The thermal controller implementation on Tegra194 is very similar to the
implementation on Tegra186. Add a compatible string for the new
generation.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
RZ/G2M also has 3 interrupts routed to the TSC, but the list was not
updated to reflect this.
Just drop the list, as this is the case for this TSC variant in all
R-Car Gen3 and RZ/G2 SoCs.
Fixes: be6af481f3b2d508 ("dt-bindings: thermal: rcar-gen3-thermal: Add r8a774a1 support")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- Revert a dt-bindings patch whose driver didn't make for 4.20
- fix a kernel oops at vicodec driver
- fix a frame overflow at gspca with was causing regressions on some
cameras, making them to not work
- use the proper type for wait_queue head
- make media request API compatible with 32-bit userspace on 64-bit
kernel
- fix a regression on Kernel 4.19 at dvb-pll
- don't use SPDX headers yet for GFDL
* tag 'media/v4.20-4' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
media: mediactl docs: Fix licensing message
media: dvb-pll: don't re-validate tuner frequencies
media: dvb-pll: fix tuner frequency ranges
media: Revert "media: dt-bindings: Document the Rockchip VPU bindings"
media: gspca: fix frame overflow error
media: vicodec: fix memchr() kernel oops
media: cedrus: add action item to the TODO
media: media-request: Add compat ioctl
media: Use wait_queue_head_t for media_request
Pull STIBP fallout fixes from Thomas Gleixner:
"The performance destruction department finally got it's act together
and came up with a cure for the STIPB regression:
- Provide a command line option to control the spectre v2 user space
mitigations. Default is either seccomp or prctl (if seccomp is
disabled in Kconfig). prctl allows mitigation opt-in, seccomp
enables the migitation for sandboxed processes.
- Rework the code to handle the conditional STIBP/IBPB control and
remove the now unused ptrace_may_access_sched() optimization
attempt
- Disable STIBP automatically when SMT is disabled
- Optimize the switch_to() logic to avoid MSR writes and invocations
of __switch_to_xtra().
- Make the asynchronous speculation TIF updates synchronous to
prevent stale mitigation state.
As a general cleanup this also makes retpoline directly depend on
compiler support and removes the 'minimal retpoline' option which just
pretended to provide some form of security while providing none"
* 'x86-pti-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
x86/speculation: Provide IBPB always command line options
x86/speculation: Add seccomp Spectre v2 user space protection mode
x86/speculation: Enable prctl mode for spectre_v2_user
x86/speculation: Add prctl() control for indirect branch speculation
x86/speculation: Prepare arch_smt_update() for PRCTL mode
x86/speculation: Prevent stale SPEC_CTRL msr content
x86/speculation: Split out TIF update
ptrace: Remove unused ptrace_may_access_sched() and MODE_IBRS
x86/speculation: Prepare for conditional IBPB in switch_mm()
x86/speculation: Avoid __switch_to_xtra() calls
x86/process: Consolidate and simplify switch_to_xtra() code
x86/speculation: Prepare for per task indirect branch speculation control
x86/speculation: Add command line control for indirect branch speculation
x86/speculation: Unify conditional spectre v2 print functions
x86/speculataion: Mark command line parser data __initdata
x86/speculation: Mark string arrays const correctly
x86/speculation: Reorder the spec_v2 code
x86/l1tf: Show actual SMT state
x86/speculation: Rework SMT state change
sched/smt: Expose sched_smt_present static key
Merge misc fixes from Andrew Morton:
"31 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (31 commits)
ocfs2: fix potential use after free
mm/khugepaged: fix the xas_create_range() error path
mm/khugepaged: collapse_shmem() do not crash on Compound
mm/khugepaged: collapse_shmem() without freezing new_page
mm/khugepaged: minor reorderings in collapse_shmem()
mm/khugepaged: collapse_shmem() remember to clear holes
mm/khugepaged: fix crashes due to misaccounted holes
mm/khugepaged: collapse_shmem() stop if punched or truncated
mm/huge_memory: fix lockdep complaint on 32-bit i_size_read()
mm/huge_memory: splitting set mapping+index before unfreeze
mm/huge_memory: rename freeze_page() to unmap_page()
initramfs: clean old path before creating a hardlink
kernel/kcov.c: mark funcs in __sanitizer_cov_trace_pc() as notrace
psi: make disabling/enabling easier for vendor kernels
proc: fixup map_files test on arm
debugobjects: avoid recursive calls with kmemleak
userfaultfd: shmem: UFFDIO_COPY: set the page dirty if VM_WRITE is not set
userfaultfd: shmem: add i_size checks
userfaultfd: shmem/hugetlbfs: only allow to register VM_MAYWRITE vmas
userfaultfd: shmem: allocate anonymous memory for MAP_PRIVATE shmem
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
- Cortex-A76 erratum workaround
- ftrace fix to enable syscall events on arm64
- Fix uninitialised pointer in iort_get_platform_device_domain()
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
ACPI/IORT: Fix iort_get_platform_device_domain() uninitialized pointer value
arm64: ftrace: Fix to enable syscall events on arm64
arm64: Add workaround for Cortex-A76 erratum 1286807
Mel Gorman reports a hackbench regression with psi that would prohibit
shipping the suse kernel with it default-enabled, but he'd still like
users to be able to opt in at little to no cost to others.
With the current combination of CONFIG_PSI and the psi_disabled bool set
from the commandline, this is a challenge. Do the following things to
make it easier:
1. Add a config option CONFIG_PSI_DEFAULT_DISABLED that allows distros
to enable CONFIG_PSI in their kernel but leave the feature disabled
unless a user requests it at boot-time.
To avoid double negatives, rename psi_disabled= to psi=.
2. Make psi_disabled a static branch to eliminate any branch costs
when the feature is disabled.
