path: root/Documentation
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "It's been a busy development cycle for target-core in a number of different areas. The fabric API usage for se_node_acl allocation is now within target-core code, dropping the external API callers for all fabric drivers tree-wide. There is a new conversion to RCU hlists for se_node_acl and se_portal_group LUN mappings, that turns fast-past LUN lookup into a completely lockless code-path. It also removes the original hard-coded limitation of 256 LUNs per fabric endpoint. The configfs attributes for backends can now be shared between core and driver code, allowing existing drivers to use common code while still allowing flexibility for new backend provided attributes. The highlights include: - Merge sbc_verify_dif_* into common code (sagi) - Remove iscsi-target support for obsolete IFMarker/OFMarker (Christophe Vu-Brugier) - Add bidi support in target/user backend (ilias + vangelis + agover) - Move se_node_acl allocation into target-core code (hch) - Add crc_t10dif_update common helper (akinobu + mkp) - Handle target-core odd SGL mapping for data transfer memory (akinobu) - Move transport ID handling into target-core (hch) - Move task tag into struct se_cmd + support 64-bit tags (bart) - Convert se_node_acl->device_list[] to RCU hlist (nab + hch + paulmck) - Convert se_portal_group->tpg_lun_list[] to RCU hlist (nab + hch + paulmck) - Simplify target backend driver registration (hch) - Consolidate + simplify target backend attribute implementations (hch + nab) - Subsume se_port + t10_alua_tg_pt_gp_member into se_lun (hch) - Drop lun_sep_lock for se_lun->lun_se_dev RCU usage (hch + nab) - Drop unnecessary core_tpg_register TFO parameter (nab) - Use 64-bit LUNs tree-wide (hannes) - Drop left-over TARGET_MAX_LUNS_PER_TRANSPORT limit (hannes)" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (76 commits) target: Bump core version to v5.0 target: remove target_core_configfs.h target: remove unused TARGET_CORE_CONFIG_ROOT define target: consolidate version defines target: implement WRITE_SAME with UNMAP bit using ->execute_unmap target: simplify UNMAP handling target: replace se_cmd->execute_rw with a protocol_data field target/user: Fix inconsistent kmap_atomic/kunmap_atomic target: Send UA when changing LUN inventory target: Send UA upon LUN RESET tmr completion target: Send UA on ALUA target port group change target: Convert se_lun->lun_deve_lock to normal spinlock target: use 'se_dev_entry' when allocating UAs target: Remove 'ua_nacl' pointer from se_ua structure target_core_alua: Correct UA handling when switching states xen-scsiback: Fix compile warning for 64-bit LUN target: Remove TARGET_MAX_LUNS_PER_TRANSPORT target: use 64-bit LUNs target: Drop duplicate + unused se_dev_check_wce target: Drop unnecessary core_tpg_register TFO parameter ...
2015-07-04Merge tag 'ntb-4.2' of git://github.com/jonmason/ntbLinus Torvalds
Pull NTB updates from Jon Mason: "This includes a pretty significant reworking of the NTB core code, but has already produced some significant performance improvements. An abstraction layer was added to allow the hardware and clients to be easily added. This required rewriting the NTB transport layer for this abstraction layer. This modification will allow future "high performance" NTB clients. In addition to this change, a number of performance modifications were added. These changes include NUMA enablement, using CPU memcpy instead of asyncdma, and modification of NTB layer MTU size" * tag 'ntb-4.2' of git://github.com/jonmason/ntb: (22 commits) NTB: Add split BAR output for debugfs stats NTB: Change WARN_ON_ONCE to pr_warn_once on unsafe NTB: Print driver name and version in module init NTB: Increase transport MTU to 64k from 16k NTB: Rename Intel code names to platform names NTB: Default to CPU memcpy for performance NTB: Improve performance with write combining NTB: Use NUMA memory in Intel driver NTB: Use NUMA memory and DMA chan in transport NTB: Rate limit ntb_qp_link_work NTB: Add tool test client NTB: Add ping pong test client NTB: Add parameters for Intel SNB B2B addresses NTB: Reset transport QP link stats on down NTB: Do not advance transport RX on link down NTB: Differentiate transport link down messages NTB: Check the device ID to set errata flags NTB: Enable link for Intel root port mode in probe NTB: Read peer info from local SPAD in transport NTB: Split ntb_hw_intel and ntb_transport drivers ...
2015-07-04dax: Add block size note to documentationMatthew Wilcox
For block devices which are small enough, mkfs will default to creating a filesystem with block sizes smaller than page size. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-04NTB: Rename Intel code names to platform namesDave Jiang
Instead of using the platform code names, use the correct platform names to identify the respective Intel NTB hardware. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add tool test clientAllen Hubbe
This is a simple debugging driver that enables the doorbell and scratch pad registers to be read and written from the debugfs. This tool enables more complicated debugging to be scripted from user space. This driver may be used to test that your ntb hardware and drivers are functioning at a basic level. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add ping pong test clientAllen Hubbe
This is a simple ping pong driver that exercises the scratch pads and doorbells of the ntb hardware. This driver may be used to test that your ntb hardware and drivers are functioning at a basic level. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add parameters for Intel SNB B2B addressesAllen Hubbe
Add module parameters for the addresses to be used in B2B topology. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Split ntb_hw_intel and ntb_transport driversAllen Hubbe
Change ntb_hw_intel to use the new NTB hardware abstraction layer. Split ntb_transport into its own driver. Change it to use the new NTB hardware abstraction layer. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Add NTB hardware abstraction layerAllen Hubbe
Abstract the NTB device behind a programming interface, so that it can support different hardware and client drivers. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Two FPU rewrite related fixes. This addresses all known x86 regressions at this stage. Also some other misc fixes" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/fpu: Fix boot crash in the early FPU code x86/asm/entry/64: Update path names x86/fpu: Fix FPU related boot regression when CPUID masking BIOS feature is enabled x86/boot/setup: Clean up the e820_reserve_setup_data() code x86/kaslr: Fix typo in the KASLR_FLAG documentation
2015-07-03Merge tag 'remoteproc-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc updates from Ohad Ben-Cohen: - remoteproc fixes/cleanups from Suman Anna - new remoteproc TI Wakeup M3 driver from Dave Gerlach - remoteproc core support for TI's Wakeup M3 driver from both Dave and Suman - tiny remoteproc build fix from myself * tag 'remoteproc-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: fix !CONFIG_OF build breakage remoteproc/wkup_m3: add a remoteproc driver for TI Wakeup M3 Documentation: dt: add bindings for TI Wakeup M3 processor remoteproc: add a rproc ops for performing address translation remoteproc: introduce rproc_get_by_phandle API remoteproc: fix various checkpatch warnings remoteproc/davinci: fix quoted split string checkpatch warning remoteproc/ste: add blank lines after declarations
