path: root/Documentation
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (82 commits) firewire: core: add forgotten dummy driver methods, remove unused ones firewire: add isochronous multichannel reception firewire: core: small clarifications in core-cdev firewire: core: remove unused code firewire: ohci: release channel in error path firewire: ohci: use memory barriers to order descriptor updates tools/firewire: nosy-dump: increment program version tools/firewire: nosy-dump: remove unused code tools/firewire: nosy-dump: use linux/firewire-constants.h tools/firewire: nosy-dump: break up a deeply nested function tools/firewire: nosy-dump: make some symbols static or const tools/firewire: nosy-dump: change to kernel coding style tools/firewire: nosy-dump: work around segfault in decode_fcp tools/firewire: nosy-dump: fix it on x86-64 tools/firewire: add userspace front-end of nosy firewire: nosy: note ioctls in ioctl-number.txt firewire: nosy: use generic printk macros firewire: nosy: endianess fixes and annotations firewire: nosy: annotate __user pointers and __iomem pointers firewire: nosy: fix device shutdown with active client ...
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (45 commits) nilfs2: reject filesystem with unsupported block size nilfs2: avoid rec_len overflow with 64KB block size nilfs2: simplify nilfs_get_page function nilfs2: reject incompatible filesystem nilfs2: add feature set fields to super block nilfs2: clarify byte offset in super block format nilfs2: apply read-ahead for nilfs_btree_lookup_contig nilfs2: introduce check flag to btree node buffer nilfs2: add btree get block function with readahead option nilfs2: add read ahead mode to nilfs_btnode_submit_block nilfs2: fix buffer head leak in nilfs_btnode_submit_block nilfs2: eliminate inline keywords in btree implementation nilfs2: get maximum number of child nodes from bmap object nilfs2: reduce repetitive calculation of max number of child nodes nilfs2: optimize calculation of min/max number of btree node children nilfs2: remove redundant pointer checks in bmap lookup functions nilfs2: get rid of nilfs_bmap_union nilfs2: unify bmap set_target_v operations nilfs2: get rid of nilfs_btree uses nilfs2: get rid of nilfs_direct uses ...
2010-08-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [DNS RESOLVER] Minor typo correction DNS: Fixes for the DNS query module cifs: Include linux/err.h for IS_ERR and PTR_ERR DNS: Make AFS go to the DNS for AFSDB records for unknown cells DNS: Separate out CIFS DNS Resolver code cifs: account for new creduid=0x%x parameter in spnego upcall string cifs: reduce false positives with inode aliasing serverino autodisable CIFS: Make cifs_convert_address() take a const src pointer and a length cifs: show features compiled in as part of DebugData cifs: update README Fix up trivial conflicts in fs/cifs/cifsfs.c due to workqueue changes
2010-08-07Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits) workqueue: mark init_workqueues() as early_initcall() workqueue: explain for_each_*cwq_cpu() iterators fscache: fix build on !CONFIG_SYSCTL slow-work: kill it gfs2: use workqueue instead of slow-work drm: use workqueue instead of slow-work cifs: use workqueue instead of slow-work fscache: drop references to slow-work fscache: convert operation to use workqueue instead of slow-work fscache: convert object to use workqueue instead of slow-work workqueue: fix how cpu number is stored in work->data workqueue: fix mayday_mask handling on UP workqueue: fix build problem on !CONFIG_SMP workqueue: fix locking in retry path of maybe_create_worker() async: use workqueue for worker pool workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead workqueue: implement unbound workqueue workqueue: prepare for WQ_UNBOUND implementation libata: take advantage of cmwq and remove concurrency limitations workqueue: fix worker management invocation without pending works ... Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
2010-08-06Merge branch 'x86-olpc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-olpc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc: Constify an olpc_ofw() arg x86, olpc: Use pr_debug() for EC commands x86, olpc: Add comment about implicit optimization barrier x86, olpc: Add support for calling into OpenFirmware