In terms of numbers before and after this patch, Mel says:
: The following is a comparision using CONFIG_PSI=n as a baseline against
: your patch and a vanilla kernel
: 4.20.0-rc4 4.20.0-rc4 4.20.0-rc4
: kconfigdisable-v1r1 vanilla psidisable-v1r1
: Amean 1 1.3100 ( 0.00%) 1.3923 ( -6.28%) 1.3427 ( -2.49%)
: Amean 3 3.8860 ( 0.00%) 4.1230 * -6.10%* 3.8860 ( -0.00%)
: Amean 5 6.8847 ( 0.00%) 8.0390 * -16.77%* 6.7727 ( 1.63%)
: Amean 7 9.9310 ( 0.00%) 10.8367 * -9.12%* 9.9910 ( -0.60%)
: Amean 12 16.6577 ( 0.00%) 18.2363 * -9.48%* 17.1083 ( -2.71%)
: Amean 18 26.5133 ( 0.00%) 27.8833 * -5.17%* 25.7663 ( 2.82%)
: Amean 24 34.3003 ( 0.00%) 34.6830 ( -1.12%) 32.0450 ( 6.58%)
: Amean 30 40.0063 ( 0.00%) 40.5800 ( -1.43%) 41.5087 ( -3.76%)
: Amean 32 40.1407 ( 0.00%) 41.2273 ( -2.71%) 39.9417 ( 0.50%)
: It's showing that the vanilla kernel takes a hit (as the bisection
: indicated it would) and that disabling PSI by default is reasonably
: close in terms of performance for this particular workload on this
: particular machine so;
Link: http://lkml.kernel.org/r/20181127165329.GA29728@cmpxchg.org
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Tested-by: Mel Gorman <mgorman@techsingularity.net>
Reported-by: Mel Gorman <mgorman@techsingularity.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY driver fixes from Greg KH:
"Here are some small USB and PHY driver fixes for 4.20-rc5
Nothing big at all, just the usual handful of USB fixes for reported
issues, along with some gadget and PHY driver bug fixes.
All of these have been in linux-next with no reported issues. Note,
the USB gadget fixes were in linux-next on its own branch, not in
mine, it just got merged into here yesterday and missed linux-next of
today"
* tag 'usb-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usb: gadget: u_ether: fix unsafe list iteration
USB: omap_udc: fix rejection of out transfers when DMA is used
USB: omap_udc: fix USB gadget functionality on Palm Tungsten E
USB: omap_udc: fix omap_udc_start() on 15xx machines
USB: omap_udc: fix crashes on probe error and module removal
USB: omap_udc: use devm_request_irq()
usb: core: quirks: add RESET_RESUME quirk for Cherry G230 Stream series
USB: usb-storage: Add new IDs to ums-realtek
Revert "usb: dwc3: gadget: skip Set/Clear Halt when invalid"
phy: qcom-qusb2: Fix HSTX_TRIM tuning with fused value for SDM845
phy: qcom-qusb2: Use HSTX_TRIM fused value as is
dt-bindings: phy-qcom-qmp: Fix several mistakes from prior commits
phy: uniphier-pcie: Depend on HAS_IOMEM
Pull x86 fixes from Ingo Molnar:
"Misc fixes:
- MCE related boot crash fix on certain AMD systems
- FPU exception handling fix
- FPU handling race fix
- revert+rewrite of the RSDP boot protocol extension, use boot_params
instead
- documentation fix"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/MCE/AMD: Fix the thresholding machinery initialization order
x86/fpu: Use the correct exception table macro in the XSTATE_OP wrapper
x86/fpu: Disable bottom halves while loading FPU registers
x86/acpi, x86/boot: Take RSDP address from boot params if available
x86/boot: Mostly revert commit ae7e1238e68f2a ("Add ACPI RSDP address to setup_header")
x86/ptrace: Fix documentation for tracehook_report_syscall_entry()
Pull perf fixes from Ingo Molnar:
"Misc fixes:
- counter freezing related regression fix
- uprobes race fix
- Intel PMU unusual event combination fix
- .. and diverse tooling fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
uprobes: Fix handle_swbp() vs. unregister() + register() race once more
perf/x86/intel: Disallow precise_ip on BTS events
perf/x86/intel: Add generic branch tracing check to intel_pmu_has_bts()
perf/x86/intel: Move branch tracing setup to the Intel-specific source file
perf/x86/intel: Fix regression by default disabling perfmon v4 interrupt handling
perf tools beauty ioctl: Support new ISO7816 commands
tools uapi asm-generic: Synchronize ioctls.h
tools arch x86: Update tools's copy of cpufeatures.h
tools headers uapi: Synchronize i915_drm.h
perf tools: Restore proper cwd on return from mnt namespace
tools build feature: Check if get_current_dir_name() is available
perf tools: Fix crash on synthesizing the unit
On the affected Cortex-A76 cores (r0p0 to r3p0), if a virtual address
for a cacheable mapping of a location is being accessed by a core while
another core is remapping the virtual address to a new physical page
using the recommended break-before-make sequence, then under very rare
circumstances TLBI+DSB completes before a read using the translation
being invalidated has been observed by other observers. The workaround
repeats the TLBI+DSB operation and is shared with the Qualcomm Falkor
erratum 1009
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi fixes from Mark Brown:
"A few driver specific fixes here, nothing big or that stands out for
anyone other than the driver users.
The omap2-mcspi fix is for issues that started showing up with a
change in defconfig in this release to make cpuidle get turned on by
default"
* tag 'spi-fix-v4.20-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: omap2-mcspi: Add missing suspend and resume calls
spi: mediatek: use correct mata->xfer_len when in fifo transfer
spi: uniphier: fix incorrect property items
Provide the possibility to enable IBPB always in combination with 'prctl'
and 'seccomp'.
Add the extra command line options and rework the IBPB selection to
evaluate the command instead of the mode selected by the STIPB switch case.
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: David Woodhouse <dwmw@amazon.co.uk>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Casey Schaufler <casey.schaufler@intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Jon Masters <jcm@redhat.com>
Cc: Waiman Long <longman9394@gmail.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dave Stewart <david.c.stewart@intel.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20181125185006.144047038@linutronix.de
If 'prctl' mode of user space protection from spectre v2 is selected
on the kernel command-line, STIBP and IBPB are applied on tasks which
restrict their indirect branch speculation via prctl.
SECCOMP enables the SSBD mitigation for sandboxed tasks already, so it
makes sense to prevent spectre v2 user space to user space attacks as
well.
The Intel mitigation guide documents how STIPB works:
Setting bit 1 (STIBP) of the IA32_SPEC_CTRL MSR on a logical processor
prevents the predicted targets of indirect branches on any logical
processor of that core from being controlled by software that executes
(or executed previously) on another logical processor of the same core.
