path: root/Documentation
2015-01-23Merge tag 'kvm-s390-next-20150122' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into kvm-next KVM: s390: fixes and features for kvm/next (3.20) 1. Generic - sparse warning (make function static) - optimize locking - bugfixes for interrupt injection - fix MVPG addressing modes 2. hrtimer/wakeup fun A recent change can cause KVM hangs if adjtime is used in the host. The hrtimer might wake up too early or too late. Too early is fatal as vcpu_block will see that the wakeup condition is not met and sleep again. This CPU might never wake up again. This series addresses this problem. adjclock slowing down the host clock will result in too late wakeups. This will require more work. In addition to that we also change the hrtimer from REALTIME to MONOTONIC to avoid similar problems with timedatectl set-time. 3. sigp rework We will move all "slow" sigps to QEMU (protected with a capability that can be enabled) to avoid several races between concurrent SIGP orders. 4. Optimize the shadow page table Provide an interface to announce the maximum guest size. The kernel will use that to make the pagetable 2,3,4 (or theoretically) 5 levels. 5. Provide an interface to set the guest TOD We now use two vm attributes instead of two oneregs, as oneregs are vcpu ioctl and we don't want to call them from other threads. 6. Protected key functions The real HMC allows to enable/disable protected key CPACF functions. Lets provide an implementation + an interface for QEMU to activate this the protected key instructions.
2015-01-23KVM: s390: forward most SIGP orders to user spaceDavid Hildenbrand
Most SIGP orders are handled partially in kernel and partially in user space. In order to: - Get a correct SIGP SET PREFIX handler that informs user space - Avoid race conditions between concurrently executed SIGP orders - Serialize SIGP orders per VCPU We need to handle all "slow" SIGP orders in user space. The remaining ones to be handled completely in kernel are: - SENSE - SENSE RUNNING - EXTERNAL CALL - EMERGENCY SIGNAL - CONDITIONAL EMERGENCY SIGNAL According to the PoP, they have to be fast. They can be executed without conflicting to the actions of other pending/concurrently executing orders (e.g. STOP vs. START). This patch introduces a new capability that will - when enabled - forward all but the mentioned SIGP orders to user space. The instruction counters in the kernel are still updated. Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2015-01-23KVM: s390: new parameter for SIGP STOP irqsDavid Hildenbrand
In order to get rid of the action_flags and to properly migrate pending SIGP STOP irqs triggered e.g. by SIGP STOP AND STORE STATUS, we need to remember whether to store the status when stopping. For this reason, a new parameter (flags) for the SIGP STOP irq is introduced. These flags further define details of the requested STOP and can be easily migrated. Reviewed-by: Thomas Huth <thuth@linux.vnet.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2015-01-23KVM: s390: Allow userspace to limit guest memory sizeDominik Dingel
With commit c6c956b80bdf ("KVM: s390/mm: support gmap page tables with less than 5 levels") we are able to define a limit for the guest memory size. As we round up the guest size in respect to the levels of page tables we get to guest limits of: 2048 MB, 4096 GB, 8192 TB and 16384 PB. We currently limit the guest size to 16 TB, which means we end up creating a page table structure supporting guest sizes up to 8192 TB. This patch introduces an interface that allows userspace to tune this limit. This may bring performance improvements for small guests. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2015-01-20arm/arm64: KVM: force alignment of VGIC dist/CPU/redist addressesAndre Przywara
Although the GIC architecture requires us to map the MMIO regions only at page aligned addresses, we currently do not enforce this from the kernel side. Restrict any vGICv2 regions to be 4K aligned and any GICv3 regions to be 64K aligned. Document this requirement. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-01-20arm/arm64: KVM: allow userland to request a virtual GICv3Andre Przywara
With all of the GICv3 code in place now we allow userland to ask the kernel for using a virtual GICv3 in the guest. Also we provide the necessary support for guests setting the memory addresses for the virtual distributor and redistributors. This requires some userland code to make use of that feature and explicitly ask for a virtual GICv3. Document that KVM_CREATE_IRQCHIP only works for GICv2, but is considered legacy and using KVM_CREATE_DEVICE is preferred. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-01-11KVM: arm/arm64: vgic: add init entry to VGIC KVM deviceEric Auger
Since the advent of VGIC dynamic initialization, this latter is initialized quite late on the first vcpu run or "on-demand", when injecting an IRQ or when the guest sets its registers. This initialization could be initiated explicitly much earlier by the users-space, as soon as it has provided the requested dimensioning parameters. This patch adds a new entry to the VGIC KVM device that allows the user to manually request the VGIC init: - a new KVM_DEV_ARM_VGIC_GRP_CTRL group is introduced. - Its first attribute is KVM_DEV_ARM_VGIC_CTRL_INIT The rationale behind introducing a group is to be able to add other controls later on, if needed. Signed-off-by: Eric Auger <eric.auger@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-12-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input layer fixes from Dmitry Torokhov: "Fixes for v7 protocol for ALPS devices and few other driver fixes. Also users can request input events to be stamped with boot time timestamps, in addition to real and monotonic timestamps" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: hil_kbd - fix incorrect use of init_completion Input: alps - v7: document the v7 touchpad packet protocol Input: alps - v7: fix finger counting for > 2 fingers on clickpads Input: alps - v7: sometimes a single touch is reported in mt[1] Input: alps - v7: ignore new packets Input: evdev - add CLOCK_BOOTTIME support Input: psmouse - expose drift duration for IBM trackpoints Input: stmpe - bias keypad columns properly Input: stmpe - enforce device tree only mode mfd: stmpe: add pull up/down register offsets for STMPE Input: optimize events_per_packet count calculation Input: edt-ft5x06 - fixed a macro coding style issue Input: gpio_keys - replace timer and workqueue with delayed workqueue Input: gpio_keys - allow separating gpio and irq in device tree
2014-12-20Merge tag 'clk-for-linus-3.19' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clk framework updates from Mike Turquette: "This is much later than usual due to several last minute bugs that had to be addressed. As usual the majority of changes are new drivers and modifications to existing drivers. The core recieved many fixes along with the groundwork for several large changes coming in the future which will better parition clock providers from clock consumers" * tag 'clk-for-linus-3.19' of git://git.linaro.org/people/mike.turquette/linux: (86 commits) clk: samsung: Fix Exynos 5420 pinctrl setup and clock disable failure due to domain being gated ARM: OMAP3: clock: fix boot breakage in legacy mode ARM: OMAP2+: clock: fix DPLL code to use new determine rate APIs clk: Really fix deadlock with mmap_sem clk: mmp: fix sparse non static symbol warning clk: Change clk_ops->determine_rate to return a clk_hw as the best parent clk: change clk_debugfs_add_file to take a struct clk_hw clk: Don't expose __clk_get_accuracy clk: Don't try to use a struct clk* after it could have been freed clk: Remove unused function __clk_get_prepare_count clk: samsung: Fix double add of syscore ops after driver rebind clk: samsung: exynos4: set parent of sclk_hdmiphy to hdmi clk: samsung: exynos4415: Fix build with PM_SLEEP disabled clk: samsung: remove unnecessary inclusion of header files from clk.h clk: samsung: remove unnecessary CONFIG_OF from clk.c clk: samsung: Spelling s/bwtween/between/ clk: rockchip: Add support for the mmc clock phases using the framework clk: rockchip: add bindings for the mmc clocks clk: rockchip: rk3288 export i2s0_clkout for use in DT clk: rockchip: use clock ID for DMC (memory controller) on rk3288 ...
