path: root/MAINTAINERS
2009-10-01MAINTAINERS: ARM/Palm file patternsJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Tomas Cech <sleep_walker@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24Merge branch 'origin' into for-linusRussell King
Conflicts: MAINTAINERS
2009-09-24Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (21 commits) x86/PCI: make 32 bit NUMA node array int, not unsigned char x86/PCI: default pcibus cpumask to all cpus if it lacks affinity MAINTAINTERS: remove hotplug driver entries PCI: pciehp: remove slot capabilities definitions PCI: pciehp: remove error message definitions PCI: pciehp: remove number field PCI: pciehp: remove hpc_ops PCI: pciehp: remove pci_dev field PCI: pciehp: remove crit_sect mutex PCI: pciehp: remove slot_bus field PCI: pciehp: remove first_slot field PCI: pciehp: remove slot_device_offset field PCI: pciehp: remove hp_slot field PCI: pciehp: remove device field PCI: pciehp: remove bus field PCI: pciehp: remove slot_num_inc field PCI: pciehp: remove num_slots field PCI: pciehp: remove slot_list field PCI: fix VGA arbiter header file PCI: Disable AER with pci=nomsi ... Fixed up trivial conflicts in MAINTAINERS
2009-09-24MAINTAINERS: add Matt Mackall and Herbert Xu to HARDWARE RANDOM NUMBER GENERATORJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge branch 'ixp4xx' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6 * 'ixp4xx' of git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6: Add MAINTAINERS entry for ARM/INTEL IXP4xx arch support. ixp4xx: arch_idle() documentation fixup ixp4xx: timer and clocks cleanups
2009-09-23Merge branch 'sfi-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 * 'sfi-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6: SFI: remove unneeded includes sfi: Remove unused code SFI: Hook PCI MMCONFIG x86: add arch-specific SFI support SFI: add capability to parse ACPI tables SFI: add platform-independent core support SFI: create linux/sfi.h SFI: Simple Firmware Interface - MAINTAINERS, Kconfig
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-23Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Clearly mark ACPI drivers as such i2c: Add driver for SMBus Control Method Interface i2c-pnx: Correct use of request_region/request_mem_region MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665 i2c-piix4: Add AMD SB900 SMBus device ID i2c/chips: Remove deprecated pcf8574 driver i2c/chips: Remove deprecated pca9539 driver i2c/chips: Remove deprecated pcf8575 driver gpio/pcf857x: Copy i2c_device_id from old pcf8574 driver i2c/scx200_acb: Provide more information on bus errors i2c: Provide compatibility links for i2c adapters i2c: Convert i2c adapters to bus devices i2c: Convert i2c clients to a device type i2c/tsl2550: Use combined SMBus transactions i2c-taos-evm: Switch echo off to improve performance i2c: Drop unused i2c_driver.id field
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (142 commits) USB: Fix sysfs paths in documentation USB: skeleton: fix coding style issues. USB: O_NONBLOCK in read path of skeleton USB: make usb-skeleton honor O_NONBLOCK in write path USB: skel_read really sucks royally USB: Add hub descriptor update hook for xHCI USB: xhci: Support USB hubs. USB: xhci: Set multi-TT field for LS/FS devices under hubs. USB: xhci: Set route string for all devices. USB: xhci: Fix command wait list handling. USB: xhci: Change how xHCI commands are handled. USB: xhci: Refactor input device context setup. USB: xhci: Endpoint representation refactoring. USB: gadget: ether needs to select CRC32 USB: fix USBTMC get_capabilities success handling USB: fix missing error check in probing USB: usbfs: add USBDEVFS_URB_BULK_CONTINUATION flag USB: support for autosuspend in sierra while online USB: ehci-dbgp,ehci: Allow dbpg to work with suspend/resume USB: ehci-dbgp,documentation: Documentation updates for ehci-dbgp ...
2009-09-23Merge branch 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-scoreLinus Torvalds
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score: score: update email address in MAINTAINERS. score: Cleanup linker script using new macros. score: Make THREAD_SIZE available to assembly files. score: Make PAGE_SIZE available to assembly.