2010-08-06Merge branch 'timers-timekeeping-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: um: Fix read_persistent_clock fallout kgdb: Do not access xtime directly powerpc: Clean up obsolete code relating to decrementer and timebase powerpc: Rework VDSO gettimeofday to prevent time going backwards clocksource: Add __clocksource_updatefreq_hz/khz methods x86: Convert common clocksources to use clocksource_register_hz/khz timekeeping: Make xtime and wall_to_monotonic static hrtimer: Cleanup direct access to wall_to_monotonic um: Convert to use read_persistent_clock timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset powerpc: Cleanup xtime usage powerpc: Simplify update_vsyscall time: Kill off CONFIG_GENERIC_TIME time: Implement timespec_add x86: Fix vtime/file timestamp inconsistencies Trivial conflicts in Documentation/feature-removal-schedule.txt Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as per Thomas' earlier merge commit 47916be4e28c ("Merge branch 'powerpc.cherry-picks' into timers/clocksource")
2010-08-06Merge branch 'timers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: Documentation: Add timers/timers-howto.txt timer: Added usleep_range timer Revert "timer: Added usleep[_range] timer" clockevents: Remove the per cpu tick skew posix_timer: Move copy_to_user(created_timer_id) down in timer_create() timer: Added usleep[_range] timer timers: Document meaning of deferrable timer
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq pcmcia: do not request windows if you don't need to pcmcia: insert PCMCIA device resources into resource tree pcmcia: export resource information to sysfs pcmcia: use struct resource for PCMCIA devices, part 2 pcmcia: remove memreq_t pcmcia: move local definitions out of include/pcmcia/cs.h pcmcia: do not use io_req_t when calling pcmcia_request_io() pcmcia: do not use io_req_t after call to pcmcia_request_io() pcmcia: use struct resource for PCMCIA devices pcmcia: clean up cs.h pcmcia: use pcmica_{read,write}_config_byte pcmcia: remove cs_types.h pcmcia: remove unused flag, simplify headers pcmcia: remove obsolete CS_EVENT_ definitions pcmcia: split up central event handler pcmcia: simplify event callback pcmcia: remove obsolete ioctl Conflicts in: - drivers/staging/comedi/drivers/* - drivers/staging/wlags49_h2/wl_cs.c due to dev_info_t and whitespace changes
2010-08-06Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (30 commits) PCI: update for owner removal from struct device_attribute PCI: Fix warnings when CONFIG_DMI unset PCI: Do not run NVidia quirks related to MSI with MSI disabled x86/PCI: use for_each_pci_dev() PCI: use for_each_pci_dev() PCI: MSI: Restore read_msi_msg_desc(); add get_cached_msi_msg_desc() PCI: export SMBIOS provided firmware instance and label to sysfs PCI: Allow read/write access to sysfs I/O port resources x86/PCI: use host bridge _CRS info on ASRock ALiveSATA2-GLAN PCI: remove unused HAVE_ARCH_PCI_SET_DMA_MAX_SEGMENT_{SIZE|BOUNDARY} PCI: disable mmio during bar sizing PCI: MSI: Remove unsafe and unnecessary hardware access PCI: Default PCIe ASPM control to on and require !EMBEDDED to disable PCI: kernel oops on access to pci proc file while hot-removal PCI: pci-sysfs: remove casts from void* ACPI: Disable ASPM if the platform won't provide _OSC control for PCIe PCI hotplug: make sure child bridges are enabled at hotplug time PCI hotplug: shpchp: Removed check for hotplug of display devices PCI hotplug: pciehp: Fixed return value sign for pciehp_unconfigure_device PCI: Don't enable aspm before drivers have had a chance to veto it ...
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (28 commits) driver core: device_rename's new_name can be const sysfs: Remove owner field from sysfs struct attribute powerpc/pci: Remove owner field from attribute initialization in PCI bridge init regulator: Remove owner field from attribute initialization in regulator core driver leds: Remove owner field from attribute initialization in bd2802 driver scsi: Remove owner field from attribute initialization in ARCMSR driver scsi: Remove owner field from attribute initialization in LPFC driver cgroupfs: create /sys/fs/cgroup to mount cgroupfs on Driver core: Add BUS_NOTIFY_BIND_DRIVER driver core: fix memory leak on one error path in bus_register() debugfs: no longer needs to depend on SYSFS sysfs: Fix one more signature discrepancy between sysfs implementation and docs. sysfs: fix discrepancies between implementation and documentation dcdbas: remove a redundant smi_data_buf_free in dcdbas_exit dmi-id: fix a memory leak in dmi_id_init error path sysfs: sysfs_chmod_file's attr can be const firmware: Update hotplug script Driver core: move platform device creation helpers to .init.text (if MODULE=n) Driver core: reduce duplicated code for platform_device creation Driver core: use kmemdup in platform_device_add_resources ...
