path: root/Documentation
2009-10-29Merge branch 'tracing/urgent' into tracing/coreIngo Molnar
Merge reason: Pick up fixes and move base from -rc1 to -rc5. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-24tracing: Fix comment typo and documentation exampleJiri Olsa
Trivial patch to fix a documentation example and to fix a comment. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091023233646.871719877@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: move virtrng_remove to .devexit.text move virtballoon_remove to .devexit.text virtio_blk: Revert serial number support virtio: let header files include virtio_ids.h virtio_blk: revert QUEUE_FLAG_VIRT addition
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-10-18inotify: deprecate the inotify kernel interfaceEric Paris
In 2.6.33 there will be no users of the inotify interface. Mark it for removal as fsnotify is more generic and is easier to use. Signed-off-by: Eric Paris <eparis@redhat.com>
2009-10-15Merge branch 'docs-next' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'docs-next' of git://git.lwn.net/linux-2.6: Update flex_arrays.txt
2009-10-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: gadget: Fix EEM driver comments and VID/PID usb-storage: Workaround devices with bogus sense size USB: ehci: Fix IST boundary checking interval math. USB: option: Support for AIRPLUS MCD650 Datacard USB: whci-hcd: always do an update after processing a halted qTD USB: whci-hcd: handle early deletion of endpoints USB: wusb: don't use the stack to read security descriptor USB: rename Documentation/ABI/.../sysfs-class-usb_host
2009-10-15Update flex_arrays.txtJonathan Corbet
The 2.6.32 merge window brought a number of changes to the flexible array API; this patch updates the documentation to match the new state of affairs. Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: sbp2: provide fallback if mgt_ORB_timeout is missing ieee1394: add documentation entry to MAINTAINERS ieee1394: update URLs in debugging-via-ohci1394.txt
2009-10-14Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/paravirt: Use normal calling sequences for irq enable/disable x86: fix kernel panic on 32 bits when profiling x86: Fix Suspend to RAM freeze on Acer Aspire 1511Lmi laptop x86, vmi: Mark VMI deprecated and schedule it for removal
2009-10-14USB: rename Documentation/ABI/.../sysfs-class-usb_hostDavid Vrabel
The usb_host class is no more. Rename its documentation file (which only contained WUSB specific files) to .../sysfs-class-uwb_rc-wusbhc. Signed-off-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-14tracing: Document HAVE_SYSCALL_TRACEPOINTS needsFrederic Weisbecker
Document the arch needed requirements to get the support for syscalls tracing. v2: HAVE_FTRACE_SYSCALLS have been changed to HAVE_SYSCALL_TRACEPOINTS recently. Update this config name in the documentation then. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org>
2009-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: hda - Allow all formats as default for Nvidia HDMI ALSA: aaci: ARM1176 aaci-pl041 AC97 register read timeout ALSA: hda - Fix volume-knob setup for Dell laptops with STAC9228 ALSA: hda - Fix mute sound with STAC9227/9228 codecs ALSA: bt87x - Add a whitelist for Pinnacle PCTV (11bd:0012) ALSA: hda - Fix overflow of spec->init_verbs in patch_realtek.c ALSA: ice1724 - Make call to set hw params succeed on ESI Juli@ ALSA: ice1724: Fix surround on Chaintech AV-710 ALSA: hda - Add full rates/formats support for Nvidia HDMI
2009-10-13Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-10-13ALSA: hda - Fix mute sound with STAC9227/9228 codecsTakashi Iwai
On FSC laptops, the sound gets muted gradually when the volume is chnaged. This is due to the wrong volume-knob widget setup. The delta bit (bit 7) shouldn't be set for these devices. This patch adds a new quirk to set the value 0x7f to the widget 0x24 instead of 0xff. Reference: Novell bnc#546006 http://bugzilla.novell.com/show_bug.cgi?id=546006 Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-13Merge branch 'tracing/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into tracing/core
2009-10-13ext3: Update documentation about ext3 quota mount optionsJan Kara
2009-10-12ftrace: add kernel command line graph function filteringStefan Assmann
Add a command line parameter to allow limiting the function graphs that are traced on boot up from the given top-level callers , when ftrace=function_graph is specified. This patch adds the following command line option: ftrace_graph_filter=function-list Where function-list is a comma separated list of functions to filter. [fweisbec@gmail.com: picked the documentation changes from the v2 patch] Signed-off-by: Stefan Assmann <sassmann@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <4AD2DEB9.2@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: (34 commits) [SCSI] qla2xxx: Fix NULL ptr deref bug in fail path during queue create [SCSI] st: fix possible memory use after free after MTSETBLK ioctl [SCSI] be2iscsi: Moving to pci_pools v3 [SCSI] libiscsi: iscsi_session_setup to allow for private space [SCSI] be2iscsi: add 10Gbps iSCSI - BladeEngine 2 driver [SCSI] zfcp: Fix hang when offlining device with offline chpid [SCSI] zfcp: Fix lockdep warning when offlining device with offline chpid [SCSI] zfcp: Fix oops during shutdown of offline device [SCSI] zfcp: Fix initial device and cfdc for delayed adapter allocation [SCSI] zfcp: correctly initialize unchained requests [SCSI] mpt2sas: Bump version 02.100.03.00 [SCSI] mpt2sas: Support dev remove when phy status is MPI2_EVENT_SAS_TOPO_PHYSTATUS_VACANT [SCSI] mpt2sas: Timeout occurred within the HANDSHAKE logic while waiting on firmware to ACK. [SCSI] mpt2sas: Call init_completion on a per request basis. [SCSI] mpt2sas: Target Reset will be issued from Interrupt context. [SCSI] mpt2sas: Added SCSIIO, Internal and high priority memory pools to support multiple TM [SCSI] mpt2sas: Copyright change to 2009. [SCSI] mpt2sas: Added mpi2_history.txt for MPI2 headers. [SCSI] mpt2sas: Update driver to MPI2 REV K headers. [SCSI] bfa: Brocade BFA FC SCSI driver ...