2009-09-23MAINTAINERS: update for TI OMAP hsmmc driverMadhusudhan Chikkature
Update maintainers entry for TI OMAP HS MMC support. Signed-off-by: Madhusudhan Chikkature <madhu.cr@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23MAINTAINERS: remove dead ncpfs listBartlomiej Zolnierkiewicz
On Saturday 01 August 2009 00:30:39 Mail Delivery Subsystem wrote: > Delivery to the following recipient failed permanently: > > linware@sh.cvut.cz > > Technical details of permanent failure: > Google tried to deliver your message, but it was rejected by the recipient > domain. We recommend contacting the other email provider for further > information about the cause of this error. The error that the other server > returned was: 450 450 <linware@sh.cvut.cz>: Recipient address rejected: > undeliverable address: unknown user: "linware" (state 14). Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23USB: gadget: Update Freescale UDC entry in MAINTAINERSLi Yang
Change the F entry for file rename, and make it also cover fsl_qe_udc driver. Update the name accordingly. Signed-off-by: Li Yang <leoli@freescale.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23score: update email address in MAINTAINERS.Chen Liqin
Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
2009-09-22Merge branch 'master' into for-linusRussell King
2009-09-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits) trivial: fix typo in aic7xxx comment trivial: fix comment typo in drivers/ata/pata_hpt37x.c trivial: typo in kernel-parameters.txt trivial: fix typo in tracing documentation trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c trivial: remove unnecessary semicolons trivial: Fix duplicated word "options" in comment trivial: kbuild: remove extraneous blank line after declaration of usage() trivial: improve help text for mm debug config options trivial: doc: hpfall: accept disk device to unload as argument trivial: doc: hpfall: reduce risk that hpfall can do harm trivial: SubmittingPatches: Fix reference to renumbered step trivial: fix typos "man[ae]g?ment" -> "management" trivial: media/video/cx88: add __init/__exit macros to cx88 drivers trivial: fix typo in CONFIG_DEBUG_FS in gcov doc trivial: fix missing printk space in amd_k7_smp_check trivial: fix typo s/ketymap/keymap/ in comment trivial: fix typo "to to" in multiple files trivial: fix typos in comments s/DGBU/DBGU/ ...
2009-09-22input: add a driver for the Winbond WPCD376I Consumer IR hardwareDavid Härdeman
Add a driver for the the Consumer IR (CIR) functionality of the Winbond WPCD376I chipset (found on e.g. Intel DG45FC motherboards). Signed-off-by: David Härdeman <david@hardeman.nu> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: move ARM lists to infradeadJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: integrate P:/M: linesJoe Perches
A couple of new uses of separate "P: name" "M: address" lines are converted to single line "M: name <address>" Signed-off-by: Joe Perches <joe@perches.com> Cc: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Cc: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: omap: fix regexFelipe Contreras
Otherwise 'arch/arm/*omap*/foo.c' wouldn't match Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22MAINTAINERS: acpi: add 'include/acpi'Felipe Contreras
2009-09-22MAINTAINERS: add IPVS include filesHannes Eder
Signed-off-by: Hannes Eder <heder@google.com> Cc: Joe Perches <joe@perches.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22sdhci: orphan driver and listPierre Ossman
Remove myself as maintainer from the sdhci driver and steer people towards the new MMC list for discussing it. Signed-off-by: Pierre Ossman <pierre@ossman.eu> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21Add MAINTAINERS entry for ARM/INTEL IXP4xx arch support.Krzysztof Hałasa
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2009-09-21Merge branch 'devel' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into devel
2009-09-21trivial: update the Kernel Janitors' web-page URLMarkus Heidelberg
The former address cannot be resolved. Signed-off-by: Markus Heidelberg <markus.heidelberg@web.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21perf: Tidy up after the big renameIngo Molnar
- provide compatibility Kconfig entry for existing PERF_COUNTERS .config's - provide courtesy copy of old perf_counter.h, for user-space projects - small indentation fixups - fix up MAINTAINERS - fix small x86 printout fallout - fix up small PowerPC comment fallout (use 'counter' as in register) Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19Merge branch 'for-rmk' of git://linux-arm.org/linux-2.6Russell King
2009-09-19Merge branch 'topstar-laptop' into releaseLen Brown
2009-09-19topstar-laptop: add new driver for hotkeys support on Topstar N01Herton Ronaldo Krzesinski
This adds Topstar Laptop Extras ACPI driver. It enables hotkeys functionality with Topstar N01 netbook. Besides hotkeys there are other functions exposed by its ACPI firmware, but for now only hotkeys reporting on Topstar N01 is supported. Topstar is a chinese manufacturer, its website can be currently reached at http://www.topstardigital.cn/ Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Reviewed-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'linus' into sfi-releaseLen Brown
Conflicts: arch/x86/kernel/setup.c drivers/acpi/power.c init/main.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-18MAINTAINERS: Add maintainer for AT24 and PCA9564/PCA9665Wolfram Sang
Add me as the maintainer for the i2c drivers I feel responsible for as I found patches going mainline I missed due to no Cc. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-18ARM: Update mailing list addressesRussell King
The old list has now been closed off; update the now invalid addresses. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-18Merge branch 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-scoreLinus Torvalds
* 'for-linus' of git://gitserver.sunplusct.com/linux-2.6-score: (22 commits) score: add TIF_NOTIFY_RESUME define in asm/thread_info.h score: make init_thread_union align to THREAD_SIZE score: update files according to review comments. score: add old syscall support score: add MEMORY_START and MEMORY_SIZE define, to make the code clear score: update inconsistent declare after .c was changed score: remove unused code, add include files in .c score: clean up mm/init.c score: make irq.h definitions local score: cleanups: dead code, 0 as pointer, shadowed variables score: fix function prototypes score: add address space annotations score: add missing #includes score: move save arg5 and arg6 instruction in front of enable_irq score: add prototypes for wrapped syscalls score: remove init_mm score: add generic sys_call_table score: remove __{put,get}_user_unknown score: unset __ARCH_WANT_IPC_PARSE_VERSION score: update files according to review comments ...
