path: root/MAINTAINERS
2007-03-29[PATCH] adaptec MAINTAINERS updatesSalyzyn, Mark
The IPS and DPT_I2O drivers are missing, so here is my 'hand coded' addition to deal with overlap to the patch below (apply both). I selected Maintained rather than supported for the ips and dpt_i2o driver due to their legacy nature. Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-27[PATCH] I2O: remove Markus from MAINTAINERSMarkus Lidel
Because i don't have much time lately and my responses are pretty slow it's probably best to remove me from MAINTAINERS to give someone else the chance to jump in. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-25[SCTP]: Update SCTP Maintainers entrySridhar Samudrala
Add Vlad Yasevich as the primary maintainer of SCTP and add a link to the project website. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-20Pull misc-for-upstream into release branchLen Brown
2007-03-16[PATCH] tpm_infineon: maintainerMarcel Selhorst
Signed-off-by: Marcel Selhorst <tpm@selhorst.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-13sony-laptop: MAINTAINERS fix entry, add L: and W:Mattia Dongili
Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-03-09Remove devfs from MAINTAINERSJörn Engel
Remove last remaining trace of devfs. Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-05[PATCH] parport is an orphanDavid Brownell
The writing on the wall seem to be that the parport stack is orphaned, rather than maintained by four folk ... and having a webpage that says the latest patches are based on a 2.5 kernel. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid: HID: fix Logitech DiNovo Edge touchwheel and Logic3 /SpectraVideo middle button HID: add git tree information to MAINTAINERS HID: fix broken Logitech S510 keyboard report descriptor; make extra keys work HID: fix possible double-free on error path in hid parser HID: hid-debug.c should #include <linux/hid-debug.h> HID: fix bug in zeroing the last field byte in output reports USB HID: use CONFIG_HID_DEBUG for outputting report descriptor USB HID: Fix USB vendor and product IDs endianness for USB HID devices
2007-03-01[PATCH] MAINTAINERS: Update email addressAntonino A. Daplas
adaplas@pol.net is still alive, but is choking on the traffic. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01HID: add git tree information to MAINTAINERSJiri Kosina
Update MAITAINERS entry for HID and USB HID, adding location of HID git tree. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-02-27Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (52 commits) netxen: do_rom_fast_write error handling natsemi: Fix detection of vanilla natsemi cards net: remove a collection of unneeded #undef REALLY_SLOW_IO stuff chelsio: Fix non-NAPI compile cxgb3 - Feed Rx free list with pages cxgb3 - Recovery from HW starvation of response queue entries. cxgb3 - Unmap offload packets when they are freed cxgb3 - FW version update cxgb3 - private ioctl cleanup cxgb3 - manage sysfs attributes per port S2IO: Restoring the mac address in s2io_reset S2IO: Avoid printing the Enhanced statistics for Xframe I card. S2IO: Making LED off during LINK_DOWN notification. S2IO: Added a loadable parameter to enable or disable vlan stripping in frame. S2IO: Optimized the delay to wait for command completion S2IO: Fixes for MSI and MSIX qla3xxx: Bumping driver version number qla3xxx: Kernic Panic on pSeries under stress conditions qla3xxx: bugfix tx reset after stress conditions. qla3xxx: Check return code from pci_map_single() in ql_release_to_lrg_buf_free_list(), ql_populate_free_queue(), ql_alloc_large_buffers(), and ql3xxx_send() ...
