path: root/Documentation
2007-04-30power management: remove firmware disk modeJohannes Berg
This patch removes the firmware disk suspend mode which is the wrong approach, it is supposed to be used for implementing firmware-based disk suspend but cannot actually be used for that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: <linux-pm@lists.linux-foundation.org> Cc: David Brownell <david-b@pacbell.net> Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Merge branch 'for-2.6.22' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.22' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (255 commits) [POWERPC] Remove dev_dbg redefinition in drivers/ps3/vuart.c [POWERPC] remove kernel module option for booke wdt [POWERPC] Avoid putting cpu node twice [POWERPC] Spinlock initializer cleanup [POWERPC] ppc4xx_sgdma needs dma-mapping.h [POWERPC] arch/powerpc/sysdev/timer.c build fix [POWERPC] get_property cleanups [POWERPC] Remove the unused HTDMSOUND driver [POWERPC] cell: cbe_cpufreq cleanup and crash fix [POWERPC] Declare enable_kernel_spe in a header [POWERPC] Add dt_xlate_addr() to bootwrapper [POWERPC] bootwrapper: CONFIG_ -> CONFIG_DEVICE_TREE [POWERPC] Don't define a custom bd_t for Xilixn Virtex based boards. [POWERPC] Add sane defaults for Xilinx EDK generated xparameters files [POWERPC] Add uartlite boot console driver for the zImage wrapper [POWERPC] Stop using ppc_sys for Xilinx Virtex boards [POWERPC] New registration for common Xilinx Virtex ppc405 platform devices [POWERPC] Merge common virtex header files [POWERPC] Rework Kconfig dependancies for Xilinx Virtex ppc405 platform [POWERPC] Clean up cpufreq Kconfig dependencies ...
2007-04-30Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-29Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (107 commits) smc911x: fix compilation breakage wjen debug is on [netdrvr] eexpress: minor corrections add NAPI support to sb1250-mac.c ixgb: ROUND_UP macro cleanup in drivers/net/ixgb e1000: ROUND_UP macro cleanup in drivers/net/e1000 Generic HDLC sparse annotations e100: Optionally use I/O mode only to access register space e100: allow bad MAC address when running with invalid eeprom csum ehea: fix for dlpar support ehea: fix for sysfs entries 3C509: Remove unnecessary include of <linux/pm_legacy.h> NetXen: Fix for vmalloc issues NetXen: Fixes for Power PC architecture NetXen: Port swap feature for multi port cards NetXen: Removal of redundant macros NetXen: Multi PCI support for Quad cards NetXen: Removal of redundant argument passing NetXen: Use multiple PCI functions [netdrvr e100] experiment with doing RX in a similar manner to eepro100 [PATCH] ieee80211: add missing global needed by IEEE80211_DEBUG_XXXX ...
2007-04-29Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (105 commits) sonypi: use mutex instead of semaphore sony-laptop: remove user visible camera controls as platform attributes meye: make meye use sony-laptop instead of sonypi sony-laptop: add a meye-usable include file for camera ops sony-laptop: complete the motion eye camera support in sony-laptop sonypi: try to detect if sony-laptop has already taken one of the known ioports sonypi: suggest sonypi users to try sony-laptop instead sony-laptop: add edge modem support (also called WWAN) sony-laptop: add locking on accesses to the ioport and global vars sony-laptop: add camera enable/disable parameter, better handle possible infinite loop thinkpad-acpi: make drivers/misc/thinkpad_acpi:fan_mutex static ACPI: thinkpad-acpi: add sysfs support to wan and bluetooth subdrivers ACPI: thinkpad-acpi: add sysfs support to hotkey subdriver ACPI: thinkpad-acpi: improve dock subdriver initialization ACPI: thinkpad-acpi: improve debugging for acpi helpers ACPI: thinkpad-acpi: improve fan control documentation ACPI: thinkpad-acpi: map ENXIO to EINVAL for fan sysfs ACPI: thinkpad-acpi: fix a fan watchdog invocation ACPI: thinkpad-acpi: do not arm fan watchdog if it would not work ACPI: thinkpad-acpi: add a fan-control feature master toggle ...
