path: root/MAINTAINERS
2010-05-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ar9170/usb.c drivers/scsi/iscsi_tcp.c net/ipv4/ipmr.c
2010-05-05Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/libertas_tf/cmd.c drivers/net/wireless/libertas_tf/main.c
2010-04-29Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ps3: Update ps3_defconfig powerpc/ps3: Update platform maintainer powerpc/pseries: Flush lazy kernel mappings after unplug operations powerpc/numa: Add form 1 NUMA affinity powerpc/fsl-booke: Fix CONFIG_RELOCATABLE support on FSL Book-E ppc32 powerpc: 2.6.34 update of defconfigs for embedded 6xx/7xxx, 8xx, 8xxx powerpc/mpc8xxx defconfigs - turn off SYSFS_DEPRECATED powerpc/83xx: configure SIL SATA driver in 83xx-wide defconfig powerpc/83xx: enable EPOLL syscall in defconfig powerpc/83xx: add RTC drivers in 83xx defconfig powerpc/fsl-cpm: Configure clock correctly for SCC powerpc/fsl_booke: Correct test for MMU_FTR_BIG_PHYS powerpc/85xx/86xx: Fix build w/ CONFIG_PCI=n
2010-04-28powerpc/ps3: Update platform maintainerGeoff Levand
Update the PS3 entries in the MAINTAINERS file. Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-04-27MAINTAINERS: add entry for include/linux/iw_handler.hJohn W. Linville
2010-04-22dri-devel mailing list moved - update MAINTAINERSValdis.Kletnieks@vt.edu
I posted to dri-devel@lists.sourceforge.net, and got a bounce back: The dri-devel list has moved to freedesktop.org (see http://lists.freedesktop.org/mailman/listinfo/dri-devel). If you were subscribed to the list here, the subscription should have been transferred to the new location. Please only post to the new list. Fix MAINTAINERS to correspond. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] bnx2i: Bug fixes related to MTU change issue when there are active iscsi sessions [SCSI] ibmvscsi: fix DMA API misuse [SCSI] wd7000: fix reset handler typo spin_unlock_irq() => spin_lock_irq() [SCSI] zfcp: Fix tracing of requests with error status [SCSI] zfcp: Update MAINTAINERS entry [SCSI] iscsi_tcp: fix relogin/shutdown hang [SCSI] qla2xxx: fix lock imbalance [SCSI] lpfc: fix lock imbalances [SCSI] be2iscsi: fix lock imbalance [SCSI] dpt_i2o: several use after free issues
2010-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-6000.c net/core/dev.c
2010-04-14hwmon: (applesmc) Switch maintainersHenrik Rydberg
Nicolas has expressed a wish to be relieved from the maintenance of applesmc, so we simply switch maintainer with this patch. Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Acked-by: Nicolas Boichat <nicolas@boichat.ch> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-04-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (21 commits) ARM: Fix ioremap_cached()/ioremap_wc() for SMP platforms ARM: 6043/1: AT91 slow-clock resume: Don't wait for a disabled PLL to lock ARM: 6031/1: fix Thumb-2 decompressor ARM: 6029/1: ep93xx: gpio.c: local functions should be static ARM: 6028/1: ARM: add MAINTAINERS for U300 ARM: 6024/1: bcmring: fix missing down on semaphore in dma.c MXC: mach_armadillo5x0: Add USB Host support. ARM mach-mx3: duplicated include ARM mach-mx3: duplicated include imx31: add watchdog device on litekit board. imx3: Add watchdog platform device support MXC: mach-mx31_3ds: add support for freescale mc13783 power management device. MXC: mach-mx31_3ds: Add SPI1 device support. MXC: mach-mx31_3ds: Add support for on board NAND Flash. MXC: mach-mx31_3ds: Update variable names over recent mach name modification. imx31: fix parent clock for rtc i.MX51: remove NFC AXI static mapping i.MX51: determine silicon revision dynamically i.MX51: map TZIC dynamically i.MX51: Use correct clock for gpt ...
