https://gitlab.freedesktop.org/drm/msm into drm-next
+ usual progress on cleanups
+ dsi vs EPROBE_DEFER fixes
+ msm8998 (snapdragon 835 support)
+ a540 gpu support (mesa support already landed)
+ dsi, dsi-phy support
+ mdp5 and dpu interconnect (bus/memory scaling) support
+ initial prep work for per-context pagetables (at least the parts that
don't have external dependencies like iommu/arm-smmu)
There is one more patch for fixing DSI cmd mode panels (part of a set of
patches to get things working on nexus5), but it would be conflicty with
1cff7440a86e04a613665803b42034 in drm-next without rebasing or back-merge,
and since it doesn't conflict with anything in msm-next, I think it best
if Sean merges that through drm-mix-fixes instead.
(In other news, I've been making some progress w/ getting efifb working
properly on sdm850 laptop without horrible hacks, and drm/msm + clk stuff
not totally falling over when bootloader enables display and things are
already running when driver probes.. but not quite ready yet, hopefully
we can post some of that for 5.4.. should help for both the sdm835 and
sdm850 laptops.)
Link: https://patchwork.freedesktop.org/patch/msgid/CAF6AEGsj3N4XzDLSDoa+4RHZ9wXObYmhcep0M3LjnRg48BeLvg@mail.gmail.com
into drm-next
Picking up pace on the upstreaming of Komeda driver, with quite a lot
of new features added this time. On top of that we have the small
cleanups and improved usage of the debugfs functions. Please pull!
Link: https://patchwork.freedesktop.org/patch/msgid/20190621095349.GI17204@e110455-lin.cambridge.arm.com
git://anongit.freedesktop.org/drm/drm-intel into drm-next
Features:
- HDR support (Uma, Ville)
- Add I2C symlink under HDMI connector similar to DP (Oleg)
- Add ICL multi-segmented gamma support (Shashank, Uma)
- Update register whitelist support for new hardware (Robert, John)
- GuC firmware update with updated ABI interface (Michal, Oscar)
- Add support for new DMC header versions (Lucas)
- In-kernel blitter client for selftest use (Matthew)
- Add Mule Creec Canyon (MCC) PCH support to go with EHL (Matt)
- EHL platform feature updates (Matt)
- Use Command Transport Buffers with GuC on all gens (Daniele)
- New i915.force_probe module parameter to replace i915.alpha_support (Jani)
Refactoring:
- Better runtime PM code abstraction/encapsulation (Daniele)
- VBT parsing cleanup and improvements (Jani)
- Move display code to its own subdirectory (Jani)
- Header cleanup (Jani, Daniele)
- Prep work for subsclice mask expansion (Stuart)
- Use uncore mmio register accessors more, remove unused macro wrappers (Tvrtko)
- Remove unused atomic property get/set stubs (Maarten)
- GTT cleanups and improvements (Mika)
- Pass intel_ types instead of drm_ types in plenty of display code (Ville)
- Engine reset, hangcheck, fault code cleanups and improvements (Tvrtko)
- Consider AML variants simply as either KBL or CFL ULX (Ville)
- State checker cleanups and improvements (Ville)
- GEM code reorganization to more files under gem subdirectory (Chris)
- Reducing dependency on a coarse struct_mutex (Chris)
Fixes:
- Fix use of uninitialized/incorrect error pointers (Colin, Dan)
- Fix DSI fastboot on some VLV/CHV platforms (Hans)
- Fix DSI error path (Hans)
- Add ICL port A combo PHY HW state check (Imre)
- Fix ICL AUX-B HW not done issue (Imre)
- Fix perf whitelist on gen10+ (Lionel)
- Fix PSR exit by forcing manual exit on older gens (José)
- Match voltage ranges instead of exact values (Lucas)
- Fix SDVO HDMI audio, with cleanups (Ville)
- Fix plane state dumps (Ville)
- Fix driver cleanup code to support driver hot unbind (Janusz)
- Add checks for ICL memory bandwidth requirements (Ville)
- Fix toggling between no C8 planes vs. at least one C8 plane (Ville)
- Improved checks on PLL usage conditions, refactoring (Ville)
- Avoid clobbering M/N values in fastset fuzzy checks (Ville)
- Take a runtime pm wakeref for atomic commits (Chris)
- Do not allow runtime pm autosuspend to remove userspace GGTT mmaps too quickly (Chris)
- Avoid refcount_inc on known zero count to avoid debug flagging (Chris)
Link: https://patchwork.freedesktop.org/patch/msgid/87v9x1lpdh.fsf@intel.com
Add interconnect properties such as interconnect provider specifier
, the edge source and destination ports which are required by the
interconnect API to configure interconnect path for MDSS.
Changes in v2:
- None
Changes in v3:
- Remove common property definitions (Rob Herring)
Changes in v4:
- Use port macros and change port string names (Georgi Djakov)
Changes in v5-v7:
- None
Signed-off-by: Sravanthi Kollukuduru <skolluku@codeaurora.org>
Signed-off-by: Jayant Shekhar <jshekhar@codeaurora.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Rob Clark <robdclark@chromium.org>
I rushed merging this a bit too much, and Noralf pointed out that
we're a lot better already and have made great progress.
