path: root/Documentation
2008-07-25procfs-guide: drop pointless   entitiesMike Frysinger
Having trailing &nbsp; entities in a revision numer seems pretty pointless to me. More so, it's causing me pains, so just drop them since no other guide is doing this. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25UTC timestamp option for FAT filesystems fixJoe Peterson
Signed-off-by: Joe Peterson <joe@skyrush.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpiolib: allow user-selectionMichael Buesch
This patch adds functionality to the gpio-lib subsystem to make it possible to enable the gpio-lib code even if the architecture code didn't request to get it built in. The archtitecture code does still need to implement the gpiolib accessor functions in its asm/gpio.h file. This patch adds the implementations for x86 and PPC. With these changes it is possible to run generic GPIO expansion cards on every architecture that implements the trivial wrapper functions. Support for more architectures can easily be added. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: add bt8xxgpio driverMichael Buesch
This adds the bt8xxgpio driver. The purpose of the bt8xxgpio driver is to export all of the 24 GPIO pins available on Brooktree 8xx chips to the kernel GPIO infrastructure. This makes it possible to use a physically modified BT8xx card as cheap digital GPIO card. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: David Brownell <david-b@pacbell.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: sysfs interfaceDavid Brownell
This adds a simple sysfs interface for GPIOs. /sys/class/gpio /export ... asks the kernel to export a GPIO to userspace /unexport ... to return a GPIO to the kernel /gpioN ... for each exported GPIO #N /value ... always readable, writes fail for input GPIOs /direction ... r/w as: in, out (default low); write high, low /gpiochipN ... for each gpiochip; #N is its first GPIO /base ... (r/o) same as N /label ... (r/o) descriptive, not necessarily unique /ngpio ... (r/o) number of GPIOs; numbered N .. N+(ngpio - 1) GPIOs claimed by kernel code may be exported by its owner using a new gpio_export() call, which should be most useful for driver debugging. Such exports may optionally be done without a "direction" attribute. Userspace may ask to take over a GPIO by writing to a sysfs control file, helping to cope with incomplete board support or other "one-off" requirements that don't merit full kernel support: echo 23 > /sys/class/gpio/export ... will gpio_request(23, "sysfs") and gpio_export(23); use /sys/class/gpio/gpio-23/direction to (re)configure it, when that GPIO can be used as both input and output. echo 23 > /sys/class/gpio/unexport ... will gpio_free(23), when it was exported as above The extra D-space footprint is a few hundred bytes, except for the sysfs resources associated with each exported GPIO. The additional I-space footprint is about two thirds of the current size of gpiolib (!). Since no /dev node creation is involved, no "udev" support is needed. Related changes: * This adds a device pointer to "struct gpio_chip". When GPIO providers initialize that, sysfs gpio class devices become children of that device instead of being "virtual" devices. * The (few) gpio_chip providers which have such a device node have been updated. * Some gpio_chip drivers also needed to update their module "owner" field ... for which missing kerneldoc was added. * Some gpio_chips don't support input GPIOs. Those GPIOs are now flagged appropriately when the chip is registered. Based on previous patches, and discussion both on and off LKML. A Documentation/ABI/testing/sysfs-gpio update is ready to submit once this merges to mainline. [akpm@linux-foundation.org: a few maintenance build fixes] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25documentation: update CodingStyle tips for Emacs usersJohannes Weiner
Describe a setup that integrates better with Emacs' cc-mode and also fixes up the alignment of continuation lines to really only use tabs. Signed-off-by: Johannes Weiner <hannes@saeurebad.de> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25remove some more tipar bitsAdrian Bunk
Some bits were missed when the tipar driver was removed. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25introduce HAVE_EFFICIENT_UNALIGNED_ACCESS Kconfig symbolJohannes Berg