2010-08-06Merge branch 'x86-hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, hwmon: Package Level Thermal/Power: pkgtemp documentation x86, hwmon: Package Level Thermal/Power: power limit x86, hwmon: Package Level Thermal/Power: thermal throttling handler x86, hwmon: Package Level Thermal/Power: pkgtemp hwmon driver
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
2010-08-06DNS: Fixes for the DNS query moduleDavid Howells
Fixes for the DNS query module, including: (1) Use 'negative' instead of '-ve' in the documentation. (2) Mark the kdoc comment with '/**' on dns_query(). Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-05Merge branch 'kms-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'kms-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb,docs: Update the kgdb docs to include kms drm_fb_helper: Preserve capability to use atomic kms i915: when kgdb is active display compression should be off drm/i915: use new fb debug hooks drm: add KGDB/KDB support fb: add hooks to handle KDB enter/exit kgdboc: Add call backs to allow kernel mode switching vt,console,kdb: automatically set kdb LINES variable vt,console,kdb: implement atomic console enter/leave functions
2010-08-05Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: scripts/dtc: Fix a resource leak Documentation: fix ubuntu distro name MAINTAINERS: Update kbuild git URLs Add support for the C variable in the coccicheck script Add scripts/coccinelle/deref_null.cocci Add scripts/coccinelle/err_cast.cocci Add scripts/coccinelle/resource_size.cocci Add scripts/coccinelle/alloc/kzalloc-simple.cocci Add scripts/coccinelle/alloc/drop_kmalloc_cast.cocci Add Documentation/coccinelle.txt Add a target to use the Coccinelle checker scripts: decodecode: remove bashisms Makefile: clarify a comment checkkconfigsymbols.sh: Kconfig symbols sometimes have lowercase letters scripts: add nconf into gitignore file
2010-08-05Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (26 commits) kconfig: add savedefconfig kconfig: code refactoring in confdata.c kconfig: refactor code in symbol.c kconfig: add alldefconfig kconfig: print more info when we see a recursive dependency kconfig: save location of config symbols kconfig: change nonint_oldconfig to listnewconfig kconfig: rename loose_nonint_oldconfig => oldnoconfig kconfig: use long options in conf kconfig: fix MODULES-related bug in case of no .config kconfig: make randconfig fair for booleans kconfig: Don't write invisible choice values kbuild: Warn on selecting symbols with unmet direct dependencies scripts:conf.c Fix warning: variable 'type' set but not used menuconfig: truncate list items menuconfig: fix to center checklist correctly in a corner case xconfig: add support to show hidden options which have prompts xconfig: remove unused function xconfig: clean up gconfig: fix null pointer warning ...
