path: root/MAINTAINERS
2011-10-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (549 commits) ALSA: hda - Fix ADC input-amp handling for Cx20549 codec ALSA: hda - Keep EAPD turned on for old Conexant chips ALSA: hda/realtek - Fix missing volume controls with ALC260 ASoC: wm8940: Properly set codec->dapm.bias_level ALSA: hda - Fix pin-config for ASUS W90V ALSA: hda - Fix surround/CLFE headphone and speaker pins order ALSA: hda - Fix typo ALSA: Update the sound git tree URL ALSA: HDA: Add new revision for ALC662 ASoC: max98095: Convert codec->hw_write to snd_soc_write ASoC: keep pointer to resource so it can be freed ASoC: sgtl5000: Fix wrong mask in some snd_soc_update_bits calls ASoC: wm8996: Fix wrong mask for setting WM8996_AIF_CLOCKING_2 ASoC: da7210: Add support for line out and DAC ASoC: da7210: Add support for DAPM ALSA: hda/realtek - Fix DAC assignments of multiple speakers ASoC: Use SGTL5000_LINREG_VDDD_MASK instead of hardcoded mask value ASoC: Set sgtl5000->ldo in ldo_regulator_register ASoC: wm8996: Use SND_SOC_DAPM_AIF_OUT for AIF2 Capture ASoC: wm8994: Use SND_SOC_DAPM_AIF_OUT for AIF3 Capture ...
2011-10-27Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-10-27Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: of_mdio: Don't phy_scan_fixups() twice Devicetree: Expand on ARM Primecell binding documentation dt: Add empty of_match_node() macro dt: add empty dt helpers for non-dt build devicetree: fix build error on drivers/tty/serial/altera_jtaguart.c devicetree: Add ARM pl022 spi controller binding doc devicetree: Add ARM pl061 gpio controller binding doc of/irq: of_irq_find_parent: check for parent equal to child MAINTAINERS: update devicetree maintainers dt: add helper to read 64-bit integers tty: use of_match_ptr() for of_match_table entry OF: Add of_match_ptr() macro dt: add empty for_each_child_of_node, of_find_property devicetree: Document Qualcomm and Atmel prefixes serial/imx: add of_alias_get_id() reference back dt: add of_alias_scan and of_alias_get_id devicetree: Add a registry of vendor prefixes
2011-10-26Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1519 commits) staging: et131x: Remove redundant check and return statement staging: et131x: Mainly whitespace changes to appease checkpatch staging: et131x: Remove last of the forward declarations staging: et131x: Remove even more forward declarations staging: et131x: Remove yet more forward declarations staging: et131x: Remove more forward declarations staging: et131x: Remove forward declaration of et131x_adapter_setup staging: et131x: Remove some forward declarations staging: et131x: Remove unused rx_ring.recv_packet_pool staging: et131x: Remove call to find pci pm capability staging: et131x: Remove redundant et131x_reset_recv() call staging: et131x: Remove unused rx_ring.recv_buffer_pool Staging: bcm: Fix three initialization errors in InterfaceDld.c Staging: bcm: Fix coding style issues in InterfaceDld.c staging:iio:dac: Add AD5360 driver staging:iio:trigger:bfin-timer: Fix compile error Staging: vt6655: add some range checks before memcpy() Staging: vt6655: whitespace fixes to iotcl.c Staging: vt6656: add some range checks before memcpy() Staging: vt6656: whitespace cleanups in ioctl.c ... Fix up conflicts in: - drivers/{Kconfig,Makefile}, drivers/staging/{Kconfig,Makefile}: vg driver movement - drivers/staging/brcm80211/brcmfmac/{dhd_linux.c,mac80211_if.c}: driver removal vs now stale changes - drivers/staging/rtl8192e/r8192E_core.c: driver removal vs now stale changes - drivers/staging/et131x/et131*: driver consolidation into one file, tried to do fixups