2014-12-19Merge branch 'x86-mpx-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 MPX fixes from Thomas Gleixner: "Three updates for the new MPX infrastructure: - Use the proper error check in the trap handler - Add a proper config option for it - Bring documentation up to date" * 'x86-mpx-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, mpx: Give MPX a real config option prompt x86, mpx: Update documentation x86_64/traps: Fix always true condition
2014-12-19Merge tag 'powerpc-3.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull second batch of powerpc updates from Michael Ellerman: "The highlight is the series that reworks the idle management on powernv, which allows us to use deeper idle states on those machines. There's the fix from Anton for the "BUG at kernel/smpboot.c:134!" problem. An i2c driver for powernv. This is acked by Wolfram Sang, and he asked that we take it through the powerpc tree. A fix for audit from rgb at Red Hat, acked by Paul Moore who is one of the audit maintainers. A patch from Ben to export the symbol map of our OPAL firmware as a sysfs file, so that tools can use it. Also some CXL fixes, a couple of powerpc perf fixes, a fix for smt-enabled, and the patch to add __force to get_user() so we can use bitwise types" * tag 'powerpc-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: powerpc/powernv: Ignore smt-enabled on Power8 and later powerpc/uaccess: Allow get_user() with bitwise types powerpc/powernv: Expose OPAL firmware symbol map powernv/powerpc: Add winkle support for offline cpus powernv/cpuidle: Redesign idle states management powerpc/powernv: Enable Offline CPUs to enter deep idle states powerpc/powernv: Switch off MMU before entering nap/sleep/rvwinkle mode i2c: Driver to expose PowerNV platform i2c busses powerpc: add little endian flag to syscall_get_arch() power/perf/hv-24x7: Use kmem_cache_free() instead of kfree powerpc/perf/hv-24x7: Use per-cpu page buffer cxl: Unmap MMIO regions when detaching a context cxl: Add timeout to process element commands cxl: Change contexts_lock to a mutex to fix sleep while atomic bug powerpc: Secondary CPUs must set cpu_callin_map after setting active and online
2014-12-18Merge tag 'pm+acpi-3.19-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management updates from Rafael Wysocki: "These are regression fixes (leds-gpio, ACPI backlight driver, operating performance points library, ACPI device enumeration messages, cpupower tool), other bug fixes (ACPI EC driver, ACPI device PM), some cleanups in the operating performance points (OPP) framework, continuation of CONFIG_PM_RUNTIME elimination, a couple of minor intel_pstate driver changes, a new MAINTAINERS entry for it and an ACPI fan driver change needed for better support of thermal management in user space. Specifics: - Fix a regression in leds-gpio introduced by a recent commit that inadvertently changed the name of one of the properties used by the driver (Fabio Estevam). - Fix a regression in the ACPI backlight driver introduced by a recent fix that missed one special case that had to be taken into account (Aaron Lu). - Drop the level of some new kernel messages from the ACPI core introduced by a recent commit to KERN_DEBUG which they should have used from the start and drop some other unuseful KERN_ERR messages printed by ACPI (Rafael J Wysocki). - Revert an incorrect commit modifying the cpupower tool (Prarit Bhargava). - Fix two regressions introduced by recent commits in the OPP library and clean up some existing minor issues in that code (Viresh Kumar). - Continue to replace CONFIG_PM_RUNTIME with CONFIG_PM throughout the tree (or drop it where that can be done) in order to make it possible to eliminate CONFIG_PM_RUNTIME (Rafael J Wysocki, Ulf Hansson, Ludovic Desroches). There will be one more "CONFIG_PM_RUNTIME removal" batch after this one, because some new uses of it have been introduced during the current merge window, but that should be sufficient to finally get rid of it. - Make the ACPI EC driver more robust against race conditions related to GPE handler installation failures (Lv Zheng). - Prevent the ACPI device PM core code from attempting to disable GPEs that it has not enabled which confuses ACPICA and makes it report errors unnecessarily (Rafael J Wysocki). - Add a "force" command line switch to the intel_pstate driver to make it possible to override the blacklisting of some systems in that driver if needed (Ethan Zhao). - Improve intel_pstate code documentation and add a MAINTAINERS entry for it (Kristen Carlson Accardi). - Make the ACPI fan driver create cooling device interfaces witn names that reflect the IDs of the ACPI device objects they are associated with, except for "generic" ACPI fans (PNP ID "PNP0C0B"). That's necessary for user space thermal management tools to be able to connect the fans with the parts of the system they are supposed to be cooling properly. From Srinivas Pandruvada" * tag 'pm+acpi-3.19-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits) MAINTAINERS: add entry for intel_pstate ACPI / video: update the skip case for acpi_video_device_in_dod() power / PM: Eliminate CONFIG_PM_RUNTIME NFC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM SCSI / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / EC: Fix unexpected ec_remove_handlers() invocations Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()" tracing / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM x86 / PM: Replace CONFIG_PM_RUNTIME in io_apic.c PM: Remove the SET_PM_RUNTIME_PM_OPS() macro mmc: atmel-mci: use SET_RUNTIME_PM_OPS() macro PM / Kconfig: Replace PM_RUNTIME with PM in dependencies ARM / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM sound / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM phy / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM video / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tty / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM spi: Replace CONFIG_PM_RUNTIME with CONFIG_PM ACPI / PM: Do not disable wakeup GPEs that have not been enabled ACPI / utils: Drop error messages from acpi_evaluate_reference() ...