2010-08-05Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: modpost: support objects with more than 64k sections trivial: fix a typo in a filename frv: clean up arch/frv/Makefile kbuild: allow assignment to {A,C}FLAGS_KERNEL on the command line kbuild: allow assignment to {A,C,LD}FLAGS_MODULE on the command line Kbuild: Add option to set -femit-struct-debug-baseonly Makefile: "make kernelrelease" should show the correct full kernel version Makefile.build: make KBUILD_SYMTYPES work again
2010-08-05sysfs: Fix one more signature discrepancy between sysfs implementation and docs.Ira Weiny
Signed-off-by: Ira Weiny <weiny2@llnl.gov> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05sysfs: fix discrepancies between implementation and documentationBart Van Assche
Fix all discrepancies I know of between the sysfs implementation and its documentation. Signed-off-by: Bart Van Assche <bart.vanassche@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05firmware: Update hotplug scriptMagnus Damm
Update the in-kernel hotplug example script to work properly with recent kernels. Without this fix the script may load the firmware twice - both at "add" and "remove" time. The second load only triggers in the case when multiple firmware images are used. A good example is the b43 driver which does not work properly without this fix. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05Driver core: reduce duplicated code for platform_device creationUwe Kleine-König
This makes the two similar functions platform_device_register_simple and platform_device_register_data one line inline functions using a new generic function platform_device_register_resndata. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-05Merge branch 'upstream/xen' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen * 'upstream/xen' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen: (23 commits) xen/panic: use xen_reboot and fix smp_send_stop Xen: register panic notifier to take crashes of xen guests on panic xen: support large numbers of CPUs with vcpu info placement xen: drop xen_sched_clock in favour of using plain wallclock time pvops: do not notify callers from register_xenstore_notifier Introduce CONFIG_XEN_PVHVM compile option blkfront: do not create a PV cdrom device if xen_hvm_guest support multiple .discard.* sections to avoid section type conflicts xen/pvhvm: fix build problem when !CONFIG_XEN xenfs: enable for HVM domains too x86: Call HVMOP_pagetable_dying on exit_mmap. x86: Unplug emulated disks and nics. x86: Use xen_vcpuop_clockevent, xen_clocksource and xen wallclock. implement O_NONBLOCK for /proc/xen/xenbus xen: Fix find_unbound_irq in presence of ioapic irqs. xen: Add suspend/resume support for PV on HVM guests. xen: Xen PCI platform device driver. x86/xen: event channels delivery on HVM. x86: early PV on HVM features initialization. xen: Add support for HVM hypercalls. ...
2010-08-05docbook: use IDs as filenames to support multiple booksJohannes Berg
I'm trying to generate a <set> of <book>s in docbook for wireless to link together all the cfg80211 and mac80211 documentation. However, docbook will generate "re01.html" anew for each book for the first <refentry>, presumably due to a bug in the stylesheets. An effective workaround is to use IDs for the filenames, which makes them more descriptive as well, e.g. API-enum-ieee80211-band.html. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Documentation: fix kbuild typos and wordingNicolas Kaiser
Fixed some typos and wording. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Documentation: update kbuild make typos/grammar/text flowMatt Mooney
Update section 3.7 examples to reflect the current state of the Makefiles used. Fix spelling and grammar errors along with flow of text. Signed-off-by: matt mooney <mfm@muteddisk.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Documentation: update kbuild make examples#2 to reflect changesMatt Mooney
Update section 3.2 and 3.5 example, along with text in section 3.5 to reflect change. Signed-off-by: matt mooney <mfm@muteddisk.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Documentation: update kbuild loadable modules goals & examplesMatt Mooney
Update section 3.3 Loadable module goals - obj-m, from $(<module_name>-objs) to $(<module_name>-y) for easier addition of conditional objects to the module. The examples are also updated to reflect the current state of each Makefile used. Signed-off-by: matt mooney <mfm@muteddisk.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Documentation/vm: fix spelling in page-types.cTommi Rantala
