git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'for-linus' of git://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (207 commits)
ARM: 7267/1: Remove BUILD_BUG_ON from asm/bug.h
ARM: 7269/1: mach-sa1100: fix sched_clock breakage
ARM: 7198/1: arm/imx6: add restart support for imx6q
ARM: restart: remove the now empty arch_reset()
ARM: restart: remove comments about adding code to arch_reset()
ARM: restart: lpc32xx & u300: remove unnecessary printk
ARM: restart: plat-samsung: remove plat/reset.h and s5p_reset_hook
ARM: restart: w90x900: use new restart hook
ARM: restart: Versatile Express: use new restart hook
ARM: restart: versatile: use new restart hook
ARM: restart: u300: use new restart hook
ARM: restart: tegra: use new restart hook
ARM: restart: spear: use new restart hook
ARM: restart: shark: use new restart hook
ARM: restart: sa1100: use new restart hook
ARM: 7252/1: restart: S5PV210: use new restart hook
ARM: 7251/1: restart: S5PC100: use new restart hook
ARM: 7250/1: restart: S5P64X0: use new restart hook
ARM: 7266/1: restart: S3C64XX: use new restart hook
ARM: 7265/1: restart: S3C24XX: use new restart hook
Fix up trivial conflict in arch/arm/mm/init.c due to removal of
memblock_init() clashing with the movement of the sorting of the meminfo
array.
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (185 commits)
powerpc: fix compile error with 85xx/p1010rdb.c
powerpc: fix compile error with 85xx/p1023_rds.c
powerpc/fsl: add MSI support for the Freescale hypervisor
arch/powerpc/sysdev/fsl_rmu.c: introduce missing kfree
powerpc/fsl: Add support for Integrated Flash Controller
powerpc/fsl: update compatiable on fsl 16550 uart nodes
powerpc/85xx: fix PCI and localbus properties in p1022ds.dts
powerpc/85xx: re-enable ePAPR byte channel driver in corenet32_smp_defconfig
powerpc/fsl: Update defconfigs to enable some standard FSL HW features
powerpc: Add TBI PHY node to first MDIO bus
sbc834x: put full compat string in board match check
powerpc/fsl-pci: Allow 64-bit PCIe devices to DMA to any memory address
powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exit
offb: Fix setting of the pseudo-palette for >8bpp
offb: Add palette hack for qemu "standard vga" framebuffer
offb: Fix bug in calculating requested vram size
powerpc/boot: Change the WARN to INFO for boot wrapper overlap message
powerpc/44x: Fix build error on currituck platform
powerpc/boot: Change the load address for the wrapper to fit the kernel
powerpc/44x: Enable CRASH_DUMP for 440x
Fix up a trivial conflict in arch/powerpc/include/asm/cputime.h due to
the additional sparse-checking code for cputime_t.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1958 commits)
net: pack skb_shared_info more efficiently
net_sched: red: split red_parms into parms and vars
net_sched: sfq: extend limits
cnic: Improve error recovery on bnx2x devices
cnic: Re-init dev->stats_addr after chip reset
net_sched: Bug in netem reordering
bna: fix sparse warnings/errors
bna: make ethtool_ops and strings const
xgmac: cleanups
net: make ethtool_ops const
vmxnet3" make ethtool ops const
xen-netback: make ops structs const
virtio_net: Pass gfp flags when allocating rx buffers.
ixgbe: FCoE: Add support for ndo_get_fcoe_hbainfo() call
netdev: FCoE: Add new ndo_get_fcoe_hbainfo() call
igb: reset PHY after recovering from PHY power down
igb: add basic runtime PM support
igb: Add support for byte queue limits.
e1000: cleanup CE4100 MDIO registers access
e1000: unmap ce4100_gbe_mdio_base_virt in e1000_remove
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
x86: Fix atomic64_xxx_cx8() functions
x86: Fix and improve cmpxchg_double{,_local}()
x86_64, asm: Optimise fls(), ffs() and fls64()
x86, bitops: Move fls64.h inside __KERNEL__
x86: Fix and improve percpu_cmpxchg{8,16}b_double()
x86: Report cpb and eff_freq_ro flags correctly
x86/i386: Use less assembly in strlen(), speed things up a bit
x86: Use the same node_distance for 32 and 64-bit
x86: Fix rflags in FAKE_STACK_FRAME
x86: Clean up and extend do_int3()
x86: Call do_notify_resume() with interrupts enabled
x86/div64: Add a micro-optimization shortcut if base is power of two
x86-64: Cleanup some assembly entry points
x86-64: Slightly shorten line system call entry and exit paths
x86-64: Reduce amount of redundant code generated for invalidate_interruptNN
x86-64: Slightly shorten int_ret_from_sys_call
x86, efi: Convert efi_phys_get_time() args to physical addresses
x86: Default to vsyscall=emulate
x86-64: Set siginfo and context on vsyscall emulation faults
x86: consolidate xchg and xadd macros
This resolves the conflict in the arch/arm/mach-s3c64xx/s3c6400.c file,
and it fixes the build error in the arch/x86/kernel/microcode_core.c
file, that the merge did not catch.