Ergo setting STIBP protects the task itself from being attacked from a task
running on a different hyper-thread and protects the tasks running on
different hyper-threads from being attacked.
While the document suggests that the branch predictors are shielded between
the logical processors, the observed performance regressions suggest that
STIBP simply disables the branch predictor more or less completely. Of
course the document wording is vague, but the fact that there is also no
requirement for issuing IBPB when STIBP is used points clearly in that
direction. The kernel still issues IBPB even when STIBP is used until Intel
clarifies the whole mechanism.
IBPB is issued when the task switches out, so malicious sandbox code cannot
mistrain the branch predictor for the next user space task on the same
logical processor.
Link: https://lkml.kernel.org/r/20181125185006.051663132@linutronix.de
Now that all prerequisites are in place:
- Add the prctl command line option
- Default the 'auto' mode to 'prctl'
- When SMT state changes, update the static key which controls the
conditional STIBP evaluation on context switch.
- At init update the static key which controls the conditional IBPB
Link: https://lkml.kernel.org/r/20181125185005.958421388@linutronix.de
Add the PR_SPEC_INDIRECT_BRANCH option for the PR_GET_SPECULATION_CTRL and
PR_SET_SPECULATION_CTRL prctls to allow fine grained per task control of
indirect branch speculation via STIBP and IBPB.
Invocations:
Check indirect branch speculation status with
- prctl(PR_GET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, 0, 0, 0);
Enable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_ENABLE, 0, 0);
Disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_DISABLE, 0, 0);
Force disable indirect branch speculation with
- prctl(PR_SET_SPECULATION_CTRL, PR_SPEC_INDIRECT_BRANCH, PR_SPEC_FORCE_DISABLE, 0, 0);
See Documentation/userspace-api/spec_ctrl.rst.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181125185005.866780996@linutronix.de
Add command line control for user space indirect branch speculation
mitigations. The new option is: spectre_v2_user=
The initial options are:
- on: Unconditionally enabled
- off: Unconditionally disabled
-auto: Kernel selects mitigation (default off for now)
When the spectre_v2= command line argument is either 'on' or 'off' this
implies that the application to application control follows that state even
if a contradicting spectre_v2_user= argument is supplied.
Originally-by: Tim Chen <tim.c.chen@linux.intel.com>
Link: https://lkml.kernel.org/r/20181125185005.082720373@linutronix.de
Right now, it mentions two SPDX headers that don't exist inside the Kernel:
GFDL-1.1-or-later
And an exception:
no-invariant-sections
While it would be trivial to add the first one, there's no way,
currently, to distinguish, with SPDX, between a free and a non-free
document under GFDL.
Free documents with GFDL should not have invariant sections.
There's an open issue at SPDX tree waiting for it to be solved.
While we don't have this issue closed, let's just replace by a
free-text license, and add a TODO note to remind us to revisit it
later.
Reviewed-by: Tomasz Figa <tfiga@chromium.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/kishon/linux-phy into usb-linus
Kishon writes:
phy: for 4.20-rc
*) Fix updating HSTX_TRIM tuning parameter in qcom-qusb2 PHY driver
*) Fix inconsistencies between dt-bindings and the driver
*) Add "Depend on HAS_IOMEM" uniphier-pcie to avoid randconfig errors
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
* tag 'phy-for-4.20-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/kishon/linux-phy:
Pull XArray updates from Matthew Wilcox:
"We found some bugs in the DAX conversion to XArray (and one bug which
predated the XArray conversion). There were a couple of bugs in some
of the higher-level functions, which aren't actually being called in
today's kernel, but surfaced as a result of converting existing radix
tree & IDR users over to the XArray.
Some of the other changes to how the higher-level APIs work were also
motivated by converting various users; again, they're not in use in
today's kernel, so changing them has a low probability of introducing
a bug.
Dan can still trigger a bug in the DAX code with hot-offline/online,
and we're working on tracking that down"
* tag 'xarray-4.20-rc4' of git://git.infradead.org/users/willy/linux-dax:
XArray tests: Add missing locking
dax: Avoid losing wakeup in dax_lock_mapping_entry
dax: Fix huge page faults
dax: Fix dax_unlock_mapping_entry for PMD pages
dax: Reinstate RCU protection of inode
dax: Make sure the unlocking entry isn't locked
dax: Remove optimisation from dax_lock_mapping_entry
XArray tests: Correct some 64-bit assumptions
XArray: Correct xa_store_range
XArray: Fix Documentation
XArray: Handle NULL pointers differently for allocation
XArray: Unify xa_store and __xa_store
XArray: Add xa_store_bh() and xa_store_irq()
XArray: Turn xa_erase into an exported function
XArray: Unify xa_cmpxchg and __xa_cmpxchg
XArray: Regularise xa_reserve
nilfs2: Use xa_erase_irq
XArray: Export __xa_foo to non-GPL modules
XArray: Fix xa_for_each with a single element at 0
git://git.kernel.org/pub/scm/linux/kernel/git/hid/hid
Pull HID fixes from Jiri Kosina:
- revert of the high-resolution scrolling feature, as it breaks certain
hardware due to incompatibilities between Logitech and Microsoft
worlds. Peter Hutterer is working on a fixed implementation. Until
that is finished, revert by Benjamin Tissoires.
- revert of incorrect strncpy->strlcpy conversion in uhid, from David
Herrmann
- fix for buggy sendfile() implementation on uhid device node, from
Eric Biggers
- a few assorted device-ID specific quirks
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/hid/hid:
Revert "Input: Add the `REL_WHEEL_HI_RES` event code"
Revert "HID: input: Create a utility class for counting scroll events"
Revert "HID: logitech: Add function to enable HID++ 1.0 "scrolling acceleration""
Revert "HID: logitech: Enable high-resolution scrolling on Logitech mice"
Revert "HID: logitech: Use LDJ_DEVICE macro for existing Logitech mice"
Revert "HID: logitech: fix a used uninitialized GCC warning"
Revert "HID: input: simplify/fix high-res scroll event handling"
HID: Add quirk for Primax PIXART OEM mice
HID: i2c-hid: Disable runtime PM for LG touchscreen
HID: multitouch: Add pointstick support for Cirque Touchpad
HID: steam: remove input device when a hid client is running.
