path: root/MAINTAINERS
2006-12-03Remove long-unmaintained ftape driver subsystem.Jeff Garzik
It's bitrotten, long unmaintained, long hidden under BROKEN_ON_SMP, etc. As scheduled in feature-removal-schedule.txt, and ack'd several times on lkml. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02[PATCH] Atmel MACB ethernet driverHaavard Skinnemoen
Driver for the Atmel MACB on-chip ethernet module. Tested on AVR32/AT32AP7000/ATSTK1000. I've heard rumours that it works with AT91SAM9260 as well, and it may be possible to share some code with the at91_ether driver for AT91RM9200. Hardware documentation can be found in the AT32AP7000 data sheet, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Changes since previous version: * Probe for PHY ID instead of depending on it being provided through platform_data. * Grab initial ethernet address from the MACB registers instead of depending on platform_data. * Set MII/RMII mode correctly. These changes are mostly about making the driver more compatible with the at91 infrastructure. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-02Add NetXen 1G/10G ethernet driver.Amit S. Kale
Signed-off-by: Amit S. Kale <amitkale@netxen.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-30tabify MAINTAINERSJim Cromie
2006-11-22[ARM] 3941/1: [Jornada7xx] - Addition to MAINTAINERSKristoffer Ericson
Adding myself to the MAINTAINERS file. Signed-off-by: Kristoffer Ericson <Kristoffer_e1@hotmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-14[PATCH] usb: MAINTAINERS updatesDavid Brownell
Looks like I still take care of the USB gadget/peripheral framework. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-08[PATCH] Tigran has movedTigran Aivazian
2006-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/hwmon-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/hwmon-2.6: hwmon: Fix debug messages in w83781d hwmon: Let w83781d and lm78 load again w83627ehf: Fix the detection of fan5 k8temp: Documentation update smsc47m1: List the SMSC LPC47M112 as supported hwmon: Fix documentation typos adm9240: Update Grant Coady's email address w83791d: Fix unchecked return status
2006-10-18k8temp: Documentation updateRudolf Marek
Update the documentation for the k8temp driver. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18change pci hotplug subsystem maintainer to KristenKristen Carlson Accardi
Here's a patch adding me to the maintainers file for the pci hotplug subsystem, as we discussed. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-17[PATCH] New MMC maintainerPierre Ossman
I will be taking over after Russell King as the new maintainer of the MMC layer. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-15[NETFILTER]: Update MAINTAINERS entryPatrick McHardy
Patches should go to myself CC netfilter-devel. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-14MSI S270 Laptop support: backlight, wlan, bluetooth statesLennart Poettering
Create a driver to support the platform-specific features of MSI S270 laptops (and maybe other MSI laptops). This driver implements a backlight device for controlling LCD brightness (/sys/class/backlight/msi-laptop-bl/). In addition it allows access to the WLAN and Bluetooth states through a platform driver (/sys/devices/platform/msi-laptop-pf/). Signed-off-by: Lennart Poettering <mzxreary@0pointer.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2006-10-12[GFS2] Update git tree name/locationSteven Whitehouse
The plan is to have two trees. One for bug fixes to be sent on a regular basis (-fixes) and another called -nmw which will contain items queued for the next merge window (hence the name). The -nmw tree will come & go according to need. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-09[SPARC64]: Update MAINTAINERS entry.David S. Miller
ultralinux@vger is deprecated, folks should use sparclinux@vger for both sparc ports. Eddie, Anton, and Jakub haven't been active in sparc64 maintainence for years, so best to remove them as reports do nothing more than fill up their mailboxes :) Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-06[PATCH] MAINTAINERS: take over scx200-* and pc8736* driversJim Cromie
