path: root/MAINTAINERS
2012-06-20brcm80211: add mailing list address for brcm80211 driversArend van Spriel
Added the mailing list address brcm80211-dev-list@broadcom.com which can be used to report issues and in bug reports. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: MAINTAINERS drivers/net/wireless/iwlwifi/pcie/trans.c
2012-06-08wireless: add my new trees to MAINTAINERSJohannes Berg
Add my new trees to the MAINTAINERS file for the components that I maintain in the new trees. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06wireless: update wireless URLsJohannes Berg
The preferred URL is http://wireless.kernel.org/ rather than http://linuxwireless.org/, update all URLs to point there. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-31Merge tag 'for-v3.5' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Anton Vorontsov: "A bunch of fixes for v3.5, nothing extraordinary." * tag 'for-v3.5' of git://git.infradead.org/battery-2.6: (27 commits) smb347-charger: Include missing <linux/err.h> smb347-charger: Clean up battery attributes max17042_battery: Add support for max17047/50 chip sbs-battery.c: Capacity attr = remaining relative capacity isp1704_charger: Use after free on probe error ds2781_battery: Use DS2781_PARAM_EEPROM_SIZE and DS2781_USER_EEPROM_SIZE power_supply: Fix a typo in BATTERY_DS2781 Kconfig entry charger-manager: Provide cm_notify_event function for in-kernel use charger-manager: Poll battery health in normal state smb347-charger: Convert to regmap API smb347-charger: Move IRQ enabling to the end of probe smb347-charger: Rename few functions to match better what they are doing smb347-charger: Convert to use module_i2c_driver() smb347_charger: Cleanup power supply registration code in probe ab8500: Clean up probe routines ab8500_fg: Harden platform data check ab8500_btemp: Harden platform data check ab8500_charger: Harden platform data check MAINTAINERS: Fix 'F' entry for the power supply class max17042_battery: Handle irq request failure case ...
2012-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking changes from David S. Miller: 1) Fix IPSEC header length calculation for transport mode in ESP. The issue is whether to do the calculation before or after alignment. Fix from Benjamin Poirier. 2) Fix regression in IPV6 IPSEC fragment length calculations, from Gao Feng. This is another transport vs tunnel mode issue. 3) Handle AF_UNSPEC connect()s properly in L2TP to avoid OOPSes. Fix from James Chapman. 4) Fix USB ASIX driver's reception of full sized VLAN packets, from Eric Dumazet. 5) Allow drop monitor (and, more generically, all generic netlink protocols) to be automatically loaded as a module. From Neil Horman. Fix up trivial conflict in Documentation/feature-removal-schedule.txt due to new entries added next to each other at the end. As usual. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits) net/smsc911x: Repair broken failure paths virtio-net: remove useless disable on freeze netdevice: Update netif_dbg for CONFIG_DYNAMIC_DEBUG drop_monitor: Add module alias to enable automatic module loading genetlink: Build a generic netlink family module alias net: add MODULE_ALIAS_NET_PF_PROTO_NAME r6040: Do a Proper deinit at errorpath and also when driver unloads (calling r6040_remove_one) r6040: disable pci device if the subsequent calls (after pci_enable_device) fails skb: avoid unnecessary reallocations in __skb_cow net: sh_eth: fix the rxdesc pointer when rx descriptor empty happens asix: allow full size 8021Q frames to be received rds_rdma: don't assume infiniband device is PCI l2tp: fix oops in L2TP IP sockets for connect() AF_UNSPEC case mac80211: fix ADDBA declined after suspend with wowlan wlcore: fix undefined symbols when CONFIG_PM is not defined mac80211: fix flag check for QoS NOACK frames ath9k_hw: apply internal regulator settings on AR933x ath9k_hw: update AR933x initvals to fix issues with high power devices ath9k: fix a use-after-free-bug when ath_tx_setup_buffer() fails ath9k: stop rx dma before stopping tx ...
2012-05-30Merge branch 'for-3.5/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "Here are the driver related changes for 3.5. It contains: - The floppy changes from Jiri. Jiri is now also marked as the maintainer of floppy.c, I shall be publically branding his forehead with red hot iron at the next opportune moment. - A batch of drbd updates and fixes from the linbit crew, as well as fixes from others. - Two small fixes for xen-blkfront courtesy of Jan." * 'for-3.5/drivers' of git://git.kernel.dk/linux-block: (70 commits) floppy: take over maintainership floppy: remove floppy-specific O_EXCL handling floppy: convert to delayed work and single-thread wq xen-blkfront: module exit handling adjustments xen-blkfront: properly name all devices drbd: grammar fix in log message drbd: check MODULE for THIS_MODULE drbd: Restore the request restart logic drbd: introduce a bio_set to allocate housekeeping bios from drbd: remove unused define drbd: bm_page_async_io: properly initialize page->private drbd: use the newly introduced page pool for bitmap IO drbd: add page pool to be used for meta data IO drbd: allow bitmap to change during writeout from resync_finished drbd: fix race between drbdadm invalidate/verify and finishing resync drbd: fix resend/resubmit of frozen IO drbd: Ensure that data_size is not 0 before using data_size-1 as index drbd: Delay/reject other state changes while establishing a connection drbd: move put_ldev from __req_mod() to the endio callback drbd: fix WRITE_ACKED_BY_PEER_AND_SIS to not set RQ_NET_DONE ...
2012-05-29MAINTAINERS: remove AlessandroAlessandro Rubini
I'm definitely not up to date on the subject matter any more and haven't been able to comment on the messages on the topic. Signed-off-by: Alessandro Rubini <rubini@ipvvis.unipv.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29hamradio/scc: orphan driver in MAINTAINERSUwe Kleine-König
The email address doesn't exist anymore and the website yields a 404. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29Merge tag 'mfd-3.5-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: "Besides the usual cleanups, this one brings: * Support for 5 new chipsets: Intel's ICH LPC and SCH Centerton, ST-E's STAX211, Samsung's MAX77693 and TI's LM3533. * Device tree support for the twl6040, tps65910, da9502 and ab8500 drivers. * Fairly big tps56910, ab8500 and db8500 updates. * i2c support for mc13xxx. * Our regular update for the wm8xxx driver from Mark." Fix up various conflicts with other trees, largely due to ab5500 removal etc. * tag 'mfd-3.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (106 commits) mfd: Fix build break of max77693 by adding REGMAP_I2C option mfd: Fix twl6040 build failure mfd: Fix max77693 build failure mfd: ab8500-core should depend on MFD_DB8500_PRCMU gpio: tps65910: dt: process gpio specific device node info mfd: Remove the parsing of dt info for tps65910 gpio mfd: Save device node parsed platform data for tps65910 sub devices mfd: Add r_select to lm3533 platform data gpio: Add Intel Centerton support to gpio-sch mfd: Emulate active low IRQs as well as active high IRQs for wm831x mfd: Mark two lm3533 zone registers as volatile mfd: Fix return type of lm533 attribute is_visible mfd: Enable Device Tree support in the ab8500-pwm driver mfd: Enable Device Tree support in the ab8500-sysctrl driver mfd: Add support for Device Tree to twl6040 mfd: Register the twl6040 child for the ASoC codec unconditionally mfd: Allocate twl6040 IRQ numbers dynamically mfd: twl6040 code cleanup in interrupt initialization part mfd: Enable ab8500-gpadc driver for Device Tree mfd: Prevent unassigned pointer from being used in ab8500-gpadc driver ...