Trivial typo fixes. Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05DNS: Separate out CIFS DNS Resolver codeWang Lei
Separate out the DNS resolver key type from the CIFS filesystem into its own module so that it can be made available for general use, including the AFS filesystem module. This facility makes it possible for the kernel to upcall to userspace to have it issue DNS requests, package up the replies and present them to the kernel in a useful form. The kernel is then able to cache the DNS replies as keys can be retained in keyrings. Resolver keys are of type "dns_resolver" and have a case-insensitive description that is of the form "[<type>:]<domain_name>". The optional <type> indicates the particular DNS lookup and packaging that's required. The <domain_name> is the query to be made. If <type> isn't given, a basic hostname to IP address lookup is made, and the result is stored in the key in the form of a printable string consisting of a comma-separated list of IPv4 and IPv6 addresses. This key type is supported by userspace helpers driven from /sbin/request-key and configured through /etc/request-key.conf. The cifs.upcall utility is invoked for UNC path server name to IP address resolution. The CIFS functionality is encapsulated by the dns_resolve_unc_to_ip() function, which is used to resolve a UNC path to an IP address for CIFS filesystem. This part remains in the CIFS module for now. See the added Documentation/networking/dns_resolver.txt for more information. Signed-off-by: Wang Lei <wang840925@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-05Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (79 commits) powerpc/8xx: Add support for the MPC8xx based boards from TQC powerpc/85xx: Introduce support for the Freescale P1022DS reference board powerpc/85xx: Adding DTS for the STx GP3-SSA MPC8555 board powerpc/85xx: Change deprecated binding for 85xx-based boards powerpc/tqm85xx: add a quirk for ti1520 PCMCIA bridge powerpc/tqm85xx: update PCI interrupt-map attribute powerpc/mpc8308rdb: support for MPC8308RDB board from Freescale powerpc/fsl_pci: add quirk for mpc8308 pcie bridge powerpc/85xx: Cleanup QE initialization for MPC85xxMDS boards powerpc/85xx: Fix booting for P1021MDS boards powerpc/85xx: Fix SWIOTLB initalization for MPC85xxMDS boards powerpc/85xx: kexec for SMP 85xx BookE systems powerpc/5200/i2c: improve i2c bus error recovery of/xilinxfb: update tft compatible versions powerpc/fsl-diu-fb: Support setting display mode using EDID powerpc/5121: doc/dts-bindings: update doc of FSL DIU bindings powerpc/5121: shared DIU framebuffer support powerpc/5121: move fsl-diu-fb.h to include/linux powerpc/5121: fsl-diu-fb: fix issue with re-enabling DIU area descriptor powerpc/512x: add clock structure for Video-IN (VIU) unit ...
2010-08-05Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (150 commits) MIPS: PowerTV: Separate PowerTV USB support from non-USB code MIPS: strip the un-needed sections of vmlinuz MIPS: Clean up the calculation of VMLINUZ_LOAD_ADDRESS MIPS: Clean up arch/mips/boot/compressed/decompress.c MIPS: Clean up arch/mips/boot/compressed/ld.script MIPS: Unify the suffix of compressed vmlinux.bin MIPS: PowerTV: Add Gaia platform definitions. MIPS: BCM47xx: Fix nvram_getenv return value. MIPS: Octeon: Allow more than 3.75GB of memory with PCIe MIPS: Clean up notify_die() usage. MIPS: Remove unused task_struct.trap_no field. Documentation: Mention that KProbes is supported on MIPS SAMPLES: kprobe_example: Make it print something on MIPS. MIPS: kprobe: Add support. MIPS: Add instrunction format for BREAK and SYSCALL MIPS: kprobes: Define regs_return_value() MIPS: Ritually kill stupid printk. MIPS: Octeon: Disallow MSI-X interrupt and fall back to MSI interrupts. MIPS: Octeon: Support 256 MSI on PCIe MIPS: Decode core number for R2 CPUs. ...
2010-08-05kgdb,docs: Update the kgdb docs to include kmsJason Wessel
Update the kgdb docs to include information about kernel mode setting support. [Randy Dunlap <rdunlap@xenotime.net>: grammatical corrections] CC: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-08-05nick piggin: change email addressNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-05Documentation: Mention that KProbes is supported on MIPSDavid Daney