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-11[SCSI] zfcp: Update MAINTAINERS entryChristof Schmitt
Martin no longer works on zfcp, remove his entry from the MAINTAINERS file and add Swen as co-maintainer. Also remove the reference to the zfcpdump.txt file, zfcpdump is not part of the zfcp device driver. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Acked-by: Martin Peschke <mpeschke@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-08MAINTAINERS: Put the virtio-console entry in correct alphabetical orderAmit Shah
Move around the entry for virtio-console to keep the file sorted. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-04-07ARM: 6028/1: ARM: add MAINTAINERS for U300Linus Walleij
This adds myself as maintainer of the U300 machine and associated system-on-chip drivers. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-03-30MAINTAINERS: ipg: Jesse Huang's email address bouncesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30KEYS: Add MAINTAINERS recordDavid Howells
Add a MAINTAINERS record for the key management facility. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-29vxge: Updating Maintainer list of S2IO 10GbE drivers (xframe / vxge).Sreenivasa Honnur
- updating Maintainer list of S2IO 10GbE drivers (xframe / vxge). Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Ramkrishna Vepa <ram.vepa@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (28 commits) ceph: update discussion list address in MAINTAINERS ceph: some documentations fixes ceph: fix use after free on mds __unregister_request ceph: avoid loaded term 'OSD' in documention ceph: fix possible double-free of mds request reference ceph: fix session check on mds reply ceph: handle kmalloc() failure ceph: propagate mds session allocation failures to caller ceph: make write_begin wait propagate ERESTARTSYS ceph: fix snap rebuild condition ceph: avoid reopening osd connections when address hasn't changed ceph: rename r_sent_stamp r_stamp ceph: fix connection fault con_work reentrancy problem ceph: prevent dup stale messages to console for restarting mds ceph: fix pg pool decoding from incremental osdmap update ceph: fix mds sync() race with completing requests ceph: only release unused caps with mds requests ceph: clean up handle_cap_grant, handle_caps wrt session mutex ceph: fix session locking in handle_caps, ceph_check_caps ceph: drop unnecessary WARN_ON in caps migration ...
2010-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) r8169: offical fix for CVE-2009-4537 (overlength frame DMAs) ipv6: Don't drop cache route entry unless timer actually expired. tulip: Add missing parens. r8169: fix broken register writes pcnet_cs: add new id bonding: fix broken multicast with round-robin mode drivers/net: Fix continuation lines e1000: do not modify tx_queue_len on link speed change net: ipmr/ip6mr: prevent out-of-bounds vif_table access ixgbe: Do not run all Diagnostic offline tests when VFs are active igb: use correct bits to identify if managability is enabled benet: Fix compile warnnings in drivers/net/benet/be_ethtool.c net: Add MSG_WAITFORONE flag to recvmmsg e1000e: do not modify tx_queue_len on link speed change igbvf: do not modify tx_queue_len on link speed change ipv4: Restart rt_intern_hash after emergency rebuild (v2) ipv4: Cleanup struct net dereference in rt_intern_hash net: fix netlink address dumping in IPv4/IPv6 tulip: Fix null dereference in uli526x_rx_packet() gianfar: fix undo of reserve() ...
2010-03-29ceph: update discussion list address in MAINTAINERSSage Weil
Signed-off-by: Sage Weil <sage@newdream.net>
2010-03-25isdn: Add netdev to lists in MAINTAINERS entry.David S. Miller
2010-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits) TIPC: Removed inactive maintainer isdn: Cleanup Sections in PCMCIA driver elsa isdn: Cleanup Sections in PCMCIA driver avma1 isdn: Cleanup Sections in PCMCIA driver teles isdn: Cleanup Sections in PCMCIA driver sedlbauer via-velocity: Fix FLOW_CNTL_TX_RX handling in set_mii_flow_control() netfilter: xt_hashlimit: IPV6 bugfix netfilter: ip6table_raw: fix table priority netfilter: xt_hashlimit: dl_seq_stop() fix af_key: return error if pfkey_xfrm_policy2msg_prep() fails skbuff: remove unused dma_head & dma_maps fields vlan: updates vlan real_num_tx_queues vlan: adds vlan_dev_select_queue igb: only use vlan_gro_receive if vlans are registered igb: do not modify tx_queue_len on link speed change igb: count Rx FIFO errors correctly bnx2: Use proper handler during netpoll. bnx2: Fix netpoll crash. ksz884x: fix return value of netdev_set_eeprom cgroups: net_cls as module ...
