path: root/Makefile
2013-02-27Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: - Alias generation in modpost is cross-compile safe. - kernel/timeconst.h is now generated using a bc script instead of perl. - scripts/link-vmlinux.sh now works with an alternative $KCONFIG_CONFIG. - destination-y for exported headers is supported in Kbuild files again. - depmod is called with -P $CONFIG_SYMBOL_PREFIX on architectures that need it. - CONFIG_DEBUG_INFO_REDUCED disables var-tracking - scripts/setlocalversion works with too much translated locales ;) * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Fix reading of .config in link-vmlinux.sh kbuild: Unset language specific variables in setlocalversion script Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCED depmod: pass -P $CONFIG_SYMBOL_PREFIX kbuild: Fix destination-y for installed headers scripts/link-vmlinux.sh: source variables from KCONFIG_CONFIG kernel: Replace timeconst.pl with a bc script mod/file2alias: make modalias generation safe for cross compiling
2013-02-25Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "The sweeping change is to make add_taint() explicitly indicate whether to disable lockdep, but it's a mechanical change." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Add option to not sign modules during modules_install MODSIGN: Add -s <signature> option to sign-file MODSIGN: Specify the hash algorithm on sign-file command line MODSIGN: Simplify Makefile with a Kconfig helper module: clean up load_module a little more. modpost: Ignore ARC specific non-alloc sections module: constify within_module_* taint: add explicit flag to show whether lock dep is still OK. module: printk message when module signature fail taints kernel.
2013-02-22Kbuild: Disable var tracking with CONFIG_DEBUG_INFO_REDUCEDAndi Kleen
Newer gcc enables the var-tracking pass with -g to keep track which registers contain which variables. This is one of the slower passes in gcc. With reduced debug info (aimed at objdump -S, but not using a full debugger) we don't need this fine grained tracking. But it was still enabled because -g was enabled. Disable it explicitely for DEBUG_INFO_REDUCED. On my 8T workstation this gives me about a 12 second gain in building a reasonable kernel config (2min16 vs 2min28) with DEBUG_INFO_REDUCED. With full DEBUG_INFO it takes 2min46 The actual improvement in user time taken by the compiler is much higher (all CPU combined user time 15min5s vs 16m30 before) but the usual amdahl bottleneck on the linker prevents more speedup. It still saves some more energy and keeps cycles for other things. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22depmod: pass -P $CONFIG_SYMBOL_PREFIXJames Hogan
On architectures which have symbol prefixes, depmod emits lots of warnings like this: WARNING: $module.ko needs unknown symbol $symbol This is because depmod isn't being passed the -P <symbol_prefix> arguments to specify the symbol prefix to ignore. This option is included since the 3.13 release of module-init-tools. Update scripts/depmod.sh to take extra arguments for the symbol prefix (required but may be empty), and update the main Makefile to always pass "$(CONFIG_SYMBOL_PREFIX)" to scripts/depmod.sh. If the provided symbol prefix is non-empty, scripts/depmod.sh checks if depmod --version reports module-init-tools with a version number < 3.13 otherwise it appends -P $SYMBOL_PREFIX to the depmod command line. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Michal Marek <mmarek@suse.cz> Cc: linux-kbuild@vger.kernel.org Cc: Mike Frysinger <vapier@gentoo.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: uclinux-dist-devel@blackfin.uclinux.org Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-19Merge branch 'x86-build-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull two x86 kernel build changes from Ingo Molnar: "The first change modifies how 'make oldconfig' works on cross-bitness situations on x86. It was felt the new behavior of preserving the bitness of the .config is more logical. This is a leftover of the merge. The second change eliminates a Perl warning. (There's another, more complete fix resulting of this warning fix, which second fix in flight to you via the kbuild tree, which will remove the timeconst.pl script altogether.)" * 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timeconst.pl: Eliminate Perl warning x86: Default to ARCH=x86 to avoid overriding CONFIG_64BIT
