The introduction of the uapi directories in v3.7-rc1 moved some of the
generated headers from arch/*/include/generated to the uapi directory,
keeping the #include directives intact.
This creates a problem when bisecting, because the unversioned files are
not cleaned automatically by git and the compiler might include stale
headers as a result. Instead of cleaning them in the Makefiles, promote
arch/*/include/generated/uapi in the search path. Under normal
circumstances, there is no overlap between this uapi subdirectory and
its parent, so the include choices remain the same. We keep
arch/*/include/generated/uapi in the USERINCLUDE variable so that it is
usable standalone.
Note that we cannot completely swap the order of the uapi and
kernel-only directories, since the headers in include/uapi/asm-generic
are meant to be wrapped by their include/asm-generic counterparts when
building kernel code.
Reported-by: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
Reported-by: David Drysdale <dmd@lurklurk.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild updates from Michal Marek:
"Here are the kbuild changes for v3.19-rc1:
- Cleanups and deduplication in the main Makefile and
scripts/Makefile.*
- Sort the output of *config targets in make help
- Old <linux/version.h> is always removed to avoid a surprise during
bisecting
- Warning fix in kconfig"
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: remove redundant -rR flag of hdr-inst
kbuild: Fix make help-<board series> on powerpc
kbuild: Automatically remove stale <linux/version.h> file
kconfig: Fix warning "‘jump’ may be used uninitialized"
Makefile: sort list of defconfig targets in make help output
kbuild: Remove duplicate $(cmd) definition in Makefile.clean
kbuild: collect shorthands into scripts/Kbuild.include
make ARCH=powerpc help-<board series> should not require a cofigured
source tree. Also, sort the boards in the output.
In 3.7, the file moved from include/linux/ to
include/generated/uapi/linux/. The path in the #include directive
remained the same for compatibility reasons, but this created a problem
when bisecting. Commit 9c8cdb71 (kbuild: unconditionally clobber
include/linux/version.h on distclean) fixes this, provided the user does
make distclean between builds. Better not rely on the user and delete
the stale file each time make is invoked.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Without sorting this list is completely unreadable for ARCH=arm.
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
The shorthand "clean" is defined in both the top Makefile and
scripts/Makefile.clean. Likewise, the "hdr-inst" is defined in
both the top Makefile and scripts/Makefile.headersinst.
To reduce code duplication, this commit collects them into
scripts/Kbuild.include like the "build" and "modbuiltin" shorthands.
It requires scripts/Makefile.clean to include scripts/Kbuild.include,
but its impact on the performance of "make clean" should be
negligible.
Sasha Levin reports:
"gcc5 changes the default standard to c11, which makes kernel build
unhappy
Explicitly define the kernel standard to be gnu89 which should keep
everything working exactly like it was before gcc5"
There are multiple small issues with the new default, but the biggest
issue seems to be that the old - and very useful - GNU extension to
allow a cast in front of an initializer has gone away.
Patch updated by Kirill:
"I'm pretty sure all gcc versions you can build kernel with supports
-std=gnu89. cc-option is redunrant.
We also need to adjust HOSTCFLAGS otherwise allmodconfig fails for me"
Note by Andrew Pinski:
"Yes it was reported and both problems relating to this extension has
been added to gnu99 and gnu11. Though there are other issues with the
kernel dealing with extern inline have different semantics between
gnu89 and gnu99/11"
End result: we may be able to move up to a newer stdc model eventually,
but right now the newer models have some annoying deficiencies, so the
traditional "gnu89" model ends up being the preferred one.