2014-12-18Merge tag 'platform-drivers-x86-v3.19-1' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver update from Darren Hart: - thinkpad-acpi: Switch to software mute, cleanups - acerhdf: Bang-bang thermal governor, new models, cleanups - dell-laptop: New keyboard backlight support and documentation - toshiba_acpi: Keyboard backlight updates, hotkey handling - dell-wmi: Keypress filtering, WMI event processing - eeepc-laptop: Multiple cleanups, improved error handling, documentation - hp_wireless: Inform the user if hp_wireless_input_setup()/add() fails - misc: Code cleanups, quirks, various new IDs * tag 'platform-drivers-x86-v3.19-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (33 commits) platform/x86/acerhdf: Still depends on THERMAL Documentation: Add entry for dell-laptop sysfs interface acpi: Remove _OSI(Linux) for ThinkPads thinkpad-acpi: Try to use full software mute control acerhdf: minor clean up acerhdf: added critical trip point acerhdf: Use bang-bang thermal governor acerhdf: Adding support for new models acerhdf: Adding support for "manual mode" dell-smo8800: Add more ACPI ids and change description of driver platform: x86: dell-laptop: Add support for keyboard backlight toshiba_acpi: Add keyboard backlight mode change event toshiba_acpi: Change notify funtion to handle more events toshiba_acpi: Move hotkey enabling code to its own function dell-wmi: Don't report keypresses on keybord illumination change dell-wmi: Don't report keypresses for radio state changes hp_wireless: Inform the user if hp_wireless_input_setup()/add() fails toshiba-acpi: Add missing ID (TOS6207) Sony-laptop: Deletion of an unnecessary check before the function call "pci_dev_put" platform: x86: Deletion of checks before backlight_device_unregister() ...
2014-12-18Merge tag 'media/v3.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull second set of media updates from Mauro Carvalho Chehab: - Move drivers for really old legacy hardware to staging. Those are using obsolete media kAPIs and are for hardware that nobody uses for years. Simply not worth porting them to the new kAPIs. Of course, if anyone pops up to fix, we can move them back from there - While not too late, do some API fixups at the new colorspace API, added for v3.19 - Some improvements for rcar_vin driver - Some fixups at cx88 and vivid drivers - Some Documentation fixups * tag 'media/v3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] bq/c-qcam, w9966, pms: move to staging in preparation for removal [media] tlg2300: move to staging in preparation for removal [media] vino/saa7191: move to staging in preparation for removal [media] MAINTAINERS: vivi -> vivid [media] cx88: remove leftover start_video_dma() call [media] cx88: add missing alloc_ctx support [media] v4l2-ioctl: WARN_ON if querycap didn't fill device_caps [media] vivid: fix CROP_BOUNDS typo for video output [media] DocBook media: update version number and document changes [media] vivid.txt: document new controls [media] DocBook media: add missing ycbcr_enc and quantization fields [media] v4l2-mediabus.h: use two __u16 instead of two __u32 [media] rcar_vin: Fix interrupt enable in progressive [media] rcar_vin: Enable VSYNC field toggle mode [media] rcar_vin: Add scaling support [media] rcar_vin: Add DT support for r8a7793 and r8a7794 SoCs [media] rcar_vin: Add YUYV capture format support
2014-12-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix NBMA tunnel mac header handling in GRE, from Timo Teräs. 2) Fix a NAPI race in the fec driver, from Nimrod Andy. 3) The new IFF_VNET_LE bit is outside the size of the flags member it is stored in (which is 16-bits), store the state locally in the drivers. From Michael S Tsirkin. 4) We are kicking the tires with the new wireless maintainership situation. Bluetooth fixes via Johan Hedberg, and mac80211 fixes from Johannes Berg. 5) Fix locking and leaks in geneve driver, from Jesse Gross. 6) Make netlink TX mmap code always copy, so we don't have to be potentially exposed to the user changing the underlying contents from underneath us. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (63 commits) be2net: Fix incorrect setting of tunnel offload flag in netdev features bnx2x: fix typos in "configure" xen-netback: support frontends without feature-rx-notify again MAINTAINERS: changes for wireless cxgb4: Fix decoding QSA module for ethtool get settings geneve: Fix races between socket add and release. geneve: Remove socket and offload handlers at destruction. netlink: Don't reorder loads/stores before marking mmap netlink frame as available netlink: Always copy on mmap TX. Bluetooth: Fix bug with filter in service discovery optimization mac80211: free management frame keys when removing station net: Disallow providing non zero VLAN ID for NIC drivers FDB add flow net/mlx4: Cache line CQE/EQE stride fixes net: fec: Fix NAPI race xen-netfront: use napi_complete() correctly to prevent Rx stalling ip_tunnel: Add missing validation of encap type to ip_tunnel_encap_setup() ip_tunnel: Add sanity checks to ip_tunnel_encap_add_ops() net: Allow FIXED_PHY to be modular. if_tun: drop broken IFF_VNET_LE macvtap: drop broken IFF_VNET_LE ...
2014-12-18Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM update from Paolo Bonzini: "3.19 changes for KVM: - spring cleaning: removed support for IA64, and for hardware- assisted virtualization on the PPC970 - ARM, PPC, s390 all had only small fixes For x86: - small performance improvements (though only on weird guests) - usual round of hardware-compliancy fixes from Nadav - APICv fixes - XSAVES support for hosts and guests. XSAVES hosts were broken because the (non-KVM) XSAVES patches inadvertently changed the KVM userspace ABI whenever XSAVES was enabled; hence, this part is going to stable. Guest support is just a matter of exposing the feature and CPUID leaves support" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (179 commits) KVM: move APIC types to arch/x86/ KVM: PPC: Book3S: Enable in-kernel XICS emulation by default KVM: PPC: Book3S HV: Improve H_CONFER implementation KVM: PPC: Book3S HV: Fix endianness of instruction obtained from HEIR register KVM: PPC: Book3S HV: Remove code for PPC970 processors KVM: PPC: Book3S HV: Tracepoints for KVM HV guest interactions KVM: PPC: Book3S HV: Simplify locking around stolen time calculations arch: powerpc: kvm: book3s_paired_singles.c: Remove unused function arch: powerpc: kvm: book3s_pr.c: Remove unused function arch: powerpc: kvm: book3s.c: Remove some unused functions arch: powerpc: kvm: book3s_32_mmu.c: Remove unused function KVM: PPC: Book3S HV: Check wait conditions before sleeping in kvmppc_vcore_blocked KVM: PPC: Book3S HV: ptes are big endian KVM: PPC: Book3S HV: Fix inaccuracies in ICP emulation for H_IPI KVM: PPC: Book3S HV: Fix KSM memory corruption KVM: PPC: Book3S HV: Fix an issue where guest is paused on receiving HMI KVM: PPC: Book3S HV: Fix computation of tlbie operand KVM: PPC: Book3S HV: Add missing HPTE unlock KVM: PPC: BookE: Improve irq inject tracepoint arm/arm64: KVM: Require in-kernel vgic for the arch timers ...
2014-12-18Merge branch 'next' into for-linusDmitry Torokhov
Second round of input updates for 3.19.
