The Broadcom ARM tree location has changed names to reflect other SoC
families that are queued here. Also add the 216xx family as maintained.
Signed-off-by: Matt Porter <mporter@linaro.org>
shiraz.hashim@st.com email-id doesn't exist anymore as he has left the
company. Replace ST's id with shiraz.linux.kernel@gmail.com.
It also updates .mailmap file to fix address for 'git shortlog'.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
tools/perf/bench/numa.c
Pull perf fixes from Jiri Olsa.
Leaving ghostprotocols.net for old networking stuff.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-jott6d40nkjjc3vvh3vw53lp@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Pull exofs updates from Boaz Harrosh:
"Trivial updates to exofs for 3.15-rc1
Just a few fixes sent by people"
* 'for-linus' of git://git.open-osd.org/linux-open-osd:
MAINTAINERS: Update email address for bhalevy
fs: Mark functions as static in exofs/ore_raid.c
fs: Mark function as static in exofs/super.c
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Here is the pull request from the i2c subsystem. It got a little
delayed because I needed to wait for a dependency to be included
(commit b424080a9e08: "reset: Add optional resets and stubs"). Plus,
I had some email problems. All done now, the highlights are:
- drivers can now deprecate their use of i2c classes. That shouldn't
be used on embedded platforms anyhow and was often blindly
copy&pasted. This mechanism gives users time to switch away and
ultimately boot faster once the use of classes for those drivers is
gone for good.
- new drivers for QUP, Cadence, efm32
- tracepoint support for I2C and SMBus
- bigger cleanups for the mv64xxx, nomadik, and designware drivers
And the usual bugfixes, cleanups, feature additions. Most stuff has
been in linux-next for a while. Just some hot fixes and new drivers
were added a bit more recently."
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (63 commits)
i2c: cadence: fix Kconfig dependency
i2c: Add driver for Cadence I2C controller
i2c: cadence: Document device tree bindings
Documentation: i2c: improve section about flags mangling the protocol
i2c: qup: use proper type fro clk_freq
i2c: qup: off by ones in qup_i2c_probe()
i2c: efm32: fix binding doc
MAINTAINERS: update I2C web resources
i2c: qup: New bus driver for the Qualcomm QUP I2C controller
i2c: qup: Add device tree bindings information
i2c: i2c-xiic: deprecate class based instantiation
i2c: i2c-sirf: deprecate class based instantiation
i2c: i2c-mv64xxx: deprecate class based instantiation
i2c: i2c-designware-platdrv: deprecate class based instantiation
i2c: i2c-davinci: deprecate class based instantiation
i2c: i2c-bcm2835: deprecate class based instantiation
i2c: mv64xxx: Fix reset controller handling
i2c: omap: fix usage of IS_ERR_VALUE with pm_runtime_get_sync
i2c: efm32: new bus driver
i2c: exynos5: remove unnecessary cast of void pointer
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull MMC updates from Chris Ball:
"MMC highlights for 3.15:
Core:
- CONFIG_MMC_UNSAFE_RESUME=y is now default behavior
- DT bindings for SDHCI UHS, eMMC HS200, high-speed DDR, at 1.8/1.2V
- Add GPIO descriptor based slot-gpio card detect API
Drivers:
- dw_mmc: Refactor SOCFPGA support as a variant inside dw_mmc-pltfm.c
- mmci: Support HW busy detection on ux500
- omap: Support MMC_ERASE
- omap_hsmmc: Support MMC_PM_KEEP_POWER, MMC_PM_WAKE_SDIO_IRQ, (a)cmd23
- rtsx: Support pre-req/post-req async
- sdhci: Add support for Realtek RTS5250 controllers
- sdhci-acpi: Add support for 80860F16, fix 80860F14/SDIO card detect
- sdhci-msm: Add new driver for Qualcomm SDHCI chipset support
- sdhci-pxav3: Add support for Marvell Armada 380 and 385 SoCs"
* tag 'mmc-updates-for-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (102 commits)
mmc: sdhci-acpi: Intel SDIO has broken card detect
mmc: sdhci-pxav3: add support for the Armada 38x SDHCI controller
mmc: sdhci-msm: Add platform_execute_tuning implementation
mmc: sdhci-msm: Initial support for Qualcomm chipsets
mmc: sdhci-msm: Qualcomm SDHCI binding documentation
sdhci: only reprogram retuning timer when flag is set
mmc: rename ARCH_BCM to ARCH_BCM_MOBILE
mmc: sdhci: Allow for irq being shared
mmc: sdhci-acpi: Add device id 80860F16
mmc: sdhci-acpi: Fix broken card detect for ACPI HID 80860F14
mmc: slot-gpio: Add GPIO descriptor based CD GPIO API
mmc: slot-gpio: Split out CD IRQ request into a separate function
mmc: slot-gpio: Record GPIO descriptors instead of GPIO numbers
Revert "dts: socfpga: Add support for SD/MMC on the SOCFPGA platform"
mmc: sdhci-spear: use generic card detection gpio support
mmc: sdhci-spear: remove support for power gpio
mmc: sdhci-spear: simplify resource handling
mmc: sdhci-spear: fix platform_data usage
mmc: sdhci-spear: fix error handling paths for DT
mmc: sdhci-bcm-kona: fix build errors when built-in
Pull drm updates from Dave Airlie:
"Highlights:
- drm:
Generic display port aux features, primary plane support, drm
master management fixes, logging cleanups, enforced locking checks
(instead of docs), documentation improvements, minor number
handling cleanup, pseudofs for shared inodes.
