Provide rb_insert_augmented() and rb_erase_augmented() through a new
rbtree_augmented.h include file. rb_erase_augmented() is defined there as
an __always_inline function, in order to allow inlining of augmented
rbtree callbacks into it. Since this generates a relatively large
function, each augmented rbtree user should make sure to have a single
call site.
Signed-off-by: Michel Lespinasse <walken@google.com>
Cc: Hillf Danton <dhillf@gmail.com>
After both prio_tree users have been converted to use red-black trees,
there is no need to keep around the prio tree library anymore.
Introduce new augmented rbtree APIs that allow minimal recalculation of
augmented node information.
A new callback is added to the rbtree insertion and erase rebalancing
functions, to be called on each tree rotations. Such rotations preserve
the subtree's root augmented value, but require recalculation of the one
child that was previously located at the subtree root.
In the insertion case, the handcoded search phase must be updated to
maintain the augmented information on insertion, and then the rbtree
coloring/rebalancing algorithms keep it up to date.
In the erase case, things are more complicated since it is library
code that manipulates the rbtree in order to remove internal nodes.
This requires a couple additional callbacks to copy a subtree's
augmented value when a new root is stitched in, and to recompute
augmented values down the ancestry path when a node is removed from
the tree.
In order to preserve maximum speed for the non-augmented case,
we provide two versions of each tree manipulation function.
rb_insert_augmented() is the augmented equivalent of rb_insert_color(),
and rb_erase_augmented() is the augmented equivalent of rb_erase().
The deprecated /proc/<pid>/oom_adj is scheduled for removal this month.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Acked-by: David Rientjes <rientjes@google.com>
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA,
currently it lost original meaning but still has some effects:
| effect | alternative flags
1| account as reserved_vm | VM_IO
2| skip in core dump | VM_IO, VM_DONTDUMP
3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP
This patch removes reserved_vm counter from mm_struct. Seems like nobody
cares about it, it does not exported into userspace directly, it only
reduces total_vm showed in proc.
Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP.
remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP.
remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP.
[akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Venkatesh Pallipadi <venki@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This contains pretty many small commits covering fairly large range of
files in sound/ directory. Partly because of additional API support
and partly because of constantly developed ASoC and ARM stuff.
Some highlights:
- Introduced the helper function and documentation for exposing the
channel map via control API, as discussed in Plumbers; most of PCI
drivers are covered, will follow more drivers later
- Most of drivers have been replaced with the new PM callbacks (if
the bus is supported)
- HD-audio controller got the support of runtime PM and the support
of D3 clock-stop. Also changing the power_save option in sysfs
kicks off immediately to enable / disable the power-save mode.
- Another significant code change in HD-audio is the rewrite of
firmware loading code. Other than that, most of changes in
HD-audio are continued cleanups and standardization for the generic
auto parser and bug fixes (HBR, device-specific fixups), in
addition to the support of channel-map API.
- Addition of ASoC bindings for the compressed API, used by the
mid-x86 drivers.
- Lots of cleanups and API refreshes for ASoC codec drivers and
DaVinci.
- Conversion of OMAP to dmaengine.
- New machine driver for Wolfson Microelectronics Bells.
- New CODEC driver for Wolfson Microelectronics WM0010.
- Enhancements to the ux500 and wm2000 drivers
- A new driver for DA9055 and the support for regulator bypass mode."
Fix up various arm soc header file reorg conflicts.
* tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits)
ALSA: hda - Add new codec ALC283 ALC290 support
ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls
ALSA: hda - fix indices on boost volume on Conexant
ALSA: aloop - add locking to timer access
ALSA: hda - Fix hang caused by race during suspend.
sound: Remove unnecessary semicolon
ALSA: hda/realtek - Fix detection of ALC271X codec
ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310
ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event
ALSA: hda - make a generic unsol event handler
ASoC: codecs: Add DA9055 codec driver
ASoC: eukrea-tlv320: Convert it to platform driver
ALSA: ASoC: add DT bindings for CS4271
ASoC: wm_hubs: Ensure volume updates are handled during class W startup
ASoC: wm5110: Adding missing volume update bits
ASoC: wm5110: Add OUT3R support
ASoC: wm5110: Add AEC loopback support
ASoC: wm5110: Rename EPOUT to HPOUT3
ASoC: arizona: Add more clock rates
ASoC: arizona: Add more DSP options for mixer input muxes
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pul ACPI & Power Management updates from Len Brown:
- acpidump utility added
- intel_idle driver now supports IVB Xeon
- turbostat utility can now count SMIs
- ACPI can now bind to USB3 hubs
- misc fixes
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (49 commits)
ACPI: Add new sysfs interface to export device description
ACPI: Harden acpi_table_parse_entries() against BIOS bug
tools/power/turbostat: add option to count SMIs, re-name some options
tools/power turbostat: add [-d MSR#][-D MSR#] options to print counter deltas
intel_idle: enable IVB Xeon support
tools/power turbostat: add [-m MSR#] option
tools/power turbostat: make -M output pretty
tools/power turbostat: print more turbo-limit information
tools/power turbostat: delete unused line
tools/power turbostat: run on IVB Xeon
tools/power/acpi/acpidump: create acpidump(8), local make install targets
tools/power/acpi/acpidump: version 20101221 - find dynamic tables in sysfs
ACPI: run _OSC after ACPI_FULL_INITIALIZATION
tools/power/acpi/acpidump: version 20071116
tools/power/acpi/acpidump: version 20070714
tools/power/acpi/acpidump: version 20060606
tools/power/acpi/acpidump: version 20051111
xo15-ebook: convert to module_acpi_driver()
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull ceph updates from Sage Weil:
"The bulk of this pull is a series from Alex that refactors and cleans
up the RBD code to lay the groundwork for supporting the new image
format and evolving feature set. There are also some cleanups in
libceph, and for ceph there's fixed validation of file striping
layouts and a bugfix in the code handling a shrinking MDS cluster."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (71 commits)
ceph: avoid 32-bit page index overflow
ceph: return EIO on invalid layout on GET_DATALOC ioctl
rbd: BUG on invalid layout
ceph: propagate layout error on osd request creation
libceph: check for invalid mapping
ceph: convert to use le32_add_cpu()
ceph: Fix oops when handling mdsmap that decreases max_mds
rbd: update remaining header fields for v2
rbd: get snapshot name for a v2 image
rbd: get the snapshot context for a v2 image
rbd: get image features for a v2 image
rbd: get the object prefix for a v2 rbd image
rbd: add code to get the size of a v2 rbd image
rbd: lay out header probe infrastructure
rbd: encapsulate code that gets snapshot info
rbd: add an rbd features field
rbd: don't use index in __rbd_add_snap_dev()
rbd: kill create_snap sysfs entry
rbd: define rbd_dev_image_id()
rbd: define some new format constants
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"The big new feature added this time is supporting online resizing
using the meta_bg feature. This allows us to resize file systems
which are greater than 16TB. In addition, the speed of online
resizing has been improved in general.
We also fix a number of races, some of which could lead to deadlocks,
in ext4's Asynchronous I/O and online defrag support, thanks to good
work by Dmitry Monakhov.