MIPS now has KProbes support, so kprobes.txt should reflect it. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org To: ananth@in.ibm.com To: anil.s.keshavamurthy@intel.com To: davem@davemloft.net To: masami.hiramatsu.pt@hitachi.com Cc: linux-kernel@vger.kernel.org Cc: hschauhan@nulltrace.org Patchwork: https://patchwork.linux-mips.org/patch/1527/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05Merge branch 'topic/misc' into for-linusTakashi Iwai
2010-08-05Merge branch 'topic/hda' into for-linusTakashi Iwai
2010-08-05Merge branch 'perf/nmi' into perf/coreIngo Molnar
Conflicts: kernel/Makefile Merge reason: Add the now complete topic, fix the conflict. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (30 commits) Revert "HID: add support for the Wacom Intuos 4 wireless" HID: fix up Kconfig entry for ACRUX driver HID: add ACRUX game controller force feedback support HID: Force input registration for "VEC footpedal" HID: add HID_QUIRK_HIDINPUT_FORCE HID: hid-input.c: indentation fixes HID: hiddev: use usb_find_interface, get rid of BKL HID: ignore digitizer usage Undefined (0x00) HID: Add support for Conceptronic CLLRCMCE HID: hid-ids.h: Whitespace fixup, align using TABs HID: picolcd: implement refcounting of framebuffer HID: picolcd: do not reallocate memory on depth change HID: picolcd: Add minimal palette required by fbcon on 8bpp HID: magicmouse: Correct parsing of large X and Y motions. HID: magicmouse: report last touch up HID: picolcd: fix deferred_io init/cleanup to fb ordering HID: hid-ids.h: keep vendor ids in alphabetical order HID: add proper support for Elecom BM084 bluetooth mouse HID: magicmouse: enable horizontal scrolling HID: magicmouse: add param for scroll speed ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (39 commits) random: Reorder struct entropy_store to remove padding on 64bits padata: update API documentation padata: Remove padata_get_cpumask crypto: pcrypt - Update pcrypt cpumask according to the padata cpumask notifier crypto: pcrypt - Rename pcrypt_instance padata: Pass the padata cpumasks to the cpumask_change_notifier chain padata: Rearrange set_cpumask functions padata: Rename padata_alloc functions crypto: pcrypt - Dont calulate a callback cpu on empty callback cpumask padata: Check for valid cpumasks padata: Allocate cpumask dependend recources in any case padata: Fix cpu index counting crypto: geode_aes - Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used) pcrypt: Added sysfs interface to pcrypt padata: Added sysfs primitives to padata subsystem padata: Make two separate cpumasks padata: update documentation padata: simplify serialization mechanism padata: make padata_do_parallel to return zero on success padata: Handle empty padata cpumasks ...
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (276 commits) [SCSI] zfcp: Trigger logging in the FCP channel on qdio error conditions [SCSI] zfcp: Introduce experimental support for DIF/DIX [SCSI] zfcp: Enable data division support for FCP devices [SCSI] zfcp: Prevent access on uninitialized memory. [SCSI] zfcp: Post events through FC transport class [SCSI] zfcp: Cleanup QDIO attachment and improve processing. [SCSI] zfcp: Cleanup function parameters for sbal value. [SCSI] zfcp: Use correct width for timer_interval field [SCSI] zfcp: Remove SCSI device when removing unit [SCSI] zfcp: Use memdup_user and kstrdup [SCSI] zfcp: Fix retry after failed "open port" erp action [SCSI] zfcp: Fail erp after timeout [SCSI] zfcp: Use forced_reopen in terminate_rport_io callback [SCSI] zfcp: Register SCSI devices after successful fc_remote_port_add [SCSI] zfcp: Do not try "forced close" when port is already closed [SCSI] zfcp: Do not unblock rport from REOPEN_PORT_FORCED [SCSI] sd: add support for runtime PM [SCSI] implement runtime Power Management [SCSI] convert to the new PM framework [SCSI] Unify SAM_ and SAM_STAT_ macros ...
2010-08-04Merge branch 'upstream/pvhvm' into upstream/xenJeremy Fitzhardinge
* upstream/pvhvm: Introduce CONFIG_XEN_PVHVM compile option blkfront: do not create a PV cdrom device if xen_hvm_guest support multiple .discard.* sections to avoid section type conflicts xen/pvhvm: fix build problem when !CONFIG_XEN xenfs: enable for HVM domains too x86: Call HVMOP_pagetable_dying on exit_mmap. x86: Unplug emulated disks and nics. x86: Use xen_vcpuop_clockevent, xen_clocksource and xen wallclock. xen: Fix find_unbound_irq in presence of ioapic irqs. xen: Add suspend/resume support for PV on HVM guests. xen: Xen PCI platform device driver. x86/xen: event channels delivery on HVM. x86: early PV on HVM features initialization. xen: Add support for HVM hypercalls. Conflicts: arch/x86/xen/enlighten.c arch/x86/xen/time.c
