path: root/Documentation
2015-09-10proc: export idle flag via kpageflagsVladimir Davydov
As noted by Minchan, a benefit of reading idle flag from /proc/kpageflags is that one can easily filter dirty and/or unevictable pages while estimating the size of unused memory. Note that idle flag read from /proc/kpageflags may be stale in case the page was accessed via a PTE, because it would be too costly to iterate over all page mappings on each /proc/kpageflags read to provide an up-to-date value. To make sure the flag is up-to-date one has to read /sys/kernel/mm/page_idle/bitmap first. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10mm: introduce idle page trackingVladimir Davydov
Knowing the portion of memory that is not used by a certain application or memory cgroup (idle memory) can be useful for partitioning the system efficiently, e.g. by setting memory cgroup limits appropriately. Currently, the only means to estimate the amount of idle memory provided by the kernel is /proc/PID/{clear_refs,smaps}: the user can clear the access bit for all pages mapped to a particular process by writing 1 to clear_refs, wait for some time, and then count smaps:Referenced. However, this method has two serious shortcomings: - it does not count unmapped file pages - it affects the reclaimer logic To overcome these drawbacks, this patch introduces two new page flags, Idle and Young, and a new sysfs file, /sys/kernel/mm/page_idle/bitmap. A page's Idle flag can only be set from userspace by setting bit in /sys/kernel/mm/page_idle/bitmap at the offset corresponding to the page, and it is cleared whenever the page is accessed either through page tables (it is cleared in page_referenced() in this case) or using the read(2) system call (mark_page_accessed()). Thus by setting the Idle flag for pages of a particular workload, which can be found e.g. by reading /proc/PID/pagemap, waiting for some time to let the workload access its working set, and then reading the bitmap file, one can estimate the amount of pages that are not used by the workload. The Young page flag is used to avoid interference with the memory reclaimer. A page's Young flag is set whenever the Access bit of a page table entry pointing to the page is cleared by writing to the bitmap file. If page_referenced() is called on a Young page, it will add 1 to its return value, therefore concealing the fact that the Access bit was cleared. Note, since there is no room for extra page flags on 32 bit, this feature uses extended page flags when compiled on 32 bit. [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: kpageidle requires an MMU] [akpm@linux-foundation.org: decouple from page-flags rework] Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10proc: add kpagecgroup fileVladimir Davydov
/proc/kpagecgroup contains a 64-bit inode number of the memory cgroup each page is charged to, indexed by PFN. Having this information is useful for estimating a cgroup working set size. The file is present if CONFIG_PROC_PAGE_MONITOR && CONFIG_MEMCG. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Andres Lagar-Cavilla <andreslc@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-10zswap: update docs for runtime-changeable attributesDan Streetman
Change the Documentation/vm/zswap.txt doc to indicate that the "zpool" and "compressor" params are now changeable at runtime. Signed-off-by: Dan Streetman <ddstreet@ieee.org> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-09Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull inifiniband/rdma updates from Doug Ledford: "This is a fairly sizeable set of changes. I've put them through a decent amount of testing prior to sending the pull request due to that. There are still a few fixups that I know are coming, but I wanted to go ahead and get the big, sizable chunk into your hands sooner rather than waiting for those last few fixups. Of note is the fact that this creates what is intended to be a temporary area in the drivers/staging tree specifically for some cleanups and additions that are coming for the RDMA stack. We deprecated two drivers (ipath and amso1100) and are waiting to hear back if we can deprecate another one (ehca). We also put Intel's new hfi1 driver into this area because it needs to be refactored and a transfer library created out of the factored out code, and then it and the qib driver and the soft-roce driver should all be modified to use that library. I expect drivers/staging/rdma to be around for three or four kernel releases and then to go away as all of the work is completed and final deletions of deprecated drivers are done. Summary of changes for 4.3: - Create drivers/staging/rdma - Move amso1100 driver to staging/rdma and schedule for deletion - Move ipath driver to staging/rdma and schedule for deletion - Add hfi1 driver to staging/rdma and set TODO for move to regular tree - Initial support for namespaces to be used on RDMA devices - Add RoCE GID table handling to the RDMA core caching code - Infrastructure to support handling of devices with differing read and write scatter gather capabilities - Various iSER updates - Kill off unsafe usage of global mr registrations - Update SRP driver - Misc mlx4 driver updates - Support for the mr_alloc verb - Support for a netlink interface between kernel and user space cache daemon to speed path record queries and route resolution - Ininitial support for safe hot removal of verbs devices" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (136 commits) IB/ipoib: Suppress warning for send only join failures IB/ipoib: Clean up send-only multicast joins IB/srp: Fix possible protection fault IB/core: Move SM class defines from ib_mad.h to ib_smi.h IB/core: Remove unnecessary defines from ib_mad.h IB/hfi1: Add PSM2 user space header to header_install IB/hfi1: Add CSRs for CONFIG_SDMA_VERBOSITY mlx5: Fix incorrect wc pkey_index assignment for GSI messages IB/mlx5: avoid destroying a NULL mr in reg_user_mr error flow IB/uverbs: reject invalid or unknown opcodes IB/cxgb4: Fix if statement in pick_local_ip6adddrs IB/sa: Fix rdma netlink message flags IB/ucma: HW Device hot-removal support IB/mlx4_ib: Disassociate support IB/uverbs: Enable device removal when there are active user space applications IB/uverbs: Explicitly pass ib_dev to uverbs commands IB/uverbs: Fix race between ib_uverbs_open and remove_one IB/uverbs: Fix reference counting usage of event files IB/core: Make ib_dealloc_pd return void IB/srp: Create an insecure all physical rkey only if needed ...
2015-09-08Merge tag 'for-linus-4.3' of git://git.code.sf.net/p/openipmi/linux-ipmiLinus Torvalds
Pull IPMI updates from Corey Minyard: "Most of these have been sitting in linux-next for more than a release, particularly commit 0fbcf4af7c83 ("ipmi: Convert the IPMI SI ACPI handling to a platform device") which is probably the most complex patch. That is also the one that changes drivers/acpi/acpi_pnp.c. The change in that file is only removing IPMI from a "special platform devices" list, since I convert it to the standard PNP interface. I posted this one to the ACPI list twice and got no response, and it seems to work well in my testing, so I'm hoping it's good. Hidehiro Kawai posted a set of changes that improves the panic time handling in the IPMI driver. The rest of the changes are minor bug fixes or cleanups and some documentation" * tag 'for-linus-4.3' of git://git.code.sf.net/p/openipmi/linux-ipmi: ipmi:ssif: Add a module parm to specify that SMBus alerts don't work ipmi: add of_device_id in MODULE_DEVICE_TABLE ipmi: Compensate for BMCs that wont set the irq enable bit ipmi: Don't call receive handler in the panic context ipmi: Avoid touching possible corrupted lists in the panic context ipmi: Don't flush messages in sender() in run-to-completion mode ipmi: Factor out message flushing procedure ipmi: Remove unneeded set_run_to_completion call ipmi: Make some data const that was only read ipmi: constify SSIF ACPI device ids ipmi: Delete an unnecessary check before the function call "cleanup_one_si" char:ipmi - Change 1 to true for bool type variables during initialization. impi:Remove unneeded setting of module owner to THIS_MODULE in the platform structure, powernv_ipmi_driver ipmi: Add a comment in how messages are delivered from the lower layer ipmi/powernv: Fix potential invalid pointer dereference ipmi: Convert the IPMI SI ACPI handling to a platform device ipmi: Add device tree bindings information
2015-09-08Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: "Almost all of the rest of MM. There was an unusually large amount of MM material this time" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (141 commits) zpool: remove no-op module init/exit mm: zbud: constify the zbud_ops mm: zpool: constify the zpool_ops mm: swap: zswap: maybe_preload & refactoring zram: unify error reporting zsmalloc: remove null check from destroy_handle_cache() zsmalloc: do not take class lock in zs_shrinker_count() zsmalloc: use class->pages_per_zspage zsmalloc: consider ZS_ALMOST_FULL as migrate source zsmalloc: partial page ordering within a fullness_list zsmalloc: use shrinker to trigger auto-compaction zsmalloc: account the number of compacted pages zsmalloc/zram: introduce zs_pool_stats api zsmalloc: cosmetic compaction code adjustments zsmalloc: introduce zs_can_compact() function zsmalloc: always keep per-class stats zsmalloc: drop unused variable `nr_to_migrate' mm/memblock.c: fix comment in __next_mem_range() mm/page_alloc.c: fix type information of memoryless node memory-hotplug: fix comments in zone_spanned_pages_in_node() and zone_spanned_pages_in_node() ...