2009-09-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (55 commits) regulator: Voltage count for AB3100 mfd: Convert WM8350 to use request_threaded_irq() mfd: Update MAINTAINERS patterns for WM831x mfd: Fix twl4030-power warnings regulator: AB3100 support rtc: AB3100 RTC support mfd: Fix ab3100-otp build failure mfd: OMAP: Board-specifc twl4030 DPS scripts for RX51 board mfd: Print warning for twl4030 out-of-order script loading mfd: Add support for TWL4030/5030 dynamic power switching mfd: AB3100 OTP readout regulator: Add Freescale MC13783 driver mfd: Add Freescale MC13783 driver mfd: AB3100 disable irq nosync mfd: AB3100 alter default setting mfd: AB3100 propagate error mfd: AB3100 accessor function cleanups rtc: Add support for RTCs on Wolfson WM831x devices regulator: get pcap data from the parent device input: PCAP2 misc input driver ...
2009-09-18Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (62 commits) DaVinci: DM646x - platform changes for vpif capture and display drivers davinci: DM355 - platform changes for vpfe capture davinci: DM644x platform changes for vpfe capture davinci: audio: move tlv320aic33 i2c setup into board files DaVinci: EDMA: Adding 2 new APIs for allocating/freeing PARAMs DaVinci: DM365: Adding entries for DM365 IRQ's DaVinci: DM355: Adding PINMUX entries for DM355 Display davinci: Handle pinmux conflict between mmc/sd and nor flash davinci: Add NOR flash support for da850/omap-l138 davinci: Add NAND flash support for DA850/OMAP-L138 davinci: Add MMC/SD support for da850/omap-l138 davinci: Add platform support for da850/omap-l138 GLCD davinci: Macro to convert GPIO signal to GPIO pin number davinci: Audio support for DA850/OMAP-L138 EVM davinci: Audio support for DA830 EVM davinci: Correct the number of GPIO pins for da850/omap-l138 davinci: Configure MDIO pins for EMAC DaVinci: DM365: Add Support for new Revision of silicon DaVinci: DM365: Fix Compilation issue due to PINMUX entry DaVinci: EDMA: Updating default queue handling ...
2009-09-18Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Flush disk caches on fsync when needed ext3: Add locking to ext3_do_update_inode ext3: Fix possible deadlock between ext3_truncate() and ext3_get_blocks() jbd: Annotate transaction start also for journal_restart() jbd: Journal block numbers can ever be only 32-bit use unsigned int for them ext3: Update MAINTAINERS for ext3 and JBD JBD: round commit timer up to avoid uncommitted transaction
2009-09-17Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (44 commits) vsnprintf: remove duplicate comment of vsnprintf softirq: add BLOCK_IOPOLL to softirq_to_name oprofile: fix oprofile regression: select RING_BUFFER_ALLOW_SWAP tracing: switch function prints from %pf to %ps vsprintf: add %ps that is the same as %pS but is like %pf tracing: Fix minor bugs for __unregister_ftrace_function_probe tracing: remove notrace from __kprobes annotation tracing: optimize global_trace_clock cachelines MAINTAINERS: Update tracing tree details ftrace: document function and function graph implementation tracing: make testing syscall events a separate configuration tracing: remove some unused macros ftrace: add compile-time check on F_printk() tracing: fix F_printk() typos tracing: have TRACE_EVENT macro use __flags to not shadow parameter tracing: add static to generated TRACE_EVENT functions ring-buffer: typecast cmpxchg to fix PowerPC warning tracing: add filter event logic to special, mmiotrace and boot tracers tracing: remove trace_event_types.h tracing: use the new trace_entries.h to create format files ...