2010-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1443 commits) phy/marvell: add 88ec048 support igb: Program MDICNFG register prior to PHY init e1000e: correct MAC-PHY interconnect register offset for 82579 hso: Add new product ID can: Add driver for esd CAN-USB/2 device l2tp: fix export of header file for userspace can-raw: Fix skb_orphan_try handling Revert "net: remove zap_completion_queue" net: cleanup inclusion phy/marvell: add 88e1121 interface mode support u32: negative offset fix net: Fix a typo from "dev" to "ndev" igb: Use irq_synchronize per vector when using MSI-X ixgbevf: fix null pointer dereference due to filter being set for VLAN 0 e1000e: Fix irq_synchronize in MSI-X case e1000e: register pm_qos request on hardware activation ip_fragment: fix subtracting PPPOE_SES_HLEN from mtu twice net: Add getsockopt support for TCP thin-streams cxgb4: update driver version cxgb4: add new PCI IDs ... Manually fix up conflicts in: - drivers/net/e1000e/netdev.c: due to pm_qos registration infrastructure changes - drivers/net/phy/marvell.c: conflict between adding 88ec048 support and cleaning up the IDs - drivers/net/wireless/ipw2x00/ipw2100.c: trivial ipw2100_pm_qos_req conflict (registration change vs marking it static)
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Runtime: Add runtime PM statistics (v3) PM / Runtime: Make runtime_status attribute not debug-only (v. 2) PM: Do not use dynamically allocated objects in pm_wakeup_event() PM / Suspend: Fix ordering of calls in suspend error paths PM / Hibernate: Fix snapshot error code path PM / Hibernate: Fix hibernation_platform_enter() pm_qos: Get rid of the allocation in pm_qos_add_request() pm_qos: Reimplement using plists plist: Add plist_last PM: Make it possible to avoid races between wakeup and system sleep PNPACPI: Add support for remote wakeup PM: describe kernel policy regarding wakeup defaults (v. 2) PM / Hibernate: Fix typos in comments in kernel/power/swap.c
2010-08-04Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Remove pointless printk from p4-clockmod. [CPUFREQ] Fix section mismatch for powernow_cpu_init in powernow-k7.c [CPUFREQ] Fix section mismatch for longhaul_cpu_init. [CPUFREQ] Fix section mismatch for longrun_cpu_init. [CPUFREQ] powernow-k8: Fix misleading variable naming [CPUFREQ] Convert pci_table entries to PCI_VDEVICE (if PCI_ANY_ID is used) [CPUFREQ] arch/x86/kernel/cpu/cpufreq: use for_each_pci_dev() [CPUFREQ] fix brace coding style issue. [CPUFREQ] x86 cpufreq: Make trace_power_frequency cpufreq driver independent [CPUFREQ] acpi-cpufreq: Fix CPU_ANY CPUFREQ_{PRE,POST}CHANGE notification [CPUFREQ] ondemand: don't synchronize sample rate unless multiple cpus present [CPUFREQ] unexport (un)lock_policy_rwsem* functions [CPUFREQ] ondemand: Refactor frequency increase code [CPUFREQ] powernow-k8: On load failure, remind the user to enable support in BIOS setup [CPUFREQ] powernow-k8: Limit Pstate transition latency check [CPUFREQ] Fix PCC driver error path [CPUFREQ] fix double freeing in error path of pcc-cpufreq [CPUFREQ] pcc driver should check for pcch method before calling _OSC [CPUFREQ] fix memory leak in cpufreq_add_dev [CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)" Manually fix up non-data merge conflict introduced by new calling conventions for trace_power_start() in commit 6f4f2723d085 ("x86 cpufreq: Make trace_power_frequency cpufreq driver independent"), which didn't update the intel_idle native hardware cpuidle driver.
2010-08-04Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (88 commits) ips driver: make it less chatty intel_scu_ipc: fix size field for intel_scu_ipc_command intel_scu_ipc: return -EIO for error condition in busy_loop intel_scu_ipc: fix data packing of PMIC command on Moorestown Clean up command packing on MRST. zero the stack buffer before giving random garbage to the SCU Fix stack buffer size for IPC writev messages intel_scu_ipc: Use the new cpu identification function intel_scu_ipc: tidy up unused bits Remove indirect read write api support. intel_scu_ipc: Support Medfield processors intel_scu_ipc: detect CPU type automatically x86 plat: limit x86 platform driver menu to X86 acpi ec_sys: Be more cautious about ec write access acpi ec: Fix possible double io port registration hp-wmi: acpi_drivers.h is already included through acpi.h two lines below hp-wmi: Fix mixing up of and/or directive dell-laptop: make dell_laptop_i8042_filter() static asus-laptop: fix asus_input_init error path msi-wmi: make needlessly global symbols static ...