In many cases, especially in networking, it can be beneficial to know at compile time whether the architecture can do unaligned accesses efficiently. This patch introduces a new Kconfig symbol HAVE_EFFICIENT_UNALIGNED_ACCESS for that purpose and adds it to the powerpc and x86 architectures. Also add some documentation about alignment and networking, and especially one intended use of this symbol. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> [x86 architecture part] Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6: acpi: fix crash in core ACPI code, triggered by CONFIG_ACPI_PCI_SLOT=y ACPI: thinkpad-acpi: don't misdetect in get_thinkpad_model_data() on -ENOMEM ACPI: thinkpad-acpi: bump up version to 0.21 ACPI: thinkpad-acpi: add bluetooth and WWAN rfkill support ACPI: thinkpad-acpi: WLSW overrides other rfkill switches ACPI: thinkpad-acpi: prepare for bluetooth and wwan rfkill support ACPI: thinkpad-acpi: consolidate wlsw notification function ACPI: thinkpad-acpi: minor refactor on radio switch init Revert "ACPI: don't walk tables if ACPI was disabled" Revert "dock: bay: Don't call acpi_walk_namespace() when ACPI is disabled." Revert "Fix FADT parsing" ACPI : Set FAN device to correct state in boot phase ACPI: Ignore _BQC object when registering backlight device ACPI: stop complaints about interrupt link End Tags and blank IRQ descriptors
2008-07-24Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Remove __DECLARE_SEMAPHORE_GENERIC Remove asm/semaphore.h Remove use of asm/semaphore.h Add missing semaphore.h includes Remove mention of semaphores from kernel-locking
2008-07-24video: sh7760fb: SH7760/SH7763 LCDC framebuffer driverNobuhiro Iwamatsu
Framebuffer driver for the SH7760/SH7763 integrated LCD controller. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Reviewed-by: Paul Mundt <lethal@linux-sh.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Siegfried Schaefer <s.schaefer@schaefer-edv.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24tridentfb: documentation updateKrzysztof Helt
Make the tridentfb documentation closer to current state of the tridentfb driver. Fix also some formatting. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24pm: acpi hibernation: utilize hardware signatureShaohua Li
ACPI defines a hardware signature. BIOS calculates the signature according to hardware configure and if hardware changes while hibernated, the signature will change. In that case, S4 resume should fail. Still, there may be systems on which this mechanism does not work correctly, so it is better to provide a workaround for them. For this reason, add a new switch to the acpi_sleep= command line argument allowing one to disable hardware signature checking. [shaohua.li@intel.com: build fix] Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Andi Kleen <andi@firstfloor.org> Cc: Len Brown <lenb@kernel.org> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: <Valdis.Kletnieks@vt.edu> Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24pm: remove obsolete piece of PM documentationRafael J. Wysocki
Remove some obsolete PM documentation. The majority of contents of Documentation/power/pm.txt are outdated. Remove the outdated parts of this file and move the rest to Documentation/power/apm-acpi.txt . Update the index in Documentation/power/ as appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24pm: boot time suspend selftestDavid Brownell
Boot-time test for system suspend states (STR or standby). The generic RTC framework triggers wakeup alarms, which are used to exit those states. - Measures some aspects of suspend time ... this uses "jiffies" until someone converts it to use a timebase that works properly even while timer IRQs are disabled. - Triggered by a command line parameter. By default nothing even vaguely troublesome will happen, but "test_suspend=mem" will give you a brief STR test during system boot. (Or you may need to use "test_suspend=standby" instead, if your hardware needs that.) This isn't without problems. It fires early enough during boot that for example both PCMCIA and MMC stacks have misbehaved. The workaround in those cases was to boot without such media cards inserted. [matthltc@us.ibm.com: fix compile failure in boot time suspend selftest] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pavel Machek <pavel@suse.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Matt Helsley <matthltc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24memory-hotplug: add sysfs removable attribute for hotplug memory removeBadari Pulavarty