- ttm:
add ability to allocate from both ends
- i915:
broadwell features, power domain and runtime pm, per-process
address space infrastructure (not enabled)
- msm:
power management, hdmi audio support
- nouveau:
ongoing GPU fault recovery, initial maxwell support, random fixes
- exynos:
refactored driver to clean up a lot of abstraction, DP support
moved into drm, LVDS bridge support added, parallel panel support
- gma500:
SGX MMU support, SGX irq handling, asle irq work fixes
- radeon:
video engine bringup, ring handling fixes, use dp aux helpers
- vmwgfx:
add rendernode support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (849 commits)
DRM: armada: fix corruption while loading cursors
drm/dp_helper: don't return EPROTO for defers (v2)
drm/bridge: export ptn3460_init function
drm/exynos: remove MODULE_DEVICE_TABLE definitions
ARM: dts: exynos4412-trats2: enable exynos/fimd node
ARM: dts: exynos4210-trats: enable exynos/fimd node
ARM: dts: exynos4412-trats2: add panel node
ARM: dts: exynos4210-trats: add panel node
ARM: dts: exynos4: add MIPI DSI Master node
drm/panel: add S6E8AA0 driver
ARM: dts: exynos4210-universal_c210: add proper panel node
drm/panel: add ld9040 driver
panel/ld9040: add DT bindings
panel/s6e8aa0: add DT bindings
drm/exynos: add DSIM driver
exynos/dsim: add DT bindings
drm/exynos: disallow fbdev initialization if no device is connected
drm/mipi_dsi: create dsi devices only for nodes with reg property
drm/mipi_dsi: add flags to DSI messages
Skip intel_crt_init for Dell XPS 8700
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Maciej Patelczyk <maciej.patelczyk@intel.com>
Cc: Artur Paszkiewicz <artur.paszkiewicz@intel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Add a driver for the Cadence I2C controller. This controller is for
example found in Xilinx Zynq.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Tested-by: Michal Simek <michal.simek@xilinx.com>
Reviewed-by: Harini Katakam <harinik@xilinx.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework changes from Mike Turquette:
"The clock framework changes for 3.15 look similar to past pull
requests. Mostly clock driver updates, more Device Tree support in
the form of common functions useful across platforms and a handful of
features and fixes to the framework core"
* tag 'clk-for-linus-3.15' of git://git.linaro.org/people/mike.turquette/linux: (86 commits)
clk: shmobile: fix setting paretn clock rate
clk: shmobile: rcar-gen2: fix lb/sd0/sd1/sdh clock parent to pll1
clk: Fix minor errors in of_clk_init() function comments
clk: reverse default clk provider initialization order in of_clk_init()
clk: sirf: update copyright years to 2014
clk: mmp: try to use closer one when do round rate
clk: mmp: fix the wrong calculation formula
clk: mmp: fix wrong mask when calculate denominator
clk: st: Adds quadfs clock binding
clk: st: Adds clockgen-vcc and clockgen-mux clock binding
clk: st: Adds clockgen clock binding
clk: st: Adds divmux and prediv clock binding
clk: st: Support for A9 MUX clocks
clk: st: Support for ClockGenA9/DDR/GPU
clk: st: Support for QUADFS inside ClockGenB/C/D/E/F
clk: st: Support for VCC-mux and MUX clocks
clk: st: Support for PLLs inside ClockGenA(s)
clk: st: Support for DIVMUX and PreDiv Clocks
clk: support hardware-specific debugfs entries
clk: s2mps11: Use of_get_child_by_name
Pull ARM SoC specific changes from Arnd Bergmann:
"Lots of changes specific to one of the SoC families. Some that stick
out are:
- mach-qcom gains new features, most importantly SMP support for the
newer chips (Stephen Boyd, Rohit Vaswani)
- mvebu gains support for three new SoCs: Armada 375, 380 and 385
(Thomas Petazzoni and Free-electrons team)
- SMP support for Rockchips (Heiko Stübner)
- Lots of i.MX changes (Shawn Guo)
- Added support for BCM5301x SoC (Hauke Mehrtens)
- Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn
and Sebastian Hesselbarth doing the final part of a long journey)
- Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd
Bergmann)"
* tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits)
ARM: sunxi: Select HAVE_ARM_ARCH_TIMER
ARM: cache-tauros2: remove ARMv6 code
ARM: mvebu: don't select CONFIG_NEON
ARM: davinci: fix DT booting with default defconfig
ARM: configs: bcm_defconfig: enable bcm590xx regulator support
ARM: davinci: remove tnetv107x support
MAINTAINERS: Update ARM STi maintainers
ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE
ARM: bcm21664: Add board support.
ARM: sunxi: Add the new watchog compatibles to the reboot code
ARM: enable ARM_HAS_SG_CHAIN for multiplatform
ARM: davinci: remove da8xx_omapl_defconfig
ARM: davinci: da8xx: fix multiple watchdog device registration
ARM: davinci: add da8xx specific configs to davinci_all_defconfig
ARM: davinci: enable da8xx build concurrently with older devices
ARM: BCM5301X: workaround suppress fault
ARM: BCM5301X: add early debugging support
ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU
ARM: mach-bcm: Remove GENERIC_TIME
ARM: shmobile: APMU: Fix warnings due to improper printk formats
Pull ARM SoC cleanups from Arnd Bergmann:
"These cleanup patches are mainly move stuff around and should all be
harmless. They are mainly split out so that other branches can be
based on top to avoid conflicts.
Notable changes are:
- We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no
longer used (Uwe Kleine-König)
- The Qualcomm MSM platform is split out into legacy mach-msm and
new-style mach-qcom, to allow easier maintainance of the new
hardware support without regressions (Kumar Gala)
- A rework of some of the Kconfig logic to simplify multiplatform
support (Rob Herring)
- Samsung Exynos gets closer to supporting multiplatform (Sachin
Kamat and others)
- mach-bcm3528 gets merged into mach-bcm (Stephen Warren)
- at91 gains some common clock framework support (Alexandre Belloni,
Jean-Jacques Hiblot and other French people)"
* tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits)
ARM: hisi: select HAVE_ARM_SCU only for SMP
ARM: efm32: allow uncompress debug output
ARM: prima2: build reset code standalone
ARM: at91: add PWM clock
ARM: at91: move sam9261 SoC to common clk
ARM: at91: prepare common clk transition for sam9261 SoC
ARM: at91: updated the at91_dt_defconfig with support for the ADS7846
ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek
ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs
ARM: at91: dt: Add at91sam9261 dt SoC support
ARM: at91: switch sam9rl to common clock framework
ARM: at91/dt: define main clk frequency of at91sam9rlek
ARM: at91/dt: define at91sam9rl clocks
ARM: at91: prepare common clk transition for sam9rl SoCs
ARM: at91: prepare sam9 dt boards transition to common clk
ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek
ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs
ARM: at91: Add at91sam9rl DT SoC support
ARM: at91: prepare at91sam9rl DT transition
ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig
Pull ARM SoC non-critical bug fixes from Arnd Bergmann:
"Lots of isolated bug fixes that were not found to be important enough
to be submitted before the merge window or backported into stable
kernels.
The vast majority of these came out of Arnd's randconfig testing and
just prevents running into build-time bugs in configurations that we
do not care about in practice"
* tag 'fixes-non-critical-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: at91: fix a typo
ARM: moxart: fix CPU selection
ARM: tegra: fix board DT pinmux setup
ARM: nspire: Fix compiler warning
IXP4xx: Fix DMA masks.
Revert "ARM: ixp4xx: Make dma_set_coherent_mask common, correct implementation"
IXP4xx: Fix Goramo Multilink GPIO conversion.