2013-02-18Linux 3.8v3.8Linus Torvalds
2013-02-09Linux 3.8-rc7v3.8-rc7Linus Torvalds
2013-02-01Linux 3.8-rc6v3.8-rc6Linus Torvalds
2013-01-25Linux 3.8-rc5v3.8-rc5Linus Torvalds
2013-01-25MODSIGN: Add option to not sign modules during modules_installMichal Marek
To allow the builder to sign only a subset of modules, or to sign the modules using a key that is not available on the build machine, add CONFIG_MODULE_SIG_ALL. If this option is unset, no modules will be signed during build. The default is 'y', to preserve the current behavior. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-25MODSIGN: Specify the hash algorithm on sign-file command lineMichal Marek
Make the script usable without a .config file. Signed-off-by: Michal Marek <mmarek@suse.cz> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-24mod/file2alias: make modalias generation safe for cross compilingAndreas Schwab
Use the target compiler to compute the offsets for the fields of the device_id structures, so that it won't be broken by different alignments between the host and target ABIs. This also fixes missing endian corrections for some modaliases. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-01-22arm64: makefile: fix uname munging when setting ARCH on native machineWill Deacon
By popular demand, arch/aarch64 is now known as arch/arm64. However, uname -m (and indeed the GNU triplet) still use aarch64 as the machine string. This patch fixes native builds of both the kernel and perf tools by updating the relevant Makefiles to munge the output of uname -m and set the ARCH variable appropriately. Cc: <stable@vger.kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-01-17Linux 3.8-rc4v3.8-rc4Linus Torvalds
2013-01-09Linux 3.8-rc3v3.8-rc3Linus Torvalds
2013-01-02Linux 3.8-rc2v3.8-rc2Linus Torvalds
2012-12-21Linux 3.8-rc1v3.8-rc1Linus Torvalds
2012-12-20x86: Default to ARCH=x86 to avoid overriding CONFIG_64BITDavid Woodhouse
It is easy to waste a bunch of time when one takes a 32-bit .config from a test machine and try to build it on a faster 64-bit system, and its existing setting of CONFIG_64BIT=n gets *changed* to match the build host. Similarly, if one has an existing build tree it is easy to trash an entire build tree that way. This is because the default setting for $ARCH when discovered from 'uname' is one of the legacy pre-x86-merge values (i386 or x86_64), which effectively force the setting of CONFIG_64BIT to match. We should default to ARCH=x86 instead, finally completing the merge that we started so long ago. This patch preserves the behaviour of the legacy ARCH settings for commands such as: make ARCH=x86_64 randconfig make ARCH=i386 randconfig ... since making the value of CONFIG_64BIT actually random in that situation is not desirable. In time, perhaps we can retire this legacy use of the old ARCH= values. We already have a way to override values for *any* config option, using $KCONFIG_ALLCONFIG, so it could be argued that we don't necessarily need to keep ARCH={i386,x86_64} around as a special case just for overriding CONFIG_64BIT. We'd probably at least want to add a way to override config options from the command line ('make CONFIG_FOO=y oldconfig') before we talk about doing that though. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Link: http://lkml.kernel.org/r/1356040315.3198.51.camel@shinybook.infradead.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-12-20Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The kbuild changes are minimal this time: - scripts/pnmlogo fix for some newer format - minor top-level Makefile cleanup - fix for a v3.5 regression with make clean M=<directory>" * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kbuild: Do not remove vmlinux when cleaning external module scripts/pnmtologo: fix for plain PBM kbuild: Remove reference to uninitialised variable
2012-12-19Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "Nothing all that exciting; a new module-from-fd syscall for those who want to verify the source of the module (ChromeOS) and/or use standard IMA on it or other security hooks." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Fix kbuild output when using default extra_certificates MODSIGN: Avoid using .incbin in C source modules: don't hand 0 to vmalloc. module: Remove a extra null character at the top of module->strtab. ASN.1: Use the ASN1_LONG_TAG and ASN1_INDEFINITE_LENGTH constants ASN.1: Define indefinite length marker constant moduleparam: use __UNIQUE_ID() __UNIQUE_ID() MODSIGN: Add modules_sign make target powerpc: add finit_module syscall. ima: support new kernel module syscall add finit_module syscall to asm-generic ARM: add finit_module syscall to ARM security: introduce kernel_module_from_file hook module: add flags arg to sys_finit_module() module: add syscall to load module from fd