2007-02-27remove the jffs MAINTAINERS entryAdrian Bunk
This patch removes the MAINTAINERS entry for the removed jffs filesystem. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-27spidernet: maintainershipLinas Vepstas
Update driver support contact info. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Jens Osterkamp <Jens.Osterkamp@de.ibm.com> Cc: Kou Ishizaki <kou.ishizaki@toshiba.co.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-26[PATCH] add MAINTAINERS entry for high-res timers, clockevents, dynticksIngo Molnar
Thomas is the maintainer and primary author of the high-res timers, clockevents and dynticks code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-23USB: Davicom DM9601 usbnet driverPeter Korsgaard
This patch adds a driver for the Davicom DM9601 USB 1.1 10/100Mbps ethernet adaptor using the usbnet framework. See http://www.davicom.com.tw/eng/products/dm9601.htm for details. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-21V4L/DVB: MAINTAINERS: tag pvrusb2 list as subscribers-onlyMike Isely
Posting to the pvrusb2 mailing list is for subscribers only. Anyone can subscribe of course. This is done purely to keep spammers and similar pond scum from bothering the subscribers of the list. This patch marks the pvrusb2 list tag in MAINTAINERS to reflect this situation. Signed-off-by: Mike Isely <isely@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-20[PATCH] Update OSDL/Linux-Foundation maintainer addressesSimon Horman
The patch below updates MAINTAIER address Individuals (Only Andrew :): osdl.org -> linux-foundation.org Lists: osdl.org -> lists.osdl.org I assume the latter will change at some stage, but at least with this change the osdl/linux-foundation lists are consistent. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20backlight: Add maintainer entryRichard Purdie
Add myself as the backlight class/subsystem maintainer. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-19Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon/vt1211: Add probing of alternate config index port hwmon/f71805f: Fix a race condition hwmon/abituguru: Fix unchecked return status hwmon: New driver for the Analog Devices ADM1029 hwmon/w83627ehf: Add support for the W83627DHG chip hwmon: Use subsys_initcall hwmon/lm70: Make lm70_remove a __devexit function hwmon: Cleanup a bogus legacy comment hwmon: Simplify the locking model of two drivers hwmon: Drop unused mutexes in two drivers hwmon/it87: Add PWM base frequency control
2007-02-19Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (51 commits) sk98lin: mark deprecated in Kconfig Hostess SV-11 depends on INET Fix link autonegotiation timer. sk98lin: planned removal B44: increase wait loop b44: replace define e1000: allow ethtool to see link status when down e1000: remove obsolete custom pci_save_state code e1000: fix shared interrupt warning message atm: Use ARRAY_SIZE macro when appropriate bugfixes and new hardware support for arcnet driver pcnet32 NAPI no longer experimental MAINTAINER macb: Remove inappropriate spinlocks around mii calls Convert meth to netdev_priv sky2: v1.13 sky2: receive error handling improvements sky2: transmit timeout sky2: flow control negotiation for Yukon-FE sky2: no need to reset pause bits on shutdown ...
2007-02-17MAINTAINERpcnet32@verizon.net
After being the defacto maintainer for a couple of years, I can now become the official maintainer. Signed-off-by: Don Fry <pcnet32@verizon.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-16Pull sony into release branchLen Brown
2007-02-16Pull misc-for-upstream into release branchLen Brown
Conflicts: drivers/usb/misc/appledisplay.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-14hwmon: New driver for the Analog Devices ADM1029Corentin Labbe
Signed-off-by: Corentin Labbe <corentin.labbe@geomatys.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-14Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (94 commits) [PATCH] x86-64: Remove mk_pte_phys() [PATCH] i386: Fix broken CONFIG_COMPAT_VDSO on i386 [PATCH] i386: fix 32-bit ioctls on x64_32 [PATCH] x86: Unify pcspeaker platform device code between i386/x86-64 [PATCH] i386: Remove extern declaration from mm/discontig.c, put in header. [PATCH] i386: Rename cpu_gdt_descr and remove extern declaration from smpboot.c [PATCH] i386: Move mce_disabled to asm/mce.h [PATCH] i386: paravirt unhandled fallthrough [PATCH] x86_64: Wire up compat epoll_pwait [PATCH] x86: Don't require the vDSO for handling a.out signals [PATCH] i386: Fix Cyrix MediaGX detection [PATCH] i386: Fix warning in cpu initialization [PATCH] i386: Fix warning in microcode.c [PATCH] x86: Enable NMI watchdog for AMD Family 0x10 CPUs [PATCH] x86: Add new CPUID bits for AMD Family 10 CPUs in /proc/cpuinfo [PATCH] i386: Remove fastcall in paravirt.[ch] [PATCH] x86-64: Fix wrong gcc check in bitops.h [PATCH] x86-64: survive having no irq mapping for a vector [PATCH] i386: geode configuration fixes [PATCH] i386: add option to show more code in oops reports ...