The microcode_core.c patch was provided by Stephen Rothwell
<sfr@canb.auug.org.au> who was invaluable in the merge issues involved
with the large sysdev removal process in the driver-core tree.
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (106 commits)
perf kvm: Fix copy & paste error in description
perf script: Kill script_spec__delete
perf top: Fix a memory leak
perf stat: Introduce get_ratio_color() helper
perf session: Remove impossible condition check
perf tools: Fix feature-bits rework fallout, remove unused variable
perf script: Add generic perl handler to process events
perf tools: Use for_each_set_bit() to iterate over feature flags
perf tools: Unify handling of features when writing feature section
perf report: Accept fifos as input file
perf tools: Moving code in some files
perf tools: Fix out-of-bound access to struct perf_session
perf tools: Continue processing header on unknown features
perf tools: Improve macros for struct feature_ops
perf: builtin-record: Document and check that mmap_pages must be a power of two.
perf: builtin-record: Provide advice if mmap'ing fails with EPERM.
perf tools: Fix truncated annotation
perf script: look up thread using tid instead of pid
perf tools: Look up thread names for system wide profiling
perf tools: Fix comm for processes with named threads
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits)
cpu: Export cpu_up()
rcu: Apply ACCESS_ONCE() to rcu_boost() return value
Revert "rcu: Permit rt_mutex_unlock() with irqs disabled"
docs: Additional LWN links to RCU API
rcu: Augment rcu_batch_end tracing for idle and callback state
rcu: Add rcutorture tests for srcu_read_lock_raw()
rcu: Make rcutorture test for hotpluggability before offlining CPUs
driver-core/cpu: Expose hotpluggability to the rest of the kernel
rcu: Remove redundant rcu_cpu_stall_suppress declaration
rcu: Adaptive dyntick-idle preparation
rcu: Keep invoking callbacks if CPU otherwise idle
rcu: Irq nesting is always 0 on rcu_enter_idle_common
rcu: Don't check irq nesting from rcu idle entry/exit
rcu: Permit dyntick-idle with callbacks pending
rcu: Document same-context read-side constraints
rcu: Identify dyntick-idle CPUs on first force_quiescent_state() pass
rcu: Remove dynticks false positives and RCU failures
rcu: Reduce latency of rcu_prepare_for_idle()
rcu: Eliminate RCU_FAST_NO_HZ grace-period hang
rcu: Avoid needlessly IPIing CPUs at GP end
* 'core-debugobjects-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timer: Use debugobjects to catch deletion of uninitialized timers
timer: Setup uninitialized timer with a stub callback
debugobjects: Extend to assert that an object is initialized
debugobjects: Be smarter about static objects
arch/arm/kernel/setup.c
arch/arm/mach-shmobile/board-kota2.c
Merge reason: Update from -rc4 to -rc7.
v2, based on Jay's review.
I kept the 'link must be up' part, because this is enforced in the code.
Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
cc: Andy Gospodarek <andy@greyhouse.net>
Unlike all of the other cpuid bits, the TSC deadline timer bit is set
unconditionally, regardless of what userspace wants.
This is broken in several ways:
- if userspace doesn't use KVM_CREATE_IRQCHIP, and doesn't emulate the TSC
deadline timer feature, a guest that uses the feature will break
- live migration to older host kernels that don't support the TSC deadline
timer will cause the feature to be pulled from under the guest's feet;
breaking it
- guests that are broken wrt the feature will fail.
Fix by not enabling the feature automatically; instead report it to userspace.
Because the feature depends on KVM_CREATE_IRQCHIP, which we cannot guarantee
will be called, we expose it via a KVM_CAP_TSC_DEADLINE_TIMER and not
KVM_GET_SUPPORTED_CPUID.