2015-09-08Merge tag 'iommu-updates-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull iommu updates for from Joerg Roedel: "This time the IOMMU updates are mostly cleanups or fixes. No big new features or drivers this time. In particular the changes include: - Bigger cleanup of the Domain<->IOMMU data structures and the code that manages them in the Intel VT-d driver. This makes the code easier to understand and maintain, and also easier to keep the data structures in sync. It is also a preparation step to make use of default domains from the IOMMU core in the Intel VT-d driver. - Fixes for a couple of DMA-API misuses in ARM IOMMU drivers, namely in the ARM and Tegra SMMU drivers. - Fix for a potential buffer overflow in the OMAP iommu driver's debug code - A couple of smaller fixes and cleanups in various drivers - One small new feature: Report domain-id usage in the Intel VT-d driver to easier detect bugs where these are leaked" * tag 'iommu-updates-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (83 commits) iommu/vt-d: Really use upper context table when necessary x86/vt-d: Fix documentation of DRHD iommu/fsl: Really fix init section(s) content iommu/io-pgtable-arm: Unmap and free table when overwriting with block iommu/io-pgtable-arm: Move init-fn declarations to io-pgtable.h iommu/msm: Use BUG_ON instead of if () BUG() iommu/vt-d: Access iomem correctly iommu/vt-d: Make two functions static iommu/vt-d: Use BUG_ON instead of if () BUG() iommu/vt-d: Return false instead of 0 in irq_remapping_cap() iommu/amd: Use BUG_ON instead of if () BUG() iommu/amd: Make a symbol static iommu/amd: Simplify allocation in irq_remapping_alloc() iommu/tegra-smmu: Parameterize number of TLB lines iommu/tegra-smmu: Factor out tegra_smmu_set_pde() iommu/tegra-smmu: Extract tegra_smmu_pte_get_use() iommu/tegra-smmu: Use __GFP_ZERO to allocate zeroed pages iommu/tegra-smmu: Remove PageReserved manipulation iommu/tegra-smmu: Convert to use DMA API iommu/tegra-smmu: smmu_flush_ptc() wants device addresses ...
2015-09-08Merge tag 'mmc-v4.3' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC updates from Ulf Hansson: "MMC core: - Fix a race condition in the request handling - Skip trim commands for some buggy kingston eMMCs - An optimization and a correction for erase groups - Set CMD23 quirk for some Sandisk cards MMC host: - sdhci: Give GPIO CD higher precedence and don't poll when it's used - sdhci: Fix DMA memory leakage - sdhci: Some updates for clock management - sdhci-of-at91: introduce driver for the Atmel SDMMC - sdhci-of-arasan: Add support for sdhci-5.1 - sdhci-esdhc-imx: Add support for imx7d which also supports HS400 - sdhci: A collection of fixes and improvements for various sdhci hosts - omap_hsmmc: Modernization of the regulator code - dw_mmc: A couple of fixes for DMA and PIO mode - usdhi6rol0: A few fixes and support probe deferral for regulators - pxamci: Convert to use dmaengine - sh_mmcif: Fix the suspend process in a short term solution - tmio: Adjust timeout for commands - sunxi: Fix timeout while gating/ungating clock" * tag 'mmc-v4.3' of git://git.linaro.org/people/ulf.hansson/mmc: (67 commits) mmc: android-goldfish: remove incorrect __iomem annotation mmc: core: fix race condition in mmc_wait_data_done mmc: host: omap_hsmmc: remove CONFIG_REGULATOR check mmc: host: omap_hsmmc: use ios->vdd for setting vmmc voltage mmc: host: omap_hsmmc: use regulator_is_enabled to find pbias status mmc: host: omap_hsmmc: enable/disable vmmc_aux regulator based on previous state mmc: host: omap_hsmmc: don't use ->set_power to set initial regulator state mmc: host: omap_hsmmc: avoid pbias regulator enable on power off mmc: host: omap_hsmmc: add separate function to set pbias mmc: host: omap_hsmmc: add separate functions for enable/disable supply mmc: host: omap_hsmmc: return error if any of the regulator APIs fail mmc: host: omap_hsmmc: remove unnecessary pbias set_voltage mmc: host: omap_hsmmc: use mmc_host's vmmc and vqmmc mmc: host: omap_hsmmc: use the ocrmask provided by the vmmc regulator mmc: host: omap_hsmmc: cleanup omap_hsmmc_reg_get() mmc: host: omap_hsmmc: return on fatal errors from omap_hsmmc_reg_get mmc: host: omap_hsmmc: use devm_regulator_get_optional() for vmmc mmc: sdhci-of-at91: fix platform_no_drv_owner.cocci warnings mmc: sh_mmcif: Fix suspend process mmc: usdhi6rol0: fix error return code ...
2015-09-08Merge tag 'platform-drivers-x86-v4.3-1' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver updates from Darren Hart: "Significant work on toshiba_acpi, including new hardware support, refactoring, and cleanups. Extend device support for asus, ideapad, and acer systems. New surface pro 3 buttons driver. Misc minor cleanups for thinkpad and hp-wireless. acer-wmi: - No rfkill on HP Omen 15 wifi thinkpad_acpi: - Remove side effects from vdbg_printk -> no_printk macro surface pro 3: - Add support driver for Surface Pro 3 buttons hp-wireless: - remove unneeded goto/label in hpwl_init ideapad-laptop: - add alternative representation for Yoga 2 to DMI table - Add Lenovo Yoga 3 14 to no_hw_rfkill dmi list asus-laptop: - Add key found on Asus F3M MAINTAINERS: - Remove Toshiba Linux mailing list address toshiba_acpi: - Bump driver version to 0.23 - Remove unnecessary checks and returns in HCI/SCI functions - Refactor *{get, set} functions return value - Remove "*not supported" feature prints - Change *available functions return type - Add set_fan_status function - Change some variables to avoid warnings from ninja-check - Reorder toshiba_acpi_alt_keymap entries - Remove unused wireless defines - Transflective backlight updates - Avoid registering input device on WMI event laptops - Add /dev/toshiba_acpi device - Adapt /proc/acpi/toshiba/keys to TOS1900 devices" * tag 'platform-drivers-x86-v4.3-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (21 commits) acer-wmi: No rfkill on HP Omen 15 wifi thinkpad_acpi: Remove side effects from vdbg_printk -> no_printk macro surface pro 3: Add support driver for Surface Pro 3 buttons hp-wireless: remove unneeded goto/label in hpwl_init ideapad-laptop: add alternative representation for Yoga 2 to DMI table asus-laptop: Add key found on Asus F3M MAINTAINERS: Remove Toshiba Linux mailing list address ideapad-laptop: Add Lenovo Yoga 3 14 to no_hw_rfkill dmi list toshiba_acpi: Bump driver version to 0.23 toshiba_acpi: Remove unnecessary checks and returns in HCI/SCI functions toshiba_acpi: Refactor *{get, set} functions return value toshiba_acpi: Remove "*not supported" feature prints toshiba_acpi: Change *available functions return type toshiba_acpi: Add set_fan_status function toshiba_acpi: Change some variables to avoid warnings from ninja-check toshiba_acpi: Reorder toshiba_acpi_alt_keymap entries toshiba_acpi: Remove unused wireless defines toshiba_acpi: Transflective backlight updates toshiba_acpi: Avoid registering input device on WMI event laptops toshiba_acpi: Add /dev/toshiba_acpi device ...
2015-09-08Merge branch 'i2c/for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Features: - new drivers: Renesas EMEV2, register based MUX, NXP LPC2xxx - core: scans DT and assigns wakeup interrupts. no driver changes needed. - core: some refcouting issues fixed and better API for that - core: new helper function for best effort block read emulation - slave framework: proper DT bindings and userspace instantiation - some bigger work for xiic, pxa, omap drivers .. and quite a number of smaller driver fixes, cleanups, improvements" * 'i2c/for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (65 commits) i2c: mux: reg Change ioread endianness for readback i2c: mux: reg: fix compilation warnings i2c: mux: reg: simplify register size checking i2c: muxes: fix leaked i2c adapter device node references i2c: allow specifying separate wakeup interrupt in device tree of/irq: export of_get_irq_byname() i2c: xgene-slimpro: dma_mapping_error() doesn't return an error code i2c: Replace I2C_CROS_EC_TUNNEL dependency eeprom: at24: use i2c_smbus_read_i2c_block_data_or_emulated i2c: core: Add support for best effort block read emulation i2c: lpc2k: add driver i2c: mux: Add register-based mux i2c-mux-reg i2c: dt: describe generic bindings i2c: slave: print warning if slave flag not set i2c: support 10 bit and slave addresses in sysfs 'new_device' i2c: take address space into account when checking for used addresses i2c: apply DT flags when probing i2c: make address check indpendent from client struct i2c: rename address check functions i2c: apply address offset for slaves, too ...
