Pull drm fixes from Dave Airlie:
"One intel fix, one rockchip fix, and a bunch of radeon fixes for some
regressions from audio rework and vm stability"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/i915/chv: Implement WaDisableShadowRegForCpd
drm/radeon: fix userptr return value checking (v2)
drm/radeon: check new address before removing old one
drm/radeon: reset BOs address after clearing it.
drm/radeon: fix lockup when BOs aren't part of the VM on release
drm/radeon: add SI DPM quirk for Sapphire R9 270 Dual-X 2G GDDR5
drm/radeon: adjust pll when audio is not enabled
drm/radeon: only enable audio streams if the monitor supports it
drm/radeon: only mark audio as connected if the monitor supports it (v3)
drm/radeon/audio: don't enable packets until the end
drm/radeon: drop dce6_dp_enable
drm/radeon: fix ordering of AVI packet setup
drm/radeon: Use drm_calloc_ab for CS relocs
drm/rockchip: fix error check when getting irq
MAINTAINERS: add entry for Rockchip drm drivers
https://github.com/markyzq/kernel-drm-rockchip into drm-fixes
one fix and maintainers update
* 'drm-next0420' of https://github.com/markyzq/kernel-drm-rockchip:
With my job change kernel work will be "own time"; I'm keeping lguest
and modules (and the virtio standards work), but virtio kernel has to
go.
This makes it clear that Michael is in charge. He's good, but having
me watch over his shoulder won't help.
Good luck Michael!
Pull more power management and ACPI updates from Rafael Wysocki:
"These are fixes mostly (intel_pstate, ACPI core, ACPI EC driver,
cpupower tool), a new CPU ID for the Intel RAPL driver and one
intel_pstate driver improvement that didn't make it to my previous
pull requests due to timing.
Specifics:
- Fix a build warning in the intel_pstate driver showing up in
non-SMP builds (Borislav Petkov)
- Change one of the intel_pstate's P-state selection parameters for
Baytrail and Cherrytrail CPUs to significantly improve performance
at the cost of a small increase in energy consumption (Kristen
Carlson Accardi)
- Fix a NULL pointer dereference in the ACPI EC driver due to an
unsafe list walk in the query handler removal routine (Chris
Bainbridge)
- Get rid of a false-positive lockdep warning in the ACPI container
hot-remove code (Rafael J Wysocki)
- Prevent the ACPI device enumeration code from creating device
objects of a wrong type in some cases (Rafael J Wysocki)
- Add Skylake processors support to the Intel RAPL power capping
driver (Brian Bian)
- Drop the stale MAINTAINERS entry for the ACPI dock driver that is
regarded as part of the ACPI core and maintained along with it now
(Chao Yu)
- Fix cpupower tool breakage caused by a library API change in libpci
3.3.0 (Lucas Stach)"
* tag 'pm+acpi-4.1-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / scan: Add a scan handler for PRP0001
ACPI / scan: Annotate physical_node_lock in acpi_scan_is_offline()
ACPI / EC: fix NULL pointer dereference in acpi_ec_remove_query_handler()
MAINTAINERS: remove maintainship entry of docking station driver
powercap / RAPL: Add support for Intel Skylake processors
cpufreq: intel_pstate: Fix an annoying !CONFIG_SMP warning
intel_pstate: Change the setpoint for Atom params
cpupower: fix breakage from libpci API change
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver updates from Darren Hart:
"This series includes significant updates to the toshiba_acpi driver
and the reintroduction of the dell-laptop keyboard backlight additions
I had to revert previously. Also included are various fixes for
typos, warnings, correctness, and minor bugs.
Specifics:
dell-laptop:
- add support for keyboard backlight.
toshiba_acpi:
- adaptive keyboard, hotkey, USB sleep and charge, and backlight
updates. Update sysfs documentation.
toshiba_bluetooth:
- fix enabling/disabling loop on recent devices
apple-gmux:
- lock iGP IO to protect from vgaarb changes
other:
- Fix typos, clear gcc warnings, clarify pr_* messages, correct
return types, update MAINTAINERS"
* tag 'platform-drivers-x86-v4.1-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (25 commits)
toshiba_acpi: Do not register vendor backlight when acpi_video bl is available
MAINTAINERS: Add me on list of Dell laptop drivers
platform: x86: dell-laptop: Add support for keyboard backlight
Documentation/ABI: Update sysfs-driver-toshiba_acpi entry
toshiba_acpi: Fix pr_* messages from USB Sleep Functions
toshiba_acpi: Update and fix USB Sleep and Charge modes
wmi: Use bool function return values of true/false not 1/0
toshiba_bluetooth: Fix enabling/disabling loop on recent devices
toshiba_bluetooth: Clean up *_add function and disable BT device at removal
toshiba_bluetooth: Add three new functions to the driver
toshiba_acpi: Fix the enabling of the Special Functions
toshiba_acpi: Use the Hotkey Event Type function for keymap choosing
toshiba_acpi: Add Hotkey Event Type function and definitions
x86/wmi: delete unused wmi_data_lock mutex causing gcc warning
apple-gmux: lock iGP IO to protect from vgaarb changes
MAINTAINERS: Add missing Toshiba devices and add myself as maintainer
toshiba_acpi: Update events in toshiba_acpi_notify
intel-oaktrail: Fix trivial typo in comment
thinkpad_acpi: off by one in adaptive_keyboard_hotkey_notify_hotkey()
thinkpad_acpi: signedness bugs getting current_mode
Pull slave-dmaengine updates from Vinod Koul:
- new drivers for:
- Ingenic JZ4780 controller
- APM X-Gene controller
- Freescale RaidEngine device
- Renesas USB Controller
- remove device_alloc_chan_resources dummy handlers
- sh driver cleanups for peri peri and related emmc and asoc patches
as well
- fixes and enhancements spread over the drivers
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (59 commits)
dmaengine: dw: don't prompt for DW_DMAC_CORE
dmaengine: shdmac: avoid unused variable warnings
dmaengine: fix platform_no_drv_owner.cocci warnings
dmaengine: pch_dma: fix memory leak on failure path in pch_dma_probe()
dmaengine: at_xdmac: unlock spin lock before return
dmaengine: xgene: devm_ioremap() returns NULL on error
dmaengine: xgene: buffer overflow in xgene_dma_init_channels()
dmaengine: usb-dmac: Fix dereferencing freed memory 'desc'
dmaengine: sa11x0: report slave capabilities to upper layers
dmaengine: vdma: Fix compilation warnings
dmaengine: fsl_raid: statify fsl_re_chan_probe
dmaengine: Driver support for FSL RaidEngine device.
dmaengine: xgene_dma_init_ring_mngr() can be static
Documentation: dma: Add documentation for the APM X-Gene SoC DMA device DTS binding
arm64: dts: Add APM X-Gene SoC DMA device and DMA clock DTS nodes
dmaengine: Add support for APM X-Gene SoC DMA engine driver
dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver
dmaengine: renesas,usb-dmac: Add device tree bindings documentation
dmaengine: edma: fixed wrongly initialized data parameter to the edma callback
dmaengine: ste_dma40: fix implicit conversion
* acpi-dock:
* acpi-ec:
* acpi-scan:
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA updates from Roland Dreier:
- IPoIB fixes from Doug Ledford and Erez Shitrit
- iSER updates from Sagi Grimberg
- mlx4 GUID handling changes from Yishai Hadas
- other misc fixes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (51 commits)
mlx5: wrong page mask if CONFIG_ARCH_DMA_ADDR_T_64BIT enabled for 32Bit architectures
IB/iser: Rewrite bounce buffer code path
IB/iser: Bump version to 1.6
IB/iser: Remove code duplication for a single DMA entry
IB/iser: Pass struct iser_mem_reg to iser_fast_reg_mr and iser_reg_sig_mr
IB/iser: Modify struct iser_mem_reg members
IB/iser: Make fastreg pool cache friendly
IB/iser: Move PI context alloc/free to routines
IB/iser: Move fastreg descriptor pool get/put to helper functions
IB/iser: Merge build page-vec into register page-vec
IB/iser: Get rid of struct iser_rdma_regd
IB/iser: Remove redundant assignments in iser_reg_page_vec
IB/iser: Move memory reg/dereg routines to iser_memory.c
IB/iser: Don't pass ib_device to fall_to_bounce_buff routine
IB/iser: Remove a redundant struct iser_data_buf
IB/iser: Remove redundant cmd_data_len calculation
IB/iser: Fix wrong calculation of protection buffer length
IB/iser: Handle fastreg/local_inv completion errors
IB/iser: Fix unload during ep_poll wrong dereference
ib_srpt: convert printk's to pr_* functions
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"These fix an ia64 regression caused by tighter resource checking we
merged during the merge window and remove an invalid email address
from MAINTAINERS.