Singed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Pull kbuild changes from Michal Marek:
- fix for handling dependencies of *-objs targets by Masahiro Yamada
- lots of cleanups in the kbuild machinery, also by Masahiro
- fixes for the kconfig build to use an UTF-8 capable ncurses library
if possible and to build on not-so-standard installs
- some more minor fixes
kbuild: Do not reference *-n variables in the Makefile
kbuild: simplify build, clean, modbuiltin shorthands
kbuild: arm: Do not define "comma" twice
kbuild: remove obj-n and lib-n handling
kbuild: remove unnecessary variable initializaions
kbuild: remove unnecessary "obj- := dummy.o" trick
kbuild: handle C=... and M=... after entering into build directory
kbuild: use $(Q) for sub-make target
kbuild: fake the "Entering directory ..." message more simply
kconfig/lxdialog: get ncurses CFLAGS with pkg-config
kconfig: nconfig: fix multi-byte UTF handling
kconfig: lxdialog: fix spelling
kbuild: Make scripts executable
kbuild: remove redundant clean-files from scripts/kconfig/Makefile
kbuild: refactor script/kconfig/Makefile
kbuild: handle the dependency of multi-objs hostprogs appropriately
kbuild: handle multi-objs dependency appropriately
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc
Pull documentation updates from Jiri Kosina:
"Updates to kernel documentation.
I took this over (hopefully temporarily) from Randy who was not
willing to maintain it any longer. This pile mostly is a relay of
queue that Randy already had in his tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc:
Documentation: fix broken v4l-utils URL
Documentation: update include path for mpssd
Documentation: correct parameter error for dma_mapping_error
MAINTAINERS: update location of linux-doc tree
Documentation: remove networking/.gitignore
tools: add more endian.h macros
Make Documenation depend on headers_install
Docs: this_cpu_ops: remove redundant add forms
Documentation: disable vdso_test to avoid breakage with old glibc
Documentation: update vDSO makefile to build portable examples
Documentation: update .gitignore files
Documentation: support glibc versions without htole macros
v4l2-pci-skeleton: Only build if PCI is available
Documentation: fix misc. warnings
Documentation: make functions static to avoid prototype warnings
Documentation: add makefiles for more targets
Documentation: use subdir-y to avoid unnecessary built-in.o files
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"Nothing major: support for compressing modules, and auto-tainting
params.
PS. My virtio-next tree is empty: DaveM took the patches I had. There
might be a virtio-rng starvation fix, but so far it's a bit voodoo
so I will get to that in the next two days or it will wait"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
moduleparam: Resolve missing-field-initializer warning
kbuild: handle module compression while running 'make modules_install'.
modinst: wrap long lines in order to enhance cmd_modules_install
modsign: lookup lines ending in .ko in .mod files
modpost: simplify file name generation of *.mod.c files
modpost: reduce visibility of symbols and constify r/o arrays
param: check for tainting before calling set op.
drm/i915: taint the kernel if unsafe module parameters are set
module: add module_param_unsafe and module_param_named_unsafe
module: make it possible to have unsafe, tainting module params
module: rename KERNEL_PARAM_FL_NOARG to avoid confusion
Kconfig options are either 'y', 'm', or undefined.
$(if $(KBUILD_SRC),$(srctree)/) was a useful strategy
to omit a long absolute path for in-source-tree build
prior to commit 890676c65d699db3ad82e7dddd0cf8fb449031af
(kbuild: Use relative path when building in the source tree).
Now $(srctree) is "." when building in the source tree.
It would not be annoying to add "$(srctree)/" all the time.
This commit avoids processing C=... and M=... twice
when O=... is also given.
Besides, we can also remove KBUILD_EXTMOD="$(KBUILD_EXTMOD)"
in the sub-make target.
Acked-by: Peter Foley <pefoley2@pefoley.com>
Since commit 066b7ed9558087a7957a1128f27d7a3462ff117f
(kbuild: Do not print the build directory with make -s),
"Q" is defined above the sub-make target.
This commit takes advantage of that and replaces
"$(if $(KBUILD_VERBOSE:1=),@)" with "$(Q)".
Commit c2e28dc975ea87feed84415006ae143424912ac7
(kbuild: Print the name of the build directory)
added a gimmick to show the "Entering directory ...".
Instead of echoing the hard-coded message (that is, we need to know
the exact message), moving --no-print-directory would be easier.