2015-09-08Merge tag 'rtc-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull RTC updates from Alexandre Belloni: "Core: - use is_visible() to control sysfs attributes - switch wakealarm attribute to DEVICE_ATTR_RW - make rtc_does_wakealarm() return boolean - properly manage lifetime of dev and cdev in rtc device - remove unnecessary device_get() in rtc_device_unregister - fix double free in rtc_register_device() error path New drivers: - NXP LPC24xx - Xilinx Zynq MP - Dialog DA9062 Subsystem wide cleanups: - fix drivers that consider 0 as a valid IRQ in client->irq - Drop (un)likely before IS_ERR(_OR_NULL) - drop the remaining owner assignment for i2c_driver and platform_driver - module autoload fixes Drivers: - 88pm80x: add device tree support - abx80x: fix RTC write bit - ab8500: Add a sentinel to ab85xx_rtc_ids[] - armada38x: Align RTC set time procedure with the official errata - as3722: correct month value - at91sam9: cleanups - at91rm9200: get and use slow clock and cleanups - bq32k: remove redundant check - cmos: century support, proper fix for the spurious wakeup - ds1307: cleanups and wakeup irq support - ds1374: Remove unused variable - ds1685: Use module_platform_driver - ds3232: fix WARNING trace in resume function - gemini: fix ptr_ret.cocci warnings - mt6397: implement suspend/resume - omap: support internal and external clock enabling - opal: Enable alarms only when opal supports tpo - pcf2127: use OFS flag to detect unreliable date and warn the user - pl031: fix typo for author email - rx8025: huge cleanup and fixes - sa1100/pxa: share common code - s5m: fix to update ctrl register - s3c: fix clocks and wakeup, cleanup - sirfsoc: use regmap - nvram_read()/nvram_write() functions for cmos, ds1305, ds1307, ds1343, ds1511, ds1553, ds1742, m48t59, rp5c01, stk17ta8, tx4939 - use rtc_valid_tm() error code when reading date/time instead of 0 for isl12022, pcf2123, pcf2127" * tag 'rtc-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (90 commits) rtc: abx80x: fix RTC write bit rtc: ab8500: Add a sentinel to ab85xx_rtc_ids[] rtc: ds1374: Remove unused variable rtc: Fix module autoload for OF platform drivers rtc: Fix module autoload for rtc-{ab8500,max8997,s5m} drivers rtc: omap: Add external clock enabling support rtc: omap: Add internal clock enabling support ARM: dts: AM437x: Add the internal and external clock nodes for rtc rtc: s5m: fix to update ctrl register rtc: add xilinx zynqmp rtc driver devicetree: bindings: rtc: add bindings for xilinx zynqmp rtc rtc: as3722: correct month value ARM: config: Switch PXA27x platforms to use PXA RTC driver ARM: mmp: remove unused RTC register definitions ARM: sa1100: remove unused RTC register definitions rtc: sa1100/pxa: convert to run-time register mapping ARM: pxa: add memory resource to SA1100 RTC device rtc: pxa: convert to use shared sa1100 functions rtc: sa1100: prepare to share sa1100_rtc_ops rtc: ds3232: fix WARNING trace in resume function ...
2015-09-08zsmalloc: account the number of compacted pagesSergey Senozhatsky
Compaction returns back to zram the number of migrated objects, which is quite uninformative -- we have objects of different sizes so user space cannot obtain any valuable data from that number. Change compaction to operate in terms of pages and return back to compaction issuer the number of pages that were freed during compaction. So from now on we will export more meaningful value in zram<id>/mm_stat -- the number of freed (compacted) pages. This requires: (a) a rename of `num_migrated' to 'pages_compacted' (b) a internal API change -- return first_page's fullness_group from putback_zspage(), so we know when putback_zspage() did free_zspage(). It helps us to account compaction stats correctly. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm/page_alloc.c: fix a misleading commentYaowei Bai
The comment says that the per-cpu batchsize and zone watermarks are determined by present_pages which is definitely wrong, they are both calculated from managed_pages. Fix it. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08Documentation: update libhugetlbfs location and use for testingMike Kravetz
The URL for libhugetlbfs has changed. Also, put a stronger emphasis on using libgugetlbfs for hugetlb regression testing. Signed-off-by: Mike Kravetz <mike.kravetz@oracle.com> Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Joern Engel <joern@logfs.org> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: David Rientjes <rientjes@google.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm: add dma_pool_zalloc() call to DMA APISean O. Stalley
Add a wrapper function for dma_pool_alloc() to get zeroed memory. Signed-off-by: Sean O. Stalley <sean.stalley@intel.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Gilles Muller <Gilles.Muller@lip6.fr> Cc: Nicolas Palix <nicolas.palix@imag.fr> Cc: Michal Marek <mmarek@suse.cz> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm, oom: do not panic for oom kills triggered from sysrqDavid Rientjes
Sysrq+f is used to kill a process either for debug or when the VM is otherwise unresponsive. It is not intended to trigger a panic when no process may be killed. Avoid panicking the system for sysrq+f when no processes are killed. Signed-off-by: David Rientjes <rientjes@google.com> Suggested-by: Michal Hocko <mhocko@suse.cz> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08mm: /proc/pid/smaps:: show proportional swap share of the mappingMinchan Kim
We want to know per-process workingset size for smart memory management on userland and we use swap(ex, zram) heavily to maximize memory efficiency so workingset includes swap as well as RSS. On such system, if there are lots of shared anonymous pages, it's really hard to figure out exactly how many each process consumes memory(ie, rss + wap) if the system has lots of shared anonymous memory(e.g, android). This patch introduces SwapPss field on /proc/<pid>/smaps so we can get more exact workingset size per process. Bongkyu tested it. Result is below. 1. 50M used swap SwapTotal: 461976 kB SwapFree: 411192 kB $ adb shell cat /proc/*/smaps | grep "SwapPss:" | awk '{sum += $2} END {print sum}'; 48236 $ adb shell cat /proc/*/smaps | grep "Swap:" | awk '{sum += $2} END {print sum}'; 141184 2. 240M used swap SwapTotal: 461976 kB SwapFree: 216808 kB $ adb shell cat /proc/*/smaps | grep "SwapPss:" | awk '{sum += $2} END {print sum}'; 230315 $ adb shell cat /proc/*/smaps | grep "Swap:" | awk '{sum += $2} END {print sum}'; 1387744 [akpm@linux-foundation.org: simplify kunmap_atomic() call] Signed-off-by: Minchan Kim <minchan@kernel.org> Reported-by: Bongkyu Kim <bongkyu.kim@lge.com> Tested-by: Bongkyu Kim <bongkyu.kim@lge.com> Cc: Hugh Dickins <hughd@google.com> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08pagemap: update documentationKonstantin Khlebnikov
Notes about recent changes. [akpm@linux-foundation.org: various tweaks] Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: Mark Williamson <mwilliamson@undo-software.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08pagemap: add mmap-exclusive bit for marking pages mapped only hereKonstantin Khlebnikov
This patch sets bit 56 in pagemap if this page is mapped only once. It allows to detect exclusively used pages without exposing PFN: present file exclusive state 0 0 0 non-present 1 1 0 file page mapped somewhere else 1 1 1 file page mapped only here 1 0 0 anon non-CoWed page (shared with parent/child) 1 0 1 anon CoWed page (or never forked) CoWed pages in (MAP_FILE | MAP_PRIVATE) areas are anon in this context. MMap-exclusive bit doesn't reflect potential page-sharing via swapcache: page could be mapped once but has several swap-ptes which point to it. Application could detect that by swap bit in pagemap entry and touch that pte via /proc/pid/mem to get real information. See http://lkml.kernel.org/r/CAEVpBa+_RyACkhODZrRvQLs80iy0sqpdrd0AaP_-tgnX3Y9yNQ@mail.gmail.com Requested by Mark Williamson. [akpm@linux-foundation.org: fix spello] Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Reviewed-by: Mark Williamson <mwilliamson@undo-software.com> Tested-by: Mark Williamson <mwilliamson@undo-software.com> Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08dax: add huge page fault supportMatthew Wilcox
This is the support code for DAX-enabled filesystems to allow them to provide huge pages in response to faults. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-08Merge tag 'libnvdimm-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "This update has successfully completed a 0day-kbuild run and has appeared in a linux-next release. The changes outside of the typical drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and the introduction of ZONE_DEVICE + devm_memremap_pages(). Summary: - Introduce ZONE_DEVICE and devm_memremap_pages() as a generic mechanism for adding device-driver-discovered memory regions to the kernel's direct map. This facility is used by the pmem driver to enable pfn_to_page() operations on the page frames returned by DAX ('direct_access' in 'struct block_device_operations'). For now, the 'memmap' allocation for these "device" pages comes from "System RAM". Support for allocating the memmap from device memory will arrive in a later kernel. - Introduce memremap() to replace usages of ioremap_cache() and ioremap_wt(). memremap() drops the __iomem annotation for these mappings to memory that do not have i/o side effects. The replacement of ioremap_cache() with memremap() is limited to the pmem driver to ease merging the api change in v4.3. Completion of the conversion is targeted for v4.4. - Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem driver, update the VFS DAX implementation and PMEM api to provide persistence guarantees for kernel operations on a DAX mapping. - Convert the ACPI NFIT 'BLK' driver to map the block apertures as cacheable to improve performance. - Miscellaneous updates and fixes to libnvdimm including support for issuing "address range scrub" commands, clarifying the optimal 'sector size' of pmem devices, a clarification of the usage of the ACPI '_STA' (status) property for DIMM devices, and other minor fixes" * tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits) libnvdimm, pmem: direct map legacy pmem by default libnvdimm, pmem: 'struct page' for pmem libnvdimm, pfn: 'struct page' provider infrastructure x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB add devm_memremap_pages mm: ZONE_DEVICE for "device memory" mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h dax: drop size parameter to ->direct_access() nd_blk: change aperture mapping from WC to WB nvdimm: change to use generic kvfree() pmem, dax: have direct_access use __pmem annotation dax: update I/O path to do proper PMEM flushing pmem: add copy_from_iter_pmem() and clear_pmem() pmem, x86: clean up conditional pmem includes pmem: remove layer when calling arch_has_wmb_pmem() pmem, x86: move x86 PMEM API to new pmem.h header libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option pmem: switch to devm_ allocations devres: add devm_memremap libnvdimm, btt: write and validate parent_uuid ...