2015-07-03Merge tag 'hwspinlock-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock Pull hwspinlock updates from Ohad Ben-Cohen: - hwspinlock core DT support from Suman Anna - OMAP hwspinlock DT support from Suman Anna - QCOM hwspinlock DT support from Bjorn Andersson - a new CSR atlas7 hwspinlock driver from Wei Chen - CSR atlas7 hwspinlock DT binding document from Wei Chen - a tiny QCOM hwspinlock driver fix from Bjorn Andersson * tag 'hwspinlock-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/hwspinlock: hwspinlock: qcom: Correct msb in regmap_field DT: hwspinlock: add the CSR atlas7 hwspinlock bindings document hwspinlock: add a CSR atlas7 driver hwspinlock: qcom: Add support for Qualcomm HW Mutex block DT: hwspinlock: Add binding documentation for Qualcomm hwmutex hwspinlock/omap: add support for dt nodes Documentation: dt: add the omap hwspinlock bindings document hwspinlock/core: add device tree support Documentation: dt: add common bindings for hwspinlock
2015-07-03hwmon: Document which I2C addresses can be probedJean Delvare
Add an item to the checklist when submitting a new hwmon driver: only some I2C addresses can be probed, others should not for safety reasons. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
2015-07-03hwmon: (w83792d) Additional PWM outputs supportRoger Lucas
Add pwm[4-7] and the associated pwm[4-7]_mode attributes. Signed-off-by: Roger Lucas <vt8231@hiddenengine.co.uk> Signed-off-by: Jean Delvare <jdelvare@suse.de>
2015-07-02Merge tag 'acpica-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPICA updates from Rafael Wysocki: "Additional ACPICA material for v4.2-rc1 This will update the ACPICA code in the kernel to upstream revision 20150619 (a bug-fix release mostly including stable-candidate fixes) and restore an earlier ACPICA commit that had to be reverted due to a regression introduced by it (the regression is addressed by blacklisting the only known system affected by it to date). The only new feature added by this update is the support for overriding objects in the ACPI namespace and a new ACPI table that can be used for that called the Override System Definition Table (OSDT). That should allow us to "patch" the ACPI namespace built from incomplete or incorrect ACPI System Definition tables (DSDT, SSDT) during system startup without the need to provide replacements for all of those tables in the future. Specifics: - Fix system resume problems related to 32-bit and 64-bit versions of the Firmware ACPI Control Structure (FACS) in the firmare (Lv Zheng) - Fix double initialization of the FACS (Lv Zheng) - Add _CLS object processing code to ACPICA (Suravee Suthikulpanit) - Add support for the (currently missing) new GIC version field in the Multiple APIC Description Table (MADT) (Hanjun Guo) - Add support for overriding objects in the ACPI namespace to ACPICA and OSDT support (Lv Zheng, Bob Moore, Zhang Rui) - Updates related to the TCPA and TPM2 ACPI tables (Bob Moore) - Restore the commit modifying _REV to always return "2" (as required by ACPI 6) and add a blacklisting mechanism for systems that may be affected by that change (Rafael J Wysocki) - Assorted fixes and cleanups (Bob Moore, Lv Zheng, Sascha Wildner)" * tag 'acpica-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits) Revert 'Revert "ACPICA: Permanently set _REV to the value '2'."' ACPI / init: Make it possible to override _REV ACPICA: Update version to 20150619 ACPICA: Comment update, no functional change ACPICA: Update TPM2 ACPI table ACPICA: Update definitions for the TCPA and TPM2 ACPI tables ACPICA: Split C library prototypes to new header ACPICA: De-macroize calls to standard C library functions ACPI / acpidump: Update acpidump manual ACPICA: acpidump: Convert the default behavior to dump from /sys/firmware/acpi/tables ACPICA: acpidump: Allow customized tables to be dumped without accessing /dev/mem ACPICA: Cleanup output for the ASL Debug object ACPICA: Update for acpi_install_table memory types ACPICA: Namespace: Change namespace override to avoid node deletion ACPICA: Namespace: Add support of OSDT table ACPICA: Namespace: Add support to allow overriding objects ACPICA: ACPI 6.0: Add values for MADT GIC version field ACPICA: Utilities: Add _CLS processing ACPICA: Add dragon_fly support to unix file mapping file ACPICA: EFI: Add EFI interface definitions to eliminate dependency of GNU EFI ...
2015-07-03ACPI / init: Make it possible to override _REVRafael J. Wysocki
The platform firmware on some systems expects Linux to return "5" as the supported ACPI revision which makes it expose system configuration information in a special way. For example, based on what ACPI exports as the supported revision, Dell XPS 13 (2015) configures its audio device to either work in HDA mode or in I2S mode, where the former is supposed to be used on Linux until the latter is fully supported (in the kernel as well as in user space). Since ACPI 6 mandates that _REV should return "2" if ACPI 2 or later is supported by the OS, a subsequent change will make that happen, so make it possible to override that on systems where "5" is expected to be returned for Linux to work correctly one them (such as the Dell machine mentioned above). Original-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-02Merge tag 'armsoc-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC late fixes and dependencies from Kevin Hilman: "This is a collection of a few late fixes and other misc stuff that had dependencies on things being merged from other trees. Other than the fixes, the primary feature being added is the conversion of some OMAP drivers to the new generic wakeirq interface" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: multi_v7_defconfig: Enable BRCMNAND driver ARM: BCM: Do not select CONFIG_MTD_NAND_BRCMNAND ARM: at91/dt: update udc compatible strings ARM: at91/dt: trivial: fix USB udc compatible string arm64: dts: Add APM X-Gene standby GPIO controller DTS entries soc: qcom: spm: Fix idle on THUMB2 kernels ARM: dove: fix legacy dove IRQ numbers ARM: mvebu: fix suspend to RAM on big-endian configurations ARM: mvebu: adjust Armada XP DT spi muxing after pinctrl function rename serial: 8250_omap: Move wake-up interrupt to generic wakeirq serial: omap: Switch wake-up interrupt to generic wakeirq mmc: omap_hsmmc: Change wake-up interrupt to use generic wakeirq
2015-07-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse Pull fuse updates from Miklos Szeredi: "This is the start of improving fuse scalability. An input queue and a processing queue is split out from the monolithic fuse connection, each of those having their own spinlock. The end of the patchset adds the ability to clone a fuse connection. This means, that instead of having to read/write requests/answers on a single fuse device fd, the fuse daemon can have multiple distinct file descriptors open. Each of those can be used to receive requests and send answers, currently the only constraint is that a request must be answered on the same fd as it was read from. This can be extended further to allow binding a device clone to a specific CPU or NUMA node. Based on a patchset by Srinivas Eeda and Ashish Samant. Thanks to Ashish for the review of this series" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: (40 commits) fuse: update MAINTAINERS entry fuse: separate pqueue for clones fuse: introduce per-instance fuse_dev structure fuse: device fd clone fuse: abort: no fc->lock needed for request ending fuse: no fc->lock for pqueue parts fuse: no fc->lock in request_end() fuse: cleanup request_end() fuse: request_end(): do once fuse: add req flag for private list fuse: pqueue locking fuse: abort: group pqueue accesses fuse: cleanup fuse_dev_do_read() fuse: move list_del_init() from request_end() into callers fuse: duplicate ->connected in pqueue fuse: separate out processing queue fuse: simplify request_wait() fuse: no fc->lock for iqueue parts fuse: allow interrupt queuing without fc->lock fuse: iqueue locking ...