There are also a large number of more minor bug fixes and cleanups
from a number of other ext4 contributors, quite of few of which have
submitted fixes for the first time."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (69 commits)
ext4: fix ext4_flush_completed_IO wait semantics
ext4: fix mtime update in nodelalloc mode
ext4: fix ext_remove_space for punch_hole case
ext4: punch_hole should wait for DIO writers
ext4: serialize truncate with owerwrite DIO workers
ext4: endless truncate due to nonlocked dio readers
ext4: serialize unlocked dio reads with truncate
ext4: serialize dio nonlocked reads with defrag workers
ext4: completed_io locking cleanup
ext4: fix unwritten counter leakage
ext4: give i_aiodio_unwritten a more appropriate name
ext4: ext4_inode_info diet
ext4: convert to use leXX_add_cpu()
ext4: ext4_bread usage audit
fs: reserve fallocate flag codepoint
ext4: remove redundant offset check in mext_check_arguments()
ext4: don't clear orphan list on ro mount with errors
jbd2: fix assertion failure in commit code due to lacking transaction credits
ext4: release donor reference when EXT4_IOC_MOVE_EXT ioctl fails
ext4: enable FITRIM ioctl on bigalloc file system
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull i2c updates from Jean Delvare:
"Most visible changes are the SMBus multiplexing support added to the
i2c-i801 driver, as well as support for the VIA VX900."
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c-piix4: Fix build failure
i2c: Correct struct i2c_driver doc about detection
i2c-i801: Let i2c-mux-gpio find the GPIO chip
i2c-mux-gpio: Update documentation
i2c-mux-gpio: Add support for dynamically allocated GPIO pins
i2c-mux-gpio: Use devm_kzalloc instead of kzalloc
i2c-i801: Support SMBus multiplexing on Asus Z8 series
i2c-viapro: Add VIA VX900 device ID
i2c-parport: i2c_parport_irq can be static
i2c-designware: i2c_dw_xfer_msg can be static
i2c/scx200_*: Replace printks with pr_<level>s
i2c: Make I2C available on UML
i2c: Convert struct i2c_msg initialization to C99 format
i2c-smbus: Convert kzalloc to devm_kzalloc
i2c-mux: Add support for device auto-detection
Pull ARM updates from Russell King:
"This is the first chunk of ARM updates for this merge window.
Conflicts are expected in two files - asm/timex.h and
mach-integrator/integrator_cp.c. Nothing particularly stands out more
than anything else.
Most of the growth is down to the opcodes stuff from Dave Martin,
which is countered by Rob's patches to use more of the asm-generic
headers on ARM."
(A few more conflicts grew since then, but it all looked fairly trivial)
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (44 commits)
ARM: 7548/1: include linux/sched.h in syscall.h
ARM: 7541/1: Add ARM ERRATA 775420 workaround
ARM: ensure vm_struct has its phys_addr member filled in
ARM: 7540/1: kexec: Check segment memory addresses
ARM: 7539/1: kexec: scan for dtb magic in segments
ARM: 7538/1: delay: add registration mechanism for delay timer sources
ARM: 7536/1: smp: Formalize an IPI for wakeup
ARM: 7525/1: ptrace: use updated syscall number for syscall auditing
ARM: 7524/1: support syscall tracing
ARM: 7519/1: integrator: convert platform devices to Device Tree
ARM: 7518/1: integrator: convert AMBA devices to device tree
ARM: 7517/1: integrator: initial device tree support
ARM: 7516/1: plat-versatile: add DT support to FPGA IRQ
ARM: 7515/1: integrator: check PL010 base address from resource
ARM: 7514/1: integrator: call common init function from machine
ARM: 7522/1: arch_timers: register a time/cycle counter
ARM: 7523/1: arch_timers: enable the use of the virtual timer
ARM: 7531/1: mark kernelmode mem{cpy,set} non-experimental
ARM: 7520/1: Build dtb files in all target
ARM: Fix build warning in arch/arm/mm/alignment.c
Pull late ARM soc platform updates from Olof Johansson:
"This branch contains updates to OMAP and Marvell platforms (kirkwood,
dove, mvebu) that came in after we had done the big multiplatform
merges, so they were kept separate from the rest, and not separated
into the traditional topics of cleanup/driver/platform features.
For OMAP, the updates are:
- Runtime PM conversions for the GPMC and RNG IP blocks
- Preparation patches for the OMAP common clock framework conversion
- clkdev alias additions required by other drivers
- Performance Monitoring Unit (PMU) support for OMAP2, 3, and
non-4430 OMAP4
- OMAP hwmod code and data improvements
- Preparation patches for the IOMMU runtime PM conversion
- Preparation patches for OMAP4 full-chip retention support
For Kirkwood/Dove/mvebu:
- New driver for "address decoder controller" for mvebu, which is a
piece of hardware that configures addressable devices and
peripherals. First user is the boot rom aperture on armada XP
since it is needed for SMP support.
- New device tree bindings for peripherals such as gpio-fan, iconnect
nand, mv_cesa and the above address decoder controller.
- Some defconfig updates, mostly to enable new DT boards and a few
drivers.
- New drivers using the pincontrol subsystem for dove, kirkwood and
mvebu
- New clean gpio driver for mvebu"
* tag 'soc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (98 commits)
ARM: mvebu: fix build breaks from multi-platform conversion
ARM: OMAP4460/4470: PMU: Enable PMU for OMAP4460/70
ARM: OMAP2+: PMU: Add runtime PM support
ARM: OMAP4430: PMU: prepare to create PMU device via HWMOD
ARM: OMAP2+: PMU: Convert OMAP2/3 devices to use HWMOD
ARM: OMAP3: hwmod data: Add debugss HWMOD data
ARM: OMAP2+: clockdomain/hwmod: add workaround for EMU clockdomain idle problems
ARM: OMAP: Add a timer attribute for timers that can interrupt the DSP
hwrng: OMAP: remove SoC restrictions from driver registration
ARM: OMAP: split OMAP1, OMAP2+ RNG device registration
hwrng: OMAP: convert to use runtime PM
hwrng: OMAP: store per-device data in per-device variables, not file statics
ARM: OMAP2xxx: hwmod/CM: add RNG integration data
ARM: OMAP2+: gpmc: minimal driver support
ARM: OMAP2+: gpmc: Adapt to HWMOD
ARM: OMAP2/3: hwmod data: add gpmc
ARM: OMAP4: hwmod data: add mmu hwmod for ipu and dsp
ARM: OMAP3: hwmod data: add mmu data for iva and isp
ARM: OMAP: iommu: fix including iommu.h without IOMMU_API selected
ARM: OMAP4: hwmod data: add missing HWMOD_NO_IDLEST flags to some PRCM IP blocks
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
"The first part of the media updates for Kernel 3.7.
This series contain:
- A major tree renaming patch series: now, drivers are organized
internally by their used bus, instead of by V4L2 and/or DVB API,
providing a cleaner driver location for hybrid drivers that
implement both APIs, and allowing to cleanup the Kconfig items and
make them more intuitive for the end user;
- Media Kernel developers are typically very lazy with their duties
of keeping the MAINTAINERS entries for their drivers updated. As
now the tree is more organized, we're doing an effort to add/update
those entries for the drivers that aren't currently orphan;
- Several DVB USB drivers got moved to a new DVB USB v2 core; the new
core fixes several bugs (as the existing one that got bitroted).
