path: root/Documentation
2012-07-24Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull first round of SCSI updates from James Bottomley: "The most important feature of this patch set is the new async infrastructure that makes sure async_synchronize_full() synchronizes all domains and allows us to remove all the hacks (like having scsi_complete_async_scans() in the device base code) and means that the async infrastructure will "just work" in future. The rest is assorted driver updates (aacraid, bnx2fc, virto-scsi, megaraid, bfa, lpfc, qla2xxx, qla4xxx) plus a lot of infrastructure work in sas and FC. Signed-off-by: James Bottomley <JBottomley@Parallels.com>" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (97 commits) [SCSI] Revert "[SCSI] fix async probe regression" [SCSI] cleanup usages of scsi_complete_async_scans [SCSI] queue async scan work to an async_schedule domain [SCSI] async: make async_synchronize_full() flush all work regardless of domain [SCSI] async: introduce 'async_domain' type [SCSI] bfa: Fix to set correct return error codes and misc cleanup. [SCSI] aacraid: Series 7 Async. (performance) mode support [SCSI] aha152x: Allow use on 64bit systems [SCSI] virtio-scsi: Add vdrv->scan for post VIRTIO_CONFIG_S_DRIVER_OK LUN scanning [SCSI] bfa: squelch lockdep complaint with a spin_lock_init [SCSI] qla2xxx: remove unnecessary reads of PCI_CAP_ID_EXP [SCSI] qla4xxx: remove unnecessary read of PCI_CAP_ID_EXP [SCSI] ufs: fix incorrect return value about SUCCESS and FAILED [SCSI] ufs: reverse the ufshcd_is_device_present logic [SCSI] ufs: use module_pci_driver [SCSI] usb-storage: update usb devices for write cache quirk in quirk list. [SCSI] usb-storage: add support for write cache quirk [SCSI] set to WCE if usb cache quirk is present. [SCSI] virtio-scsi: hotplug support for virtio-scsi [SCSI] virtio-scsi: split scatterlist per target ...
2012-07-24Merge branch 'for-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "Nothing too interesting. A minor bug fix and some cleanups." * 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: Update remount documentation cgroup: cgroup_rm_files() was calling simple_unlink() with the wrong inode cgroup: Remove populate() documentation cgroup: remove hierarchy_mutex
2012-07-24Merge branch 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue changes from Tejun Heo: "There are three major changes. - WQ_HIGHPRI has been reimplemented so that high priority work items are served by worker threads with -20 nice value from dedicated highpri worker pools. - CPU hotplug support has been reimplemented such that idle workers are kept across CPU hotplug events. This makes CPU hotplug cheaper (for PM) and makes the code simpler. - flush_kthread_work() has been reimplemented so that a work item can be freed while executing. This removes an annoying behavior difference between kthread_worker and workqueue." * 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix spurious CPU locality WARN from process_one_work() kthread_worker: reimplement flush_kthread_work() to allow freeing the work item being executed kthread_worker: reorganize to prepare for flush_kthread_work() reimplementation workqueue: simplify CPU hotplug code workqueue: remove CPU offline trustee workqueue: don't butcher idle workers on an offline CPU workqueue: reimplement CPU online rebinding to handle idle workers workqueue: drop @bind from create_worker() workqueue: use mutex for global_cwq manager exclusion workqueue: ROGUE workers are UNBOUND workers workqueue: drop CPU_DYING notifier operation workqueue: perform cpu down operations from low priority cpu_notifier() workqueue: reimplement WQ_HIGHPRI using a separate worker_pool workqueue: introduce NR_WORKER_POOLS and for_each_worker_pool() workqueue: separate out worker_pool flags workqueue: use @pool instead of @gcwq or @cpu where applicable workqueue: factor out worker_pool from global_cwq workqueue: don't use WQ_HIGHPRI for unbound workqueues
2012-07-24Merge tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linuxLinus Torvalds
Pull common clk framework changes from Michael Turquette: "This includes a small number of core framework improvments, platform ports and new DT bindings." Fix up trivial conflicts in drivers/clk/Makefile * tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linux: (21 commits) clk: fix compile for OF && !COMMON_CLK clk: fix clk_get on of_clk_get_by_name return check clk: mxs: clk_register_clkdev mx28 usb clocks clk: add highbank clock support dt: add clock binding doc to primecell bindings clk: add DT fixed-clock binding support clk: add DT clock binding support ARM: integrator: convert to common clock clk: add versatile ICST307 driver ARM: integrator: put symbolic bus names on devices ARM: u300: convert to common clock clk: cache parent clocks only for muxes clk: wm831x: Add initial WM831x clock driver clk: Constify struct clk_init_data clk: Add CLK_IS_BASIC flag to identify basic clocks clk: Add support for rate table based dividers clk: Add support for power of two type dividers clk: mxs: imx28: decrease the frequency of ref_io1 for SSP2 and SSP3 clk: mxs: add clkdev lookup for pwm clk: mxs: Fix the GPMI clock name ...
2012-07-24Merge tag 'iommu-updates-v3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "The most important part of these updates is the IOMMU groups code enhancement written by Alex Williamson. It abstracts the problem that a given hardware IOMMU can't isolate any given device from any other device (e.g. 32 bit PCI devices can't usually be isolated). Devices that can't be isolated are grouped together. This code is required for the upcoming VFIO framework. Another IOMMU-API change written by me is the introduction of domain attributes. This makes it easier to handle GART-like IOMMUs with the IOMMU-API because now the start-address and the size of the domain address space can be queried. Besides that there are a few cleanups and fixes for the NVidia Tegra IOMMU drivers and the reworked init-code for the AMD IOMMU. The latter is from my patch-set to support interrupt remapping. The rest of this patch-set requires x86 changes which are not mergabe yet. So full support for interrupt remapping with AMD IOMMUs will come in a future merge window." * tag 'iommu-updates-v3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits) iommu/amd: Fix hotplug with iommu=pt iommu/amd: Add missing spin_lock initialization iommu/amd: Convert iommu initialization to state machine iommu/amd: Introduce amd_iommu_init_dma routine iommu/amd: Move unmap_flush message to amd_iommu_init_dma_ops() iommu/amd: Split enable_iommus() routine iommu/amd: Introduce early_amd_iommu_init routine iommu/amd: Move informational prinks out of iommu_enable iommu/amd: Split out PCI related parts of IOMMU initialization iommu/amd: Use acpi_get_table instead of acpi_table_parse iommu/amd: Fix sparse warnings iommu/tegra: Don't call alloc_pdir with as->lock iommu/tegra: smmu: Fix unsleepable memory allocation at alloc_pdir() iommu/tegra: smmu: Remove unnecessary sanity check at alloc_pdir() iommu/exynos: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/tegra: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/msm: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/omap: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/vt-d: Implement DOMAIN_ATTR_GEOMETRY attribute iommu/amd: Implement DOMAIN_ATTR_GEOMETRY attribute ...