2012-05-26Merge branch 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linuxLinus Torvalds
Pull i2c-embedded changes from Wolfram Sang: "Major changes: - lots of devicetree additions for existing drivers. I tried hard to make sure the bindings are proper. In more complicated cases, I requested acks from people having more experience with them than me. That took a bit of extra time and also some time went into discussions with developers about what bindings are and what not. I have the feeling that the workflow with bindings should be improved to scale better. I will spend some more thought on this... - i2c-muxes are succesfully used meanwhile, so we dropped EXPERIMENTAL for them and renamed the drivers to a standard pattern to match the rest of the subsystem. They can also be used with devicetree now. - ixp2000 was removed since the whole platform goes away. - cleanups (strlcpy instead of strcpy, NULL instead of 0) - The rest is typical driver fixes I assume. All patches have been in linux-next at least since v3.4-rc6." Fixed up trivial conflict in arch/arm/mach-lpc32xx/common.c due to the same patch already having come in through the arm/soc trees, with additional patches on top of it. * 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (35 commits) i2c: davinci: Free requested IRQ in remove i2c: ocores: register OF i2c devices i2c: tegra: notify transfer-complete after clearing status. I2C: xiic: Add OF binding support i2c: Rename last mux driver to standard pattern i2c: tegra: fix 10bit address configuration i2c: muxes: rename first set of drivers to a standard pattern of/i2c: implement of_find_i2c_adapter_by_node i2c: implement i2c_verify_adapter i2c-s3c2410: Add HDMIPHY quirk for S3C2440 i2c-s3c2410: Rework device type handling i2c: muxes are not EXPERIMENTAL anymore i2c/of: Automatically populate i2c mux busses from device tree data. i2c: Add a struct device * parameter to i2c_add_mux_adapter() of/i2c: call i2c_verify_client from of_find_i2c_device_by_node i2c: designware: Add clk_{un}prepare() support i2c: designware: add PM support i2c: ixp2000: remove driver i2c: pnx: add device tree support i2c: imx: don't use strcpy but strlcpy ...
2012-05-26Merge tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc: soc specific changes (part 2) from Olof Johansson: "This adds support for the spear13xx platform, which has first been under review a long time ago and finally been completed after generic spear work has gone into the clock, dt and pinctrl branches. Also a number of updates for the samsung socs are part of this branch." Fix up trivial conflicts in drivers/gpio/gpio-samsung.c that look much worse than they are: the exonys5 init code was refactored in commit fd454997d687 ("gpio: samsung: refactor gpiolib init for exynos4/5"), and then commit f10590c9836c ("ARM: EXYNOS: add GPC4 bank instance") added a new gpio chip define and did tiny updates to the init code. So the conflict diff looks like hell, but it's actually a fairly simple change. * tag 'soc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (34 commits) ARM: exynos: fix building with CONFIG_OF disabled ARM: EXYNOS: Add AUXDATA for i2c controllers ARM: dts: Update device tree source files for EXYNOS5250 ARM: EXYNOS: Add device tree support for interrupt combiner ARM: EXYNOS: Add irq_domain support for interrupt combiner ARM: EXYNOS: Remove a new bus_type instance for EXYNOS5 ARM: EXYNOS: update irqs for EXYNOS5250 SoC ARM: EXYNOS: Add pre-divider and fout mux clocks for bpll and mpll ARM: EXYNOS: add GPC4 bank instance ARM: EXYNOS: Redefine IRQ_MCT_L0,1 definition ARM: EXYNOS: Modify the GIC physical address for static io-mapping ARM: EXYNOS: Add watchdog timer clock instance pinctrl: SPEAr1310: Fix pin numbers for clcd_high_res SPEAr: Update MAINTAINERS and Documentation SPEAr13xx: Add defconfig SPEAr13xx: Add compilation support SPEAr13xx: Add dts and dtsi files pinctrl: Add SPEAr13xx pinctrl drivers pinctrl: SPEAr: Create macro for declaring GPIO PINS SPEAr13xx: Add common clock framework support ...
2012-05-26Merge tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clock driver changes from Olof Johansson: "The new clock subsystem was merged in linux-3.4 without any users, this now moves the first three platforms over to it: imx, mxs and spear. The series also contains the changes for the clock subsystem itself, since Mike preferred to have it together with the platforms that require these changes, in order to avoid interdependencies and conflicts." Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code removed in one branch, added OF support in another) and drivers/dma/imx-sdma.c (independent changes next to each other). * tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate(). clk: Provide dummy clk_unregister() SPEAr: Update defconfigs SPEAr: Add SMI NOR partition info in dts files SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock SPEAr: Add DT bindings for SPEAr's timer ARM i.MX: remove now unused clock files ARM: i.MX6: implement clocks using common clock framework ARM i.MX35: implement clocks using common clock framework ARM i.MX5: implement clocks using common clock framework ARM: Kirkwood: Replace clock gating ARM: Orion: Audio: Add clk/clkdev support ARM: Orion: PCIE: Add support for clk ARM: Orion: XOR: Add support for clk ARM: Orion: CESA: Add support for clk ...
2012-05-24Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull XFS update from Ben Myers: - Removal of xfsbufd - Background CIL flushes have been moved to a workqueue. - Fix to xfs_check_page_type applicable to filesystems where blocksize < page size - Fix for stale data exposure when extsize hints are used. - A series of xfs_buf cache cleanups. - Fix for XFS_IOC_ALLOCSP - Cleanups for includes and removal of xfs_lrw.[ch]. - Moved all busy extent handling to it's own file so that it is easier to merge with userspace. - Fix for log mount failure. - Fix to enable inode reclaim during quotacheck at mount time. - Fix for delalloc quota accounting. - Fix for memory reclaim deadlock on agi buffer. - Fixes for failed writes and to clean up stale delalloc blocks. - Fix to use GFP_NOFS in blkdev_issue_flush - SEEK_DATA/SEEK_HOLE support * 'for-linus' of git://oss.sgi.com/xfs/xfs: (57 commits) xfs: add trace points for log forces xfs: fix memory reclaim deadlock on agi buffer xfs: fix delalloc quota accounting on failure xfs: protect xfs_sync_worker with s_umount semaphore xfs: introduce SEEK_DATA/SEEK_HOLE support xfs: make xfs_extent_busy_trim not static xfs: make XBF_MAPPED the default behaviour xfs: flush outstanding buffers on log mount failure xfs: Properly exclude IO type flags from buffer flags xfs: clean up xfs_bit.h includes xfs: move xfs_do_force_shutdown() and kill xfs_rw.c xfs: move xfs_get_extsz_hint() and kill xfs_rw.h xfs: move xfs_fsb_to_db to xfs_bmap.h xfs: clean up busy extent naming xfs: move busy extent handling to it's own file xfs: move xfsagino_t to xfs_types.h xfs: use iolock on XFS_IOC_ALLOCSP calls xfs: kill XBF_DONTBLOCK xfs: kill xfs_read_buf() xfs: kill XBF_LOCK ...