Now, suspend/resume finally started to work fine (at least with
some devices - we should expect more work with regards to it);
- added multistream support for DVB-T2, and unified the API for
DVB-S2 and ISDB-S. Backward binary support is preserved;
- as usual, a few new drivers, some V4L2 core improvements and lots
of drivers improvements and fixes.
There are some points to notice on this series:
1) you should expect a trivial merge conflict on your tree, with the
removal of Documentation/feature-removal-schedule.txt: this series
would be adding two additional entries there. I opted to not
rebase it due to this recent change;
2) With regards to the PCTV 520e udev-related breakage, I opted to
fix it in a way that the patches can be backported to 3.5 even
without your firmware fix patch. This way, Greg doesn't need to
rush backporting your patch (as there are still the firmware cache
and firmware path customization issues to be addressed there).
I'll send later a patch (likely after the end of the merge window)
reverting the rest of the DRX-K async firmware request, fully
restoring its original behaviour to allow media drivers to
initialize everything serialized as before for 3.7 and upper.
3) I'm planning to work on this weekend to test the DMABUF patches
for V4L2. The patches are on my queue for several Kernel cycles,
but, up to now, there is/was no way to test the series locally.
I have some concerns about this particular changeset with regards
to security issues, and with regards to the replacement of the old
VIDIOC_OVERLAY ioctl's that is broken on modern systems, due to
GPU drivers change. The Overlay API allows direct PCI2PCI
transfers from a media capture card into the GPU framebuffer, but
its API is crappy. Also, the only existing X11 driver that
implements it requires a XV extension that is not available
anymore on modern drivers. The DMABUF can do the same thing, but
with it is promising to be a properly-designed API. If I can
successfully test this series and be happy with it, I should be
asking you to pull them next week."
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (717 commits)
em28xx: regression fix: use DRX-K sync firmware requests on em28xx
drxk: allow loading firmware synchrousnously
em28xx: Make all em28xx extensions to be initialized asynchronously
[media] tda18271: properly report read errors in tda18271_get_id
[media] tda18271: delay IR & RF calibration until init() if delay_cal is set
[media] MAINTAINERS: add Michael Krufky as tda827x maintainer
[media] MAINTAINERS: add Michael Krufky as tda8290 maintainer
[media] MAINTAINERS: add Michael Krufky as cxusb maintainer
[media] MAINTAINERS: add Michael Krufky as lg2160 maintainer
[media] MAINTAINERS: add Michael Krufky as lgdt3305 maintainer
[media] MAINTAINERS: add Michael Krufky as mxl111sf maintainer
[media] MAINTAINERS: add Michael Krufky as mxl5007t maintainer
[media] MAINTAINERS: add Michael Krufky as tda18271 maintainer
[media] s5p-tv: Report only multi-plane capabilities in vidioc_querycap
[media] s5p-mfc: Fix misplaced return statement in s5p_mfc_suspend()
[media] exynos-gsc: Add missing static storage class specifiers
[media] exynos-gsc: Remove <linux/version.h> header file inclusion
[media] s5p-fimc: Fix incorrect condition in fimc_lite_reqbufs()
[media] s5p-tv: Fix potential NULL pointer dereference error
[media] s5k6aa: Fix possible NULL pointer dereference
Pull pstore changes from Anton Vorontsov:
1) We no longer ad-hoc to the function tracer "high level"
infrastructure and no longer use its debugfs knobs. The change
slightly touches kernel/trace directory, but it got the needed ack
from Steven Rostedt:
http://lkml.org/lkml/2012/8/21/688
2) Added maintainers entry;
3) A bunch of fixes, nothing special.
* tag 'for-v3.7' of git://git.infradead.org/users/cbou/linux-pstore:
pstore: Avoid recursive spinlocks in the oops_in_progress case
pstore/ftrace: Convert to its own enable/disable debugfs knob
pstore/ram: Add missing platform_device_unregister
MAINTAINERS: Add pstore maintainers
pstore/ram: Mark ramoops_pstore_write_buf() as notrace
pstore/ram: Fix printk format warning
pstore/ram: Fix possible NULL dereference
Pull battery updates from Anton Vorontsov:
"1. New drivers:
- Marvell 88pm860x charger and battery drivers;
- Texas Instruments LP8788 charger driver;
2. Two new power supply properties: whether a battery is authentic,
and chargers' maximal currents and voltages;
3. A lot of TI LP8727 Charger cleanups;
4. New features for Charger Manager, mainly now we can disable
specific regulators;
5. Random fixes and cleanups for other drivers."
Fix up trivial conflicts in <linux/mfd/88pm860x.h>
* tag 'for-v3.7' of git://git.infradead.org/battery-2.6: (52 commits)
pda_power: Remove ac_draw_failed goto and label
charger-manager: Add support sysfs entry for charger
charger-manager: Support limit of maximum possible
charger-manager: Check fully charged state of battery periodically
lp8727_charger: More pure cosmetic improvements
lp8727_charger: Fix checkpatch warning
lp8727_charger: Add description in the private data
lp8727_charger: Fix a typo - chg_parm to chg_param
lp8727_charger: Make some cosmetic changes in lp8727_delayed_func()
lp8727_charger: Clean up lp8727_charger_changed()
lp8727_charger: Return if the battery is discharging
lp8727_charger: Make lp8727_charger_get_propery() simpler
lp8727_charger: Make lp8727_ctrl_switch() inline
lp8727_charger: Make lp8727_init_device() shorter
lp8727_charger: Clean up lp8727_is_charger_attached()
lp8727_charger: Use specific definition
lp8727_charger: Clean up lp8727 definitions
lp8727_charger: Use the definition rather than enum
lp8727_charger: Fix code for getting battery temp
lp8727_charger: Clear interrrupts at inital time
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull ADM Xen support from Konrad Rzeszutek Wilk:
Features:
* Allow a Linux guest to boot as initial domain and as normal guests
on Xen on ARM (specifically ARMv7 with virtualized extensions). PV
console, block and network frontend/backends are working.
Bug-fixes:
* Fix compile linux-next fallout.
* Fix PVHVM bootup crashing.
The Xen-unstable hypervisor (so will be 4.3 in a ~6 months), supports
ARMv7 platforms.
The goal in implementing this architecture is to exploit the hardware
as much as possible. That means use as little as possible of PV
operations (so no PV MMU) - and use existing PV drivers for I/Os
(network, block, console, etc). This is similar to how PVHVM guests
operate in X86 platform nowadays - except that on ARM there is no need
for QEMU. The end result is that we share a lot of the generic Xen
drivers and infrastructure.