Memory may be hot-removed on a per-memory-block basis, particularly on POWER where the SPARSEMEM section size often matches the memory-block size. A user-level agent must be able to identify which sections of memory are likely to be removable before attempting the potentially expensive operation. This patch adds a file called "removable" to the memory directory in sysfs to help such an agent. In this patch, a memory block is considered removable if; o It contains only MOVABLE pageblocks o It contains only pageblocks with free pages regardless of pageblock type On the other hand, a memory block starting with a PageReserved() page will never be considered removable. Without this patch, the user-agent is forced to choose a memory block to remove randomly. Sample output of the sysfs files: ./memory/memory0/removable: 0 ./memory/memory1/removable: 0 ./memory/memory2/removable: 0 ./memory/memory3/removable: 0 ./memory/memory4/removable: 0 ./memory/memory5/removable: 0 ./memory/memory6/removable: 0 ./memory/memory7/removable: 1 ./memory/memory8/removable: 0 ./memory/memory9/removable: 0 ./memory/memory10/removable: 0 ./memory/memory11/removable: 0 ./memory/memory12/removable: 0 ./memory/memory13/removable: 0 ./memory/memory14/removable: 0 ./memory/memory15/removable: 0 ./memory/memory16/removable: 0 ./memory/memory17/removable: 1 ./memory/memory18/removable: 1 ./memory/memory19/removable: 1 ./memory/memory20/removable: 1 ./memory/memory21/removable: 1 ./memory/memory22/removable: 1 Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Mel Gorman <mel@csn.ul.ie> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24powerpc: support multiple hugepage sizesJon Tollefson
Instead of using the variable mmu_huge_psize to keep track of the huge page size we use an array of MMU_PAGE_* values. For each supported huge page size we need to know the hugepte_shift value and have a pgtable_cache. The hstate or an mmu_huge_psizes index is passed to functions so that they know which huge page size they should use. The hugepage sizes 16M and 64K are setup(if available on the hardware) so that they don't have to be set on the boot cmd line in order to use them. The number of 16G pages have to be specified at boot-time though (e.g. hugepagesz=16G hugepages=5). Signed-off-by: Jon Tollefson <kniht@linux.vnet.ibm.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: override default huge page sizeNick Piggin
Allow configurations with the default huge page size which is different to the traditional HPAGE_SIZE size. The default huge page size is the one represented in the legacy /proc ABIs, SHM, and which is defaulted to when mounting hugetlbfs filesystems. This is implemented with a new kernel option default_hugepagesz=, which defaults to HPAGE_SIZE if not specified. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24x86: add hugepagesz option on 64-bitAndi Kleen
Add an hugepagesz=... option similar to IA64, PPC etc. to x86-64. This finally allows to select GB pages for hugetlbfs in x86 now that all the infrastructure is in place. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: new sysfs interfaceNishanth Aravamudan
Provide new hugepages user APIs that are more suited to multiple hstates in sysfs. There is a new directory, /sys/kernel/hugepages. Underneath that directory there will be a directory per-supported hugepage size, e.g.: /sys/kernel/hugepages/hugepages-64kB /sys/kernel/hugepages/hugepages-16384kB /sys/kernel/hugepages/hugepages-16777216kB corresponding to 64k, 16m and 16g respectively. Within each hugepages-size directory there are a number of files, corresponding to the tracked counters in the hstate, e.g.: /sys/kernel/hugepages/hugepages-64/nr_hugepages /sys/kernel/hugepages/hugepages-64/nr_overcommit_hugepages /sys/kernel/hugepages/hugepages-64/free_hugepages /sys/kernel/hugepages/hugepages-64/resv_hugepages /sys/kernel/hugepages/hugepages-64/surplus_hugepages Of these files, the first two are read-write and the latter three are read-only. The size of the hugepage being manipulated is trivially deducible from the enclosing directory and is always expressed in kB (to match meminfo). [dave@linux.vnet.ibm.com: fix build] [nacc@us.ibm.com: hugetlb: hang off of /sys/kernel/mm rather than /sys/kernel] [nacc@us.ibm.com: hugetlb: remove CONFIG_SYSFS dependency] Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: create /sys/kernel/mmNishanth Aravamudan