Revert "ARM: ixp4xx: fix gpio rework"
ARM: tegra: make debug_ll code build for ARMv6
ARM: sunxi: fix build for THUMB2_KERNEL
ARM: exynos: add missing include of linux/module.h
ARM: exynos: fix l2x0 saved regs handling
ARM: samsung: select CRC32 for SAMSUNG_PM_CHECK
ARM: samsung: select ATAGS where necessary
ARM: samsung: fix SAMSUNG_PM_DEBUG Kconfig logic
ARM: samsung: allow serial driver to be disabled
ARM: s5pv210: enable IDE support in MACH_TORBRECK
ARM: s5p64x0: fix building with only one soc type
ARM: s3c64xx: select power domains only when used
ARM: s3c64xx: MACH_SMDK6400 needs HSMMC1
git://anongit.freedesktop.org/drm-intel into drm-next
Merge window -fixes pull request as usual. Well, I did sneak in Jani's
drm_i915_private_t typedef removal, need to have fun with a big sed job
too ;-)
Otherwise:
- hdmi interlaced fixes (Jesse&Ville)
- pipe error/underrun/crc tracking fixes, regression in late 3.14-rc (but
not cc: stable since only really relevant for igt runs)
- large cursor wm fixes (Chris)
- fix gpu turbo boost/throttle again, was getting stuck due to vlv rps
patches (Chris+Imre)
- fix runtime pm fallout (Paulo)
- bios framebuffer inherit fix (Chris)
- a few smaller things
* tag 'drm-intel-fixes-2014-04-04' of git://anongit.freedesktop.org/drm-intel: (196 commits)
drm/i915: vlv: fix RPS interrupt mask setting
Revert "drm/i915/vlv: fixup DDR freq detection per Punit spec"
drm/i915: move power domain init earlier during system resume
drm/i915: Fix the computation of required fb size for pipe
drm/i915: don't get/put runtime PM at the debugfs forcewake file
drm/i915: fix WARNs when reading DDI state while suspended
drm/i915: don't read cursor registers on powered down pipes
drm/i915: get runtime PM at i915_display_info
drm/i915: don't read pp_ctrl_reg if we're suspended
drm/i915: get runtime PM at i915_reg_read_ioctl
drm/i915: don't schedule force_wake_timer at gen6_read
drm/i915: vlv: reserve the GT power context only once during driver init
drm/i915: prefer struct drm_i915_private to drm_i915_private_t
drm/i915/overlay: prefer struct drm_i915_private to drm_i915_private_t
drm/i915/ringbuffer: prefer struct drm_i915_private to drm_i915_private_t
drm/i915/display: prefer struct drm_i915_private to drm_i915_private_t
drm/i915/irq: prefer struct drm_i915_private to drm_i915_private_t
drm/i915/gem: prefer struct drm_i915_private to drm_i915_private_t
drm/i915/dma: prefer struct drm_i915_private to drm_i915_private_t
git://anongit.freedesktop.org/tegra/linux into drm-next
drm/panel: Changes for v3.15-rc1
Add support for a couple more simple panels. A few cleanups to the
simple panel driver are also included (gpiod interface conversion,
removal of redundant call to regulator_disable()).
* tag 'drm/panel/for-3.15-rc1' of git://anongit.freedesktop.org/tegra/linux:
drm/panel: add support for LG LD070WX3-SL01 panel
drm/panel: add support for LG LH500WX1-SD03 panel
drm/panel: simple: Allow DSI panels to provide mode flags
drm/panel: simple: Allow GPIO accesses to sleep
drm/panel: remove redundant regulator_disable()
drm/panel: use gpiod interface for enable GPIO
drm/panel: Add LG 12.9" LCD panel
MAINTAINERS: Add entry for DRM panel drivers
MAINTAINERS
Pull file locking updates from Jeff Layton:
"Highlights:
- maintainership change for fs/locks.c. Willy's not interested in
maintaining it these days, and is OK with Bruce and I taking it.
- fix for open vs setlease race that Al ID'ed
- cleanup and consolidation of file locking code
- eliminate unneeded BUG() call
- merge of file-private lock implementation"
* 'locks-3.15' of git://git.samba.org/jlayton/linux:
locks: make locks_mandatory_area check for file-private locks
locks: fix locks_mandatory_locked to respect file-private locks
locks: require that flock->l_pid be set to 0 for file-private locks
locks: add new fcntl cmd values for handling file private locks
locks: skip deadlock detection on FL_FILE_PVT locks
locks: pass the cmd value to fcntl_getlk/getlk64
locks: report l_pid as -1 for FL_FILE_PVT locks
locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT"
locks: rename locks_remove_flock to locks_remove_file
locks: consolidate checks for compatible filp->f_mode values in setlk handlers
locks: fix posix lock range overflow handling
locks: eliminate BUG() call when there's an unexpected lock on file close
locks: add __acquires and __releases annotations to locks_start and locks_stop
locks: remove "inline" qualifier from fl_link manipulation functions
locks: clean up comment typo
locks: close potential race between setlease and open
MAINTAINERS: update entry for fs/locks.c
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"The main set of series of patches for media subsystem, including:
- document RC sysfs class
- added an API to setup scancode to allow waking up systems using the
Remote Controller
- add API for SDR devices. Drivers are still on staging
- some API improvements for getting EDID data from media
inputs/outputs
- new DVB frontend driver for drx-j (ATSC)
- one driver (it913x/it9137) got removed, in favor of an improvement
on another driver (af9035)
- added a skeleton V4L2 PCI driver at documentation
- added a dual flash driver (lm3646)
- added a new IR driver (img-ir)
- added an IR scancode decoder for the Sharp protocol
- some improvements at the usbtv driver, to allow its core to be
reused.
- added a new SDR driver (rtl2832u_sdr)
- added a new tuner driver (msi001)
- several improvements at em28xx driver to fix PM support, device
removal and to split the V4L2 specific bits into a separate
sub-driver
- one driver got converted to videobuf2 (s2255drv)
- the e4000 tuner driver now follows an improved binding model
- some fixes at V4L2 compat32 code
- several fixes and enhancements at videobuf2 code
- some cleanups at V4L2 API documentation
- usual driver enhancements, new board additions and misc fixups"
[ NOTE! This merge effective drops commit 4329b93b283c ("of: Reduce
indentation in of_graph_get_next_endpoint").
The of_graph_get_next_endpoint() function was moved and renamed by
commit fd9fdb78a9bf ("[media] of: move graph helpers from
drivers/media/v4l2-core to drivers/of"). It was originally called
v4l2_of_get_next_endpoint() and lived in the file
drivers/media/v4l2-core/v4l2-of.c.
In that original location, it was then fixed to support empty port
nodes by commit b9db140c1e46 ("[media] v4l: of: Support empty port
nodes"), and that commit clashes badly with the dropped "Reduce
intendation" commit. I had to choose one or the other, and decided
that the "Support empty port nodes" commit was more important ]
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (426 commits)
[media] em28xx-dvb: fix PCTV 461e tuner I2C binding
Revert "[media] em28xx-dvb: fix PCTV 461e tuner I2C binding"
[media] em28xx: fix PCTV 290e LNA oops
[media] m88ds3103: fix bug on .set_tone()
[media] saa7134: fix WARN_ON during resume
[media] v4l2-dv-timings: add module name, description, license
[media] videodev2.h: add parenthesis around macro arguments
[media] saa6752hs: depends on CRC32
[media] si4713: fix Kconfig dependencies
[media] Sensoray 2255 uses videobuf2
[media] adv7180: free an interrupt on failure paths in init_device()
[media] e4000: make VIDEO_V4L2 dependency optional
[media] af9033: Don't export functions for the hardware filter
[media] af9035: use af9033 PID filters
[media] af9033: implement PID filter
[media] rtl2832_sdr: do not use dynamic stack allocation
[media] e4000: fix 32-bit build error
[media] em28xx-audio: make sure audio is unmuted on open()
[media] DocBook media: v4l2_format_sdr was renamed to v4l2_sdr_format
Add myself as the maintainer for DRM panel drivers. The plan is to
collect panel-related patches in one place to reduce conflicts and
unburden Dave.