2015-07-02x86/asm/entry/64: Update path namesJames C Boyd
The paths mentioned in this file weren't updated through some file rename commits. Fix them to refer to the correct path. Signed-off-by: James C Boyd <jcboyd.dev@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: corbet@lwn.net Cc: trivial@kernel.org Link: http://lkml.kernel.org/r/1435781606-3037-1-git-send-email-jcboyd.dev@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-01Merge tag 'devicetree-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree updates from Grant Likely: "A whole lot of bug fixes. Nothing stands out here except the ability to enable CONFIG_OF on every architecture, and an import of a newer version of dtc" * tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: (22 commits) of/irq: Rename "intc_desc" to "of_intc_desc" to fix OF on sh of/irq: Fix pSeries boot failure Documentation: DT: Fix a typo in the filename "lantiq,<chip>-pinumx.txt" of: define of_find_node_by_phandle for !CONFIG_OF of/address: use atomic allocation in pci_register_io_range() of: Add vendor prefix for Zodiac Inflight Innovations dt/fdt: add empty versions of early_init_dt_*_memory_arch of: clean-up unnecessary libfdt include paths of: make unittest select OF_EARLY_FLATTREE instead of depend on it of: make CONFIG_OF user selectable MIPS: prepare for user enabling of CONFIG_OF of/fdt: fix argument name and add comments of unflatten_dt_node() of: return NUMA_NO_NODE from fallback of_node_to_nid() tps6507x.txt: Remove executable permission of/overlay: Grammar s/an negative/a negative/ of/fdt: Make fdt blob input parameters of unflatten functions const of: add helper function to retrive match data of: Grammar s/property exist/property exists/ of: Move OF flags to be visible even when !CONFIG_OF scripts/dtc: Update to upstream version 9d3649bd3be245c9 ...
2015-07-01Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - new driver for ST's LPC Watchdog - new driver for Conexant Digicolor CX92755 SoC - new driver for DA9062 watchdog - Addition of the watchdog registration deferral mechanism - several improvements on omap_wdt - several improvements and reboot-support for imgpdc_wdt - max63xx_wdt improvements - imx2_wdt improvements - dw_wdt improvements - and other small improvements and fixes" * git://www.linux-watchdog.org/linux-watchdog: (37 commits) watchdog: omap_wdt: early_enable module parameter watchdog: gpio_wdt: Add option for early registration watchdog: watchdog_core: Add watchdog registration deferral mechanism watchdog: max63xx: dynamically allocate device watchdog: imx2_wdt: Disable previously acquired clock on error path watchdog: imx2_wdt: Check for clk_prepare_enable() error watchdog: hpwdt: Add support for WDIOC_SETOPTIONS watchdog: docs: omap_wdt also understands nowayout watchdog: omap_wdt: implement get_timeleft watchdog: da9062: DA9062 watchdog driver watchdog: imx2_wdt: set watchdog parent device watchdog: mena21_wdt: Fix possible NULL pointer dereference watchdog: dw_wdt: keepalive the watchdog at write time watchdog: dw_wdt: No need for a spinlock watchdog: imx2_wdt: also set wdog->timeout to new_timeout watchdog: Allow compile test of GPIO consumers if !GPIOLIB watchdog: cadence: Add dependency on HAS_IOMEM watchdog: max63xx_wdt: Constify platform_device_id watchdog: MAX63XX_WATCHDOG does not depend on ARM watchdog: imgpdc: Add some documentation about the timeout ...
2015-07-01Merge tag 'clk-for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull clock framework updates from Michael Turquette: "The changes to the common clock framework for 4.2 are dominated by new drivers and updates to existing ones, as usual. There are some fixes to the framework itself and several cleanups for sparse warnings, etc" * tag 'clk-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: (135 commits) clk: stm32: Add clock driver for STM32F4[23]xxx devices dt-bindings: Document the STM32F4 clock bindings cpufreq: exynos: remove Exynos4210 specific cpufreq driver support ARM: Exynos: switch to using generic cpufreq driver for Exynos4210 clk: samsung: exynos4: add cpu clock configuration data and instantiate cpu clock clk: samsung: add infrastructure to register cpu clocks clk: add CLK_RECALC_NEW_RATES clock flag for Exynos cpu clock support doc: dt: add documentation for lpc1850-ccu clk driver clk: add lpc18xx ccu clk driver doc: dt: add documentation for lpc1850-cgu clk driver clk: add lpc18xx cgu clk driver clk: keystone: add support for post divider register for main pll clk: mvebu: flag the crypto clk as CLK_IGNORE_UNUSED clk: cygnus: remove Cygnus dummy clock binding clk: cygnus: add clock support for Broadcom Cygnus clk: Change bcm clocks build dependency clk: iproc: add initial common clock support clk: iproc: define Broadcom iProc clock binding MAINTAINERS: update email for Michael Turquette clk: meson: add some error handling in meson_clk_register_cpu() ...
2015-07-01Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem updates from Bryan Wu: "In this cycle, we finished to merge patches for LED Flash class driver. Other than that we have some bug fixes and new drivers for LED controllers" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (33 commits) leds:lp55xx: fix firmware loading error leds: fix max77693-led build errors leds: fix aat1290 build errors leds: aat1290: pass flags parameter to devm_gpiod_get leds: ktd2692: pass flags parameter to devm_gpiod_get drivers/leds: don't use module_init in non-modular leds-cobalt-raq.c leds: aat1290: add support for V4L2 Flash sub-device DT: aat1290: Document handling external strobe sources leds: max77693: add support for V4L2 Flash sub-device media: Add registration helpers for V4L2 flash sub-devices v4l: async: Add a pointer to of_node to struct v4l2_subdev, match it Documentation: leds: Add description of v4l2-flash sub-device leds: add BCM6358 LED driver leds: add DT binding for BCM6358 LED controller leds: fix brightness changing when software blinking is active Documentation: leds-lp5523: describe master fader attributes leds: lp5523: add master_fader support leds: leds-gpio: Allow compile test if !GPIOLIB leds: leds-gpio: Add missing #include <linux/of.h> gpiolib: Add missing dummies for the unified device properties interface ...