Details on how to compile/boot/etc are available at this Wiki:
http://wiki.xen.org/wiki/Xen_ARMv7_with_Virtualization_Extensions
and this blog has links to a technical discussion/presentations on the
overall architecture:
http://blog.xen.org/index.php/2012/09/21/xensummit-sessions-new-pvh-virtualisation-mode-for-arm-cortex-a15arm-servers-and-x86/
* tag 'stable/for-linus-3.7-arm-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (21 commits)
xen/xen_initial_domain: check that xen_start_info is initialized
xen: mark xen_init_IRQ __init
xen/Makefile: fix dom-y build
arm: introduce a DTS for Xen unprivileged virtual machines
MAINTAINERS: add myself as Xen ARM maintainer
xen/arm: compile netback
xen/arm: compile blkfront and blkback
xen/arm: implement alloc/free_xenballooned_pages with alloc_pages/kfree
xen/arm: receive Xen events on ARM
xen/arm: initialize grant_table on ARM
xen/arm: get privilege status
xen/arm: introduce CONFIG_XEN on ARM
xen: do not compile manage, balloon, pci, acpi, pcpu and cpu_hotplug on ARM
xen/arm: Introduce xen_ulong_t for unsigned long
xen/arm: Xen detection and shared_info page mapping
docs: Xen ARM DT bindings
xen/arm: empty implementation of grant_table arch specific functions
xen/arm: sync_bitops
xen/arm: page.h definitions
xen/arm: hypercalls
'module_acpi_driver-simplify', 'turbostat' and 'usb3' into release
add acpidump utility
turbostat can now count SMIs
misc fixes
Add support to export the device description obtained from the ACPI _STR
method, if one exists for a device, to user-space via a sysfs interface.
This new interface provides a standard and platform neutral way for users
to obtain the description text stored in the ACPI _STR method. If no
_STR method exists for the device, no sysfs 'description' file will be
created. The 'description' file will be located in the /sys/devices/
directory using the device's path.
/sys/device/<bus>/<bridge path>/<device path>.../firmware_node/description
Example:
/sys/devices/pci0000:00/0000:00.07.0/0000:0e:00.0/firmware_node/description
It can also be located using the ACPI device path, for example:
/sys/devices/LNXSYSTM:00/device:00/ACPI0004:00/PNP0A08:00/device:13/device:15/description
/sys/devices/LNXSYSTM:00/device:00/ACPI0004:00/ACPI0004:01/ACPI0007:02/description
Execute the 'cat' command on the 'description' file to obtain the
description string for that device.
This patch also includes documentation describing how the new sysfs
interface works
Changes from v1-v2 based on comments by Len Brown and Fengguang Wu
* Removed output "No Description" and leaving a NULL attribute if the
_STR method failed to evaluate.
* In acpi_device_remove_files() removed the redundent check of
dev->pnp.str_obj before calling free. This check triggered a message
from smatch.
Signed-off-by: Lance Ortiz <lance.ortiz@hp.com>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next
ASoC: Additional updates for v3.7
A couple more updates for 3.7, enhancements to the ux500 and wm2000
drivers, a new driver for DA9055 and the support for regulator bypass
mode. With the exception of the DA9055 this has all had a chance to
soak in -next (the driver was added on Friday so should be in -next
today).
* Document the possibility to pass relative GPIO pin numbers.
* Document what platform device IDs to use, so that they do not
collide.
Cc: Peter Korsgaard <peter.korsgaard@barco.com>
The SMBus controller in the VIA VX900 appears to be compatible with
the VIA VX855, so just add the device ID.
This closes kernel bug #43096.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Benjamin Herrenschmidt:
"Some highlights in addition to the usual batch of fixes:
- 64TB address space support for 64-bit processes by Aneesh Kumar
- Gavin Shan did a major cleanup & re-organization of our EEH support
code (IBM fancy PCI error handling & recovery infrastructure) which
paves the way for supporting different platform backends, along
with some rework of the PCIe code for the PowerNV platform in order
to remove home made resource allocations and instead use the
generic code (which is possible after some small improvements to it
done by Gavin).
- Uprobes support by Ananth N Mavinakayanahalli
- A pile of embedded updates from Freescale folks, including new SoC
and board supports, more KVM stuff including preparing for 64-bit
BookE KVM support, ePAPR 1.1 updates, etc..."
Fixup trivial conflicts in drivers/scsi/ipr.c
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits)
powerpc/iommu: Fix multiple issues with IOMMU pools code
powerpc: Fix VMX fix for memcpy case
driver/mtd:IFC NAND:Initialise internal SRAM before any write
powerpc/fsl-pci: use 'Header Type' to identify PCIE mode
powerpc/eeh: Don't release eeh_mutex in eeh_phb_pe_get
powerpc: Remove tlb batching hack for nighthawk
powerpc: Set paca->data_offset = 0 for boot cpu
powerpc/perf: Sample only if SIAR-Valid bit is set in P7+
powerpc/fsl-pci: fix warning when CONFIG_SWIOTLB is disabled
powerpc/mpc85xx: Update interrupt handling for IFC controller
powerpc/85xx: Enable USB support in p1023rds_defconfig
powerpc/smp: Do not disable IPI interrupts during suspend
powerpc/eeh: Fix crash on converting OF node to edev
powerpc/eeh: Lock module while handling EEH event
powerpc/kprobe: Don't emulate store when kprobe stwu r1
powerpc/kprobe: Complete kprobe and migrate exception frame
powerpc/kprobe: Introduce a new thread flag
powerpc: Remove unused __get_user64() and __put_user64()
powerpc/eeh: Global mutex to protect PE tree
powerpc/eeh: Remove EEH PE for normal PCI hotplug
Merge misc patches from Andrew Morton:
"The MM tree is rather stuck while I wait to find out what the heck is
happening with sched/numa. Probably I'll need to route around all the
code which was added to -next, sigh.
So this is "everything else", or at least most of it - other small
bits are still awaiting resolutions of various kinds."
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (180 commits)
lib/decompress.c add __init to decompress_method and data
kernel/resource.c: fix stack overflow in __reserve_region_with_split()
omfs: convert to use beXX_add_cpu()
taskstats: cgroupstats_user_cmd() may leak on error
aoe: update aoe-internal version number to 50
aoe: update documentation to better reflect aoe-plus-udev usage
aoe: remove unused code
aoe: make dynamic block minor numbers the default
aoe: update and specify AoE address guards and error messages
aoe: retain static block device numbers for backwards compatibility
aoe: support more AoE addresses with dynamic block device minor numbers
aoe: update documentation with new URL and VM settings reference
aoe: update copyright year in touched files
aoe: update internal version number to 49
aoe: remove unused code and add cosmetic improvements
aoe: increase net_device reference count while using it
aoe: associate frames with the AoE storage target
aoe: disallow unsupported AoE minor addresses
aoe: do revalidation steps in order
aoe: failover remote interface based on aoe_deadsecs parameter
Signed-off-by: Ed Cashin <ecashin@coraid.com>
The old area has a new URL. Also, now that the driver can perform better,
it is worth mentioning the VM settings that help aoe to sink dirty pages
out early, avoiding unecessary memory pressure when much I/O is going on.
Some coredump handlers want to create a core file in a way compatible with
standard behavior. Standard behavior with fs.suid_dumpable = 2 is to
create core file with uid=gid=0. However, there was no way for coredump
handler to know that the process being dumped was suid'ed.
This patch adds the new %d specifier for format_corename() which simply
reports __get_dumpable(mm->flags), this is compatible with
/proc/sys/fs/suid_dumpable we already have.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=787135
Developed during a discussion with Denys Vlasenko.
