Add more information about some dm-raid table parameters and clarify how
parameters are printed when 'dmsetup table' is issued.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Add corrupt_bio_byte feature to simulate corruption by overwriting a byte at a
specified position with a specified value during intervals when the device is
"down".
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Add 'drop_writes' option to drop writes silently while the
device is 'down'. Reads are not touched.
* 'for-linus' of git://neil.brown.name/md: (75 commits)
md/raid10: handle further errors during fix_read_error better.
md/raid10: Handle read errors during recovery better.
md/raid10: simplify read error handling during recovery.
md/raid10: record bad blocks due to write errors during resync/recovery.
md/raid10: attempt to fix read errors during resync/check
md/raid10: Handle write errors by updating badblock log.
md/raid10: clear bad-block record when write succeeds.
md/raid10: avoid writing to known bad blocks on known bad drives.
md/raid10 record bad blocks as needed during recovery.
md/raid10: avoid reading known bad blocks during resync/recovery.
md/raid10 - avoid reading from known bad blocks - part 3
md/raid10: avoid reading from known bad blocks - part 2
md/raid10: avoid reading from known bad blocks - part 1
md/raid10: Split handle_read_error out from raid10d.
md/raid10: simplify/reindent some loops.
md/raid5: Clear bad blocks on successful write.
md/raid5. Don't write to known bad block on doubtful devices.
md/raid5: write errors should be recorded as bad blocks if possible.
md/raid5: use bad-block log to improve handling of uncorrectable read errors.
md/raid5: avoid reading from known bad blocks.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (54 commits)
tpm_nsc: Fix bug when loading multiple TPM drivers
tpm: Move tpm_tis_reenable_interrupts out of CONFIG_PNP block
tpm: Fix compilation warning when CONFIG_PNP is not defined
TOMOYO: Update kernel-doc.
tpm: Fix a typo
tpm_tis: Probing function for Intel iTPM bug
tpm_tis: Fix the probing for interrupts
tpm_tis: Delay ACPI S3 suspend while the TPM is busy
tpm_tis: Re-enable interrupts upon (S3) resume
tpm: Fix display of data in pubek sysfs entry
tpm_tis: Add timeouts sysfs entry
tpm: Adjust interface timeouts if they are too small
tpm: Use interface timeouts returned from the TPM
tpm_tis: Introduce durations sysfs entry
tpm: Adjust the durations if they are too small
tpm: Use durations returned from TPM
TOMOYO: Enable conditional ACL.
TOMOYO: Allow using argv[]/envp[] of execve() as conditions.
TOMOYO: Allow using executable's realpath and symlink's target as conditions.
TOMOYO: Allow using owner/group etc. of file objects as conditions.
Fix up trivial conflict in security/tomoyo/realpath.c
Previous patches in the bad block series extended behavior of
rdev's 'state' interface but lacked documentation update.
Fix it.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
Previous patch in the bad block series added new sysfs interfaces
([unacknowledged_]bad_blocks) for each rdev without documentation.
Add it.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (53 commits)
Input: synaptics - fix reporting of min coordinates
Input: tegra-kbc - enable key autorepeat
Input: kxtj9 - fix locking typo in kxtj9_set_poll()
Input: kxtj9 - fix bug in probe()
Input: intel-mid-touch - remove pointless checking for variable 'found'
Input: hp_sdc - staticize hp_sdc_kicker()
Input: pmic8xxx-keypad - fix a leak of the IRQ during init failure
Input: cy8ctmg110_ts - set reset_pin and irq_pin from platform data
Input: cy8ctmg110_ts - constify i2c_device_id table
Input: cy8ctmg110_ts - fix checking return value of i2c_master_send
Input: lifebook - make dmi callback functions return 1
Input: atkbd - make dmi callback functions return 1
Input: gpio_keys - switch to using SIMPLE_DEV_PM_OPS
Input: gpio_keys - add support for device-tree platform data
Input: aiptek - remove double define
Input: synaptics - set minimum coordinates as reported by firmware
Input: synaptics - process button bits in AGM packets
Input: synaptics - rename set_slot to be more descriptive
Input: synaptics - fuzz position for touchpad with reduced filtering
Input: synaptics - set resolution for MT_POSITION_X/Y axes
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
merge fchmod() and fchmodat() guts, kill ancient broken kludge
xfs: fix misspelled S_IS...()
xfs: get rid of open-coded S_ISREG(), etc.