Add a kobject to create /sys/kernel/mm when sysfs is mounted. The kobject will exist regardless. This will allow for the hugepage related sysfs directories to exist under the mm "subsystem" directory. Add an ABI file appropriately. [kosaki.motohiro@jp.fujitsu.com: fix build] Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24vmallocinfo: add NUMA informationEric Dumazet
Christoph recently added /proc/vmallocinfo file to get information about vmalloc allocations. This patch adds NUMA specific information, giving number of pages allocated on each memory node. This should help to check that vmalloc() is able to respect NUMA policies. Example of output on a four nodes machine (one cpu per node) 1) network hash tables are evenly spreaded on four nodes (OK) (Same point for inodes and dentries hash tables) 2) iptables tables (x_tables) are correctly allocated on each cpu node (OK). 3) sys_swapon() allocates its memory from one node only. 4) each loaded module is using memory on one node. Sysadmins could tune their setup to change points 3) and 4) if necessary. grep "pages=" /proc/vmallocinfo 0xffffc20000000000-0xffffc20000201000 2101248 alloc_large_system_hash+0x204/0x2c0 pages=512 vmalloc N0=128 N1=128 N2=128 N3=128 0xffffc20000201000-0xffffc20000302000 1052672 alloc_large_system_hash+0x204/0x2c0 pages=256 vmalloc N0=64 N1=64 N2=64 N3=64 0xffffc2000031a000-0xffffc2000031d000 12288 alloc_large_system_hash+0x204/0x2c0 pages=2 vmalloc N1=1 N2=1 0xffffc2000031f000-0xffffc2000032b000 49152 cramfs_uncompress_init+0x2e/0x80 pages=11 vmalloc N0=3 N1=3 N2=2 N3=3 0xffffc2000033e000-0xffffc20000341000 12288 sys_swapon+0x640/0xac0 pages=2 vmalloc N0=2 0xffffc20000341000-0xffffc20000344000 12288 xt_alloc_table_info+0xfe/0x130 [x_tables] pages=2 vmalloc N0=2 0xffffc20000344000-0xffffc20000347000 12288 xt_alloc_table_info+0xfe/0x130 [x_tables] pages=2 vmalloc N1=2 0xffffc20000347000-0xffffc2000034a000 12288 xt_alloc_table_info+0xfe/0x130 [x_tables] pages=2 vmalloc N2=2 0xffffc2000034a000-0xffffc2000034d000 12288 xt_alloc_table_info+0xfe/0x130 [x_tables] pages=2 vmalloc N3=2 0xffffc20004381000-0xffffc20004402000 528384 alloc_large_system_hash+0x204/0x2c0 pages=128 vmalloc N0=32 N1=32 N2=32 N3=32 0xffffc20004402000-0xffffc20004803000 4198400 alloc_large_system_hash+0x204/0x2c0 pages=1024 vmalloc vpages N0=256 N1=256 N2=256 N3=256 0xffffc20004803000-0xffffc20004904000 1052672 alloc_large_system_hash+0x204/0x2c0 pages=256 vmalloc N0=64 N1=64 N2=64 N3=64 0xffffc20004904000-0xffffc20004bec000 3047424 sys_swapon+0x640/0xac0 pages=743 vmalloc vpages N0=743 0xffffffffa0000000-0xffffffffa000f000 61440 sys_init_module+0xc27/0x1d00 pages=14 vmalloc N1=14 0xffffffffa000f000-0xffffffffa0014000 20480 sys_init_module+0xc27/0x1d00 pages=4 vmalloc N0=4 0xffffffffa0014000-0xffffffffa0017000 12288 sys_init_module+0xc27/0x1d00 pages=2 vmalloc N0=2 0xffffffffa0017000-0xffffffffa0022000 45056 sys_init_module+0xc27/0x1d00 pages=10 vmalloc N1=10 0xffffffffa0022000-0xffffffffa0028000 24576 sys_init_module+0xc27/0x1d00 pages=5 vmalloc N3=5 0xffffffffa0028000-0xffffffffa0050000 163840 sys_init_module+0xc27/0x1d00 pages=39 vmalloc N1=39 0xffffffffa0050000-0xffffffffa0052000 8192 sys_init_module+0xc27/0x1d00 pages=1 vmalloc N1=1 0xffffffffa0052000-0xffffffffa0056000 16384 sys_init_module+0xc27/0x1d00 pages=3 vmalloc N1=3 0xffffffffa0056000-0xffffffffa0081000 176128 sys_init_module+0xc27/0x1d00 pages=42 vmalloc N3=42 0xffffffffa0081000-0xffffffffa00ae000 184320 sys_init_module+0xc27/0x1d00 pages=44 vmalloc N3=44 0xffffffffa00ae000-0xffffffffa00b1000 12288 sys_init_module+0xc27/0x1d00 pages=2 vmalloc N3=2 0xffffffffa00b1000-0xffffffffa00b9000 32768 sys_init_module+0xc27/0x1d00 pages=7 vmalloc N0=7 0xffffffffa00b9000-0xffffffffa00c4000 45056 sys_init_module+0xc27/0x1d00 pages=10 vmalloc N3=10 0xffffffffa00c6000-0xffffffffa00e0000 106496 sys_init_module+0xc27/0x1d00 pages=25 vmalloc N2=25 0xffffffffa00e0000-0xffffffffa00f1000 69632 sys_init_module+0xc27/0x1d00 pages=16 vmalloc N2=16 0xffffffffa00f1000-0xffffffffa00f4000 12288 sys_init_module+0xc27/0x1d00 pages=2 vmalloc N3=2 0xffffffffa00f4000-0xffffffffa00f7000 12288 sys_init_module+0xc27/0x1d00 pages=2 vmalloc N3=2 [akpm@linux-foundation.org: fix comment] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24access_process_vm device memory infrastructureRik van Riel