2011-10-25Merge branch 'pm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm * 'pm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (63 commits) PM / Clocks: Remove redundant NULL checks before kfree() PM / Documentation: Update docs about suspend and CPU hotplug ACPI / PM: Add Sony VGN-FW21E to nonvs blacklist. ARM: mach-shmobile: sh7372 A4R support (v4) ARM: mach-shmobile: sh7372 A3SP support (v4) PM / Sleep: Mark devices involved in wakeup signaling during suspend PM / Hibernate: Improve performance of LZO/plain hibernation, checksum image PM / Hibernate: Do not initialize static and extern variables to 0 PM / Freezer: Make fake_signal_wake_up() wake TASK_KILLABLE tasks too PM / Hibernate: Add resumedelay kernel param in addition to resumewait MAINTAINERS: Update linux-pm list address PM / ACPI: Blacklist Vaio VGN-FW520F machine known to require acpi_sleep=nonvs PM / ACPI: Blacklist Sony Vaio known to require acpi_sleep=nonvs PM / Hibernate: Add resumewait param to support MMC-like devices as resume file PM / Hibernate: Fix typo in a kerneldoc comment PM / Hibernate: Freeze kernel threads after preallocating memory PM: Update the policy on default wakeup settings PM / VT: Cleanup #if defined uglyness and fix compile error PM / Suspend: Off by one in pm_suspend() PM / Hibernate: Include storage keys in hibernation image on s390 ...
2011-10-25Merge branch 'for-next' of git://git.linaro.org/people/triad/linux-pinctrlLinus Torvalds
* 'for-next' of git://git.linaro.org/people/triad/linux-pinctrl: pinctrl/sirf: fix sirfsoc_get_group_pins prototype pinctrl: Don't copy function name when requesting a pin pinctrl: Don't copy pin names when registering them pinctrl: Remove unsafe __refdata pinctrl: get_group_pins() const fixes pinctrl: add a driver for the CSR SiRFprimaII pinmux pinctrl: add a driver for the U300 pinmux drivers: create a pin control subsystem
2011-10-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits) dp83640: free packet queues on remove dp83640: use proper function to free transmit time stamping packets ipv6: Do not use routes from locally generated RAs |PATCH net-next] tg3: add tx_dropped counter be2net: don't create multiple RX/TX rings in multi channel mode be2net: don't create multiple TXQs in BE2 be2net: refactor VF setup/teardown code into be_vf_setup/clear() be2net: add vlan/rx-mode/flow-control config to be_setup() net_sched: cls_flow: use skb_header_pointer() ipv4: avoid useless call of the function check_peer_pmtu TCP: remove TCP_DEBUG net: Fix driver name for mdio-gpio.c ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces ipv4: fix ipsec forward performance regression jme: fix irq storm after suspend/resume route: fix ICMP redirect validation net: hold sock reference while processing tx timestamps tcp: md5: add more const attributes Add ethtool -g support to virtio_net ... Fix up conflicts in: - drivers/net/Kconfig: The split-up generated a trivial conflict with removal of a stale reference to Documentation/networking/net-modules.txt. Remove it from the new location instead. - fs/sysfs/dir.c: Fairly nasty conflicts with the sysfs rb-tree usage, conflicting with Eric Biederman's changes for tagged directories.
2011-10-25Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (260 commits) usb: renesas_usbhs: fixup inconsistent return from usbhs_pkt_push() usb/isp1760: Allow to optionally trigger low-level chip reset via GPIOLIB. USB: gadget: midi: memory leak in f_midi_bind_config() USB: gadget: midi: fix range check in f_midi_out_open() QE/FHCI: fixed the CONTROL bug usb: renesas_usbhs: tidyup for smatch warnings USB: Fix USB Kconfig dependency problem on 85xx/QoirQ platforms EHCI: workaround for MosChip controller bug usb: gadget: file_storage: fix race on unloading USB: ftdi_sio.c: Use ftdi async_icount structure for TIOCMIWAIT, as in other drivers USB: ftdi_sio.c:Fill MSR fields of the ftdi async_icount structure USB: ftdi_sio.c: Fill LSR fields of the ftdi async_icount structure USB: ftdi_sio.c:Fill TX field of the ftdi async_icount structure USB: ftdi_sio.c: Fill the RX field of the ftdi async_icount structure USB: ftdi_sio.c: Basic icount infrastructure for ftdi_sio usb/isp1760: Let OF bindings depend on general CONFIG_OF instead of PPC_OF . USB: ftdi_sio: Support TI/Luminary Micro Stellaris BD-ICDI Board USB: Fix runtime wakeup on OHCI xHCI/USB: Make xHCI driver have a BOS descriptor. usb: gadget: add new usb gadget for ACM and mass storage ...