vfs: document locking requirements for d_move, __d_move and d_materialise_unique
omfs: fix (mode & S_IFDIR) abuse
btrfs: S_ISREG(mode) is not mode & S_IFREG...
ima: fmode_t misspelled as mode_t...
pci-label.c: size_t misspelled as mode_t
jffs2: S_ISLNK(mode & S_IFMT) is pointless
snd_msnd ->mode is fmode_t, not mode_t
v9fs_iop_get_acl: get rid of unused variable
vfs: dont chain pipe/anon/socket on superblock s_inodes list
Documentation: Exporting: update description of d_splice_alias
fs: add missing unlock in default_llseek()
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
MAINTAINERS: add maintainer of CSR SiRFprimaII machine
ARM: CSR: initializing L2 cache
ARM: CSR: mapping early DEBUG_LL uart
ARM: CSR: Adding CSR SiRFprimaII board support
OMAP4: clocks: Update the clock tree with 4460 clock nodes
OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts
OMAP4: ID: add omap_has_feature for max freq supported
OMAP: ID: introduce chip detection for OMAP4460
ARM: Xilinx: merge board file into main platform code
ARM: Xilinx: Adding Xilinx board support
Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
When a kernel BUG or oops occurs, ChromeOS intends to panic and
immediately reboot, with stacktrace and other messages preserved in RAM
across reboot.
But the longer we delay, the more likely the user is to poweroff and
lose the info.
panic_timeout (seconds before rebooting) is set by panic= boot option or
sysctl or /proc/sys/kernel/panic; but 0 means wait forever, so at
present we have to delay at least 1 second.
Let a negative number mean reboot immediately (with the small cosmetic
benefit of suppressing that newline-less "Rebooting in %d seconds.."
message).
Signed-off-by: Hugh Dickins <hughd@chromium.org>
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Olaf Hering <olaf@aepfle.de>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Dave Airlie <airlied@gmail.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
See: DMA-API.txt, part Id, DMA_FROM_DEVICE description.
Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
git grep shows there are no users in tree, so we can remove them safely.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: Jiri Slaby <jslaby@suse.cz>
Acked-by: Vinod Koul <vinod.koul@intel.com>
Add support for the shm_rmid_forced sysctl. If set to 1, all shared
memory objects in current ipc namespace will be automatically forced to
use IPC_RMID.
The POSIX way of handling shmem allows one to create shm objects and
call shmdt(), leaving shm object associated with no process, thus
consuming memory not counted via rlimits.
With shm_rmid_forced=1 the shared memory object is counted at least for
one process, so OOM killer may effectively kill the fat process holding
the shared memory.
It obviously breaks POSIX - some programs relying on the feature would
stop working. So set shm_rmid_forced=1 only if you're sure nobody uses
"orphaned" memory. Use shm_rmid_forced=0 by default for compatability
reasons.
The feature was previously impemented in -ow as a configure option.
[akpm@linux-foundation.org: fix documentation, per Randy]
[akpm@linux-foundation.org: fix warning]
[akpm@linux-foundation.org: readability/conventionality tweaks]
[akpm@linux-foundation.org: fix shm_rmid_forced/shm_forced_rmid confusion, use standard comment layout]
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Serge E. Hallyn" <serge.hallyn@canonical.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
Cc: Tejun Heo <tj@kernel.org>
Cc: Solar Designer <solar@openwall.com>
The commit log of 0ae5e89c60c9 ("memcg: count the soft_limit reclaim
in...") says it adds scanning stats to memory.stat file. But it doesn't
because we considered we needed to make a concensus for such new APIs.