Cc: rdunlap@infradead.org
Cc: linux-doc@vger.kernel.org
Cc: sudeep.dutt@intel.com
Cc: nikhil.rao@intel.com
Cc: ashutosh.dixit@intel.com
Cc: akpm@linux-foundation.org
Cc: gregkh@linuxfoundation.org
Signed-off-by: Peter Foley <pefoley2@pefoley.com>
Since module-init-tools (gzip) and kmod (gzip and xz) support compressed
modules, it could be useful to include a support for compressing modules
right after having them installed. Doing this in kbuild instead of per
distro can permit to make this kind of usage more generic.
This patch add a Kconfig entry to "Enable loadable module support" menu
and let you choose to compress using gzip (default) or xz.
Both gzip and xz does not used any extra -[1-9] option since Andi Kleen
and Rusty Russell prove no gain is made using them. gzip is called with -n
argument to avoid storing original filename inside compressed file, that
way we can save some more bytes.
On a v3.16 kernel, 'make allmodconfig' generated 4680 modules for a
total of 378MB (no strip, no sign, no compress), the following table
shows observed disk space gain based on the allmodconfig .config :
| time |
| manual .ko | make | size | percent
| compression | modules_install | | gain
- | | 18.61s | 378M |
GZIP | 3m16s | 3m37s | 102M | 73.41%
XZ | 5m22s | 5m39s | 77M | 79.83%
The gain for restricted environnement seems to be interesting while
uncompress can be time consuming but happens only while loading a module,
that is generally done only once.
This is fully compatible with signed modules while the signed module is
compressed. module-init-tools or kmod handles decompression
and provide to other layer the uncompressed but signed payload.
Reviewed-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Bertrand Jacquin <beber@meleeweb.net>
Pull misc kbuild updates from Michal Marek:
"This is the non-critical part of kbuild for 3.17-rc1:
- make help hint to use make -s with make kernelrelease et al.
- moved a kbuild document to Documentation/kbuild where it belongs
- four new Coccinelle scripts, one dropped and one fixed
- new make kselftest target to run various tests on the kernel"
* 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: kselftest - new make target to build and run kernel selftests
Coccinelle: Script to replace if and BUG with BUG_ON
Coccinelle: Script to detect incorrect argument to sizeof
Coccinelle: Script to use ARRAY_SIZE instead of division of two sizeofs
Coccinelle: Script to detect cast after memory allocation
coccinelle/null: solve parse error
Documentation: headers_install.txt is part of kbuild
kbuild: make -s should be used with kernelrelease/kernelversion/image_name
- make clean also considers $(extra-m) and $(extra-) to be consistent
- cleanup and fixes in scripts/Makefile.host
- allow to override the name of the Python 2 executable with make
PYTHON=... (only needed for ia64 in practice)
- option to split debugingo into *.dwo files to save disk space if the
compiler supports it (CONFIG_DEBUG_INFO_SPLIT)
- option to use dwarf4 debuginfo if the compiler supports it
(CONFIG_DEBUG_INFO_DWARF4)
- fix for disabling certain warnings with clang
- fix for unneeded rebuild with dash when a command contains
backslashes
kbuild: Fix handling of backslashes in *.cmd files
kbuild, LLVMLinux: Supress warnings unless W=1-3
Kbuild: Add a option to enable dwarf4 v2
kbuild: Support split debug info v4
kbuild: allow to override Python command name
kbuild: clean-up and bug fix of scripts/Makefile.host
kbuild: clean up scripts/Makefile.host
kbuild: drop shared library support from Makefile.host
kbuild: fix a bug of C++ host program handling
kbuild: fix a typo in scripts/Makefile.host
scripts/Makefile.clean: clean also $(extra-m) and $(extra-)
Add a new make target "kselftest" to enable kernel testing. This
new target builds and runs kernel selftests. Running as root is
recommended for a complete test run as some tests don't run when
run by non-root user. Build, install, and boot kernel before
running kselftest on it.
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