2012-07-24Merge tag 'dt-for-3.6' of git://sources.calxeda.com/kernel/linuxLinus Torvalds
Pull devicetree updates from Rob Herring: "A small set of changes for devicetree: - Couple of Documentation fixes - Addition of new helper function of_node_full_name - Improve of_parse_phandle_with_args return values - Some NULL related sparse fixes" Grant's busy packing. * tag 'dt-for-3.6' of git://sources.calxeda.com/kernel/linux: of: mtd: nuke useless const qualifier devicetree: add helper inline for retrieving a node's full name of: return -ENOENT when no property usage-model.txt: fix typo machine_init->init_machine of: Fix null pointer related warnings in base.c file LED: Fix missing semicolon in OF documentation of: fix a few typos in the binding documentation
2012-07-24Merge tag 'pinctrl-for-v3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "These are the accumulated pin control patches for v3.6: - Various cleanups to the U300 driver - Refactor the pin control core to automatically remove any GPIO ranges when the drivers are removed, instead of having the drivers do this explicitly. - Add a function for registering a batch of GPIO ranges. - Fix a number of incorrect but non-regressive error checks. - Incremental improvements to the COH901, i.MX and Nomadik drivers - Add a one-register-per-pin entirely Device Tree-based pin control driver from Tony Lindgren." * tag 'pinctrl-for-v3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: Add one-register-per-pin type device tree based pinctrl driver pinctrl/nomadik: add spi2_oc1_2 pin group pinctrl/nomadik: kerneldoc fix pinctrl/nomadik: use devm_* allocators for gpio probe pinctrl/nomadik: add pin group to mco function pinctrl/nomadik: add hsit_a_2 pin group pinctrl/nomadik: add pin group smcs1 and smps0 pinctrl/nomadik: fix hsir_a_1_pins pin list pinctrl: pinctrl-imx: fix map setting problem if NO_PAD_CTL is set pinctrl/coh901: use clk_prepare_[en|dis]able() pinctrl/pinctrl-tegra: remove IS_ERR checking of pmx->pctl pinctrl/pinctrl-spear: remove IS_ERR checking of pmx->pctl pinctrl/u300: drop unused variable pinctrl: select the proper symbol pinctrl: add pinctrl_add_gpio_ranges function pinctrl: remove pinctrl_remove_gpio_range pinctrl/pinctrl-core: cleanup pinctrl_register pinctrl/u300: delete pointless debug print pinctrl/pinctrl-u300: remove devm_kfree at driver unload
2012-07-24Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull i2c updates from Jean Delvare: "The most important changes here are a big cleanup of the i2c-piix4 driver, cleanups and interrupt support to the i2c-i801 driver, and support for the SCCB protocol." * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-omap: Add support for I2C_M_STOP message flag i2c: Fall back to emulated SMBus if the operation isn't supported natively i2c: Add SCCB support i2c-tiny-usb: Add support for the Robofuzz OSIF USB/I2C converter i2c-i801: Enable IRQ for byte_by_byte transactions i2c-i801: Enable interrupts on ICH5/7/8/9/10 i2c-i801: Enable IRQ for SMBus transactions i2c-i801: Consolidate polling i2c-i801: Drop ENABLE_INT9 i2c-i801: Rename some SMBHSTCNT bit constants i2c-i801: Check and return errors during byte-by-byte transfers i2c-i801: Clear only status bits in HST_STS i2c-i801: Refactor use of LAST_BYTE in i801_block_transaction_byte_by_byte i2c-smbus: Use module_i2c_driver() i2c/writing-clients: Mention module_i2c_driver() i2c-piix4: Support AMD auxiliary SMBus controller i2c-piix4: Separate registration and probing code i2c-piix4: Eliminate piix4_smba global variable i2c/busses: Use module_pci_driver i2c: Update Guenter Roeck's e-mail address
2012-07-24Merge tag 'sound-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound update from Takashi Iwai: "This is a fairly quiet release in all sound area. Only a little bit of changes in the core side while most of changes are seen in the drivers. HD-audio: - A few new codec additions for Nvidia, Realtek and VIA - Intel Haswell audio support - Support for "phantom" jacks for consistent jack reporting - Major clean-ups in HDMI/DP driver codes - A workaround for inverted digital-mic pins with Realtek codecs - Removal of beep_mode=2 option ASoC: - Added the ability to add and remove DAPM paths dynamically, mostly for reparenting on clock changes - New machine drivers for Marvell Brownstone, ST-Ericsson Ux500 reference platform and ttc-dkp - New CPU drivers for Blackfin BF6xx SPORTs in I2S mode, Marvell MMP, Synopsis Designware I2S controllers, and SPEAr DMA and S/PDIF - New CODEC drivers for Dialog DA732x, ST STA529, ST-Ericsson AB8500, TI Isabelle and Wolfson Microelectronics WM5102 and WM5110 - DAPM fixes for the recent locking changes - Fix for _PRE and _POST widgets (which have been broken for a few releases now) - A couple of minor driver updates Misc - Conversion to new dev_pm_ops in platform and PCI drivers - LTC support and some fixes in PCXHR driver - A few fixes and PM support for ISA OPti9xx and WSS cards - Some TLV code cleanup - Move driver-specific headers from include/sound to local dirs" * tag 'sound-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (212 commits) ASoC: dapm: Fix _PRE and _POST events for DAPM performance improvements ALSA: hda - add dock support for Thinkpad X230 Tablet ALSA: hda - Turn on PIN_OUT from hdmi playback prepare. ASoC imx-audmux: add MX31_AUDMUX_PORT7_SSI_PINS_7 define ASoC: littlemill: Add userspace control of the WM1250 I/O ASoC: wm8994: Update micdet for irqdomain conversion ALSA: hda - make sure alc268 does not OOPS on codec parse ALSA: hda - Add support for Realtek ALC282 ALSA: hda - Fix index number conflicts of phantom jacks ALSA: opti9xx: Fix section mismatch by PM support ALSA: snd-opti9xx: Implement suspend/resume ALSA: hda - Add new GPU codec ID to snd-hda ALSA: hda - Fix driver type of Haswell controller to AZX_DRIVER_SCH ALSA: hda - add Haswell HDMI codec id ALSA: hda - Add DeviceID for Haswell HDA ALSA: wss_lib: Fix resume on Yamaha OPL3-SAx ALSA: wss_lib: fix suspend/resume ALSA: es1938: replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGE ALSA: tlv: add DECLARE_TLV_DB_RANGE() ALSA: tlv: add DECLARE_TLV_CONTAINER() ...