Resource management:
- ia64: Treat all Address Space Descriptors as windows (Bjorn Helgaas)
Miscellaneous:
- MAINTAINERS: Remove Mohit Kumar (email bounces) (Bjorn Helgaas)"
* tag 'pci-v4.1-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
ia64/PCI: Treat all host bridge Address Space Descriptors (even consumers) as windows
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Some virtio internal cleanups, a new virtio device "virtio input", and
a change to allow the legacy virtio balloon.
Most excitingly, some lguest work! No seriously, I got some cleanup
patches"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio: drop virtio_device_is_legacy_only
virtio_pci: support non-legacy balloon devices
virtio_mmio: support non-legacy balloon devices
virtio_ccw: support non-legacy balloon devices
virtio: balloon might not be a legacy device
virtio_balloon: transitional interface
virtio_ring: Update weak barriers to use dma_wmb/rmb
virtio_pci_modern: switch to type-safe io accessors
virtio_pci_modern: type-safe io accessors
lguest: handle traps on the "interrupt suppressed" iret instruction.
virtio: drop a useless config read
virtio_config: reorder functions
Add virtio-input driver.
lguest: suppress interrupts for single insn, not range.
lguest: simplify lguest_iret
lguest: rename i386_head.S in the comments
lguest: explicitly set miscdevice's private_data NULL
lguest: fix pending interrupt test.
Pull ARM SoC multiplatform code changes from Olof Johansson:
"The changes here belong to two main platforms:
- Atmel At91 is flipping the bit and going multiplatform. This
includes some cleanups and removal of code, and the final flip of
config dependencies
- Shmobile has several platforms that are going multiplatform, but
this branch also contains a bunch of cleanups that they weren't
able to keep separate in a good way. THere's also a removal of one
of their SoCs and the corresponding boards (sh7372 and mackerel)"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits)
ARM: at91/pm: move AT91_MEMCTRL_* to pm.h
ARM: at91/pm: move the standby functions to pm.c
ARM: at91: fix pm_suspend.S compilation when ARMv6 is selected
ARM: at91: add a Kconfig dependency on multi-platform
ARM: at91: drop AT91_TIMER_HZ
ARM: at91: remove hardware.h
ARM: at91: remove SoC headers
ARM: at91: remove useless mach/cpu.h
ARM: at91: remove unused headers
ARM: at91: switch at91_dt_defconfig to multiplatform
ARM: at91: switch to multiplatform
ARM: shmobile: r8a7778: enable multiplatform target
ARM: shmobile: bockw: add sound to DT
ARM: shmobile: r8a7778: add sound to DT
ARM: shmobile: bockw: add devices hooked up to i2c0 to DT
DT: i2c: add trivial binding for OKI ML86V7667 video decoder
ARM: shmobile: r8a7778: common clock framework CPG driver
ARM: shmobile: bockw dts: set extal clock frequency
ARM: shmobile: bockw dts: Move Ethernet node to BSC
ARM: shmobile: r8a73a4: Remove legacy code
Pull ARM SoC driver updates from Olof Johansson:
"Driver updates for v4.1. Some of these are for drivers/soc, where we
find more and more SoC-specific drivers these days. Some are for
other driver subsystems where we have received acks from the
appropriate maintainers.
The larger parts of this branch are:
- MediaTek support for their PMIC wrapper interface, a high-level
interface for talking to the system PMIC over a dedicated I2C
interface.
- Qualcomm SCM driver has been moved to drivers/firmware. It's used
for CPU up/down and needs to be in a shared location for arm/arm64
common code.
- cleanup of ARM-CCI PMU code.
- another set of cleanusp to the OMAP GPMC code"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (43 commits)
soc/mediatek: Remove unused variables
clocksource: atmel-st: select MFD_SYSCON
soc: mediatek: Add PMIC wrapper for MT8135 and MT8173 SoCs
arm-cci: Fix CCI PMU event validation
arm-cci: Split the code for PMU vs driver support
arm-cci: Get rid of secure transactions for PMU driver
arm-cci: Abstract the CCI400 PMU specific definitions
arm-cci: Rearrange code for splitting PMU vs driver code
drivers: cci: reject groups spanning multiple HW PMUs
ARM: at91: remove useless include
clocksource: atmel-st: remove mach/hardware dependency
clocksource: atmel-st: use syscon/regmap
ARM: at91: time: move the system timer driver to drivers/clocksource
ARM: at91: properly initialize timer
ARM: at91: at91rm9200: remove deprecated arm_pm_restart
watchdog: at91rm9200: implement restart handler
watchdog: at91rm9200: use the system timer syscon
mfd: syscon: Add atmel system timer registers definition
ARM: at91/dt: declare atmel,at91rm9200-st as a syscon
soc: qcom: gsbi: Add support for ADM CRCI muxing
Pull ARM DT updates from Olof Johansson:
"As always, this tends to be one of our bigger branches. There are
lots of updates this release, but not that many jumps out as something
that needs more detailed coverage. Some of the highlights are:
- DTs for the new Annapurna Labs Alpine platform
- more graphics DT pieces falling into place on Exynos, bridges,
clocks.
- plenty of DT updates for Qualcomm platforms for various IP blocks
- some churn on Tegra due to switch-over to tool-generated pinctrl
data
- misc fixes and updates for Atmel at91 platforms
- various DT updates to add IP block support on Broadcom's Cygnus
platforms
- more updates for Renesas platforms as DT support is added for
various IP blocks (IPMMU, display, audio, etc)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (231 commits)
ARM: dts: alpine: add internal pci
Revert "ARM: dts: mt8135: Add pinctrl/GPIO/EINT node for mt8135."