Add MAINTAINERS entries for new scx200_hrt and pc8736x_gpio drivers, and take over maintenance of scx200_gpio, authored by Christer Weinigel (which I've hacked at), who no longer has the hardware. Also take over hwmon/pc87360, authored by Jean Delvare, who's dropped maintenance to dedicate more time to hwmon subsystem. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Christer Weinigel <christer@weinigel.se> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-05[PATCH] x86-64: Calgary IOMMU: Update Jon's contact infoJon Mason
Also add copyright for work done after leaving IBM. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-04[PATCH] The scheduled removal of some OSS driversAdrian Bunk
This patch contains the scheduled removal of OSS drivers that: - have ALSA drivers for the same hardware without known regressions and - whose Kconfig options have been removed in 2.6.17. [michal.k.k.piotrowski@gmail.com: build fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] RCU: CREDITS and MAINTAINERSJosh Triplett
Add MAINTAINERS entry for Read-Copy Update (RCU), listing Dipankar Sarma as maintainer, and giving the URL for Paul McKenney's RCU site. Add MAINTAINERS entry for rcutorture, listing myself as maintainer. Add CREDITS entries for developers of RCU, RCU variants, and rcutorture. Use Paul McKenney's preferred email address in include/linux/rcupdate.h . Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Paul McKenney <paulmck@us.ibm.com> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] mmc: driver for TI FlashMedia card reader - sourceAlex Dubov
Driver for TI Flash Media card reader. At present, only MMC/SD cards are supported. [akpm@osdl.org: cleanups, build fixes] Signed-off-by: Alex Dubov <oakad@yahoo.com> Cc: Daniel Qarras <dqarras@yahoo.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] Remove me from maintainers for serial and mmcRussell King
As advertised earlier. I invite interested parties to take over and add their own entries as they see fit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6: sh64: Remove me from sh64 maintainers. sh64: Update cayman defconfig.
2006-10-03[PATCH] MAINTAINERS: Removes duplicated entryLuiz Fernando N. Capitulino
The 'STABLE BRANCH' entry is duplicated, remove it. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Cc: Greg KH <greg@kroah.com> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03sh64: Remove me from sh64 maintainers.Richard Curnow
Drop Richard as a co-maintainer, as he no longer has interest in working on the platform. Signed-off-by: Richard Curnow <rc@rc0.org.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-09-30[PATCH] Update axboe@suse.de email addressJens Axboe
As people often look for the copyright in files to see who to mail, update the link to a neutral one. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (48 commits) ieee1394: raw1394: arm functions slept in atomic context ieee1394: sbp2: enable auto spin-up for all SBP-2 devices MAINTAINERS: updates to IEEE 1394 subsystem maintainership ieee1394: ohci1394: check for errors in suspend or resume set power state of firewire host during suspend ieee1394: ohci1394: more obvious endianess handling ieee1394: ohci1394: fix endianess bug in debug message ieee1394: sbp2: don't prefer MODE SENSE 10 ieee1394: nodemgr: grab class.subsys.rwsem in nodemgr_resume_ne ieee1394: nodemgr: fix rwsem recursion ieee1394: sbp2: more help in Kconfig ieee1394: sbp2: prevent rare deadlock in shutdown ieee1394: sbp2: update includes ieee1394: sbp2: better handling of transport errors ieee1394: sbp2: recheck node generation in sbp2_update ieee1394: sbp2: safer agent reset in error handlers ieee1394: sbp2: handle "sbp2util_node_write_no_wait failed" CONFIG_PM=n slim: drivers/ieee1394/ohci1394.c ieee1394: safer definition of empty macros video1394: add poll file operation support ...