This patch is a trial to add memory.scan_stat. This shows
- the number of scanned pages(total, anon, file)
- the number of rotated pages(total, anon, file)
- the number of freed pages(total, anon, file)
- the number of elaplsed time (including sleep/pause time)
for both of direct/soft reclaim.
The biggest difference with oringinal Ying's one is that this file
can be reset by some write, as
# echo 0 ...../memory.scan_stat
Example of output is here. This is a result after make -j 6 kernel
under 300M limit.
[kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.scan_stat
[kamezawa@bluextal ~]$ cat /cgroup/memory/A/memory.vmscan_stat
scanned_pages_by_limit 9471864
scanned_anon_pages_by_limit 6640629
scanned_file_pages_by_limit 2831235
rotated_pages_by_limit 4243974
rotated_anon_pages_by_limit 3971968
rotated_file_pages_by_limit 272006
freed_pages_by_limit 2318492
freed_anon_pages_by_limit 962052
freed_file_pages_by_limit 1356440
elapsed_ns_by_limit 351386416101
scanned_pages_by_system 0
scanned_anon_pages_by_system 0
scanned_file_pages_by_system 0
rotated_pages_by_system 0
rotated_anon_pages_by_system 0
rotated_file_pages_by_system 0
freed_pages_by_system 0
freed_anon_pages_by_system 0
freed_file_pages_by_system 0
elapsed_ns_by_system 0
scanned_pages_by_limit_under_hierarchy 9471864
scanned_anon_pages_by_limit_under_hierarchy 6640629
scanned_file_pages_by_limit_under_hierarchy 2831235
rotated_pages_by_limit_under_hierarchy 4243974
rotated_anon_pages_by_limit_under_hierarchy 3971968
rotated_file_pages_by_limit_under_hierarchy 272006
freed_pages_by_limit_under_hierarchy 2318492
freed_anon_pages_by_limit_under_hierarchy 962052
freed_file_pages_by_limit_under_hierarchy 1356440
elapsed_ns_by_limit_under_hierarchy 351386416101
scanned_pages_by_system_under_hierarchy 0
scanned_anon_pages_by_system_under_hierarchy 0
scanned_file_pages_by_system_under_hierarchy 0
rotated_pages_by_system_under_hierarchy 0
rotated_anon_pages_by_system_under_hierarchy 0
rotated_file_pages_by_system_under_hierarchy 0
freed_pages_by_system_under_hierarchy 0
freed_anon_pages_by_system_under_hierarchy 0
freed_file_pages_by_system_under_hierarchy 0
elapsed_ns_by_system_under_hierarchy 0
total_xxxx is for hierarchy management.
This will be useful for further memcg developments and need to be
developped before we do some complicated rework on LRU/softlimit
management.
This patch adds a new struct memcg_scanrecord into scan_control struct.
sc->nr_scanned at el is not designed for exporting information. For
example, nr_scanned is reset frequentrly and incremented +2 at scanning
mapped pages.
To avoid complexity, I added a new param in scan_control which is for
exporting scanning score.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Cc: Ying Han <yinghan@google.com>
Cc: Andrew Bresticker <abrestic@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t
ext3.txt: update the links in the section "useful links" to the latest ones
ext3: Fix data corruption in inodes with journalled data
ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get
ext3: Fix compilation with -DDX_DEBUG
quota: Remove unused declaration
jbd: Use WRITE_SYNC in journal checkpoint.
jbd: Fix oops in journal_remove_journal_head()
ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs()
ext3/ioctl.c: silence sparse warnings about different address spaces
ext3/ext4 Documentation: remove bh/nobh since it has been deprecated
ext3: Improve truncate error handling
ext3: use proper little-endian bitops
ext2: include fs.h into ext2_fs.h
ext3: Fix oops in ext3_try_to_allocate_with_rsv()
jbd: fix a bug of leaking jh->b_jcount
jbd: remove dependency on __GFP_NOFAIL
ext3: Convert ext3 to new truncate calling convention
jbd: Add fixed tracepoints
ext3: Add fixed tracepoints
Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and
new fixed tracepoints.