2015-09-08Merge tag 'trace-v4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing update from Steven Rostedt: "Mostly this is just clean ups and micro optimizations. The changes with more meat are: - Allowing the trace event filters to filter on CPU number and process ids - Two new markers for trace output latency were added (10 and 100 msec latencies) - Have tracing_thresh filter function profiling time I also worked on modifying the ring buffer code for some future work, and moved the adding of the timestamp around. One of my changes caused a regression, and since other changes were built on top of it and already tested, I had to operate a revert of that change. Instead of rebasing, this change set has the code that caused a regression as well as the code to revert that change without touching the other changes that were made on top of it" * tag 'trace-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer: Revert "ring-buffer: Get timestamp after event is allocated" tracing: Don't make assumptions about length of string on task rename tracing: Allow triggers to filter for CPU ids and process names ftrace: Format MCOUNT_ADDR address as type unsigned long tracing: Introduce two additional marks for delay ftrace: Fix function_graph duration spacing with 7-digits ftrace: add tracing_thresh to function profile tracing: Clean up stack tracing and fix fentry updates ring-buffer: Reorganize function locations ring-buffer: Make sure event has enough room for extend and padding ring-buffer: Get timestamp after event is allocated ring-buffer: Move the adding of the extended timestamp out of line ring-buffer: Add event descriptor to simplify passing data ftrace: correct the counter increment for trace_buffer data tracing: Fix for non-continuous cpu ids tracing: Prefer kcalloc over kzalloc with multiply
2015-09-08Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - PKCS#7 support added to support signed kexec, also utilized for module signing. See comments in 3f1e1bea. ** NOTE: this requires linking against the OpenSSL library, which must be installed, e.g. the openssl-devel on Fedora ** - Smack - add IPv6 host labeling; ignore labels on kernel threads - support smack labeling mounts which use binary mount data - SELinux: - add ioctl whitelisting (see http://kernsec.org/files/lss2015/vanderstoep.pdf) - fix mprotect PROT_EXEC regression caused by mm change - Seccomp: - add ptrace options for suspend/resume" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (57 commits) PKCS#7: Add OIDs for sha224, sha284 and sha512 hash algos and use them Documentation/Changes: Now need OpenSSL devel packages for module signing scripts: add extract-cert and sign-file to .gitignore modsign: Handle signing key in source tree modsign: Use if_changed rule for extracting cert from module signing key Move certificate handling to its own directory sign-file: Fix warning about BIO_reset() return value PKCS#7: Add MODULE_LICENSE() to test module Smack - Fix build error with bringup unconfigured sign-file: Document dependency on OpenSSL devel libraries PKCS#7: Appropriately restrict authenticated attributes and content type KEYS: Add a name for PKEY_ID_PKCS7 PKCS#7: Improve and export the X.509 ASN.1 time object decoder modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYS extract-cert: Cope with multiple X.509 certificates in a single file sign-file: Generate CMS message as signature instead of PKCS#7 PKCS#7: Support CMS messages also [RFC5652] X.509: Change recorded SKID & AKID to not include Subject or Issuer PKCS#7: Check content type and versions MAINTAINERS: The keyrings mailing list has moved ...
2015-09-08Merge tag 'for-linus-4.3-rc0-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen updates from David Vrabel: "Xen features and fixes for 4.3: - Convert xen-blkfront to the multiqueue API - [arm] Support binding event channels to different VCPUs. - [x86] Support > 512 GiB in a PV guests (off by default as such a guest cannot be migrated with the current toolstack). - [x86] PMU support for PV dom0 (limited support for using perf with Xen and other guests)" * tag 'for-linus-4.3-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (33 commits) xen: switch extra memory accounting to use pfns xen: limit memory to architectural maximum xen: avoid another early crash of memory limited dom0 xen: avoid early crash of memory limited dom0 arm/xen: Remove helpers which are PV specific xen/x86: Don't try to set PCE bit in CR4 xen/PMU: PMU emulation code xen/PMU: Intercept PMU-related MSR and APIC accesses xen/PMU: Describe vendor-specific PMU registers xen/PMU: Initialization code for Xen PMU xen/PMU: Sysfs interface for setting Xen PMU mode xen: xensyms support xen: remove no longer needed p2m.h xen: allow more than 512 GB of RAM for 64 bit pv-domains xen: move p2m list if conflicting with e820 map xen: add explicit memblock_reserve() calls for special pages mm: provide early_memremap_ro to establish read-only mapping xen: check for initrd conflicting with e820 map xen: check pre-allocated page tables for conflict with memory map xen: check for kernel memory conflicting with memory layout ...
2015-09-07Merge tag 'nfs-for-4.3-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: Stable patches: - Fix atomicity of pNFS commit list updates - Fix NFSv4 handling of open(O_CREAT|O_EXCL|O_RDONLY) - nfs_set_pgio_error sometimes misses errors - Fix a thinko in xs_connect() - Fix borkage in _same_data_server_addrs_locked() - Fix a NULL pointer dereference of migration recovery ops for v4.2 client - Don't let the ctime override attribute barriers. - Revert "NFSv4: Remove incorrect check in can_open_delegated()" - Ensure flexfiles pNFS driver updates the inode after write finishes - flexfiles must not pollute the attribute cache with attrbutes from the DS - Fix a protocol error in layoutreturn - Fix a protocol issue with NFSv4.1 CLOSE stateids Bugfixes + cleanups - pNFS blocks bugfixes from Christoph - Various cleanups from Anna - More fixes for delegation corner cases - Don't fsync twice for O_SYNC/IS_SYNC files - Fix pNFS and flexfiles layoutstats bugs - pnfs/flexfiles: avoid duplicate tracking of mirror data - pnfs: Fix layoutget/layoutreturn/return-on-close serialisation issues - pnfs/flexfiles: error handling retries a layoutget before fallback to MDS Features: - Full support for the OPEN NFS4_CREATE_EXCLUSIVE4_1 mode from Kinglong - More RDMA client transport improvements from Chuck - Removal of the deprecated ib_reg_phys_mr() and ib_rereg_phys_mr() verbs from the SUNRPC, Lustre and core infiniband tree. - Optimise away the close-to-open getattr if there is no cached data" * tag 'nfs-for-4.3-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (108 commits) NFSv4: Respect the server imposed limit on how many changes we may cache NFSv4: Express delegation limit in units of pages Revert "NFS: Make close(2) asynchronous when closing NFS O_DIRECT files" NFS: Optimise away the close-to-open getattr if there is no cached data NFSv4.1/flexfiles: Clean up ff_layout_write_done_cb/ff_layout_commit_done_cb NFSv4.1/flexfiles: Mark the layout for return in ff_layout_io_track_ds_error() nfs: Remove unneeded checking of the return value from scnprintf nfs: Fix truncated client owner id without proto type NFSv4.1/flexfiles: Mark layout for return if the mirrors are invalid NFSv4.1/flexfiles: RW layouts are valid only if all mirrors are valid NFSv4.1/flexfiles: Fix incorrect usage of pnfs_generic_mark_devid_invalid() NFSv4.1/flexfiles: Fix freeing of mirrors NFSv4.1/pNFS: Don't request a minimal read layout beyond the end of file NFSv4.1/pnfs: Handle LAYOUTGET return values correctly NFSv4.1/pnfs: Don't ask for a read layout for an empty file. NFSv4.1: Fix a protocol issue with CLOSE stateids NFSv4.1/flexfiles: Don't mark the entire deviceid as bad for file errors SUNRPC: Prevent SYN+SYNACK+RST storms SUNRPC: xs_reset_transport must mark the connection as disconnected NFSv4.1/pnfs: Ensure layoutreturn reserves space for the opaque payload ...
2015-09-05Merge tag 'media/v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - new DVB frontend drivers: ascot2e, cxd2841er, horus3a, lnbh25 - new HDMI capture driver: tc358743 - new driver for NetUP DVB new boards (netup_unidvb) - IR support for DVBSky cards (smipcie-ir) - Coda driver has gain macroblock tiling support - Renesas R-Car gains JPEG codec driver - new DVB platform driver for STi boards: c8sectpfe - added documentation for the media core kABI to device-drivers DocBook - lots of driver fixups, cleanups and improvements * tag 'media/v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (297 commits) [media] c8sectpfe: Remove select on undefined LIBELF_32 [media] i2c: fix platform_no_drv_owner.cocci warnings [media] cx231xx: Use wake_up_interruptible() instead of wake_up_interruptible_nr() [media] tc358743: only queue subdev notifications if devnode is set [media] tc358743: add missing Kconfig dependency/select [media] c8sectpfe: Use %pad to print 'dma_addr_t' [media] DocBook media: Fix typo "the the" in xml files [media] tc358743: make reset gpio optional [media] tc358743: set direction of reset gpio using devm_gpiod_get [media] dvbdev: document most of the functions/data structs [media] dvb_frontend.h: document the struct dvb_frontend [media] dvb-frontend.h: document struct dtv_frontend_properties [media] dvb-frontend.h: document struct dvb_frontend_ops [media] dvb: Use DVBFE_ALGO_HW where applicable [media] dvb_frontend.h: document struct analog_demod_ops [media] dvb_frontend.h: Document struct dvb_tuner_ops [media] Docbook: Document struct analog_parameters [media] dvb_frontend.h: get rid of dvbfe_modcod [media] add documentation for struct dvb_tuner_info [media] dvb_frontend: document dvb_frontend_tune_settings ...