Fixes the Illumos guest kernel, which uses the TSC deadline timer feature.
[avi: add the KVM_CAP + documentation]
Reported-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Only allow KVM device assignment to attach to devices which:
- Are not bridges
- Have BAR resources (assume others are special devices)
- The user has permissions to use
Assigning a bridge is a configuration error, it's not supported, and
typically doesn't result in the behavior the user is expecting anyway.
Devices without BAR resources are typically chipset components that
also don't have host drivers. We don't want users to hold such devices
captive or cause system problems by fencing them off into an iommu
domain. We determine "permission to use" by testing whether the user
has access to the PCI sysfs resource files. By default a normal user
will not have access to these files, so it provides a good indication
that an administration agent has granted the user access to the device.
[Yang Bai: add missing #include]
[avi: fix comment style]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Yang Bai <hamo.by@gmail.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This option has no users and it exposes a security hole that we
can allow devices to be assigned without iommu protection. Make
KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option.
net/bluetooth/l2cap_core.c
Just two overlapping changes, one added an initialization of
a local variable, and another change added a new local variable.
Just fixed typo of sample code in packet_mmap.txt
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This reverts commit e5671dfae59b165e2adfd4dfbdeab11ac8db5bda.
After a follow up discussion with Michal, it was agreed it would
be better to leave the kmem controller with just the tcp files,
deferring the behavior of the other general memory.kmem.* files
for a later time, when more caches are controlled. This is because
generic kmem files are not used by tcp accounting and it is
not clear how other slab caches would fit into the scheme.
We are reverting the original commit so we can track the reference.
Part of the patch is kept, because it was used by the later tcp
code. Conflicts are shown in the bottom. init/Kconfig is removed from
the revert entirely.
Signed-off-by: Glauber Costa <glommer@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
CC: Kirill A. Shutemov <kirill@shutemov.name>
CC: Paul Menage <paul@paulmenage.org>
CC: Greg Thelen <gthelen@google.com>
CC: Johannes Weiner <jweiner@redhat.com>
CC: David S. Miller <davem@davemloft.net>
Documentation/cgroups/memory.txt
mm/memcontrol.c
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
Merge reason: Update with the latest fixes.
Fix some trivial typos.
Signed-off-by: Shan Wei <shanwei88@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/core
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: add missing spin_unlock at ceph_mdsc_build_path()
ceph: fix SEEK_CUR, SEEK_SET regression
crush: fix mapping calculation when force argument doesn't exist
ceph: use i_ceph_lock instead of i_lock
rbd: remove buggy rollback functionality
rbd: return an error when an invalid header is read
ceph: fix rasize reporting by ceph_show_options
This patch introduces kmem.tcp.usage_in_bytes file, living in the
kmem_cgroup filesystem. It is a simple read-only file that displays the
amount of kernel memory currently consumed by the cgroup.
Reviewed-by: Hiroyouki Kamezawa <kamezawa.hiroyu@jp.fujitsu.com>
CC: Eric W. Biederman <ebiederm@xmission.com>
This patch uses the "tcp.limit_in_bytes" field of the kmem_cgroup to
effectively control the amount of kernel memory pinned by a cgroup.
This value is ignored in the root cgroup, and in all others,
caps the value specified by the admin in the net namespaces'
view of tcp_sysctl_mem.
If namespaces are being used, the admin is allowed to set a
value bigger than cgroup's maximum, the same way it is allowed
to set pretty much unlimited values in a real box.
This patch introduces memory pressure controls for the tcp
protocol. It uses the generic socket memory pressure code
introduced in earlier patches, and fills in the
necessary data in cg_proto struct.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtisu.com>
The goal of this work is to move the memory pressure tcp
controls to a cgroup, instead of just relying on global
conditions.
To avoid excessive overhead in the network fast paths,
the code that accounts allocated memory to a cgroup is
hidden inside a static_branch(). This branch is patched out
until the first non-root cgroup is created. So when nobody
is using cgroups, even if it is mounted, no significant performance
penalty should be seen.
This patch handles the generic part of the code, and has nothing
tcp-specific.
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujtsu.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
This patch lays down the foundation for the kernel memory component
of the Memory Controller.
As of today, I am only laying down the following files:
* memory.independent_kmem_limit
* memory.kmem.limit_in_bytes (currently ignored)
* memory.kmem.usage_in_bytes (always zero)
CC: Michal Hocko <mhocko@suse.cz>
The Japanese/Korean/Chinese versions still need updating.