2012-12-14MODSIGN: Add modules_sign make targetJosh Boyer
If CONFIG_MODULE_SIG is set, and 'make modules_sign' is called then this patch will cause the modules to get a signature appended. The make target is intended to be run after 'make modules_install', and will modify the modules in-place in the installed location. It can be used to produce signed modules after they have been processed by distribution build scripts. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (minor typo fix)
2012-12-10Linux 3.7v3.7Linus Torvalds
2012-12-09kbuild: Do not remove vmlinux when cleaning external modulePawel Moll
Since commit 1f2bfbd00e466ff3489b2ca5cc75b1cccd14c123 "kbuild: link of vmlinux moved to a script" make clean with M=<dir> argument (so cleaning external module) removes vmlinux, System.map and couple of other files from the *main* kernel build directory! This not what was happening before and almost certainly not what one would expect. This patch moves makes the clean target of the script called only when !KBUILD_EXTMOD. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Cc: stable@vger.kernel.org [v3.5+] Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-12-03Linux 3.7-rc8v3.7-rc8Linus Torvalds
2012-12-01Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "This is mostly about unbreaking architectures that took the UAPI changes in the v3.7 cycle, plus misc fixes." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf kvm: Fix building perf kvm on non x86 arches perf kvm: Rename perf_kvm to perf_kvm_stat perf: Make perf build for x86 with UAPI disintegration applied perf powerpc: Use uapi/unistd.h to fix build error tools: Pass the target in descend tools: Honour the O= flag when tool build called from a higher Makefile tools: Define a Makefile function to do subdir processing x86: Export asm/{svm.h,vmx.h,perf_regs.h} perf tools: Fix strbuf_addf() when the buffer needs to grow perf header: Fix numa topology printing perf, powerpc: Fix hw breakpoints returning -ENOSPC
2012-11-25Linux 3.7-rc7v3.7-rc7Linus Torvalds
2012-11-20kbuild: Remove reference to uninitialised variableCharles Keepax
Verbose output variable is unnecessary because the command's echo is already surpressed. Additionally because the block defines skip-makefile the variable Q is not defined within the makefile, which can cause problems if Q is defined in the users environment. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-11-19tools: Honour the O= flag when tool build called from a higher MakefileDavid Howells
Honour the O= flag that was passed to a higher level Makefile and then passed down as part of a tool build. To make this work, the top-level Makefile passes the original O= flag and subdir=tools to the tools/Makefile, and that in turn passes subdir=$(O)/$(subdir)/foodir when building tool foo in directory $(O)/$(subdir)/foodir (where the intervening slashes aren't added if an element is missing). For example, take perf. This is found in tools/perf/. Assume we're building into directory ~/zebra/, so we pass O=~/zebra to make. Dependening on where we run the build from, we see: make run in dir $(OUTPUT) dir ======================= ================== linux ~/zebra/tools/perf/ linux/tools ~/zebra/perf/ linux/tools/perf ~/zebra/ and if O= is not set, we get: make run in dir $(OUTPUT) dir ======================= ================== linux linux/tools/perf/ linux/tools linux/tools/perf/ linux/tools/perf linux/tools/perf/ The output directories are created by the descend function if they don't already exist. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Borislav Petkov <bp@amd64.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1378.1352379110@warthog.procyon.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-11-16Linux 3.7-rc6v3.7-rc6Linus Torvalds
2012-11-11Linux 3.7-rc5v3.7-rc5Linus Torvalds
2012-11-04Linux 3.7-rc4v3.7-rc4Linus Torvalds
2012-10-28Linux 3.7-rc3v3.7-rc3Linus Torvalds
2012-10-20Linux 3.7-rc2v3.7-rc2Linus Torvalds
2012-10-19MODSIGN: perlify sign-file and merge in x509keyidDavid Howells