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Alex Kelly <alex.page.kelly@gmail.com>
Cc: Cong Wang <amwang@redhat.com>
Cc: Jiri Moskovcak <jmoskovc@redhat.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add an RTC driver for Freescale Secure Non-Volatile Storage (SNVS)
Low Power (LP) RTC.
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
To get time information via /proc/driver/rtc, only the first device (rtc0)
is used. If the rtcN (eg. rtc1 or rtc2) is used for the system clock,
there is no way to get information of rtcN via /proc/driver/rtc. With
this patch, the time data can be retrieved from the system clock RTC.
If the RTC_HCTOSYS_DEVICE is not defined, then rtc0 is used by default.
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
The block comment style in net/ and drivers/net is non-standard.
Document it.
Cc: "Allan, Bruce W" <bruce.w.allan@intel.com>
Cc: Andy Whitcroft <apw@canonical.com>
Acked-by: Andrei Emeltchenko <andrei.emeltchenko@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD changes from Samuel Ortiz:
"MFD bits for the 3.7 merge window.
As usual we have a few new drivers:
- TI LP8788
- TI OMAP USB TLL
- Maxim MAX8907
- SMSC ECE1099
- Dialog Semiconductor DA9055
- A simpler syscon driver that allow us to get rid of the anatop one.
Drivers are also gradually getting Device Tree and IRQ domain support.
The following drivers got DT support:
- palmas, 88pm860x, tc3589x and twl4030-audio
And those ones now use the IRQ domain APIs:
- 88pm860x, tc3589x, db8500_prcmu
Also some other interesting changes:
- Intel's ICH LPC now supports Lynx Point
- TI's twl4030-audio added a GPO child
- tps6527 enabled its backlight subdevice
- The twl6030 pwm driver moved to the new PWM subsystem
And finally a bunch of cleanup and casual fixes for mc13xxx, 88pm860x,
palmas, ab8500, wm8994, wm5110, max8907 and the tps65xxx family."
Fix up various annoying conflicts: the DT and IRQ domain support came in
twice and was already in 3.6. And then it was apparently rebased.
Guys, DON'T REBASE!
* tag 'mfd-3.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (89 commits)
ARM: dts: Enable 88pm860x pmic
mfd: 88pm860x: Move gpadc init into touch
mfd: 88pm860x: Device tree support
mfd: 88pm860x: Use irqdomain
mfd: smsc: Add support for smsc gpio io/keypad driver
backlight: tps65217_bl: Add missing platform_set_drvdata in tps65217_bl_probe
mfd: DA9055 core driver
mfd: tps65910: Add alarm interrupt of TPS65910 RTC to mfd device list
mfd: wm5110: Add register patches for revision B
mfd: wm5110: Disable control interface error report for WM5110 rev B
mfd: max8907: Remove regulator-compatible from DT docs
backlight: Add TPS65217 WLED driver
mfd: Add backlight as subdevice to the tps65217
mfd: Provide the PRCMU with its own IRQ domain
mfd: Fix max8907 sparse warning
mfd: Add lp8788 mfd driver
mfd: dbx500: Provide a more accurate smp_twd clock
mfd: rc5t583: Fix warning messages
regulator: palmas: Add DT support
mfd: palmas: Change regulator defns to better suite DT
'misc', 'opcodes' and 'syscall' into for-linus
Pull KVM updates from Avi Kivity:
"Highlights of the changes for this release include support for vfio
level triggered interrupts, improved big real mode support on older
Intels, a streamlines guest page table walker, guest APIC speedups,
PIO optimizations, better overcommit handling, and read-only memory."
* tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits)
KVM: s390: Fix vcpu_load handling in interrupt code
KVM: x86: Fix guest debug across vcpu INIT reset
KVM: Add resampling irqfds for level triggered interrupts
KVM: optimize apic interrupt delivery
KVM: MMU: Eliminate pointless temporary 'ac'
KVM: MMU: Avoid access/dirty update loop if all is well
KVM: MMU: Eliminate eperm temporary
KVM: MMU: Optimize is_last_gpte()
KVM: MMU: Simplify walk_addr_generic() loop
KVM: MMU: Optimize pte permission checks
KVM: MMU: Update accessed and dirty bits after guest pagetable walk
KVM: MMU: Move gpte_access() out of paging_tmpl.h
KVM: MMU: Optimize gpte_access() slightly
KVM: MMU: Push clean gpte write protection out of gpte_access()
KVM: clarify kvmclock documentation
KVM: make processes waiting on vcpu mutex killable
KVM: SVM: Make use of asm.h
KVM: VMX: Make use of asm.h
KVM: VMX: Make lto-friendly
KVM: x86: lapic: Clean up find_highest_vector() and count_vectors()
arch/s390/include/asm/processor.h
arch/x86/kvm/i8259.c
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc
Pull remoteproc update from Ohad Ben-Cohen:
- Remoteproc Recovery - by Fernando Guzman Lugo
When a remote processor crash is detected, this mechanism will remove
all virtio children devices, wait until their drivers let go, hard
reset the remote processor and reload the firmware (resulting in the
relevant virtio children devices re-added). Essentially the entire
software stack is reset, together with the relevant hardware, so
users don't have to reset the entire phone.
- STE Modem driver is added - by Sjur Brændeland
- OMAP DSP boot address support is added - by Juan Gutierrez
- A handful of fixes/cleanups - Sjur Brændeland, Dan Carpenter, Emil
Goode
* tag 'remoteproc-for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc:
remoteproc: Fix use of format specifyer
remoteproc: fix a potential NULL-dereference on cleanup
remoteproc: select VIRTIO to avoid build breakage
remoteproc: return -EFAULT on copy_from_user failure
remoteproc: snprintf() can return more than was printed
remoteproc: Add STE modem driver
remtoteproc: maintain max notifyid
remoteproc: create a 'recovery' debugfs entry
remoteproc: add actual recovery implementation
remoteproc: add rproc_report_crash function to notify rproc crashes
remoteproc: Add dependency to HAS_DMA
remoteproc/omap: set bootaddr support
Pull drm merge (part 1) from Dave Airlie:
"So first of all my tree and uapi stuff has a conflict mess, its my
fault as the nouveau stuff didn't hit -next as were trying to rebase
regressions out of it before we merged.
Highlights:
- SH mobile modesetting driver and associated helpers
- some DRM core documentation
- i915 modesetting rework, haswell hdmi, haswell and vlv fixes, write
combined pte writing, ilk rc6 support,
- nouveau: major driver rework into a hw core driver, makes features
like SLI a lot saner to implement,
- psb: add eDP/DP support for Cedarview
- radeon: 2 layer page tables, async VM pte updates, better PLL
selection for > 2 screens, better ACPI interactions
The rest is general grab bag of fixes.
So why part 1? well I have the exynos pull req which came in a bit
late but was waiting for me to do something they shouldn't have and it
looks fairly safe, and David Howells has some more header cleanups
he'd like me to pull, that seem like a good idea, but I'd like to get
this merge out of the way so -next dosen't get blocked."
Tons of conflicts mostly due to silly include line changes, but mostly
mindless. A few other small semantic conflicts too, noted from Dave's
pre-merged branch.