Revert "HID: uhid: use strlcpy() instead of strncpy()"
HID: uhid: forbid UHID_CREATE under KERNEL_DS or elevated privileges
HID: input: Ignore battery reported by Symbol DS4308
HID: Add quirk for Microsoft PIXART OEM mouse
Pull networking fixes from David Miller:
1) Need to take mutex in ath9k_add_interface(), from Dan Carpenter.
2) Fix mt76 build without CONFIG_LEDS_CLASS, from Arnd Bergmann.
3) Fix socket wmem accounting in SCTP, from Xin Long.
4) Fix failed resume crash in ena driver, from Arthur Kiyanovski.
5) qed driver passes bytes instead of bits into second arg of
bitmap_weight(). From Denis Bolotin.
6) Fix reset deadlock in ibmvnic, from Juliet Kim.
7) skb_scrube_packet() needs to scrub the fwd marks too, from Petr
Machata.
8) Make sure older TCP stacks see enough dup ACKs, and avoid doing SACK
compression during this period, from Eric Dumazet.
9) Add atomicity to SMC protocol cursor handling, from Ursula Braun.
10) Don't leave dangling error pointer if bpf_prog_add() fails in
thunderx driver, from Lorenzo Bianconi. Also, when we unmap TSO
headers, set sq->tso_hdrs to NULL.
11) Fix race condition over state variables in act_police, from Davide
Caratti.
12) Disable guest csum in the presence of XDP in virtio_net, from Jason
Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (64 commits)
net: gemini: Fix copy/paste error
net: phy: mscc: fix deadlock in vsc85xx_default_config
dt-bindings: dsa: Fix typo in "probed"
net: thunderx: set tso_hdrs pointer to NULL in nicvf_free_snd_queue
net: amd: add missing of_node_put()
team: no need to do team_notify_peers or team_mcast_rejoin when disabling port
virtio-net: fail XDP set if guest csum is negotiated
virtio-net: disable guest csum during XDP set
net/sched: act_police: add missing spinlock initialization
net: don't keep lonely packets forever in the gro hash
net/ipv6: re-do dad when interface has IFF_NOARP flag change
packet: copy user buffers before orphan or clone
ibmvnic: Update driver queues after change in ring size support
ibmvnic: Fix RX queue buffer cleanup
net: thunderx: set xdp_prog to NULL if bpf_prog_add fails
net/dim: Update DIM start sample after each DIM iteration
net: faraday: ftmac100: remove netif_running(netdev) check before disabling interrupts
net/smc: use after free fix in smc_wr_tx_put_slot()
net/smc: atomic SMCD cursor handling
net/smc: add SMC-D shutdown signal
The correct form is "can be probed", so fix the typo.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
This reverts commit e4183d3256e3cd668e899d06af66da5aac3a51af.
The commit was picked by mistake, as the Rockchip VPU driver
is not ready for inclusion yet, and it's still under discussion.
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are some small char/misc driver fixes for issues that have been
reported.
Nothing major, highlights include:
- gnss sync write fixes
- uio oops fix
- nvmem fixes
- other minor fixes and some documentation/maintainers updates
Full details are in the shortlog.
All of these have been in linux-next for a while with no reported
issues"
* tag 'char-misc-4.20-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Documentation/security-bugs: Postpone fix publication in exceptional cases
MAINTAINERS: Add Sasha as a stable branch maintainer
gnss: sirf: fix synchronous write timeout
gnss: serial: fix synchronous write timeout
uio: Fix an Oops on load
test_firmware: fix error return getting clobbered
nvmem: core: fix regression in of_nvmem_cell_get()
misc: atmel-ssc: Fix section annotation on atmel_ssc_get_driver_data
drivers/misc/sgi-gru: fix Spectre v1 vulnerability
Drivers: hv: kvp: Fix the recent regression caused by incorrect clean-up
slimbus: ngd: remove unnecessary check
Pull USB fixes from Greg KH:
"Here are a number of small USB fixes for 4.20-rc4.
There's the usual xhci and dwc2/3 fixes as well as a few minor other
issues resolved for problems that have been reported. Full details are
in the shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'usb-4.20-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usb: cdc-acm: add entry for Hiro (Conexant) modem
usb: xhci: Prevent bus suspend if a port connect change or polling state is detected
usb: core: Fix hub port connection events lost
usb: dwc3: gadget: fix ISOC TRB type on unaligned transfers
Revert "usb: gadget: ffs: Fix BUG when userland exits with submitted AIO transfers"
usb: dwc2: pci: Fix an error code in probe
usb: dwc3: Fix NULL pointer exception in dwc3_pci_remove()
xhci: Add quirk to workaround the errata seen on Cavium Thunder-X2 Soc
usb: xhci: fix timeout for transition from RExit to U0
usb: xhci: fix uninitialized completion when USB3 port got wrong status
xhci: Add check for invalid byte size error when UAS devices are connected.
xhci: handle port status events for removed USB3 hcd
xhci: Fix leaking USB3 shared_hcd at xhci removal
USB: misc: appledisplay: add 20" Apple Cinema Display
USB: quirks: Add no-lpm quirk for Raydium touchscreens
usb: quirks: Add delay-init quirk for Corsair K70 LUX RGB
USB: Wait for extra delay time after USB_PORT_FEAT_RESET for quirky hub
usb: dwc3: gadget: Properly check last unaligned/zero chain TRB
usb: dwc3: core: Clean up ULPI device
This reverts commit aaf9978c3c0291ef3beaa97610bc9c3084656a85.
Quoting Peter:
There is a HID feature report called "Resolution Multiplier"
Described in the "Enhanced Wheel Support in Windows" doc and
the "USB HID Usage Tables" page 30.
http://download.microsoft.com/download/b/d/1/bd1f7ef4-7d72-419e-bc5c-9f79ad7bb66e/wheel.docx
https://www.usb.org/sites/default/files/documents/hut1_12v2.pdf
This was new for Windows Vista, so we're only a decade behind here. I only
accidentally found this a few days ago while debugging a stuck button on a
Microsoft mouse.
The docs above describe it like this: a wheel control by default sends
value 1 per notch. If the resolution multiplier is active, the wheel is
expected to send a value of $multiplier per notch (e.g. MS Sculpt mouse) or
just send events more often, i.e. for less physical motion (e.g. MS Comfort
mouse).