ARM: mvebu: use 0xf1000000 as internal registers on Armada 370 DB
ARM: dts: qcom: Add idle state device nodes for 8064
ARM: dts: qcom: Add idle states device nodes for 8084
ARM: dts: qcom: Add idle states device nodes for 8974/8074
ARM: dts: qcom: Update power-controller device node for 8064 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8084 Krait CPUs
ARM: dts: qcom: Add power-controller device node for 8074 Krait CPUs
devicetree: bindings: Document qcom,idle-states
devicetree: bindings: Update qcom,saw2 node bindings
dt-bindings: Add #defines for MSM8916 clocks and resets
arm: dts: qcom: Add LPASS Audio HW to IPQ8064 device tree
arm: dts: qcom: Add APQ8084 chipset SPMI PMIC's nodes
arm: dts: qcom: Add 8x74 chipset SPMI PMIC's nodes
arm: dts: qcom: Add SPMI PMIC Arbiter nodes for APQ8084 and MSM8974
arm: dts: qcom: Add LCC nodes
arm: dts: qcom: Add TCSR support for MSM8960
arm: dts: qcom: Add TCSR support for MSM8660
arm: dts: qcom: Add TCSR support for IPQ8064
Pull ARM SoC platform updates from Olof Johansson:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. In this case, that includes:
- support for the new Annapurna Labs "Alpine" platform
- a rework greatly simplifying adding new platform support to the
MCPM subsystem (Multi-cluster power management)
- cpuidle and PM improvements for Exynos3250
- misc updates for Renesas, OMAP, Meson, i.MX. Some of these could
have gone in other branches but ended up here for various reasons"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
ARM: alpine: add support for generic pci
ARM: Exynos: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: migrate DCSCB to the new MCPM backend abstraction
ARM: vexpress: DCSCB: tighten CPU validity assertion
ARM: vexpress: migrate TC2 to the new MCPM backend abstraction
ARM: MCPM: move the algorithmic complexity to the core code
ARM: EXYNOS: allow cpuidle driver usage on Exynos3250 SoC
ARM: EXYNOS: add AFTR mode support for Exynos3250
ARM: EXYNOS: add code for setting/clearing boot flag
ARM: EXYNOS: fix CPU1 hotplug on Exynos3250
ARM: S3C64XX: Use fixed IRQ bases to avoid conflicts on Cragganmore
ARM: cygnus: fix const declaration bcm_cygnus_dt_compat
ARM: DRA7: hwmod: Fix the hwmod class for GPTimer4
ARM: DRA7: hwmod: Add data for GPTimers 13 through 16
ARM: EXYNOS: Remove left over 'extra_save'
ARM: EXYNOS: Constify exynos_pm_data array
ARM: EXYNOS: use static in suspend.c
ARM: EXYNOS: Use platform device name as power domain name
ARM: EXYNOS: add support for async-bridge clocks for pm_domains
ARM: omap-device: add missed callback for suspend-to-disk
Pull ARM SoC cleanups from Olof Johansson:
"We've got a fairly large cleanup branch this time. The bulk of this
is removal of non-DT platforms of several flavors:
- Atmel at91 platforms go full-DT, with removal of remaining
board-file based support
- OMAP removes legacy board files for three more platforms
- removal of non-DT mach-msm, newer Qualcomm platforms now live in
mach-qcom
- Freescale i.MX25 also removes non-DT platform support"
Most of the rest of the changes here are fallout from the above, i.e. for
example removal of drivers that now lack platforms, etc.
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits)
mmc: Remove msm_sdcc driver
gpio: Remove gpio-msm-v1 driver
ARM: Remove mach-msm and associated ARM architecture code
ARM: shmobile: cpuidle: Remove the pointless default driver
ARM: davinci: dm646x: Add interrupt resource for McASPs
ARM: davinci: irqs: Correct McASP1 TX interrupt definition for DM646x
ARM: davinci: dm646x: Clean up the McASP DMA resources
ARM: davinci: devices-da8xx: Add support for McASP2 on da830
ARM: davinci: devices-da8xx: Clean up and correct the McASP device creation
ARM: davinci: devices-da8xx: Add interrupt resource to McASP structs
ARM: davinci: devices-da8xx: Add resource name for the McASP DMA request
ARM: OMAP2+: Remove legacy support for omap3 TouchBook
ARM: OMAP3: Remove legacy support for devkit8000
ARM: OMAP3: Remove legacy support for EMA-Tech Stalker board
ARM: shmobile: Consolidate the pm code for R-Car Gen2
ARM: shmobile: r8a7791: Correct SYSCIER value
ARM: shmobile: r8a7790: Correct SYSCIER value
ARM: at91: remove old setup
ARM: at91: sama5d4: remove useless map_io
ARM: at91: sama5 use SoC detection infrastructure
Pull ARM SoC fixes from Olof Johansson:
"Here's the usual "low-priority fixes that didn't make it into the last
few -rcs, with a twist: We had a fixes pull request that I didn't send
in time to get into 4.0, so we'll send some of them to Greg for
-stable as well.
Contents here is as usual not all that controversial:
- a handful of randconfig fixes from Arnd, in particular for older
Samsung platforms
- Exynos fixes, !SMP building, DTS updates for MMC and lid switch
- Kbuild fix to create output subdirectory for DTB files
- misc minor fixes for OMAP"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
ARM: at91/dt: sama5d3 xplained: add phy address for macb1
kbuild: Create directory for target DTB
ARM: mvebu: Disable CPU Idle on Armada 38x
ARM: DRA7: Enable Cortex A15 errata 798181
ARM: dts: am57xx-beagle-x15: Add thermal map to include fan and tmp102
ARM: dts: DRA7: Add bandgap and related thermal nodes
bus: ocp2scp: SYNC2 value should be changed to 0x6
ARM: dts: am4372: Add "ti,am437x-ocp2scp" as compatible string for OCP2SCP
ARM: OMAP2+: remove superfluous NULL pointer check
ARM: EXYNOS: Fix build breakage cpuidle on !SMP
ARM: dts: fix lid and power pin-functions for exynos5250-spring
ARM: dts: fix mmc node updates for exynos5250-spring
ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688
MAINTAINERS: add OMAP defconfigs under OMAP SUPPORT
ARM: OMAP1: PM: fix some build warnings on 1510-only Kconfigs
ARM: cns3xxx: don't export static symbol
ARM: S3C24XX: avoid a Kconfig warning
ARM: S3C24XX: fix header file inclusions
ARM: S3C24XX: fix building without PM_SLEEP
ARM: S3C24XX: use SAMSUNG_WAKEMASK for s3c2416
Email to Mohit Kumar <mohit.kumar@st.com> has been bouncing, so remove the
address from MAINTAINERS and add an entry in CREDITS.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull more input subsystem updates from Dmitry Torokhov:
- an update to Atmel MXT driver that makes it functional on Google
Pixel 2 boxes (both touchpad and touchscreen)
- a new VMware VMMouse driver that should allow us drop X vmmouse
driver that requires root privileges (since it accesses ioports)
- XBox One controllers now support force feedback (rumble)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: lm8333 - fix broken email address
Input: cyapa - fix setting suspend scan rate
Input: elan_i2c - fix calculating number of x and y traces.
Input: elan_i2c - report hovering contacts
Input: elants_i2c - zero-extend hardware ID in firmware name
Input: alps - document separate pointstick button bits for V2 devices
Input: atmel_mxt_ts - add support for Google Pixel 2
Input: xpad - add rumble support for Xbox One controller
Input: ff-core - use new debug macros
Input: add vmmouse driver
Input: elan_i2c - adjust for newer firmware pressure reporting
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- a new frontend driver for new ATSC devices: lgdt3306a
- a new sensor driver: ov2659
- a new platform driver: xilinx
- the m88ts2022 tuner driver was merged at ts2020 driver
- the media controller gained experimental support for DVB and hybrid
devices
- lots of random cleanups, fixes and improvements on media drivers
* tag 'media/v4.1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (404 commits)
[media] uvcvideo: add support for VIDIOC_QUERY_EXT_CTRL
[media] uvcvideo: fix cropcap v4l2-compliance failure
[media] media: omap3isp: remove unused clkdev
[media] coda: Add tracing support
[media] coda: drop dma_sync_single_for_device in coda_bitstream_queue
[media] coda: fix fill bitstream errors in nonstreaming case
[media] coda: call SEQ_END when the first queue is stopped
[media] coda: fail to start streaming if userspace set invalid formats
[media] coda: remove duplicate error messages for buffer allocations
[media] coda: move parameter buffer in together with context buffer allocation
[media] coda: allocate bitstream buffer from REQBUFS, size depends on the format
[media] coda: allocate per-context buffers from REQBUFS
[media] coda: use strlcpy instead of snprintf
[media] coda: bitstream payload is unsigned
[media] coda: fix double call to debugfs_remove
[media] coda: check kasprintf return value in coda_open
[media] coda: bitrate can only be set in kbps steps
[media] v4l2-mem2mem: no need to initialize b in v4l2_m2m_next_buf and v4l2_m2m_buf_remove
[media] s5p-mfc: set allow_zero_bytesused flag for vb2_queue_init
[media] coda: set allow_zero_bytesused flag for vb2_queue_init
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver patchset for 4.1-rc1.