Signed-off-by: Thierry Reding <treding@nvidia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull bulk of gpio updates from Linus Walleij:
"A pretty big chunk of changes this time, but it has all been on
rotation in linux-next and had some testing. Of course there will be
some amount of fixes on top...
- Merged in a branch of irqchip changes from Thomas Gleixner: we need
to have new callbacks from the irqchip to determine if the GPIO
line will be eligible for IRQs, and this callback must be able to
say "no". After some thinking I got the branch from tglx and have
switched all current users over to use this.
- Based on tglx patches, we have added some generic irqchip helpers
in the gpiolib core. These will help centralize code when GPIO
drivers have simple chained/cascaded IRQs. Drivers will still
define their irqchip vtables, but the gpiolib core will take care
of irqdomain set-up, mapping from local offsets to Linux irqs, and
reserve resources by marking the GPIO lines for IRQs.
- Initially the PL061 and Nomadik GPIO/pin control drivers have been
switched over to use the new gpiochip-to-irqchip infrastructure
with more drivers expected for the next kernel cycle. The
factoring of just two drivers still makes it worth it so it is
already a win.
- A new driver for the Synopsys DesignWare APB GPIO block.
- Modify the DaVinci GPIO driver to be reusable also for the new TI
Keystone architecture.
- A new driver for the LSI ZEVIO SoCs.
- Delete the obsolte tnetv107x driver.
- Some incremental work on GPIO descriptors: have
gpiod_direction_output() use a logical level, respecting assertion
polarity through ACTIVE_LOW flags, adding gpiod_direction_output_raw()
for the case where you want to set that very value. Add
gpiochip_get_desc() to fetch a GPIO descriptor from a specific
offset on a certain chip inside driver code.
- Switch ACPI GPIO code over to using gpiochip_get_desc() and get rid
of gpio_to_desc().
- The ACPI GPIO event handling code has been reworked after
encountering an actual real life implementation.
- Support for ACPI GPIO operation regions.
- Generic GPIO chips can now be assigned labels/names from platform
data.
- We now clamp values returned from GPIO drivers to the boolean [0,1]
range.
- Some improved documentation on how to use the polarity flag was
added.
- a large slew of incremental driver updates and non-critical fixes.
Some targeted for stable"
* tag 'gpio-v3.15-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (80 commits)
gpio: rcar: Add helper variable dev = &pdev->dev
gpio-lynxpoint: force gpio_get() to return "1" and "0" only
gpio: unmap gpio irqs properly
pch_gpio: set value before enabling output direction
gpio: moxart: Actually set output state in moxart_gpio_direction_output()
gpio: moxart: Avoid forward declaration
gpio: mxs: Allow for recursive enable_irq_wake() call
gpio: samsung: Add missing "break" statement
gpio: twl4030: Remove redundant assignment
gpio: dwapb: correct gpio-cells in binding document
gpio: iop: fix devm_ioremap_resource() return value checking
pinctrl: coh901: convert driver to use gpiolib irqchip
pinctrl: nomadik: convert driver to use gpiolib irqchip
gpio: pl061: convert driver to use gpiolib irqchip
gpio: add IRQ chip helpers in gpiolib
pinctrl: nomadik: factor in platform data container
pinctrl: nomadik: rename secondary to latent
gpio: Driver for SYSCON-based GPIOs
gpio: generic: Use platform_device_id->driver_data field for driver flags
pinctrl: coh901: move irq line locking to resource callbacks
Also, web-page entry is updated according to relocation of project's web
site.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Update git repository entry of nilfs2 file system and maintainer's
email description.
Seems he's gone off to bigger/better things. So long, etc...
microblaze-uclinux mailing list is almost dead and it is just causing
troubles for non subscribers which are getting email about waiting for
moderator. Approval never happens. Move it to LKML.
Reported-by: Richard Guy Briggs <rgb@redhat.com>
Dialog Semiconductor Ltd would like to add a new section called DIALOG
SEMICONDUCTOR DRIVERS which contains a new e-mail address that can cover
all Dialog supported drivers: support.opensource@diasemi.com.
Signed-off-by: Opensource [Steve Twiss] <stwiss.opensource@diasemi.com>
Signed-off-by: David Dajun Chen <david.chen@diasemi.com>
Cc: Mark Brown <broonie@linaro.org>
Cc: Joe Perches <joe@perches.com>
Mark it so.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Now that irqchip drivers for xtensa live outside arch/xtensa we'd like
to add them to our maintenance list.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Marc Gauthier <marc@cadence.com>
Paul Mundt's email address bounces regularly, and he hasn't taken any
SuperH patches for about one year.
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
Suggested-by: Paul Bolle <pebolle@tiscali.nl>
Cc: Paul Mundt <paul.mundt@gmail.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Laurent Pinchart <Laurent.pinchart@ideasonboard.com>
Cc: Simon Horman <horms@verge.net.au>
Bryan Wu and Lee Jones volunteer to maintain backlight drivers and help
to setup git-tree for backlight subsystem. Thus, I add them as
backlight co-maintainers.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Bryan Wu <cooloney@gmail.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Apart from reordering the SELinux mmap code to ensure DAC is called
before MAC, these are minor maintenance updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: correctly label /proc inodes in use before the policy is loaded
selinux: put the mmap() DAC controls before the MAC controls
selinux: fix the output of ./scripts/get_maintainer.pl for SELinux
evm: enable key retention service automatically
ima: skip memory allocation for empty files
evm: EVM does not use MD5
ima: return d_name.name if d_path fails
integrity: fix checkpatch errors
ima: fix erroneous removal of security.ima xattr
security: integrity: Use a more current logging style
MAINTAINERS: email updates and other misc. changes
ima: reduce memory usage when a template containing the n field is used
ima: restore the original behavior for sending data with ima template
Integrity: Pass commname via get_task_comm()
fs: move i_readcount
ima: use static const char array definitions
security: have cap_dentry_init_security return error
ima: new helper: file_inode(file)
kernel: Mark function as static in kernel/seccomp.c
capability: Use current logging styles
Tonian is now Primary Data.
Signed-off-by: Benny Halevy <bhalevy@primarydata.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Pull networking updates from David Miller:
"Here is my initial pull request for the networking subsystem during
this merge window:
1) Support for ESN in AH (RFC 4302) from Fan Du.
2) Add full kernel doc for ethtool command structures, from Ben
Hutchings.
3) Add BCM7xxx PHY driver, from Florian Fainelli.
4) Export computed TCP rate information in netlink socket dumps, from
Eric Dumazet.