2011-10-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) mm: memory hotplug: Check if pages are correctly reserved on a per-section basis Revert "memory hotplug: Correct page reservation checking" Update email address for stable patch submission dynamic_debug: fix undefined reference to `__netdev_printk' dynamic_debug: use a single printk() to emit messages dynamic_debug: remove num_enabled accounting dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions uio: Support physical addresses >32 bits on 32-bit systems sysfs: add unsigned long cast to prevent compile warning drivers: base: print rejected matches with DEBUG_DRIVER memory hotplug: Correct page reservation checking memory hotplug: Refuse to add unaligned memory regions remove the messy code file Documentation/zh_CN/SubmitChecklist ARM: mxc: convert device creation to use platform_device_register_full new helper to create platform devices with dma mask docs/driver-model: Update device class docs docs/driver-model: Document device.groups kobj_uevent: Ignore if some listeners cannot handle message dynamic_debug: make netif_dbg() call __netdev_printk() dynamic_debug: make netdev_dbg() call __netdev_printk() ...
2011-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits) MAINTAINERS: linux-m32r is moderated for non-subscribers linux@lists.openrisc.net is moderated for non-subscribers Drop default from "DM365 codec select" choice parisc: Kconfig: cleanup Kernel page size default Kconfig: remove redundant CONFIG_ prefix on two symbols cris: remove arch/cris/arch-v32/lib/nand_init.S microblaze: add missing CONFIG_ prefixes h8300: drop puzzling Kconfig dependencies MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers tty: drop superfluous dependency in Kconfig ARM: mxc: fix Kconfig typo 'i.MX51' Fix file references in Kconfig files aic7xxx: fix Kconfig references to READMEs Fix file references in drivers/ide/ thinkpad_acpi: Fix printk typo 'bluestooth' bcmring: drop commented out line in Kconfig btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888' doc: raw1394: Trivial typo fix CIFS: Don't free volume_info->UNC until we are entirely done with it. treewide: Correct spelling of successfully in comments ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (61 commits) HID: hid-magicmouse: Magic Trackpad has 1 button, not 2 HID: Add device IDs for more SJOY adapters HID: primax: remove spurious dependency HID: support primax keyboards violating USB HID spec HID: usbhid: cancel timer for retry synchronously HID: wacom: Set input bits before registration HID: consolidate MacbookAir 4,1 mappings HID: MacbookAir4,1 and MacbookAir4,2 need entry in hid_mouse_ignore_list[] HID: Add support MacbookAir 4,1 keyboard HID: hidraw: open count should not increase if error HID: hiddev: potential info leak in hiddev_ioctl() HID: multitouch: decide if hid-multitouch needs to handle mt devices HID: add autodetection of multitouch devices HID: "hid-logitech" driver with Logitech Driving Force GT HID: hid-logitech-dj: fix off by one HID: hidraw: protect hidraw_disconnect() better HID: hid-multitouch: add support for the IDEACOM 6650 chip HID: Add full support for Logitech Unifying receivers HID: hidraw: free list for all error in hidraw_open HID: roccat: Kone now reports external profile changes via roccat device ...