In order to be able to debug things like the X server and programs using the PPC Cell SPUs, the debugger needs to be able to access device memory through ptrace and /proc/pid/mem. This patch: Add the generic_access_phys access function and put the hooks in place to allow access_process_vm to access device or PPC Cell SPU memory. [riel@redhat.com: Add documentation for the vm_ops->access function] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Benjamin Herrensmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Hugh Dickins <hugh@veritas.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: add a basic debugging framework for memory initialisationMel Gorman
Boot initialisation is very complex, with significant numbers of architecture-specific routines, hooks and code ordering. While significant amounts of the initialisation is architecture-independent, it trusts the data received from the architecture layer. This is a mistake, and has resulted in a number of difficult-to-diagnose bugs. This patchset adds some validation and tracing to memory initialisation. It also introduces a few basic defensive measures. The validation code can be explicitly disabled for embedded systems. This patch: Add additional debugging and verification code for memory initialisation. Once enabled, the verification checks are always run and when required additional debugging information may be outputted via a mminit_loglevel= command-line parameter. The verification code is placed in a new file mm/mm_init.c. Ideally other mm initialisation code will be moved here over time. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Remove asm/semaphore.hMatthew Wilcox
All users have now been converted to linux/semaphore.h and we don't need to keep these files around any longer. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-07-24Remove mention of semaphores from kernel-lockingMatthew Wilcox
Since the consensus seems to be to eliminate semaphores where possible, we shouldn't be educating people about how to use them as locks. Use mutexes instead. Semaphores should be described in a separate document if we end up keeping them. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-23Merge branch 'core/softlockup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/softlockup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: fix invalid proc_handler for softlockup_panic softlockup: fix watchdog task wakeup frequency softlockup: fix watchdog task wakeup frequency softlockup: show irqtrace softlockup: print a module list on being stuck softlockup: fix NMI hangs due to lock race - 2.6.26-rc regression softlockup: fix false positives on nohz if CPU is 100% idle for more than 60 seconds softlockup: fix softlockup_thresh fix softlockup: fix softlockup_thresh unaligned access and disable detection at runtime softlockup: allow panic on lockup
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (82 commits) ipw2200: Call netif_*_queue() interfaces properly. netxen: Needs to include linux/vmalloc.h [netdrvr] atl1d: fix !CONFIG_PM build r6040: rework init_one error handling r6040: bump release number to 0.18 r6040: handle RX fifo full and no descriptor interrupts r6040: change the default waiting time r6040: use definitions for magic values in descriptor status r6040: completely rework the RX path r6040: call napi_disable when puting down the interface and set lp->dev accordingly. mv643xx_eth: fix NETPOLL build r6040: rework the RX buffers allocation routine r6040: fix scheduling while atomic in r6040_tx_timeout r6040: fix null pointer access and tx timeouts r6040: prefix all functions with r6040 rndis_host: support WM6 devices as modems at91_ether: use netstats in net_device structure sfc: Create one RX queue and interrupt per CPU package by default sfc: Use a separate workqueue for resets sfc: I2C adapter initialisation fixes ...