5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas
Dichtel.
6) Convert many drivers to pci_enable_msix_range(), from Alexander
Gordeev.
7) Record SKB timestamps more efficiently, from Eric Dumazet.
8) Switch to microsecond resolution for TCP round trip times, also
from Eric Dumazet.
9) Clean up and fix 6lowpan fragmentation handling by making use of
the existing inet_frag api for it's implementation.
10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss.
11) Auto size SKB lengths when composing netlink messages based upon
past message sizes used, from Eric Dumazet.
12) qdisc dumps can take a long time, add a cond_resched(), From Eric
Dumazet.
13) Sanitize netpoll core and drivers wrt. SKB handling semantics.
Get rid of never-used-in-tree netpoll RX handling. From Eric W
Biederman.
14) Support inter-address-family and namespace changing in VTI tunnel
driver(s). From Steffen Klassert.
15) Add Altera TSE driver, from Vince Bridgers.
16) Optimizing csum_replace2() so that it doesn't adjust the checksum
by checksumming the entire header, from Eric Dumazet.
17) Expand BPF internal implementation for faster interpreting, more
direct translations into JIT'd code, and much cleaner uses of BPF
filtering in non-socket ocntexts. From Daniel Borkmann and Alexei
Starovoitov"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits)
netpoll: Use skb_irq_freeable to make zap_completion_queue safe.
net: Add a test to see if a skb is freeable in irq context
qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port'
net: ptp: move PTP classifier in its own file
net: sxgbe: make "core_ops" static
net: sxgbe: fix logical vs bitwise operation
net: sxgbe: sxgbe_mdio_register() frees the bus
Call efx_set_channels() before efx->type->dimension_resources()
xen-netback: disable rogue vif in kthread context
net/mlx4: Set proper build dependancy with vxlan
be2net: fix build dependency on VxLAN
mac802154: make csma/cca parameters per-wpan
mac802154: allow only one WPAN to be up at any given time
net: filter: minor: fix kdoc in __sk_run_filter
netlink: don't compare the nul-termination in nla_strcmp
can: c_can: Avoid led toggling for every packet.
can: c_can: Simplify TX interrupt cleanup
can: c_can: Store dlc private
can: c_can: Reduce register access
can: c_can: Make the code readable
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Nothing exciting: virtio-blk users might see a bit of a boost from the
doubling of the default queue length though"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio-blk: base queue-depth on virtqueue ringsize or module param
Revert a02bbb1ccfe8: MAINTAINERS: add virtio-dev ML for virtio
virtio: fail adding buffer on broken queues.
virtio-rng: don't crash if virtqueue is broken.
virtio_balloon: don't crash if virtqueue is broken.
virtio_blk: don't crash, report error if virtqueue is broken.
virtio_net: don't crash if virtqueue is broken.
virtio_balloon: don't softlockup on huge balloon changes.
virtio: Use pci_enable_msix_exact() instead of pci_enable_msix()
MAINTAINERS: virtio-dev is subscribers only
tools/virtio: add a missing )
tools/virtio: fix missing kmemleak_ignore symbol
tools/virtio: update internal copies of headers
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull main powerpc updates from Ben Herrenschmidt:
"This time around, the powerpc merges are going to be a little bit more
complicated than usual.
This is the main pull request with most of the work for this merge
window. I will describe it a bit more further down.
There is some additional cpuidle driver work, however I haven't
included it in this tree as it depends on some work in tip/timer-core
which Thomas accidentally forgot to put in a topic branch. Since I
didn't want to carry all of that tip timer stuff in powerpc -next, I
setup a separate branch on top of Thomas tree with just that cpuidle
driver in it, and Stephen has been carrying that in next separately
for a while now. I'll send a separate pull request for it.
Additionally, two new pieces in this tree add users for a sysfs API
that Tejun and Greg have been deprecating in drivers-core-next.
Thankfully Greg reverted the patch that removes the old API so this
merge can happen cleanly, but once merged, I will send a patch
adjusting our new code to the new API so that Greg can send you the
removal patch.
Now as for the content of this branch, we have a lot of perf work for
power8 new counters including support for our new "nest" counters
(also called 24x7) under pHyp (not natively yet).
We have new functionality when running under the OPAL firmware
(non-virtualized or KVM host), such as access to the firmware error
logs and service processor dumps, system parameters and sensors, along
with a hwmon driver for the latter.
There's also a bunch of bug fixes accross the board, some LE fixes,
and a nice set of selftests for validating our various types of copy
loops.
On the Freescale side, we see mostly new chip/board revisions, some
clock updates, better support for machine checks and debug exceptions,
etc..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (70 commits)
powerpc/book3s: Fix CFAR clobbering issue in machine check handler.
powerpc/compat: 32-bit little endian machine name is ppcle, not ppc
powerpc/le: Big endian arguments for ppc_rtas()
powerpc: Use default set of netfilter modules (CONFIG_NETFILTER_ADVANCED=n)
powerpc/defconfigs: Enable THP in pseries defconfig
powerpc/mm: Make sure a local_irq_disable prevent a parallel THP split
powerpc: Rate-limit users spamming kernel log buffer
powerpc/perf: Fix handling of L3 events with bank == 1
powerpc/perf/hv_{gpci, 24x7}: Add documentation of device attributes
powerpc/perf: Add kconfig option for hypervisor provided counters
powerpc/perf: Add support for the hv 24x7 interface
powerpc/perf: Add support for the hv gpci (get performance counter info) interface
powerpc/perf: Add macros for defining event fields & formats
powerpc/perf: Add a shared interface to get gpci version and capabilities
powerpc/perf: Add 24x7 interface headers
powerpc/perf: Add hv_gpci interface header
powerpc: Add hvcalls for 24x7 and gpci (Get Performance Counter Info)
sysfs: create bin_attributes under the requested group
powerpc/perf: Enable BHRB access for EBB events
powerpc/perf: Add BHRB constraint and IFM MMCRA handling for EBB
Pull x86 old platform removal from Peter Anvin:
"This patchset removes support for several completely obsolete
platforms, where the maintainers either have completely vanished or
acked the removal. For some of them it is questionable if there even
exists functional specimens of the hardware"
Geert Uytterhoeven apparently thought this was a April Fool's pull request ;)
* 'x86-nuke-platforms-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, platforms: Remove NUMAQ
x86, platforms: Remove SGI Visual Workstation
x86, apic: Remove support for IBM Summit/EXA chipset
x86, apic: Remove support for ia32-based Unisys ES7000
Advertise the patchwork tracker. Also, change to https for the website.