* 'x86-olpc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, olpc-xo15-sci: Enable EC wakeup capability
x86, olpc: Fix dependency on POWER_SUPPLY
x86, olpc: Add XO-1.5 SCI driver
x86, olpc: Add XO-1 RTC driver
x86, olpc-xo1-sci: Propagate power supply/battery events
x86, olpc-xo1-sci: Add lid switch functionality
x86, olpc-xo1-sci: Add GPE handler and ebook switch functionality
x86, olpc: EC SCI wakeup mask functionality
x86, olpc: Add XO-1 SCI driver and power button control
x86, olpc: Add XO-1 suspend/resume support
x86, olpc: Rename olpc-xo1 to olpc-xo1-pm
x86, olpc: Move CS5536-related constants to cs5535.h
x86, olpc: Add missing elements to device tree
Following commits a904937 and 0c1aa9a update the d_splice_alias
desciption.
Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (135 commits)
drm/radeon/kms: fix DP training for DPEncoderService revision bigger than 1.1
drm/radeon/kms: add missing vddci setting on NI+
drm/radeon: Add a rmb() in IH processing
drm/radeon: ATOM Endian fix for atombios_crtc_program_pll()
drm/radeon: Fix the definition of RADEON_BUF_SWAP_32BIT
drm/radeon: Do an MMIO read on interrupts when not uisng MSIs
drm/radeon: Writeback endian fixes
drm/radeon: Remove a bunch of useless _iomem casts
drm/gem: add support for private objects
DRM: clean up and document parsing of video= parameter
DRM: Radeon: Fix section mismatch.
drm: really make debug levels match in edid failure code
drm/radeon/kms: fix i2c map for rv250/280
drm/nouveau/gr: disable fifo access and idle before suspend ctx unload
drm/nouveau: pass flag to engine fini() method on suspend
drm/nouveau: replace nv04_graph_fifo_access() use with direct reg bashing
drm/nv40/gr: rewrite/split context takedown functions
drm/nouveau: detect disabled device in irq handler and return IRQ_NONE
drm/nouveau: ignore connector type when deciding digital/analog on DVI-I
drm/nouveau: Add a quirk for Gigabyte NX86T
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (741 commits)
staging:iio:meter:ade7753 should be 16 bit read not 8 bit for mode register.
staging:iio:kfifo_buf fix double initialization of the ring device structure.
staging:iio:accel:lis3l02dq: fix incorrect pointer passed to spi_set_drvdata.
staging:iio:imu fix missing register table index for some channels
spectra: enable device before poking it
staging: rts_pstor: Fix a miswriting
staging/lirc_bt829: Return -ENODEV when no hardware is found.
staging/lirc_parallel: remove pointless prototypes.
staging/lirc_parallel: fix panic on rmmod
staging:iio:adc:ad7476: Incorrect pointer into spi_set_drvdata.