2008-07-22e1000: delete non NAPI code from the driverFrancois Romieu
Compile-tested only. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: remove CONFIG_KMOD from core kernel code remove CONFIG_KMOD from lib remove CONFIG_KMOD from sparc64 rework try_then_request_module to do less in non-modular kernels remove mention of CONFIG_KMOD from documentation make CONFIG_KMOD invisible modules: Take a shortcut for checking if an address is in a module module: turn longs into ints for module sizes Shrink struct module: CONFIG_UNUSED_SYMBOLS ifdefs module: reorder struct module to save space on 64 bit builds module: generic each_symbol iterator function module: don't use stop_machine for waiting rmmod
2008-07-22Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (49 commits) powerpc: Fix build bug with binutils < 2.18 and GCC < 4.2 powerpc/eeh: Don't panic when EEH_MAX_FAILS is exceeded fbdev: Teaches offb about palette on radeon r5xx/r6xx powerpc/cell/edac: Log a syndrome code in case of correctable error powerpc/cell: Add DMA_ATTR_WEAK_ORDERING dma attribute and use in Cell IOMMU code powerpc: Indicate which oprofile counters to use while in compat mode powerpc/boot: Change spaces to tabs powerpc: Remove duplicate 6xx option in Kconfig powerpc: Use PPC_LONG and PPC_LONG_ALIGN in lib/string.S powerpc: Use PPC_LONG_ALIGN in uaccess.h powerpc: Add a #define for aligning to a long-sized boundary powerpc: Fix OF parsing of 64 bits PCI addresses powerpc: Use WARN_ON(1) instead of __WARN() powerpc: Fix support for latencytop powerpc/ps3: Update ps3_defconfig powerpc/ps3: Add a sub-match id to ps3_system_bus powerpc: Add a 6xx defconfig powerpc/dma: Use the struct dma_attrs in iommu code powerpc/cell: Add support for power button of future IBM cell blades powerpc/cell: Cleanup sysreset_hack for IBM cell blades ...
2008-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (79 commits) arm: bus_id -> dev_name() and dev_set_name() conversions sparc64: fix up bus_id changes in sparc core code 3c59x: handle pci_name() being const MTD: handle pci_name() being const HP iLO driver sysdev: Convert the x86 mce tolerant sysdev attribute to generic attribute sysdev: Add utility functions for simple int/ulong variable sysdev attributes sysdev: Pass the attribute to the low level sysdev show/store function driver core: Suppress sysfs warnings for device_rename(). kobject: Transmit return value of call_usermodehelper() to caller sysfs-rules.txt: reword API stability statement debugfs: Implement debugfs_remove_recursive() HOWTO: change email addresses of James in HOWTO always enable FW_LOADER unless EMBEDDED=y uio-howto.tmpl: use unique output names uio-howto.tmpl: use standard copyright/legal markings sysfs: don't call notify_change sysdev: fix debugging statements in registration code. kobject: should use kobject_put() in kset-example kobject: reorder kobject to save space on 64 bit builds ...