2011-10-25ALSA: Update the sound git tree URLTakashi Iwai
Now back to kernel.org but without -2.6 suffix. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-25Merge branches 'acrux', 'logitech', 'multitouch', 'roccat' and 'wiimote' ↵Jiri Kosina
into for-linus
2011-10-25Merge branch 'next' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'next' of git://selinuxproject.org/~jmorris/linux-security: (95 commits) TOMOYO: Fix incomplete read after seek. Smack: allow to access /smack/access as normal user TOMOYO: Fix unused kernel config option. Smack: fix: invalid length set for the result of /smack/access Smack: compilation fix Smack: fix for /smack/access output, use string instead of byte Smack: domain transition protections (v3) Smack: Provide information for UDS getsockopt(SO_PEERCRED) Smack: Clean up comments Smack: Repair processing of fcntl Smack: Rule list lookup performance Smack: check permissions from user space (v2) TOMOYO: Fix quota and garbage collector. TOMOYO: Remove redundant tasklist_lock. TOMOYO: Fix domain transition failure warning. TOMOYO: Remove tomoyo_policy_memory_lock spinlock. TOMOYO: Simplify garbage collector. TOMOYO: Fix make namespacecheck warnings. target: check hex2bin result encrypted-keys: check hex2bin result ...
2011-10-25Merge branch 'staging-next' into Linux 3.1Greg Kroah-Hartman
This was done to resolve a conflict in the drivers/staging/comedi/drivers/ni_labpc.c file that resolved a build bugfix in Linus's tree with a "better" bugfix that was in the staging-next tree that resolved the issue in a more complete manner. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-24Merge branch 'master' of ra.kernel.org:/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2011-10-24Merge commit 'v3.1' into devicetree/nextGrant Likely
2011-10-24Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: fix superpage support in pfn_to_dma_pte() intel-iommu: set iommu_superpage on VM domains to lowest common denominator intel-iommu: fix return value of iommu_unmap() API MAINTAINERS: Update VT-d entry for drivers/pci -> drivers/iommu move intel-iommu: Export a flag indicating that the IOMMU is used for iGFX. intel-iommu: Workaround IOTLB hang on Ironlake GPU intel-iommu: Fix AB-BA lockdep report
2011-10-19ehea: Change maintainer to meThadeu Lima de Souza Cascardo
Breno Leitao has passed the maintainership to me. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Cc: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Breno Leitão <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19MAINTAINERS: Update VT-d entry for drivers/pci -> drivers/iommu moveRoland Dreier
Commit 166e9278a3f9 ("x86/ia64: intel-iommu: move to drivers/iommu/") moved the VT-d driver to drivers/iommu, but left the "F:" line in MAINTAINERS pointing to drivers/pci, which breaks scripts/get_maintainer.pl. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-17MAINTAINERS: can: the mailinglist moved to vger.kernel.orgMarc Kleine-Budde
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-17MANITAINERS: Add Cragganmore reference platform to Wolfson supportMark Brown
2011-10-17MAINTAINERS: Add maintainer for Analog Devices sound CODECsLars-Peter Clausen
The MAINTAINERS entry for the ADI sound CODEC drivers currently only lists the ADI devices-drivers-devel mailing-list. Add myself as additional contact, since I'm the person at ADI who is currently doing most of the work on these drivers. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-17MAINTAINERS: linux-m32r is moderated for non-subscribersPaul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-17linux@lists.openrisc.net is moderated for non-subscribersPaul Bolle
2011-10-16MAINTAINERS: Update linux-pm list addressWANG Cong
Change the linux-pm list address in MAINTAINERS, as it has been moved to vger.kernel.org now. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-10-13drivers: create a pin control subsystemLinus Walleij
This creates a subsystem for handling of pin control devices. These are devices that control different aspects of package pins. Currently it handles pinmuxing, i.e. assigning electronic functions to groups of pins on primarily PGA and BGA type of chip packages which are common in embedded systems. The plan is to also handle other I/O pin control aspects such as biasing, driving, input properties such as schmitt-triggering, load capacitance etc within this subsystem, to remove a lot of ARM arch code as well as feature-creepy GPIO drivers which are implementing the same thing over and over again. This is being done to depopulate the arch/arm/* directory of such custom drivers and try to abstract the