For the latter, you need the right HW of course. The Sculpt mouse has
tactile wheel clicks, so nothing really changes. The Comfort mouse has
continuous motion with no tactile clicks. Similar to the free-wheeling
Logitech mice but without any inertia.
Note that the doc also says that Vista and onwards *always* enable this
feature where available.
An example HID definition looks like this:
Usage Page Generic Desktop (0x01)
Usage Resolution Multiplier (0x48)
Logical Minimum 0
Logical Maximum 1
Physical Minimum 1
Physical Maximum 16
Report Size 2 # in bits
Report Count 1
Feature (Data, Var, Abs)
So the actual bits have values 0 or 1 and that reflects real values 1 or 16.
We've only seen single-bits so far, so there's low-res and hi-res, but
nothing in between.
The multiplier is available for HID usages "Wheel" and "AC Pan" (horiz wheel).
Microsoft suggests that
> Vendors should ship their devices with smooth scrolling disabled and allow
> Windows to enable it. This ensures that the device works like a regular HID
> device on legacy operating systems that do not support smooth scrolling.
(see the wheel doc linked above)
The mice that we tested so far do reset on unplug.
Device Support looks to be all (?) Microsoft mice but nothing else
Not supported:
- Logitech G500s, G303
- Roccat Kone XTD
- all the cheap Lenovo, HP, Dell, Logitech USB mice that come with a
workstation that I could find don't have it.
- Etekcity something something
- Razer Imperator
Supported:
- Microsoft Comfort Optical Mouse 3000 - yes, physical: 1:4
- Microsoft Sculpt Ergonomic Mouse - yes, physical: 1:12
- Microsoft Surface mouse - yes, physical: 1:4
So again, I think this is really just available on Microsoft mice, but
probably all decent MS mice released over the last decade.
Looking at the hardware itself:
- no noticeable notches in the weel
- low-res: 18 events per 360deg rotation (click angle 20 deg)
- high-res: 72 events per 360deg → matches multiplier of 4
- I can feel the notches during wheel turns
- low-res: 24 events per 360 deg rotation (click angle 15 deg)
- horiz wheel is tilt-based, continuous output value 1
- high-res: 24 events per 360deg with value 12 → matches multiplier of 12
- horiz wheel output rate doubles/triples?, values is 3
- It's a touch strip, not a wheel so no notches
- high-res: events have value 4 instead of 1
a bit strange given that it doesn't actually have notches.
Ok, why is this an issue for the current API? First, because the logitech
multiplier used in Harry's patches looks suspiciously like the Resolution
Multiplier so I think we should assume it's the same thing. Nestor, can you
shed some light on that?
- `REL_WHEEL` is defined as the number of notches, emulated where needed.
- `REL_WHEEL_HI_RES` is the movement of the user's finger in microns.
- `WM_MOUSEWHEEL` (Windows) is is a multiple of 120, defined as "the threshold
for action to be taken and one such action"
https://docs.microsoft.com/en-us/windows/desktop/inputdev/wm-mousewheel
If the multiplier is set to M, this means we need an accumulated value of M
until we can claim there was a wheel click. So after enabling the multiplier
and setting it to the maximum (like Windows):
- M units are 15deg rotation → 1 unit is 2620/M micron (see below). This is
the `REL_WHEEL_HI_RES` value.
- wheel diameter 20mm: 15 deg rotation is 2.62mm, 2620 micron (pi * 20mm /
(360deg/15deg))
- For every M units accumulated, send one `REL_WHEEL` event
The problem here is that we've now hardcoded 20mm/15 deg into the kernel and
we have no way of getting the size of the wheel or the click angle into the
kernel.
In userspace we now have to undo the kernel's calculation. If our click angle
is e.g. 20 degree we have to undo the (lossy) calculation from the kernel and
calculate the correct angle instead. This also means the 15 is a hardcoded
option forever and cannot be changed.
In hid-logitech-hidpp.c, the microns per unit is hardcoded per device.
Harry, did you measure those by hand? We'd need to update the kernel for
every device and there are 10 years worth of devices from MS alone.
The multiplier default is 8 which is in the right ballpark, so I'm pretty
sure this is the same as the Resolution Multiplier, just in HID++ lingo. And
given that the 120 magic factor is what Windows uses in the end, I can't
imagine Logitech rolling their own thing here. Nestor?
And we're already fairly inaccurate with the microns anyway. The MX Anywhere
2S has a click angle of 20 degrees (18 stops) and a 17mm wheel, so a wheel
notch is approximately 2.67mm, one event at multiplier 8 (1/8 of a notch)
would be 334 micron. That's only 80% of the fallback value of 406 in the
kernel. Multiplier 6 gives us 445micron (10% off). I'm assuming multiplier 7
doesn't exist because it's not a factor of 120.
Summary:
Best option may be to simply do what Windows is doing, all the HW manufacturers
have to use that approach after all. Switch `REL_WHEEL_HI_RES` to report in
fractions of 120, with 120 being one notch and divide that by the multiplier
for the actual events. So e.g. the Logitech multiplier 8 would send value 15
for each event in hi-res mode. This can be converted in userspace to
whatever userspace needs (combined with a hwdb there that tells you wheel
size/click angle/...).
include/uapi/linux/input-event-codes.h -> I kept the new
reserved event in the code, so I had to adapt the revert
slightly
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Acked-by: Harry Cutts <hcutts@chromium.org>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
handling
Kyle Huey reported that 'rr', a replay debugger, broke due to the following commit:
af3bdb991a5c ("perf/x86/intel: Add a separate Arch Perfmon v4 PMI handler")
Rework the 'disable_counter_freezing' __setup() parameter such that we
can explicitly enable/disable it and switch to default disabled.
To this purpose, rename the parameter to "perf_v4_pmi=" which is a much
better description and allows requiring a bool argument.
[ mingo: Improved the changelog some more. ]
Reported-by: Kyle Huey <me@kylehuey.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Kan Liang <kan.liang@linux.intel.com>
Cc: Robert O'Callahan <robert@ocallahan.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: acme@kernel.org
Link: http://lkml.kernel.org/r/20181120170842.GZ2131@hirez.programming.kicks-ass.net
At the request of the reporter, the Linux kernel security team offers to
postpone the publishing of a fix for up to 5 business days from the date
of a report.