2007-04-28Pull misc-for-upstream into release branchLen Brown
2007-04-28Pull thinkpad into release branchLen Brown
Conflicts: drivers/misc/Kconfig Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-28Pull sony into release branchLen Brown
2007-04-28meye: make meye use sony-laptop instead of sonypimalattia@linux.it
Change sonypi_camera_command() calls to sony_pic_camera_command() and use the renamed macros. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-28ACPI: thinkpad-acpi: add sysfs support to wan and bluetooth subdriversHenrique de Moraes Holschuh
Add support to sysfs to the wan and bluetooth subdrivers. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-28ACPI: thinkpad-acpi: add sysfs support to hotkey subdriverHenrique de Moraes Holschuh
Add the hotkey sysfs support. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-28ACPI: thinkpad-acpi: improve fan control documentationHenrique de Moraes Holschuh
Improve fan control documentation and fix one mistake. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-28ACPI: thinkpad-acpi: add a fan-control feature master toggleHenrique de Moraes Holschuh
Len Brown considers that an active by default fan control interface in laptops may be too close to giving users enough rope. There is a good chance he is quite correct on this, especially if someone decides to use that interface in applets and users are not aware of its risks. This patch adds a master switch to thinkpad-acpi that enables or disables the entire fan-control feature as a module parameter: "fan_control". It defaults to disabled. Set it to non-zero to enable fan control. Also, the patch removes the expermiental status from fan control, since it is stable enough to not be called experimental, and the master switch makes it safe enough to do so. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-04-28phy layer: add kernel-doc + DocBookRandy Dunlap
Convert function documentation in drivers/net/phy/ to kernel-doc and add it to DocBook. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28[PATCH] bcm43xx: Update Documentation/bcm43xx.txtLarry Finger
The in-kernel documentation of the bcm43xx driver is out of date. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (78 commits) USB: update MAINAINERS and CREDITS for Freescale USB driver USB: update gadget files for fsl_usb2_udc driver USB: add Freescale high-speed USB SOC device controller driver USB: quirk for broken suspend of IT8152F/G USB: iowarrior.c: timeouts too small in usb_control_msg calls USB: dell device id for option.c USB: Remove Huawei unusual_devs entry USB: CP2101 New Device IDs USB: add picdem device to ldusb usbfs micro optimitation USB: remove ancient/broken CRIS hcd usb ethernet gadget, workaround network stack API glitch USB: add "busnum" attribute for USB devices USB: cxacru: ADSL state management usbatm: Detect usb device shutdown and ignore failed urbs USB: Remove duplicate define of OHCI_QUIRK_ZFMICRO USB: BandRich BandLuxe HSDPA Data Card Driver USB gadget rndis: fix struct rndis_packet_msg_type unaligned bug USB Elan FTDI: check for driver registration status USB: sierra: add more checks on shutdown ...
2007-04-27Merge branch 'master' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb * 'master' of ssh://master.kernel.org/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (184 commits) V4L/DVB (5563): Radio-maestro.c Replace radio_ioctl to use video_ioctl2 V4L/DVB (5562): Radio-gemtek-pci.c Replace gemtek_pci_ioctl to use video_ioctl2 V4L/DVB (5560): Ivtv: fix incorrect bitwise-and for command flags. V4L/DVB (5558): Opera: use 7-bit i2c addresses V4L/DVB (5557): Cafe_ccic: check return value of pci_enable_device V4L/DVB (5556): Radio-gemtek.c Replace gemtek_ioctl to use video_ioctl2 V4L/DVB (5555): Radio-aimslab.c Replace rt_ioctl to use video_ioctl2 V4L/DVB (5554): Fix: vidioc_g_parm were not zeroing the memory V4L/DVB (5553): Replace typhoon_do_ioctl to use video_ioctl2 V4L/DVB (5552): Plan-b: Switch to refcounting PCI API V4L/DVB (5551): Plan-b: header change V4L/DVB (5550): Radio-sf16fmi.c Replace fmi_do_ioctl to use video_ioctl2 V4L/DVB (5549): Radio-sf16fmr2.c Replace fmr2_do_ioctl to use video_ioctl2 V4L/DVB (5548): Fix v4l2 buffer to the length V4L/DVB (5547): Add ENUM_FRAMESIZES and ENUM_FRAMEINTERVALS ioctls V4L/DVB (5546): Radio-terratec.c Replace tt_do_ioctl to use video_ioctl2 V4L/DVB (5545): Saa7146: Release capture buffers on device close V4L/DVB (5544): Budget-av: Make inversion setting configurable, add KNC ONE V1.0 card V4L/DVB (5543): Tda10023: Add support for frontend TDA10023 V4L/DVB (5542): Budget-av: Remove polarity switching of the clock for DVB-C ...