infrastructure they all need. See the Documentation/pinctrl.txt file that is part of this patch for more details. ChangeLog v1->v2: - Various minor fixes from Joe's and Stephens review comments - Added a pinmux_config() that can invoke custom configuration with arbitrary data passed in or out to/from the pinmux driver ChangeLog v2->v3: - Renamed subsystem folder to "pinctrl" since we will likely want to keep other pin control such as biasing in this subsystem too, so let us keep to something generic even though we're mainly doing pinmux now. - As a consequence, register pins as an abstract entity separate from the pinmux. The muxing functions will claim pins out of the pin pool and make sure they do not collide. Pins can now be named by the pinctrl core. - Converted the pin lookup from a static array into a radix tree, I agreed with Grant Likely to try to avoid any static allocation (which is crap for device tree stuff) so I just rewrote this to be dynamic, just like irq number descriptors. The platform-wide definition of number of pins goes away - this is now just the sum total of the pins registered to the subsystem. - Make sure mappings with only a function name and no device works properly. ChangeLog v3->v4: - Define a number space per controller instead of globally, Stephen and Grant requested the same thing so now maps need to define target controller, and the radix tree of pin descriptors is a property on each pin controller device. - Add a compulsory pinctrl device entry to the pinctrl mapping table. This must match the pinctrl device, like "pinctrl.0" - Split the file core.c in two: core.c and pinmux.c where the latter carry all pinmux stuff, the core is for generic pin control, and use local headers to access functionality between files. It is now possible to implement a "blank" pin controller without pinmux capabilities. This split will make new additions like pindrive.c, pinbias.c etc possible for combined drivers and chunks of functionality which is a GoodThing(TM). - Rewrite the interaction with the GPIO subsystem - the pin controller descriptor now handles this by defining an offset into the GPIO numberspace for its handled pin range. This is used to look up the apropriate pin controller for a GPIO pin. Then that specific GPIO range is matched 1-1 for the target controller instance. - Fixed a number of review comments from Joe Perches. - Broke out a header file pinctrl.h for the core pin handling stuff that will be reused by other stuff than pinmux. - Fixed some erroneous EXPORT() stuff. - Remove mispatched U300 Kconfig and Makefile entries - Fixed a number of review comments from Stephen Warren, not all of them - still WIP. But I think the new mapping that will specify which function goes to which pin mux controller address 50% of your concerns (else beat me up). ChangeLog v4->v5: - Defined a "position" for each function, so the pin controller now tracks a function in a certain position, and the pinmux maps define what position you want the function in. (Feedback from Stephen Warren and Sascha Hauer). - Since we now need to request a combined function+position from the machine mapping table that connect mux settings to drivers, it was extended with a position field and a name field. The name field is now used if you e.g. need to switch between two mux map settings at runtime. - Switched from a class device to using struct bus_type for this subsystem. Verified sysfs functionality: seems to work fine. (Feedback from Arnd Bergmann and Greg Kroah-Hartman) - Define a per pincontroller list of GPIO ranges from the GPIO pin space that can be handled by the pin controller. These can be added one by one at runtime. (Feedback from Barry Song) - Expanded documentation of regulator_[get|enable|disable|put] semantics. - Fixed a number of review comments from Barry Song. (Thanks!) ChangeLog v5->v6: - Create an abstract pin group concept that can sort pins into named and enumerated groups no matter what the use of these groups may be, one possible usecase is a group of pins being muxed in or so. The intention is however to also use these groups for other pin control activities. - Make it compulsory for pinmux functions to associate with at least one group, so the abstract pin group concept is used to define the groups of pins affected by a pinmux function. The pinmux driver interface has been altered so as to enforce a function to list applicable groups per function. - Provide an optional .group entry in the pinmux machine map so the map can select beteween different available groups to be used with a certain function. - Consequent changes all over the place so that