While it is generally undesirable to keep a fix private after it has
been developed, this short window is intended to allow distributions to
package the fix into their kernel builds and permits early inclusion of
the security team in the case of a co-ordinated disclosure with other
parties. Unfortunately, discussions with major Linux distributions and
cloud providers has revealed that 5 business days is not sufficient to
achieve either of these two goals.
As an example, cloud providers need to roll out KVM security fixes to a
global fleet of hosts with sufficient early ramp-up and monitoring. An
end-to-end timeline of less than two weeks dramatically cuts into the
amount of early validation and increases the chance of guest-visible
regressions.
The consequence of this timeline mismatch is that security issues are
commonly fixed without the involvement of the Linux kernel security team
and are instead analysed and addressed by an ad-hoc group of developers
across companies contributing to Linux. In some cases, mainline (and
therefore the official stable kernels) can be left to languish for
extended periods of time. This undermines the Linux kernel security
process and puts upstream developers in a difficult position should they
find themselves involved with an undisclosed security problem that they
are unable to report due to restrictions from their employer.
To accommodate the needs of these users of the Linux kernel and
encourage them to engage with the Linux security team when security
issues are first uncovered, extend the maximum period for which fixes
may be delayed to 7 calendar days, or 14 calendar days in exceptional
cases, where the logistics of QA and large scale rollouts specifically
need to be accommodated. This brings parity with the linux-distros@
maximum embargo period of 14 calendar days.
Cc: Amit Shah <aams@amazon.com>
Cc: Laura Abbott <labbott@redhat.com>
Co-developed-by: Thomas Gleixner <tglx@linutronix.de>
Co-developed-by: David Woodhouse <dwmw@amazon.co.uk>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Reviewed-by: Tyler Hicks <tyhicks@canonical.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
- add a missing include at v4l2-controls uAPI header
- minor kAPI update for the request API
- some fixes at CEC core
- use a lower minimum height for the virtual codec driver
- cleanup a gcc warning due to the lack of a fall though markup
- tc358743: Remove unnecessary self assignment
- fix the V4L event subscription logic
- docs: Document metadata format in struct v4l2_format
- omap3isp and ipu3-cio2: fix unbinding logic
* tag 'media/v4.20-3' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
media: ipu3-cio2: Use cio2_queues_exit
media: ipu3-cio2: Unregister device nodes first, then release resources
media: omap3isp: Unregister media device as first
media: docs: Document metadata format in struct v4l2_format
media: v4l: event: Add subscription to list before calling "add" operation
media: dm365_ipipeif: better annotate a fall though
media: Rename vb2_m2m_request_queue -> v4l2_m2m_request_queue
media: cec: increase debug level for 'queue full'
media: cec: check for non-OK/NACK conditions while claiming a LA
media: vicodec: lower minimum height to 360
media: tc358743: Remove unnecessary self assignment
media: v4l: fix uapi mpeg slice params definition
v4l2-controls: add a missing include
setup_header")
Peter Anvin pointed out that commit:
ae7e1238e68f2a ("x86/boot: Add ACPI RSDP address to setup_header")
should be reverted as setup_header should only contain items set by the
legacy BIOS.
So revert said commit. Instead of fully reverting the dependent commit
of:
e7b66d16fe4172 ("x86/acpi, x86/boot: Take RSDP address for boot params if available")
just remove the setup_header reference in order to replace it by
a boot_params in a followup patch.
Suggested-by: "H. Peter Anvin" <hpa@zytor.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
Cc: boris.ostrovsky@oracle.com
Cc: bp@alien8.de
Cc: daniel.kiper@oracle.com
Cc: sstabellini@kernel.org
Cc: xen-devel@lists.xenproject.org
Link: http://lkml.kernel.org/r/20181120072529.5489-2-jgross@suse.com
1) Fix some potentially uninitialized variables and use-after-free in
kvaser_usb can drier, from Jimmy Assarsson.
2) Fix leaks in qed driver, from Denis Bolotin.
3) Socket leak in l2tp, from Xin Long.
4) RSS context allocation fix in bnxt_en from Michael Chan.
5) Fix cxgb4 build errors, from Ganesh Goudar.
6) Route leaks in ipv6 when removing exceptions, from Xin Long.
7) Memory leak in IDR allocation handling of act_pedit, from Davide
Caratti.
8) Use-after-free of bridge vlan stats, from Nikolay Aleksandrov.
9) When MTU is locked, do not force DF bit on ipv4 tunnels. From
Sabrina Dubroca.
10) When NAPI cached skb is reused, we must set it to the proper initial
state which includes skb->pkt_type. From Eric Dumazet.
11) Lockdep and non-linear SKB handling fix in tipc from Jon Maloy.
12) Set RX queue properly in various tuntap receive paths, from Matthew
Cover.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (61 commits)
tuntap: fix multiqueue rx
ipv6: Fix PMTU updates for UDP/raw sockets in presence of VRF
tipc: don't assume linear buffer when reading ancillary data
tipc: fix lockdep warning when reinitilaizing sockets
net-gro: reset skb->pkt_type in napi_reuse_skb()
tc-testing: tdc.py: Guard against lack of returncode in executed command
tc-testing: tdc.py: ignore errors when decoding stdout/stderr
ip_tunnel: don't force DF when MTU is locked
MAINTAINERS: Add entry for CAKE qdisc
net: bridge: fix vlan stats use-after-free on destruction
socket: do a generic_file_splice_read when proto_ops has no splice_read
net: phy: mdio-gpio: Fix working over slow can_sleep GPIOs
Revert "net: phy: mdio-gpio: Fix working over slow can_sleep GPIOs"
net/sched: act_pedit: fix memory leak when IDR allocation fails
net: lantiq: Fix returned value in case of error in 'xrx200_probe()'
ipv6: fix a dst leak when removing its exception
net: mvneta: Don't advertise 2.5G modes
drivers/net/ethernet/qlogic/qed/qed_rdma.h: fix typo
net/mlx4: Fix UBSAN warning of signed integer overflow
The life-checking function, which is used by kAFS to make sure that a call
is still live in the event of a pending signal, only samples the received
packet serial number counter; it doesn't actually provoke a change in the
counter, rather relying on the server to happen to give us a packet in the
time window.