Lots of different driver subsystem updates here, nothing major, full
details are in the shortlog.
All of this has been in linux-next for a while"
* tag 'char-misc-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (133 commits)
mei: trace: remove unused TRACE_SYSTEM_STRING
DTS: ARM: OMAP3-N900: Add lis3lv02d support
Documentation: DT: lis302: update wakeup binding
lis3lv02d: DT: add wakeup unit 2 and wakeup threshold
lis3lv02d: DT: use s32 to support negative values
Drivers: hv: hv_balloon: correctly handle num_pages>INT_MAX case
Drivers: hv: hv_balloon: correctly handle val.freeram<num_pages case
mei: replace check for connection instead of transitioning
mei: use mei_cl_is_connected consistently
mei: fix mei_poll operation
hv_vmbus: Add gradually increased delay for retries in vmbus_post_msg()
Drivers: hv: hv_balloon: survive ballooning request with num_pages=0
Drivers: hv: hv_balloon: eliminate jumps in piecewiese linear floor function
Drivers: hv: hv_balloon: do not online pages in offline blocks
hv: remove the per-channel workqueue
hv: don't schedule new works in vmbus_onoffer()/vmbus_onoffer_rescind()
hv: run non-blocking message handlers in the dispatch tasklet
coresight: moving to new "hwtracing" directory
coresight-tmc: Adding a status interface to sysfs
coresight: remove the unnecessary configuration coresight-default-sink
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clock framework updates from Michael Turquette:
"The changes to the common clock framework for 4.0 are mostly new clock
drivers and updates to existing ones for feature enhancements and bug
fixes.
There is more churn than usual in the framework core due to the change
to introduce per-user unique struct clk pointers in 4.0. This caused
several regressions to surface, some of which were sent as fixes to
4.0. New generic clock drivers were added for GPIO- and PWM-based
clock controllers.
Additionally the common clk-divider code recieved several fixes to the
way it rounds rates"
* tag 'clk-for-linus-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (91 commits)
clk: check ->determine/round_rate() return value in clk_calc_new_rates
clk: at91: usb: propagate rate modification to the parent clk
clk: samsung: exynos4: Disable ARMCLK down feature on Exynos4210 SoC
clk: don't use __initconst for non-const arrays
clk: at91: change to using endian agnositc IO
clk: clk-gpio-gate: Fix active low
clk: Add PWM clock driver
clk: Add clock driver for mb86s7x
clk: pxa: pxa3xx: add missing os timer clock
clk: tegra: Use the proper parent for plld_dsi
clk: tegra: Use generic tegra_osc_clk_init() on Tegra114
clk: tegra: Model oscillator as clock
clk: tegra: Add peripheral registers for bank Y
clk: tegra: Register the proper number of resets
clk: tegra: Remove needless initializations
clk: tegra: Use consistent indentation
clk: tegra: Various whitespace cleanups
clk: tegra: Enable HDA to HDMI clocks on Tegra124
clk: tegra: Fix a bunch of sparse warnings
clk: tegra: Fix typo tabel -> table
git://people.freedesktop.org/~airlied/linux into v4l_for_linus
* 'drm-next-merged' of git://people.freedesktop.org/~airlied/linux: (9717 commits)
media-bus: Fixup RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus format
hexdump: avoid warning in test function
fs: take i_mutex during prepare_binprm for set[ug]id executables
smp: Fix error case handling in smp_call_function_*()
iommu-common: Fix PARISC compile-time warnings
sparc: Make LDC use common iommu poll management functions
sparc: Make sparc64 use scalable lib/iommu-common.c functions
Break up monolithic iommu table/lock into finer graularity pools and lock
sparc: Revert generic IOMMU allocator.
tools/power turbostat: correct dumped pkg-cstate-limit value
tools/power turbostat: calculate TSC frequency from CPUID(0x15) on SKL
tools/power turbostat: correct DRAM RAPL units on recent Xeon processors
tools/power turbostat: Initial Skylake support
tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for O= option in Makefile
tools/power turbostat: modprobe msr, if needed
tools/power turbostat: dump MSR_TURBO_RATIO_LIMIT2
tools/power turbostat: use new MSR_TURBO_RATIO_LIMIT names
Bluetooth: hidp: Fix regression with older userspace and flags validation
config: Enable NEED_DMA_MAP_STATE by default when SWIOTLB is selected
perf/x86/intel/pt: Fix and clean up error handling in pt_event_add()
That solves several merge conflicts:
Documentation/DocBook/media/v4l/subdev-formats.xml
Documentation/devicetree/bindings/vendor-prefixes.txt
drivers/staging/media/mn88473/mn88473.c
include/linux/kconfig.h
include/uapi/linux/media-bus-format.h
The ones at subdev-formats.xml and media-bus-format.h are not trivial.
That's why we opted to merge from DRM.
Merge a set of fixes that we missed sending in before v4.0 release. These
will also be sent to -stable.
* fixes: (659 commits)
arm64: juno: Fix misleading name of UART reference clock
ARM: dts: sunxi: Remove overclocked/overvoltaged OPP
ARM: dts: sun4i: a10-lime: Override and remove 1008MHz OPP setting
ARM: socfpga: dts: fix spi1 interrupt
ARM: dts: Fix gpio interrupts for dm816x
ARM: dts: dra7: remove ti,hwmod property from pcie phy
ARM: OMAP: dmtimer: disable pm runtime on remove
ARM: OMAP: dmtimer: check for pm_runtime_get_sync() failure
ARM: OMAP2+: Fix socbus family info for AM33xx devices
ARM: dts: omap3: Add missing dmas for crypto
+ Linux 4.0-rc4
The merge is clean, but the arm build fails afterwards,
due to API changes in the regulator tree.
I've included the patch into the merge to fix the build.
Mark Yao looks after the Rockchip drm drivers and should thus also get
patches touching these.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Pull PMEM driver from Ingo Molnar:
"This is the initial support for the pmem block device driver:
persistent non-volatile memory space mapped into the system's physical
memory space as large physical memory regions.
The driver is based on Intel code, written by Ross Zwisler, with fixes
by Boaz Harrosh, integrated with x86 e820 memory resource management
and tidied up by Christoph Hellwig.
Note that there were two other separate pmem driver submissions to
lkml: but apparently all parties (Ross Zwisler, Boaz Harrosh) are
reasonably happy with this initial version.
This version enables minimal support that enables persistent memory
devices out in the wild to work as block devices, identified through a
magic (non-standard) e820 flag and auto-discovered if
CONFIG_X86_PMEM_LEGACY=y, or added explicitly through manipulating the
memory maps via the "memmap=..." boot option with the new, special '!'
modifier character.
Limitations: this is a regular block device, and since the pmem areas
are not struct page backed, they are invisible to the rest of the
system (other than the block IO device), so direct IO to/from pmem
areas, direct mmap() or XIP is not possible yet. The page cache will
also shadow and double buffer pmem contents, etc.