2012-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Trivial updates all over the place as usual." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (29 commits) Fix typo in include/linux/clk.h . pci: hotplug: Fix typo in pci iommu: Fix typo in iommu video: Fix typo in drivers/video Documentation: Add newline at end-of-file to files lacking one arm,unicore32: Remove obsolete "select MISC_DEVICES" module.c: spelling s/postition/position/g cpufreq: Fix typo in cpufreq driver trivial: typo in comment in mksysmap mach-omap2: Fix typo in debug message and comment scsi: aha152x: Fix sparse warning and make printing pointer address more portable. Change email address for Steve Glendinning Btrfs: fix typo in convert_extent_bit via: Remove bogus if check netprio_cgroup.c: fix comment typo backlight: fix memory leak on obscure error path Documentation: asus-laptop.txt references an obsolete Kconfig item Documentation: ManagementStyle: fixed typo mm/vmscan: cleanup comment error in balance_pgdat mm: cleanup on the comments of zone_reclaim_stat ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID updates from Jiri Kosina: "The list of changes worth pointing out explicitly: - We are getting 'UHID', which is a new framework for implementing HID transport drivers in userspace (this is different from HIDRAW, which is transport-independent and provides report parsing facilities; uhid is for the other (transport) part of the pipeline). It's needed for (and currently being used by) Bluetooth-LowEnergy, as its specification mandates things we don't want in the kernel. Written by David Herrmann. - there have been quite a few bugs in runtime suspend/resume paths (probably never reported to actually happen in the wild, but still). Alan Stern fixed those. - a few other driver updates and fixes and random new device support." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (45 commits) HID: add ASUS AIO keyboard model AK1D HID: add support for Cypress barcode scanner 04B4:ED81 HID: Allow drivers to be their own listener HID: usbhid: fix error paths in suspend HID: usbhid: check for suspend or reset before restarting HID: usbhid: replace HID_REPORTED_IDLE with HID_SUSPENDED HID: usbhid: inline some simple routines HID: usbhid: fix autosuspend calls HID: usbhid: fix use-after-free bug HID: hid-core: optimize in case of hidraw HID: hidraw: fix list->buffer memleak HID: uhid: Fix sending events with invalid data HID: roccat: added sensor sysfs attribute for Savu HID: Add driver for Holtek based keyboards with broken HID HID: Add suport for the brightness control keys on HP keyboards HID: magicmouse: Implement Multi-touch Protocol B (MT-B) HID: magicmouse: Removing report_touches switch HID: roccat: rename roccat_common functions to roccat_common2 HID: roccat: fix wrong hid_err usage on struct usb_device HID: roccat: move functionality to roccat-common ...
2012-07-24Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon updates from Guenter Roeck: "New drivers for DA9052/53 PMIC as well as HIH-6130/HIH-6131 humidity and temperature sensors. Convert drivers to use devm_ functions and to use dev_pm_ops. Address a couple of Coverity errors/warnings as well as compile warnings. Some functional improvements in applesmc driver." * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (72 commits) hwmon: (applesmc) Ignore some temperature registers hwmon: (applesmc) Allow negative temperature values hwmon: (s3c-hwmon) Use devm_kzalloc instead of kzalloc hwmon: (w83781d) Fix compile warning hwmon: (applesmc) Shorten minimum wait time hwmon: (exynos4_tmu) Use struct dev_pm_ops for power management hwmon: (gpio-fan) Use struct dev_pm_ops for power management hwmon: (abituguru3) Use struct dev_pm_ops for power management hwmon: (abituguru) Use struct dev_pm_ops for power management hwmon: (acpi_power_meter) Fix unintentional integer overflow hwmon: (acpi_power_meter) Cleanup and optimizations hwmon: Honeywell Humidicon HIH-6130/HIH-6131 humidity and temperature sensor driver hwmon: (applesmc) Skip sensor mapping hwmon: (ntc_thermistor) Ensure that data->name string is terminated hwmon: (w83l785ts) Convert to use devm_ functions hwmon: (w83l785ts) Simplify code and improve readability hwmon: (smsc47m192) Convert to use devm_ functions hwmon: (smsc47m1) Convert to use devm_ functions hwmon: (smsc47b397) Convert to use devm_ functions hwmon: (k8temp) Convert to use devm_ functions ...