e.g. debugfs present reasonable information about the world. - Drop the per-pin mux (*config) function in the pinmux_ops struct - I was afraid that this would start to be used for things totally unrelated to muxing, we can introduce that to the generic struct pinctrl_ops if needed. I want to keep muxing orthogonal to other pin control subjects and not mix these things up. ChangeLog v6->v7: - Make it possible to have several map entries matching the same device, pin controller and function, but using a different group, and alter the semantics so that pinmux_get() will pick all matching map entries, and store the associated groups in a list. The list will then be iterated over at pinmux_enable()/pinmux_disable() and corresponding driver functions called for each defined group. Notice that you're only allowed to map multiple *groups* to the same { device, pin controller, function } triplet, attempts to map the same device to multiple pin controllers will for example fail. This is hopefully the crucial feature requested by Stephen Warren. - Add a pinmux hogging field to the pinmux mapping entries, and enable the pinmux core to hog pinmux map entries. This currently only works for pinmuxes without assigned devices as it looks now, but with device trees we can look up the corresponding struct device * entries when we register the pinmux driver, and have it hog each pinmux map in turn, for a simple approach to non-dynamic pin muxing. This addresses an issue from Grant Likely that the machine should take care of as much of the pinmux setup as possible, not the devices. By supplying a list of hogs, it can now instruct the core to take care of any static mappings. - Switch pinmux group retrieveal function to grab an array of strings representing the groups rather than an array of unsigned and rewrite accordingly. - Alter debugfs to show the grouplist handled by each pinmux. Also add a list of hogs. - Dynamically allocate a struct pinmux at pinmux_get() and free it at pinmux_put(), then add these to the global list of pinmuxes active as we go along. - Go over the list of pinmux maps at pinmux_get() time and repeatedly apply matches. - Retrieve applicable groups per function from the driver as a string array rather than a unsigned array, then lookup the enumerators. - Make the device to pinmux map a singleton - only allow the mapping table to be registered once and even tag the registration function with __init so it surely won't be abused. - Create a separate debugfs file to view the pinmux map at runtime. - Introduce a spin lock to the pin descriptor struct, lock it when modifying pin status entries. Reported by Stijn Devriendt. - Fix up the documentation after review from Stephen Warren. - Let the GPIO ranges give names as const char * instead of some fixed-length string. - add a function to unregister GPIO ranges to mirror the registration function. - Privatized the struct pinctrl_device and removed it from the <linux/pinctrl/pinctrl.h> API, the drivers do not need to know the members of this struct. It is now in the local header "core.h". - Rename the concept of "anonymous" mux maps to "system" muxes and add convenience macros and documentation. ChangeLog v7->v8: - Delete the leftover pinmux_config() function from the <linux/pinctrl/pinmux.h> header. - Fix a race condition found by Stijn Devriendt in pin_request() ChangeLog v8->v9: - Drop the bus_type and the sysfs attributes and all, we're not on the clear about how this should be used for e.g. userspace interfaces so let us save this for the future. - Use the right name in MAINTAINERS, PIN CONTROL rather than PINMUX - Don't kfree() the device state holder, let the .remove() callback handle this. - Fix up numerous kerneldoc headers to have one line for the function description and more verbose documentation below the parameters ChangeLog v9->v10: - pinctrl: EXPORT_SYMBOL needs export.h, folded in a patch from Steven Rothwell - fix pinctrl_register error handling, folded in a patch from Axel Lin - Various fixes to documentation text so that it's consistent. - Removed pointless comment from drivers/Kconfig - Removed dependency on SYSFS since we removed the bus in v9. - Renamed hopelessly abbreviated pctldev_* functions to the more verbose pinctrl_dev_* - Drop mutex properly when looking up GPIO ranges - Return NULL instead of ERR_PTR() errors on registration of pin controllers, using cast pointers is fragile. We can live without the detailed error codes for sure. Cc: Stijn Devriendt <highguy@gmail.com> Cc: Joe Perches <joe@perches.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Barry Song <21cnbao@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-10-13MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribersPaul Bolle