Initial support is for x86"
* 'x86-pmem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
drivers/block/pmem: Fix 32-bit build warning in pmem_alloc()
drivers/block/pmem: Add a driver for persistent memory
x86/mm: Add support for the non-standard protected e820 type
Pull documentation updates from Jonathan Corbet:
"Numerous fixes, the overdue removal of the i2o docs, some new Chinese
translations, and, hopefully, the README fix that will end the flow of
identical patches to that file"
* tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (34 commits)
Documentation/memcg: update memcg/kmem status
Documentation: blackfin: Makefile: Typo building issue
Documentation/vm/pagemap.txt: correct location of page-types tool
Documentation/memory-barriers.txt: typo fix
doc: Add guest_nice column to example output of `cat /proc/stat'
Documentation/kernel-parameters: Move "eagerfpu" to its right place
Documentation: gpio: Update ACPI part of the document to mention _DSD
docs/completion.txt: Various tweaks and corrections
doc: completion: context, scope and language fixes
Documentation:Update Documentation/zh_CN/arm64/memory.txt
Documentation:Update Documentation/zh_CN/arm64/booting.txt
Documentation: Chinese translation of arm64/legacy_instructions.txt
DocBook media: fix broken EIA hyperlink
Documentation: tweak the maintainers entry
README: Change gzip/bzip2 to xz compression format
README: Update version number reference
doc:pci: Fix typo in Documentation/PCI
Documentation: drm: Use '->' when describing access through pointers.
Documentation: Remove mentioning of block barriers
Documentation/email-clients.txt: Fix one grammar mistake, add extra info about TB
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux
Pull devicetree changes from Grant Likely:
"Here are the devicetree changes queued up for v4.1. Nothing really
exciting here. Rob has another few commits for big-endian attached
UARTs, but those will be sent in a separate merge request since they
haven't been as thoroughly tested as this batch.
Here are the highlights:
- lots of unittest cleanup from Frank Rowand
- bugfixes and updates to the of_graph code
- tighten up of_get_mac_address() code
- documentation updates"
* tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux:
of/unittest: Fix of_platform_depopulate test case
of/unittest: early return from test skips tests
of/unittest: breadcrumbs to reduce pain of future maintainers
of/unittest: reduce checkpatch noise - line after declarations
of/unittest: typo in error string
of/unittest: add const where needed
of_net: factor out repetitive code from of_get_mac_address()
drivers/of: Add empty ranges quirk for PA-Semi
of: Allow selection of OF_DYNAMIC and OF_OVERLAY if OF_UNITTEST
of: Empty node & property flag accessors when !OF
of: Explicitly include linux/types.h in of_graph.h
dt-bindings: brcm: rationalize Broadcom documentation naming
of/unittest: replace 'selftest' with 'unittest'
Documentation: rename of_selftest.txt to of_unittest.txt
Documentation: update the of_selftest.txt
dt: OF_UNITTEST make dependency broken
MAINTAINERS: Pantelis Antoniou device tree overlay maintainer
of: Add of_graph_get_port_by_id function
of: Add for_each_endpoint_of_node helper macro
of: Decrement refcount of previous endpoint in of_graph_get_next_endpoint
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.1 development cycle:
- A new GPIO hogging mechanism has been added. This can be used on
boards that want to drive some GPIO line high, low, or set it as
input on boot and then never touch it again. For some embedded
systems this is bliss and simplifies things to a great extent.
- Some API cleanup and closure: gpiod_get_array() and
gpiod_put_array() has been added to get and put GPIOs in bulk as
was possible with the non-descriptor API.
- Encapsulate cross-calls to the pin control subsystem in
<linux/gpio/driver.h>. Now this should be the only header any GPIO
driver needs to include or something is wrong. Cleanups
restricting drivers to this include are welcomed if tested.
- Sort the GPIO Kconfig and split it into submenus, as it was
becoming and unstructured, illogical and unnavigatable mess. I
hope this is easier to follow. Menus that require a certain
subsystem like I2C can now be hidden nicely for example, still
working on others.
- New drivers:
- New driver for the Altera Soft GPIO.
- The F7188x driver now handles the F71869 and F71869A variants.
- The MIPS Loongson driver has been moved to drivers/gpio for
consolidation and cleanup.
- Cleanups:
- The MAX732x is converted to use the GPIOLIB_IRQCHIP
infrastructure.
- The PCF857x is converted to use the GPIOLIB_IRQCHIP
infrastructure.
- Radical cleanup of the OMAP driver.
- Misc:
- Enable the DWAPB GPIO for all architectures. This is a "hard
IP" block from Synopsys which has started to turn up in so
diverse architectures as X86 Quark, ARC and a slew of ARM
systems. So even though it's not an expander, it's generic
enough to be available for all.
- We add a mock GPIO on Crystalcove PMIC after a long discussion
with Daniel Vetter et al, tracing back to the shootout at the
kernel summit where DRM drivers and sub-componentization was
discussed. In this case a mock GPIO is assumed to be the best
compromise gaining some reuse of infrastructure without making
DRM drivers overly complex at the same time. Let's see"
* tag 'gpio-v4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (62 commits)
Revert "gpio: sch: use uapi/linux/pci_ids.h directly"
gpio: dwapb: remove dependencies
gpio: dwapb: enable for ARC
gpio: removing kfree remove functionality
gpio: mvebu: Fix mask/unmask managment per irq chip type
gpio: split GPIO drivers in submenus
gpio: move MFD GPIO drivers under their own comment
gpio: move BCM Kona Kconfig option
gpio: arrange SPI Kconfig symbols alphabetically
gpio: arrange PCI GPIO controllers alphabetically
gpio: arrange I2C Kconfig symbols alphabetically
gpio: arrange Kconfig symbols alphabetically
gpio: ich: Implement get_direction function
gpio: use (!foo) instead of (foo == NULL)
gpio: arizona: drop owner assignment from platform_drivers
gpio: max7300: remove 'ret' variable
gpio: use devm_kzalloc
gpio: x-gene: fix devm_ioremap_resource() check
gpio: loongson: Add Loongson-3A/3B GPIO driver support
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
Add the new list that Mediatek specific patches should also be
directed to.
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Cc: Olof Johansson <olof@lixom.net>
I've noticed that most of the patches for the RTC subsystem are currently
either taken directly by Andrew or going through another maintainer's
tree, quite often without an Acked-by or Reviewed-by tag.
I'd like to propose myself as the RTC subsystem co-maintainer, to mainly
help Alessandro reviewing incoming patches and maintain a subsystem tree
to avoid having the RTC patches going through trees when they have no
particular dependencies.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Pull block driver updates from Jens Axboe:
"This is the block driver pull request for 4.1. As with the core bits,
this is a relatively slow round. This pull request contains:
- Various fixes and cleanups for NVMe, from Alexey Khoroshilov, Chong
Yuan, myself, Keith Busch, and Murali Iyer.
- Documentation and code cleanups for nbd from Markus Pargmann.
- Change of brd maintainer to me, from Ross Zwisler. At least the
email doesn't bounce anymore then.