2012-07-24Merge tag 'stable/for-linus-3.6-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull frontswap updates from Konrad Rzeszutek Wilk: "Cleanups in code and documentation. Little bit of refactoring for cleaner look." * tag 'stable/for-linus-3.6-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: mm/frontswap: cleanup doc and comment error mm: frontswap: remove unneeded headers mm: frontswap: split out function to clear a page out mm: frontswap: remove unnecessary check during initialization mm: frontswap: make all branches of if statement in put page consistent mm: frontswap: split frontswap_shrink further to simplify locking mm: frontswap: split out __frontswap_unuse_pages mm: frontswap: split out __frontswap_curr_pages mm: frontswap: trivial coding convention issues mm: frontswap: remove casting from function calls through ops structure
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen update from Konrad Rzeszutek Wilk: "Features: * Performance improvement to lower the amount of traps the hypervisor has to do 32-bit guests. Mainly for setting PTE entries and updating TLS descriptors. * MCE polling driver to collect hypervisor MCE buffer and present them to /dev/mcelog. * Physical CPU online/offline support. When an privileged guest is booted it is present with virtual CPUs, which might have an 1:1 to physical CPUs but usually don't. This provides mechanism to offline/online physical CPUs. Bug-fixes for: * Coverity found fixes in the console and ACPI processor driver. * PVonHVM kexec fixes along with some cleanups. * Pages that fall within E820 gaps and non-RAM regions (and had been released to hypervisor) would be populated back, but potentially in non-RAM regions." * tag 'stable/for-linus-3.6-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: populate correct number of pages when across mem boundary (v2) xen PVonHVM: move shared_info to MMIO before kexec xen: simplify init_hvm_pv_info xen: remove cast from HYPERVISOR_shared_info assignment xen: enable platform-pci only in a Xen guest xen/pv-on-hvm kexec: shutdown watches from old kernel xen/x86: avoid updating TLS descriptors if they haven't changed xen/x86: add desc_equal() to compare GDT descriptors xen/mm: zero PTEs for non-present MFNs in the initial page table xen/mm: do direct hypercall in xen_set_pte() if batching is unavailable xen/hvc: Fix up checks when the info is allocated. xen/acpi: Fix potential memory leak. xen/mce: add .poll method for mcelog device driver xen/mce: schedule a workqueue to avoid sleep in atomic context xen/pcpu: Xen physical cpus online/offline sys interface xen/mce: Register native mce handler as vMCE bounce back point x86, MCE, AMD: Adjust initcall sequence for xen xen/mce: Add mcelog support for Xen platform
2012-07-24Merge tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Avi Kivity: "Highlights include - full big real mode emulation on pre-Westmere Intel hosts (can be disabled with emulate_invalid_guest_state=0) - relatively small ppc and s390 updates - PCID/INVPCID support in guests - EOI avoidance; 3.6 guests should perform better on 3.6 hosts on interrupt intensive workloads) - Lockless write faults during live migration - EPT accessed/dirty bits support for new Intel processors" Fix up conflicts in: - Documentation/virtual/kvm/api.txt: Stupid subchapter numbering, added next to each other. - arch/powerpc/kvm/booke_interrupts.S: PPC asm changes clashing with the KVM fixes - arch/s390/include/asm/sigp.h, arch/s390/kvm/sigp.c: Duplicated commits through the kvm tree and the s390 tree, with subsequent edits in the KVM tree. * tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (93 commits) KVM: fix race with level interrupts x86, hyper: fix build with !CONFIG_KVM_GUEST Revert "apic: fix kvm build on UP without IOAPIC" KVM guest: switch to apic_set_eoi_write, apic_write apic: add apic_set_eoi_write for PV use KVM: VMX: Implement PCID/INVPCID for guests with EPT KVM: Add x86_hyper_kvm to complete detect_hypervisor_platform check KVM: PPC: Critical interrupt emulation support KVM: PPC: e500mc: Fix tlbilx emulation for 64-bit guests KVM: PPC64: booke: Set interrupt computation mode for 64-bit host KVM: PPC: bookehv: Add ESR flag to Data Storage Interrupt KVM: PPC: bookehv64: Add support for std/ld emulation. booke: Added crit/mc exception handler for e500v2 booke/bookehv: Add host crit-watchdog exception support KVM: MMU: document mmu-lock and fast page fault KVM: MMU: fix kvm_mmu_pagetable_walk tracepoint KVM: MMU: trace fast page fault KVM: MMU: fast path of handling guest page fault KVM: MMU: introduce SPTE_MMU_WRITEABLE bit KVM: MMU: fold tlb flush judgement into mmu_spte_update ...
2012-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David S Miller: 1) Remove the ipv4 routing cache. Now lookups go directly into the FIB trie and use prebuilt routes cached there. No more garbage collection, no more rDOS attacks on the routing cache. Instead we now get predictable and consistent performance, no matter what the pattern of traffic we service. This has been almost 2 years in the making. Special thanks to Julian Anastasov, Eric Dumazet, Steffen Klassert, and others who have helped along the way. I'm sure that with a change of this magnitude there will be some kind of fallout, but such things ought the be simple to fix at this point. Luckily I'm not European so I'll be around all of August to fix things :-) The major stages of this work here are each fronted by a forced merge commit whose commit message contains a top-level description of the motivations and implementation issues. 2) Pre-demux of established ipv4 TCP sockets, saves a route demux on input. 3) TCP SYN/ACK performance tweaks from Eric Dumazet. 4) Add namespace support for netfilter L4 conntrack helpers, from Gao Feng. 5) Add config mechanism for Energy Efficient Ethernet to ethtool, from Yuval Mintz. 6) Remove quadratic behavior from /proc/net/unix, from Eric Dumazet. 7) Support for connection tracker helpers in userspace, from Pablo Neira Ayuso. 8) Allow userspace driven TX load balancing functions in TEAM driver, from Jiri Pirko. 9) Kill off NLMSG_PUT and RTA_PUT macros, more gross stuff with embedded gotos. 10) TCP Small Queues, essentially minimize the amount of TCP data queued up in the packet scheduler layer. Whereas the existing BQL (Byte Queue Limits) limits the pkt_sched --> netdevice queuing levels, this controls the TCP --> pkt_sched queueing levels. From Eric Dumazet. 11) Reduce the number of get_page/put_page ops done on SKB fragments, from Alexander Duyck. 12) Implement protection against blind resets in TCP (RFC 5961), from Eric Dumazet. 13) Support the client side of TCP Fast Open, basically the ability to send data in the SYN exchange, from Yuchung Cheng. Basically, the sender queues up data with a sendmsg() call using MSG_FASTOPEN, then they do the connect() which emits the queued up fastopen data. 14) Avoid all the problems we get into in TCP when timers or PMTU events hit a locked socket. The TCP Small Queues changes added a tcp_release_cb() that allows us to queue work up to the release_sock() caller, and that's what we use here too. From Eric Dumazet. 15) Zero copy on TX support for TUN driver, from Michael S. Tsirkin. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1870 commits) genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEP r8169: revert "add byte queue limit support". ipv4: Change rt->rt_iif encoding. net: Make skb->skb_iif always track skb->dev ipv4: Prepare for change of rt->rt_iif encoding. ipv4: Remove all RTCF_DIRECTSRC handliing. ipv4: Really ignore ICMP address requests/replies. decnet: Don't set RTCF_DIRECTSRC. net/ipv4/ip_vti.c: Fix __rcu warnings detected by sparse. ipv4: Remove redundant assignment rds: set correct msg_namelen openvswitch: potential NULL deref in sample() tcp: dont drop MTU reduction indications bnx2x: Add new 57840 device IDs tcp: avoid oops in tcp_metrics and reset tcpm_stamp niu: Change niu_rbr_fill() to use unlikely() to check niu_rbr_add_page() return value niu: Fix to check for dma mapping errors. net: Fix references to out-of-scope variables in put_cmsg_compat() net: ethernet: davinci_emac: add pm_runtime support net: ethernet: davinci_emac: Remove unnecessary #include ...