2011-10-10MAINTAINERS: Update tegra maintainer informationOlof Johansson
A couple of changes to the Tegra maintainership setup: I'm very glad to bring on Stephen Warren on board as a maintainer. The work he has done so far is excellent, and the fact that he works for Nvidia means he has long-term interest in the platform. Erik Gilling did an astounding amount of work on getting things up and running but has been a silent partner on the maintainership side for a while, and is stepping down. Thanks for your contributions so far, Erik. Finally, update the git URL since I'll take over running the main repo for a while. Overall maintainership model isn't changing much at this time: We'll all three review patches as appropriate, and one of us will collect the main repo (me at this time). Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Erik Gilling <konkers@android.com> Acked-by: Colin Cross <ccross@android.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-07Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: net/batman-adv/soft-interface.c
2011-10-05MAINTAINERS: update devicetree maintainersRob Herring
As requested by Grant, adding myself as an additional devicetree maintainer. Also, add Documentation/devicetree to the file list for devicetree. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-03MAINTAINERS: the staging tree dropped the "-2.6" suffixGreg Kroah-Hartman
Now that we are in the 3.x days, "2.6" doesn't make sense. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-30Merge branch 'master' of ↵John W. Linville
git://git.infradead.org/users/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/wl12xx/main.c
2011-09-29staging: nvec: Add myself to MAINTAINERSJulian Andres Klode
I intent to support this code, especially the parts I wrote; and will thus enter as co-maintainer. Signed-off-by: Julian Andres Klode <jak@jak-linux.org> Acked-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-29staging: nvec: add MAINTAINERS infoMarc Dietrich
This adds the relevant info to the MAINTAINERS file so people can find the right person to blame. Signed-off-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Julian Andres Klode <jak@jak-linux.org> Acked-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-29MAINTAINERS: tehuti: Alexander Indenbaum's address bouncesIan Campbell
I got: Generating server: Tehuti.onmicrosoft.com baum@tehutinetworks.net #< #5.1.1 smtp;550 5.1.1 RESOLVER.ADR.RecipNotFound; not found> #SMTP# Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Alexander Indenbaum <baum@tehutinetworks.net> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-27MAINTAINERS: update iwlwifiWey-Yi Guy
Change to iwlwifi.git instead of iwlwifi-2.6.git iwlwifi-2.6.git still works for backward compatibility Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-22Merge branch 'master' of github.com:davem330/netDavid S. Miller
Conflicts: MAINTAINERS drivers/net/Kconfig drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c drivers/net/ethernet/broadcom/tg3.c drivers/net/wireless/iwlwifi/iwl-pci.c drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c drivers/net/wireless/rt2x00/rt2800usb.c drivers/net/wireless/wl12xx/main.c
2011-09-20NFC: move nfc.h from include/net to include/net/nfcIlan Elias
The file nfc.h was moved from include/net to include/net/nfc, since new NFC header files will be added to include/net/nfc. Signed-off-by: Ilan Elias <ilane@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-19Merge branch 'master' of ssh://infradead/~/public_git/wireless-next into ↵John W. Linville
for-davem
2011-09-18Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: (62 commits) ipv6: don't use inetpeer to store metrics for routes. can: ti_hecc: include linux/io.h IRDA: Fix global type conflicts in net/irda/irsysctl.c v2 net: Handle different key sizes between address families in flow cache net: Align AF-specific flowi structs to long ipv4: Fix fib_info->fib_metrics leak caif: fix a potential NULL dereference sctp: deal with multiple COOKIE_ECHO chunks ibmveth: Fix checksum offload failure handling ibmveth: Checksum offload is always disabled ibmveth: Fix issue with DMA mapping failure ibmveth: Fix DMA unmap error pch_gbe: support ML7831 IOH pch_gbe: added the process of FIFO over run error pch_gbe: fixed the issue which receives an unnecessary packet. sfc: Use 64-bit writes for TX push where possible Revert "sfc: Use write-combining to reduce TX latency" and follow-ups bnx2x: Fix ethtool advertisement bnx2x: Fix 578xx link LED bnx2x: Fix XMAC loopback test ...