2007-04-27USB: add power/level sysfs attributeAlan Stern
This patch (as874) adds another piece to the user-visible part of the USB autosuspend interface. The new power/level sysfs attribute allows users to force the device on (with autosuspend off), force the device to sleep (with autoresume off), or return to normal automatic operation. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: Allow autosuspend delay to equal 0Alan Stern
This patch (as867) adds an entry for the new power/autosuspend attribute in Documentation/ABI/testing, and it changes the behavior of the delay value. Now a delay of 0 means to autosuspend as soon as possible, and negative values will prevent autosuspend. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27usbmon: Extended text APIPete Zaitcev
This patch adds a new text API, codenamed '1u', which captures more URB fields than old '1t' interface did. Also the '1u' text API is compatible with the future "bus zero" extension. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27V4L/DVB (5530): Usbvision: remove CustomDevice facilityThierry MERLE
usbvision has a module parameter that ables the user to add a new USB entry at driver load. This functionality is useless by experience (adding statically the entry is easy). Furthermore, the USB_DEVICE(0xfff0, 0xfff0) USB entry caused usbvision_probe to be called for all unclaimed devices. Signed-off-by: Thierry MERLE <thierry.merle@free.fr> Acked-by: Dwaine Garden <DwaineGarden@rogers.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5515): Use a better format to represent usbvision supported boardsMauro Carvalho Chehab
Changed usbvision cards table to allow: 1) Not repeat USB ID on two structs; 2) Not need to specify both usb and card description tables at the same order, removing some magic; Some cards had duplicated names. Fixed. A test for an specific board were doing by using a string comparation. The comparation were wrong. Also, it is not a good practice to recognize a board based on his string name. Acked-by: Thierry MERLE <thierry.merle@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5500): Add a CARDLIST for the supported devices by usbvision driverMauro Carvalho Chehab
2007-04-27V4L/DVB (5497): Additional card support for bttv driverScott Alfter
SSAI (www.ssai.us) makes several Bt878-based capture cards that get used in our surveillance, conferencing, and medical imaging systems. The attached relatively small patch adds support for these cards, which fall into two broad * boards with one or more Bt878s, one or more composite inputs, and no S-video or tuner inputs * boards with one Bt878, one composite input, one S-video input, and no tuner input Signed-off-by: Scott Alfter <salfter@ssai.us> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5474): SN9C1xx driver updatesLuca Risolia
@ Don't assume that SOF headers can't cross packets boundaries @ Fix compression quality selection + Add support for MI-0360 image sensor * Documentation updates @ Fix sysfs @ MI0343 rewritten * HV7131R color fixes and add new ABLC control * Rename the archive from "sn9c102" to "sn9c1xx" * fix typos * better support for TAS5110D @ fix OV7630 wrong colors @ Don't return an error if no input buffers are enqueued yet on VIDIOC_STREAMON * Add informations about colorspaces * More appropriate error codes in case of failure of some system calls * More precise hardware detection * Add more informations about supported hardware in the documentation + More supported devices + Add support for HV7131R image sensor Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5446): Renamed ASUStek P7131 card [1043:4876]Hartmut Hackmann
The new name fits to what it is and what is on the box. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5445): Added / corrected support for some ASUS hybrid boardsHartmut Hackmann
There are 2 new entries for p7131 boards and one correction for a board with LNA. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5437): Update cx23415 documentationIan Armstrong