2012-05-24MAINTAINERSjamal
After about two decades, I am giving up on cyberus. Nabwaga Manyanga. Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-24Merge branch 'drm-core-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull main drm updates from Dave Airlie: "This is the main merge window request for the drm. It's big, but jam packed will lots of features and of course 0 regressions. (okay maybe there'll be one). Highlights: - new KMS drivers for server GPU chipsets: ast, mgag200 and cirrus (qemu only). These drivers use the generic modesetting drivers. - initial prime/dma-buf support for i915, nouveau, radeon, udl and exynos - switcheroo audio support: so GPUs with HDMI can turn off the sound driver without crashing stuff. - There are some patches drifting outside drivers/gpu into x86 and EFI for better handling of multiple video adapters in Apple Macs, they've got correct acks except one trivial fixup. - Core: edid parser has better DMT and reduced blanking support, crtc properties, plane properties, - Drivers: exynos: add 2D core accel support, prime support, hdmi features intel: more Haswell support, initial Valleyview support, more hdmi infoframe fixes, update MAINTAINERS for Daniel, lots of cleanups and fixes radeon: more HDMI audio support, improved GPU lockup recovery support, remove nested mutexes, less memory copying on PCIE, fix bus master enable race (kexec), improved fence handling gma500: cleanups, 1080p support, acpi fixes nouveau: better nva3 memory reclocking, kepler accel (needs external firmware rip), async buffer moves on nv84+ hw. I've some more dma-buf patches that rely on the dma-buf merge for vmap stuff, and I've a few fixes building up, but I'd decided I'd better get rid of the main pull sooner rather than later, so the audio guys are also unblocked." Fix up trivial conflict due to some duplicated changes in drivers/gpu/drm/i915/intel_ringbuffer.c * 'drm-core-next' of git://people.freedesktop.org/~airlied/linux: (605 commits) drm/nouveau/nvd9: Fix GPIO initialisation sequence. drm/nouveau: Unregister switcheroo client on exit drm/nouveau: Check dsm on switcheroo unregister drm/nouveau: fix a minor annoyance in an output string drm/nouveau: turn a BUG into a WARN drm/nv50: decode PGRAPH DATA_ERROR = 0x24 drm/nouveau/disp: fix dithering not being enabled on some eDP macbooks drm/nvd9/copy: initialise copy engine, seems to work like nvc0 drm/nvc0/ttm: use copy engines for async buffer moves drm/nva3/ttm: use copy engine for async buffer moves drm/nv98/ttm: add in a (disabled) crypto engine buffer copy method drm/nv84/ttm: use crypto engine for async buffer copies drm/nouveau/ttm: untangle code to support accelerated buffer moves drm/nouveau/fbcon: use fence for sync, rather than notifier drm/nv98/crypt: non-stub implementation of the engine hooks drm/nouveau/fifo: turn all fifo modules into engine modules drm/nv50/graph: remove ability to do interrupt-driven context switching drm/nv50: remove manual context unload on context destruction drm/nv50: remove execution engine context saves on suspend drm/nv50/fifo: use hardware channel kickoff functionality ...
2012-05-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer updates from Dmitry Torokhov: - a bunch of new drivers (DA9052/53 touchscreenn controller, Synaptics Navpoint, LM8333 keypads, Wacom I2C touhscreen); - updates to existing touchpad drivers (ALPS, Sntelic); - Wacom driver now supports Intuos5; - device-tree bindings in numerous drivers; - other cleanups and fixes. Fix annoying conflict in drivers/input/tablet/wacom_wac.c that I think implies that the input layer device naming is broken, but let's see. I brough it up with Dmitry. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) Input: matrix-keymap - fix building keymaps Input: spear-keyboard - document DT bindings Input: spear-keyboard - add device tree bindings Input: matrix-keymap - wire up device tree support Input: matrix-keymap - uninline and prepare for device tree support Input: adp5588 - add support for gpio names Input: omap-keypad - dynamically handle register offsets Input: synaptics - fix compile warning MAINTAINERS: adjust input-related patterns Input: ALPS - switch to using input_mt_report_finger_count Input: ALPS - add semi-MT support for v4 protocol Input: Add Synaptics NavPoint (PXA27x SSP/SPI) driver Input: atmel_mxt_ts - dump each message on just 1 line Input: atmel_mxt_ts - do not read extra (checksum) byte Input: atmel_mxt_ts - verify object size in mxt_write_object Input: atmel_mxt_ts - only allow root to update firmware Input: atmel_mxt_ts - use CONFIG_PM_SLEEP Input: sentelic - report device's production serial number Input: tl6040-vibra - Device Tree support Input: evdev - properly handle read/write with count 0 ...
2012-05-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - some V4L2 API updates needed by embedded devices - DVB API extensions for ATSC-MH delivery system, used in US for mobile TV - new tuners for fc0011/0012/0013 and tua9001 - a new dvb driver for af9033/9035 - a new ATSC-MH frontend (lg2160) - new remote controller keymaps - Removal of a few legacy webcam driver that got replaced by gspca on several kernel versions ago - a new driver for Exynos 4/5 webcams(s5pp fimc-lite) - a new webcam sensor driver (smiapp) - a new video input driver for embedded (sta2x1xx) - several improvements, fixes, cleanups, etc inside the drivers. Manually fix up conflicts due to err() -> dev_err() conversion in drivers/staging/media/easycap/easycap_main.c * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (484 commits) [media] saa7134-cards: Remove a PCI entry added by mistake [media] radio-sf16fmi: add support for SF16-FMD [media] rc-loopback: remove duplicate line [media] patch for Asus My Cinema PS3-100 (1043:48cd) [media] au0828: Move the Kconfig knob under V4L_USB_DRIVERS [media] em28xx: simple comment fix [media] [resend] radio-sf16fmr2: add PnP support for SF16-FMD2 [media] smiapp: Use v4l2_ctrl_new_int_menu() instead of v4l2_ctrl_new_custom() [media] smiapp: Add support for 8-bit uncompressed formats [media] smiapp: Allow generic quirk registers [media] smiapp: Use non-binning limits if the binning limit is zero [media] smiapp: Initialise rval in smiapp_read_nvm() [media] smiapp: Round minimum pre_pll up rather than down in ip_clk_freq check [media] smiapp: Use 8-bit reads only before identifying the sensor [media] smiapp: Quirk for sensors that only do 8-bit reads [media] smiapp: Pass struct sensor to register writing commands instead of i2c_client [media] smiapp: Allow using external clock from the clock framework [media] zl10353: change .read_snr() to report SNR as a 0.1 dB [media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300) [media] m88rs2000 - only flip bit 2 on reg 0x70 on 16th try ...