2007-02-14[PATCH] SPI: atmel_spi driverHaavard Skinnemoen
Driver for the Atmel on-chip SPI master controller. Tested primarily on AVR32/AT32AP7000/ATSTK1000 using mtd_dataflash and the jffs2 filesystem. Should also work fine on various AT91 ARM-based chips like AT91SAM926x and AT91RM9200. Hardware documentation can be found in the AT32AP7000 data sheet, or its AT91 siblings, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13i2c: PA Semi SMBus driverOlof Johansson
New driver for the PA Semi SMBus interfaces. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13[PATCH] x86-64: list x86_64 quilt treeRandy Dunlap
List x86_64 quilt tree in MAINTAINERS. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andi Kleen <ak@suse.de>
2007-02-13sony-laptop: add to MAINTAINERSMattia Dongili
2007-02-12[PATCH] MAINTAINERS: remove two dead e-mailJiri Slaby
Cyclades no longer serves the 2 e-mails listed in MAINTAINERS. Remove them and mark those entries as Orphaned. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] drivers: add LCD supportMiguel Ojeda Sandonis
Add support for auxiliary displays, the ks0108 LCD controller, the cfag12864b LCD and adds a framebuffer device: cfag12864bfb. - Add a "auxdisplay/" folder in "drivers/" for auxiliary display drivers. - Add support for the ks0108 LCD Controller as a device driver. (uses parport interface) - Add support for the cfag12864b LCD as a device driver. (uses ks0108 LCD Controller driver) - Add a framebuffer device called cfag12864bfb. (uses cfag12864b LCD driver) - Add the usual Documentation, includes, Makefiles, Kconfigs, MAINTAINERS, CREDITS... - Miguel Ojeda will maintain all the stuff above. [rdunlap@xenotime.net: workqueue fixups] [akpm@osdl.org: kconfig fix] Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com> Cc: Greg KH <greg@kroah.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10ACPI: add video driver MAINTAINERLen Brown
2007-02-09Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-tcLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-tc: [EISA] EISA registration with !CONFIG_EISA [TC] pmagb-b-fb: Convert to the driver model [TC] dec_esp: Driver model for the PMAZ-A [TC] mips: pmag-ba-fb: Convert to the driver model [TC] defxx: TURBOchannel support [TC] TURBOchannel support for the DECstation [TC] MIPS: TURBOchannel resources off-by-one fix [TC] MIPS: TURBOchannel update to the driver model
2007-02-09Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: (212 commits) [PATCH] Fix breakage with CONFIG_SYSFS_DEPRECATED [ALSA] version 1.0.14rc2 [ALSA] ASoC documentation updates [ALSA] ca0106 - Add missing sysfs device assignment [ALSA] aoa i2sbus: Stop Apple i2s DMA gracefully [ALSA] hda-codec - Add support for Fujitsu PI1556 Realtek ALC880 [ALSA] aoa: remove suspend/resume printks [ALSA] Fix possible deadlocks in sequencer at removal of ports [ALSA] emu10k1 - Fix STAC9758 front channel [ALSA] soc - Clean up with kmemdup() [ALSA] snd-ak4114: Fix two array overflows [ALSA] ac97_bus power management [ALSA] usbaudio - Add support for Edirol UA-101 [ALSA] hda-codec - Add ALC861VD/ALC660VD support [ALSA] soc - ASoC 0.13 Sharp poodle machine [ALSA] soc - ASoC 0.13 Sharp tosa machine [ALSA] soc - ASoC 0.13 spitz machine [ALSA] soc - ASoC Sharp corgi machine [ALSA] soc - ASoC 0.13 pxa2xx DMA [ALSA] soc - ASoC 0.13 pxa2xx AC97 driver ...
2007-02-09[TC] MIPS: TURBOchannel update to the driver modelMaciej W. Rozycki
This is a set of changes to convert support for the TURBOchannel bus to the driver model. It implements the usual set of calls similar to what other bus drivers have: tc_register_driver(), tc_unregister_driver(), etc. All the platform-specific bits have been removed and headers from asm-mips/dec/ have been merged into linux/tc.h, which should be included by drivers. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-09[ALSA] ASoC: documentation & maintainerLiam Girdwood
This patch adds documentation describing the ASoC architecture and a maintainer entry for ASoC. The documentation includes the following files:- codec.txt: Codec driver internals. DAI.txt: Description of Digital Audio Interface standards and how to configure a DAI within your codec and CPU DAI drivers. dapm.txt: Dynamic Audio Power Management. platform.txt: Platform audio DMA and DAI. machine.txt: Machine driver internals. pop_clicks.txt: How to minimise audio artifacts. clocking.txt: ASoC clocking for best power performance. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-08MAINTAINERS: update DMFE and wireless drivers mailing listRandy Dunlap
List netdev as the mailing list for DMFE (network driver) instead of lkml. List linux-wireless as the mailing list for wireless network drivers. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (116 commits) sk98lin: planned removal AT91: MACB support sky2: version 1.12 sky2: add new chip ids sky2: Yukon Extreme support sky2: safer transmit timeout sky2: TSO support for EC_U sky2: use dev_err for error reports sky2: add Wake On Lan support fix unaligned exception in /drivers/net/wireless/orinoco.c Remove unused kernel config option DLCI_COUNT z85230: spinlock logic mips: declance: Driver model for the PMAD-A Spidernet: Rework RX linked list NET: turn local_save_flags() + local_irq_disable() into local_irq_save() NET-3c59x: turn local_save_flags() + local_irq_disable() into local_irq_save() hp100: convert pci_module_init() to pci_register_driver() NetXen: Added ethtool support for user level tools. NetXen: Firmware crb init changes. maintainers: add atl1 maintainers ...