Turn sign-file into perl and merge in x509keyid. The latter doesn't need to be a separate script as it doesn't actually need to work out the SHA1 sum of the X.509 certificate itself, since it can get that from the X.509 certificate. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-19kbuild: sign the modules at install timeRusty Russell
Linus deleted the old code and put signing on the install command, I fixed it to extract the keyid and signer-name within sign-file and cleaned up that script now it always signs in-place. Some enthusiast should convert sign-key to perl and pull x509keyid into it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-17uapi: Allow automatic generation of uapi/asm/ header filesCatalin Marinas
Several arch/*/include/uapi/asm/* header simply include the corresponding <asm-generic/*> file. This patch allows such files to be specified in uapi/asm/Kbuild via "generic-y += ..." to be automatically generated (similar to asm/Kbuild). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de>
2012-10-14Linux 3.7-rc1v3.7-rc1Linus Torvalds
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-12Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kbuild changes from Michal Marek: "The main part of kbuild for v3.7 contains: - Fix for scripts/Makefile.modpost to not choke on a '.ko' substring in the build directory path - Two warning fixes (modpost and main Makefile) - __compiletime_error works also with gcc 4.3 - make tar{gz,bz2,xz}-pkg uses default compression settings instead of saving as many bytes as possible (this should actually be in the misc branch, I don't know why I applied it here)." * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: compiler-gcc4.h: correct verion check for __compiletime_error modpost: Permit .GCC.command.line sections Kbuild: use normal compression settings for tar*-pkg scripts/Makefile.modpost: error in finding modules from .mod files. kbuild: Remove useless warning while appending KCFLAGS
2012-10-10MODSIGN: Make mrproper should remove generated files.Rusty Russell
It doesn't, because the clean targets don't include kernel/Makefile, and because two files were missing from the list. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-10MODSIGN: Provide gitignore and make clean rules for extra filesDavid Howells
Provide gitignore and make clean rules for extra files to hide and clean up the extra files produced by module signing stuff once it is added. Also add a clean up rule for the module content extractor program used to extract the data to be signed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-10-02UAPI: Plumb the UAPI Kbuilds into the user header installation and checkingDavid Howells
Plumb the UAPI Kbuilds into the user header installation and checking system. As the headers are split the entries will be transferred across from the old Kbuild files to the UAPI Kbuild files. The changes made in this commit are: (1) Exported generated files (of which there are currently four) are moved to uapi/ directories under the appropriate generated/ directory, thus we get: include/generated/uapi/linux/version.h arch/x86/include/generated/uapi/asm/unistd_32.h arch/x86/include/generated/uapi/asm/unistd_64.h arch/x86/include/generated/uapi/asm/unistd_x32.h These paths were added to the build as -I flags in a previous patch. (2) scripts/Makefile.headersinst is now given the UAPI path to install from rather than the old path. It then determines the old path from that and includes that Kbuild also if it exists, thus permitting the headers to exist in either directory during the changeover. I also renamed the "install" variable to "installdir" as it refers to a directory not the install program. (3) scripts/headers_install.pl is altered to take a list of source file paths instead of just their names so that the makefile can tell it exactly where to find each file. For the moment, files can be obtained from one of four places for each output directory: .../include/uapi/foo/ .../include/generated/uapi/foo/ .../include/foo/ .../include/generated/foo/ The non-UAPI paths will be dropped later. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: Move linux/version.hDavid Howells
Move include/linux/version.h to the include/generated/ header directory. A later patch will move it to include/uapi/generated/. This allows us to get rid of the objhdr-y list. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-02UAPI: Partition the header include path sets and add uapi/ header directoriesDavid Howells