2012-05-23Merge branch 'delete-mca' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull the MCA deletion branch from Paul Gortmaker: "It was good that we could support MCA machines back in the day, but realistically, nobody is using them anymore. They were mostly limited to 386-sx 16MHz CPU and some 486 class machines and never more than 64MB of RAM. Even the enthusiast hobbyist community seems to have dried up close to ten years ago, based on what you can find searching various websites dedicated to the relatively short lived hardware. So lets remove the support relating to CONFIG_MCA. There is no point carrying this forward, wasting cycles doing routine maintenance on it; wasting allyesconfig build time on validating it, wasting I/O on git grep'ping over it, and so on." Let's see if anybody screams. It generally has compiled, and James Bottomley pointed out that there was a MCA extension from NCR that allowed for up to 4GB of memory and PPro-class machines. So in *theory* there may be users out there. But even James (technically listed as a maintainer) doesn't actually have a system, and while Alan Cox claims to have a machine in his cellar that he offered to anybody who wants to take it off his hands, he didn't argue for keeping MCA support either. So we could bring it back. But somebody had better speak up and talk about how they have actually been using said MCA hardware with modern kernels for us to do that. And David already took the patch to delete all the networking driver code (commit a5e371f61ad3: "drivers/net: delete all code/drivers depending on CONFIG_MCA"). * 'delete-mca' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: MCA: delete all remaining traces of microchannel bus support. scsi: delete the MCA specific drivers and driver code serial: delete the MCA specific 8250 support. arm: remove ability to select CONFIG_MCA
2012-05-23Merge branch 'sbp-target-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull sbp-2 (firewire) target mode support from Nicholas Bellinger: "The FireWire SBP-2 Target is a driver for using an IEEE-1394 connection as a SCSI transport. This module uses the SCSI Target framework to expose LUNs to other machines attached to a FireWire bus, in effect acting as a FireWire hard disk similar to FireWire Target Disk mode on many Apple computers. Also included are the two drivers/firewire/ patches required by sbp-target to access fw_request fabric speed needed for mgt_agent TCODE_WRITE_BLOCK_REQUEST ops, and exporting fw_card kref logic used when creating/destroying active session references to individual endpoints. A credit goes to Chris in being able to get this code up and running so quickly w/o any target core changes, and special thanks goes out to Stefan Richter + Clemens Ladisch + Andy Grover for their help in getting this driver ready for mainline. Also, one of Chris's goals was to be able to connect sbp-target to a PowerPC based MacOS-X based client, that he accomplished along the way in this obligatory screenshot: http://linux-iscsi.org/wiki/File:Linux-fireware-target-bootc-macosx.png Great work Chris + linux-1394 team !!" Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> * 'sbp-target-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: sbp-target: Initial merge of firewire/ieee-1394 target mode support firewire: Move fw_card kref functions into linux/firewire.h firewire: Add function to get speed from opaque struct fw_request
2012-05-23Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This is the first big chunk for 3.5 merges of sound stuff. There are a few big changes in different areas. First off, the streaming logic of USB-audio endpoints has been largely rewritten for the better support of "implicit feedback". If anything about USB got broken, this change has to be checked. For HD-audio, the resume procedure was changed; instead of delaying the resume of the hardware until the first use, now waking up immediately at resume. This is for buggy BIOS. For ASoC, dynamic PCM support and the improved support for digital links between off-SoC devices are major framework changes. Some highlights are below: * HD-audio - Avoid accesses of invalid pin-control bits that may stall the codec - V-ref setup cleanups - Fix the races in power-saving code - Fix the races in codec cache hashes and connection lists - Split some common codes for BIOS auto-parser to hda_auto_parser.c - Changed the PM resume code to wake up immediately for buggy BIOS - Creative SoundCore3D support - Add Conexant CX20751/2/3/4 codec support * ASoC - Dynamic PCM support, allowing support for SoCs with internal routing through components with tight sequencing and formatting constraints within their internal paths or where there are multiple components connected with CPU managed DMA controllers inside the SoC. - Greatly improved support for direct digital links between off-SoC devices, providing a much simpler way of connecting things like digital basebands to CODECs. - Much more fine grained and robust locking, cleaning up some of the confusion that crept in with multi-component. - CPU support for nVidia Tegra 30 I2S and audio hub controllers and ST-Ericsson MSP I2S controolers - New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124, Texas Instruments LM49453. - Some regmap changes needed by the Tegra I2S driver. - mc13783 audio support. * Misc - Rewrite with module_pci_driver() - Xonar DGX support for snd-oxygen - Improvement of packet handling in snd-firewire driver - New USB-endpoint streaming logic - Enhanced M-audio FTU quirks and relevant cleanups - Increment the support of OSS devices to 256 - snd-aloop accuracy improvement There are a few more pending changes for 3.5, but they will be sent slightly later as partly depending on the changes of DRM." Fix up conflicts in regmap (due to duplicate patches, with some further updates then having already come in from the regmap tree). Also some fairly trivial context conflicts in the imx and mcx soc drivers. * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits) ALSA: snd-usb: fix stream info output in /proc ALSA: pcm - Add proper state checks to snd_pcm_drain() ALSA: sh: Fix up namespace collision in sh_dac_audio. ALSA: hda/realtek - Fix unused variable compile warning ASoC: sh: fsi: enable chip specific data transfer mode ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger() ASoC: sh: fsi: use same format for IN/OUT ASoC: sh: fsi: add fsi_version() and removed meaningless version check ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC ASoC: tegra: Add machine driver for WM8753 codec ALSA: hda - Fix possible races of accesses to connection list array ASoC: OMAP: HDMI: Introduce codec ARM: mx31_3ds: Add sound support ASoC: imx-mc13783 cleanup mx31moboard: Add sound support ASoC: mc13783 codec cleanups ASoC: add imx-mc13783 sound support ASoC: Add mc13783 codec mfd: mc13xxx: add codec platform data ASoC: don't flip master of DT-instantiated DAI links ...
2012-05-23Merge tag 'sh-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
Pull SuperH updates from Paul Mundt: - New CPUs: SH7734 (SH-4A), SH7264 and SH7269 (SH-2A) - New boards: RSK2+SH7264, RSK2+SH7269 - Unbreaking kgdb for SMP - Consolidation of _32/_64 page fault handling. - watchdog and legacy DMA chainsawing, part 1 - Conversion to evt2irq() hwirq lookup, to support relocation of vectored IRQs for irqdomains. * tag 'sh-for-linus' of git://github.com/pmundt/linux-sh: (98 commits) sh: intc: Kill off special reservation interface. sh: Enable PIO API for hp6xx and se770x. sh: Kill off machvec IRQ hinting. sh: dma: More legacy cpu dma chainsawing. sh: Kill off MAX_DMA_ADDRESS leftovers. sh: Tidy up some of the cpu legacy dma header mess. sh: Move sh4a dma header from cpu-sh4 to cpu-sh4a. sh64: Fix up vmalloc fault range check. Revert "sh: Ensure fixmap and store queue space can co-exist." serial: sh-sci: Fix for port types without BRI interrupts. sh: legacy PCI evt2irq migration. sh: cpu dma evt2irq migration. sh: sh7763rdp evt2irq migration. sh: sdk7780 evt2irq migration. sh: migor evt2irq migration. sh: landisk evt2irq migration. sh: kfr2r09 evt2irq migration. sh: ecovec24 evt2irq migration. sh: ap325rxa evt2irq migration. sh: urquell evt2irq migration. ...