2012-07-24i2c-i801: Enable IRQ for SMBus transactionsDaniel Kurtz
Add a new 'feature' to i2c-i801 to enable using PCI interrupts. When the feature is enabled, then an isr is installed for the device's PCI IRQ. An I2C/SMBus transaction is always terminated by one of the following interrupt sources: FAILED, BUS_ERR, DEV_ERR, or on success: INTR. When the isr fires for one of these cases, it sets the ->status variable and wakes up the waitq. The waitq then saves off the status code, and clears ->status (in preparation for some future transaction). The SMBus controller generates an INTR irq at the end of each transaction where INTREN was set in the HST_CNT register. No locking is needed around accesses to priv->status since all writes to it are serialized: it is only ever set once in the isr at the end of a transaction, and cleared while no interrupts can occur. In addition, the I2C adapter lock guarantees that entire I2C transactions for a single adapter are always serialized. For this patch, the INTREN bit is set only for SMBus block, byte and word transactions, but not for I2C reads or writes. The use of the DS (BYTE_DONE) interrupt with byte-by-byte I2C transactions is implemented in a subsequent patch. The interrupt feature has only been enabled for COUGARPOINT hardware. In addition, it is disabled if SMBus is using the SMI# interrupt. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24i2c/writing-clients: Mention module_i2c_driver()Jean Delvare
Based on a previous patch from Peter Meerwald. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2012-07-24i2c-piix4: Support AMD auxiliary SMBus controllerAndrew Armenia
Some AMD chipsets, such as the SP5100, have an auxiliary SMBus controller with a second set of registers. This patch adds support for this auxiliary controller. Tested on ASUS KCMA-D8 motherboard. Signed-off-by: Andrew Armenia <andrew@asquaredlabs.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24Merge branch 'uhid' into for-linusJiri Kosina
Conflicts: drivers/hid/Kconfig
2012-07-24Merge branches 'hidraw', 'magicmouse', 'multitouch', 'roccat', ↵Jiri Kosina
'suspend-fixes' and 'upstream' into for-linus
2012-07-23Merge tag 'newsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull support for three new arm SoC types from Arnd Bergmann: - The mvebu platform includes Marvell's Armada XP and Armada 370 chips, made by the mvebu business unit inside of Marvell. Since the same group also made the older but similar platforms we call "orion5x", "kirkwood", "mv78xx0" and "dove", we plan to move all of them into the mach-mvebu directory in the future. - socfpga is Altera's platform based on Cortex-A9 cores and a lot of FPGA space. This is similar to the Xilinx zynq platform we already support. The code is particularly clean, which is helped by the fact that the hardware doesn't do much besides the parts that are expected to get added in the FPGA. - The OMAP subarchitecture gains support for the latest generation, the OMAP5 based on the new Cortex-A15 core. Support is rather rudimentary for now, but will be extended in the future. * tag 'newsoc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) ARM: socfpga: initial support for Altera's SOCFPGA platform arm: mvebu: generate DTBs for supported SoCs ARM: mvebu: MPIC: read number of interrupts from control register arm: mach-mvebu: add entry to MAINTAINERS arm: mach-mvebu: add compilation/configuration change arm: mach-mvebu: add defconfig arm: mach-mvebu: add documentation for new device tree bindings arm: mach-mvebu: add support for Armada 370 and Armada XP with DT arm: mach-mvebu: add source files arm: mach-mvebu: add header clocksource: time-armada-370-xp: Marvell Armada 370/XP SoC timer driver ARM: Kconfig update to support additional GPIOs in OMAP5 ARM: OMAP5: Add the build support arm/dts: OMAP5: Add omap5 dts files ARM: OMAP5: board-generic: Add device tree support ARM: omap2+: board-generic: clean up the irq data from board file ARM: OMAP5: Add SMP support ARM: OMAP5: Add the WakeupGen IP updates ARM: OMAP5: l3: Add l3 error handler support for omap5 ARM: OMAP5: gpmc: Update gpmc_init() ... Conflicts: Documentation/devicetree/bindings/arm/omap/omap.txt arch/arm/mach-omap2/Makefile drivers/clocksource/Kconfig drivers/clocksource/Makefile
2012-07-23Merge tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc timer updates from Arnd Bergmann: "This contains two branches dealing with timers, one for the picoxcell platform that is now using DT with the platform-independent dw_apb_timer driver. The other change is for the omap-specific dmtimer driver." * tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: clocksource: dw_apb_timer: Add common DTS glue for dw_apb_timer ARM: OMAP2+: Simplify dmtimer clock aliases ARM: OMAP2+: Move dmtimer clock set function to dmtimer driver ARM: OMAP1: Fix dmtimer support ARM: OMAP: Add flag to indicate if a timer needs a manual reset ARM: OMAP: Remove timer function pointer for context loss counter ARM: OMAP: Remove loses_context variable from timer platform data ARM: OMAP2+: Fix external clock support for dmtimers ARM: OMAP2+: HWMOD: Correct timer device attributes ARM: OMAP: Add DMTIMER capability variable to represent timer features ARM: OMAP2+: Add dmtimer platform function to reserve systimers ARM: OMAP2+: Remove unused max number of timers definition ARM: OMAP: Remove unnecessary clk structure
2012-07-23Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc device tree description updates from Arnd Bergmann: "This branch contains two kinds of updates: Some platforms in the process of getting converted to device tree based booting, and the platform specific patches necessary for that are included here. Other platforms are already converted, so we just need to update the actual device tree source files and the binding documents to add support for new board and new drivers. In the future we will probably separate those into two branches, and in the long run, the plan is to move the device tree source files out of the kernel repository, but that has to wait until we have completed a much larger portion of the binding documents." Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly added clkdev registers next to a few removed unnecessary ones. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: LPC32xx: Add PWM to base dts file ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5 ARM: EXYNOS: Add spi clock support for EXYNOS5 ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4 ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock ARM: ux500: Remove PMU platform registration when booting with DT ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure ARM: ux500: Ensure vendor specific properties have the vendor's identifier pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree ARM: ux500: Apply ab8500-debug node do the db8500 DT structure ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT ...
2012-07-23Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull general arm-soc cleanups from Arnd Bergmann: "These are all boring changes, moving stuff around or renaming things mostly, and also getting rid of stuff that is duplicate or should not be there to start with. Platform-wise this is all over the place, mainly omap, samsung, at91, imx and tegra." Resolve trivial conflict in arch/arm/mach-omap2/clockdomains3xxx_data.c * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) ARM: clps711x: Remove the setting of the time ARM: clps711x: Removed superfluous transform virt_to_bus and related functions ARM: clps711x/p720t: Replace __initcall by .init_early call ARM: S3C24XX: Remove unused GPIO definitions for Openmoko GTA02 board ARM: S3C24XX: Remove unused GPIO definitions for port J ARM: S3C24XX: Remove unused GPA, GPE, GPH bank GPIO aliases ARM: S3C24XX: Convert the touchscreen setup code to common GPIO API ARM: S3C24XX: Convert the PM code to gpiolib API ARM: S3C24XX: Convert QT2410 board file to the gpiolib API ARM: S3C24XX: Convert SMDK board file to the gpiolib API ARM: S3C24XX: Free the backlight gpio requested in Mini2440 board code ARM: imx: remove unused pdata from device macros ARM: imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DS ARM: at91: fix new build errors ARM: at91: add AIC5 support ARM: at91: remove mach/irqs.h ARM: at91: sparse irq support ARM: at91: at91 based machines specify their own irq handler at run time ARM: at91: remove static irq priorities for sam9x5 ARM: at91: add of irq priorities support ...