2006-09-29[PATCH] SuperH list is moderatedMatthew Wilcox
I just got a bounce telling me my contributions aren't welcome. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] network block device is mostly known as "NBD"Pavel Machek
People search maintainers for NBD and then decide it is not maintained. (akpm: ditto LVM. And other things, but I forget what they were) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] SuperH maintainership changeKaz Kojima
I think this is a time to step down from my SUPERH architecture maintainerships. The major development issues for this port seem to shift on the hardwares I can't access and I have no recent activity on kernel. I shouldn't qualify as a maintainer of SUPERH port now and there is no problem because Paul is actively maintaining it. The attached patch drops my name, address and web URL from MAINTAINERS file. Signed-off-by: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Add to MAINTAINERS fileJim Lewis
This patch adds Jim Lewis to the MAINTAINERS file for the Spidernet network driver. Signed-off-by: James K Lewis <jklewis@us.ibm.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28hwmon: New driver for the VIA VT1211Juerg Haefliger
hwmon: New driver for the VIA VT1211 This is a new driver for the VIA VT1211 Super-IO chip. It is a rewrite of the existing vt1211 driver (by Mark D. Studebaker and Lars Ekman) which has been around for a while but never made it into the main kernel tree. It is implemented as a platform driver and therefore requires lm_sensors 2.10.1 to function properly. Signed-off-by: Juerg Haefliger <juergh@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-28Merge branch 'master' into gfs2Steven Whitehouse
2006-09-26Merge branch 'master' into upstreamJeff Garzik
2006-09-26[PATCH] avr32 architectureHaavard Skinnemoen
This adds support for the Atmel AVR32 architecture as well as the AT32AP7000 CPU and the AT32STK1000 development board. AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. The AVR32 architecture is not binary compatible with earlier 8-bit AVR architectures. The AVR32 architecture, including the instruction set, is described by the AVR32 Architecture Manual, available from http://www.atmel.com/dyn/resources/prod_documents/doc32000.pdf The Atmel AT32AP7000 is the first CPU implementing the AVR32 architecture. It features a 7-stage pipeline, 16KB instruction and data caches and a full Memory Management Unit. It also comes with a large set of integrated peripherals, many of which are shared with the AT91 ARM-based controllers from Atmel. Full data sheet is available from http://www.atmel.com/dyn/resources/prod_documents/doc32003.pdf while the CPU core implementation including caches and MMU is documented by the AVR32 AP Technical Reference, available from http://www.atmel.com/dyn/resources/prod_documents/doc32001.pdf Information about the AT32STK1000 development board can be found at http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3918 including a BSP CD image with an earlier version of this patch, development tools (binaries and source/patches) and a root filesystem image suitable for booting from SD card. Alternatively, there's a preliminary "getting started" guide available at http://avr32linux.org/twiki/bin/view/Main/GettingStarted which provides links to the sources and patches you will need in order to set up a cross-compiling environment for avr32-linux. This patch, as well as the other patches included with the BSP and the toolchain patches, is actively supported by Atmel Corporation. [dmccr@us.ibm.com: Fix more pxx_page macro locations] [bunk@stusta.de: fix `make defconfig'] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[NetLabel]: update docs with website informationPaul Moore
Now that all of the supporting pieces of NetLabel have a home at SourceForge update the Kconfig help text and add an entry to the MAINTAINERS file. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[PATCH] softmac: Update MAINTAINERS entryDaniel Drake
This mailing list has been deactivated. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-25[GFS2] Fix up merge of Linus' kernel into GFS2Steven Whitehouse
This fixes up a couple of conflicts when merging up with Linus' latest kernel. This will hopefully allow GFS2 to be more easily merged into forthcoming -mm and FC kernels due to the "one line per header" format now used for the kernel headers. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Conflicts: include/linux/Kbuild include/linux/kernel.h
2006-09-24Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (217 commits) net/ieee80211: fix more crypto-related build breakage [PATCH] Spidernet: add ethtool -S (show statistics) [NET] GT96100: Delete bitrotting ethernet driver [PATCH] mv643xx_eth: restrict to 32-bit PPC_MULTIPLATFORM [PATCH] Cirrus Logic ep93xx ethernet driver r8169: the MMIO region of the 8167 stands behin BAR#1 e1000, ixgb: Remove pointless wrappers [PATCH] Remove powerpc specific parts of 3c509 driver [PATCH] s2io: Switch to pci_get_device [PATCH] gt96100: move to pci_get_device API [PATCH] ehea: bugfix for register access functions [PATCH] e1000 disable device on PCI error drivers/net/phy/fixed: #if 0 some incomplete code drivers/net: const-ify ethtool_ops declarations [PATCH] ethtool: allow const ethtool_ops [PATCH] sky2: big endian [PATCH] sky2: fiber support [PATCH] sky2: tx pause bug fix drivers/net: Trim trailing whitespace [PATCH] ehea: IBM eHEA Ethernet Device Driver ... Manually resolved conflicts in drivers/net/ixgb/ixgb_main.c and drivers/net/sky2.c related to CHECKSUM_HW/CHECKSUM_PARTIAL changes by commit 84fa7933a33f806bbbaae6775e87459b1ec584c0 that just happened to be next to unrelated changes in this update.