2009-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/addr: Fix resolution of local IPv6 addresses RDMA/cxgb3: Handle NULL inetdev pointer in iwch_query_port() mlx4_core: Add 40GigE device ID RDMA/iwcm: Don't call provider reject func with irqs disabled IB: Fix typo in udev rule documentation
2009-10-08x86, vmi: Mark VMI deprecated and schedule it for removalAlok Kataria
Add text in feature-removal.txt indicating that VMI will be removed in the 2.6.37 timeframe. Signed-off-by: Alok N Kataria <akataria@vmware.com> Acked-by: Chris Wright <chrisw@sous-sol.org> LKML-Reference: <1254193238.13456.48.camel@ank32.eng.vmware.com> [ removed a bogus Kconfig change, marked (DEPRECATED) in Kconfig ] Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) ethoc: limit the number of buffers to 128 ethoc: use system memory as buffer ethoc: align received packet to make IP header at word boundary ethoc: fix buffer address mapping ethoc: fix typo to compute number of tx descriptors au1000_eth: Duplicate test of RX_OVERLEN bit in update_rx_stats() netxen: Fix Unlikely(x) > y pasemi_mac: ethtool get settings fix add maintainer for network drop monitor kernel service tg3: Fix phylib locking strategy rndis_host: support ETHTOOL_GPERMADDR ipv4: arp_notify address list bug gigaset: add kerneldoc comments gigaset: correct debugging output selection gigaset: improve error recovery gigaset: fix device ERROR response handling gigaset: announce if built with debugging gigaset: handle isoc frame errors more gracefully gigaset: linearize skb gigaset: fix reject/hangup handling ...
2009-10-08page-types: add hwpoison/unpoison featureWu Fengguang
For hwpoison stress testing. The debugfs mount point is assumed to be /debug/. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08page-types: introduce kpageflags_flags()Wu Fengguang
2009-10-08page-types: make voffset local variablesWu Fengguang
2009-10-08page-types: make standalone pagemap/kpageflags read routinesWu Fengguang
Refactor the code to be more modular and easier to reuse. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08page-types: introduce checked_open()Wu Fengguang
This helps merge duplicate code (now and future) and outstand the main logic. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08page-types: add GPL noteWu Fengguang
2009-10-08pagemap: document KPF_KSM and show it in page-typesWu Fengguang
It indicates to the system admin that processes mapping such pages may be eating less physical memory than the reported numbers by legacy tools. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Acked-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08pagemap: export KPF_HWPOISONWu Fengguang
This flag indicates a hardware detected memory corruption on the page. Any future access of the page data may bring down the machine. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08cgroups: update documentation of cgroups tasks and procs filesPaul Menage
Update documentation of cgroups tasks and procs files Document the cgroup.procs file. Clarify the semantics of the cgroup.procs and tasks files. Although the current cgroup.procs interface returns a sorted and uniqified list of pids, potential future performance enhancements could result in those properties being removed - explicitly document this aspect of the API. There are no existing users of cgroup.procs, so compatibility isn't an issue. There are users of the "tasks" file, but none that would appear to break in the event of the sorted property being broken. The standard "libcpuset" explicitly sorts the results of reading from the tasks file, and "libcg" and other users don't appear to care about ordering. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-08ksm: more on default valuesHugh Dickins
Adjust the max_kernel_pages default to a quarter of totalram_pages, instead of nr_free_buffer_pages() / 4: the KSM pages themselves come from highmem, and even on a 16GB PAE machine, 4GB of KSM pages would only be pinning 32MB of lowmem with their rmap_items, so no need for the more obscure calculation (nor for its own special init function). There is no way for the user to switch KSM on if CONFIG_SYSFS is not enabled, so in that case default run to KSM_RUN_MERGE. Update KSM Documentation and Kconfig to reflect the new defaults. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Izik Eidus <ieidus@redhat.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-07IB: Fix typo in udev rule documentationBart Van Assche
The proper syntax for udev rules is KERNEL==... instead of KERNEL=... Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Reported-by: Lukasz Jurewicz <lukasz.jurewicz@gmail.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-10-06Documentation: expand isdn/INTERFACE.CAPI documentTilman Schmidt