2010-03-25TIPC: Removed inactive maintainerJon Maloy
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-24MAINTAINERS: use tab not spaces for delimiterJoe Perches
Keeps MAINTAINERS a bit more consistent. done via sed -r -i -e 's/^([A-Z]):[ \t]+/\1:\t/g' MAINTAINERS Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits) ceph: update for write_inode API change ceph: reset osd after relevant messages timed out ceph: fix flush_dirty_caps race with caps migration ceph: include migrating caps in issued set ceph: fix osdmap decoding when pools include (removed) snaps ceph: return EBADF if waiting for caps on closed file ceph: set osd request message front length correctly ceph: reset front len on return to msgpool; BUG on mismatched front iov ceph: fix snaptrace decoding on cap migration between mds ceph: use single osd op reply msg ceph: reset bits on connection close ceph: remove bogus mds forward warning ceph: remove fragile __map_osds optimization ceph: fix connection fault STANDBY check ceph: invalidate_authorizer without con->mutex held ceph: don't clobber write return value when using O_SYNC ceph: fix client_request_forward decoding ceph: drop messages on unregistered mds sessions; cleanup ceph: fix comments, locking in destroy_inode ceph: move dereference after NULL test ... Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
2010-03-18enic: Clean up: Change driver description; Fix tab space; Update MAINTAINERSVasanthy Kolluri
1) Change enic driver description to "Cisco VIC Ethernet NIC Driver" 2) Fix tab space 3) Update MAINTAINERS list Signed-off-by: Scott Feldman <scofeldm@cisco.com> Signed-off-by: Vasanthy Kolluri <vkolluri@cisco.com> Signed-off-by: Roopa Prabhu <roprabhu@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sunxvr1000: Add missing FB=y depenency. MAINTAINERS: Add entry for sparc serial drivers. drivers/serial/sunsab.c: adjust the constant used to initialize the interrupt_mask0 fields
2010-03-16MAINTAINERS: Add entry for sparc serial drivers.David S. Miller
2010-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (108 commits) bridge: ensure to unlock in error path in br_multicast_query(). drivers/net/tulip/eeprom.c: fix bogus "(null)" in tulip init messages sky2: Avoid rtnl_unlock without rtnl_lock ipv6: Send netlink notification when DAD fails drivers/net/tg3.c: change the field used with the TG3_FLAG_10_100_ONLY constant ipconfig: Handle devices which take some time to come up. mac80211: Fix memory leak in ieee80211_if_write() mac80211: Fix (dynamic) power save entry ipw2200: use kmalloc for large local variables ath5k: read eeprom IQ calibration values correctly for G mode ath5k: fix I/Q calibration (for real) ath5k: fix TSF reset ath5k: use fixed antenna for tx descriptors libipw: split ieee->networks into small pieces mac80211: Fix sta_mtx unlocking on insert STA failure path rt2x00: remove KSEG1ADDR define from rt2x00soc.h net: add ColdFire support to the smc91x driver asix: fix setting mac address for AX88772 ipv6 ip6_tunnel: eliminate unused recursion field from ip6_tnl{}. net: Fix dev_mc_add() ...
2010-03-13Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Provide generic perf_sample_data initialization MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer perf trace: Don't use pager if scripting perf trace/scripting: Remove extraneous header read perf, ARM: Modify kuser rmb() call to compile for Thumb-2 x86/stacktrace: Don't dereference bad frame pointers perf archive: Don't try to collect files without a build-id perf_events, x86: Fixup fixed counter constraints perf, x86: Restrict the ANY flag perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE perf, x86: add some IBS macros to perf_event.h perf, x86: make IBS macros available in perf_event.h hw-breakpoints: Remove stub unthrottle callback x86/hw-breakpoints: Remove the name field perf: Remove pointless breakpoint union perf lock: Drop the buffers multiplexing dependency perf lock: Fix and add misc documentally things percpu: Add __percpu sparse annotations to hw_breakpoint
2010-03-12Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (370 commits) ARM: S3C2443: Add set_rate and round_rate calls for armdiv clock ARM: S3C2443: Remove #if 0 for clk_mpll ARM: S3C2443: Update notes on MPLLREF clock ARM: S3C2443: Further clksrc-clk conversions ARM: S3C2443: Change to using plat-samsung clksrc-clk implementation USB: Fix s3c-hsotg build following Samsung platform header moves ARM: S3C64XX: Reintroduce unconditional build of audio device ARM: 5961/1: ux500: fix CLKRST addresses ARM: 5977/1: arm: Enable backtrace printing on oops when PC is corrupted ASoC: Fix S3C64xx IIS driver for Samsung header reorg ARM: S3C2440: Fix plat-s3c24xx move of s3c2440/s3c2442 support [ARM] pxa: fix typo in mxm8x10.h [ARM] pxa/raumfeld: set GPIO drive bits for LED pins [ARM] pxa/zeus: Add support for mcp2515 CAN bus [ARM] pxa/zeus: Add support for onboard max6369 watchdog [ARM] pxa/zeus: Add Eurotech as the manufacturer [ARM] pxa/zeus: Correct the USB host initialisation flags [ARM] pxa/zeus: Allow usage of 8250-compatible UART in uncompress [ARM] pxa: refactor uncompress.h for non-PXA uarts [ARM] mmp2: fix incorrect calling of chip->mask_ack() for 2nd level cascaded IRQs ...