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (447 commits)
drm/nv98/crypt: fix fuc build with latest envyas
drm/nouveau/devinit: fixup various issues with subdev ctor/init ordering
drm/nv41/vm: fix and enable use of "real" pciegart
drm/nv44/vm: fix and enable use of "real" pciegart
drm/nv04/dmaobj: fixup vm target handling in preparation for nv4x pcie
drm/nouveau: store supported dma mask in vmmgr
drm/nvc0/ibus: initial implementation of subdev
drm/nouveau/therm: add support for fan-control modes
drm/nouveau/hwmon: rename pwm0* to pmw1* to follow hwmon's rules
drm/nouveau/therm: calculate the pwm divisor on nv50+
drm/nouveau/fan: rewrite the fan tachometer driver to get more precision, faster
drm/nouveau/therm: move thermal-related functions to the therm subdev
drm/nouveau/bios: parse the pwm divisor from the perf table
drm/nouveau/therm: use the EXTDEV table to detect i2c monitoring devices
drm/nouveau/therm: rework thermal table parsing
drm/nouveau/gpio: expose the PWM/TOGGLE parameter found in the gpio vbios table
drm/nouveau: fix pm initialization order
drm/nouveau/bios: check that fixed tvdac gpio data is valid before using it
drm/nouveau: log channel debug/error messages from client object rather than drm client
drm/nouveau: have drm debugging macros build on top of core macros
git://git.infradead.org/users/dhowells/linux-headers
Pull preparatory patches for user API disintegration from David Howells:
"The patches herein prepare for the extraction of the Userspace API
bits from the various header files named in the Kbuild files.
New subdirectories are created under either include/uapi/ or
arch/x/include/uapi/ that correspond to the subdirectory containing
that file under include/ or arch/x/include/.
The new subdirs under the uapi/ directory are populated with Kbuild
files that mostly do nothing at this time. Further patches will
disintegrate the headers in each original directory and fill in the
Kbuild files as they do it.
These patches also:
(1) fix up #inclusions of "foo.h" rather than <foo.h>.
(2) Remove some redundant #includes from the DRM code.
(3) Make the kernel build infrastructure handle Kbuild files both in
the old places and the new UAPI place that both specify headers
to be exported.
(4) Fix some kernel tools that #include kernel headers during their
build.
I have compile tested this with allyesconfig against x86_64,
allmodconfig against i386 and a scattering of additional defconfigs of
other arches. Prepared for main script
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>"
* tag 'uapi-prep-20121002' of git://git.infradead.org/users/dhowells/linux-headers:
UAPI: Plumb the UAPI Kbuilds into the user header installation and checking
UAPI: x86: Differentiate the generated UAPI and internal headers
UAPI: Remove the objhdr-y export list
UAPI: Move linux/version.h
UAPI: Set up uapi/asm/Kbuild.asm
UAPI: x86: Fix insn_sanity build failure after UAPI split
UAPI: x86: Fix the test_get_len tool
UAPI: (Scripted) Set up UAPI Kbuild files
UAPI: Partition the header include path sets and add uapi/ header directories
UAPI: (Scripted) Convert #include "..." to #include <path/...> in kernel system headers
UAPI: (Scripted) Convert #include "..." to #include <path/...> in drivers/gpu/
UAPI: (Scripted) Remove redundant DRM UAPI header #inclusions from drivers/gpu/.
UAPI: Refer to the DRM UAPI headers with <...> and from certain headers only
Pull devicetree updates from Rob Herring:
- Import of latest upstream device tree compiler (dtc)
- New function of_get_child_by_name
- Support for #size-cells of 0 and #addr-cells of >2
- Couple of DT binding documentation updates
Fix up trivial conflicts due to of_get_child_by_name() having been added
next to the new of_get_next_available_child().
* tag 'dt-for-3.7' of git://sources.calxeda.com/kernel/linux:
MAINTAINERS: add scripts/dtc under Devicetree maintainers
dtc: import latest upstream dtc
dt: Document general interrupt controller bindings
dt/s3c64xx/spi: Use of_get_child_by_name to get a named child
dt: introduce of_get_child_by_name to get child node by name
of: i2c: add support for wakeup-source property
of/address: Handle #address-cells > 2 specially
DT: export of_irq_to_resource_table()
devicetree: serial: Add documentation for imx serial
devicetree: pwm: mxs-pwm.txt: Fix reg field annotation
of: Allow busses with #size-cells=0
Pull JFS update from Dave Kleikamp:
"JFS TRIM support and some minor fixes"
* tag 'jfs-3.7' of git://github.com/kleikamp/linux-shaggy:
jfs: Fix do_div precision in commit b40c2e66
JFS: use list_move instead of list_del/list_add
jfs: Remove obsolete email address
fs/jfs: TRIM support for JFS Filesystem
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- Integrity: add local fs integrity verification to detect offline
attacks
- Integrity: add digital signature verification
- Simple stacking of Yama with other LSMs (per LSS discussions)
- IBM vTPM support on ppc64
- Add new driver for Infineon I2C TIS TPM
- Smack: add rule revocation for subject labels"
Fixed conflicts with the user namespace support in kernel/auditsc.c and
security/integrity/ima/ima_policy.c.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits)
Documentation: Update git repository URL for Smack userland tools
ima: change flags container data type
Smack: setprocattr memory leak fix
Smack: implement revoking all rules for a subject label
Smack: remove task_wait() hook.
ima: audit log hashes
ima: generic IMA action flag handling
ima: rename ima_must_appraise_or_measure
audit: export audit_log_task_info
tpm: fix tpm_acpi sparse warning on different address spaces
samples/seccomp: fix 31 bit build on s390
ima: digital signature verification support
ima: add support for different security.ima data types
ima: add ima_inode_setxattr/removexattr function and calls
ima: add inode_post_setattr call
ima: replace iint spinblock with rwlock/read_lock
ima: allocating iint improvements
ima: add appraise action keywords and default rules
ima: integrity appraisal extension
vfs: move ima_file_free before releasing the file
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-next
This is a major rework of the nouveau driver core, to reflect more closely
how the hw is used and to make it easier to implement newer features now
that the GPUs are more clearly understood than when nouveau started.
It also contains a few other bits:
thermal patches
nv41/44 pcie gart fixes
i2c unregistering fixes.
* 'drm-nouveau-next' of git://anongit.freedesktop.org/git/nouveau/linux-2.6: (191 commits)
drivers/gpu/drm/nouveau/nouveau_dp.c
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull CMA and DMA-mapping updates from Marek Szyprowski:
"This time the pull request is rather small, because the further
redesign patches were not ready on time.
This pull request consists of the patches which extend ARM DMA-mapping
subsystem with support for CPU coherent (ACP) DMA busses. The first
client of the new version is HighBank SATA driver. The second part of
the pull request includes various cleanup for both CMA common code and
ARM DMA-mapping subsystem."
Fix up trivial add-add conflict due to the "dma-coherent" DT property
being added next to the "calxeda,port-phys" property for the Calxeda
AHCI controller.