2014-12-18Merge branches 'pm-opp', 'pm-cpufreq' and 'pm-tools'Rafael J. Wysocki
* pm-opp: PM / OPP: do error handling at the bottom of dev_pm_opp_add_dynamic() PM / OPP: handle allocation of device_opp in a separate routine PM / OPP: reuse find_device_opp() instead of duplicating code PM / OPP: Staticize __dev_pm_opp_remove() PM / OPP: replace kfree with kfree_rcu while freeing 'struct device_opp' * pm-cpufreq: MAINTAINERS: add entry for intel_pstate intel_pstate: Add a few comments intel_pstate: add kernel parameter to force loading * pm-tools: Revert "tools: cpupower: fix return checks for sysfs_get_idlestate_count()"
2014-12-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management update from Zhang Rui: "Summary: - of-thermal extension to allow drivers to register and use its functionality in a better way, without exploiting thermal core. From Lukasz Majewski. - Fix a bug in intel_soc_dts_thermal driver which calls a sleep function in interrupt handler. From Maurice Petallo. - add a thermal UAPI header file for exporting the thermal generic netlink information to user-space. From Florian Fainelli. - First round of refactoring in Exynos driver. Bartlomiej and Lukasz are attempting to make it lean and easier to understand. - New thermal driver for Rockchip (rk3288), with support for DT thermal. From Caesar Wang. - New thermal driver for Nvidia, Tegra124 SOCTHERM driver, with support for DT thermal. From Mikko Perttunen. - New cooling device, based on common clock framework. From Eduardo Valentin. - a couple of small fixes in thermal core framework. From Srinivas Pandruvada, Javi Merino, Luis Henriques. - Dropping Armada A375-Z1 SoC thermal support as the chip is not in the market, armada folks decided to drop its support. - a couple of small fixes and cleanups in int340x thermal driver" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (58 commits) thermal: provide an UAPI header file Thermal/int340x: Clear the error value of the last acpi_bus_get_device() call thermal/powerclamp: add id for braswell cpu thermal: Intel SoC DTS: Don't do thermal zone update inside spin_lock Thermal: fix platform_no_drv_owner.cocci warnings Thermal/int340x: avoid unnecessary pointer casting thermal: int3403: Delete a check before thermal_zone_device_unregister() thermal/int3400: export uuids thermal: of: Extend current of-thermal.c code to allow setting emulated temp thermal: of: Extend of-thermal to export table of trip points thermal: of: Rename struct __thermal_trip to struct thermal_trip thermal: of: Extend of-thermal.c to provide check if trip point is valid thermal: of: Extend of-thermal.c to provide number of trip points thermal: Fix error path in thermal_init() thermal: lock the thermal zone when switching governors thermal: core: ignore invalid trip temperature thermal: armada: Remove support for A375-Z1 SoC thermal: rockchip: add driver for thermal dt-bindings: document Rockchip thermal thermal: exynos: remove exynos_tmu_data.h include ...
2014-12-17Merge tag 'pwm/for-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm updates from Thierry Reding: "There are two new drivers, one for the BCM2835 (Raspberry Pi) and one used in conjunction with the LCD controller on various Atmel SoCs. The Samsung PWM driver can now be built for 64-bit ARM (Exynos7). A couple of fixes have been applied to the FTM PWM driver and system sleep support was added" * tag 'pwm/for-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: atmel-hlcdc: add at91sam9x5 and sama5d3 errata handling pwm: ftm: Add Power Management support for FTM PWM pwm: ftm: Add regmap rbtree type cache support pwm: ftm: Correctly track usage count pwm: samsung: Allow Samsung PWM driver to be enabled on Exynos7 pwm: add DT bindings documentation for atmel-hlcdc-pwm driver pwm: add support for atmel-hlcdc-pwm device pwm: Add BCM2835 PWM driver
2014-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "Two new drivers for Elan hardware (for I2C touchpad and touchscreen found in several Chromebooks and other devices), a driver for Goodix touch panel, and small fixes to Cypress I2C trackpad and other input drivers. Also we switched to use __maybe_unused instead of gating suspend/ resume code with #ifdef guards to get better compile coverage" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (27 commits) Input: gpio_keys - fix warning regarding uninitialized 'button' variable Input: add support for Elan eKTH I2C touchscreens Input: gpio_keys - fix warning regarding uninitialized 'irq' variable Input: cyapa - use 'error' for error codes Input: cyapa - fix resuming the device Input: gpio_keys - add device tree support for interrupt only keys Input: amikbd - allocate temporary keymap buffer on the stack Input: amikbd - fix build if !CONFIG_HW_CONSOLE Input: lm8323 - missing error check in lm8323_set_disable() Input: initialize device counter variables with -1 Input: initialize input_no to -1 to avoid subtraction Input: i8042 - do not try to load on Intel NUC D54250WYK Input: atkbd - correct MSC_SCAN events for force_release keys Input: cyapa - switch to using managed resources Input: lifebook - use "static inline" instead of "inline" in lifebook.h Input: touchscreen - use __maybe_unused instead of ifdef around suspend/resume Input: mouse - use __maybe_unused instead of ifdef around suspend/resume Input: misc - use __maybe_unused instead of ifdef around suspend/resume Input: cap11xx - support for irq-active-high option Input: cap11xx - add support for various cap11xx devices ...
2014-12-17Merge tag 'for-linus-20141215' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD updates from Brian Norris: "Summary: - Add device tree support for DoC3 - SPI NOR: Refactoring, for better layering between spi-nor.c and its driver users (e.g., m25p80.c) New flash device support Support 6-byte ID strings - NAND: New NAND driver for Allwinner SoC's (sunxi) GPMI NAND: add support for raw (no ECC) access, for testing purposes Add ATO manufacturer ID A few odd driver fixes - MTD tests: Allow testers to compensate for OOB bitflips in oobtest Fix a torturetest regression - nandsim: Support longer ID byte strings And more" * tag 'for-linus-20141215' of git://git.infradead.org/linux-mtd: (63 commits) mtd: tests: abort torturetest on erase errors mtd: physmap_of: fix potential NULL dereference mtd: spi-nor: allow NULL as chip name and try to auto detect it mtd: nand: gpmi: add raw oob access functions mtd: nand: gpmi: add proper raw access support mtd: nand: gpmi: add gpmi_copy_bits function mtd: spi-nor: factor out write_enable() for erase commands mtd: spi-nor: add support for s25fl128s mtd: spi-nor: remove the jedec_id/ext_id mtd: spi-nor: add id/id_len for flash_info{} mtd: nand: correct the comment of function nand_block_isreserved() jffs2: Drop bogus if in comment mtd: atmel_nand: replace memcpy32_toio/memcpy32_fromio with memcpy mtd: cafe_nand: drop duplicate .write_page implementation mtd: m25p80: Add support for serial flash Spansion S25FL132K MTD: m25p80: fix inconsistency in m25p_ids compared to spi_nor_ids mtd: spi-nor: improve wait-till-ready timeout loop mtd: delete unnecessary checks before two function calls mtd: nand: omap: Fix NAND enumeration on 3430 LDP mtd: nand: add ATO manufacturer info ...