Also, the stable kernel 2.6.x.y descriptions are out of date
and should be updated as well.
Cc: stable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
Tyler Hicks pointed me at an additional article on RCU and I figured
it should probably be mentioned with the others.
An IRC discussion uncovered many conflicting opinions on what types
of data may be atomically loaded and stored. This commit therefore
calls this out the official set: pointers, longs, ints, and chars (but
not shorts). This commit also gives some examples of compiler mischief
that can thwart atomicity.
Please note that this discussion is relevant to !SMP kernels if
CONFIG_PREEMPT=y: preemption can cause almost as much trouble as can SMP.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Jes Sorensen <jes@sgi.com>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Running CPU-hotplug operations concurrently with rcutorture has
historically been a good way to find bugs in both RCU and CPU hotplug.
This commit therefore adds an rcutorture module parameter called
"onoff_interval" that causes a randomly selected CPU-hotplug operation to
be executed at the specified interval, in seconds. The default value of
"onoff_interval" is zero, which disables rcutorture-instigated CPU-hotplug
operations.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Although it is easy to run rcutorture tests under KVM, there is currently
no nice way to run such a test for a fixed time period, collect all of
the rcutorture data, and then shut the system down cleanly. This commit
therefore adds an rcutorture module parameter named "shutdown_secs" that
specified the run duration in seconds, after which rcutorture terminates
the test and powers the system down. The default value for "shutdown_secs"
is zero, which disables shutdown.
Update various files in Documentation/RCU to reflect srcu_read_lock_raw()
and srcu_read_unlock_raw(). Credit to Peter Zijlstra for suggesting
use of the existing _raw suffix instead of the earlier bulkref names.
One of lclaudio's systems was seeing RCU CPU stall warnings from idle.
These turned out to be caused by a bug that stopped scheduling-clock
tick interrupts from being sent to a given CPU for several hundred seconds.
This commit therefore updates the documentation to call this out as a
possible cause for RCU CPU stall warnings.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Earlier versions of RCU used the scheduling-clock tick to detect idleness
by checking for the idle task, but handled idleness differently for
CONFIG_NO_HZ=y. But there are now a number of uses of RCU read-side
critical sections in the idle task, for example, for tracing. A more
fine-grained detection of idleness is therefore required.
This commit presses the old dyntick-idle code into full-time service,
so that rcu_idle_enter(), previously known as rcu_enter_nohz(), is
always invoked at the beginning of an idle loop iteration. Similarly,
rcu_idle_exit(), previously known as rcu_exit_nohz(), is always invoked
at the end of an idle-loop iteration. This allows the idle task to
use RCU everywhere except between consecutive rcu_idle_enter() and
rcu_idle_exit() calls, in turn allowing architecture maintainers to
specify exactly where in the idle loop that RCU may be used.
Because some of the userspace upcall uses can result in what looks
to RCU like half of an interrupt, it is not possible to expect that
the irq_enter() and irq_exit() hooks will give exact counts. This
patch therefore expands the ->dynticks_nesting counter to 64 bits
and uses two separate bitfields to count process/idle transitions
and interrupt entry/exit transitions. It is presumed that userspace
upcalls do not happen in the idle loop or from usermode execution
(though usermode might do a system call that results in an upcall).
The counter is hard-reset on each process/idle transition, which
avoids the interrupt entry/exit error from accumulating. Overflow
is avoided by the 64-bitness of the ->dyntick_nesting counter.
This commit also adds warnings if a non-idle task asks RCU to enter
idle state (and these checks will need some adjustment before applying
Frederic's OS-jitter patches (http://lkml.org/lkml/2011/10/7/246).
In addition, validation of ->dynticks and ->dynticks_nesting is added.
There are a number of bugs that can leak or overuse lock classes,
which can cause the maximum number of lock classes (currently 8191)
to be exceeded. However, the documentation does not tell you how to
track down these problems. This commit addresses this shortcoming.