* 'for-v3.7' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: dma-mapping: Remove unsed var at arm_coherent_iommu_unmap_page
ARM: highbank: add coherent DMA setup
ARM: kill off arch_is_coherent
ARM: add coherent iommu dma ops
ARM: add coherent dma ops
ARM: dma-mapping: Refrain noisy console message
ARM: dma-mapping: Small logical clean up
drivers: dma-contiguous: refactor dma_alloc_from_contiguous()
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull first round of SCSI updates from James Bottomley:
"This is a large set of updates, mostly for drivers (qla2xxx [including
support for new 83xx based card], qla4xxx, mpt2sas, bfa, zfcp, hpsa,
be2iscsi, isci, lpfc, ipr, ibmvfc, ibmvscsi, megaraid_sas).
There's also a rework for tape adding virtually unlimited numbers of
tape drives plus a set of dif fixes for sd and a fix for a live lock
on hot remove of SCSI devices.
This round includes a signed tag pull of isci-for-3.6
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
Fix up trivial conflict in drivers/scsi/qla2xxx/qla_nx.c due to new PCI
helper function use in a function that was removed by this pull.
* tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (198 commits)
[SCSI] st: remove st_mutex
[SCSI] sd: Ensure we correctly disable devices with unknown protection type
[SCSI] hpsa: gen8plus Smart Array IDs
[SCSI] qla4xxx: Update driver version to 5.03.00-k1
[SCSI] qla4xxx: Disable generating pause frames for ISP83XX
[SCSI] qla4xxx: Fix double clearing of risc_intr for ISP83XX
[SCSI] qla4xxx: IDC implementation for Loopback
[SCSI] qla4xxx: update copyrights in LICENSE.qla4xxx
[SCSI] qla4xxx: Fix panic while rmmod
[SCSI] qla4xxx: Fail probe_adapter if IRQ allocation fails
[SCSI] qla4xxx: Prevent MSI/MSI-X falling back to INTx for ISP82XX
[SCSI] qla4xxx: Update idc reg in case of PCI AER
[SCSI] qla4xxx: Fix double IDC locking in qla4_8xxx_error_recovery
[SCSI] qla4xxx: Clear interrupt while unloading driver for ISP83XX
[SCSI] qla4xxx: Print correct IDC version
[SCSI] qla4xxx: Added new mbox cmd to pass driver version to FW
[SCSI] scsi_dh_alua: Enable STPG for unavailable ports
[SCSI] scsi_remove_target: fix softlockup regression on hot remove
[SCSI] ibmvscsi: Fix host config length field overflow
[SCSI] ibmvscsi: Remove backend abstraction
Pull power management updates from Rafael J Wysocki:
- Improved system suspend/resume and runtime PM handling for the SH
TMU, CMT and MTU2 clock event devices (also used by ARM/shmobile).
- Generic PM domains framework extensions related to cpuidle support
and domain objects lookup using names.
- ARM/shmobile power management updates including improved support for
the SH7372's A4S power domain containing the CPU core.
- cpufreq changes related to AMD CPUs support from Matthew Garrett,
Andre Przywara and Borislav Petkov.
- cpu0 cpufreq driver from Shawn Guo.
- cpufreq governor fixes related to the relaxing of limit from Michal
Pecio.
- OMAP cpufreq updates from Axel Lin and Richard Zhao.
- cpuidle ladder governor fixes related to the disabling of states from
Carsten Emde and me.
- Runtime PM core updates related to the interactions with the system
suspend core from Alan Stern and Kevin Hilman.
- Wakeup sources modification allowing more helper functions to be
called from interrupt context from John Stultz and additional
diagnostic code from Todd Poynor.
- System suspend error code path fix from Feng Hong.
Fixed up conflicts in cpufreq/powernow-k8 that stemmed from the
workqueue fixes conflicting fairly badly with the removal of support for
hardware P-state chips. The changes were independent but somewhat
intertwined.
* tag 'pm-for-3.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (76 commits)
Revert "PM QoS: Use spinlock in the per-device PM QoS constraints code"
PM / Runtime: let rpm_resume() succeed if RPM_ACTIVE, even when disabled, v2
cpuidle: rename function name "__cpuidle_register_driver", v2
cpufreq: OMAP: Check IS_ERR() instead of NULL for omap_device_get_by_hwmod_name
cpuidle: remove some empty lines
PM: Prevent runtime suspend during system resume
PM / Sleep: use resume event when call dpm_resume_early
cpuidle / ACPI : move cpuidle_device field out of the acpi_processor_power structure
ACPI / processor: remove pointless variable initialization
ACPI / processor: remove unused function parameter
cpufreq: OMAP: remove loops_per_jiffy recalculate for smp
sections: fix section conflicts in drivers/cpufreq
cpufreq: conservative: update frequency when limits are relaxed
cpufreq / ondemand: update frequency when limits are relaxed
properly __init-annotate pm_sysrq_init()
cpufreq: Add a generic cpufreq-cpu0 driver
PM / OPP: Initialize OPP table from device tree
ARM: add cpufreq transiton notifier to adjust loops_per_jiffy for smp
cpufreq: Remove support for hardware P-state chips from powernow-k8
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
Pull libata changes from Jeff Garzik:
"Minor libata updates, nothing notable.
1) Apply -- and then revert -- the FUA feature. Caused disk
corruption in linux-next, proving it cannot be turned on by
default.
Net effect to upstream tree: zero
2) New AHCI platform driver sata_highbank
3) Improve SCSI MODE SENSE handling; support MODE SELECT
4) AHCI: support aggressive device sleep (power mgmt)
5) sata_fsl: minor fix
6) pata_arasan: clk support"
* tag 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
sata_mv: Fix warnings when no PCI
[libata] Makefile: Fix build error in sata_highbank
[libata] export ata_dev_set_feature()
libata-core: use ATA_LBA in ata_build_rw_tf()
ata/ahci_platform: Add clock framework support
pata_arasan: add Device Tree probing capability
pata_arasan: Add clk_{un}prepare() support
ata: add platform driver for Calxeda AHCI controller
sata_fsl: add workaround for data length mismatch on freescale V2 controller
ahci: implement aggressive SATA device sleep support
ata: define enum constants for IDENTIFY DEVICE
Revert "libata: enable SATA disk fua detection on default"
[libata] scsi: implement MODE SELECT command
[libata] scsi: support MODE SENSE request for changeable and default parameters
[libata] scsi: Remove unlikely() from FUA check
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc
Pull spi updates from Mark Brown:
"No framework work here, only a bunch of driver updates of varying
sizes:
- Factoring out of the core hardware support from the MXS MMC driver
by Marek Vasut to allow the hardware to also be used for SPI.
- Lots of error handling cleanups from Guenter Roeck
- Removal of the existing Tegra driver which is quite comprehensively
broken as detailed in the changelog for the removal.
- DT suppport for the PL022 and GPIO drivers.
- pinctrl support for OMAP and PL022."
Pulling from Mark Brown as Grant Likely is still busy moving.