2014-12-16[media] DocBook media: update version number and document changesHans Verkuil
Update the version to 3.19. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-12-16[media] vivid.txt: document new controlsHans Verkuil
Document the new 'Y'CbCr Encoding' and 'Quantization' controls. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-12-16[media] DocBook media: add missing ycbcr_enc and quantization fieldsHans Verkuil
I forgot to add these fields to the relevant structs. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2014-12-16Merge tag 'trace-3.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "As the merge window is still open, and this code was not as complex as I thought it might be. I'm pushing this in now. This will allow Thomas to debug his irq work for 3.20. This adds two new features: 1) Allow traceopoints to be enabled right after mm_init(). By passing in the trace_event= kernel command line parameter, tracepoints can be enabled at boot up. For debugging things like the initialization of interrupts, it is needed to have tracepoints enabled very early. People have asked about this before and this has been on my todo list. As it can be helpful for Thomas to debug his upcoming 3.20 IRQ work, I'm pushing this now. This way he can add tracepoints into the IRQ set up and have users enable them when things go wrong. 2) Have the tracepoints printed via printk() (the console) when they are triggered. If the irq code locks up or reboots the box, having the tracepoint output go into the kernel ring buffer is useless for debugging. But being able to add the tp_printk kernel command line option along with the trace_event= option will have these tracepoints printed as they occur, and that can be really useful for debugging early lock up or reboot problems. This code is not that intrusive and it passed all my tests. Thomas tried them out too and it works for his needs. Link: http://lkml.kernel.org/r/20141214201609.126831471@goodmis.org" * tag 'trace-3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Add tp_printk cmdline to have tracepoints go to printk() tracing: Move enabling tracepoints to just after rcu_init()
2014-12-15Input: stmpe - enforce device tree only modeLinus Walleij
The STMPE keypad controller is only used with device tree configured systems, so force the configuration to come from device tree only, and now actually get the rows and cols from the device tree too. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-12-15Input: gpio_keys - allow separating gpio and irq in device treeDmitry Torokhov
This change allows specify interrupt for buttons separately form gpio, potentially allowing to form several "clusters" of buttons on different interrupts. Button defined without both gpio and irq in device tree is a hared error instead of a warning now. Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-12-15Merge branch 'next' into for-linusDmitry Torokhov
Prepare input updates for 3.19.
2014-12-15Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu: "We got some cleanup and driver for LP8860 as well as some patches for LED Flash Class" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: lp8860: Fix module dependency leds: lp8860: Introduce TI lp8860 4 channel LED driver leds: Add support for setting brightness in a synchronous way leds: implement sysfs interface locking mechanism leds: syscon: handle multiple syscon instances leds: delete copy/paste mistake leds: regulator: Convert to devm_regulator_get_exclusive
2014-12-15Merge tag 'staging-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver updates from Greg KH: "Here's the big staging tree pull request for 3.19-rc1. We continued to delete more lines than were added, always a good thing, but not at a huge rate this release, only about 70k lines removed overall mostly from removing the horrid bcm driver. Lots of normal staging driver cleanups and fixes all over the place, well over a thousand of them, the shortlog shows all the horrid details. The "contentious" thing here is the movement of the Android binder code out of staging into the "real" part of the kernel. This is code that has been stable for a few years now and is working as-is in the tens of millions of devices with no issues. Yes, the code is horrid, and the userspace api leaves a lot to be desired, but it's not going to change due to legacy issues that we have no control over. Because so many devices and companies rely on this, and the code is stable, might as well promote it out of staging. This was all discussed at the Linux Plumbers conference, and everyone participating agreed that this was the best way forward. There is work happening to replace the binder code with something new that is happening right now, but I don't expect to see the results of that work for another year at the earliest. If that ever happens, and Android switches over to it, I'll gladly remove this version. As for maintainers, I'll be glad to maintain this code, I've been doing it for the past few years with no problems. I'll send a MAINTAINERS entry for it before 3.19-final is out, still need to talk to the Google developers about if they are willing to help with it or not, last I checked they were, which was good. All of these patches have been in linux-next for a while with no reported issues" * tag 'staging-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1382 commits) Staging: slicoss: Fix long line issues in slicoss.c staging: rtl8712: remove unnecessary else after return staging: comedi: change some printk calls to pr_err staging: rtl8723au: hal: Removed the extra semicolon lustre: Deletion of unnecessary checks before three function calls staging: lustre: fix sparse warnings: static function declaration staging: lustre: fixed sparse warnings related to static declarations staging: unisys: remove duplicate header staging: unisys: remove unneeded structure staging: ft1000 : replace __attribute ((__packed__) with __packed drivers: staging: rtl8192e: Include "asm/unaligned.h" instead of "access_ok.h" in "rtl819x_BAProc.c" Drivers:staging:rtl8192e: Fixed checkpatch warning Drivers:staging:clocking-wizard: Added a newline staging: clocking-wizard: check for a valid clk_name pointer staging: rtl8723au: Hal_InitPGData() avoid unnecessary typecasts staging: rtl8723au: _DisableAnalog(): Avoid zero-init variables unnecessarily staging: rtl8723au: Remove unnecessary wrapper _ResetDigitalProcedure1() staging: rtl8723au: _ResetDigitalProcedure1_92C() reduce code obfuscation staging: rtl8723au: Remove unnecessary wrapper _DisableRFAFEAndResetBB() staging: rtl8723au: _DisableRFAFEAndResetBB8192C(): Reduce code obfuscation ...