2012-07-23Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull the big VFS changes from Al Viro: "This one is *big* and changes quite a few things around VFS. What's in there: - the first of two really major architecture changes - death to open intents. The former is finally there; it was very long in making, but with Miklos getting through really hard and messy final push in fs/namei.c, we finally have it. Unlike his variant, this one doesn't introduce struct opendata; what we have instead is ->atomic_open() taking preallocated struct file * and passing everything via its fields. Instead of returning struct file *, it returns -E... on error, 0 on success and 1 in "deal with it yourself" case (e.g. symlink found on server, etc.). See comments before fs/namei.c:atomic_open(). That made a lot of goodies finally possible and quite a few are in that pile: ->lookup(), ->d_revalidate() and ->create() do not get struct nameidata * anymore; ->lookup() and ->d_revalidate() get lookup flags instead, ->create() gets "do we want it exclusive" flag. With the introduction of new helper (kern_path_locked()) we are rid of all struct nameidata instances outside of fs/namei.c; it's still visible in namei.h, but not for long. Come the next cycle, declaration will move either to fs/internal.h or to fs/namei.c itself. [me, miklos, hch] - The second major change: behaviour of final fput(). Now we have __fput() done without any locks held by caller *and* not from deep in call stack. That obviously lifts a lot of constraints on the locking in there. Moreover, it's legal now to call fput() from atomic contexts (which has immediately simplified life for aio.c). We also don't need anti-recursion logics in __scm_destroy() anymore. There is a price, though - the damn thing has become partially asynchronous. For fput() from normal process we are guaranteed that pending __fput() will be done before the caller returns to userland, exits or gets stopped for ptrace. For kernel threads and atomic contexts it's done via schedule_work(), so theoretically we might need a way to make sure it's finished; so far only one such place had been found, but there might be more. There's flush_delayed_fput() (do all pending __fput()) and there's __fput_sync() (fput() analog doing __fput() immediately). I hope we won't need them often; see warnings in fs/file_table.c for details. [me, based on task_work series from Oleg merged last cycle] - sync series from Jan - large part of "death to sync_supers()" work from Artem; the only bits missing here are exofs and ext4 ones. As far as I understand, those are going via the exofs and ext4 trees resp.; once they are in, we can put ->write_super() to the rest, along with the thread calling it. - preparatory bits from unionmount series (from dhowells). - assorted cleanups and fixes all over the place, as usual. This is not the last pile for this cycle; there's at least jlayton's ESTALE work and fsfreeze series (the latter - in dire need of fixes, so I'm not sure it'll make the cut this cycle). I'll probably throw symlink/hardlink restrictions stuff from Kees into the next pile, too. Plus there's a lot of misc patches I hadn't thrown into that one - it's large enough as it is..." * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits) ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file() btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file() switch dentry_open() to struct path, make it grab references itself spufs: shift dget/mntget towards dentry_open() zoran: don't bother with struct file * in zoran_map ecryptfs: don't reinvent the wheels, please - use struct completion don't expose I_NEW inodes via dentry->d_inode tidy up namei.c a bit unobfuscate follow_up() a bit ext3: pass custom EOF to generic_file_llseek_size() ext4: use core vfs llseek code for dir seeks vfs: allow custom EOF in generic_file_llseek code vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes vfs: Remove unnecessary flushing of block devices vfs: Make sys_sync writeout also block device inodes vfs: Create function for iterating over block devices vfs: Reorder operations during sys_sync quota: Move quota syncing to ->sync_fs method quota: Split dquot_quota_sync() to writeback and cache flushing part vfs: Move noop_backing_dev_info check from sync into writeback ...
2012-07-23mm/frontswap: cleanup doc and comment errorWanpeng Li
Signed-off-by: Wanpeng Li <liwp.linux@gmail.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-23Merge branches 'iommu/fixes', 'x86/amd', 'groups', 'arm/tegra' and ↵Joerg Roedel
'api/domain-attr' into next Conflicts: drivers/iommu/iommu.c include/linux/iommu.h
2012-07-22Merge tag 'mmc-merge-for-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.6: Core: - Rename cd-gpio to slot-gpio and extend it to support more slot GPIO functions, such as write-protect. - Add a function to get regulators (Vdd and Vccq) for a host. Drivers: - sdhci-pxav2, sdhci-pxav3: Add device tree support. - sdhi: Add device tree support. - sh_mmcif: Add support for regulators, device tree, slot-gpio. - tmio: Add regulator support, use slot-gpio." * tag 'mmc-merge-for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (62 commits) mmc: sdhci-dove: Prepare for common clock framework mmc: sdhci-dove: Add SDHCI_QUIRK_NO_HISPD_BIT mmc: omap_hsmmc: ensure probe returns error upon resource failure mmc: mxs-mmc: Add wp-inverted property mmc: esdhc: Fix DMA_MASK to not break mx25 DMA access mmc: core: reset signal voltage on power up mmc: sd: Fix sd current limit setting mmc: omap_hsmmc: add clk_prepare and clk_unprepare mmc: sdhci: When a UHS switch fails, cycle power if regulator is used mmc: atmel-mci: modify CLKDIV displaying in debugfs mmc: atmel-mci: fix incorrect setting of host->data to NULL mmc: sdhci: poll for card even when card is logically unremovable mmc: sdhci: Introduce new flag SDHCI_USING_RETUNING_TIMER mmc: sdio: Change pr_warning to pr_warn_ratelimited mmc: core: Simplify and fix for SD switch processing mmc: sdhci: restore host settings when card is removed mmc: sdhci: fix incorrect command used in tuning mmc: sdhci-pci: CaFe has broken card detection mmc: sdhci: Report failure reasons for all cases in sdhci_add_host() mmc: s3cmci: Convert s3cmci driver to gpiolib API ...