2011-09-16MAINTAINERS: update ath6klKalle Valo
It's not in staging anymore and I'm the current maintainer. Cc: Luis R. Rodriguez <mcgrof@gmail.com> Cc: Naveen Singh <nvesing@qca.qualcomm.com> Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-15Merge branch 'for-linus' of git://github.com/tiwai/soundLinus Torvalds
* 'for-linus' of git://github.com/tiwai/sound: ALSA: pcm - fix race condition in wait_for_avail() ALSA: HDA: Cirrus - fix "Surround Speaker" volume control name ALSA: hda - Terminate the recursive connection search properly ASoC: Fix trivial build regression in Kirkwood I2S ASoC: Blackfin: bf5xx-ad193x: Fix codec device name ASoC: Fix reporting of partial jack updates ASoC: imx: Fix build warning of unused 'card' variable ASoC: Fix register cache sync register_writable WARN_ONs ASoC: snd_soc_codec_{readable,writable}_register change default to true ASoC: soc-dapm: Fix parameter comment for snd_soc_dapm_free MAINTAINERS: Add some missed Wolfson files ASoC: MPC5200: replace of_device with platform_device
2011-09-14MAINTAINERS: update e-mail address of Benny HalevyBenny Halevy
Acked-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-14Merge git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6Linus Torvalds
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: (25 commits) [SCSI] bnx2i: Fixed the endian on TTT for NOP out transmission [SCSI] libfc: fix referencing to fc_fcp_pkt from the frame pointer via fr_fsp() [SCSI] libfc: block SCSI eh thread for blocked rports [SCSI] libfc: fix fc_eh_host_reset [SCSI] fcoe: Fix deadlock between fip's recv_work and rtnl [SCSI] qla2xxx: Update version number to 8.03.07.07-k. [SCSI] qla2xxx: Set the task attributes after memsetting fcp cmnd. [SCSI] qla2xxx: Correct inadvertent loop state transitions during port-update handling. [SCSI] qla2xxx: Save and restore irq in the response queue interrupt handler. [SCSI] qla2xxx: Double check for command completion if abort mailbox command fails. [SCSI] qla2xxx: Acquire hardware lock while manipulating dsd list. [SCSI] qla2xxx: Fix qla24xx revision check while enabling interrupts. [SCSI] qla2xxx: T10 DIF - Fix incorrect error reporting. [SCSI] qla2xxx: T10 DIF - Handle uninitalized sectors. [SCSI] hpsa: fix physical device lun and target numbering problem [SCSI] hpsa: fix problem that OBDR devices are not detected [SCSI] isci: add version number [SCSI] isci: fix event-get pointer increment [SCSI] isci: dynamic interrupt coalescing [SCSI] isci: Leave requests alone if already terminating. ...
2011-09-15TOMOYO: Bump version.Tetsuo Handa
Tell userland tools that this is TOMOYO 2.5. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <jmorris@namei.org>
2011-09-07HID: wiimote: Add MAINTAINERS entryDavid Herrmann
Add entry to MAINTAINERS and also bump version level as the core driver is feature complete now. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-08-30MAINTAINERS: Update BNA 10G MaintainerIan Campbell
ddutt@brocade.com bounces with 550 "RESOLVER.ADR.RecipNotFound" Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Rasesh Mody <rmody@brocade.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joe Perches <joe@perches.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30MAINTAINERS: Update Cisco VIC driver maintainersIan Campbell
vkolluri@cisco.com bounces and I get "Unknown address error 550". Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Christian Benvenuti <benve@cisco.com> Cc: Roopa Prabhu <roprabhu@cisco.com> Cc: David Wang <dwang2@cisco.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joe Perches <joe@perches.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-30MAINTAINERS: Update ATLX driver maintainersIan Campbell
jie.yang@atheros.com bounces and I get a 550 "Unknown address error". Perhaps they have moved on? Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Chris Snook <chris.snook@gmail.com> Cc: Jie Yang <jie.yang@atheros.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Joe Perches <joe@perches.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