- Note that send_message() may be called in interrupt context. - Describe the storage of CAPI messages and payload data in SKBs. - Add more details to the description of the _cmsg structure. - Describe kernelcapi debugging output. Impact: documentation Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Don't leak 64-bit kernel register values to 32-bit processes x86, SLUB: Remove unused CONFIG FAST_CMPXCHG_LOCAL x86: earlyprintk: Fix regression to handle serial,ttySn as 1 arg x86: Don't generate cmpxchg8b_emu if CONFIG_X86_CMPXCHG64=y x86: Fix csum_ipv6_magic asm memory clobber x86: Optimize cmpxchg64() at build-time some more
2009-10-04pktgen: Fix multiqueue handlingEric Dumazet
It is not currently possible to instruct pktgen to use one selected tx queue. When Robert added multiqueue support in commit 45b270f8, he added an interval (queue_map_min, queue_map_max), and his code doesnt take into account the case of min = max, to select one tx queue exactly. I suspect a high performance setup on a eight txqueue device wants to use exactly eight cpus, and assign one tx queue to each sender. This patchs makes pktgen select the right tx queue, not the first one. Also updates Documentation to reflect Robert changes. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-04Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: macintosh: Don't assume i2c device probing always succeeds i2c: Hide probe errors caused by ACPI resource conflicts i2c: Minor documentation update mfd: AB3100 drop unused module parameters Staging: IIO: tsl2561: Drop unused module parameters leds: leds-pca9532 - Drop unused module parameters ltc4215/ltc4245: Discard obsolete detect methods ds2482: Discard obsolete detect method max6875: Discard obsolete detect method i2c: Move misc devices documentation
2009-10-04i2c: Minor documentation updateJean Delvare
The sysfs path to i2c adapters has changed recently, update the documentation to reflect that change. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-04ltc4215/ltc4245: Discard obsolete detect methodsJean Delvare
There is no point in implementing a detect callback for the LTC4215 and LTC4245, as these devices can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callbacks. This shrinks the binary module sizes by 36% and 46%, respectively. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2009-10-04ds2482: Discard obsolete detect methodJean Delvare
There is no point in implementing a detect callback for the DS2482, as this device can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callback. This shrinks the binary module size by 21%. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ben Gardner <gardner.ben@gmail.com>
2009-10-04max6875: Discard obsolete detect methodJean Delvare
There is no point in implementing a detect callback for the MAX6875, as this device can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callback. This basically divides the binary module size by 2. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Ben Gardner <gardner.ben@gmail.com>
2009-10-04i2c: Move misc devices documentationJean Delvare
Some times ago the eeprom and max6875 drivers moved to drivers/misc/eeprom, but their documentation did not follow. It's finally time to get rid of Documentation/i2c/chips. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Gardner <gardner.ben@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2009-10-04Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: (41 commits) Revert "Seperate read and write statistics of in_flight requests" cfq-iosched: don't delay async queue if it hasn't dispatched at all block: Topology ioctls cfq-iosched: use assigned slice sync value, not default cfq-iosched: rename 'desktop' sysfs entry to 'low_latency' cfq-iosched: implement slower async initiate and queue ramp up cfq-iosched: delay async IO dispatch, if sync IO was just done cfq-iosched: add a knob for desktop interactiveness Add a tracepoint for block request remapping block: allow large discard requests block: use normal I/O path for discard requests swapfile: avoid NULL pointer dereference in swapon when s_bdev is NULL fs/bio.c: move EXPORT* macros to line after function Add missing blk_trace_remove_sysfs to be in pair with blk_trace_init_sysfs cciss: fix build when !PROC_FS block: Do not clamp max_hw_sectors for stacking devices block: Set max_sectors correctly for stacking devices cciss: cciss_host_attr_groups should be const cciss: Dynamically allocate the drive_info_struct for each logical drive. cciss: Add usage_count attribute to each logical drive in /sys ...