2007-02-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (140 commits) ACPICA: reduce table header messages to fit within 80 columns asus-laptop: merge with ACPICA table update ACPI: bay: Convert ACPI Bay driver to be compatible with sysfs update. ACPI: bay: new driver is EXPERIMENTAL ACPI: bay: make drive_bays static ACPI: bay: make bay a platform driver ACPI: bay: remove prototype procfs code ACPI: bay: delete unused variable ACPI: bay: new driver adding removable drive bay support ACPI: dock: check if parent is on dock ACPICA: fix gcc build warnings Altix: Add ACPI SSDT PCI device support (hotplug) Altix: ACPI SSDT PCI device support ACPICA: reduce conflicts with Altix patch series ACPI_NUMA: fix HP IA64 simulator issue with extended memory domain ACPI: fix HP RX2600 IA64 boot ACPI: build fix for IBM x440 - CONFIG_X86_SUMMIT ACPICA: Update version to 20070126 ACPICA: Fix for incorrect parameter passed to AcpiTbDeleteTable during table load. ACPICA: Update copyright to 2007. ...
2007-02-06maintainers: add atl1 maintainersJay Cliburn
MAINTAINERS: add atl1 maintainers Add a maintainers entry for atl1. Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (32 commits) mmc: tifm: replace kmap with page_address mmc: sdhci: fix voltage ocr mmc: sdhci: replace kmap with page_address mmc: wbsd: replace kmap with page_address mmc: handle pci_enable_device() return value in sdhci mmc: Proper unclaim in mmc_block mmc: change wbsd mailing list mmc: Graceful fallback for fancy features mmc: Handle wbsd's stupid command list mmc: Allow host drivers to specify max block count mmc: Allow host drivers to specify a max block size tifm_sd: add suspend and resume functionality tifm_core: add suspend/resume infrastructure for tifm devices tifm_7xx1: prettify tifm_7xx1: recognize device 0xac8f as supported tifm_7xx1: switch from workqueue to kthread tifm_7xx1: Merge media insert and media remove functions tifm_7xx1: simplify eject function Add dummy_signal_irq function to save check in ISR Remove unused return value from signal_irq callback ...
2007-02-05PA Semi PWRficient Ethernet driverOlof Johansson
Driver for the PA Semi PWRficient on-chip Ethernet (1/10G) Basic enablement, will be complemented with performance enhancements over time. PHY support will be added as well. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-05[PATCH] Update Prism54 MAINTAINERS entryMichael Buesch
prism54-private@prism54.org bounces with SMTP error from remote mailer after RCPT TO:<prism54-private@prism54.org>: host mx1.tuxfamily.net [212.85.158.8]: 550 unknown user developers@islsm.org seems to be the new mailing list. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-02-05[S390] Update maintainers file.Martin Schwidefsky
Use the new linux-s390@vger.kernel.org mailing list instead of linux-390@vm.marist.edu. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-04mmc: change wbsd mailing listPierre Ossman
The wbsd-devel list has been shut down. Refer people to LKML instead. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2007-02-03Pull asus into test branchLen Brown
2007-02-02[PATCH] MAINTAINERS: ufs entryEvgeniy Dushistov
Mark ufs file system as maintainable, and add me as maintainer, to help people find appropriate person to assign bugs. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] Remove avr32@atmel.com from MAINTAINERSHaavard Skinnemoen
avr32@atmel.com is a technical support address and is not really appropriate for sending patches. Lots of annoying automatics getting in the way. I'm still the maintainer of all the entries touched by this patch, so nothing changes with regard to the "Supported" status of the AVR32 architecture or the macb driver. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[MAINTAINERS]: netfilter@ is subscribers-onlyRandy Dunlap
netfilter mailing list is subscribers-only. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