Pull first round of SCSI updates from James Bottomley:
"This patch consists of the usual driver updates (megaraid_sas,
scsi_debug, qla2xxx, qla4xxx, lpfc, bnx2fc, be2iscsi, hpsa, ipr) plus
an assortment of minor fixes and the first precursors of SCSI-MQ (the
code path simplifications) and the bug fix for the USB oops on remove
(which involves an infrastructure change, so is sent via the main tree
with a delayed backport after a cycle in which it is shown to
introduce no new bugs)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (196 commits)
[SCSI] sd: Quiesce mode sense error messages
[SCSI] add support for per-host cmd pools
[SCSI] simplify command allocation and freeing a bit
[SCSI] megaraid: simplify internal command handling
[SCSI] ses: Use vpd information from scsi_device
[SCSI] Add EVPD page 0x83 and 0x80 to sysfs
[SCSI] Return VPD page length in scsi_vpd_inquiry()
[SCSI] scsi_sysfs: Implement 'is_visible' callback
[SCSI] hpsa: update driver version to 3.4.4-1
[SCSI] hpsa: fix bad endif placement in RAID 5 mapper code
[SCSI] qla2xxx: Fix build errors related to invalid print fields on some architectures.
[SCSI] bfa: Replace large udelay() with mdelay()
[SCSI] vmw_pvscsi: Some improvements in pvscsi driver.
[SCSI] vmw_pvscsi: Add support for I/O requests coalescing.
[SCSI] vmw_pvscsi: Fix pvscsi_abort() function.
[SCSI] remove deprecated IRQF_DISABLED from SCSI
[SCSI] bfa: Updating Maintainers email ids
[SCSI] ipr: Add new CCIN definition for Grand Canyon support
[SCSI] ipr: Format HCAM overlay ID 0x21
[SCSI] ipr: Use pci_enable_msi_range() and pci_enable_msix_range()
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg KH:
"Here's the big USB pull request for 3.15-rc1.
The normal set of patches, lots of controller driver updates, and a
smattering of individual USB driver updates as well.
All have been in linux-next for a while"
* tag 'usb-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (249 commits)
xhci: Transition maintainership to Mathias Nyman.
USB: disable reset-resume when USB_QUIRK_RESET is set
USB: unbind all interfaces before rebinding any
usb: phy: Add ulpi IDs for SMSC USB3320 and TI TUSB1210
usb: gadget: tcm_usb_gadget: stop format strings
usb: gadget: f_fs: add missing spinlock and mutex unlock
usb: gadget: composite: switch over to ERR_CAST()
usb: gadget: inode: switch over to memdup_user()
usb: gadget: f_subset: switch over to PTR_RET
usb: gadget: lpc32xx_udc: fix wrong clk_put() sequence
USB: keyspan: remove dead debugging code
USB: serial: add missing newlines to dev_<level> messages.
USB: serial: add missing braces
USB: serial: continue to write on errors
USB: serial: continue to read on errors
USB: serial: make bulk_out_size a lower limit
USB: cypress_m8: fix potential scheduling while atomic
devicetree: bindings: document lsi,zevio-usb
usb: chipidea: add support for USB OTG controller on LSI Zevio SoCs
usb: chipidea: imx: Use dev_name() for ci_hdrc name to distinguish USBs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the huge drivers/staging/ update for 3.15-rc1.
Loads of cleanup fixes, a few drivers removed, and some new ones
added.
* tag 'staging-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1375 commits)
staging: xillybus: XILLYBUS_PCIE depends on PCI_MSI
staging: xillybus: Added "select CRC32" for XILLYBUS in Kconfig
staging: comedi: poc: remove obsolete driver
staging: unisys: replace kzalloc/kfree with UISMALLOC/UISFREE
staging: octeon-usb: prevent memory corruption
staging: usbip: fix line over 80 characters
staging: usbip: fix quoted string split across lines
Staging: unisys: Remove RETINT macro
Staging: unisys: Remove FAIL macro
Staging: unisys: Remove RETVOID macro
Staging: unisys: Remove RETPTR macro
Staging: unisys: Remove RETBOOL macro
Staging: unisys: Remove FAIL_WPOSTCODE_1 macro
Staging: unisys: Cleanup macros to get rid of goto statements
Staging: unisys: include: Remove unused macros from timskmod.h
staging: dgap: fix the rest of the checkpatch warnings in dgap.c
Staging: bcm: Remove unnecessary parentheses
staging: wlags49_h2: Delete unnecessary braces
staging: wlags49_h2: Do not use assignment in if condition
staging: wlags49_h2: Enclose macro in a do-while loop
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver patches from Greg KH:
"Here's the big char/misc driver updates for 3.15-rc1.
Lots of various things here, including the new mcb driver subsystem.
All of these have been in linux-next for a while"
* tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits)
extcon: Move OF helper function to extcon core and change function name
extcon: of: Remove unnecessary function call by using the name of device_node
extcon: gpio: Use SIMPLE_DEV_PM_OPS macro
extcon: palmas: Use SIMPLE_DEV_PM_OPS macro
mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro
mei: amthif: fix checkpatch error
mei: client.h fix checkpatch errors
mei: use cl_dbg where appropriate
mei: fix Unnecessary space after function pointer name
mei: report consistently copy_from/to_user failures
mei: drop pr_fmt macros
mei: make me hw headers private to me hw.
mei: fix memory leak of pending write cb objects
mei: me: do not reset when less than expected data is received
drivers: mcb: Fix build error discovered by 0-day bot
cs5535-mfgpt: Simplify dependencies
spmi: pm: drop bus-level PM suspend/resume routines
spmi: pmic_arb: make selectable on ARCH_QCOM
Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle
pch_phub: Report error writing MAC back to user
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"There have been lots of changes in ALSA core, HD-audio and ASoC, also
most of PCI drivers touched by conversions of printks. All these
resulted in a high volume and wide ranged patch sets in this release.
Many changes are fairly trivial, but also lots of nice cleanups and
refactors. There are a few new drivers, most notably, the Intel
Haswell and Baytrail ASoC driver.
Core changes:
- A bit modernization; embed the device struct into snd_card struct,
so that it may be referred from the beginning. A new
snd_card_new() function is introduced for that, and all drivers
have been converted.
- Simplification in the device management code in ALSA core; now
managed by a simple priority list instead
- Converted many kernel messages to use the standard dev_err() & co;
this would be the pretty visible difference, especially for
HD-audio.
HD-audio:
- Conexant codecs use the auto-parser as default now; the old static
code still remains in case of regressions. Some old quirks have
been rewritten with the fixups for auto-parser.
- C-Media codecs also use the auto-parser as default now, too.
- A device struct is assigned to each HD-audio codec, and the
formerly hwdep attributes are accessible over the codec sysfs, too.
hwdep attributes still remain for compatibility.
- Split the PCI-specific stuff for HD-audio controller into a
separate module, ane make a helper module for the generic
controller driver. This is a preliminary change for supporting
Tegra HDMI controller in near future, which slipped from 3.15
merge.