Fix this by adding a function to force a ping to be transmitted.
kAFS then keeps track of whether there's been a stall, and if so, uses the
new function to ping the server, resetting the timeout to allow the reply
to come back.
If there's a stall, a ping and the call is *still* stalled in the same
place after another period, then the call will be aborted.
Fixes: bc5e3a546d55 ("rxrpc: Use MSG_WAITALL to tell sendmsg() to temporarily ignore signals")
Fixes: f4d15fb6f99a ("rxrpc: Provide functions for allowing cleaner handling of signals")
Pull power management fixes from Rafael Wysocki:
"These remove a stale DT entry left behind after recent removal of a
cpufreq driver without users, fix up error handling in the imx6q
cpufreq driver, fix two issues in the cpufreq documentation, and
update the ARM cpufreq driver.
Specifics:
- Drop stale DT binding for the arm_big_little_dt driver removed
recently (Sudeep Holla).
- Fix up error handling in the imx6q cpufreq driver to make it report
voltage scaling failures (Anson Huang).
- Fix two issues in the cpufreq documentation (Viresh Kumar, Zhao Wei
Liew).
- Fix ARM cpuidle driver initialization regression from the 4.19 time
frame and rework the driver registration part of it to simplify
code (Ulf Hansson)"
* tag 'pm-4.20-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ARM: cpuidle: Convert to use cpuidle_register|unregister()
ARM: cpuidle: Don't register the driver when back-end init returns -ENXIO
dt-bindings: cpufreq: remove stale arm_big_little_dt entry
Documentation: cpufreq: Correct a typo
cpufreq: imx6q: add return value check for voltage scale
Documentation: cpu-freq: Frequencies aren't always sorted
ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/mkl/linux-can
Marc Kleine-Budde says:
pull-request: can 2018-11-09
this is a pull request of 20 patches for net/master.
First we have a patch by Oliver Hartkopp which changes the raw socket's
raw_sendmsg() to return an error value if the user tries to send a CANFD
frame to a CAN-2.0 device.
The next two patches are by Jimmy Assarsson and fix potential problems
in the kvaser_usb driver.
YueHaibing's patches for the ucan driver fix a compile time warning and
remove a duplicate include.
Eugeniu Rosca patch adds more binding documentation to the rcar_can
driver bindings. The next two patches are by Fabrizio Castro for the
rcar_can driver and fixes a problem in the driver's probe function and
document the r8a774a1 binding.
Lukas Wunner's patch fixes a recpetion problem in hi311x driver by
switching from edge to level triggered interruts.
The next three patches all target the flexcan driver. Pankaj Bansal's
patch unconditionally unlocks the last mailbox used for RX. Alexander
Stein provides a better workaround for a hardware limitation when
sending RTR frames, by using the last mailbox for TX, resulting in fewer
lost frames. The patch by me simplyfies the driver, by making a runtime
value a compile time constant.
The following 4 patches are by me and provide the groundwork for the
next patches by Oleksij Rempel. To avoid code duplication common code in
the common CAN driver infrastructure is factured out and error handling
is cleaned up.
The next 4 patches are by Oleksij Rempel and fix the problem in the
flexcan driver that other processes see TX frames arrive out of order
with ragards to a RX'ed frame (which are send by a different system on
the CAN bus as the result of our TX frame).
Digging through the "phy-qcom-qmp" showed me many inconsistencies
between the bindings and the reality of the driver. Let's fix them
all.
* In commit 2d66eab18375 ("dt-bindings: phy: qmp: Add support for QMP
phy in IPQ8074") we probably should have explicitly listed that
there are no clocks for this PHY and also added the reset names in
alphabetical order. You can see that there are no clocks in the
driver where "clk_list" is NULL.
* In commit 8587b220f05e ("dt-bindings: phy-qcom-qmp: Update bindings
for QMP V3 USB PHY") we probably should have listed the resets for
this new PHY and also removed the "(Optional)" marking for the "cfg"
reset since PHYs that need "cfg" really do need it. It's just that
not all PHYs need it.
* In commit 7f0802074120 ("dt-bindings: phy-qcom-qmp: Update bindings
for sdm845") we forgot to update one instance of the string
"qcom,qmp-v3-usb3-phy" to be "qcom,sdm845-qmp-usb3-phy". Let's fix
that. We should also have added "qcom,sdm845-qmp-usb3-uni-phy" to
the clock-names and reset-names lists.
* In commit 99c7c7364b71 ("dt-bindings: phy-qcom-qmp: Add UFS phy
compatible string for sdm845") we should have added the set of
clocks and resets for "qcom,sdm845-qmp-ufs-phy". These were taken
from the driver.
* Cleanup the wording for what properties child nodes have to make it
more obvious which types of PHYs need clocks and resets. This was
sorta implicit in the "-names" description but I found myself
confused.
* As per the code not all "pcie qmp phys" have resets. Specifically
note that the "has_lane_rst" property in the driver is false for
"ipq8074-qmp-pcie-phy". Thus make it clear exactly which PHYs need
child nodes with resets.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Evan Green <evgreen@chromium.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Pull x86 fixes from Thomas Gleixner:
"A set of x86 fixes:
- Cure the LDT remapping to user space on 5 level paging which ended
up in the KASLR space
- Remove LDT mapping before freeing the LDT pages
- Make NFIT MCE handling more robust
- Unbreak the VSMP build by removing the dependency on paravirt ops
- Support broken PIT emulation on Microsoft hyperV
- Don't trace vmware_sched_clock() to avoid tracer recursion
- Remove -pipe from KBUILD CFLAGS which breaks clang and is also
slower on GCC
- Trivial coding style and typo fixes"
x86/cpu/vmware: Do not trace vmware_sched_clock()
x86/vsmp: Remove dependency on pv_irq_ops
x86/ldt: Remove unused variable in map_ldt_struct()
x86/ldt: Unmap PTEs for the slot before freeing LDT pages
x86/mm: Move LDT remap out of KASLR region on 5-level paging
acpi/nfit, x86/mce: Validate a MCE's address before using it
acpi/nfit, x86/mce: Handle only uncorrectable machine checks
x86/build: Remove -pipe from KBUILD_CFLAGS
x86/hyper-v: Fix indentation in hv_do_fast_hypercall16()
Documentation/x86: Fix typo in zero-page.txt
x86/hyper-v: Enable PIT shutdown quirk
clockevents/drivers/i8253: Add support for PIT shutdown quirk
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"I2C has one bugfix (qcom-geni driver), one arch enablement (i2c-omap
driver, no code change), and a new driver (nvidia-gpu) this time"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
usb: typec: ucsi: add support for Cypress CCGx
i2c: nvidia-gpu: make pm_ops static
i2c: add i2c bus driver for NVIDIA GPU
i2c: qcom-geni: Fix runtime PM mismatch with child devices
MAINTAINERS: Add entry for i2c-omap driver
i2c: omap: Enable for ARCH_K3
dt-bindings: i2c: omap: Add new compatible for AM654 SoCs
Latest NVIDIA GPU card has USB Type-C interface. There is a
Type-C controller which can be accessed over I2C.