2015-09-05Merge tag 'md/4.3' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: - an assortment of little fixes, several for minor races only likely to be hit during testing - further cluster-md-raid1 development, not ready for real use yet. - new RAID6 syndrome code for ARM NEON - fix a race where a write can return before failure of one device is properly recorded in metadata, so an immediate crash might result in that write being lost. * tag 'md/4.3' of git://neil.brown.name/md: (33 commits) md/raid5: ensure device failure recorded before write request returns. md/raid5: use bio_list for the list of bios to return. md/raid10: ensure device failure recorded before write request returns. md/raid1: ensure device failure recorded before write request returns. md-cluster: remove inappropriate try_module_get from join() md: extend spinlock protection in register_md_cluster_operations md-cluster: Read the disk bitmap sb and check if it needs recovery md-cluster: only call complete(&cinfo->completion) when node join cluster md-cluster: add missed lockres_free md-cluster: remove the unused sb_lock md-cluster: init suspend_list and suspend_lock early in join md-cluster: add the error check if failed to get dlm lock md-cluster: init completion within lockres_init md-cluster: fix deadlock issue on message lock md-cluster: transfer the resync ownership to another node md-cluster: split recover_slot for future code reuse md-cluster: use %pU to print UUIDs md: setup safemode_timer before it's being used md/raid5: handle possible race as reshape completes. md: sync sync_completed has correct value as recovery finishes. ...
2015-09-05Merge tag 'nfsd-4.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Nothing major, but: - Add Jeff Layton as an nfsd co-maintainer: no change to existing practice, just an acknowledgement of the status quo. - Two patches ("nfsd: ensure that...") for a race overlooked by the state locking rewrite, causing a crash noticed by multiple users. - Lots of smaller bugfixes all over from Kinglong Mee. - From Jeff, some cleanup of server rpc code in preparation for possible shift of nfsd threads to workqueues" * tag 'nfsd-4.3' of git://linux-nfs.org/~bfields/linux: (52 commits) nfsd: deal with DELEGRETURN racing with CB_RECALL nfsd: return CLID_INUSE for unexpected SETCLIENTID_CONFIRM case nfsd: ensure that delegation stateid hash references are only put once nfsd: ensure that the ol stateid hash reference is only put once net: sunrpc: fix tracepoint Warning: unknown op '->' nfsd: allow more than one laundry job to run at a time nfsd: don't WARN/backtrace for invalid container deployment. fs: fix fs/locks.c kernel-doc warning nfsd: Add Jeff Layton as co-maintainer NFSD: Return word2 bitmask if setting security label in OPEN/CREATE NFSD: Set the attributes used to store the verifier for EXCLUSIVE4_1 nfsd: SUPPATTR_EXCLCREAT must be encoded before SECURITY_LABEL. nfsd: Fix an FS_LAYOUT_TYPES/LAYOUT_TYPES encode bug NFSD: Store parent's stat in a separate value nfsd: Fix two typos in comments lockd: NLM grace period shouldn't block NFSv4 opens nfsd: include linux/nfs4.h in export.h sunrpc: Switch to using hash list instead single list sunrpc/nfsd: Remove redundant code by exports seq_operations functions sunrpc: Store cache_detail in seq_file's private directly ...
2015-09-05Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge patch-bomb from Andrew Morton: - a few misc things - Andy's "ambient capabilities" - fs/nofity updates - the ocfs2 queue - kernel/watchdog.c updates and feature work. - some of MM. Includes Andrea's userfaultfd feature. [ Hadn't noticed that userfaultfd was 'default y' when applying the patches, so that got fixed in this merge instead. We do _not_ mark new features that nobody uses yet 'default y' - Linus ] * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits) mm/hugetlb.c: make vma_has_reserves() return bool mm/madvise.c: make madvise_behaviour_valid() return bool mm/memory.c: make tlb_next_batch() return bool mm/dmapool.c: change is_page_busy() return from int to bool mm: remove struct node_active_region mremap: simplify the "overlap" check in mremap_to() mremap: don't do uneccesary checks if new_len == old_len mremap: don't do mm_populate(new_addr) on failure mm: move ->mremap() from file_operations to vm_operations_struct mremap: don't leak new_vma if f_op->mremap() fails mm/hugetlb.c: make vma_shareable() return bool mm: make GUP handle pfn mapping unless FOLL_GET is requested mm: fix status code which move_pages() returns for zero page mm: memcontrol: bring back the VM_BUG_ON() in mem_cgroup_swapout() genalloc: add support of multiple gen_pools per device genalloc: add name arg to gen_pool_get() and devm_gen_pool_create() mm/memblock: WARN_ON when nid differs from overlap region Documentation/features/vm: add feature description and arch support status for batched TLB flush after unmap mm: defer flush of writable TLB entries mm: send one IPI per CPU to TLB flush all entries after unmapping pages ...
2015-09-05ARM: dts: AM437x: Add the internal and external clock nodes for rtcKeerthy
rtc can either be supplied from internal 32k clock or external crystal generated 32k clock. Internal clock is SOC specific and the external clock is board dependent. Adding the corresponding nodes. Signed-off-by: Keerthy <j-keerthy@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05devicetree: bindings: rtc: add bindings for xilinx zynqmp rtcSuneel Garapati
adds file for description on device node bindings for RTC found on Xilinx Zynq Ultrascale+ MPSoC. Signed-off-by: Suneel Garapati <suneel.garapati@xilinx.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05doc: dt: add documentation for nxp,lpc1788-rtcJoachim Eastwood
Document NXP LPC178x/18xx/408x/43xx bindings Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05Merge linux-block/for-4.3/core into md/for-linuxNeilBrown
There were a few conflicts that are fairly easy to resolve. Signed-off-by: NeilBrown <neilb@suse.com>
2015-09-04Documentation/features/vm: add feature description and arch support status ↵Mel Gorman
for batched TLB flush after unmap Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: change the read API to return a uffd_msgAndrea Arcangeli
I had requests to return the full address (not the page aligned one) to userland. It's not entirely clear how the page offset could be relevant because userfaults aren't like SIGBUS that can sigjump to a different place and it actually skip resolving the fault depending on a page offset. There's currently no real way to skip the fault especially because after a UFFDIO_COPY|ZEROPAGE, the fault is optimized to be retried within the kernel without having to return to userland first (not even self modifying code replacing the .text that touched the faulting address would prevent the fault to be repeated). Userland cannot skip repeating the fault even more so if the fault was triggered by a KVM secondary page fault or any get_user_pages or any copy-user inside some syscall which will return to kernel code. The second time FAULT_FLAG_RETRY_NOWAIT won't be set leading to a SIGBUS being raised because the userfault can't wait if it cannot release the mmap_map first (and FAULT_FLAG_RETRY_NOWAIT is required for that). Still returning userland a proper structure during the read() on the uffd, can allow to use the current UFFD_API for the future non-cooperative extensions too and it looks cleaner as well. Once we get additional fields there's no point to return the fault address page aligned anymore to reuse the bits below PAGE_SHIFT. The only downside is that the read() syscall will read 32bytes instead of 8bytes but that's not going to be measurable overhead. The total number of new events that can be extended or of new future bits for already shipped events, is limited to 64 by the features field of the uffdio_api structure. If more will be needed a bump of UFFD_API will be required. [akpm@linux-foundation.org: use __packed] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: uAPIAndrea Arcangeli
Defines the uAPI of the userfaultfd, notably the ioctl numbers and protocol. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04userfaultfd: linux/Documentation/vm/userfaultfd.txtAndrea Arcangeli
This is the latest userfaultfd patchset. The postcopy live migration feature on the qemu side is mostly ready to be merged and it entirely depends on the userfaultfd syscall to be merged as well. So it'd be great if this patchset could be reviewed for merging in -mm. Userfaults allow to implement on demand paging from userland and more generally they allow userland to more efficiently take control of the behavior of page faults than what was available before (PROT_NONE + SIGSEGV trap). The use cases are: 1) KVM postcopy live migration (one form of cloud memory externalization). KVM postcopy live migration is the primary driver of this work: http://blog.zhaw.ch/icclab/setting-up-post-copy-live-migration-in-openstack/ http://lists.gnu.org/archive/html/qemu-devel/2015-02/msg04873.html 2) postcopy live migration of binaries inside linux containers: http://thread.gmane.org/gmane.linux.kernel.mm/132662 3) KVM postcopy live snapshotting (allowing to limit/throttle the memory usage, unlike fork would, plus the avoidance of fork overhead in the first place). While the wrprotect tracking is not implemented yet, the syscall API is already contemplating the wrprotect fault tracking and it's generic enough to allow its later implementation in a backwards compatible fashion. 4) KVM userfaults on shared memory. The UFFDIO_COPY lowlevel method should be extended to work also on tmpfs and then the uffdio_register.ioctls will notify userland that UFFDIO_COPY is available even when the registered virtual memory range is tmpfs backed. 5) alternate mechanism to notify web browsers or apps on embedded devices that volatile pages have been reclaimed. This basically avoids the need to run a syscall before the app can access with the CPU the virtual regions marked volatile. This depends on point 4) to be fulfilled first, as volatile pages happily apply to tmpfs. Even though there wasn't a real use case requesting it yet, it also allows to implement distributed shared memory in a way that readonly shared mappings can exist simultaneously in different hosts and they can be become exclusive at the first wrprotect fault. This patch (of 22): Add documentation. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Cc: zhang.zhanghailiang@huawei.com Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Andres Lagar-Cavilla <andreslc@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Hugh Dickins <hughd@google.com> Cc: Peter Feiner <pfeiner@google.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-04Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main pull request for the drm for 4.3. Nouveau is probably the biggest amount of changes in here, since it missed 4.2. Highlights below, along with the usual bunch of fixes. All stuff outside drm should have applicable acks. Highlights: - new drivers: freescale dcu kms driver - core: more atomic fixes disable some dri1 interfaces on kms drivers drop fb panic handling, this was just getting more broken, as more locking was required. new core fbdev Kconfig support - instead of each driver enable/disabling it struct_mutex cleanups - panel: more new panels cleanup Kconfig - i915: Skylake support enabled by default legacy modesetting using atomic infrastructure Skylake fixes GEN9 workarounds - amdgpu: Fiji support CGS support for amdgpu Initial GPU scheduler - off by default Lots of bug fixes and optimisations. - radeon: DP fixes misc fixes - amdkfd: Add Carrizo support for amdkfd using amdgpu. - nouveau: long pending cleanup to complete driver, fully bisectable which makes it larger, perfmon work more reclocking improvements maxwell displayport fixes - vmwgfx: new DX device support, supports OpenGL 3.3 screen targets support - mgag200: G200eW support G200e new revision support - msm: dragonboard 410c support, msm8x94 support, msm8x74v1 support yuv format support dma plane support mdp5 rotation initial hdcp - sti: atomic support - exynos: lots of cleanups atomic modesetting/pageflipping support render node support - tegra: tegra210 support (dc, dsi, dp/hdmi) dpms with atomic modesetting support - atmel: support for 3 more atmel SoCs new input formats, PRIME support. - dwhdmi: preparing to add audio support - rockchip: yuv plane support" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (1369 commits) drm/amdgpu: rename gmc_v8_0_init_compute_vmid drm/amdgpu: fix vce3 instance handling drm/amdgpu: remove ib test for the second VCE Ring drm/amdgpu: properly enable VM fault interrupts drm/amdgpu: fix warning in scheduler drm/amdgpu: fix buffer placement under memory pressure drm/amdgpu/cz: fix cz_dpm_update_low_memory_pstate logic drm/amdgpu: fix typo in dce11 watermark setup drm/amdgpu: fix typo in dce10 watermark setup drm/amdgpu: use top down allocation for non-CPU accessible vram drm/amdgpu: be explicit about cpu vram access for driver BOs (v2) drm/amdgpu: set MEC doorbell range for Fiji drm/amdgpu: implement burst NOP for SDMA drm/amdgpu: add insert_nop ring func and default implementation drm/amdgpu: add amdgpu_get_sdma_instance helper function drm/amdgpu: add AMDGPU_MAX_SDMA_INSTANCES drm/amdgpu: add burst_nop flag for sdma drm/amdgpu: add count field for the SDMA NOP packet v2 drm/amdgpu: use PT for VM sync on unmap drm/amdgpu: make wait_event uninterruptible in push_job ...