2012-07-22Merge tag 'pm-for-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: - ACPI conversion to PM handling based on struct dev_pm_ops. - Conversion of a number of platform drivers to PM handling based on struct dev_pm_ops and removal of empty legacy PM callbacks from a couple of PCI drivers. - Suspend-to-both for in-kernel hibernation from Bojan Smojver. - cpuidle fixes and cleanups from ShuoX Liu, Daniel Lezcano and Preeti Murthy. - cpufreq bug fixes from Jonghwa Lee and Stephen Boyd. - Suspend and hibernate fixes from Srivatsa Bhat and Colin Cross. - Generic PM domains framework updates. - RTC CMOS wakeup signaling update from Paul Fox. - sparse warnings fixes from Sachin Kamat. - Build warnings fixes for the generic PM domains framework and PM sysfs code. - sysfs switch for printing device suspend times from Sameer Nanda. - Documentation fix from Oskar Schirmer. * tag 'pm-for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (70 commits) cpufreq: Fix sysfs deadlock with concurrent hotplug/frequency switch EXYNOS: bugfix on retrieving old_index from freqs.old PM / Sleep: call early resume handlers when suspend_noirq fails PM / QoS: Use NULL pointer instead of plain integer in qos.c PM / QoS: Use NULL pointer instead of plain integer in pm_qos.h PM / Sleep: Require CAP_BLOCK_SUSPEND to use wake_lock/wake_unlock PM / Sleep: Add missing static storage class specifiers in main.c cpuilde / ACPI: remove time from acpi_processor_cx structure cpuidle / ACPI: remove usage from acpi_processor_cx structure cpuidle / ACPI : remove latency_ticks from acpi_processor_cx structure rtc-cmos: report wakeups from interrupt handler PM / Sleep: Fix build warning in sysfs.c for CONFIG_PM_SLEEP unset PM / Domains: Fix build warning for CONFIG_PM_RUNTIME unset olpc-xo15-sci: Use struct dev_pm_ops for power management PM / Domains: Replace plain integer with NULL pointer in domain.c file PM / Domains: Add missing static storage class specifier in domain.c file PM / crypto / ux500: Use struct dev_pm_ops for power management PM / IPMI: Remove empty legacy PCI PM callbacks tpm_nsc: Use struct dev_pm_ops for power management tpm_tis: Use struct dev_pm_ops for power management ...
2012-07-22Merge tag 'regulator-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates from Mark Brown: "Lots and lots of fixes from Axel and some others here, plus some framework enhancements which continue the theme of factoring code out of the drivers and into the core. - Initial framework support for GPIO controlled enable signals, saving a bunch of code in drivers. - Move fixed regulator enable time and voltage mapping table specifications to data. - Used some of the recent framework enhancements to make voltage change notifications more useful, passing the voltage in as an argument to the notification. - Fixed the pattern used for finding individual regulators on a device to not rely on the node name, supporting the use of multiple PMICs of the same type in the system. - New drivers for Maxim MAX77686, TI LP872x and LP8788, Samsung S2MPS11, and Wolfson Arizona microphone supplies and LDOs." * tag 'regulator-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (176 commits) regulator: add new lp8788 regulator driver regulator: mc13xxx: Remove extern function declaration for mc13xxx_sw_regulator regulator: tps65910: set input_supply on desc unconditionally regulator: palmas: Fix calcuating selector in palmas_map_voltage_smps regulator: lp872x: Simplify implementation of lp872x_find_regulator_init_data() regulator: twl: Fix list_voltate for twl6030ldo_ops regulator: twl: Convert twl6030ldo_ops to [get|set]_voltage_sel regulator: twl: Fix the formula to calculate vsel and voltage for twl6030ldo regulator: s5m8767: Properly handle gpio_request failure regulator: max8997: Properly handle gpio_request failure regulator: tps62360: use devm_* for gpio request regulator: tps6586x: add support for input supply regulator: tps65217: Add device tree support regulator: aat2870: Remove unused min_uV and max_uV from struct aat2870_regulator regulator: aat2870: Convert to regulator_list_voltage_table regulator: da9052: initialize of_node param for regulator register regulator: Add REGULATOR_STATUS_UNDEFINED. regulator: Fix a typo in regulator_mode_to_status() core function. regulator: s2mps11: Use sec_reg_write rather than sec_reg_update when mask is 0xff regulator: s2mps11: Fix wrong setting for config.dev ...
2012-07-22net-next: minor cleanups for bonding documentationRick Jones
The section titled "Configuring Bonding for Maximum Throughput" is actually section twelve not thirteen, and there are a couple of words spelled incorrectly. Signed-off-by: Rick Jones <rick.jones2@hp.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22sctp: Implement quick failover draft from tsvwgNeil Horman
I've seen several attempts recently made to do quick failover of sctp transports by reducing various retransmit timers and counters. While its possible to implement a faster failover on multihomed sctp associations, its not particularly robust, in that it can lead to unneeded retransmits, as well as false connection failures due to intermittent latency on a network. Instead, lets implement the new ietf quick failover draft found here: http://tools.ietf.org/html/draft-nishida-tsvwg-sctp-failover-05 This will let the sctp stack identify transports that have had a small number of errors, and avoid using them quickly until their reliability can be re-established. I've tested this out on two virt guests connected via multiple isolated virt networks and believe its in compliance with the above draft and works well. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: Sridhar Samudrala <sri@us.ibm.com> CC: "David S. Miller" <davem@davemloft.net> CC: linux-sctp@vger.kernel.org CC: joe@perches.com Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-22Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU changes from Ingo Molnar: "Quoting from Paul, the major features of this series are: 1. Preventing latency spikes of more than 200 microseconds for kernels built with NR_CPUS=4096, which is reportedly becoming the default for some distros. This is a first step, as it does not help with systems that actually -have- 4096 CPUs (work on this case is in progress, but is not yet ready for mainline). This category also includes improving concurrency of rcu_barrier(), placed here due to conflicts. Posted to LKML at: https://lkml.org/lkml/2012/6/22/381 Note that patches 18-22 of that series have been defered to 3.7, as they have not yet proven themselves to be mainline-ready (and yes, these are the ones intended to get rid of RCU's latency spikes for systems that actually have 4096 CPUs). 2. Updates to documentation and rcutorture fixes, the latter category including improvements to rcu_barrier() testing. Posted to LKML at http://lkml.indiana.edu/hypermail/linux/kernel/1206.1/04094.html. 3. Miscellaneous fixes posted to LKML at: https://lkml.org/lkml/2012/6/22/500 with the exception of the last commit, which was posted here: http://www.gossamer-threads.com/lists/linux/kernel/1561830 4. RCU_FAST_NO_HZ fixes and improvements. Posted to LKML at: http://lkml.indiana.edu/hypermail/linux/kernel/1206.1/00006.html http://www.gossamer-threads.com/lists/linux/kernel/1561833 The first four patches of the first series went into 3.5 to fix a regression. 5. Code-style fixes. These were posted to LKML at http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/01180.html http://lkml.indiana.edu/hypermail/linux/kernel/1205.2/01181.html" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (48 commits) rcu: Fix broken strings in RCU's source code. rcu: Fix code-style issues involving "else" rcu: Introduce check for callback list/count mismatch rcu: Make RCU_FAST_NO_HZ respect nohz= boot parameter rcu: Fix qlen_lazy breakage rcu: Round FAST_NO_HZ lazy timeout to nearest second rcu: The rcu_needs_cpu() function is not a quiescent state rcu: Dump only the current CPU's buffers for idle-entry/exit warnings rcu: Add check for CPUs going offline with callbacks queued rcu: Disable preemption in rcu_blocking_is_gp() rcu: Prevent uninitialized string in RCU CPU stall info rcu: Fix rcu_is_cpu_idle() #ifdef in TINY_RCU rcu: Split RCU core processing out of __call_rcu() rcu: Prevent __call_rcu() from invoking RCU core on offline CPUs rcu: Make __call_rcu() handle invocation from idle rcu: Remove function versions of __kfree_rcu and __is_kfree_rcu_offset rcu: Consolidate tree/tiny __rcu_read_{,un}lock() implementations rcu: Remove return value from rcu_assign_pointer() key: Remove extraneous parentheses from rcu_assign_keypointer() rcu: Remove return value from RCU_INIT_POINTER() ...