2008-07-22specialix: Code cleanupsAlan Cox
Go through the inlines and other oddments that are iffy. Remove various bits of dead code and bogus debug. Turn the crtsdts compile time option into a runtime switch. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-22remove mention of CONFIG_KMOD from documentationJohannes Berg
Also includes a few Kconfig files (xtensa, blackfin) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: linux-doc@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2008-07-22Merge commit 'origin/master'Benjamin Herrenschmidt
Manually fixed up: drivers/net/fs_enet/fs_enet-main.c
2008-07-21sysfs-rules.txt: reword API stability statementNathan Lynch
The first paragraph of this document implies that user space developers shouldn't use sysfs at all, but then it goes on to describe rules that developers should follow when accessing sysfs. Not only is this somewhat self-contradictory, it has been shown to discourage developers from using established sysfs interfaces. A note of caution is more appropriate than a blanket "sysfs will never be stable" assertion. Signed-off-by: Nathan Lynch <ntl@pobox.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21HOWTO: change email addresses of James in HOWTOTsugikazu Shibata
Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21uio-howto.tmpl: use unique output namesMike Frysinger
The Userspace I/O HOWTO template sets two different sections with the same html output name (about.html). This clearly won't work, so change the first one to a unique "aboutthis.html" to prevent clobbering. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Hans J. Koch <hjk@linutronix.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21uio-howto.tmpl: use standard copyright/legal markingsMike Frysinger
The Userspace I/O HOWTO document uses straight <sect1> tags and plain text to describe copyright/legal information. It should instead use the <copyright> and <legalnotice> tags like all other documents in the kernel. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Hans J. Koch <hjk@linutronix.de> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21UIO: Add write function to allow irq maskingHans J. Koch
Sometimes it is necessary to enable/disable the interrupt of a UIO device from the userspace part of the driver. With this patch, the UIO kernel driver can implement an "irqcontrol()" function that does this. Userspace can write an s32 value to /dev/uioX (usually 0 or 1 to turn the irq off or on). The UIO core will then call the driver's irqcontrol function. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21sysfs: add /sys/dev/{char,block} to lookup sysfs path by major:minorDan Williams
Why?: There are occasions where userspace would like to access sysfs attributes for a device but it may not know how sysfs has named the device or the path. For example what is the sysfs path for /dev/disk/by-id/ata-ST3160827AS_5MT004CK? With this change a call to stat(2) returns the major:minor then userspace can see that /sys/dev/block/8:32 links to /sys/block/sdc. What are the alternatives?: 1/ Add an ioctl to return the path: Doable, but sysfs is meant to reduce the need to proliferate ioctl interfaces into the kernel, so this seems counter productive. 2/ Use udev to create these symlinks: Also doable, but it adds a udev dependency to utilities that might be running in a limited environment like an initramfs. 3/ Do a full-tree search of sysfs. [kay.sievers@vrfy.org: fix duplicate registrations] [kay.sievers@vrfy.org: cleanup suggestions] Cc: Neil Brown <neilb@suse.de> Cc: Tejun Heo <htejun@gmail.com> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Reviewed-by: SL Baur <steve@xemacs.org> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Mark Lord <lkml@rtr.ca> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-22powerpc/cell: Add DMA_ATTR_WEAK_ORDERING dma attribute and use in Cell IOMMU ↵Mark Nelson
code Introduce a new dma attriblue DMA_ATTR_WEAK_ORDERING to use weak ordering on DMA mappings in the Cell processor. Add the code to the Cell's IOMMU implementation to use this code. Dynamic mappings can be weakly or strongly ordered on an individual basis but the fixed mapping has to be either completely strong or completely weak. This is currently decided by a kernel boot option (pass iommu_fixed=weak for a weakly ordered fixed linear mapping, strongly ordered is the default). Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (100 commits) usb-storage: revert DMA-alignment change for Wireless USB USB: use reset_resume when normal resume fails usb_gadget: composite cdc gadget fault handling usb gadget: minor USBCV fix for composite framework USB: Fix bug with byte order in isp116x-hcd.c fio write/read USB: fix double kfree in ipaq in error case USB: fix build error in cdc-acm for CONFIG_PM=n USB: remove board-specific UP2OCR configuration from pxa27x-udc USB: EHCI: Reconciling USB register differences on MPC85xx vs MPC83xx USB: Fix pointer/int cast in USB devio code usb gadget: g_cdc dependso on NET USB: Au1xxx-usb: suspend/resume support. USB: Au1xxx-usb: clean up ohci/ehci bus glue sources. usbfs: don't store bad pointers in registration usbfs: fix race between open and unregister usbfs: simplify the lookup-by-minor routines usbfs: send disconnect signals when device is unregistered USB: Force unbinding of drivers lacking reset_resume or other methods USB: ohci-pnx4008: I2C cleanups and fixes USB: debug port converter does not accept more than 8 byte packets ...