Partition the header include path flags into two sets, one for kernelspace builds and one for userspace builds. Add the following directories to build after the ordinary include directories so that #include will pick up the UAPI header directly if the kernel header has been moved there. The userspace set (represented by the USERINCLUDE make variable) contains: -I $(srctree)/arch/$(hdr-arch)/include/uapi -I arch/$(hdr-arch)/include/generated/uapi -I $(srctree)/include/uapi -I include/generated/uapi -include $(srctree)/include/linux/kconfig.h and the kernelspace set (represented by the LINUXINCLUDE make variable) contains: -I $(srctree)/arch/$(hdr-arch)/include -I arch/$(hdr-arch)/include/generated -I $(srctree)/include -I include --- if not building in the source tree plus everything in the USERINCLUDE set. Then use USERINCLUDE in building the x86 boot code. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-10-01Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf update from Ingo Molnar: "Lots of changes in this cycle as well, with hundreds of commits from over 30 contributors. Most of the activity was on the tooling side. Higher level changes: - New 'perf kvm' analysis tool, from Xiao Guangrong. - New 'perf trace' system-wide tracing tool - uprobes fixes + cleanups from Oleg Nesterov. - Lots of patches to make perf build on Android out of box, from Irina Tirdea - Extend ftrace function tracing utility to be more dynamic for its users. It allows for data passing to the callback functions, as well as reading regs as if a breakpoint were to trigger at function entry. The main goal of this patch series was to allow kprobes to use ftrace as an optimized probe point when a probe is placed on an ftrace nop. With lots of help from Masami Hiramatsu, and going through lots of iterations, we finally came up with a good solution. - Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng. - Various tracing updates from Steve Rostedt - Clean up and improve 'perf sched' performance by elliminating lots of needless calls to libtraceevent. - Event group parsing support, from Jiri Olsa - UI/gtk refactorings and improvements from Namhyung Kim - Add support for non-tracepoint events in perf script python, from Feng Tang - Add --symbols to 'script', similar to the one in 'report', from Feng Tang. Infrastructure enhancements and fixes: - Convert the trace builtins to use the growing evsel/evlist tracepoint infrastructure, removing several open coded constructs like switch like series of strcmp to dispatch events, etc. Basically what had already been showcased in 'perf sched'. - Add evsel constructor for tracepoints, that uses libtraceevent just to parse the /format events file, use it in a new 'perf test' to make sure the libtraceevent format parsing regressions can be more readily caught. - Some strange errors were happening in some builds, but not on the next, reported by several people, problem was some parser related files, generated during the build, didn't had proper make deps, fix from Eric Sandeen. - Introduce struct and cache information about the environment where a perf.data file was captured, from Namhyung Kim. - Fix handling of unresolved samples when --symbols is used in 'report', from Feng Tang. - Add union member access support to 'probe', from Hyeoncheol Lee. - Fixups to die() removal, from Namhyung Kim. - Render fixes for the TUI, from Namhyung Kim. - Don't enable annotation in non symbolic view, from Namhyung Kim. - Fix pipe mode in 'report', from Namhyung Kim. - Move related stats code from stat to util/, will be used by the 'stat' kvm tool, from Xiao Guangrong. - Remove die()/exit() calls from several tools. - Resolve vdso callchains, from Jiri Olsa - Don't pass const char pointers to basename, so that we can unconditionally use libgen.h and thus avoid ifdef BIONIC lines, from David Ahern - Refactor hist formatting so that it can be reused with the GTK browser, From Namhyung Kim - Fix build for another rbtree.c change, from Adrian Hunter. - Make 'perf diff' command work with evsel hists, from Jiri Olsa. - Use the only field_sep var that is set up: symbol_conf.field_sep, fix from Jiri Olsa. - .gitignore compiled python binaries, from Namhyung Kim. - Get rid of die() in more libtraceevent places, from Namhyung Kim. - Rename libtraceevent 'private' struct member to 'priv' so that it works in C++, from