2012-07-21hwmon: Honeywell Humidicon HIH-6130/HIH-6131 humidity and temperature sensor ↵Iain Paton
driver This is a new driver for the Honeywell Humidicon HIH-6130/HIH-6131 humidity sensor. The driver is based on the existing Sensiron sht21 driver with the necessary changes to the probe, update_measurements and conversion functions necessary to use the Honeywell sensors. There's no difference between the 6130 & 6131 other than the 6131 having an external condensation filter attached. Signed-off-by: Iain Paton <ipaton0@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-07-21hwmon: Document the use of devres functionsGuenter Roeck
devres functions are the preferred means to allocate resources in hwmon drivers. Document it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-07-21hwmon: Driver for DA9052/53 PMICAshish Jangam
The DA9052 PMIC provides an Analogue to Digital Converter with 10 bits resolution and 10 channels. This patch monitors the DA9052 PMIC's ADC channels mostly for battery parameters like battery temperature, junction temperature, battery current etc. This patch is functionally tested on Samsung SMDKV6410 Signed-off-by: David Dajun Chen <dchen@diasemi.com> Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com> [Guenter Roeck: __init --> __devinit for probe function] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2012-07-21mmc: sdhci-pxa: Add device tree supportChris Ball
Tested on an OLPC XO-1.75. (MMP2, sdhci-pxav3, CONFIG_MACH_MMP2_DT=y) Signed-off-by: Chris Ball <cjb@laptop.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-07-20Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch Jesse Gross says: ==================== A few bug fixes and small enhancements for net-next/3.6. ... Ansis Atteka (1): openvswitch: Do not send notification if ovs_vport_set_options() failed Ben Pfaff (1): openvswitch: Check gso_type for correct sk_buff in queue_gso_packets(). Jesse Gross (2): openvswitch: Enable retrieval of TCP flags from IPv6 traffic. openvswitch: Reset upper layer protocol info on internal devices. Leo Alterman (1): openvswitch: Fix typo in documentation. Pravin B Shelar (1): openvswitch: Check currect return value from skb_gso_segment() Raju Subramanian (1): openvswitch: Replace Nicira Networks. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-20openvswitch: Fix typo in documentation.Leo Alterman
Signed-off-by: Leo Alterman <lalterman@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-07-20Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-20Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
2012-07-20ALSA: hda - add dock support for Thinkpad X230 TabletDavid Henningsson
Also add a model/fixup string "lenovo-dock", so that other Thinkpad users will be able to test this fixup easily, to see if it enables dock I/O for them as well. Cc: stable@kernel.org BugLink: https://bugs.launchpad.net/bugs/1026953 Tested-by: John McCarron <john.mccarron@canonical.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-20[SCSI] usb-storage: add support for write cache quirkNamjae Jeon
Add support for write cache quirk on usb hdd. scsi driver will be set to wce by detecting write cache quirk in quirk list when plugging usb hdd. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-07-20HID: roccat: added sensor sysfs attribute for SavuStefan Achatz
The sensor attr can be used to tweak the optical sensor of the Savu. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-19xen/pcpu: Xen physical cpus online/offline sys interfaceLiu, Jinsong
This patch provide Xen physical cpus online/offline sys interface. User can use it for their own purpose, like power saving: by offlining some cpus when light workload it save power greatly. Its basic workflow is, user online/offline cpu via sys interface, then hypercall xen to implement, after done xen inject virq back to dom0, and then dom0 sync cpu status. Signed-off-by: Jiang, Yunhong <yunhong.jiang@intel.com> Signed-off-by: Liu, Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-07-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/ixgbevf/ixgbevf_main.c
2012-07-19net-tcp: Fast Open client - cookie-less modeYuchung Cheng
In trusted networks, e.g., intranet, data-center, the client does not need to use Fast Open cookie to mitigate DoS attacks. In cookie-less mode, sendmsg() with MSG_FASTOPEN flag will send SYN-data regardless of cookie availability. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-19net-tcp: Fast Open client - sendmsg(MSG_FASTOPEN)Yuchung Cheng
sendmsg() (or sendto()) with MSG_FASTOPEN is a combo of connect(2) and write(2). The application should replace connect() with it to send data in the opening SYN packet. For blocking socket, sendmsg() blocks until all the data are buffered locally and the handshake is completed like connect() call. It returns similar errno like connect() if the TCP handshake fails. For non-blocking socket, it returns the number of bytes queued (and transmitted in the SYN-data packet) if cookie is available. If cookie is not available, it transmits a data-less SYN packet with Fast Open cookie request option and returns -EINPROGRESS like connect(). Using MSG_FASTOPEN on connecting or connected socket will result in simlar errno like repeating connect() calls. Therefore the application should only use this flag on new sockets. The buffer size of sendmsg() is independent of the MSS of the connection. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-19bridge: update documentation referencesstephen hemminger
Update the references to bridge utilities and web pages to current locations Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