- Device-specific fixes: mute LED support for Lenovo Ideapad, mic LED
fix for HP laptops, more ASUS subwoofer quirks, yet more Dell
laptop headset quirks
- Make the HD-audio codec response a bit more robust
- A few improvements on Realtek ALC282 / 283 about the pop noises
- A couple of Intel HDMI fixes
ASoC:
- Lots of cleanups for enumerations; refactored lots of error prone
original codes to use more modern APIs
- Elimination of the ASoC level wrappers for I2C and SPI moving us
closer to converting to regmap completely and avoiding some
randconfig hassle
- Provide both manually and transparently locked DAPM APIs rather
than a mix of the two fixing some concurrency issues
- Start converting CODEC drivers to use separate bus interface
drivers rather than having them all in one file helping avoid
dependency issues
- DPCM support for Intel Haswell and Bay Trail platforms, lots of
fixes
- Lots of work on improvements for simple-card, DaVinci and the
Renesas rcar drivers.
- New drivers for Analog Devices ADAU1977, TI PCM512x and parts of
the CSR SiRF SoC, TLV320AIC31XXX, Armada 370 DB, Cirrus cs42xx8
- Fixes for the simple-card DAI format DT mess
- DT support for a couple more devices.
- Use of the tdm_slot mapping in a few drivers
Others:
- Support of reset_resume callback for improved S4 in USB-audio
driver; the device with boot quirks have been little tested, which
we need to watch out in this development cycle
- Add PM support for ICE1712 driver (finally!); it's still pretty
partial support, only for M-Audio devices"
* tag 'sound-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (610 commits)
ALSA: ice1712: Add suspend support for M-Audio ICE1712-based cards
ALSA: ice1712: add suspend support for ICE1712 chip
ALSA: hda - Enable beep for ASUS 1015E
ALSA: asihpi: fix some indenting in snd_card_asihpi_pcm_new()
ALSA: hda - add headset mic detect quirks for three Dell laptops
ASoC: tegra: move AC97 clock handling to the machine driver
ASoC: simple-card: Handle many DAI links
ASoC: simple-card: Add DT documentation for multi-DAI links
ASoC: simple-card: dynamically allocate the DAI link and properties
ASoC: imx-ssi: Add .xlate_tdm_slot_mask() support.
ASoC: fsl-esai: Add .xlate_tdm_slot_mask() support.
ASoC: fsl-utils: Add fsl_asoc_xlate_tdm_slot_mask() support.
ASoC: core: remove the 'of_' prefix of of_xlate_tdm_slot_mask.
ASoC: rcar: subnode tidyup for renesas,rsnd.txt
ASoC: Remove name_prefix unset during DAI link init hack
ALSA: hda - Inform the unexpectedly ignored pins by auto-parser
ASoC: rcar: bugfix: it cares about the non-src case
ARM: bockw: fixup SND_SOC_DAIFMT_CBx_CFx flags
ASoC: pcm: Drop incorrect double/extra frees
ASoC: mfld_machine: Fix compile error
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi Updates from Mark Brown:
"A busy release for both cleanups and new drivers this time along with
further factoring out of replicated code into the core:
- Provide support in the core for DMA mapping transfers - essentially
all drivers weren't implementing this properly, now there's no
excuse.
- Dual and quad mode support for spidev.
- Fix handling of cs_change in the generic implementation.
- Remove the S3C_DMA code from the s3c64xx driver now that all the
platforms using it have been converted to dmaengine.
- Lots of improvements to the Renesas SPI controllers.
- Drivers for Allwinner A10 and A31, Qualcomm QUP and Xylinx xtfpga.
- Removal of the bitrotted ti-ssp driver"
* tag 'spi-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: (199 commits)
spi: Fix handling of cs_change in core implementation
spi: bitbang: Make spi_bitbang_stop() return void
spi: mpc52xx: Convert to use bits_per_word_mask
spi: omap-100k: Fix memory leak
spi: dw: Don't call kfree for memory allocated by devm_kzalloc
spi: fsl-dspi: Fix memory leak
spi: omap-uwire: add missing iounmap
spi: clps711x: Convert to use master->max_speed_hz
spi: clps711x: Enable driver compilation with COMPILE_TEST
spi: omap-uwire: Remove full duplex check
spi: Do not require a completion
spi: topcliff-pch: Transform noisy message to dev_vdbg
spi: coldfire-qspi: Simplify the code to set register bits for transfer speed
spi: bcm63xx: Remove unused define for PFX
spi: efm32: use $vendor,$device scheme for compatible string
spi: clps711x: Remove <mach/hardware.h> dependency
spi: topcliff-pch: Properly unregister platform devices on probe() error paths
spi: fsl-espi: Remove unused bits_per_word variable in fsl_espi_bufs
spi: altera: Remove the code to get unused platform_data
spi: fsl-lib: Fix memory leak of pinfo
Pull ACPI and power management updates from Rafael Wysocki:
"The majority of this material spent some time in linux-next, some of
it even several weeks. There are a few relatively fresh commits in
it, but they are mostly fixes and simple cleanups.
ACPI took the lead this time, both in terms of the number of commits
and the number of modified lines of code, cpufreq follows and there
are a few changes in the PM core and in cpuidle too.
A new feature that already got some LWN.net's attention is the device
PM QoS extension allowing latency tolerance requirements to be
propagated from leaf devices to their ancestors with hardware
interfaces for specifying latency tolerance. That should help systems
with hardware-driven power management to avoid going too far with it
in cases when there are latency tolerance constraints.
There also are some significant changes in the ACPI core related to
the way in which hotplug notifications are handled. They affect PCI
hotplug (ACPIPHP) and the ACPI dock station code too. The bottom line
is that all those notification now go through the root notify handler
and are propagated to the interested subsystems by means of callbacks
instead of having to install a notify handler for each device object
that we can potentially get hotplug notifications for.
In addition to that ACPICA will now advertise "Windows 2013"
compatibility for _OSI, because some systems out there don't work
correctly if that is not done (some of them don't even boot).
On the system suspend side of things, all of the device suspend and
resume callbacks, except for ->prepare() and ->complete(), are now
going to be executed asynchronously as that turns out to speed up
system suspend and resume on some platforms quite significantly and we
have a few more optimizations in that area.
Apart from that, there are some new device IDs and fixes and cleanups
all over. In particular, the system suspend and resume handling by
cpufreq should be improved and the cpuidle menu governor should be a
bit more robust now.
Specifics:
- Device PM QoS support for latency tolerance constraints on systems
with hardware interfaces allowing such constraints to be specified.
That is necessary to prevent hardware-driven power management from
becoming overly aggressive on some systems and to prevent power
management features leading to excessive latencies from being used
in some cases.
- Consolidation of the handling of ACPI hotplug notifications for
device objects. This causes all device hotplug notifications to go
through the root notify handler (that was executed for all of them
anyway before) that propagates them to individual subsystems, if
necessary, by executing callbacks provided by those subsystems
(those callbacks are associated with struct acpi_device objects
during device enumeration). As a result, the code in question
becomes both smaller in size and more straightforward and all of
those changes should not affect users.
- ACPICA update, including fixes related to the handling of _PRT in
cases when it is broken and the addition of "Windows 2013" to the
list of supported "features" for _OSI (which is necessary to
support systems that work incorrectly or don't even boot without
it). Changes from Bob Moore and Lv Zheng.