2015-07-01Merge tag 'platform-drivers-x86-v4.2-1' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver updates from Darren Hart: "Fairly routine update for platform-drivers-x86. Mostly fixes and cleanups, with a significant refactoring of toshiba* drivers. Includes the addition of the dell-rbtn driver. Details: asus-wmi: - fan control dell*: - add Dell airplane mode switch driver ideapad-laptop: - platform rfkill fixes, and regression fix pvpanic: - handle missing _STA correctly toshiba*: - rafactor bluetooth support - haps documentation - driver cleanup other: - Use acpi_video_unregister_backlight instead of acpi_video_unregister in serveral drivers. - Orphan msi-wmi. * tag 'platform-drivers-x86-v4.2-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (24 commits) MAINTAINERS: Orphan x86 driver msi-wmi ideapad: fix software rfkill setting dell-laptop: Use dell-rbtn instead i8042 filter when possible dell-rbtn: Export notifier for other kernel modules dell-rbtn: Dell Airplane Mode Switch driver samsung-laptop: Use acpi_video_unregister_backlight instead of acpi_video_unregister asus-wmi: Use acpi_video_unregister_backlight instead of acpi_video_unregister apple_gmux: Use acpi_video_unregister_backlight instead of acpi_video_unregister pvpanic: handle missing _STA correctly ideapad_laptop: Lenovo G50-30 fix rfkill reports wireless blocked asus-wmi: add fan control Documentation/ABI: Add file describing the sysfs entries for toshiba_haps toshiba_haps: Make use of DEVICE_ATTR_{RW, WO} macros toshiba_haps: Replace sscanf with kstrtoint toshiba_acpi: Bump driver version to 0.22 toshiba_acpi: Remove TOS_FAILURE check from some functions toshiba_acpi: Comments cleanup toshiba_acpi: Rename hci_{read, write}1 functions toshiba_acpi: Remove no longer needed hci_{read, write}2 functions toshiba_bluetooth: Change BT status message to debug ...
2015-07-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) mlx4 driver bug fixes (TX queue wakeups, csum complete indications) from Ido Shamay, Eran Ben Elisha, and Or Gerlitz. 2) Missing unlock in error path of PTP support in renesas driver, from Dan Carpenter. 3) Add Vitesse 8641 phy IDs to vitesse PHY driver, from Shaohui Xie. 4) Bnx2x driver bug fixes (linearization of encap packets, scratchpad parity error notifications, flow-control and speed settings) from Yuval Mintz, Manish Chopra, Shahed Shaikh, and Ariel Elior. 5) ipv6 extension header parsing in the igb chip has a HW errata, disable it. Frm Todd Fujinaka. 6) Fix PCI link state locking issue in e1000e driver, from Yanir Lubetkin. 7) Cure panics during MTU change in i40e, from Mitch Williams. 8) Don't leak promisc refs in DSA slave driver, from Gilad Ben-Yossef. 9) Add missing HAS_DMA dep to VIA Rhine driver, from Geery Uytterhoeven. 10) Make sure DMA map/unmap calls are symmetric in bnx2x driver, from Michal Schmidt. 11) Workaround for MDIO access problems in bcm7xxx devices, from FLorian Fainelli. 12) Fix races in SCTP protocol between OTTB responses and route removals, from Alexander Sverdlin. 13) Fix jumbo frame checksum issue with some mvneta devices, from Simon Guinot. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (58 commits) sock_diag: don't broadcast kernel sockets net: mvneta: disable IP checksum with jumbo frames for Armada 370 ARM: mvebu: update Ethernet compatible string for Armada XP net: mvneta: introduce compatible string "marvell, armada-xp-neta" api: fix compatibility of linux/in.h with netinet/in.h net: icplus: fix typo in constant name sis900: Trivial: Fix typos in enums stmmac: Trivial: fix typo in constant name sctp: Fix race between OOTB responce and route removal net-Liquidio: Delete unnecessary checks before the function call "vfree" vmxnet3: Bump up driver version number amd-xgbe: Add the __GFP_NOWARN flag to Rx buffer allocation net: phy: mdio-bcm-unimac: workaround initial read failures for integrated PHYs net: bcmgenet: workaround initial read failures for integrated PHYs net: phy: bcm7xxx: workaround MDIO management controller initial read bnx2x: fix DMA API usage net: via: VIA_RHINE and VIA_VELOCITY should depend on HAS_DMA net/phy: tune get_phy_c45_ids to support more c45 phy bnx2x: fix lockdep splat net: fec: don't access RACC register when not available ...
2015-07-01ARM: at91/dt: trivial: fix USB udc compatible stringNicolas Ferre
To please checkpatch and the tiresome reader, add the "atmel," prefix to the USB udc compatible string. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: <stable@vger.kernel.org> #4.0+ Signed-off-by: Kevin Hilman <khilman@linaro.org>
2015-07-01Merge tag 'omap-for-v4.2/wakeirq-drivers-v2' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/late Merge "omap generic wakeirq for v4.2 merge window" from Tony Lindgren: Omap driver changes for v4.2 to switch drivers over to Linux generic wake IRQ events for omap_hsmmc, 8250_omap and omap-serial drivers. The generic wake IRQs also fix issues that these drivers potentially have with IRQ re-entrancy at least for serial-omap. Note that because of dependencies and merge conflicts these are based on Rafael's pm-wakeirq and Greg's tty-next branches. * tag 'omap-for-v4.2/wakeirq-drivers-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (148 commits) serial: 8250_omap: Move wake-up interrupt to generic wakeirq serial: omap: Switch wake-up interrupt to generic wakeirq tty: move linux/gsmmux.h to uapi doc: dt: add documentation for nxp,lpc1850-uart serial: 8250: add LPC18xx/43xx UART driver serial: 8250_uniphier: add UniPhier serial driver serial: 8250_dw: support ACPI platforms with integrated DMA engine serial: of_serial: check the return value of clk_prepare_enable() serial: of_serial: use devm_clk_get() instead of clk_get() serial: earlycon: Add support for big-endian MMIO accesses serial: sirf: use hrtimer for data rx serial: sirf: correct the fifo empty_bit serial: sirf: fix system hung on console log output serial: 8250: remove return statements from void function sc16is7xx: use kworker for RS-485 configuration sc16is7xx: use kworker to update ier bits sc16is7xx: use kworker for md_proc sc16is7xx: move RTS delay to workqueue sc16is7xx: use kthread_worker for tx_work and irq sc16is7xx: use LSR_TEMT_BIT in .tx_empty() ...