2015-09-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "Drivers, drivers, drivers... No interesting input core changes this time" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (74 commits) Input: elan_i2c - use iap_version to get firmware information Input: max8997_haptic - fix module alias Input: elan_i2c - fix typos for validpage_count Input: psmouse - add small delay for IBM trackpoint pass-through mode Input: synaptics - fix handling of disabling gesture mode Input: elan_i2c - enable ELAN0100 acpi panels Input: gpio-keys - report error when disabling unsupported key Input: sur40 - fix error return code Input: sentelic - silence some underflow warnings Input: zhenhua - switch to using bitrev8() Input: cros_ec_keyb - replace KEYBOARD_CROS_EC dependency Input: cap11xx - add LED support Input: elants_i2c - fix for devm_gpiod_get API change Input: elan_i2c - enable asynchronous probing Input: elants_i2c - enable asynchronous probing Input: elants_i2c - wire up regulator support Input: do not emit unneeded EV_SYN when suspending Input: elants_i2c - disable idle mode before updating firmware MAINTAINERS: Add maintainer for atmel_mxt_ts Input: atmel_mxt_ts - remove warning on zero T44 count ...
2015-09-04Merge tag 'sound-4.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "There are little changes in core part, but lots of development are found in drivers, especially ASoC. The diffstat shows regmap-related changes for a slight API additions / changes, and that's all. Looking at the code size statistics, the most significant addition is for Intel Skylake. (Note that SKL support is still underway, the codec driver is missing.) Also STI controller driver is a major addition as well as a few new codec drivers. In HD-audio side, there are fewer changes than the past. The noticeable change is the support of ELD notification from i915 graphics driver. Thus this pull request carries a few changes in drm/i915. Other than that, USB-audio got a rewrite of runtime PM code. It was initiated by lockdep warning, but resulted in a good cleanup in the end. Below are the highlights: Common: - Factoring out of AC'97 reset code from ASoC into the core helper - A few regmap API extensions (in case it's not pulled yet) ASoC: - New drivers for Cirrus CS4349, GTM601, InvenSense ICS43432, Realtek RT298 and ST STI controllers - Machine drivers for Rockchip systems with MAX98090 and RT5645 and RT5650 - Initial driver support for Intel Skylake devices - Lots of rsnd cleanup and enhancements - A few DAPM fixes and cleanups - A large number of cleanups in various drivers (conversion and standardized to regmap, component) mostly by Lars-Peter and Axel HD-audio: - Extended HD-audio core for Intel Skylake controller support - Quirks for Dell headsets, Alienware 15 - Clean up of pin-based quirk tables for Realtek codecs - ELD notifier implenetation for Intel HDMI/DP USB-audio: - Refactor runtime PM code to make lockdep happier" * tag 'sound-4.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits) drm/i915: Add locks around audio component bind/unbind drm/i915: Drop port_mst_index parameter from pin/eld callback ALSA: hda - Fix missing inline for dummy snd_hdac_set_codec_wakeup() ALSA: hda - Wake the codec up on pin/ELD notify events ALSA: hda - allow codecs to access the i915 pin/ELD callback drm/i915: Call audio pin/ELD notify function drm/i915: Add audio pin sense / ELD callback ASoC: zx296702-i2s: Fix resource leak when unload module ASoC: sti_uniperif: Ensure component is unregistered when unload module ASoC: au1x: psc-i2s: Convert to use devm_ioremap_resource ASoC: sh: dma-sh7760: Convert to devm_snd_soc_register_platform ASoC: spear_pcm: Use devm_snd_dmaengine_pcm_register to fix resource leak ALSA: fireworks/bebob/dice/oxfw: fix substreams counting at vmalloc failure ASoC: Clean up docbook warnings ASoC: txx9: Convert to devm_snd_soc_register_platform ASoC: pxa: Convert to devm_snd_soc_register_platform ASoC: nuc900: Convert to devm_snd_soc_register_platform ASoC: blackfin: Convert to devm_snd_soc_register_platform ASoC: au1x: Convert to devm_snd_soc_register_platform ASoC: qcom: Constify asoc_qcom_lpass_cpu_dai_ops ...
2015-09-04Merge tag 'backlight-for-linus-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight Pull backlight updates from Lee Jones: - Stop using LP855X Platform Data to control regulators - Move PWM8941 WLED driver into Backlight - Remove invalid use of IS_ERR_VALUE() macro - Remove duplicate check for NULL data before unregistering - Export I2C Device ID structure * tag 'backlight-for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight: backlight: tosa: Export I2C module alias information backlight: lp8788_bl: Delete a check before backlight_device_unregister() backlight: sky81452: Remove unneeded use of IS_ERR_VALUE() macro backlight: pm8941-wled: Move PM8941 WLED driver to backlight backlight: lp855x: Use private data for regulator control
2015-09-04Merge tag 'mfd-for-linus-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "New Device Support: - New Clocksource driver from ST - New MFD/ACPI/DMA drivers for Intel's Sunrisepoint PCH based platforms - Add support for Arizona WM8998 and WM1814 - Add support for Dialog Semi DA9062 and DA9063 - Add support for Kontron COMe-bBL6 and COMe-cBW6 - Add support for X-Powers AXP152 - Add support for Atmel, many - Add support for STMPE, many - Add support for USB in X-Powers AXP22X Core Frameworks: - New Base API to traverse devices and their children in reverse order Bug Fixes: - Fix race between runtime-suspend and IRQs - Obtain platform data form more reliable source Fix-ups: - Constifying things - Variable signage changes - Kconfig depends|selects changes - Make use of BIT() macro - Do not supply .owner attribute in *_driver structures - MAINTAINERS entries - Stop using set_irq_flags() - Start using irq_set_chained_handler_and_data() - Export DT device ID structures" * tag 'mfd-for-linus-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (69 commits) mfd: jz4740-adc: Init mask cache in generic IRQ chip mfd: cros_ec: spi: Add OF match table mfd: stmpe: Add OF match table mfd: max77686: Split out regulator part from the DT binding mfd: Add DT binding for Maxim MAX77802 IC mfd: max77686: Use a generic name for the PMIC node in the example mfd: max77686: Don't suggest in binding to use a deprecated property mfd: Add MFD_CROS_EC dependencies mfd: cros_ec: Remove CROS_EC_PROTO dependency for SPI and I2C drivers mfd: axp20x: Add a cell for the usb power_supply part of the axp20x PMICs mfd: axp20x: Add missing registers, and mark more registers volatile mfd: arizona: Fixup some formatting/white space errors mfd: wm8994: Fix NULL pointer exception on missing pdata of: Add vendor prefix for Nuvoton mfd: mt6397: Implement wake handler and suspend/resume to handle wake up event mfd: atmel-hlcdc: Add support for new SoCs mfd: Export OF module alias information in missing drivers mfd: stw481x: Export I2C module alias information mfd: da9062: Support for the DA9063 OnKey in the DA9062 core mfd: max899x: Avoid redundant irq_data lookup ...