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-22Merge tag 'staging-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree changes from Greg Kroah-Hartman: "Here is the big staging tree pull request for the 3.5-rc1 merge window. Loads of changes here, and we just narrowly added more lines than we added: 622 files changed, 28356 insertions(+), 26059 deletions(-) But, good news is that there is a number of subsystems that moved out of the staging tree, to their respective "real" portions of the kernel. Code that moved out was: - iio core code - mei driver - vme core and bridge drivers There was one broken network driver that moved into staging as a step before it is removed from the tree (pc300), and there was a few new drivers added to the tree: - new iio drivers - gdm72xx wimax USB driver - ipack subsystem and 2 drivers All of the movements around have acks from the various subsystem maintainers, and all of this has been in the linux-next tree for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up various trivial conflicts, along with a non-trivial one found in -next and pointed out by Olof Johanssen: a clean - but incorrect - merge of the arch/arm/boot/dts/at91sam9g20.dtsi file. Fix up manually as per Stephen Rothwell. * tag 'staging-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (536 commits) Staging: bcm: Remove two unused variables from Adapter.h Staging: bcm: Removes the volatile type definition from Adapter.h Staging: bcm: Rename all "INT" to "int" in Adapter.h Staging: bcm: Fix warning: __packed vs. __attribute__((packed)) in Adapter.h Staging: bcm: Correctly format all comments in Adapter.h Staging: bcm: Fix all whitespace issues in Adapter.h Staging: bcm: Properly format braces in Adapter.h Staging: ipack/bridges/tpci200: remove unneeded casts Staging: ipack/bridges/tpci200: remove TPCI200_SHORTNAME constant Staging: ipack: remove board_name and bus_name fields from struct ipack_device Staging: ipack: improve the register of a bus and a device in the bus. staging: comedi: cleanup all the comedi_driver 'detach' functions staging: comedi: remove all 'default N' in Kconfig staging: line6/config.h: Delete unused header staging: gdm72xx depends on NET staging: gdm72xx: Set up parent link in sysfs for gdm72xx devices staging: drm/omap: initial dmabuf/prime import support staging: drm/omap: dmabuf/prime mmap support pstore/ram: Add ECC support pstore/ram: Switch to persistent_ram routines ...
2012-05-22Merge tag 'usb-3.5-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB 3.5-rc1 changes from Greg Kroah-Hartman: "Here is the big USB 3.5-rc1 pull request for the 3.5-rc1 merge window. It's touches a lot of different parts of the kernel, all USB drivers, due to some API cleanups (getting rid of the ancient err() macro) and some changes that are needed for USB 3.0 power management updates. There are also lots of new drivers, pimarily gadget, but others as well. We deleted a staging driver, which was nice, and finally dropped the obsolete usbfs code, which will make Al happy to never have to touch that again. There were some build errors in the tree that linux-next found a few days ago, but those were fixed by the most recent changes (all were due to us not building with CONFIG_PM disabled.) Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" * tag 'usb-3.5-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (477 commits) xhci: Fix DIV_ROUND_UP compile error. xhci: Fix compile with CONFIG_USB_SUSPEND=n USB: Fix core compile with CONFIG_USB_SUSPEND=n brcm80211: Fix compile error for .disable_hub_initiated_lpm. Revert "USB: EHCI: work around bug in the Philips ISP1562 controller" MAINTAINERS: Add myself as maintainer to the USB PHY Layer USB: EHCI: fix command register configuration lost problem USB: Remove races in devio.c USB: ehci-platform: remove update_device USB: Disable hub-initiated LPM for comms devices. xhci: Add Intel U1/U2 timeout policy. xhci: Add infrastructure for host-specific LPM policies. USB: Add macros for interrupt endpoint types. xhci: Reserve one command for USB3 LPM disable. xhci: Some Evaluate Context commands must succeed. USB: Disable USB 3.0 LPM in critical sections. USB: Add support to enable/disable USB3 link states. USB: Allow drivers to disable hub-initiated LPM. USB: Calculate USB 3.0 exit latencies for LPM. USB: Refactor code to set LPM support flag. ... Conflicts: arch/arm/mach-exynos/mach-nuri.c arch/arm/mach-exynos/mach-universal_c210.c drivers/net/wireless/ath/ath6kl/usb.c
2012-05-22Merge tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm soc-specific pinctrl changes from Olof Johansson: "With this, five platforms are moving to the relatively new pinctrl subsystem for their pin management, replacing the older soc specific in-kernel interfaces with common code. There is quite a bit of net addition of code for each platform being added to the pinctrl subsystem. But the payback comes later when adding new boards can be done by only providing new device trees instead." Fix up trivial conflicts in arch/arm/mach-ux500/{Makefile,board-mop500.c} * tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) mtd: nand: gpmi: fix compile error caused by pinctrl call ARM: PRIMA2: select PINCTRL and PINCTRL_SIRF in Kconfig ARM: nomadik: enable PINCTRL_NOMADIK where needed ARM: mxs: enable pinctrl support video: mxsfb: adopt pinctrl support ASoC: mxs-saif: adopt pinctrl support i2c: mxs: adopt pinctrl support mtd: nand: gpmi: adopt pinctrl support mmc: mxs-mmc: adopt pinctrl support serial: mxs-auart: adopt pinctrl support serial: amba-pl011: adopt pinctrl support spi/imx: adopt pinctrl support i2c: imx: adopt pinctrl support can: flexcan: adopt pinctrl support net: fec: adopt pinctrl support ARM: ux500: switch MSP to using pinctrl for pins ARM: ux500: alter MSP registration to return a device pointer ARM: ux500: switch to using pinctrl for uart0 ARM: ux500: delete custom pin control system ARM: ux500: switch over to Nomadik pinctrl driver ...
2012-05-22Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull first batch of arm-soc cleanups from Olof Johansson: "These cleanups are basically all over the place. The idea is to collect changes with minimal impact but large number of changes so we can avoid them from distracting in the diffstat in the other series. A significant number of lines get removed here, in particular because the ixp2000 and ixp23xx platforms get removed. These have never been extremely popular and have fallen into disuse over time with no active maintainer taking care of them. The u5500 soc never made it into a product, so we are removing it from the ux500 platform. Many good cleanups also went into the at91 and omap platforms, as has been the case for a number of releases." Trivial modify-delete conflicts in arch/arm/mach-{ixp2000,ixp23xx} * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (152 commits) ARM: clps711x: Cleanup IRQ handling ARM clps711x: Removed unused header mach/time.h ARM: clps711x: Added note about support EP731x CPU to Kconfig ARM: clps711x: Added missing register definitions ARM: clps711x: Used own subarch directory for store header file Dove: Fix Section mismatch warnings ARM: orion5x: ts78xx debugging changes ARM: orion5x: remove PM dependency from ts78xx ARM: orion5x: ts78xx fix NAND resource off by one ARM: orion5x: ts78xx whitespace cleanups Orion5x: Fix Section mismatch warnings Orion5x: Fix warning: struct pci_dev declared inside paramter list ARM: clps711x: Combine header files into one for clps711x-targets ARM: S3C24XX: Use common macro to define resources on mach-qt2410.c ARM: S3C24XX: Use common macro to define resources on mach-osiris.c ARM: EXYNOS: Adapt to cpuidle core time keeping and irq enable ARM: S5PV210: Use common macro to define resources on mach-smdkv210.c ARM: S5PV210: Use common macro to define resources on dev-audio.c ARM: S5PC100: Use common macro to define resources on dev-audio.c ARM: S5P64X0: Use common macro to define resources on dev-audio.c ...