Adds more osd mode switching information. Corrects some information regarding mode selection & local alpha operation for 16 bit modes. Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5431): Cx88: autodetect ADS Tech InstantTV DVB-SMichael Krufky
The ADS Tech InstantTV DVB-S is a clone of the KWorld DVB-S 100. This patch adds autodetection support for this card based on pci subsystem id. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5409): Add CARDLIST.ivtv and README.ivtvHans Verkuil
2007-04-27V4L/DVB (5407a): Update feature-removal-schedule.txt: remove VIDIOC_S/G_MPEGCOMPHans Verkuil
Those two experimental APIs never worked fine nor, afaik, were implemented at the apps. Their functionalities were implemented by other means. So, let's remove those obsolete stuff. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5336): Cx23416 doc updates + rename CX2341X_ENC_UNKNOWNHans Verkuil
The documentation of Several miscellaneous commands was updated. As a result of which the CX2341X_ENC_UNKNOWN command was renamed to CX2341X_ENC_SET_VERT_CROP_LINE. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5331): Identify MSI TV@nywhere DuoPeter Missel
It is a Lifeview Duo with a different ID Signed-off-by: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5330): Added card definition for AverMedia M102 miniPCIMarkus Rechberger
Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5314): Added support for tda827x tuners with preamlifiersHartmut Hackmann
This patch contains - new tuning code for the tda827xa silicon tuner. - controls the preamplifier of some boards with this tuner. - support for the Philips Tiger S hybrid DVB-T reference design. - reworked the saa7134-dvb modulue to get rid of most of the small board specific functions. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5257): USB: add zr364xx V4L2 driverAntoine Jacquet
This patch adds a V4L2 driver giving support for USB webcams based on the zr364xx chipsets. Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27the overdue removal of the mount/umount ueventsAdrian Bunk
This patch contains the overdue removal of the mount/umount uevents. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: (49 commits) IB: Set class_dev->dev in core for nice device symlink IB/ehca: Implement modify_port IB/umad: Clarify documentation of transaction ID IPoIB/cm: spin_lock_irqsave() -> spin_lock_irq() replacements IB/mad: Change SMI to use enums rather than magic return codes IB/umad: Implement GRH handling for sent/received MADs IB/ipoib: Use ib_init_ah_from_path to initialize ah_attr IB/sa: Set src_path_bits correctly in ib_init_ah_from_path() IB/ucm: Simplify ib_ucm_event() RDMA/ucma: Simplify ucma_get_event() IB/mthca: Simplify CQ cleaning in mthca_free_qp() IB/mthca: Fix mthca_write_mtt() on HCAs with hidden memory IB/mthca: Update HCA firmware revisions IB/ipath: Fix WC format drift between user and kernel space IB/ipath: Check that a UD work request's address handle is valid IB/ipath: Remove duplicate stuff from ipath_verbs.h IB/ipath: Check reserved memory keys IB/ipath: Fix unit selection when all CPU affinity bits set IB/ipath: Don't allow QPs 0 and 1 to be opened multiple times IB/ipath: Disable IB link earlier in shutdown sequence ...
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (448 commits) [IPV4] nl_fib_lookup: Initialise res.r before fib_res_put(&res) [IPV6]: Fix thinko in ipv6_rthdr_rcv() changes. [IPV4]: Add multipath cached to feature-removal-schedule.txt [WIRELESS] cfg80211: Clarify locking comment. [WIRELESS] cfg80211: Fix locking in wiphy_new. [WEXT] net_device: Don't include wext bits if not required. [WEXT]: Misc code cleanups. [WEXT]: Reduce inline abuse. [WEXT]: Move EXPORT_SYMBOL statements where they belong. [WEXT]: Cleanup early ioctl call path. [WEXT]: Remove options. [WEXT]: Remove dead debug code. [WEXT]: Clean up how wext is called. [WEXT]: Move to net/wireless [AFS]: Eliminate cmpxchg() usage in vlocation code. [RXRPC]: Fix pointers passed to bitops. [RXRPC]: Remove bogus atomic_* overrides. [AFS]: Fix u64 printing in debug logging. [AFS]: Add "directory write" support. [AFS]: Implement the CB.InitCallBackState3 operation. ...