This driver adds I2C bus driver to communicate with Type-C controller.
I2C client driver will be part of USB Type-C UCSI driver.
Signed-off-by: Ajay Gupta <ajayg@nvidia.com>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
[wsa: kept Makefile sorting]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
AM654 SoCs have same I2C IP as OMAP SoCs. Add new compatible to
handle AM654 SoCs. While at that reformat the existing compatible list
for older SoCs to list one valid compatible per line.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
If the hi3110 shares the SPI bus with another traffic-intensive device
and packets are received in high volume (by a separate machine sending
with "cangen -g 0 -i -x"), reception stops after a few minutes and the
counter in /proc/interrupts stops incrementing. Bus state is "active".
Bringing the interface down and back up reconvenes the reception. The
issue is not observed when the hi3110 is the sole device on the SPI bus.
Using a level-triggered interrupt makes the issue go away and lets the
hi3110 successfully receive 2 GByte over the course of 5 days while a
ks8851 Ethernet chip on the same SPI bus handles 6 GByte of traffic.
Unfortunately the hi3110 datasheet is mum on the trigger type. The pin
description on page 3 only specifies the polarity (active high):
http://www.holtic.com/documents/371-hi-3110_v-rev-kpdf.do
Cc: Mathias Duckeck <m.duckeck@kunbus.de>
Cc: Akshay Bhat <akshay.bhat@timesys.com>
Cc: Casey Fitzpatrick <casey.fitzpatrick@timesys.com>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Cc: linux-stable <stable@vger.kernel.org>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Document RZ/G2M (r8a774a1) SoC specific bindings.
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Signed-off-by: Chris Paterson <Chris.Paterson2@renesas.com>
Reviewed-by: Biju Das <biju.das@bp.renesas.com>
Document the support for rcar_can on R8A77965 SoC devices.
Add R8A77965 to the list of SoCs which require the "assigned-clocks" and
"assigned-clock-rates" properties (thanks, Sergei).
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds
Pull LED fixes from Jacek Anaszewski:
"All three fixes are related to the newly added pattern trigger:
- remove mutex_lock() from timer callback, which would trigger
problems related to sleeping in atomic context, the removal is
harmless since mutex protection turned out to be redundant in this
case
- fix pattern parsing to properly handle intervals with brightness == 0
- fix typos in the ABI documentation"
* tag 'led-fixes-for-4.20-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/j.anaszewski/linux-leds:
Documentation: ABI: led-trigger-pattern: Fix typos
leds: trigger: Fix sleeping function called from invalid context
Fix pattern handling optimalization
Most of the ARM platforms used v2 OPP bindings to support big-little
configurations. This arm_big_little_dt binding is incomplete and was
never used.
Commit f174e49e4906 (cpufreq: remove unused arm_big_little_dt driver)
removed the driver supporting this binding, but the binding was left
unnoticed, so let's get rid of it now.
Fixes: f174e49e4906 (cpufreq: remove unused arm_big_little_dt driver)
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
- Spelling s/brigntess/brightness/,
- Double "use".
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
Fix a typo in the admin-guide documentation for cpufreq.
Signed-off-by: Zhao Wei Liew <zhaoweiliew@gmail.com>
The order in which the frequencies are displayed in cpufreq stats
depends on the order in which the frequencies were sorted in the
frequency table provided to cpufreq core by the cpufreq driver. They can
be completely unsorted as well.
The documentation's claim that the stats will be sorted in descending
order is hence incorrect and here is an attempt to fix it.
Reported-by: Pavel <pavel2000@ngs.ru>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Devices connected under Terminus Technology Inc. Hub (1a40:0101) may
fail to work after the system resumes from suspend:
[ 206.063325] usb 3-2.4: reset full-speed USB device number 4 using xhci_hcd
[ 206.143691] usb 3-2.4: device descriptor read/64, error -32
[ 206.351671] usb 3-2.4: device descriptor read/64, error -32
Info for this hub:
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1a40 ProdID=0101 Rev=01.11
S: Product=USB 2.0 Hub
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
Some expirements indicate that the USB devices connected to the hub are
innocent, it's the hub itself is to blame. The hub needs extra delay
time after it resets its port.
Hence wait for extra delay, if the device is connected to this quirky
hub.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Cc: stable <stable@vger.kernel.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
On 5-level paging the LDT remap area is placed in the middle of the KASLR
randomization region and it can overlap with the direct mapping, the
vmalloc or the vmap area.
The LDT mapping is per mm, so it cannot be moved into the P4D page table
next to the CPU_ENTRY_AREA without complicating PGD table allocation for
5-level paging.
The 4 PGD slot gap just before the direct mapping is reserved for
hypervisors, so it cannot be used.
Move the direct mapping one slot deeper and use the resulting gap for the
LDT remap area. The resulting layout is the same for 4 and 5 level paging.
[ tglx: Massaged changelog ]
Fixes: f55f0501cbf6 ("x86/pti: Put the LDT in its own PGD if PTI is on")
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Cc: bp@alien8.de
Cc: hpa@zytor.com
Cc: dave.hansen@linux.intel.com
Cc: peterz@infradead.org
Cc: jgross@suse.com
Cc: bhe@redhat.com
Cc: willy@infradead.org
Cc: linux-mm@kvack.org
Link: https://lkml.kernel.org/r/20181026122856.66224-2-kirill.shutemov@linux.intel.com