2012-05-22Merge tag 'maintainers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc updates for MAINTAINERS file from Olof Johansson: "This is a collection of updates to the MAINTAINERS file, separated out mostly to give an overview of what has changed regarding who does what. In particular, at91, orion and prima2 platforms and drivers are updated in this batch." * tag 'maintainers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINER: add some drivers upstreamed in CSR SIRFPRIMA2 maintainership update for the Marvell Orion family of SOCs MAINTAINERS: remove non-responding web link for atmel_usba driver MAINTAINERS: add entry for Atmel timer counter (TC) MAINTAINERS: add entry for Atmel DMA driver MAINTAINERS: add entry for Atmel touch screen ADC controller driver MAINTAINERS: add entry for Atmel isi driver
2012-05-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "New notable features: - The seccomp work from Will Drewry - PR_{GET,SET}_NO_NEW_PRIVS from Andy Lutomirski - Longer security labels for Smack from Casey Schaufler - Additional ptrace restriction modes for Yama by Kees Cook" Fix up trivial context conflicts in arch/x86/Kconfig and include/linux/filter.h * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) apparmor: fix long path failure due to disconnected path apparmor: fix profile lookup for unconfined ima: fix filename hint to reflect script interpreter name KEYS: Don't check for NULL key pointer in key_validate() Smack: allow for significantly longer Smack labels v4 gfp flags for security_inode_alloc()? Smack: recursive tramsmute Yama: replace capable() with ns_capable() TOMOYO: Accept manager programs which do not start with / . KEYS: Add invalidation support KEYS: Do LRU discard in full keyrings KEYS: Permit in-place link replacement in keyring list KEYS: Perform RCU synchronisation on keys prior to key destruction KEYS: Announce key type (un)registration KEYS: Reorganise keys Makefile KEYS: Move the key config into security/keys/Kconfig KEYS: Use the compat keyctl() syscall wrapper on Sparc64 for Sparc32 compat Yama: remove an unused variable samples/seccomp: fix dependencies on arch macros Yama: add additional ptrace scopes ...
2012-05-21Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU changes from Ingo Molnar: "This is the v3.5 RCU tree from Paul E. McKenney: 1) A set of improvements and fixes to the RCU_FAST_NO_HZ feature (with more on the way for 3.6). Posted to LKML: https://lkml.org/lkml/2012/4/23/324 (commits 1-3 and 5), https://lkml.org/lkml/2012/4/16/611 (commit 4), https://lkml.org/lkml/2012/4/30/390 (commit 6), and https://lkml.org/lkml/2012/5/4/410 (commit 7, combined with the other commits for the convenience of the tester). 2) Changes to make rcu_barrier() avoid disrupting execution of CPUs that have no RCU callbacks. Posted to LKML: https://lkml.org/lkml/2012/4/23/322. 3) A couple of commits that improve the efficiency of the interaction between preemptible RCU and the scheduler, these two being all that survived an abortive attempt to allow preemptible RCU's __rcu_read_lock() to be inlined. The full set was posted to LKML at https://lkml.org/lkml/2012/4/14/143, and the first and third patches of that set remain. 4) Lai Jiangshan's algorithmic implementation of SRCU, which includes call_srcu() and srcu_barrier(). A major feature of this new implementation is that synchronize_srcu() no longer disturbs the execution of other CPUs. This work is based on earlier implementations by Peter Zijlstra and Paul E. McKenney. Posted to LKML: https://lkml.org/lkml/2012/2/22/82. 5) A number of miscellaneous bug fixes and improvements which were posted to LKML at: https://lkml.org/lkml/2012/4/23/353 with subsequent updates posted to LKML." * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) rcu: Make rcu_barrier() less disruptive rcu: Explicitly initialize RCU_FAST_NO_HZ per-CPU variables rcu: Make RCU_FAST_NO_HZ handle timer migration rcu: Update RCU maintainership rcu: Make exit_rcu() more precise and consolidate rcu: Move PREEMPT_RCU preemption to switch_to() invocation rcu: Ensure that RCU_FAST_NO_HZ timers expire on correct CPU rcu: Add rcutorture test for call_srcu() rcu: Implement per-domain single-threaded call_srcu() state machine rcu: Use single value to handle expedited SRCU grace periods rcu: Improve srcu_readers_active_idx()'s cache locality rcu: Remove unused srcu_barrier() rcu: Implement a variant of Peter's SRCU algorithm rcu: Improve SRCU's wait_idx() comments rcu: Flip ->completed only once per SRCU grace period rcu: Increment upper bit only for srcu_read_lock() rcu: Remove fast check path from __synchronize_srcu() rcu: Direct algorithmic SRCU implementation rcu: Introduce rcutorture testing for rcu_barrier() timer: Fix mod_timer_pinned() header comment ...
2012-05-21Merge tag 'rdma-for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - Add ocrdma hardware driver for Emulex IB-over-Ethernet adapters - Add generic and mlx4 support for "raw" QPs: allow suitably privileged applications to send and receive arbitrary packets directly to/from the hardware - Add "doorbell drop" handling to the cxgb4 driver - A fairly large batch of qib hardware driver changes - A few fixes for lockdep-detected issues - A few other miscellaneous fixes and cleanups Fix up trivial conflict in drivers/net/ethernet/emulex/benet/be.h. * tag 'rdma-for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (53 commits) RDMA/cxgb4: Include vmalloc.h for vmalloc and vfree IB/mlx4: Fix mlx4_ib_add() error flow IB/core: Fix IB_SA_COMP_MASK macro IB/iser: Fix error flow in iser ep connection establishment IB/mlx4: Increase the number of vectors (EQs) available for ULPs RDMA/cxgb4: Add query_qp support RDMA/cxgb4: Remove kfifo usage RDMA/cxgb4: Use vmalloc() for debugfs QP dump RDMA/cxgb4: DB Drop Recovery for RDMA and LLD queues RDMA/cxgb4: Disable interrupts in c4iw_ev_dispatch() RDMA/cxgb4: Add DB Overflow Avoidance RDMA/cxgb4: Add debugfs RDMA memory stats cxgb4: DB Drop Recovery for RDMA and LLD queues cxgb4: Common platform specific changes for DB Drop Recovery cxgb4: Detect DB FULL events and notify RDMA ULD RDMA/cxgb4: Drop peer_abort when no endpoint found RDMA/cxgb4: Always wake up waiters in c4iw_peer_abort_intr() mlx4_core: Change bitmap allocator to work in round-robin fashion RDMA/nes: Don't call event handler if pointer is NULL RDMA/nes: Fix for the ORD value of the connecting peer ...