2015-07-01Merge tag 'arc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull ARC architecture updates from Vineet Gupta: - support for HS38 cores based on ARCv2 ISA ARCv2 is the next generation ISA from Synopsys and basis for the HS3{4,6,8} families of processors which retain the traditional ARC mantra of low power and configurability and are now more performant and feature rich. HS38x is a 10 stage pipeline core which supports MMU (with huge pages) and SMP (upto 4 cores) among other features. + www.synopsys.com/dw/ipdir.php?ds=arc-hs38-processor + http://news.synopsys.com/2014-10-14-New-DesignWare-ARC-HS38-Processor-Doubles-Performance-for-Embedded-Linux-Applications + http://www.embedded.com/electronics-news/4435975/Synopsys-ARC-HS38-core-gives-2X-boost-to-Linux-based-apps - support for ARC SDP (Software Development platform): Main Board + CPU Cards = AXS101: CPU Card with ARC700 in silicon @ 700 MHz = AXS103: CPU Card with HS38x in FPGA - refactoring of ARCompact port to accomodate new ARCv2 ISA - misc updates/cleanups * tag 'arc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (72 commits) ARC: Fix build failures for ARCompact in linux-next after ARCv2 support ARCv2: Allow older gcc to cope with new regime of ARCv2/ARCompact support ARCv2: [vdk] dts files and defconfig for HS38 VDK ARCv2: [axs103] Support ARC SDP FPGA platform for HS38x cores ARC: [axs101] Prepare for AXS103 ARCv2: [nsim*hs*] Support simulation platforms for HS38x cores ARCv2: All bits in place, allow ARCv2 builds ARCv2: SLC: Handle explcit flush for DMA ops (w/o IO-coherency) ARCv2: STAR 9000837815 workaround hardware exclusive transactions livelock ARC: Reduce bitops lines of code using macros ARCv2: barriers arch: conditionally define smp_{mb,rmb,wmb} ARC: add smp barriers around atomics per Documentation/atomic_ops.txt ARC: add compiler barrier to LLSC based cmpxchg ARCv2: SMP: intc: IDU 2nd level intc for dynamic IRQ distribution ARCv2: SMP: clocksource: Enable Global Real Time counter ARCv2: SMP: ARConnect debug/robustness ARCv2: SMP: Support ARConnect (MCIP) for Inter-Core-Interrupts et al ARC: make plat_smp_ops weak to allow over-rides ARCv2: clocksource: Introduce 64bit local RTC counter ...
2015-07-01watchdog: omap_wdt: early_enable module parameterLars Poeschel
Add a early_enable module parameter to the omap_wdt that starts the watchdog on module insertion. The default value is 0 which does not start the watchdog - which also does not change the behavior if the parameter is not given. Signed-off-by: Lars Poeschel <poeschel@lemonage.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-07-01fuse: device fd cloneMiklos Szeredi
Allow an open fuse device to be "cloned". Userspace can create a clone by: newfd = open("/dev/fuse", O_RDWR) ioctl(newfd, FUSE_DEV_IOC_CLONE, &oldfd); At this point newfd will refer to the same fuse connection as oldfd. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reviewed-by: Ashish Samant <ashish.samant@oracle.com>
2015-07-01fs/file.c: don't acquire files->file_lock in fd_install()Eric Dumazet
Mateusz Guzik reported : Currently obtaining a new file descriptor results in locking fdtable twice - once in order to reserve a slot and second time to fill it. Holding the spinlock in __fd_install() is needed in case a resize is done, or to prevent a resize. Mateusz provided an RFC patch and a micro benchmark : http://people.redhat.com/~mguzik/pipebench.c A resize is an unlikely operation in a process lifetime, as table size is at least doubled at every resize. We can use RCU instead of the spinlock. __fd_install() must wait if a resize is in progress. The resize must block new __fd_install() callers from starting, and wait that ongoing install are finished (synchronize_sched()) resize should be attempted by a single thread to not waste resources. rcu_sched variant is used, as __fd_install() and expand_fdtable() run from process context. It gives us a ~30% speedup using pipebench on a dual Intel(R) Xeon(R) CPU E5-2696 v2 @ 2.50GHz Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Mateusz Guzik <mguzik@redhat.com> Acked-by: Mateusz Guzik <mguzik@redhat.com> Tested-by: Mateusz Guzik <mguzik@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-30Merge tag 'xfs-for-linus-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs Pul xfs updates from Dave Chinner: "There's a couple of small API changes to the core DAX code which required small changes to the ext2 and ext4 code bases, but otherwise everything is within the XFS codebase. This update contains: - A new sparse on-disk inode record format to allow small extents to be used for inode allocation when free space is fragmented. - DAX support. This includes minor changes to the DAX core code to fix problems with lock ordering and bufferhead mapping abuse. - transaction commit interface cleanup - removal of various unnecessary XFS specific type definitions - cleanup and optimisation of freelist preparation before allocation - various minor cleanups - bug fixes for - transaction reservation leaks - incorrect inode logging in unwritten extent conversion - mmap lock vs freeze ordering - remote symlink mishandling - attribute fork removal issues" * tag 'xfs-for-linus-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/linux-xfs: (49 commits) xfs: don't truncate attribute extents if no extents exist xfs: clean up XFS_MIN_FREELIST macros xfs: sanitise error handling in xfs_alloc_fix_freelist xfs: factor out free space extent length check xfs: xfs_alloc_fix_freelist() can use incore perag structures xfs: remove xfs_caddr_t xfs: use void pointers in log validation helpers xfs: return a void pointer from xfs_buf_offset xfs: remove inst_t xfs: remove __psint_t and __psunsigned_t xfs: fix remote symlinks on V5/CRC filesystems xfs: fix xfs_log_done interface xfs: saner xfs_trans_commit interface xfs: remove the flags argument to xfs_trans_cancel xfs: pass a boolean flag to xfs_trans_free_items xfs: switch remaining xfs_trans_dup users to xfs_trans_roll xfs: check min blks for random debug mode sparse allocations xfs: fix sparse inodes 32-bit compile failure xfs: add initial DAX support xfs: add DAX IO path support ...