- Two xen-blkback fixes from Tao Chen"
* 'for-4.1/drivers' of git://git.kernel.dk/linux-block: (23 commits)
NVMe: Meta data handling through submit io ioctl
NVMe: Add translation for block limits
NVMe: Remove check for null
NVMe: Fix error handling of class_create("nvme")
xen-blkback: define pr_fmt macro to avoid the duplication of DRV_PFX
xen-blkback: enlarge the array size of blkback name
nbd: Return error pointer directly
nbd: Return error code directly
nbd: Remove fixme that was already fixed
nbd: Restructure debugging prints
nbd: Fix device bytesize type
nbd: Replace kthread_create with kthread_run
nbd: Remove kernel internal header
Documentation: nbd: Add list of module parameters
Documentation: nbd: Reformat to allow more documentation
NVMe: increase depth of admin queue
nvme: Fix PRP list calculation for non-4k system page size
NVMe: Fix blk-mq hot cpu notification
NVMe: embedded iod mask cleanup
NVMe: Freeze admin queue on device failure
As Rafael suggested, docking station driver is maintained along with the
ACPI core nowadays, so it's better to remove this entry.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
Pull SCSI updates from James Bottomley:
"This is the usual grab bag of driver updates (lpfc, qla2xxx, storvsc,
aacraid, ipr) plus an assortment of minor updates. There's also a
major update to aic1542 which moves the driver into this millenium"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (106 commits)
change SCSI Maintainer email
sd, mmc, virtio_blk, string_helpers: fix block size units
ufs: add support to allow non standard behaviours (quirks)
ufs-qcom: save controller revision info in internal structure
qla2xxx: Update driver version to 8.07.00.18-k
qla2xxx: Restore physical port WWPN only, when port down detected for FA-WWPN port.
qla2xxx: Fix virtual port configuration, when switch port is disabled/enabled.
qla2xxx: Prevent multiple firmware dump collection for ISP27XX.
qla2xxx: Disable Interrupt handshake for ISP27XX.
qla2xxx: Add debugging info for MBX timeout.
qla2xxx: Add serdes read/write support for ISP27XX
qla2xxx: Add udev notification to save fw dump for ISP27XX
qla2xxx: Add message for sucessful FW dump collected for ISP27XX.
qla2xxx: Add support to load firmware from file for ISP 26XX/27XX.
qla2xxx: Fix beacon blink for ISP27XX.
qla2xxx: Increase the wait time for firmware to be ready for P3P.
qla2xxx: Fix crash due to wrong casting of reg for ISP27XX.
qla2xxx: Fix warnings reported by static checker.
lpfc: Update version to 10.5.0.0 for upstream patch set
lpfc: Update copyright to 2015
Merge second patchbomb from Andrew Morton:
- the rest of MM
- various misc bits
- add ability to run /sbin/reboot at reboot time
- printk/vsprintf changes
- fiddle with seq_printf() return value
* akpm: (114 commits)
parisc: remove use of seq_printf return value
lru_cache: remove use of seq_printf return value
tracing: remove use of seq_printf return value
cgroup: remove use of seq_printf return value
proc: remove use of seq_printf return value
s390: remove use of seq_printf return value
cris fasttimer: remove use of seq_printf return value
cris: remove use of seq_printf return value
openrisc: remove use of seq_printf return value
ARM: plat-pxa: remove use of seq_printf return value
nios2: cpuinfo: remove use of seq_printf return value
microblaze: mb: remove use of seq_printf return value
ipc: remove use of seq_printf return value
rtc: remove use of seq_printf return value
power: wakeup: remove use of seq_printf return value
x86: mtrr: if: remove use of seq_printf return value
linux/bitmap.h: improve BITMAP_{LAST,FIRST}_WORD_MASK
MAINTAINERS: CREDITS: remove Stefano Brivio from B43
.mailmap: add Ricardo Ribalda
CREDITS: add Ricardo Ribalda Delgado
This email address isn't working anymore
Consistently use a single tab after the "specifier:" type.
Create zsmalloc doc which explains design concept and stat information.
Signed-off-by: Minchan Kim <minchan@kernel.org>
Cc: Juneho Choi <juno.choi@lge.com>
Cc: Gunho Lee <gunho.lee@lge.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Seth Jennings <sjennings@variantweb.net>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"There have been major modernization with the standard bus: in ALSA
sequencer core and HD-audio. Also, HD-audio receives the regmap
support replacing the in-house cache register cache code. These
changes shouldn't impact the existing behavior, but rather
refactoring.
In addition, HD-audio got the code split to a core library part and
the "legacy" driver parts. This is a preliminary work for adapting
the upcoming ASoC HD-audio driver, and the whole transition is still
work in progress, likely finished in 4.1.
Along with them, there are many updates in ASoC area as usual, too:
lots of cleanups, Intel code shuffling, etc.
Here are some highlights:
ALSA core:
- PCM: the audio timestamp / wallclock enhancement
- PCM: fixes in DPCM management
- Fixes / cleanups of user-space control element management
- Sequencer: modernization using the standard bus
HD-audio:
- Modernization using the standard bus
- Regmap support
- Use standard runtime PM for codec power saving
- Widget-path based power-saving for IDT, VIA and Realtek codecs
- Reorganized sysfs entries for each codec object
- More Dell headset support
ASoC:
- Move of jack registration to the card level
- Lots of ASoC cleanups, mainly moving things from the CODEC level to
the card level
- Support for DAPM routes specified by both the machine driver and DT
- Continuing improvements to rcar
- pcm512x enhacements
- Intel platforms updates
- rt5670 updates / fixes
- New platforms / devices: some non-DSP Qualcomm platforms, Google's
Storm platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC
Misc:
- ice1724: Improved ESI W192M support
- emu10k1: Emu 1010 fixes/enhancement"
* tag 'sound-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits)
ALSA: hda - set GET bit when adding a vendor verb to the codec regmap
ALSA: hda/realtek - Enable the ALC292 dock fixup on the Thinkpad T450
ALSA: hda - Fix another race in runtime PM refcounting
ALSA: hda - Expose codec type sysfs
ALSA: ctl: fix to handle several elements added by one operation for userspace element
ASoC: Intel: fix array_size.cocci warnings
ASoC: n810: Automatically disconnect non-connected pins
ASoC: n810: Consistently pass the card DAPM context to n810_ext_control()
ASoC: davinci-evm: Use card DAPM context to access widgets
ASoC: mop500_ab8500: Use card DAPM context to access widgets
ASoC: wm1133-ev1: Use card DAPM context to access widgets
ASoC: atmel: Improve machine driver compile test coverage
ASoC: atmel: Add dependency to SND_SOC_I2C_AND_SPI where necessary
ALSA: control: Fix a typo of SNDRV_CTL_ELEM_ACCESS_TLV_* with SNDRV_CTL_TLV_OP_*
ALSA: usb-audio: Don't attempt to get Microsoft Lifecam Cinema sample rate
ASoC: rnsd: fix build regression without CONFIG_OF
ALSA: emu10k1: add toggles for E-mu 1010 optical ports
ALSA: ctl: fill identical information to return value when adding userspace elements
ALSA: ctl: fix a bug to return no identical information in info operation for userspace controls
ALSA: ctl: confirm to return all identical information in 'activate' event
Updating the MAINTAINERS file with ocrdma maintainers and their email ids
Signed-off-by: Selvin Xavier <selvin.xavier@emulex.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights for this window:
- improved AVC hashing for SELinux by John Brooks and Stephen Smalley
- addition of an unconfined label to Smack
- Smack documentation update
- TPM driver updates"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (28 commits)
lsm: copy comm before calling audit_log to avoid race in string printing
tomoyo: Do not generate empty policy files
tomoyo: Use if_changed when generating builtin-policy.h
tomoyo: Use bin2c to generate builtin-policy.h
selinux: increase avtab max buckets
selinux: Use a better hash function for avtab
selinux: convert avtab hash table to flex_array
selinux: reconcile security_netlbl_secattr_to_sid() and mls_import_netlbl_cat()
selinux: remove unnecessary pointer reassignment
Smack: Updates for Smack documentation
tpm/st33zp24/spi: Add missing device table for spi phy.