* tag 'spi-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc: (53 commits)
spi: remove completely broken Tegra driver
spi/imx: set the inactive state of the clock according to the clock polarity
spi/pl022: get/put resources on suspend/resume
spi/pl022: use more managed resources
spi/pl022: Devicetree support w/o platform data
spi/s3c64xx: Don't free controller_data on non-dt platforms
spi: omap2-mcspi: add pinctrl support
spi/pl022: adopt pinctrl support
spi: omap2-mcspi: Cleanup the omap2_mcspi_txrx_dma function
spi/gpio: Fix stub for spi_gpio_probe_dt()
spi/mxs: Make the SPI block clock speed configurable via DT
spi: spi-sh-hspi: drop frees of devm_ alloc'd data
spi/pl022: Fix chipselects pointer computation
spi: spi-tle62x0: Use module_spi_driver macro
mxs/spi: Rework the mxs_ssp_timeout to be more readable
mxs/spi: Decrement the DMA/PIO border
mxs/spi: Increment the transfer length only if transfer succeeded
mxs/spi: Fix issues when doing long continuous transfer
spi: spi-gpio: Add DT bindings
spi: spi-gpio: store chipselect information in private structure
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A few drivers were updated with device tree bindings and others got a
few small cleanups and fixes."
Fix trivial conflict in drivers/input/keyboard/omap-keypad.c due to
changes clashing with a whitespace cleanup.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (28 commits)
Input: wacom - mark Intuos5 pad as in-prox when touching buttons
Input: synaptics - adjust threshold for treating position values as negative
Input: hgpk - use %*ph to dump small buffer
Input: gpio_keys_polled - fix dt pdata->nbuttons
Input: Add KD[GS]KBDIACRUC ioctls to the compatible list
Input: omap-keypad - fixed formatting
Input: tegra - move platform data header
Input: wacom - add support for EMR on Cintiq 24HD touch
Input: s3c2410_ts - make s3c_ts_pmops const
Input: samsung-keypad - use of_get_child_count() helper
Input: samsung-keypad - use of_match_ptr()
Input: uinput - fix formatting
Input: uinput - specify exact bit sizes on userspace APIs
Input: uinput - mark failed submission requests as free
Input: uinput - fix race that can block nonblocking read
Input: uinput - return -EINVAL when read buffer size is too small
Input: uinput - take event lock when fetching events from buffer
Input: get rid of MATCH_BIT() macro
Input: rotary-encoder - add DT bindings
Input: rotary-encoder - constify platform data pointers
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pinctrl changes from Linus Walleij:
"Some of this stuff is hitting arch/arm/* and have been ACKed by the
ARM SoC folks, or it's device tree bindings pertaining to the specific
driver.
These are the bulk pinctrl changes for kernel v3.7:
- Add subdrivers for the DB8540 and NHK8815 Nomadik-type ASICs,
provide platform config for the Nomadik.
- Add a driver for the i.MX35.
- Add a driver for the BCM2835, an advanced GPIO expander.
- Various fixes and clean-ups and minor improvements for the core,
Nomadik, pinctr-single, sirf drivers.
- Some platform config for the ux500."
* tag 'pinctrl-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (27 commits)
pinctrl: add bcm2835 driver
pinctrl: clarify idle vs sleep states
pinctrl/nomadik: use irq_find_mapping()
pinctrl: sirf: add lost chained_irq_enter and exit in sirfsoc_gpio_handle_irq
pinctrl: sirf: initialize the irq_chip pointer of pinctrl_gpio_range
pinctrl: sirf: fix spinlock deadlock in sirfsoc_gpio_set_input
pinctrl: sirf: add missing pins to pinctrl list
pinctrl: sirf: fix a typo in sirfsoc_gpio_probe
pinctrl: pinctrl-single: add debugfs pin h/w state info
ARM: ux500: 8500: update I2C sleep states pinctrl
pinctrl: Fix potential memory leak in pinctrl_register_one_pin()
ARM: ux500: tidy up pin sleep modes
ARM: ux500: fix spi2 pin group
pinctrl: imx: remove duplicated const
pinctrl: document semantics vs GPIO
ARM: ux500: 8500: use hsit_a_2 group for HSI
pinctrl: use kasprintf() in pinmux_request_gpio()
pinctrl: pinctrl-single: Add pinctrl-single,bits type of mux
pinctrl/nomadik : add MC1_a_2 pin MC1 function group list
pinctrl: pinctrl-single: Make sure we do not change bits outside of mask
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"So this is the LW GPIO patch stack for v3.7:
- refactoring from Thierry Redding at Arnd Bergmann's request to use
the seq_file iterator interface in gpiolib.
- A new driver for Avionic Design's N-bit GPIO expander.
- Two instances of mutexes replaced by spinlocks from Axel Lin to
code that is supposed to be fastpath compliant.
- IRQ demuxer and gpio_to_irq() support for pcf857x by Kuninori
Morimoto.
- Dynamic GPIO numbers, device tree support, daisy chaining and some
other fixes for the 74x164 driver by Maxime Ripard.
- IRQ domain and device tree support for the tc3589x driver by Lee
Jones.
- Some conversion to use managed resources devm_* code.
- Some instances of clk_prepare() or clk_prepare_enable() added to
support the new, stricter common clock framework.
- Some for_each_set_bit() simplifications.
- Then a lot of fixes as we fixed up all of the above tripping over
our own shoelaces and that kind of thing."
* tag 'gpio-for-v3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (34 commits)
gpio: pcf857x: select IRQ_DOMAIN
gpio: Document device_node's det_debounce
gpio-lpc32xx: Add GPI_28
gpio: adnp: dt: Reference generic interrupt binding
gpio: Add Avionic Design N-bit GPIO expander support
gpio: pxa: using for_each_set_bit to simplify the code
gpio_msm: using for_each_set_bit to simplify the code
gpio: Enable the tc3298x GPIO expander driver for Device Tree
gpio: Provide the tc3589x GPIO expander driver with an IRQ domain
ARM: shmobile: kzm9g: use gpio-keys instead of gpio-keys-polled
gpio: pcf857x: fixup smatch WARNING
gpio: 74x164: Add support for the daisy-chaining
gpio: 74x164: dts: Add documentation for the dt binding
dt: Fix incorrect reference in gpio-led documentation
gpio: 74x164: Add device tree support
gpio: 74x164: Use dynamic gpio number assignment if no pdata is present
gpio: 74x164: Use devm_kzalloc
gpio: 74x164: Use module_spi_driver boiler plate function
gpio: sx150x: Use irq_data_get_irq_chip_data() at appropriate places
gpio: em: Use irq_data_get_irq_chip_data() at appropriate places
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- xattr support added. The implementation is shared with tmpfs. The
usage is restricted and intended to be used to manage per-cgroup
metadata by system software. tmpfs changes are routed through this
branch with Hugh's permission.
- cgroup subsystem ID handling simplified.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: Define CGROUP_SUBSYS_COUNT according the configuration
cgroup: Assign subsystem IDs during compile time
cgroup: Do not depend on a given order when populating the subsys array
cgroup: Wrap subsystem selection macro
cgroup: Remove CGROUP_BUILTIN_SUBSYS_COUNT
cgroup: net_prio: Do not define task_netpioidx() when not selected
cgroup: net_cls: Do not define task_cls_classid() when not selected
cgroup: net_cls: Move sock_update_classid() declaration to cls_cgroup.h
cgroup: trivial fixes for Documentation/cgroups/cgroups.txt
xattr: mark variable as uninitialized to make both gcc and smatch happy
fs: add missing documentation to simple_xattr functions
cgroup: add documentation on extended attributes usage
cgroup: rename subsys_bits to subsys_mask
cgroup: add xattr support
cgroup: revise how we re-populate root directory
xattr: extract simple_xattr code from tmpfs