2015-06-30net: mvneta: introduce compatible string "marvell, armada-xp-neta"Simon Guinot
The mvneta driver supports the Ethernet IP found in the Armada 370, XP, 380 and 385 SoCs. Since at least one more hardware feature is available for the Armada XP SoCs then a way to identify them is needed. This patch introduces a new compatible string "marvell,armada-xp-neta". Signed-off-by: Simon Guinot <simon.guinot@sequanux.org> Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit") Cc: <stable@vger.kernel.org> # v3.8+ Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-30Merge remote-tracking branch 'robh/for-next' into devicetree/nextGrant Likely
2015-06-30Merge branch 'x86/boot' into x86/urgentIngo Molnar
Merge branch that got ready. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-29Merge tag 'libnvdimm-for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm Pull libnvdimm subsystem from Dan Williams: "The libnvdimm sub-system introduces, in addition to the libnvdimm-core, 4 drivers / enabling modules: NFIT: Instantiates an "nvdimm bus" with the core and registers memory devices (NVDIMMs) enumerated by the ACPI 6.0 NFIT (NVDIMM Firmware Interface table). After registering NVDIMMs the NFIT driver then registers "region" devices. A libnvdimm-region defines an access mode and the boundaries of persistent memory media. A region may span multiple NVDIMMs that are interleaved by the hardware memory controller. In turn, a libnvdimm-region can be carved into a "namespace" device and bound to the PMEM or BLK driver which will attach a Linux block device (disk) interface to the memory. PMEM: Initially merged in v4.1 this driver for contiguous spans of persistent memory address ranges is re-worked to drive PMEM-namespaces emitted by the libnvdimm-core. In this update the PMEM driver, on x86, gains the ability to assert that writes to persistent memory have been flushed all the way through the caches and buffers in the platform to persistent media. See memcpy_to_pmem() and wmb_pmem(). BLK: This new driver enables access to persistent memory media through "Block Data Windows" as defined by the NFIT. The primary difference of this driver to PMEM is that only a small window of persistent memory is mapped into system address space at any given point in time. Per-NVDIMM windows are reprogrammed at run time, per-I/O, to access different portions of the media. BLK-mode, by definition, does not support DAX. BTT: This is a library, optionally consumed by either PMEM or BLK, that converts a byte-accessible namespace into a disk with atomic sector update semantics (prevents sector tearing on crash or power loss). The sinister aspect of sector tearing is that most applications do not know they have a atomic sector dependency. At least today's disk's rarely ever tear sectors and if they do one almost certainly gets a CRC error on access. NVDIMMs will always tear and always silently. Until an application is audited to be robust in the presence of sector-tearing the usage of BTT is recommended. Thanks to: Ross Zwisler, Jeff Moyer, Vishal Verma, Christoph Hellwig, Ingo Molnar, Neil Brown, Boaz Harrosh, Robert Elliott, Matthew Wilcox, Andy Rudoff, Linda Knippers, Toshi Kani, Nicholas Moulin, Rafael Wysocki, and Bob Moore" * tag 'libnvdimm-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: (33 commits) arch, x86: pmem api for ensuring durability of persistent memory updates libnvdimm: Add sysfs numa_node to NVDIMM devices libnvdimm: Set numa_node to NVDIMM devices acpi: Add acpi_map_pxm_to_online_node() libnvdimm, nfit: handle unarmed dimms, mark namespaces read-only pmem: flag pmem block devices as non-rotational libnvdimm: enable iostat pmem: make_request cleanups libnvdimm, pmem: fix up max_hw_sectors libnvdimm, blk: add support for blk integrity libnvdimm, btt: add support for blk integrity fs/block_dev.c: skip rw_page if bdev has integrity libnvdimm: Non-Volatile Devices tools/testing/nvdimm: libnvdimm unit test infrastructure libnvdimm, nfit, nd_blk: driver for BLK-mode access persistent memory nd_btt: atomic sector updates libnvdimm: infrastructure for btt devices libnvdimm: write blk label set libnvdimm: write pmem label set libnvdimm: blk labels and namespace instantiation ...
2015-06-29Merge tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have support for few new devices, few new features and odd fixes spread thru the subsystem. New devices added: - support for CSRatlas7 dma controller - Allwinner H3(sun8i) controller - TI DMA crossbar driver on DRA7x - new pxa driver New features added: - memset support is bought back now that we have a user in xdmac controller - interleaved transfers support different source and destination strides - supporting DMA routers and configuration thru DT - support for reusing descriptors - xdmac memset and interleaved transfer support - hdmac support for interleaved transfers - omap-dma support for memcpy Others: - Constify platform_device_id - mv_xor fixes and improvements" * tag 'dmaengine-4.2-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (46 commits) dmaengine: xgene: fix file permission dmaengine: fsl-edma: clear pending interrupts on initialization dmaengine: xdmac: Add memset support Documentation: dmaengine: document DMA_CTRL_ACK dmaengine: virt-dma: don't always free descriptor upon completion dmaengine: Revert "drivers/dma: remove unused support for MEMSET operations" dmaengine: hdmac: Implement interleaved transfers dmaengine: Move icg helpers to global header dmaengine: mv_xor: improve descriptors list handling and reduce locking dmaengine: mv_xor: Enlarge descriptor pool size dmaengine: mv_xor: add support for a38x command in descriptor mode dmaengine: mv_xor: Rename function for consistent naming dmaengine: mv_xor: bug fix for racing condition in descriptors cleanup dmaengine: pl330: fix wording in mcbufsz message dmaengine: sirf: add CSRatlas7 SoC support dmaengine: xgene-dma: Fix "incorrect type in assignement" warnings dmaengine: fix kernel-doc documentation dmaengine: pxa_dma: add support for legacy transition dmaengine: pxa_dma: add debug information dmaengine: pxa: add pxa dmaengine driver ...
2015-06-29watchdog: watchdog_core: Add watchdog registration deferral mechanismJean-Baptiste Theou
Currently, watchdog subsystem require the misc subsystem to register a watchdog. This may not be the case in case of an early registration of a watchdog, which can be required when the watchdog cannot be disabled. This patch introduces a deferral mechanism to remove this requirement. Signed-off-by: Jean-Baptiste Theou <jtheou@adeneo-embedded.us> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2015-06-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "The main change in this kernel is Casey's generalized LSM stacking work, which removes the hard-coding of Capabilities and Yama stacking, allowing multiple arbitrary "small" LSMs to be stacked with a default monolithic module (e.g. SELinux, Smack, AppArmor). See https://lwn.net/Articles/636056/ This will allow smaller, simpler LSMs to be incorporated into the mainline kernel and arbitrarily stacked by users. Also, this is a useful cleanup of the LSM code in its own right" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) tpm, tpm_crb: fix le64_to_cpu conversions in crb_acpi_add() vTPM: set virtual device before passing to ibmvtpm_reset_crq tpm_ibmvtpm: remove unneccessary message level. ima: update builtin policies ima: extend "mask" policy matching support ima: add support for new "euid" policy condition ima: fix ima_show_template_data_ascii() Smack: freeing an error pointer in smk_write_revoke_subj() selinux: fix setting of security labels on NFS selinux: Remove unused permission definitions selinux: enable genfscon labeling for sysfs and pstore files selinux: enable per-file labeling for debugfs files. selinux: update netlink socket classes signals: don't abuse __flush_signals() in selinux_bprm_committed_creds() selinux: Print 'sclass' as string when unrecognized netlink message occurs Smack: allow multiple labels in onlycap Smack: fix seq operations in smackfs ima: pass iint to ima_add_violation() ima: wrap event related data to the new ima_event_data structure integrity: add validity checks for 'path' parameter ...
2015-06-27Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - Improvements to the tlb_dump code - KVM fixes - Add support for appended DTB - Minor improvements to the R12000 support - Minor improvements to the R12000 support - Various platform improvments for BCM47xx - The usual pile of minor cleanups - A number of BPF fixes and improvments - Some improvments to the support for R3000 and DECstations - Some improvments to the ATH79 platform support - A major patchset for the JZ4740 SOC adding support for the CI20 platform - Add support for the Pistachio SOC - Minor BMIPS/BCM63xx platform support improvments. - Avoid "SYNC 0" as memory barrier when unlocking spinlocks - Add support for the XWR-1750 board. - Paul's __cpuinit/__cpuinitdata cleanups. - New Malta CPU board support large memory so enable ZONE_DMA32. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (131 commits) MIPS: spinlock: Adjust arch_spin_lock back-off time MIPS: asmmacro: Ensure 64-bit FP registers are used with MSA MIPS: BCM47xx: Simplify handling SPROM revisions MIPS: Cobalt Don't use module_init in non-modular MTD registration. MIPS: BCM47xx: Move NVRAM driver to the drivers/firmware/ MIPS: use for_each_sg() MIPS: BCM47xx: Don't select BCMA_HOST_PCI MIPS: BCM47xx: Add helper variable for storing NVRAM length MIPS: IRQ/IP27: Move IRQ allocation API to platform code. MIPS: Replace smp_mb with release barrier function in unlocks. MIPS: i8259: DT support MIPS: Malta: Basic DT plumbing MIPS: include errno.h for ENODEV in mips-cm.h MIPS: Define GCR_GIC_STATUS register fields MIPS: BPF: Introduce BPF ASM helpers MIPS: BPF: Use BPF register names to describe the ABI MIPS: BPF: Move register definition to the BPF header MIPS: net: BPF: Replace RSIZE with SZREG MIPS: BPF: Free up some callee-saved registers MIPS: Xtalk: Update xwidget.h with known Xtalk device numbers ...