Staging: zram: Fix kunmapping order
Revert "gma500: Fix dependencies"
gma500: Add medfield header
gma500: wire up the mrst i2c bus from chip_info
gma500: Fix DPU build
gma500: Clean up the DPU config and make it runtime
gma500: resync with Medfield progress
gma500: Use the mrst helpers and power control for mode commit
gma500@ Fix backlight range error
gma500: More Moorestown muddle meddling means MM maybe might modeset
Fix up fairly trivial conflicts all over, mostly due to header file
cleanup conflicts, but some deleted files and some just context changes:
- Documentation/feature-removal-schedule.txt
- drivers/staging/bcm/headers.h
- drivers/staging/brcm80211/brcmfmac/dhd_linux.c
- drivers/staging/brcm80211/brcmfmac/dhd_sdio.c
- drivers/staging/brcm80211/brcmfmac/wl_cfg80211.h
- drivers/staging/brcm80211/brcmfmac/wl_iw.c
- drivers/staging/et131x/et131x_netdev.c
- drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c
- drivers/staging/rtl8192e/r8192E.h
- drivers/staging/usbip/userspace/src/utils.h
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (115 commits)
EHCI: fix direction handling for interrupt data toggles
USB: serial: add IDs for WinChipHead USB->RS232 adapter
USB: OHCI: fix another regression for NVIDIA controllers
usb: gadget: m66592-udc: add pullup function
usb: gadget: m66592-udc: add function for external controller
usb: gadget: r8a66597-udc: add pullup function
usb: renesas_usbhs: support multi driver
usb: renesas_usbhs: inaccessible pipe is not an error
usb: renesas_usbhs: care buff alignment when dma handler
USB: PL2303: correctly handle baudrates above 115200
usb: r8a66597-hcd: fixup USB_PORT_STAT_C_SUSPEND shift
usb: renesas_usbhs: compile/config are rescued
usb: renesas_usbhs: fixup comment-out
usb: update email address in ohci-sh and r8a66597-hcd
usb: r8a66597-hcd: add function for external controller
EHCI: only power off port if over-current is active
USB: mon: Allow to use usbmon without debugfs
USB: EHCI: go back to using the system clock for QH unlinks
ehci: add pci quirk for Ordissimo and RM Slate 100 too
ehci: refactor pci quirk to use standard dmi_check_system method
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
updated Documentation/ja_JP/SubmittingPatches
debugfs: add documentation for debugfs_create_x64
uio: uio_pdrv_genirq: Add OF support
firmware: gsmi: remove sysfs entries when unload the module
Documentation/zh_CN: Fix messy code file email-clients.txt
driver core: add more help description for "path to uevent helper"
driver-core: modify FIRMWARE_IN_KERNEL help message
driver-core: Kconfig grammar corrections in firmware configuration
DOCUMENTATION: Replace create_device() with device_create().
DOCUMENTATION: Update overview.txt in Doc/driver-model.
pti: pti_tty_install documentation mispelling.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits)
drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c
powerpc/85xx: fix mpic configuration in CAMP mode
powerpc: Copy back TIF flags on return from softirq stack
powerpc/64: Make server perfmon only built on ppc64 server devices
powerpc/pseries: Fix hvc_vio.c build due to recent changes
powerpc: Exporting boot_cpuid_phys
powerpc: Add CFAR to oops output
hvc_console: Add kdb support
powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon
powerpc/irq: Quieten irq mapping printks
powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs
powerpc: Add mpt2sas driver to pseries and ppc64 defconfig
powerpc: Disable IRQs off tracer in ppc64 defconfig
powerpc: Sync pseries and ppc64 defconfigs
powerpc/pseries/hvconsole: Fix dropped console output
hvc_console: Improve tty/console put_chars handling
powerpc/kdump: Fix timeout in crash_kexec_wait_realmode
powerpc/mm: Fix output of total_ram.
powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards
powerpc: Correct annotations of pmu registration functions
Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and
drivers/cpufreq
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus:
Squashfs: Make ZLIB compression support optional
Squashfs: Update documentation for XZ and add squashfs-tools devel tree
* 'for-3.1' of git://linux-nfs.org/~bfields/linux:
nfsd: don't break lease on CLAIM_DELEGATE_CUR
locks: rename lock-manager ops
nfsd4: update nfsv4.1 implementation notes
nfsd: turn on reply cache for NFSv4
nfsd4: call nfsd4_release_compoundargs from pc_release
nfsd41: Deny new lock before RECLAIM_COMPLETE done
fs: locks: remove init_once
nfsd41: check the size of request
nfsd41: error out when client sets maxreq_sz or maxresp_sz too small
nfsd4: fix file leak on open_downgrade
nfsd4: remember to put RW access on stateid destruction
NFSD: Added TEST_STATEID operation
NFSD: added FREE_STATEID operation
svcrpc: fix list-corrupting race on nfsd shutdown
rpc: allow autoloading of gss mechanisms
svcauth_unix.c: quiet sparse noise
svcsock.c: include sunrpc.h to quiet sparse noise
nfsd: Remove deprecated nfsctl system call and related code.
NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
There have been persistent lockdep RCU splats, indicating that submitters
are not testing with CONFIG_PROVE_RCU. Add this config option to the list
in Documentation/SubmitChecklist. Also add CONFIG_DEBUG_OBJECTS_RCU_HEAD
for good measure.
The FSA9480 is a USB port accessory detector and switch. This patch adds
support the FSA9480 USB Switch.
[akpm@linux-foundation.org: make a couple of things static]
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Cc: Greg KH <greg@kroah.com>
The badness() function in the oom killer was renamed to oom_badness() in
a63d83f427fb ("oom: badness heuristic rewrite") since it is a globally
exported function for clarity.
The prototype for the old function still existed in linux/oom.h, so remove
it. There are no existing users.
Also fixes documentation and comment references to badness() and adjusts
them accordingly.
Signed-off-by: David Rientjes <rientjes@google.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
In commit a2c8990aed5ab ("memsw: remove noswapaccount kernel parameter"),
Michal forgot to remove some left pieces of noswapaccount in the tree,
this patch removes them all.
Acked-by: Michal Hocko <mhocko@suse.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (lm78) Become the maintainer
hwmon: (lm78) Make ISA interface depend on CONFIG_ISA
hwmon: (lm78) Avoid forward declarations
hwmon: (sht15) Correct a comment mistake
hwmon: (max1111) Avoid extra memory allocations
hwmon: (it87) Add chassis intrusion detection support
hwmon: (via-cputemp) Add VID reporting support
hwmon-vid: Add support for VIA family 6 model D CPU
hwmon: New driver sch5636
hwmon: (sch5627) Factor out some code shared with sch5636 driver
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
fs: take the ACL checks to common code
bury posix_acl_..._masq() variants
kill boilerplates around posix_acl_create_masq()
generic_acl: no need to clone acl just to push it to set_cached_acl()
kill boilerplate around posix_acl_chmod_masq()
reiserfs: cache negative ACLs for v1 stat format
xfs: cache negative ACLs if there is no attribute fork
9p: do no return 0 from ->check_acl without actually checking
vfs: move ACL cache lookup into generic code
CIFS: Fix oops while mounting with prefixpath
xfs: Fix wrong return value of xfs_file_aio_write
fix devtmpfs race
caam: don't pass bogus S_IFCHR to debugfs_create_...()
get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose
asus-wmi: ->is_visible() can't return negative
fix jffs2 ACLs on big-endian with 16bit mode_t
9p: close ACL leaks
ocfs2_init_acl(): fix a leak
VFS : mount lock scalability for internal mounts
Declare myself the maintainer of the lm78 driver. I still have a
running system with one of these chips.
Also count myself as a co-author of the driver. With 34 commits over
6 years, it seems fair.
Add chassis intrusion detection support for all supported devices,
using the standard interface.
This patch adds a new driver for SMSC SCH5636 Super I/O chips.
The chips include an embedded microcontroller for hardware monitoring
solutions, allowing motherboard manufacturers to create their own
custom hwmon solution based upon the SCH5636.
Currently the sch5636 driver only supports the Fujitsu Theseus SCH5636
based hwmon solution. The sch5636 driver runs a sanity check on
loading to ensure it is dealing with a Fujitsu Theseus and not with
another custom SCH5636 based hwmon solution.
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/deletion' of git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: mach-loki: delete
ARM: mach-s3c2400: delete
ARM: mach-s3c24a0: delete
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits)
block: strict rq_affinity
backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu
block: fix patch import error in max_discard_sectors check
block: reorder request_queue to remove 64 bit alignment padding
CFQ: add think time check for group
CFQ: add think time check for service tree
CFQ: move think time check variables to a separate struct
fixlet: Remove fs_excl from struct task.
cfq: Remove special treatment for metadata rqs.
block: document blk_plug list access
block: avoid building too big plug list
compat_ioctl: fix make headers_check regression
block: eliminate potential for infinite loop in blkdev_issue_discard
compat_ioctl: fix warning caused by qemu
block: flush MEDIA_CHANGE from drivers on close(2)
blk-throttle: Make total_nr_queued unsigned
block: Add __attribute__((format(printf...) and fix fallout
fs/partitions/check.c: make local symbols static
block:remove some spare spaces in genhd.c
block:fix the comment error in blkdev.h
In Documentation/filesystems/ext3.txt, the section "useful links"
provides two links which link to ibm developerworks articles. While
the second one can be redirected to the latest one, the first one
http://www.ibm.com/developerworks/library/l-fs7.html
fails to be redirected.