2010-08-04Merge branch 'kvm-updates/2.6.36' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.36' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (198 commits) KVM: VMX: Fix host GDT.LIMIT corruption KVM: MMU: using __xchg_spte more smarter KVM: MMU: cleanup spte set and accssed/dirty tracking KVM: MMU: don't atomicly set spte if it's not present KVM: MMU: fix page dirty tracking lost while sync page KVM: MMU: fix broken page accessed tracking with ept enabled KVM: MMU: add missing reserved bits check in speculative path KVM: MMU: fix mmu notifier invalidate handler for huge spte KVM: x86 emulator: fix xchg instruction emulation KVM: x86: Call mask notifiers from pic KVM: x86: never re-execute instruction with enabled tdp KVM: Document KVM_GET_SUPPORTED_CPUID2 ioctl KVM: x86: emulator: inc/dec can have lock prefix KVM: MMU: Eliminate redundant temporaries in FNAME(fetch) KVM: MMU: Validate all gptes during fetch, not just those used for new pages KVM: MMU: Simplify spte fetch() function KVM: MMU: Add gpte_valid() helper KVM: MMU: Add validate_direct_spte() helper KVM: MMU: Add drop_large_spte() helper KVM: MMU: Use __set_spte to link shadow pages ...
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits) Input: adp5588-keypad - fix NULL dereference in adp5588_gpio_add() Input: cy8ctmg110 - capacitive touchscreen support Input: keyboard - also match braille-only keyboards Input: adp5588-keys - export unused GPIO pins Input: xpad - add product ID for Hori Fighting Stick EX2 Input: adxl34x - fix leak and use after free Input: samsung-keypad - Add samsung keypad driver Input: i8042 - reset keyboard controller wehen resuming from S2R Input: synaptics - set min/max for finger width Input: synaptics - only report width on hardware that supports it Input: evdev - signal that device is writable in evdev_poll() Input: mousedev - signal that device is writable in mousedev_poll() Input: change input handlers to use bool when possible Input: document the MT event slot protocol Input: introduce MT event slots Input: usbtouchscreen - implement reset_resume Input: usbtouchscreen - implement runtime power management Input: usbtouchscreen - implement basic suspend/resume Input: Add ATMEL QT602240 touchscreen driver Input: fix signedness warning in input_set_keycode() ...
2010-08-04Merge branch 'v4l_for_2.6.35' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_2.6.35' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (243 commits) V4L/DVB: sms: Convert IR support to use the Remote Controller core V4L/DVB: sms: properly initialize IR phys and IR name V4L/DVB: standardize names at rc-dib0700 tables V4L/DVB: smsusb: enable IR port for Hauppauge WinTV MiniStick V4L/DVB: dib0700: Fix RC protocol logic to properly handle NEC/NECx and RC-5 V4L/DVB: dib0700: properly implement IR change_protocol V4L/DVB: dib0700: break keytable into NEC and RC-5 variants V4L/DVB: dib0700: avoid bad repeat V4L/DVB: Port dib0700 to rc-core V4L/DVB: Add a keymap file with dib0700 table V4L/DVB: dvb-usb: add support for rc-core mode V4L/DVB: dvb-usb: prepare drivers for using rc-core V4L/DVB: dvb-usb: get rid of struct dvb_usb_rc_key V4L/DVB: rj54n1cb0c: fix a comment in the driver V4L/DVB: V4L2: sh_vou: VOU does support the full PAL resolution too V4L/DVB: V4L2: sh_mobile_camera_ceu: add support for CSI2 V4L/DVB: V4L2: soc-camera: add a MIPI CSI-2 driver for SH-Mobile platforms V4L/DVB: V4L2: soc-camera: export soc-camera bus type for notifications V4L/DVB: V4L2: mediabus: add 12-bit Bayer and YUV420 pixel formats V4L/DVB: mediabus: fix ambiguous pixel code names ...