tpm/st33zp24: Add proper wait for ordinal duration in case of irq mode
smack: Fix gcc warning from unused smack_syslog_lock mutex in smackfs.c
Smack: Allow an unconfined label in bringup mode
Smack: getting the Smack security context of keys
Smack: Assign smack_known_web as default smk_in label for kernel thread's socket
tpm/tpm_infineon: Use struct dev_pm_ops for power management
MAINTAINERS: Add Jason as designated reviewer for TPM
tpm: Update KConfig text to include TPM2.0 FIFO chips
tpm/st33zp24/dts/st33zp24-spi: Add dts documentation for st33zp24 spi phy
Pull crypto update from Herbert Xu:
"Here is the crypto update for 4.1:
New interfaces:
- user-space interface for AEAD
- user-space interface for RNG (i.e., pseudo RNG)
New hashes:
- ARMv8 SHA1/256
- ARMv8 AES
- ARMv8 GHASH
- ARM assembler and NEON SHA256
- MIPS OCTEON SHA1/256/512
- MIPS img-hash SHA1/256 and MD5
- Power 8 VMX AES/CBC/CTR/GHASH
- PPC assembler AES, SHA1/256 and MD5
- Broadcom IPROC RNG driver
Cleanups/fixes:
- prevent internal helper algos from being exposed to user-space
- merge common code from assembly/C SHA implementations
- misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (169 commits)
crypto: arm - workaround for building with old binutils
crypto: arm/sha256 - avoid sha256 code on ARMv7-M
crypto: x86/sha512_ssse3 - move SHA-384/512 SSSE3 implementation to base layer
crypto: x86/sha256_ssse3 - move SHA-224/256 SSSE3 implementation to base layer
crypto: x86/sha1_ssse3 - move SHA-1 SSSE3 implementation to base layer
crypto: arm64/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer
crypto: arm64/sha1-ce - move SHA-1 ARMv8 implementation to base layer
crypto: arm/sha2-ce - move SHA-224/256 ARMv8 implementation to base layer
crypto: arm/sha256 - move SHA-224/256 ASM/NEON implementation to base layer
crypto: arm/sha1-ce - move SHA-1 ARMv8 implementation to base layer
crypto: arm/sha1_neon - move SHA-1 NEON implementation to base layer
crypto: arm/sha1 - move SHA-1 ARM asm implementation to base layer
crypto: sha512-generic - move to generic glue implementation
crypto: sha256-generic - move to generic glue implementation
crypto: sha1-generic - move to generic glue implementation
crypto: sha512 - implement base layer for SHA-512
crypto: sha256 - implement base layer for SHA-256
crypto: sha1 - implement base layer for SHA-1
crypto: api - remove instance when test failed
crypto: api - Move alg ref count init to crypto_check_alg
Pull networking updates from David Miller:
1) Add BQL support to via-rhine, from Tino Reichardt.
2) Integrate SWITCHDEV layer support into the DSA layer, so DSA drivers
can support hw switch offloading. From Floria Fainelli.
3) Allow 'ip address' commands to initiate multicast group join/leave,
from Madhu Challa.
4) Many ipv4 FIB lookup optimizations from Alexander Duyck.
5) Support EBPF in cls_bpf classifier and act_bpf action, from Daniel
Borkmann.
6) Remove the ugly compat support in ARP for ugly layers like ax25,
rose, etc. And use this to clean up the neigh layer, then use it to
implement MPLS support. All from Eric Biederman.
7) Support L3 forwarding offloading in switches, from Scott Feldman.
8) Collapse the LOCAL and MAIN ipv4 FIB tables when possible, to speed
up route lookups even further. From Alexander Duyck.
9) Many improvements and bug fixes to the rhashtable implementation,
from Herbert Xu and Thomas Graf. In particular, in the case where
an rhashtable user bulk adds a large number of items into an empty
table, we expand the table much more sanely.
10) Don't make the tcp_metrics hash table per-namespace, from Eric
Biederman.
11) Extend EBPF to access SKB fields, from Alexei Starovoitov.
12) Split out new connection request sockets so that they can be
established in the main hash table. Much less false sharing since
hash lookups go direct to the request sockets instead of having to
go first to the listener then to the request socks hashed
underneath. From Eric Dumazet.
13) Add async I/O support for crytpo AF_ALG sockets, from Tadeusz Struk.
14) Support stable privacy address generation for RFC7217 in IPV6. From
Hannes Frederic Sowa.
15) Hash network namespace into IP frag IDs, also from Hannes Frederic
Sowa.
16) Convert PTP get/set methods to use 64-bit time, from Richard
Cochran.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1816 commits)
fm10k: Bump driver version to 0.15.2
fm10k: corrected VF multicast update
fm10k: mbx_update_max_size does not drop all oversized messages
fm10k: reset head instead of calling update_max_size
fm10k: renamed mbx_tx_dropped to mbx_tx_oversized
fm10k: update xcast mode before synchronizing multicast addresses
fm10k: start service timer on probe
fm10k: fix function header comment
fm10k: comment next_vf_mbx flow
fm10k: don't handle mailbox events in iov_event path and always process mailbox
fm10k: use separate workqueue for fm10k driver
fm10k: Set PF queues to unlimited bandwidth during virtualization
fm10k: expose tx_timeout_count as an ethtool stat
fm10k: only increment tx_timeout_count in Tx hang path
fm10k: remove extraneous "Reset interface" message
fm10k: separate PF only stats so that VF does not display them
fm10k: use hw->mac.max_queues for stats
fm10k: only show actual queues, not the maximum in hardware
fm10k: allow creation of VLAN on default vid
fm10k: fix unused warnings
Pull power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups all over, although there are a few
items that sort of fall into the new feature category.
First off, we have new callbacks for PM domains that should help us to
handle some issues related to device initialization in a better way.
There also is some consolidation in the unified device properties API
area allowing us to use that inferface for accessing data coming from
platform initialization code in addition to firmware-provided data.
We have some new device/CPU IDs in a few drivers, support for new
chips and a new cpufreq driver too.