2012-05-21Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI misc update from James Bottomley: "The patch contains the usual assortment of driver updates (be2iscsi, bfa, bnx2i, fcoe, hpsa, isci, lpfc, megaraid, mpt2sas, pm8001, sg) plus an assortment of other changes and fixes. Also new is the fact that the isci update is delivered as a git merge (with signed tag)." * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (158 commits) isci: End the RNC resumption wait when the RNC is destroyed. isci: Fixed RNC bug that lost the suspension or resumption during destroy isci: Fix RNC AWAIT_SUSPENSION->INVALIDATING transition. isci: Manage the IREQ_NO_AUTO_FREE_TAG under scic_lock. isci: Remove obviated host callback list. isci: Check IDEV_GONE before performing abort path operations. isci: Restore the ATAPI device RNC management code. isci: Don't wait for an RNC suspend if it's being destroyed. isci: Change the phy control and link reset interface for HW reasons. isci: Added timeouts to RNC suspensions in the abort path. isci: Add protocol indicator for TMF requests. isci: Directly control IREQ_ABORT_PATH_ACTIVE when completing TMFs. isci: Wait for RNC resumption before leaving the abort path. isci: Fix RNC suspend call for SCI_RESUMING state. isci: Manage tag releases differently when aborting tasks. isci: Callbacks to libsas occur under scic_lock and are synchronized. isci: When in the abort path, defeat other resume calls until done. isci: Implement waiting for suspend in the abort path. isci: Make sure all TCs are terminated and cleaned in LUN reset. isci: Manage the LLHANG timer enable/disable per-device. ...
2012-05-21Merge tag 'pci-for-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: - Host bridge cleanups from Yinghai - Disable Bus Master bit on PCI device shutdown (kexec-related) - Stratus ftServer fix - pci_dev_reset() locking fix - IvyBridge graphics erratum workaround * tag 'pci-for-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (21 commits) microblaze/PCI: fix "io_offset undeclared" error x86/PCI: only check for spinlock being held in SMP kernels resources: add resource_overlaps() PCI: fix uninitialized variable 'cap_mask' MAINTAINERS: update PCI git tree and patchwork PCI: disable Bus Master on PCI device shutdown PCI: work around IvyBridge internal graphics FLR erratum x86/PCI: fix unused variable warning in amd_bus.c PCI: move mutex locking out of pci_dev_reset function PCI: work around Stratus ftServer broken PCIe hierarchy x86/PCI: merge pcibios_scan_root() and pci_scan_bus_on_node() x86/PCI: dynamically allocate pci_root_info for native host bridge drivers x86/PCI: embed pci_sysdata into pci_root_info on ACPI path x86/PCI: embed name into pci_root_info struct x86/PCI: add host bridge resource release for _CRS path x86/PCI: refactor get_current_resources() PCI: add host bridge release support PCI: add generic device into pci_host_bridge struct PCI: rename pci_host_bridge() to find_pci_root_bridge() x86/PCI: fix memleak with get_current_resources() ...
2012-05-21MAINTAINERS: Add myself as maintainer to the USB PHY LayerFelipe Balbi
I have been looking over those patches for quite a while. Adding myself officially as the maintainer as agreed with Greg KH. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-21Merge tag 'isci-for-3.5' into miscJames Bottomley
isci update for 3.5 1/ Rework remote-node-context (RNC) handling for proper management of the silicon state machine in error handling and hot-plug conditions. Further details below, suffice to say if the RNC is mismanaged the silicon state machines may lock up. 2/ Refactor the initialization code to be reused for suspend/resume support 3/ Miscellaneous bug fixes to address discovery issues and hardware compatibility. RNC rework details from Jeff Skirvin: In the controller, devices as they appear on a SAS domain (or direct-attached SATA devices) are represented by memory structures known as "Remote Node Contexts" (RNCs). These structures are transferred from main memory to the controller using a set of register commands; these commands include setting up the context ("posting"), removing the context ("invalidating"), and commands to control the scheduling of commands and connections to that remote device ("suspensions" and "resumptions"). There is a similar path to control RNC scheduling from the protocol engine, which interprets the results of command and data transmission and reception. In general, the controller chooses among non-suspended RNCs to find one that has work requiring scheduling the transmission of command and data frames to a target. Likewise, when a target tries to return data back to the initiator, the state of the RNC is used by the controller to determine how to treat the incoming request. As an example, if the RNC is in the state "TX/RX Suspended", incoming SSP connection requests from the target will be rejected by the controller hardware. When an RNC is "TX Suspended", it will not be selected by the controller hardware to start outgoing command or data operations (with certain priority-based exceptions). As mentioned above, there are two sources for management of the RNC states: commands from driver software, and the result of transmission and reception conditions of commands and data signaled by the controller hardware. As an example of the latter, if an outgoing SSP command ends with a OPEN_REJECT(BAD_DESTINATION) status, the RNC state will transition to the "TX Suspended" state, and this is signaled by the controller hardware in the status to the completion of the pending command as well as signaled in a controller hardware event. Examples of the former are included in the patch changelogs. Driver software is required to suspend the RNC in a "TX/RX Suspended" condition before any outstanding commands can be terminated. Failure to guarantee this can lead to a complete hardware hang condition. Earlier versions of the driver software did not guarantee that an RNC was correctly managed before I/O termination, and so operated in an unsafe way. Further, the driver performed unnecessary contortions to preserve the remote device command state and so was more complicated than it needed to be. A simplifying driver assumption is that once an I/O has entered the error handler path without having completed in the target, the requirement on the driver is that all use of the sas_task must end. Beyond that, recovery of operation is dependent on libsas and other components to reset, rediscover and reconfigure the device before normal operation can restart. In the driver, this simplifying assumption meant that the RNC management could be reduced to entry into the suspended state, terminating the targeted I/O request, and resuming the RNC as needed for device-specific management such as an SSP Abort Task or LUN Reset Management request.