2009-10-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of ssh://master.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (21 commits) ALSA: usb - Use strlcat() correctly ALSA: Fix invalid __exit in sound/mips/*.c ALSA: hda - Fix / improve ALC66x parser ALSA: ctxfi: Swapped SURROUND-SIDE mute sound: Make keywest_driver static ALSA: intel8x0 - Mute External Amplifier by default for Sony VAIO VGN-B1VP ALSA: hda - Fix digita/analog mic auto-switching with IDT codecs ASoC: fix kconfig order of Blackfin drivers ALSA: hda - Added quirk to enable sound on Toshiba NB200 ASoC: Fix dependency of CONFIG_SND_PXA2XX_SOC_IMOTE2 ALSA: Don't assume i2c device probing always succeeds ALSA: intel8x0 - Mute External Amplifier by default for Sony VAIO VGN-T350P ALSA: echoaudio - Re-enable the line-out control for the Mia card ALSA: hda - Resurrect input-source mixer of ALC268 model=acer ALSA: hda - Analog Devices AD1984A add HP Touchsmart model ALSA: hda - Add HP Pavilion dv4t-1300 to MSI whitelist ALSA: hda - CD-audio sound for hda-intel conexant benq laptop ASoC: DaVinci: Correct McASP FIFO initialization ASoC: Davinci: Fix race with cpu_dai->dma_data ASoC: DaVinci: Fix divide by zero error during 1st execution ...
2009-10-03Merge branch 'fix/hda' into for-linusTakashi Iwai
2009-10-03ieee1394: update URLs in debugging-via-ohci1394.txtJustin P. Mattock
Update URLs of the userspace tools to use ohci1394_dma=early for debugging. Seems the address ftp://ftp.suse.de/private/bk/firewire/tools/* is not very helpful. After a quick search, seems this was talked about: http://www.mail-archive.com/kgdb-bugreport@lists.sourceforge.net/msg02761.html (can't find the original thread). Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2009-10-02Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (25 commits) ARM: 5728/1: Proper prefetch abort handling on ARMv6 and ARMv7 ARM: 5727/1: Pass IFSR register to do_PrefetchAbort() ARM: 5740/1: fix valid_phys_addr_range() range check ARM: 5739/1: ARM: allow empty ATAG_CORE ARM: 5735/1: sa1111: CodingStyle cleanups ARM: 5738/1: Correct TCM documentation ARM: 5734/1: arm: fix compilation of entry-common.S for older CPUs ARM: 5733/1: fix bcmring compile error ARM: 5732/1: remove redundant include file ARM: 5731/2: Fix U300 generic GPIO, remove ifdefs from MMCI v3 ARM: Ensure do_cache_op takes mmap_sem ARM: Fix __cpuexit section mismatch warnings ARM: Don't allow highmem on SMP platforms without h/w TLB ops broadcast ARM: includecheck fix: mach-davinci, board-dm365-evm.c ARM: Remove unused CONFIG SA1100_H3XXX ARM: Fix warning: unused variable 'highmem' ARM: Fix warning: #warning syscall migrate_pages not implemented ARM: Fix SA11x0 clocksource warning ARM: Fix SA1100 Neponset serial section mismatch ARM: Fix SA1100 Assabet/Neponset PCMCIA section mismatch warnings ...
2009-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (46 commits) cnic: Fix NETDEV_UP event processing. uvesafb/connector: Disallow unpliviged users to send netlink packets pohmelfs/connector: Disallow unpliviged users to configure pohmelfs dst/connector: Disallow unpliviged users to configure dst dm/connector: Only process connector packages from privileged processes connector: Removed the destruct_data callback since it is always kfree_skb() connector/dm: Fixed a compilation warning connector: Provide the sender's credentials to the callback connector: Keep the skb in cn_callback_data e1000e/igb/ixgbe: Don't report an error if devices don't support AER net: Fix wrong sizeof net: splice() from tcp to pipe should take into account O_NONBLOCK net: Use sk_mark for routing lookup in more places sky2: irqname based on pci address skge: use unique IRQ name IPv4 TCP fails to send window scale option when window scale is zero net/ipv4/tcp.c: fix min() type mismatch warning Kconfig: STRIP: Remove stale bits of STRIP help text NET: mkiss: Fix typo tg3: Remove prev_vlan_tag from struct tx_ring_info ...
2009-10-02connector: Provide the sender's credentials to the callbackPhilipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com> Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-02net: Fix wrong sizeofJean Delvare
Which is why I have always preferred sizeof(struct foo) over sizeof(var). Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