Specifics:
- Generic PM domains support update including new PM domain callbacks
to handle device initialization better (Russell King, Rafael J
Wysocki, Kevin Hilman)
- Unified device properties API update including a new mechanism for
accessing data provided by platform initialization code (Rafael J
Wysocki, Adrian Hunter)
- ARM cpuidle update including ARM32/ARM64 handling consolidation
(Daniel Lezcano)
- intel_idle update including support for the Silvermont Core in the
Baytrail SOC and for the Airmont Core in the Cherrytrail and
Braswell SOCs (Len Brown, Mathias Krause)
- New cpufreq driver for Hisilicon ACPU (Leo Yan)
- intel_pstate update including support for the Knights Landing chip
(Dasaratharaman Chandramouli, Kristen Carlson Accardi)
- QorIQ cpufreq driver update (Tang Yuantian, Arnd Bergmann)
- powernv cpufreq driver update (Shilpasri G Bhat)
- devfreq update including Tegra support changes (Tomeu Vizoso,
MyungJoo Ham, Chanwoo Choi)
- powercap RAPL (Running-Average Power Limit) driver update including
support for Intel Broadwell server chips (Jacob Pan, Mathias Krause)
- ACPI device enumeration update related to the handling of the
special PRP0001 device ID allowing DT-style 'compatible' property
to be used for ACPI device identification (Rafael J Wysocki)
- ACPI EC driver update including limited _DEP support (Lan Tianyu,
Lv Zheng)
- ACPI backlight driver update including a new mechanism to allow
native backlight handling to be forced on non-Windows 8 systems and
a new quirk for Lenovo Ideapad Z570 (Aaron Lu, Hans de Goede)
- New Windows Vista compatibility quirk for Sony VGN-SR19XN (Chen Yu)
- Assorted ACPI fixes and cleanups (Aaron Lu, Martin Kepplinger,
Masanari Iida, Mika Westerberg, Nan Li, Rafael J Wysocki)
- Fixes related to suspend-to-idle for the iTCO watchdog driver and
the ACPI core system suspend/resume code (Rafael J Wysocki, Chen Yu)
- PM tracing support for the suspend phase of system suspend/resume
transitions (Zhonghui Fu)
- Configurable delay for the system suspend/resume testing facility
(Brian Norris)
- PNP subsystem cleanups (Peter Huewe, Rafael J Wysocki)"
* tag 'pm+acpi-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (74 commits)
ACPI / scan: Fix NULL pointer dereference in acpi_companion_match()
ACPI / scan: Rework modalias creation when "compatible" is present
intel_idle: mark cpu id array as __initconst
powercap / RAPL: mark rapl_ids array as __initconst
powercap / RAPL: add ID for Broadwell server
intel_pstate: Knights Landing support
intel_pstate: remove MSR test
cpufreq: fix qoriq uniprocessor build
ACPI / scan: Take the PRP0001 position in the list of IDs into account
ACPI / scan: Simplify acpi_match_device()
ACPI / scan: Generalize of_compatible matching
device property: Introduce firmware node type for platform data
device property: Make it possible to use secondary firmware nodes
PM / watchdog: iTCO: stop watchdog during system suspend
cpufreq: hisilicon: add acpu driver
ACPI / EC: Call acpi_walk_dep_device_list() after installing EC opregion handler
cpufreq: powernv: Report cpu frequency throttling
intel_idle: Add support for the Airmont Core in the Cherrytrail and Braswell SOCs
intel_idle: Update support for Silvermont Core in Baytrail SOC
PM / devfreq: tegra: Register governor on module init
Pull input subsystem updates from Dmitry Torokhov:
"You will get the following new drivers:
- Qualcomm PM8941 power key drver
- ChipOne icn8318 touchscreen controller driver
- Broadcom iProc touchscreen and keypad drivers
- Semtech SX8654 I2C touchscreen controller driver
ALPS driver now supports newer SS4 devices; Elantech got a fix that
should make it work on some ASUS laptops; and a slew of other
enhancements and random fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits)
Input: alps - non interleaved V2 dualpoint has separate stick button bits
Input: alps - fix touchpad buttons getting stuck when used with trackpoint
Input: atkbd - document "no new force-release quirks" policy
Input: ALPS - make alps_get_pkt_id_ss4_v2() and others static
Input: ALPS - V7 devices can report 5-finger taps
Input: ALPS - add support for SS4 touchpad devices
Input: ALPS - refactor alps_set_abs_params_mt()
Input: elantech - fix absolute mode setting on some ASUS laptops
Input: atmel_mxt_ts - split out touchpad initialisation logic
Input: atmel_mxt_ts - implement support for T100 touch object
Input: cros_ec_keyb - fix clearing keyboard state on wakeup
Input: gscps2 - drop pci_ids dependency
Input: synaptics - allocate 3 slots to keep stability in image sensors
Input: Revert "Revert "synaptics - use dmax in input_mt_assign_slots""
Input: MT - make slot assignment work for overcovered solutions
mfd: tc3589x: enforce device-tree only mode
Input: tc3589x - localize platform data
Input: tsc2007 - Convert msecs to jiffies only once
Input: edt-ft5x06 - remove EV_SYN event report
Input: edt-ft5x06 - allow to setting the maximum axes value through the DT
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull GFS2 updates from Bob Peterson:
"Here is a list of patches we've accumulated for GFS2 for the current
upstream merge window.
Most of the patches fix GFS2 quotas, which were not properly enforced.
There's another that adds me as a GFS2 co-maintainer, and a couple
patches that fix a kernel panic doing splice_write on GFS2 as well as
a few correctness patches"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
gfs2: fix quota refresh race in do_glock()
gfs2: incorrect check for debugfs returns
gfs2: allow fallocate to max out quotas/fs efficiently
gfs2: allow quota_check and inplace_reserve to return available blocks
gfs2: perform quota checks against allocation parameters
GFS2: Move gfs2_file_splice_write outside of #ifdef
GFS2: Allocate reservation during splice_write
GFS2: gfs2_set_acl(): Cache "no acl" as well
Add myself (Bob Peterson) as a maintainer of GFS2
VMMouse enables low-latency mouse-cursor-movements for VMWare and QEMU
guests. By removing the guest cursor and using the host as a guest cursor
the cursor movement appears instant although in reality there is some lag.
To be able to do this, the host's view of the cursor position must exactly
match the guest's view and an absolute pointer device is needed. Enter the
VMMouse. While the VMMouse driver has historically been an Xorg user-space
driver, implementing it as a kernel imput driver enables rootless Xorg and
new compositing display servers for VMware guests.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big staging driver patchset for 4.1-rc1.
There's a lot of patches here, the Outreachy application period
happened during this development cycle, so that means that there was a
lot of cleanup patches accepted. Other than the normal coding style
and sparse fixes here, there are some driver updates and work toward
making some of the drivers into "mergable" shape (like the Unisys
drivers.)
All of these have been in linux-next for a while"
* tag 'staging-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1214 commits)
staging: lustre: orthography & coding style
staging: lustre: lnet: lnet: fix error return code
staging: lustre: fix sparse warning
Revert "Staging: sm750fb: Fix C99 Comments"
Staging: rtl8192u: use correct array for debug output
staging: rtl8192e: Remove dead code
staging: rtl8192e: Comment cleanup (style/format)
staging: rtl8192e: Fix indentation in rtllib_rx_auth_resp()
staging: rtl8192e: Decrease nesting of rtllib_rx_auth_resp()
staging: rtl8192e: Divide rtllib_rx_auth()
staging: rtl8192e: Fix PRINTK_WITHOUT_KERN_LEVEL warnings
staging: rtl8192e: Fix DO_WHILE_MACRO_WITH_TRAILING_SEMICOLON warning
staging: rtl8192e: Fix BRACES warning
staging: rtl8192e: Fix LINE_CONTINUATIONS warning
staging: rtl8192e: Fix UNNECESSARY_PARENTHESES warnings
staging: rtl8192e: remove unused EXPORT_SYMBOL_RSL macro
staging: rtl8192e: Fix RETURN_VOID warnings
staging: rtl8192e: Fix UNNECESSARY_ELSE warning
staging: rtl8723au: Remove unneeded comments
staging: rtl8723au: Use __func__ in trace logs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB driver updates from Greg KH:
"Here's the big USB (and PHY) driver patchset for 4.1-rc1.
Everything here has been in linux-next, and the full details are below
in the shortlog. Nothing major, just the normal round of new
drivers,api updates, and other changes, mostly in the USB gadget area,
as usual"
* tag 'usb-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (252 commits)
drivers/usb/core: devio.c: Removed an uneeded space before tab
usb: dwc2: host: sleep USB_RESUME_TIMEOUT during resume
usb: chipidea: debug: add low power mode check before print registers
usb: chipidea: udc: bypass pullup DP when gadget connect in OTG fsm mode
usb: core: hub: use new USB_RESUME_TIMEOUT
usb: isp1760: hcd: use new USB_RESUME_TIMEOUT
usb: dwc2: hcd: use new USB_RESUME_TIMEOUT
usb: host: sl811: use new USB_RESUME_TIMEOUT
usb: host: r8a66597: use new USB_RESUME_TIMEOUT
usb: host: oxu210hp: use new USB_RESUME_TIMEOUT
usb: host: fusbh200: use new USB_RESUME_TIMEOUT
usb: host: fotg210: use new USB_RESUME_TIMEOUT
usb: host: isp116x: use new USB_RESUME_TIMEOUT
usb: musb: use new USB_RESUME_TIMEOUT
usb: host: uhci: use new USB_RESUME_TIMEOUT
usb: host: ehci: use new USB_RESUME_TIMEOUT
usb: host: xhci: use new USB_RESUME_TIMEOUT
usb: define a generic USB_RESUME_TIMEOUT macro
usb: musb: dsps: fix build on i386 when COMPILE_TEST is set
ehci-hub: use USB_DT_HUB