2007-04-27[S390] crypto: cleanup.Jan Glauber
Cleanup code and remove obsolete documentation. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] zfcpdump support.Michael Holzheu
s390 machines provide hardware support for creating Linux dumps on SCSI disks. For creating a dump a special purpose dump Linux is used. The first 32 MB of memory are saved by the hardware before the dump Linux is booted. Via an SCLP interface, the saved memory can be accessed from Linux. This patch exports memory and registers of the crashed Linux to userspace via a debugfs file. For more information refer to Documentation/s390/zfcpdump.txt, which is included in this patch. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[POWERPC] Fix typos in booting-without-of.txtDomen Puncer
Fix typos + some cosmetic changes. Signed-off-by: Domen Puncer <domen.puncer@telargo.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-27[IPV4]: Add multipath cached to feature-removal-schedule.txtDavid S. Miller
2007-04-26[AFS]: Update the AFS fs documentation.David Howells
Update the AFS fs documentation. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Add an interface to the AF_RXRPC module for the AFS filesystem ↵David Howells
to use Add an interface to the AF_RXRPC module so that the AFS filesystem module can more easily make use of the services available. AFS still opens a socket but then uses the action functions in lieu of sendmsg() and registers an intercept functions to grab messages before they're queued on the socket Rx queue. This permits AFS (or whatever) to: (1) Avoid the overhead of using the recvmsg() call. (2) Use different keys directly on individual client calls on one socket rather than having to open a whole slew of sockets, one for each key it might want to use. (3) Avoid calling request_key() at the point of issue of a call or opening of a socket. This is done instead by AFS at the point of open(), unlink() or other VFS operation and the key handed through. (4) Request the use of something other than GFP_KERNEL to allocate memory. Furthermore: (*) The socket buffer markings used by RxRPC are made available for AFS so that it can interpret the cooked RxRPC messages itself. (*) rxgen (un)marshalling abort codes are made available. The following documentation for the kernel interface is added to Documentation/networking/rxrpc.txt: ========================= AF_RXRPC KERNEL INTERFACE ========================= The AF_RXRPC module also provides an interface for use by in-kernel utilities such as the AFS filesystem. This permits such a utility to: (1) Use different keys directly on individual client calls on one socket rather than having to open a whole slew of sockets, one for each key it might want to use. (2) Avoid having RxRPC call request_key() at the point of issue of a call or opening of a socket. Instead the utility is responsible for requesting a key at the appropriate point. AFS, for instance, would do this during VFS operations such as open() or unlink(). The key is then handed through when the call is initiated. (3) Request the use of something other than GFP_KERNEL to allocate memory. (4) Avoid the overhead of using the recvmsg() call. RxRPC messages can be intercepted before they get put into the socket Rx queue and the socket buffers manipulated directly. To use the RxRPC facility, a kernel utility must still open an AF_RXRPC socket, bind an addess as appropriate and listen if it's to be a server socket, but then it passes this to the kernel interface functions. The kernel interface functions are as follows: (*) Begin a new client call. struct rxrpc_call * rxrpc_kernel_begin_call(struct socket *sock, struct sockaddr_rxrpc *srx, struct key *key, unsigned long user_call_ID, gfp_t gfp); This allocates the infrastructure to make a new RxRPC call and assigns call and connection numbers. The call will be made on the UDP port that the socket is bound to. The call will go to the destination address of a connected client socket unless an alternative is supplied (srx is non-NULL). If a key is supplied then this will be used to secure the call instead of the key bound to the socket with the RXRPC_SECURITY_KEY sockopt. Calls secured in this way will still share connections if at all possible. The user_call_ID is equivalent to that supplied to sendmsg() in the control data buffer. It is entirely feasible to use this to point to a kernel data structure. If this function is successful, an opaque reference to the RxRPC call is returned. The caller now holds a reference on this and it must be properly ended. (*) End a client call. void rxrpc_kernel_end_call(struct rxrpc_call *call); This is used to end a previously begun call. The user_call_ID is expunged from AF_RXRPC's knowledge and will not be seen again in association with the specified call. (*) Send data through a call. int rxrpc_kernel_send_data(struct rxrpc_call *call, struct msghdr *msg, size_t len); This is used to supply either the request part of a client call or the reply part of a server call. msg.msg_iovlen and msg.msg_iov specify the data buffers to be used. msg_iov may not be NULL and must point exclusively to in-kernel virtual addresses. msg.msg_flags may be given MSG_MORE if there will be subsequent data sends for this call. The msg must not specify a destination address, control data or any flags other than MSG_MORE. len is the total amount of data to transmit. (*) Abort a call. void rxrpc_kernel_abort_call(struct rxrpc_call *call, u32 abort_code); This is used to abort a call if it's still in an abortable state. The abort code specified will be placed