Steven Rostedt - Remove lots of exit()/die() calls from tools so that the main perf exit routine can take place, from David Ahern - Fix x86 build on x86-64, from David Ahern. - {int,str,rb}list fixes from Suzuki K Poulose - perf.data header fixes from Namhyung Kim - Allow user to indicate objdump path, needed in cross environments, from Maciek Borzecki - Fix hardware cache event name generation, fix from Jiri Olsa - Add round trip test for sw, hw and cache event names, catching the problem Jiri fixed, after Jiri's patch, the test passes successfully. - Clean target should do clean for lib/traceevent too, fix from David Ahern - Check the right variable for allocation failure, fix from Namhyung Kim - Set up evsel->tp_format regardless of evsel->name being set already, fix from Namhyung Kim - Oprofile fixes from Robert Richter. - Remove perf_event_attr needless version inflation, from Jiri Olsa - Introduce libtraceevent strerror like error reporting facility, from Namhyung Kim - Add pmu mappings to perf.data header and use event names from cmd line, from Robert Richter - Fix include order for bison/flex-generated C files, from Ben Hutchings - Build fixes and documentation corrections from David Ahern - Assorted cleanups from Robert Richter - Let O= makes handle relative paths, from Steven Rostedt - perf script python fixes, from Feng Tang. - Initial bash completion support, from Frederic Weisbecker - Allow building without libelf, from Namhyung Kim. - Support DWARF CFI based unwind to have callchains when %bp based unwinding is not possible, from Jiri Olsa. - Symbol resolution fixes, while fixing support PPC64 files with an .opt ELF section was the end goal, several fixes for code that handles all architectures and cleanups are included, from Cody Schafer. - Assorted fixes for Documentation and build in 32 bit, from Robert Richter - Cache the libtraceevent event_format associated to each evsel early, so that we avoid relookups, i.e. calling pevent_find_event repeatedly when processing tracepoint events. [ This is to reduce the surface contact with libtraceevents and make clear what is that the perf tools needs from that lib: so far parsing the common and per event fields. ] - Don't stop the build if the audit libraries are not installed, fix from Namhyung Kim. - Fix bfd.h/libbfd detection with recent binutils, from Markus Trippelsdorf. - Improve warning message when libunwind devel packages not present, from Jiri Olsa" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits) perf trace: Add aliases for some syscalls perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables perf tools: Check libaudit availability for perf-trace builtin perf hists: Add missing period_* fields when collapsing a hist entry perf trace: New tool perf evsel: Export the event_format constructor perf evsel: Introduce rawptr() method perf tools: Use perf_evsel__newtp in the event parser perf evsel: The tracepoint constructor should store sys:name perf evlist: Introduce set_filter() method perf evlist: Renane set_filters method to apply_filters perf test: Add test to check we correctly parse and match syscall open parms perf evsel: Handle endianity in intval method perf evsel: Know if byte swap is needed perf tools: Allow handling a NULL cpu_map as meaning "all cpus" perf evsel: Improve tracepoint constructor setup tools lib traceevent: Fix error path on pevent_parse_event perf test: Fix build failure trace: Move trace event enable from fs_initcall to core_initcall tracing: Add an option for disabling markers ...
2012-09-30Linux 3.6v3.6Linus Torvalds
2012-09-23Linux 3.6-rc7v3.6-rc7Linus Torvalds
2012-09-16Linux 3.6-rc6v3.6-rc6Linus Torvalds
2012-09-13Merge branch 'core/rcu' into perf/coreIngo Molnar
Steve Rostedt asked for the merge of a single commit, into both the RCU and the perf/tracing tree: | Josh made a change to the tracing code that affects both the | work Paul McKenney and I are currently doing. At the last | Kernel Summit back in August, Linus said when such a case | exists, it is best to make a separate branch based off of his | tree and place the change there. This way, the repositories | that need to share the change can both pull them in and the | SHA1 will match for both. Whichever branch is pulled in first | by Linus will also pull in the necessary change for the other | branch as well. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-09-08Linux 3.6-rc5v3.6-rc5Linus Torvalds