2012-05-18floppy: take over maintainershipJiri Kosina
I have fought the current maintainer to the death in the Thunderdome [1] https://lkml.org/lkml/2012/5/16/370 Umm, actually, there is noone taking care of the driver due to lack of real hardware, and I still have some. The driver exposes bugs on emulated/virtualized devices (mostly due to timing), but it's essential to verify the fixes against a real hardware as well (which has been holding back some of the fixes). Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-18Merge branch 'sh/evt2irq-migration' into sh-latestPaul Mundt
Conflicts: arch/sh/kernel/cpu/sh3/setup-sh770x.c arch/sh/kernel/cpu/sh3/setup-sh7710.c arch/sh/kernel/cpu/sh3/setup-sh7720.c arch/sh/kernel/cpu/sh4/setup-sh7750.c arch/sh/kernel/cpu/sh4a/setup-sh7343.c arch/sh/kernel/cpu/sh4a/setup-sh7366.c arch/sh/kernel/cpu/sh4a/setup-sh7722.c arch/sh/kernel/cpu/sh4a/setup-sh7723.c arch/sh/kernel/cpu/sh4a/setup-sh7724.c arch/sh/kernel/cpu/sh4a/setup-sh7757.c arch/sh/kernel/cpu/sh4a/setup-sh7763.c arch/sh/kernel/cpu/sh4a/setup-sh7770.c arch/sh/kernel/cpu/sh4a/setup-sh7785.c arch/sh/kernel/cpu/sh4a/setup-sh7786.c Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2012-05-17MCA: delete all remaining traces of microchannel bus support.Paul Gortmaker
Hardware with MCA bus is limited to 386 and 486 class machines that are now 20+ years old and typically with less than 32MB of memory. A quick search on the internet, and you see that even the MCA hobbyist/enthusiast community has lost interest in the early 2000 era and never really even moved ahead from the 2.4 kernels to the 2.6 series. This deletes anything remaining related to CONFIG_MCA from core kernel code and from the x86 architecture. There is no point in carrying this any further into the future. One complication to watch for is inadvertently scooping up stuff relating to machine check, since there is overlap in the TLA name space (e.g. arch/x86/boot/mca.c). Cc: Thomas Gleixner <tglx@linutronix.de> Cc: James Bottomley <JBottomley@Parallels.com> Cc: x86@kernel.org Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-05-17Merge branch 'v3.5-for-usb' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into usb-next
2012-05-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-05-15Merge remote-tracking branch 'linus/master' into staging/for_v3.5Mauro Carvalho Chehab
* linus/master: (805 commits) tty: Fix LED error return openvswitch: checking wrong variable in queue_userspace_packet() bonding: Fix LACPDU rx_dropped commit. Linux 3.4-rc7 ARM: EXYNOS: fix ctrlbit for exynos5_clk_pdma1 ARM: EXYNOS: use s5p-timer for UniversalC210 board ARM / mach-shmobile: Invalidate caches when booting secondary cores ARM / mach-shmobile: sh73a0 SMP TWD boot regression fix ARM / mach-shmobile: r8a7779 SMP TWD boot regression fix ARM: mach-shmobile: convert ag5evm to use the generic MMC GPIO hotplug helper ARM: mach-shmobile: convert mackerel to use the generic MMC GPIO hotplug helper MAINTAINERS: Add myself as the cpufreq maintainer dm mpath: check if scsi_dh module already loaded before trying to load dm thin: correct module description dm thin: fix unprotected use of prepared_discards list dm thin: reinstate missing mempool_free in cell_release_singleton gpio/exynos: Fix compiler warnings when non-exynos machines are selected gpio: pch9: Use proper flow type handlers powerpc/irq: Fix another case of lazy IRQ state getting out of sync ks8851: Update link status during link change interrupt ... Conflicts: drivers/media/common/tuners/xc5000.c drivers/media/common/tuners/xc5000.h drivers/usb/gadget/uvc_queue.c
2012-05-14MAINTAINERS: Update qib and ipath entries from QLogic to IntelMike Marciniszyn
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2012-05-14Merge branches 'spear/clock' and 'imx/clock' into next/clockArnd Bergmann
Updated to resolve dependencies. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14Merge branch 'spear/13xx' into next/soc2Arnd Bergmann
* spear/13xx: pinctrl: SPEAr1310: Fix pin numbers for clcd_high_res SPEAr: Update MAINTAINERS and Documentation SPEAr13xx: Add defconfig SPEAr13xx: Add compilation support SPEAr13xx: Add dts and dtsi files pinctrl: Add SPEAr13xx pinctrl drivers pinctrl: SPEAr: Create macro for declaring GPIO PINS SPEAr13xx: Add common clock framework support SPEAr13xx: Add source files SPEAr13xx: Add header files Depends on clock, pinctrl and dt branches to go first. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14SPEAr: Update MAINTAINERS and DocumentationViresh Kumar
This patchset updates MAINTAINERS files, makes shiraz as second Maintainer for SPEAr SoCs. It also updates Documentation mostly for SPEAr13xx. Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
2012-05-14Merge branch 'spear/pinctrl' into spear/clockArnd Bergmann
Conflicts: arch/arm/mach-spear3xx/Makefile arch/arm/mach-spear3xx/clock.c arch/arm/mach-spear3xx/include/mach/generic.h arch/arm/mach-spear6xx/clock.c arch/arm/plat-spear/Makefile drivers/pinctrl/core.c This resolves some annoying merge conflicts. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull the v3.5 RCU tree from Paul E. McKenney: 1) A set of improvements and fixes to the RCU_FAST_NO_HZ feature (with more on the way for 3.6). Posted to LKML: https://lkml.org/lkml/2012/4/23/324 (commits 1-3 and 5), https://lkml.org/lkml/2012/4/16/611 (commit 4), https://lkml.org/lkml/2012/4/30/390 (commit 6), and https://lkml.org/lkml/2012/5/4/410 (commit 7, combined with the other commits for the convenience of the tester). 2) Changes to make rcu_barrier() avoid disrupting execution of CPUs that have no RCU callbacks. Posted to LKML: https://lkml.org/lkml/2012/4/23/322. 3) A couple of commits that improve the efficiency of the interaction between preemptible RCU and the scheduler, these two being all that survived an abortive attempt to allow preemptible RCU's __rcu_read_lock() to be inlined. The full set was posted to LKML at https://lkml.org/lkml/2012/4/14/143, and the first and third patches of that set remain. 4) Lai Jiangshan's algorithmic implementation of SRCU, which includes call_srcu() and srcu_barrier(). A major feature of this new implementation is that synchronize_srcu() no longer disturbs the execution of other CPUs. This work is based on earlier implementations by Peter Zijlstra and Paul E. McKenney. Posted to LKML: https://lkml.org/lkml/2012/2/22/82. 5) A number of miscellaneous bug fixes and improvements which were posted to LKML at: https://lkml.org/lkml/2012/4/23/353 with subsequent updates posted to LKML. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-05-13Merge tag 'v3.4-rc7' into for-3.5Mark Brown
Linux 3.4-rc7 Conflicts): drivers/base/regmap/regmap.c (overlap with bug fixes) sound/soc/blackfin/bf5xx-ssm2602.c (overlap with bug fixes)
2012-05-13Merge branch 'spear/clock' into next/clockArnd Bergmann
Viresh Kumar <viresh.kumar@st.com> writes: This is rebased over a (merge of Mike's/clk-next & SPEAr's DT) + Russell's patch: CLKDEV: provide helpers for common clock framework rebased over them. * spear/clock: SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock Conflicts: drivers/clk/Makefile [Arnd: rebased again without the spear/dt branch] Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-12MAINTAINERS: Add myself as the cpufreq maintainerRafael J. Wysocki
Since cpufreq has no official maintainer at the moment, I'm willing to maintain it along some other power management core code I've been maintaining already. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