2014-12-15Merge tag 'for-v3.19' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply updates from Sebastian Reichel:: "Power supply and reset changes for the v3.19 series - update power/reset drivers to use kernel restart handler - add power off driver for i.mx6 - add DT support for gpio-charger" * tag 'for-v3.19' of git://git.infradead.org/battery-2.6: power: reset: adjust priority of simple syscon reboot driver power: ds2782_battery: Simplify the PM hooks power/reset: brcmstb: Register with kernel restart handler power/reset: hisi: Register with kernel restart handler power/reset: keystone: Register with kernel restart handler power/reset: axxia: Register with kernel restart handler power/reset: xgene: Register with kernel restart handler power/reset: xgene: Use mdelay instead of jiffies based timeout power/reset: xgene: Use local variable dev instead of pdev->dev power/reset: xgene: Drop devm_kfree power/reset: xgene: Return -ENOMEM if out of memory power/reset: vexpress: Register with kernel restart handler power: reset: imx-snvs-poweroff: add power off driver for i.mx6 power: gpio-charger: add device tree support dt-bindings: document gpio-charger bindings
2014-12-15Merge branch 'irq-irqdomain-arm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq domain ARM updates from Thomas Gleixner: "This set of changes make use of hierarchical irqdomains to provide: - MSI/ITS support for GICv3 - MSI support for GICv2m - Interrupt polarity extender for GICv1 Marc has come more cleanups for the existing extension hooks of GIC in the pipeline, but they are going to be 3.20 material" * 'irq-irqdomain-arm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits) irqchip: gicv3-its: Fix ITT allocation irqchip: gicv3-its: Move some alloc/free code to activate/deactivate irqchip: gicv3-its: Fix domain free in multi-MSI case irqchip: gic: Remove warning by including linux/irqdomain.h irqchip: gic-v2m: Add DT bindings for GICv2m irqchip: gic-v2m: Add support for ARM GICv2m MSI(-X) doorbell irqchip: mtk-sysirq: dt-bindings: Add bindings for mediatek sysirq irqchip: mtk-sysirq: Add sysirq interrupt polarity support irqchip: gic: Support hierarchy irq domain. irqchip: GICv3: Binding updates for ITS irqchip: GICv3: ITS: enable compilation of the ITS driver irqchip: GICv3: ITS: plug ITS init into main GICv3 code irqchip: GICv3: ITS: DT probing and initialization irqchip: GICv3: ITS: MSI support irqchip: GICv3: ITS: device allocation and configuration irqchip: GICv3: ITS: tables allocators irqchip: GICv3: ITS: LPI allocator irqchip: GICv3: ITS: irqchip implementation irqchip: GICv3: ITS command queue irqchip: GICv3: rework redistributor structure ...
2014-12-15Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: - AMD KFD driver merge This is the AMD HSA interface for exposing a lowlevel interface for GPGPU use. They have an open source userspace built on top of this interface, and the code looks as good as it was going to get out of tree. - Initial atomic modesetting work The need for an atomic modesetting interface to allow userspace to try and send a complete set of modesetting state to the driver has arisen, and been suffering from neglect this past year. No more, the start of the common code and changes for msm driver to use it are in this tree. Ongoing work to get the userspace ioctl finished and the code clean will probably wait until next kernel. - DisplayID 1.3 and tiled monitor exposed to userspace. Tiled monitor property is now exposed for userspace to make use of. - Rockchip drm driver merged. - imx gpu driver moved out of staging Other stuff: - core: panel - MIPI DSI + new panels. expose suggested x/y properties for virtual GPUs - i915: Initial Skylake (SKL) support gen3/4 reset work start of dri1/ums removal infoframe tracking fixes for lots of things. - nouveau: tegra k1 voltage support GM204 modesetting support GT21x memory reclocking work - radeon: CI dpm fixes GPUVM improvements Initial DPM fan control - rcar-du: HDMI support added removed some support for old boards slave encoder driver for Analog Devices adv7511 - exynos: Exynos4415 SoC support - msm: a4xx gpu support atomic helper conversion - tegra: iommu support universal plane support ganged-mode DSI support - sti: HDMI i2c improvements - vmwgfx: some late fixes. - qxl: use suggested x/y properties" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (969 commits) drm: sti: fix module compilation issue drm/i915: save/restore GMBUS freq across suspend/resume on gen4 drm: sti: correctly cleanup CRTC and planes drm: sti: add HQVDP plane drm: sti: add cursor plane drm: sti: enable auxiliary CRTC drm: sti: fix delay in VTG programming drm: sti: prepare sti_tvout to support auxiliary crtc drm: sti: use drm_crtc_vblank_{on/off} instead of drm_vblank_{on/off} drm: sti: fix hdmi avi infoframe drm: sti: remove event lock while disabling vblank drm: sti: simplify gdp code drm: sti: clear all mixer control drm: sti: remove gpio for HDMI hot plug detection drm: sti: allow to change hdmi ddc i2c adapter drm/doc: Document drm_add_modes_noedid() usage drm/i915: Remove '& 0xffff' from the mask given to WA_REG() drm/i915: Invert the mask and val arguments in wa_add() and WA_REG() drm: Zero out DRM object memory upon cleanup drm/i915/bdw: Fix the write setting up the WIZ hashing mode ...
2014-12-15fib_trie.txt: fix typoDuan Jiong
Fix the typo, there should be "It". On the other hand, fix whitespace errors detected by checkpatch.pl Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-15tracing: Add tp_printk cmdline to have tracepoints go to printk()Steven Rostedt (Red Hat)
Add the kernel command line tp_printk option that will have tracepoints that are active sent to printk() as well as to the trace buffer. Passing "tp_printk" will activate this. To turn it off, the sysctl /proc/sys/kernel/tracepoint_printk can have '0' echoed into it. Note, this only works if the cmdline option is used. Echoing 1 into the sysctl file without the cmdline option will have no affect. Note, this is a dangerous option. Having high frequency tracepoints send their data to printk() can possibly cause a live lock. This is another reason why this is only active if the command line option is used. Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1412121539300.16494@nanos Suggested-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-12-15x86, mpx: Give MPX a real config option promptDave Hansen
Give MPX a real config option. The CPUs that support it (referenced here): https://software.intel.com/en-us/forums/topic/402393 are not available publicly yet. Right now only the software emulator provides MPX for the general public. [ tglx: Make it default off. There is no point in having it on right now as no hardware and no proper tooling support are available ] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dave Hansen <dave@sr71.net> Link: http://lkml.kernel.org/r/20141212183836.2569D58D@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-12-15x86, mpx: Update documentationDave Hansen
I was writing some MPX test programs and realized that the current design makes it tricky. I did something like: bndcfgu |= bnd_dir | BNDCFGU_ENABLE; xrstor(); printf("xrstor done"); // #BR bounds exception here prctl(MPX_ENABLE_MANAGEMENT); and then compiled the app with "-fcheck-pointer-bounds -mmpx" to enable MPX instrumentation. The problem is that there is MPX instrumentation inserted in to the area of the printf(). The kernel gets a bounds exception and since management isn't yet enabled, it SIGSEGV's. Add a bit to the documentation to explain a way around this and where apps need to be careful. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dave Hansen <dave@sr71.net> Link: http://lkml.kernel.org/r/20141212183835.8C581B3E@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-12-15Merge tag 'kvm-arm-for-3.19-take2' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD Second round of changes for KVM for arm/arm64 for v3.19; fixes reboot problems, clarifies VCPU init, and fixes a regression concerning the VGIC init flow. Conflicts: arch/ia64/kvm/kvm-ia64.c [deleted in HEAD and modified in kvmarm]
2014-12-14Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security layer updates from James Morris: "In terms of changes, there's general maintenance to the Smack, SELinux, and integrity code. The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT, which allows IMA appraisal to require signatures. Support for reading keys from rootfs before init is call is also added" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits) selinux: Remove security_ops extern security: smack: fix out-of-bounds access in smk_parse_smack() VFS: refactor vfs_read() ima: require signature based appraisal integrity: provide a hook to load keys when rootfs is ready ima: load x509 certificate from the kernel integrity: provide a function to load x509 certificate from the kernel integrity: define a new function integrity_read_file() Security: smack: replace kzalloc with kmem_cache for inode_smack Smack: Lock mode for the floor and hat labels ima: added support for new kernel cmdline parameter ima_template_fmt ima: allocate field pointers array on demand in template_desc_init_fields() ima: don't allocate a copy of template_fmt in template_desc_init_fields() ima: display template format in meas. list if template name length is zero ima: added error messages to template-related functions ima: use atomic bit operations to protect policy update interface ima: ignore empty and with whitespaces policy lines ima: no need to allocate entry for comment ima: report policy load status ima: use path names cache ...