- Consolidation of ACPI _OST handling from Jiang Liu.
- ACPI battery and AC fixes allowing unusual system configurations to
be handled by that code from Alexander Mezin.
- New device IDs for the ACPI LPSS driver from Chiau Ee Chew.
- ACPI fan and thermal optimizations related to system suspend and
resume from Aaron Lu.
- Cleanups related to ACPI video from Jean Delvare.
- Assorted ACPI fixes and cleanups from Al Stone, Hanjun Guo, Lan
Tianyu, Paul Bolle, Tomasz Nowicki.
- Intel RAPL (Running Average Power Limits) driver cleanups from
Jacob Pan.
- intel_pstate fixes and cleanups from Dirk Brandewie.
- cpufreq fixes related to system suspend/resume handling from Viresh
Kumar.
- cpufreq core fixes and cleanups from Viresh Kumar, Stratos
Karafotis, Saravana Kannan, Rashika Kheria, Joe Perches.
- cpufreq drivers updates from Viresh Kumar, Zhuoyu Zhang, Rob
Herring.
- cpuidle fixes related to the menu governor from Tuukka Tikkanen.
- cpuidle fix related to coupled CPUs handling from Paul Burton.
- Asynchronous execution of all device suspend and resume callbacks,
except for ->prepare and ->complete, during system suspend and
resume from Chuansheng Liu.
- Delayed resuming of runtime-suspended devices during system suspend
for the PCI bus type and ACPI PM domain.
- New set of PM helper routines to allow device runtime PM callbacks
to be used during system suspend and resume more easily from Ulf
Hansson.
- Assorted fixes and cleanups in the PM core from Geert Uytterhoeven,
Prabhakar Lad, Philipp Zabel, Rashika Kheria, Sebastian Capella.
- devfreq fix from Saravana Kannan"
* tag 'pm+acpi-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (162 commits)
PM / devfreq: Rewrite devfreq_update_status() to fix multiple bugs
PM / sleep: Correct whitespace errors in <linux/pm.h>
intel_pstate: Set core to min P state during core offline
cpufreq: Add stop CPU callback to cpufreq_driver interface
cpufreq: Remove unnecessary braces
cpufreq: Fix checkpatch errors and warnings
cpufreq: powerpc: add cpufreq transition latency for FSL e500mc SoCs
MAINTAINERS: Reorder maintainer addresses for PM and ACPI
PM / Runtime: Update runtime_idle() documentation for return value meaning
video / output: Drop display output class support
fujitsu-laptop: Drop unneeded include
acer-wmi: Stop selecting VIDEO_OUTPUT_CONTROL
ACPI / gpu / drm: Stop selecting VIDEO_OUTPUT_CONTROL
ACPI / video: fix ACPI_VIDEO dependencies
cpufreq: remove unused notifier: CPUFREQ_{SUSPENDCHANGE|RESUMECHANGE}
cpufreq: Do not allow ->setpolicy drivers to provide ->target
cpufreq: arm_big_little: set 'physical_cluster' for each CPU
cpufreq: arm_big_little: make vexpress driver depend on bL core driver
ACPI / button: Add ACPI Button event via netlink routine
ACPI: Remove duplicate definitions of PREFIX
Pull timer changes from Thomas Gleixner:
"This assorted collection provides:
- A new timer based timer broadcast feature for systems which do not
provide a global accessible timer device. That allows those
systems to put CPUs into deep idle states where the per cpu timer
device stops.
- A few NOHZ_FULL related improvements to the timer wheel
- The usual updates to timer devices found in ARM SoCs
- Small improvements and updates all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (44 commits)
tick: Remove code duplication in tick_handle_periodic()
tick: Fix spelling mistake in tick_handle_periodic()
x86: hpet: Use proper destructor for delayed work
workqueue: Provide destroy_delayed_work_on_stack()
clocksource: CMT, MTU2, TMU and STI should depend on GENERIC_CLOCKEVENTS
timer: Remove code redundancy while calling get_nohz_timer_target()
hrtimer: Rearrange comments in the order struct members are declared
timer: Use variable head instead of &work_list in __run_timers()
clocksource: exynos_mct: silence a static checker warning
arm: zynq: Add support for cpufreq
arm: zynq: Don't use arm_global_timer with cpufreq
clocksource/cadence_ttc: Overhaul clocksource frequency adjustment
clocksource/cadence_ttc: Call clockevents_update_freq() with IRQs enabled
clocksource: Add Kconfig entries for CMT, MTU2, TMU and STI
sh: Remove Kconfig entries for TMU, CMT and MTU2
ARM: shmobile: Remove CMT, TMU and STI Kconfig entries
clocksource: armada-370-xp: Use atomic access for shared registers
clocksource: orion: Use atomic access for shared registers
clocksource: timer-keystone: Delete unnecessary variable
clocksource: timer-keystone: introduce clocksource driver for Keystone
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
"There are two memory management related changes, the CMMA support for
KVM to avoid swap-in of freed pages and the split page table lock for
the PMD level. These two come with common code changes in mm/.
A fix for the long standing theoretical TLB flush problem, this one
comes with a common code change in kernel/sched/.
Another set of changes is Heikos uaccess work, included is the initial
set of patches with more to come.
And fixes and cleanups as usual"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (36 commits)
s390/con3270: optionally disable auto update
s390/mm: remove unecessary parameter from pgste_ipte_notify
s390/mm: remove unnecessary parameter from gmap_do_ipte_notify
s390/mm: fixing comment so that parameter name match
s390/smp: limit number of cpus in possible cpu mask
hypfs: Add clarification for "weight_min" attribute
s390: update defconfigs
s390/ptrace: add support for PTRACE_SINGLEBLOCK
s390/perf: make print_debug_cf() static
s390/topology: Remove call to update_cpu_masks()
s390/compat: remove compat exec domain
s390: select CONFIG_TTY for use of tty in unconditional keyboard driver
s390/appldata_os: fix cpu array size calculation
s390/checksum: remove memset() within csum_partial_copy_from_user()
s390/uaccess: remove copy_from_user_real()
s390/sclp_early: Return correct HSA block count also for zero
s390: add some drivers/subsystems to the MAINTAINERS file
s390: improve debug feature usage
s390/airq: add support for irq ranges
s390/mm: enable split page table lock for PMD level
Both Bruce and I have done a fair bit of work in these files recently,
and would like to be notified if anyone is proposing changes to it.
Also, Matthew is no longer interested in maintaining this code, so
remove him.
Cc: Matthew Wilcox <matthew@wil.cx>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
I am the new kernel tree Documentation maintainer (except for parts that
are handled by other people, of course).
Acked-by: Rob Landley <rob@landley.net>
into spi-next
drivers/net/ethernet/marvell/mvneta.c
The mvneta.c conflict is a case of overlapping changes,
a conversion to devm_ioremap_resource() vs. a conversion
to netdev_alloc_pcpu_stats.
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