2015-09-04Merge tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have aded a new capability for scatter-gathered memset using dmaengine APIs. This is supported in xdmac & hdmac drivers We have added support for reusing descriptors for examples like video buffers etc. Driver will follow The behaviour of descriptor ack has been clarified and documented New devices added are: - dma controller in sun[457]i SoCs - lpc18xx dmamux - ZTE ZX296702 dma controller - Analog Devices AXI-DMAC DMA controller - eDMA support for dma-crossbar - imx6sx support in imx-sdma driver - imx-sdma device to device support Other: - jz4780 fixes - ioatdma large refactor and cleanup for removal of ioat v1 and v2 which is deprecated and fixes - ACPI support in X-Gene DMA engine driver - ipu irq fixes - mvxor fixes - minor fixes spread thru drivers" [ The Kconfig and Makefile entries got re-sorted alphabetically, and I handled the conflict with the new Intel integrated IDMA driver by slightly mis-sorting it on purpose: "IDMA64" got sorted after "IMX" in order to keep the Intel entries together. I think it might be a good idea to just rename the IDMA64 config entry to INTEL_IDMA64 to make the sorting be a true sort, not this mismash. Also, this merge disables the COMPILE_TEST for the sun4i DMA controller, because it does not compile cleanly at all. - Linus ] * tag 'dmaengine-4.3-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (89 commits) dmaengine: ioatdma: add Broadwell EP ioatdma PCI dev IDs dmaengine :ipu: change ipu_irq_handler() to remove compile warning dmaengine: ioatdma: Fix variable array length dmaengine: ioatdma: fix sparse "error" with prep lock dmaengine: hdmac: Add memset capabilities dmaengine: sort the sh Makefile dmaengine: sort the sh Kconfig dmaengine: sort the dw Kconfig dmaengine: sort the Kconfig dmaengine: sort the makefile drivers/dma: make mv_xor.c driver explicitly non-modular dmaengine: Add support for the Analog Devices AXI-DMAC DMA controller devicetree: Add bindings documentation for Analog Devices AXI-DMAC dmaengine: xgene-dma: Fix the lock to allow client for further submission of requests dmaengine: ioatdma: fix coccinelle warning dmaengine: ioatdma: fix zero day warning on incompatible pointer type dmaengine: tegra-apb: Simplify locking for device using global pause dmaengine: tegra-apb: Remove unnecessary return statements and variables dmaengine: tegra-apb: Avoid unnecessary channel base address calculation dmaengine: tegra-apb: Remove unused variables ...
2015-09-04Merge tag 'pinctrl-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This is the bulk of pin control changes for the v4.3 development cycle. Like with GPIO it's a lot of stuff. If my subsystems are any sign of the overall tempo of the kernel v4.3 will be a gigantic diff. [ It looks like 4.3 is calmer than 4.2 in most other subsystems, but we'll see - Linus ] Core changes: - It is possible configure groups in debugfs. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx also wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. Driver feature enhancements: - Power management support for the SiRF SoC Atlas 7. - Power down support for the Qualcomm driver. - Intel Cherryview and Baytrail: switch drivers to use raw spinlocks in IRQ handlers to play nice with the realtime patch set. - Rework and new modes handling for Qualcomm SPMI-MPP. - Pinconf power source config for SH PFC. New drivers and subdrivers: - A new driver for Conexant Digicolor CX92755. - A new driver for UniPhier PH1-LD4, PH1-Pro4, PH1-sLD8, PH1-Pro5, ProXtream2 and PH1-LD6b SoC pin control support. - Reverse-egineered the S/PDIF settings for the Allwinner sun4i driver. - Support for Qualcomm Technologies QDF2xxx ARM64 SoCs - A new Freescale i.mx6ul subdriver. Cleanup: - Remove platform data support in a number of SH PFC subdrivers" * tag 'pinctrl-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (95 commits) pinctrl: at91: fix null pointer dereference pinctrl: mediatek: Implement wake handler and suspend resume pinctrl: mediatek: Fix multiple registration issue. pinctrl: sh-pfc: r8a7794: add USB pin groups pinctrl: at91: Use generic irq_{request,release}_resources() pinctrl: cherryview: Use raw_spinlock for locking pinctrl: baytrail: Use raw_spinlock for locking pinctrl: imx6ul: Remove .owner field pinctrl: zynq: Fix typos in smc0_nand_grp and smc0_nor_grp pinctrl: sh-pfc: Implement pinconf power-source param for voltage switching clk: rockchip: add pclk_pd_pmu to the list of rk3288 critical clocks pinctrl: sun4i: add spdif to pin description. pinctrl: atlas7: clear ugly branch statements for pull and drivestrength pinctrl: baytrail: Serialize all register access pinctrl: baytrail: Drop FSF mailing address pinctrl: rockchip: only enable gpio clock when it setting pinctrl/mediatek: fix spelling mistake in dev_err error message pinctrl: cherryview: Serialize all register access pinctrl: UniPhier: PH1-Pro5: add I2C ch6 pin-mux setting pinctrl: nomadik: reflect current input value ...
2015-09-04Merge tag 'gpio-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v4.3 kernel cycle. There is quite a lot going on in the GPIO subsystem this merge window, so the main matter is decribed below. The hits in other subsystems when making the GPIO flags optional are all ACKed by their respective subsystem maintainers. Core changes: - Root out the wrapper devm_gpiod_get() and gpiod_get() etc versions of the descriptor calls that did not use the flags argument on the end. This was around for too long and eventually Uwe Kleine-König took the time to clean it out and the last users are removed along with the macros in this tag. In several cases the use of flags simplifies the code. For this reason we have (ACKed) patches hitting in DRM, IIO, media, NFC, USB+PHY up until we hammer in the nail with removing the macros. - Add a fat document describing how much ready-made GPIO stuff we have i the kernel to discourage people from reinventing a square wheel in userspace, as so often happens. - Create a separate lockdep class for each instance of a GPIO IRQ chip instead of using one class for all chips, as the current code will not work with systems with several GPIO chips doing lockdep debugging. - Protect against driver unloading also when a GPIO line is only used as IRQ for the GPIOLIB_IRQCHIP helpers. - If the GPIO chip has no designated owner, assign the parent device driver owner as owner. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx and Jiang Liu wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. - Rob Herring killed off the set_irq_flags() for all GPIO drivers. This was an ARM specific function that is replaced with the generic irq_modify_status() where special flags are actually needed. - When an OF node has a pin range for its GPIOs, return -EPROBE_DEFER if the pin controller isn't available. Pretty logical, yet needed to be fixed. - If a driver using GPIOLIB_IRQCHIP has its own irq_*_resources call back, then call these instead of the defaults provided by the GPIOLIB. - Fix an undocumented ABI hole: named GPIOs were not properly documented. Driver improvements: - Add get_direction() support to the generic GPIO driver, it's strange that we didn't have that before. - Make it possible to have input-only GPIO chips using the generic GPIO driver. - Clean out platform data support from the Emma Mobile (EM) driver - Finegrained runtime PM support for the RCAR driver. - Support r8a7795 (R-car H3) in the RCAR driver. - Support interrupts on GPIOs 16 thru 31 in the DaVinci driver. - Some consolidation and new support in the MPC8xxx driver, we now support MPC5125. - Preempt-RT-friendly patches: the OMAP, MPC8xxx, drivers uses raw spinlocks making it work better with the realime patches. - Interrupt support for the EXTRAXFS GPIO driver. - Make the ETRAXFS GPIO driver support also ARTPEC-3. - Interrupt and wakeup support for the BRCMSTB driver, also for wakeup from S5 cold boot. - Mask MXC IRQs during suspend. - Improve OMAP2 GPIO set_debounce() to work according to spec. - The VF610 driver handles IRQs properly. New drivers: - ZTE ZX GPIO driver" * tag 'gpio-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (87 commits) Revert "gpio: extraxfs: fix returnvar.cocci warnings" gpio: tc3589x: use static container helper gpio: xlp: fix error return code gpio: vf610: handle level IRQ's properly gpio: max732x: Fix error handling in probe() gpio: omap: fix clk_prepare/unprepare usage gpio: omap: protect regs access in omap_gpio_irq_handler gpio: omap: fix omap2_set_gpio_debounce gpio: omap: switch to use platform_get_irq gpio: omap: remove wrong irq_domain_remove usage in probe gpiolib: add description for gpio irqchip fields in struct gpio_chip gpio: extraxfs: fix returnvar.cocci warnings gpiolib: irqchip: use different lockdep class for each gpio irqchip gpio/grgpio: fix deadlock in grgpio_irq_unmap() Documentation: gpio: consumer: describe active low property gpio: mxc: fix section mismatch warning gpio/mxc: mask gpio interrupts in suspend gpio: omap: Fix missing raw locks conversion gpio: brcmstb: support wakeup from S5 cold boot gpio: brcmstb: Add interrupt and wakeup source support ...