2009-09-17Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: Pick up kernel/softirq.c update for dependent fix. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-17MAINTAINTERS: remove hotplug driver entriesJesse Barnes
So Kristen stops getting PCI hotplug related stuff; the maintainer switch actually happened awhile ago, but the entries were never purged. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-17Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: (39 commits) xfs: includecheck fix for fs/xfs/xfs_iops.c xfs: switch to seq_file xfs: Record new maintainer information xfs: use correct log reservation when handling ENOSPC in xfs_create xfs: xfs_showargs() reports group *and* project quotas enabled xfs: un-static xfs_inobt_lookup xfs: actually enable the swapext compat handler xfs: simplify xfs_trans_iget xfs: merge fsync and O_SYNC handling xfs: speed up free inode search xfs: rationalize xfs_inobt_lookup* xfs: untangle xfs_dialloc xfs: factor out debug checks from xfs_dialloc and xfs_difree xfs: improve xfs_inobt_update prototype xfs: improve xfs_inobt_get_rec prototype xfs: factor out inode initialisation fs/xfs: Correct redundant test xfs: remove XFS_INO64_OFFSET un-static xfs_read_agf xfs: add more statics & drop some unused functions ...
2009-09-17Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (lm85) Don't bind to Winbond/Nuvoton WPCD377I hwmon: (pcf8591) Documentation clean-ups hwmon: Clearly mark ACPI drivers as such hwmon: Use resource_size hwmon: Include <linux/io.h> instead of <asm/io.h> hwmon: (tmp421) Add documentation hwmon: Add driver for Texas Instruments TMP421/422/423 sensor chips hwmon-vid: Ignore 6th VID pin of AMD family 0Fh processors hwmon: (asus_atk0110) Add maintainer information hwmon: (abituguru3) Support multiple DMI strings per chip ID
2009-09-17mfd: Update MAINTAINERS patterns for WM831xMark Brown
The WM831x PMICs added a backlight driver and a new include directory. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17MAINTAINERS: Add entry for Wolfson PMIC driversMark Brown
2009-09-16ext3: Update MAINTAINERS for ext3 and JBDJan Kara
Stephen agreed that he's unlikely to find time for working on ext3/JBD in the near future and is not working on it for some time already. So remove him. Added myself to JBD since after Andrew I'm probably the second most sensible contact ;). CC: Stephen Tweedie <sct@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: Driver Core: devtmpfs - kernel-maintained tmpfs-based /dev debugfs: Modify default debugfs directory for debugging pktcdvd. debugfs: Modified default dir of debugfs for debugging UHCI. debugfs: Change debugfs directory of IWMC3200 debugfs: Change debuhgfs directory of trace-events-sample.h debugfs: Fix mount directory of debugfs by default in events.txt hpilo: add poll f_op hpilo: add interrupt handler hpilo: staging for interrupt handling driver core: platform_device_add_data(): use kmemdup() Driver core: Add support for compatibility classes uio: add generic driver for PCI 2.3 devices driver-core: move dma-coherent.c from kernel to driver/base mem_class: fix bug mem_class: use minor as index instead of searching the array driver model: constify attribute groups UIO: remove 'default n' from Kconfig Driver core: Add accessor for device platform data Driver core: move dev_get/set_drvdata to drivers/base/dd.c Driver core: add new device to bus's list before probing
2009-09-15Merge branch 'master' of git://oss.sgi.com/xfs/xfs into for-linusAlex Elder
Conflicts: fs/xfs/linux-2.6/xfs_lrw.c
2009-09-15uio: add generic driver for PCI 2.3 devicesMichael S. Tsirkin
This adds a generic uio driver that can bind to any PCI device. First user will be virtualization where a qemu userspace process needs to give guest OS access to the device. Interrupts are handled using the Interrupt Disable bit in the PCI command register and Interrupt Status bit in the PCI status register. All devices compliant to PCI 2.3 (circa 2002) and all compliant PCI Express devices should support these bits. Driver detects this support, and won't bind to devices which do not support the Interrupt Disable Bit in the command register. It's expected that more features of interest to virtualization will be added to this driver in the future. Possibilities are: mmap for device resources, MSI/MSI-X, eventfd (to interface with kvm), iommu. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15Nicolas Pitre has a new email addressNicolas Pitre
Due to problems at cam.org, my nico@cam.org email address is no longer valid. FRom now on, nico@fluxnic.net should be used instead. Signed-off-by: Nicolas Pitre <nico@fluxnic.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-15hwmon: (asus_atk0110) Add maintainer informationLuca Tettamanti
Add myself as asus_atk0110 maintainer. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