Update the 2 links to the latest ones.
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com>
The video= parameter of the DRM drivers supports some additional flags that
the normal fb drivers do not have. They also allow to limit these flags to
specific outputs. Both things were previously undocumented.
Also the parsing of the line had some oddities:
-A lot of misplaced options were silently ignored or partly rejected instead
of stopping the parsing immediately
-The 'R' option is documented to follow the 'M' option if specified. It is not
documented that 'M' is needed to specify 'R' (also this is the case for normal
fb drivers). In fact the code is correct for normal fb drivers but wrong for
DRM ones.
The old code allowed 'R' only _before_ 'M' (since it parses backwards) and only
if 'M' is given at all which is not needed for the DRM drivers.
-the margins option ('m') was parsed but later ignored even if the later
functions support it.
-specifying multiple enable options at the same time did not lead to an error.
-specifying something bogus for horizontal resolution (i.e. other things as
digits) did not lead to an error but an invalid resolution was used.
If any errors are encountered the position of the faulting string is now
printed to the user and the complete mode is ignored. This gives much
more consistent error behaviour.
I also removed some useless assignments and changed the local flag variables
to be bool.
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (237 commits)
ARM: 7004/1: fix traps.h compile warnings
ARM: 6998/2: kernel: use proper memory barriers for bitops
ARM: 6997/1: ep93xx: increase NR_BANKS to 16 for support of 128MB RAM
ARM: Fix build errors caused by adding generic macros
ARM: CPU hotplug: ensure we migrate all IRQs off a downed CPU
ARM: CPU hotplug: pass in proper affinity mask on IRQ migration
ARM: GIC: avoid routing interrupts to offline CPUs
ARM: CPU hotplug: fix abuse of irqdesc->node
ARM: 6981/2: mmci: adjust calculation of f_min
ARM: 7000/1: LPAE: Use long long printk format for displaying the pud
ARM: 6999/1: head, zImage: Always Enter the kernel in ARM state
ARM: btc: avoid invalidating the branch target cache on kernel TLB maintanence
ARM: ARM_DMA_ZONE_SIZE is no more
ARM: mach-shark: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-sa1100: move ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-realview: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-pxa: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-ixp4xx: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-h720x: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
ARM: mach-davinci: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_size
Current documentation referred to the old method of handling augmented
trees. Update documentation to correspond with the changes done in
commit b945d6b2554d ("rbtree: Undo augmented trees performance damage
and regression").