2015-06-27Merge branch 'for-4.2' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "A relatively quiet cycle, with a mix of cleanup and smaller bugfixes" * 'for-4.2' of git://linux-nfs.org/~bfields/linux: (24 commits) sunrpc: use sg_init_one() in krb5_rc4_setup_enc/seq_key() nfsd: wrap too long lines in nfsd4_encode_read nfsd: fput rd_file from XDR encode context nfsd: take struct file setup fully into nfs4_preprocess_stateid_op nfsd: refactor nfs4_preprocess_stateid_op nfsd: clean up raparams handling nfsd: use swap() in sort_pacl_range() rpcrdma: Merge svcrdma and xprtrdma modules into one svcrdma: Add a separate "max data segs macro for svcrdma svcrdma: Replace GFP_KERNEL in a loop with GFP_NOFAIL svcrdma: Keep rpcrdma_msg fields in network byte-order svcrdma: Fix byte-swapping in svc_rdma_sendto.c nfsd: Update callback sequnce id only CB_SEQUENCE success nfsd: Reset cb_status in nfsd4_cb_prepare() at retrying svcrdma: Remove svc_rdma_xdr_decode_deferred_req() SUNRPC: Move EXPORT_SYMBOL for svc_process uapi/nfs: Add NFSv4.1 ACL definitions nfsd: Remove dead declarations nfsd: work around a gcc-5.1 warning nfsd: Checking for acl support does not require fetching any acls ...
2015-06-26Merge branch 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue updates from Tejun Heo: "Most of the changes are around implementing and fixing fallouts from sysfs and internal interface to limit the CPUs available to all unbound workqueues to help isolating CPUs. It needs more work as ordered workqueues can roam unrestricted but still is a significant improvement" * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix typos in comments workqueue: move flush_scheduled_work() to workqueue.h workqueue: remove the lock from wq_sysfs_prep_attrs() workqueue: remove the declaration of copy_workqueue_attrs() workqueue: ensure attrs changes are properly synchronized workqueue: separate out and refactor the locking of applying attrs workqueue: simplify wq_update_unbound_numa() workqueue: wq_pool_mutex protects the attrs-installation workqueue: fix a typo workqueue: function name in the comment differs from the real function name workqueue: fix trivial typo in Documentation/workqueue.txt workqueue: Allow modifying low level unbound workqueue cpumask workqueue: Create low-level unbound workqueues cpumask workqueue: split apply_workqueue_attrs() into 3 stages
2015-06-26Merge branch 'for-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: - threadgroup_lock got reorganized so that its users can pick the actual locking mechanism to use. Its only user - cgroups - is updated to use a percpu_rwsem instead of per-process rwsem. This makes things a bit lighter on hot paths and allows cgroups to perform and fail multi-task (a process) migrations atomically. Multi-task migrations are used in several places including the unified hierarchy. - Delegation rule and documentation added to unified hierarchy. This will likely be the last interface update from the cgroup core side for unified hierarchy before lifting the devel mask. - Some groundwork for the pids controller which is scheduled to be merged in the coming devel cycle. * 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: add delegation section to unified hierarchy documentation cgroup: require write perm on common ancestor when moving processes on the default hierarchy cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write() kernfs: make kernfs_get_inode() public MAINTAINERS: add a cgroup core co-maintainer cgroup: fix uninitialised iterator in for_each_subsys_which cgroup: replace explicit ss_mask checking with for_each_subsys_which cgroup: use bitmask to filter for_each_subsys cgroup: add seq_file forward declaration for struct cftype cgroup: simplify threadgroup locking sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem sched, cgroup: reorganize threadgroup locking cgroup: switch to unsigned long for bitmasks cgroup: reorganize include/linux/cgroup.h cgroup: separate out include/linux/cgroup-defs.h cgroup: fix some comment typos
2015-06-26Merge tag 'usb-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big USB patchset for 4.2-rc1. As is normal these days, the majority of changes are in the gadget drivers, with a bunch of other small driver changes. All of these have been in linux-next with no reported issues" * tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits) usb: dwc3: Use ASCII space in Kconfig usb: chipidea: add work-around for Marvell HSIC PHY startup usb: chipidea: allow multiple instances to use default ci_default_pdata dt-bindings: Consolidate ChipIdea USB ci13xxx bindings phy: add Marvell HSIC 28nm PHY phy: Add Marvell USB 2.0 OTG 28nm PHY dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings USB: ssb: use devm_kzalloc USB: ssb: fix error handling in ssb_hcd_create_pdev() usb: isp1760: check for null return from kzalloc cdc-acm: Add support of ATOL FPrint fiscal printers usb: chipidea: usbmisc_imx: Remove unneeded semicolon USB: usbtmc: add device quirk for Rigol DS6104 USB: serial: mos7840: Use setup_timer phy: twl4030-usb: add ABI documentation phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function. phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback. phy: twl4030-usb: make runtime pm more reliable. drivers:usb:fsl: Fix compilation error for fsl ehci drv usb: renesas_usbhs: Don't disable the pipe if Control write status stage ...
2015-06-26Merge tag 'tty-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the tty and serial driver patches for 4.2-rc1. A number of individual driver updates, some code cleanups, and other minor things, full details in the shortlog. All have been in linux-next for a while with no reported issues" * tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits) Doc: serial-rs485.txt: update RS485 driver interface Doc: tty.txt: remove mention of the BKL MAINTAINERS: tty: add serial docs directory serial: sprd: check for NULL after calling devm_clk_get serial: 8250_pci: Correct uartclk for xr17v35x expansion chips serial: 8250_pci: Add support for 12 port Exar boards serial: 8250_uniphier: add bindings document for UniPhier UART serial: core: cleanup in uart_get_baud_rate() serial: stm32-usart: Add STM32 USART Driver tty/serial: kill off set_irq_flags usage tty: move linux/gsmmux.h to uapi doc: dt: add documentation for nxp,lpc1850-uart serial: 8250: add LPC18xx/43xx UART driver serial: 8250_uniphier: add UniPhier serial driver serial: 8250_dw: support ACPI platforms with integrated DMA engine serial: of_serial: check the return value of clk_prepare_enable() serial: of_serial: use devm_clk_get() instead of clk_get() serial: earlycon: Add support for big-endian MMIO accesses serial: sirf: use hrtimer for data rx serial: sirf: correct the fifo empty_bit ...