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
* 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
MAINTAINERS: Update amd-iommu F: patterns
iommu/amd: Fix typo in kernel-parameters.txt
iommu/msm: Fix compile error in mach-msm/devices-iommu.c
Fix comparison using wrong pointer variable in dma debug code
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda/realtek - Fix lost speaker volume controls
ALSA: hda/realtek - Create "Bass Speaker" for two speaker pins
ALSA: hda/realtek - Don't create extra controls with channel suffix
ALSA: hda - Fix remaining VREF mute-LED NID check in post-3.1 changes
ALSA: hda - Fix GPIO LED setup for IDT 92HD75 codecs
ASoC: Provide a more complete DMA driver stub
ASoC: Remove references to corgi and spitz from machine driver document
ASoC: Make SND_SOC_MX27VIS_AIC32X4 depend on I2C
ASoC: Fix dependency for SND_SOC_RAUMFELD and SND_PXA2XX_SOC_HX4700
ASoC: uda1380: Return proper error in uda1380_modinit failure path
ASoC: kirkwood: Make SND_KIRKWOOD_SOC_OPENRD and SND_KIRKWOOD_SOC_T5325 depend on I2C
ASoC: Mark WM8994 ADC muxes as virtual
ALSA: hda/realtek - Fix Oops in alc_mux_select()
ALSA: sis7019 - give slow codecs more time to reset
This code has been on the list to remove for a long
time, so disable it by default, add a warning to its
Kconfig, and schedule it for removal in 3.5.
The only known dependency, hal, has not required it
since its 0.5.12 release, which was in early 2009
and hal has since been deprecated completely.
This doesn't interact with resizing well, since it doesn't set the
size of the device to the size at the snapshot. It's also an expensive
operation to be synchronous. Rollback can still be done with the
userspace rbd tool.
Signed-off-by: Josh Durgin <josh.durgin@dreamhost.com>
With this patch the OProfile Basic Mode Sampling support for System z
is enhanced with a counter file system. That way hardware sampling
can be configured using the user space tools with only little
modifications.
With the patch by default new cpu_types (s390/z10, s390/z196) are
returned in order to indicate that we are running a CPU which provides
the hardware sampling facility. Existing user space tools will
complain about an unknown cpu type. In order to be compatible with
existing user space tools the `cpu_type' module parameter has been
added. Setting the parameter to `timer' will force the module to
return `timer' as cpu_type. The module will still try to use hardware
sampling if available and the hwsampling virtual filesystem will be
also be available for configuration. So this has a different effect
than using the generic oprofile module parameter `timer=1'.
If the basic mode sampling is enabled on the machine and the
cpu_type=timer parameter is not used the kernel module will provide
the following virtual filesystem:
/dev/oprofile/0/enabled
/dev/oprofile/0/event
/dev/oprofile/0/count
/dev/oprofile/0/unit_mask
/dev/oprofile/0/kernel
/dev/oprofile/0/user
In the counter file system only the values of 'enabled', 'count',
'kernel', and 'user' are evaluated by the kernel module. Everything
else must contain fixed values.
The 'event' value only supports a single event - HWSAMPLING with value
0.
The 'count' value specifies the hardware sampling rate as it is passed
to the CPU measurement facility.
The 'kernel' and 'user' flags can now be used to filter for samples
when using hardware sampling.
Additionally also the following file will be created:
/dev/oprofile/timer/enabled
This will always be the inverted value of /dev/oprofile/0/enabled. 0
is not accepted without hardware sampling.
Signed-off-by: Andreas Krebbel <krebbel@linux.vnet.ibm.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: Silence seq_scale() unused warning
ipv4:correct description for tcp_max_syn_backlog
pasemi_mac: Fix building as module
netback: Fix alert message.
r8169: fix Rx index race between FIFO overflow recovery and NAPI handler.
r8169: Rx FIFO overflow fixes.
ipv4: Fix peer validation on cached lookup.
ipv4: make sure RTO_ONLINK is saved in routing cache
iwlwifi: change the default behavior of watchdog timer
iwlwifi: do not re-configure HT40 after associated
iwlagn: fix HW crypto for TX-only keys
Revert "mac80211: clear sta.drv_priv on reconfiguration"
mac80211: fill rate filter for internal scan requests
cfg80211: amend regulatory NULL dereference fix
cfg80211: fix race on init and driver registration
Since commit c5ed63d66f24(tcp: fix three tcp sysctls tuning),
sysctl_max_syn_backlog is determined by tcp_hashinfo->ehash_mask,
and the minimal value is 128, and it will increase in proportion to the
memory of machine.
The original description for tcp_max_syn_backlog and sysctl_max_syn_backlog
are out of date.
Changelog:
V2: update description for sysctl_max_syn_backlog
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
Reviewed-by: Shan Wei <shanwei88@gmail.com>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