2010-03-12memcg: update maintainer listKAMEZAWA Hiroyuki
Nishimura-san have been working for memcg very good. His review and tests give us much improvements and account migraiton which he is now challenging is really important. He is a stakeholder. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12intelfb: new maintainerMaik Broemme
It seems that Sylvain no longer maintain the intelfb driver. Two weeks ago I had a short mail conversation with Jean regarding who can replace him. Well I will do it, because I know the driver and use it very often. Attached is a patch which update the maintainer file to make bug reporting easier. Signed-off-by: Maik Broemme <mbroemme@plusserver.de> Sylvain Meyer <sylvain.meyer@worldonline.fr> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Dave Airlie <airlied@linux.ie> Cc: Eric Anholt <eric@anholt.net> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12MAINTAINERS: add bfin_sdh driverMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-09Merge commit 'v2.6.34-rc1' into perf/urgentIngo Molnar
Conflicts: tools/perf/util/probe-event.c Merge reason: Pick up -rc1 and resolve the conflict as well. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-09MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainerIngo Molnar
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-08MAINTAINERS: add netdev to CAN network layer and drivers entriesWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-08Merge branch 'origin' into devel-stableRussell King
Conflicts: arch/arm/mach-mx2/devices.c arch/arm/mach-mx2/devices.h sound/soc/pxa/pxa-ssp.c
2010-03-07MAINTAINER: Correct CAN Maintainer responsibilities and pathsOliver Hartkopp
Update the CAN Maintainer responsibilities and add source paths. Additional the SocketCAN core ML is not subscribers-only anymore. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs: [LogFS] Change magic number [LogFS] Remove h_version field [LogFS] Check feature flags [LogFS] Only write journal if dirty [LogFS] Fix bdev erases [LogFS] Silence gcc [LogFS] Prevent 64bit divisions in hash_index [LogFS] Plug memory leak on error paths [LogFS] Add MAINTAINERS entry [LogFS] add new flash file system Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in fs/logfs/inode.c introduced by write_inode() being changed to use writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d ("pass writeback_control to ->write_inode")
2010-03-06Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (23 commits) hwmon: Remove the deprecated adt7473 driver hwmon: Fix off-by-one kind values hwmon: (tmp421) Fix temperature conversions hwmon: (tmp421) Restore missing inputs hwmon: Driver for Andigilog aSC7621 family monitoring chips hwmon: (adt7411) Improve locking hwmon: Add driver for ADT7411 voltage and temperature sensor hwmon: (w83793) Add watchdog functionality hwmon: (g760a) Make rpm_from_cnt static hwmon: (it87) Validate auto pwm settings hwmon: (it87) Add support for old automatic fan speed control hwmon: (it87) Drop dead web links in documentation hwmon: (it87) Add an entry in MAINTAINERS hwmon: (it87) Use strict_strtol instead of simple_strtol hwmon: (it87) Fix many checkpatch errors and warnings hwmon: (it87) Add support for beep on alarm hwmon: (it87) Create vid attributes by group hwmon: (it87) Refactor attributes creation and removal hwmon: (it87) Expose the PWM/temperature mappings hwmon: (it87) Display fan outputs in automatic mode as such ...
2010-03-06MAINTAINERS: document and add "Q" patchwork queue entriesJoe Perches
Patchwork queues show the acceptance/rejection state of submitted patches for various MAINTAINER trees. Document their existence. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: WAVELAN moved to stagingJoe Perches
by commit 0234f84ebb00d36c48062befa5436eef36b71ccd Update patterns Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: STARMODE RADIO IP (STRIP) moved to stagingJoe Perches
by commit 955015bb0b42167d14f776ff5947ae2463a974dc Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: update PERFORMANCE EVENTS F: patternsJoe Perches
To match arch/*/kernel perf_event location changes Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: remove HAYES ESP SERIAL DRIVERJoe Perches
Commit f53a2ade0bb9f2a81f473e6469155172a96b7c38 ("tty: esp: remove broken driver") removed it Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06MAINTAINERS: remove AMD GEODE F: arch/x86/kernel/geode_32.cJoe Perches
Commit c95d1e53ed89b75a4d7b68d1cbae4607b1479243 ("cs5535: drop the Geode-specific MFGPT/GPIO code") removed it. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-05hwmon: Driver for Andigilog aSC7621 family monitoring chipsGeorge Joseph
Hwmon driver for Andigilog aSC7621 family monitoring chips. Signed-off-by: George Joseph <george.joseph@fairview5.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (it87) Add an entry in MAINTAINERSJean Delvare
As I've just done a lot of changes to the it87 driver, I volunteer to maintain it for the year to come. Signed-off-by: Jean Delvare <khali@linux-fr.org>
