN2(ia64) system requires 1024 nodes, and the number of nodes already has been changeable by config. Suitable node's number may be changed in the future even if it is other architecture. So, I wrote configurable node's number. This patch set defines just default value for each arch which needs multi nodes except ia64. But, it is easy to change to configurable if necessary. On ia64 the number of nodes can be already configured in generic ia64 and SN2 config. But, NODES_SHIFT is defined for DIG64 and HP'S machine too. So, I changed it so that all platforms can be configured via CONFIG_NODES_SHIFT. It would be simpler. See also: http://marc.theaimsgroup.com/?l=linux-kernel&m=114358010523896&w=2 Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: alpha: use generic bitopsAkinobu Mita
- unless defined(__alpha_cix__) and defined(__alpha_fix__) - remove generic_fls() - remove generic_hweight{64,32,16,8}() - remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] tiny: Make *[ug]id16 support optionalMatt Mackall
Configurable 16-bit UID and friends support This allows turning off the legacy 16 bit UID interfaces on embedded platforms. text data bss dec hex filename 3330172 529036 190556 4049764 3dcb64 vmlinux-baseline 3328268 529040 190556 4047864 3dc3f8 vmlinux From: Adrian Bunk <bunk@stusta.de> UID16 was accidentially disabled for !EMBEDDED. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] Alpha: convert to generic irq framework (alpha part)Ivan Kokshaysky
Kconfig tweaks and tons of deletions. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Christoph Hellwig <hch@lst.de> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Kconfig fix (BLK_DEV_FD dependencies)viro@ZenIV.linux.org.uk
Sanitized and fixed floppy dependencies: split the messy dependencies for BLK_DEV_FD by introducing a new symbol (ARCH_MAY_HAVE_PC_FDC), making BLK_DEV_FD depend on that one and taking declarations of ARCH_MAY_HAVE_PC_FDC to arch/*/Kconfig. While we are at it, fixed several obvious cases when BLK_DEV_FD should have been excluded (architectures lacking asm/floppy.h are *not* going to have floppy.c compile, let alone work). If you can come up with better name for that ("this architecture might have working PC-compatible floppy disk controller"), you are more than welcome - just s/ARCH_MAY_HAVE_PC_FDC/your_prefered_name/g in the patch below... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-23[PATCH] Kconfig fix (alpha NUMA)Al Viro
NUMA is broken on alpha; marked as such Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[NET]: add a top-level Networking menu to *configSam Ravnborg
Create a new top-level menu named "Networking" thus moving net related options and protocol selection way from the drivers menu and up on the top-level where they belong. To implement this all architectures has to source "net/Kconfig" before drivers/*/Kconfig in their Kconfig file. This change has been implemented for all architectures. Device drivers for ordinary NIC's are still to be found in the Device Drivers section, but Bluetooth, IrDA and ax25 are located with their corresponding menu entries under the new networking menu item. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[PATCH] make each arch use mm/KconfigDave Hansen
For all architectures, this just means that you'll see a "Memory Model" choice in your architecture menu. For those that implement DISCONTIGMEM, you may eventually want to make your ARCH_DISCONTIGMEM_ENABLE a "def_bool y" and make your users select DISCONTIGMEM right out of the new choice menu. The only disadvantage might be if you have some specific things that you need in your help option to explain something about DISCONTIGMEM. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] ISA DMA Kconfig fixes - part 1Al Viro
A bunch of drivers use ISA DMA helpers or their equivalents for platforms that have ISA with different DMA controller (a lot of ARM boxen). Currently there is no way to put such dependency in Kconfig - CONFIG_ISA is not it (e.g. it is not set on platforms that have no ISA slots, but have on-board devices that pretend to be ISA ones). New symbol added - ISA_DMA_API. Set when we have functional enable_dma()/set_dma_mode()/etc. set of helpers. Next patches in the series will add missing dependencies for drivers that need them. I'm very carefully staying the hell out of the recurring flamefest on what exactly CONFIG_ISA would mean in ideal world - added symbol has a well-defined meaning and for now I really want to treat it as completely independent from the mess around CONFIG_ISA. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