2015-06-26Merge tag 'staging-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver updates from Greg KH: "Here's the big, really big, staging tree patches for 4.2-rc1. Loads of stuff in here, almost all just coding style fixes / churn, and a few new drivers as well, one of which I just disabled from the build a few minutes ago due to way too many build warnings. Other than the one "disable this driver" patch, all of these have been in linux-next for quite a while with no reported issues" * tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits) staging: wilc1000: disable driver due to build warnings Staging: rts5208: fix CHANGE_LINK_STATE value Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs Staging: sm750fb: modedb.h: Shorten lines to under 80 characters Staging: sm750fb: modedb.h: Replace spaces with tabs staging: comedi: addi_apci_3120: rename 'this_board' variables staging: comedi: addi_apci_1516: rename 'this_board' variables staging: comedi: ni_atmio: cleanup ni_getboardtype() staging: comedi: vmk80xx: sanity check context used to get the boardinfo staging: comedi: vmk80xx: rename 'boardinfo' variables staging: comedi: dt3000: rename 'this_board' variables staging: comedi: adv_pci_dio: rename 'this_board' variables staging: comedi: cb_pcidas64: rename 'thisboard' variables staging: comedi: cb_pcidas: rename 'thisboard' variables staging: comedi: me4000: rename 'thisboard' variables ...
2015-06-26Merge tag 'driver-core-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here is the driver core / firmware changes for 4.2-rc1. A number of small changes all over the place in the driver core, and in the firmware subsystem. Nothing really major, full details in the shortlog. Some of it is a bit of churn, given that the platform driver probing changes was found to not work well, so they were reverted. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits) Revert "base/platform: Only insert MEM and IO resources" Revert "base/platform: Continue on insert_resource() error" Revert "of/platform: Use platform_device interface" Revert "base/platform: Remove code duplication" firmware: add missing kfree for work on async call fs: sysfs: don't pass count == 0 to bin file readers base:dd - Fix for typo in comment to function driver_deferred_probe_trigger(). base/platform: Remove code duplication of/platform: Use platform_device interface base/platform: Continue on insert_resource() error base/platform: Only insert MEM and IO resources firmware: use const for remaining firmware names firmware: fix possible use after free on name on asynchronous request firmware: check for file truncation on direct firmware loading firmware: fix __getname() missing failure check drivers: of/base: move of_init to driver_init drivers/base: cacheinfo: fix annoying typo when DT nodes are absent sysfs: disambiguate between "error code" and "failure" in comments driver-core: fix build for !CONFIG_MODULES driver-core: make __device_attach() static ...
2015-06-26Merge tag 'char-misc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver pull request for 4.2-rc1. Lots of mei, extcon, coresight, uio, mic, and other driver updates in here. Full details in the shortlog. All of these have been in linux-next for some time with no reported problems" * tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits) mei: me: wait for power gating exit confirmation mei: reset flow control on the last client disconnection MAINTAINERS: mei: add mei_cl_bus.h to maintained file list misc: sram: sort and clean up included headers misc: sram: move reserved block logic out of probe function misc: sram: add private struct device and virt_base members misc: sram: report correct SRAM pool size misc: sram: bump error message level on unclean driver unbinding misc: sram: fix device node reference leak on error misc: sram: fix enabled clock leak on error path misc: mic: Fix reported static checker warning misc: mic: Fix randconfig build error by including errno.h uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config uio: pruss: Add CONFIG_HAS_IOMEM dependence uio: pruss: Include <linux/sizes.h> extcon: Redefine the unique id of supported external connectors without 'enum extcon' type char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration(). Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion parport: check exclusive access before register w1: use correct lock on error in w1_seq_show() ...
2015-06-26Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull request for v4.2. I've one other new driver from freescale on my radar, it's been posted and reviewed, I'd just like to get someone to give it a last look, so maybe I'll send it or maybe I'll leave it. There is no major nouveau changes in here, Ben was working on something big, and we agreed it was a bit late, there wasn't anything else he considered urgent to merge. There might be another msm pull for some bits that are waiting on arm-soc, I'll see how we time it. This touches some "of" stuff, acks are in place except for the fixes to the build in various configs,t hat I just applied. Summary: New drivers: - virtio-gpu: KMS only pieces of driver for virtio-gpu in qemu. This is just the first part of this driver, enough to run unaccelerated userspace on. As qemu merges more we'll start adding the 3D features for the virgl 3d work. - amdgpu: a new driver from AMD to driver their newer GPUs. (VI+) It contains a new cleaner userspace API, and is a clean break from radeon moving forward, that AMD are going to concentrate on. It also contains a set of register headers auto generated from AMD internal database. core: - atomic modesetting API completed, enabled by default now. - Add support for mode_id blob to atomic ioctl to complete interface. - bunch of Displayport MST fixes - lots of misc fixes. panel: - new simple panels - fix some long-standing build issues with bridge drivers radeon: - VCE1 support - add a GPU reset counter for userspace - lots of fixes. amdkfd: - H/W debugger support module - static user-mode queues - support killing all the waves when a process terminates - use standard DECLARE_BITMAP i915: - Add Broxton support - S3, rotation support for Skylake - RPS booting tuning - CPT modeset sequence fixes - ns2501 dither support - enable cmd parser on haswell - cdclk handling fixes - gen8 dynamic pte allocation - lots of atomic conversion work exynos: - Add atomic modesetting support - Add iommu support - Consolidate drm driver initialization - and MIC, DECON and MIPI-DSI support for exynos5433 omapdrm: - atomic modesetting support (fixes lots of things in rewrite) tegra: - DP aux transaction fixes - iommu support fix msm: - adreno a306 support - various dsi bits - various 64-bit fixes - NV12MT support rcar-du: - atomic and misc fixes sti: - fix HDMI timing complaince tilcdc: - use drm component API to access tda998x driver - fix module unloading qxl: - stability fixes" * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (872 commits) drm/nouveau: Pause between setting gpu to D3hot and cutting the power drm/dp/mst: close deadlock in connector destruction. drm: Always enable atomic API drm/vgem: Set unique to "vgem" of: fix a build error to of_graph_get_endpoint_by_regs function drm/dp/mst: take lock around looking up the branch device on hpd irq drm/dp/mst: make sure mst_primary mstb is valid in work function of: add EXPORT_SYMBOL for of_graph_get_endpoint_by_regs ARM: dts: rename the clock of MIPI DSI 'pll_clk' to 'sclk_mipi' drm/atomic: Don't set crtc_state->enable manually drm/exynos: dsi: do not set TE GPIO direction by input drm/exynos: dsi: add support for MIC driver as a bridge drm/exynos: dsi: add support for Exynos5433 drm/exynos: dsi: make use of array for clock access drm/exynos: dsi: make use of driver data for static values drm/exynos: dsi: add macros for register access drm/exynos: dsi: rename pll_clk to sclk_clk drm/exynos: mic: add MIC driver of: add helper for getting endpoint node of specific identifiers drm/exynos: add Exynos5433 decon driver ...