in the ABORT message sent. (*) Intercept received RxRPC messages. typedef void (*rxrpc_interceptor_t)(struct sock *sk, unsigned long user_call_ID, struct sk_buff *skb); void rxrpc_kernel_intercept_rx_messages(struct socket *sock, rxrpc_interceptor_t interceptor); This installs an interceptor function on the specified AF_RXRPC socket. All messages that would otherwise wind up in the socket's Rx queue are then diverted to this function. Note that care must be taken to process the messages in the right order to maintain DATA message sequentiality. The interceptor function itself is provided with the address of the socket and handling the incoming message, the ID assigned by the kernel utility to the call and the socket buffer containing the message. The skb->mark field indicates the type of message: MARK MEANING =============================== ======================================= RXRPC_SKB_MARK_DATA Data message RXRPC_SKB_MARK_FINAL_ACK Final ACK received for an incoming call RXRPC_SKB_MARK_BUSY Client call rejected as server busy RXRPC_SKB_MARK_REMOTE_ABORT Call aborted by peer RXRPC_SKB_MARK_NET_ERROR Network error detected RXRPC_SKB_MARK_LOCAL_ERROR Local error encountered RXRPC_SKB_MARK_NEW_CALL New incoming call awaiting acceptance The remote abort message can be probed with rxrpc_kernel_get_abort_code(). The two error messages can be probed with rxrpc_kernel_get_error_number(). A new call can be accepted with rxrpc_kernel_accept_call(). Data messages can have their contents extracted with the usual bunch of socket buffer manipulation functions. A data message can be determined to be the last one in a sequence with rxrpc_kernel_is_data_last(). When a data message has been used up, rxrpc_kernel_data_delivered() should be called on it.. Non-data messages should be handled to rxrpc_kernel_free_skb() to dispose of. It is possible to get extra refs on all types of message for later freeing, but this may pin the state of a call until the message is finally freed. (*) Accept an incoming call. struct rxrpc_call * rxrpc_kernel_accept_call(struct socket *sock, unsigned long user_call_ID); This is used to accept an incoming call and to assign it a call ID. This function is similar to rxrpc_kernel_begin_call() and calls accepted must be ended in the same way. If this function is successful, an opaque reference to the RxRPC call is returned. The caller now holds a reference on this and it must be properly ended. (*) Reject an incoming call. int rxrpc_kernel_reject_call(struct socket *sock); This is used to reject the first incoming call on the socket's queue with a BUSY message. -ENODATA is returned if there were no incoming calls. Other errors may be returned if the call had been aborted (-ECONNABORTED) or had timed out (-ETIME). (*) Record the delivery of a data message and free it. void rxrpc_kernel_data_delivered(struct sk_buff *skb); This is used to record a data message as having been delivered and to update the ACK state for the call. The socket buffer will be freed. (*) Free a message. void rxrpc_kernel_free_skb(struct sk_buff *skb); This is used to free a non-DATA socket buffer intercepted from an AF_RXRPC socket. (*) Determine if a data message is the last one on a call. bool rxrpc_kernel_is_data_last(struct sk_buff *skb); This is used to determine if a socket buffer holds the last data message to be received for a call (true will be returned if it does, false if not). The data message will be part of the reply on a client call and the request on an incoming call. In the latter case there will be more messages, but in the former case there will not. (*) Get the abort code from an abort message. u32 rxrpc_kernel_get_abort_code(struct sk_buff *skb); This is used to extract the abort code from a remote abort message. (*) Get the error number from a local or network error message. int rxrpc_kernel_get_error_number(struct sk_buff *skb); This is used to extract the error number from a message indicating either a local error occurred or a network error occurred. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel bothDavid Howells
Provide AF_RXRPC sockets that can be used to talk to AFS servers, or serve answers to AFS clients. KerberosIV security is fully supported. The patches and some example test programs can be found in: http://people.redhat.com/~dhowells/rxrpc/ This will eventually replace the old implementation of kernel-only RxRPC currently resident in net/rxrpc/. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Key facility changes for AF_RXRPCDavid Howells
Export the keyring key type definition and document its availability. Add alternative types into the key's type_data union to make it more useful. Not all users necessarily want to use it as a list_head (AF_RXRPC doesn't, for example), so make it clear that it can be used in other ways. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: bonding documentation fix for multiple bonding interfacesAlexandra N. Kossovsky
Fix bonding driver documentation for the case of multiple bonding interfaces. Signed-off-by: "Alexandra N. Kossovsky" <Alexandra.Kossovsky@oktetlabs.ru> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[NET]: Delete unused header file linux/if_wanpipe_common.hRobert P. J. Day
Delete the unreferenced header file include/linux/if_wanpipe_common.h, as well as the reference to it in the Doc file. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[WIRELESS]: Remove wext over netlink.Johannes Berg
As scheduled, this patch removes the pointless wext over netlink code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