2008-07-21USB: use reset_resume when normal resume failsAlan Stern
This patch (as1109b) makes USB-Persist more resilient to errors. With the current code, if a normal resume fails, it's an unrecoverable error. With the patch, if a normal resume fails (and if the device is enabled for USB-Persist) then a reset-resume is tried. This fixes the problem reported in Bugzilla #10977. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget serial: split out generic serial functionDavid Brownell
Split out the generic serial support into a "function driver". This closely mimics the ACM support, but with a MUCH simpler control model. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget serial: split out CDC ACM functionDavid Brownell
Split out CDC ACM parts of "gadget serial" to a "function driver". Some key structural differences from the previous ACM support, shared with with the generic serial function (next patch): - As a function driver, it can be combined with other functions. One gadget configuration could offer both serial and network links, as an example. - One serial port can be exposed in multiple configurations; the /dev/ttyGS0 node could be exposed regardless of which config the host selected. - One configuration can expose multiple serial ports, such as ttyGS0, ttyGS1, ttyGS2, and ttyGS3. This code should be a lot easier to understand than the previous all-in-one-big-file version of the driver. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: composite gadget coreDavid Brownell
Add <linux/usb/composite.h> interfaces for composite gadget drivers, and basic implementation support behind it: - struct usb_function ... groups one or more interfaces into a function managed as one unit within a configuration, to which it's added by usb_add_function(). - struct usb_configuration ... groups one or more such functions into a configuration managed as one unit by a driver, to which it's added by usb_add_config(). These operate at either high or full/low speeds and at a given bMaxPower. - struct usb_composite_driver ... groups one or more such configurations into a gadget driver, which may be registered or unregistered. - struct usb_composite_dev ... a usb_composite_driver manages this; it wraps the usb_gadget exposed by the controller driver. This also includes some basic kerneldoc. How to use it (the short version): provide a usb_composite_driver with a bind() that calls usb_add_config() for each of the needed configurations. The configurations in turn have bind() calls, which will usb_add_function() for each function required. Each function's bind() allocates resources needed to perform its tasks, like endpoints; sometimes configurations will allocate resources too. Separate patches will convert most gadget drivers to this infrastructure. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: use new serial coreDavid Brownell
Teach "gadget serial" to use the new abstracted (and bugfixed) TTY glue, and remove all the orignal tangled-up code. Update the documentation accordingly. This is a net object code shrink and cleanup; it should make it a lot easier to see how the TTY glue should accomodate updates to the TTY layer, be bugfixed, etc. Notable behavior changes include: it can now support getty even when there's no USB connection; it fits properly into the mdev/udev world; and RX handling is better (throttling works, and low latency). Configurations with scripts setting up the /dev/ttygserial device node (with "experimental" major number) may want to change that to be a symlink pointing to the /dev/ttyGS0 file, as a migration aid; else, just switch entirely over to mdev/udev. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: remove Documentation/usb/uhci.txtAdrian Bunk
The driver was removed before kernel 2.6.0 Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (25 commits) mmtimer: Push BKL down into the ioctl handler [IA64] Remove experimental status of kdump [IA64] Update ia64 mmr list for SGI uv [IA64] Avoid overflowing ia64_cpu_to_sapicid in acpi_map_lsapic() [IA64] adding parameter check to module_free() [IA64] improper printk format in acpi-cpufreq [IA64] pv_ops: move some functions in ivt.S to avoid lack of space. [IA64] pvops: documentation on ia64/pv_ops [IA64] pvops: add to hooks, pv_time_ops, for steal time accounting. [IA64] pvops: add hooks, pv_irq_ops, to paravirtualized irq related operations. [IA64] pvops: add hooks, pv_iosapic_ops, to paravirtualize iosapic. [IA64] pvops: define initialization hooks, pv_init_ops, for paravirtualized environment. [IA64] pvops: paravirtualize NR_IRQS [IA64] pvops: paravirtualize entry.S [IA64] pvops: paravirtualize ivt.S [IA64] pvops: paravirtualize minstate.h. [IA64] pvops: define paravirtualized instructions for native. [IA64] pvops: preparation for paravirtulization of hand written assembly code. [IA64] pvops: introduce pv_cpu_ops to paravirtualize privileged instructions. [IA64] pvops: add an early setup hook for pv_ops. ...