2014-12-14Merge tag 'char-misc-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver update for 3.19-rc1 Lots of little things all over the place in different drivers, and a new subsystem, "coresight" has been added. Full details are in the shortlog" * tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits) parport: parport_pc, do not remove parent devices early spmi: Remove shutdown/suspend/resume kernel-doc carma-fpga-program: drop videobuf dependency carma-fpga: drop videobuf dependency carma-fpga-program.c: fix compile errors i8k: Fix temperature bug handling in i8k_get_temp() cxl: Name interrupts in /proc/interrupt CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning coresight-replicator: remove .owner field for driver coresight: fixed comments in coresight.h coresight: fix typo in comment in coresight-priv.h coresight: bindings for coresight drivers coresight: Adding ABI documentation w1: support auto-load of w1_bq27000 module. w1: avoid potential u16 overflow cn: verify msg->len before making callback mei: export fw status registers through sysfs mei: read and print all six FW status registers mei: txe: add cherrytrail device id mei: kill cached host and me csr values ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-14Merge tag 'tty-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the big tty/serial driver update for 3.19-rc1. There are a number of TTY core changes/fixes in here from Peter Hurley that have all been teted in linux-next for a long time now. There are also the normal serial driver updates as well, full details in the changelog below" * tag 'tty-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (219 commits) serial: pxa: hold port.lock when reporting modem line changes tty-hvsi_lib: Deletion of an unnecessary check before the function call "tty_kref_put" tty: Deletion of unnecessary checks before two function calls n_tty: Fix read_buf race condition, increment read_head after pushing data serial: of-serial: add PM suspend/resume support Revert "serial: of-serial: add PM suspend/resume support" Revert "serial: of-serial: fix up PM ops on no_console_suspend and port type" serial: 8250: don't attempt a trylock if in sysrq serial: core: Add big-endian iotype serial: samsung: use port->fifosize instead of hardcoded values serial: samsung: prefer to use fifosize from driver data serial: samsung: fix style problems serial: samsung: wait for transfer completion before clock disable serial: icom: fix error return code serial: tegra: clean up tty-flag assignments serial: Fix io address assign flow with Fintek PCI-to-UART Product serial: mxs-auart: fix tx_empty against shift register serial: mxs-auart: fix gpio change detection on interrupt serial: mxs-auart: Fix mxs_auart_set_ldisc() serial: 8250_dw: Use 64-bit access for OCTEON. ...
2014-12-14Merge tag 'usb-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big set of USB and PHY patches for 3.19-rc1. The normal churn in the USB gadget area is in here, as well as xhci and other individual USB driver updates. The PHY tree is also in here, as there were dependancies on the USB tree. All of these have been in linux-next" * tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits) arm: omap3: twl: remove usb phy init data usbip: fix error handling in stub_probe() usb: gadget: udc: missing curly braces USB: mos7720: delete some unneeded code wusb: replace memset by memzero_explicit usbip: remove unneeded structure usb: xhci: fix comment for PORT_DEV_REMOVE xhci: don't use the same variable for stopped and halted rings current TD xhci: clear extra bits from slot context when setting max exit latency xhci: cleanup finish_td function USB: adutux: NULL dereferences on disconnect usb: chipidea: fix platform_no_drv_owner.cocci warnings usb: chipidea: Fixed a few typos in comments Documentation: bindings: add doc for the USB2 ChipIdea USB driver usb: chipidea: add a usb2 driver for ci13xxx usb: chipidea: fix phy handling usb: chipidea: remove duplicate dev_set_drvdata for host_start usb: chipidea: parameter 'mode' isn't needed for hw_device_reset usb: chipidea: add controller reset API usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER ...
2014-12-14Merge tag 'squashfs-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next Pull squashfs update from Phillip Lougher: "These patches optionally add LZ4 compression support to Squashfs. LZ4 is a lightweight compression algorithm which can be used on embedded systems to reduce CPU and memory overhead (in comparison to the standard zlib compression). These patches add the wrapper code to allow Squashfs to use the existing LZ4 decompression code, and the necessary configuration option" * tag 'squashfs-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next: Squashfs: Add LZ4 compression configuration option Squashfs: add LZ4 compression support
2014-12-14Merge tag 'gpio-v3.19-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull take two of the GPIO updates: "Same stuff as last time, now with a fixup patch for the previous compile error plus I ran a few extra rounds of compile-testing. This is the bulk of GPIO changes for the v3.19 series: - A new API that allows setting more than one GPIO at the time. This is implemented for the new descriptor-based API only and makes it possible to e.g. toggle a clock and data line at the same time, if the hardware can do this with a single register write. Both consumers and drivers need new calls, and the core will fall back to driving individual lines where needed. Implemented for the MPC8xxx driver initially - Patched the mdio-mux-gpio and the serial mctrl driver that drives modems to use the new multiple-setting API to set several signals simultaneously - Get rid of the global GPIO descriptor array, and instead allocate descriptors dynamically for each GPIO on a certain GPIO chip. This moves us closer to getting rid of the limitation of using the global, static GPIO numberspace - New driver and device tree bindings for 74xx ICs - New driver and device tree bindings for the VF610 Vybrid - Support the RCAR r8a7793 and r8a7794 - Guidelines for GPIO device tree bindings trying to get things a bit more strict with the advent of combined device properties - Suspend/resume support for the MVEBU driver - A slew of minor fixes and improvements" * tag 'gpio-v3.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (33 commits) gpio: mcp23s08: fix up compilation error gpio: pl061: document gpio-ranges property for bindings file gpio: pl061: hook request if gpio-ranges avaiable gpio: mcp23s08: Add option to configure IRQ output polarity as active high gpio: fix deferred probe detection for legacy API serial: mctrl_gpio: use gpiod_set_array function mdio-mux-gpio: Use GPIO descriptor interface and new gpiod_set_array function gpio: remove const modifier from gpiod_get_direction() gpio: remove gpio_descs global array gpio: mxs: implement get_direction callback gpio: em: Use dynamic allocation of GPIOs gpio: Check if base is positive before calling gpio_is_valid() gpio: mcp23s08: Add simple IRQ support for SPI devices gpio: mcp23s08: request a shared interrupt gpio: mcp23s08: Do not free unrequested interrupt gpio: rcar: Add r8a7793 and r8a7794 support gpio-mpc8xxx: add mpc8xxx_gpio_set_multiple function gpiolib: allow simultaneous setting of multiple GPIO outputs gpio: mvebu: add suspend/resume support gpio: gpio-davinci: remove duplicate check on resource ..