2015-09-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull tile updates from Chris Metcalf: "This includes secure computing support as well as miscellaneous minor improvements" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: tile: correct some typos in opcode type names tile/vdso: emit a GNU hash as well tile: Remove finish_arch_switch tile: enable full SECCOMP support tile/time: Migrate to new 'set-state' interface
2015-09-04Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Will Deacon: - Support for new architectural features introduced in ARMv8.1: * Privileged Access Never (PAN) to catch user pointer dereferences in the kernel * Large System Extension (LSE) for building scalable atomics and locks (depends on locking/arch-atomic from tip, which is included here) * Hardware Dirty Bit Management (DBM) for updating clean PTEs automatically - Move our PSCI implementation out into drivers/firmware/, where it can be shared with arch/arm/. RMK has also pulled this component branch and has additional patches moving arch/arm/ over. MAINTAINERS is updated accordingly. - Better BUG implementation based on the BRK instruction for trapping - Leaf TLB invalidation for unmapping user pages - Support for PROBE_ONLY PCI configurations - Various cleanups and non-critical fixes, including: * Always flush FP/SIMD state over exec() * Restrict memblock additions based on range of linear mapping * Ensure *(LIST_POISON) generates a fatal fault * Context-tracking syscall return no longer corrupts return value when not forced on. * Alternatives patching synchronisation/stability improvements * Signed sub-word cmpxchg compare fix (tickled by HAVE_CMPXCHG_LOCAL) * Force SMP=y * Hide direct DCC access from userspace * Fix EFI stub memory allocation when DRAM starts at 0x0 * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (92 commits) arm64: flush FP/SIMD state correctly after execve() arm64: makefile: fix perf_callchain.o kconfig dependency arm64: set MAX_MEMBLOCK_ADDR according to linear region size of/fdt: make memblock maximum physical address arch configurable arm64: Fix source code file path in comments arm64: entry: always restore x0 from the stack on syscall return arm64: mdscr_el1: avoid exposing DCC to userspace arm64: kconfig: Move LIST_POISON to a safe value arm64: Add __exception_irq_entry definition for function graph arm64: mm: ensure patched kernel text is fetched from PoU arm64: alternatives: ensure secondary CPUs execute ISB after patching arm64: make ll/sc __cmpxchg_case_##name asm consistent arm64: dma-mapping: Simplify pgprot handling arm64: restore cpu suspend/resume functionality ARM64: PCI: do not enable resources on PROBE_ONLY systems arm64: cmpxchg: truncate sub-word signed types before comparison arm64: alternative: put secondary CPUs into polling loop during patch arm64/Documentation: clarify wording regarding memory below the Image arm64: lse: fix lse cmpxchg code indentation arm64: remove redundant object file list ...
2015-09-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the main pull request for 4.3 for MIPS. Here's the summary: Three fixes that didn't make 4.2-stable: - a -Os build might compile the kernel using the MIPS16 instruction set but the R2 optimized inline functions in <uapi/asm/swab.h> are implemented using 32-bit wide instructions which is invalid. - a build error in pgtable-bits.h for a particular kernel configuration. - accessing registers of the CM GCR might have been compiled to use 64 bit accesses but these registers are onl 32 bit wide. And also a few new bits: - move the ATH79 GPIO driver to drivers/gpio - the definition of IRQCHIP_DECLARE has moved to linux/irqchip.h, change ATH79 accordingly. - fix definition of pgprot_writecombine - add an implementation of dma_map_ops.mmap - fix alignment of quiet build output for vmlinuz link - BCM47xx: Use kmemdup rather than duplicating its implementation - Netlogic: Fix 0x0x prefixes of constants. - merge Bjorn Helgaas' series to remove most of the weak keywords from function declarations. - CP0 and CP1 registers are best considered treated as unsigned values to avoid large values from becoming negative values. - improve support for the MIPS GIC timer. - enable common clock framework for Malta and SEAD3. - a number of improvments and fixes to dump_tlb(). - document the MIPS TLB dump functionality in Magic SysRq. - Cavium Octeon CN68XX improvments. - NetLogic improvments. - irq: Use access helper irq_data_get_affinity_mask. - handle MSA unaligned accesses. - a number of R6-related math-emu fixes. - support for I6400. - improvments to MSA support. - add uprobes support. - move from deprecated __initcall to arch_initcall. - remove finish_arch_switch(). - IRQ cleanups by Thomas Gleixner. - migrate to new 'set-state' interface. - random small cleanups" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (148 commits) MIPS: UAPI: Fix unrecognized opcode WSBH/DSBH/DSHD when using MIPS16. MIPS: Fix alignment of quiet build output for vmlinuz link MIPS: math-emu: Remove unused handle_dsemul function declaration MIPS: math-emu: Add support for the MIPS R6 MAX{, A} FPU instruction MIPS: math-emu: Add support for the MIPS R6 MIN{, A} FPU instruction MIPS: math-emu: Add support for the MIPS R6 CLASS FPU instruction MIPS: math-emu: Add support for the MIPS R6 RINT FPU instruction MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction MIPS: math-emu: Add support for the MIPS R6 SELNEZ FPU instruction MIPS: math-emu: Add support for the MIPS R6 SELEQZ FPU instruction MIPS: math-emu: Add support for the CMP.condn.fmt R6 instruction MIPS: inst.h: Add new MIPS R6 FPU opcodes MIPS: Octeon: Fix management port MII address on Kontron S1901 MIPS: BCM47xx: Use kmemdup rather than duplicating its implementation STAGING: Octeon: Use common helpers for determining interface and port MIPS: Octeon: Support interfaces 4 and 5 MIPS: Octeon: Set up 1:1 mapping between CN68XX PKO queues and ports MIPS: Octeon: Initialize CN68XX PKO STAGING: Octeon: Support CN68XX style WQE ...
2015-09-03Merge tag 'powerpc-4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: - support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask from Benjamin Herrenschmidt - EEH fixes for SRIOV from Gavin - introduce rtas_get_sensor_fast() for IRQ handlers from Thomas Huth - use hardware RNG for arch_get_random_seed_* not arch_get_random_* from Paul Mackerras - seccomp filter support from Michael Ellerman - opal_cec_reboot2() handling for HMIs & machine checks from Mahesh Salgaonkar - add powerpc timebase as a trace clock source from Naveen N. Rao - misc cleanups in the xmon, signal & SLB code from Anshuman Khandual - add an inline function to update POWER8 HID0 from Gautham R. Shenoy - fix pte_pagesize_index() crash on 4K w/64K hash from Michael Ellerman - drop support for 64K local store on 4K kernels from Michael Ellerman - move dma_get_required_mask() from pnv_phb to pci_controller_ops from Andrew Donnellan - initialize distance lookup table from drconf path from Nikunj A Dadhania - enable RTC class support from Vaibhav Jain - disable automatically blocked PCI config from Gavin Shan - add LEDs driver for PowerNV platform from Vasant Hegde - fix endianness issues in the HVSI driver from Laurent Dufour - kexec endian fixes from Samuel Mendoza-Jonas - fix corrupted pdn list from Gavin Shan - fix fenced PHB caused by eeh_slot_error_detail() from Gavin Shan - Freescale updates from Scott: Highlights include 32-bit memcpy/memset optimizations, checksum optimizations, 85xx config fragments and updates, device tree updates, e6500 fixes for non-SMP, and misc cleanup and minor fixes. - a ton of cxl updates & fixes: - add explicit precision specifiers from Rasmus Villemoes - use more common format specifier from Rasmus Villemoes - destroy cxl_adapter_idr on module_exit from Johannes Thumshirn - destroy afu->contexts_idr on release of an afu from Johannes Thumshirn - compile with -Werror from Daniel Axtens - EEH support from Daniel Axtens - plug irq_bitmap getting leaked in cxl_context from Vaibhav Jain - add alternate MMIO error handling from Ian Munsie - allow release of contexts which have been OPENED but not STARTED from Andrew Donnellan - remove use of macro DEFINE_PCI_DEVICE_TABLE from Vaishali Thakkar - release irqs if memory allocation fails from Vaibhav Jain - remove racy attempt to force EEH invocation in reset from Daniel Axtens - fix + cleanup error paths in cxl_dev_context_init from Ian Munsie - fix force unmapping mmaps of contexts allocated through the kernel api from Ian Munsie - set up and enable PSL Timebase from Philippe Bergheaud * tag 'powerpc-4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (140 commits) cxl: Set up and enable PSL Timebase cxl: Fix force unmapping mmaps of contexts allocated through the kernel api cxl: Fix + cleanup error paths in cxl_dev_context_init powerpc/eeh: Fix fenced PHB caused by eeh_slot_error_detail() powerpc/pseries: Cleanup on pci_dn_reconfig_notifier() powerpc/pseries: Fix corrupted pdn list powerpc/powernv: Enable LEDS support powerpc/iommu: Set default DMA offset in dma_dev_setup cxl: Remove racy attempt to force EEH invocation in reset cxl: Release irqs if memory allocation fails cxl: Remove use of macro DEFINE_PCI_DEVICE_TABLE powerpc/powernv: Fix mis-merge of OPAL support for LEDS driver powerpc/powernv: Reset HILE before kexec_sequence() powerpc/kexec: Reset secondary cpu endianness before kexec powerpc/hvsi: Fix endianness issues in the HVSI driver leds/powernv: Add driver for PowerNV platform powerpc/powernv: Create LED platform device powerpc/powernv: Add OPAL interfaces for accessing and modifying system LED states powerpc/powernv: Fix the log message when disabling VF cxl: Allow release of contexts which have been OPENED but not STARTED ...