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: David Woodhouse <David.Woodhouse@intel.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (21 commits)
[S390] use siginfo for sigtrap signals
[S390] dasd: add enhanced DASD statistics interface
[S390] kvm: make sigp emerg smp capable
[S390] disable cpu measurement alerts on a dying cpu
[S390] initial cr0 bits
[S390] iucv cr0 enablement bit
[S390] race safe external interrupt registration
[S390] remove tape block docu
[S390] ap: toleration support for ap device type 10
[S390] cleanup program check handler prototypes
[S390] remove kvm mmu reload on s390
[S390] Use gmap translation for accessing guest memory
[S390] use gmap address spaces for kvm guest images
[S390] kvm guest address space mapping
[S390] fix s390 assembler code alignments
[S390] move sie code to entry.S
[S390] kvm: handle tprot intercepts
[S390] qdio: clear shared DSCI before scheduling the queue handler
[S390] reference bit testing for unmapped pages
[S390] irqs: Do not trace arch_local_{*,irq_*} functions
* 'kvm-updates/3.1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits)
KVM: IOMMU: Disable device assignment without interrupt remapping
KVM: MMU: trace mmio page fault
KVM: MMU: mmio page fault support
KVM: MMU: reorganize struct kvm_shadow_walk_iterator
KVM: MMU: lockless walking shadow page table
KVM: MMU: do not need atomicly to set/clear spte
KVM: MMU: introduce the rules to modify shadow page table
KVM: MMU: abstract some functions to handle fault pfn
KVM: MMU: filter out the mmio pfn from the fault pfn
KVM: MMU: remove bypass_guest_pf
KVM: MMU: split kvm_mmu_free_page
KVM: MMU: count used shadow pages on prepareing path
KVM: MMU: rename 'pt_write' to 'emulate'
KVM: MMU: cleanup for FNAME(fetch)
KVM: MMU: optimize to handle dirty bit
KVM: MMU: cache mmio info on page fault path
KVM: x86: introduce vcpu_mmio_gva_to_gpa to cleanup the code
KVM: MMU: do not update slot bitmap if spte is nonpresent
KVM: MMU: fix walking shadow page table
KVM guest: KVM Steal time registration
The idea is from Avi:
| Maybe it's time to kill off bypass_guest_pf=1. It's not as effective as
| it used to be, since unsync pages always use shadow_trap_nonpresent_pte,
| and since we convert between the two nonpresent_ptes during sync and unsync.
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
This patch implements the kvm bits of the steal time infrastructure.
The most important part of it, is the steal time clock. It is an
continuous clock that shows the accumulated amount of steal time
since vcpu creation. It is supposed to survive cpu offlining/onlining.
[marcelo: fix build with CONFIG_KVM_GUEST=n]
Signed-off-by: Glauber Costa <glommer@redhat.com>
Tested-by: Eric B Munson <emunson@mgebm.net>
CC: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
CC: Peter Zijlstra <peterz@infradead.org>
CC: Avi Kivity <avi@redhat.com>
CC: Anthony Liguori <aliguori@us.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
After git commit 66ceed5ad1318863c21710f316942bcefff8081c removed
the tape block device driver, remove its documentation as well.
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (43 commits)
Blackfin: spi-docs: further clarify GPIO CS behavior with various modes
Blackfin: boards: fix pcm device name
Blackfin: SMP: punt unused atomic_test_mask helper
Blackfin: irqs: do not trace arch_local_{*,irq_*} functions
Blackfin: bf526: restrict reboot workaround to 0.0 silicon
Blackfin: bf51x: fix alternative portmux options
Blackfin: bf54x: fix GPIO resume code
Blackfin: dpmc: optimize SDRAM programming slightly
Blackfin: dpmc: don't save/restore scratch registers
Blackfin: bf538: pull gpio/port logic out of core hibernate paths
Blackfin: dpmc: optimize hibernate/resume path
Blackfin: dpmc: do not save/restore EVT0/EVT1/EVT4 when hibernating
Blackfin: dpmc: relocate hibernate helper macros
Blackfin: dpmc: omit RETE/RETN when hibernating
Blackfin: dpmc: optimize SIC_IWR programming a little
Blackfin: gpio/ints: generalize pint logic
Blackfin: dpmc: bind to MMR names and not CPUs
Blackfin: debug-mmrs: generalize pint logic
Blackfin: bf54x: switch to common pint MMR struct
Blackfin: bf54x: tweak MMR pint names
Some systems benefit from completions always being steered to the strict
requester cpu rather than the looser "per-socket" steering that
blk_cpu_to_group() attempts by default. This is because the first
CPU in the group mask ends up being completely overloaded with work,
while the others (including the original submitter) has power left
to spare.
Allow the strict mode to be set by writing '2' to the sysfs control
file. This is identical to the scheme used for the nomerges file,
where '2' is a more aggressive setting than just being turned on.
echo 2 > /sys/block/<bdev>/queue/rq_affinity
Cc: Roland Dreier <roland@purestorage.com>
Tested-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