2014-12-14Merge branch 'i2c/for-3.19' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "For 3.19, the I2C subsystem has to offer special candy this time. Right in time for Christmas :) - I2C slave framework: finally, a generic mechanism for Linux being an I2C slave (if the bus driver supports that). Docs are still missing but will come later this cycle, the code is good enough to go. - I2C muxes represent their topology in sysfs much more detailed. This will help users to navigate around much easier. - irq population of i2c clients is now done at probe time, not device creation time, to have better support for deferred probing. - new drivers for Imagination SCB, Amlogic Meson - DMA support added for Freescale IMX, Renesas SHMobile - slightly bigger driver updates to OMAP, i801, AT91, and rk3x (mostly quirk handling, timing updates, and using better kernel interfaces) - eeprom driver can now write with byte-access (very slow, but OK to have) - and the bunch of smaller fixes, cleanups, ID updates..." * 'i2c/for-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (56 commits) i2c: sh_mobile: remove unneeded DMA mask i2c: rcar: add slave support i2c: slave-eeprom: add eeprom simulator driver i2c: core changes for slave support MAINTAINERS: add I2C dt bindings also to I2C realm i2c: designware: Fix falling time bindings doc i2c: davinci: switch to use platform_get_irq Documentation: i2c: Use PM ops instead of legacy suspend/resume i2c: sh_mobile: optimize irq entry i2c: pxa: add support for SCCB devices omap: i2c: don't check bus state IP rev3.3 and earlier i2c: s3c2410: Handle i2c sys_cfg register in i2c driver i2c: rk3x: add Kconfig dependency on COMMON_CLK i2c: omap: add notes related to i2c multimaster mode i2c: omap: don't reset controller if Arbitration Lost detected i2c: omap: implement workaround for handling invalid BB-bit values i2c: omap: cleanup register definitions i2c: rk3x: handle dynamic clock rate changes correctly i2c: at91: enable probe deferring on dma channel request i2c: at91: remove legacy DMA support ...
2014-12-14Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes (mainly Andy's TLS fixes), plus a cleanup" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/tls: Disallow unusual TLS segments x86/tls: Validate TLS entries to protect espfix MAINTAINERS: Add me as x86 VDSO submaintainer x86/asm: Unify segment selector defines x86/asm: Guard against building the 32/64-bit versions of the asm-offsets*.c file directly x86_64, switch_to(): Load TLS descriptors before switching DS and ES x86/mm: Use min() instead of min_t() in the e820 printout code x86/mm: Fix zone ranges boot printout x86/doc: Update documentation after file shuffling
2014-12-14i2c: Driver to expose PowerNV platform i2c bussesNeelesh Gupta
The patch exposes the available i2c busses on the PowerNV platform to the kernel and implements the bus driver to support i2c and smbus commands. The driver uses the platform device infrastructure to probe the busses on the platform and registers them with the i2c driver framework. Signed-off-by: Neelesh Gupta <neelegup@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Wolfram Sang <wsa@the-dreams.de> (I2C part, excluding the bindings) Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-12-13Merge branch 'for-3.19/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver core update from Jens Axboe: "This is the pull request for the core block IO changes for 3.19. Not a huge round this time, mostly lots of little good fixes: - Fix a bug in sysfs blktrace interface causing a NULL pointer dereference, when enabled/disabled through that API. From Arianna Avanzini. - Various updates/fixes/improvements for blk-mq: - A set of updates from Bart, mostly fixing buts in the tag handling. - Cleanup/code consolidation from Christoph. - Extend queue_rq API to be able to handle batching issues of IO requests. NVMe will utilize this shortly. From me. - A few tag and request handling updates from me. - Cleanup of the preempt handling for running queues from Paolo. - Prevent running of unmapped hardware queues from Ming Lei. - Move the kdump memory limiting check to be in the correct location, from Shaohua. - Initialize all software queues at init time from Takashi. This prevents a kobject warning when CPUs are brought online that weren't online when a queue was registered. - Single writeback fix for I_DIRTY clearing from Tejun. Queued with the core IO changes, since it's just a single fix. - Version X of the __bio_add_page() segment addition retry from Maurizio. Hope the Xth time is the charm. - Documentation fixup for IO scheduler merging from Jan. - Introduce (and use) generic IO stat accounting helpers for non-rq drivers, from Gu Zheng. - Kill off artificial limiting of max sectors in a request from Christoph" * 'for-3.19/core' of git://git.kernel.dk/linux-block: (26 commits) bio: modify __bio_add_page() to accept pages that don't start a new segment blk-mq: Fix uninitialized kobject at CPU hotplugging blktrace: don't let the sysfs interface remove trace from running list blk-mq: Use all available hardware queues blk-mq: Micro-optimize bt_get() blk-mq: Fix a race between bt_clear_tag() and bt_get() blk-mq: Avoid that __bt_get_word() wraps multiple times blk-mq: Fix a use-after-free blk-mq: prevent unmapped hw queue from being scheduled blk-mq: re-check for available tags after running the hardware queue blk-mq: fix hang in bt_get() blk-mq: move the kdump check to blk_mq_alloc_tag_set blk-mq: cleanup tag free handling blk-mq: use 'nr_cpu_ids' as highest CPU ID count for hwq <-> cpu map blk: introduce generic io stat accounting help function blk-mq: handle the single queue case in blk_mq_hctx_next_cpu genhd: check for int overflow in disk_expand_part_tbl() blk-mq: add blk_mq_free_hctx_request() blk-mq: export blk_mq_free_request() blk-mq: use get_cpu/put_cpu instead of preempt_disable/preempt_enable ...