2006-09-23[SCSI] zfcp: update maintainers fileSwen Schillig
As Andreas stated he will not maintain the zfcp driver anymore. Instead I will take over the responsibility. Signed-off-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23[SCSI] zfcp: update maintainers fileAndreas Herrmann
Removed myself as maintainer of the s390 zfcp driver -- I will not maintain it any longer. Signed-off-by: Andreas Herrmann <aherrman@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-09-23Merge branch 'mainline' into upstream-linusStefan Richter
2006-09-22Merge branch 'master' into upstreamJeff Garzik
Conflicts: net/ieee80211/ieee80211_crypt_tkip.c net/ieee80211/ieee80211_crypt_wep.c
2006-09-22RDMA/amso1100: Add driver for Ammasso 1100 RNICTom Tucker
Add a driver for the Ammasso 1100 gigabit ethernet RNIC. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22IB/ehca: Add driver for IBM eHCA InfiniBand adaptersHeiko J Schick
Add a driver for IBM GX bus InfiniBand adapters, which are usable with some pSeries/System p systems. Signed-off-by: Heiko J Schick <schickhj.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2006-09-22Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (44 commits) [S390] hypfs crashes with invalid mount option. [S390] cio: subchannel evaluation function operates without lock [S390] cio: always query all paths on path verification. [S390] cio: update path groups on logical CHPID changes. [S390] cio: subchannels in no-path state. [S390] Replace nopav-message on VM. [S390] set modalias for ccw bus uevents. [S390] Get rid of DBG macro. [S390] Use alternative user-copy operations for new hardware. [S390] Make user-copy operations run-time configurable. [S390] Cleanup in signal handling code. [S390] Cleanup in page table related code. [S390] Linux API for writing z/VM APPLDATA Monitor records. [S390] xpram off by one error. [S390] Remove kexec experimental flag. [S390] cleanup appldata. [S390] fix typo in vmcp. [S390] Kernel stack overflow handling. [S390] qdio slsb processing state. [S390] Missing initialization in common i/o layer. ...
2006-09-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (114 commits) [POWERPC] Fix ohare IDE irq workaround on old powermacs [POWERPC] EEH: Power4 systems sometimes need multiple resets. [POWERPC] Include <asm/mmu.h> in arch/powerpc/sysdev/fsl_soc.h for phys_addr_t. [POWERPC] Demacrofy arch/powerpc/platforms/maple/pci.c [POWERPC] Maple U3 HT - reject inappropriate config space access [POWERPC] Fix IPIC pending register assignments [POWERPC] powerpc: fix building gdb against asm/ptrace.h [POWERPC] Remove DISCONTIGMEM cruft from page.h [POWERPC] Merge iSeries i/o operations with the rest [POWERPC] 40x: Fix debug status register defines [POWERPC] Fix compile error in sbc8560 [POWERPC] EEH: support MMIO enable recovery step [POWERPC] EEH: enable MMIO/DMA on frozen slot [POWERPC] EEH: code comment cleanup [POWERPC] EEH: balance pcidev_get/put calls [POWERPC] PPC: Fix xmon stack frame address in backtrace [POWERPC] Add AT_PLATFORM value for Xilinx Virtex-4 FX [POWERPC] Start arch/powerpc/boot code reorganization [POWERPC] Define of_read_ulong helper [POWERPC] iseries: eliminate a couple of warnings ...
2006-09-21Merge branch 'master' into gfs2Steven Whitehouse