Let's try again.
v2: Fix typo spotted by Eric Engestrom.
Fixes: 8db420ac6cf2 ("drm/todo: Improve drm_gem_object funcs todo")
Reviewed-by: Noralf Trønnes <noralf@tronnes.org>
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Sean Paul <sean@poorly.run>
Cc: Thomas Zimmermann <tzimmermann@suse.de>
Cc: Gerd Hoffmann <kraxel@redhat.com>
Cc: Rob Herring <robh@kernel.org>
Cc: Noralf Trønnes <noralf@tronnes.org>
Cc: Eric Anholt <eric@anholt.net>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190618140241.19856-1-daniel.vetter@ffwll.ch
Add documentation for the devicetree bindings of the LCD controller
present in the JZ47xx family of SoCs from Ingenic.
Signed-off-by: Paul Cercueil <paul@crapouillou.net>
Tested-by: Artur Rojek <contact@artur-rojek.eu>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190603152331.23160-1-paul@crapouillou.net
Current komeda driver uses three dedicated clks for a specific purpose:
- mclk: main engine clock
- pclk: APB clock
- pipeline->aclk: AXI clock.
But per spec the komeda HW only has three input clks:
- ACLK: used for AXI masters, APB slave and most pipeline processing
- PXCLK for pipeline 0: output pixel clock for pipeline 0
- PXCLK for pipeline 1: output pixel clock for pipeline 1
So one ACLK is enough, no need to split it to three mclk/pclk/axiclk.
Signed-off-by: James Qian Wang (Arm Technology China) <james.qian.wang@arm.com>
Signed-off-by: Liviu Dudau <liviu.dudau@arm.com>
Updates the device-tree doc about how to enable SMMU by devicetree.
Signed-off-by: Lowry Li (Arm Technology China) <lowry.li@arm.com>
Reviewed-by: Liviu Dudau <liviu.dudau@arm.com>
Reviewed-by: James Qian Wang (Arm Technology China) <james.qian.wang@arm.com>
remove-fbcon-notifiers topic branch is based on rc4, so we need a fresh
backmerge of drm-next to pull it in.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Properly configuring the overscan properties might be needed for the
initial setup of the framebuffer for display that still have overscan.
Let's allow for more properties on the kernel command line to setup each
margin.
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
Link: https://patchwork.freedesktop.org/patch/msgid/e481f1628e3768ca49226ec2115cfa4dfcbd5e4c.1560783090.git-series.maxime.ripard@bootlin.com
Rotations and reflections setup are needed in some scenarios to initialise
properly the initial framebuffer. Some drivers already had a bunch of
quirks to deal with this, such as either a private kernel command line
parameter (omapdss) or on the device tree (various panels).
In order to accomodate this, let's create a video mode parameter to deal
with the rotation and reflexion.
Link: https://patchwork.freedesktop.org/patch/msgid/777da16e42db757c1f5b414b5ca34507097fed5c.1560783090.git-series.maxime.ripard@bootlin.com
Maarten needs -rc4 backmerged so he can pull in the fbcon notifier
removal topic branch into drm-misc-next.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
The DSI phy on MSM8998 is a 10nm design like SDM845, however it has some
slightly different quirks which need to be handled by drivers. Provide
a separate compatible to assist in handling the specifics.
Signed-off-by: Jeffrey Hugo <jeffrey.l.hugo@gmail.com>
Fix the plethora of Sphinx build errors after moving the display files
under a subdirectory.
Fixes: 379bc100232a ("drm/i915: move modesetting output/encoder code under display/")
Fixes: df0566a641f9 ("drm/i915: move modesetting core code under display/")
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190617102944.25129-1-jani.nikula@intel.com
We're kinda going in the wrong direction. Spotted while typing better
gem/prime docs.
Reviewed-by: Eric Anholt <eric@anholt.net>
Acked-by: Gerd Hoffmann <kraxel@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190614203615.12639-2-daniel.vetter@ffwll.ch
Pick up rc3 and rc4 and the merges from the other branches,
we're a bit out of date.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"This has an unusually high density of tricky fixes:
- task_get_css() could deadlock when it races against a dying cgroup.
- cgroup.procs didn't list thread group leaders with live threads.
This could mislead readers to think that a cgroup is empty when
it's not. Fixed by making PROCS iterator include dead tasks. I made
a couple mistakes making this change and this pull request contains
a couple follow-up patches.
- When cpusets run out of online cpus, it updates cpusmasks of member
tasks in bizarre ways. Joel improved the behavior significantly"
* 'for-5.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cpuset: restore sanity to cpuset_cpus_allowed_fallback()
cgroup: Fix css_task_iter_advance_css_set() cset skip condition
cgroup: css_task_iter_skip()'d iterators must be advanced before accessed
cgroup: Include dying leaders with live threads in PROCS iterations
cgroup: Implement css_task_iter_skip()
cgroup: Call cgroup_release() before __exit_signal()
docs cgroups: add another example size for hugetlb
cgroup: Use css_tryget() instead of css_tryget_online() in task_get_css()
Pull block fixes from Jens Axboe:
- Remove references to old schedulers for the scheduler switching and
blkio controller documentation (Andreas)
- Kill duplicate check for report zone for null_blk (Chaitanya)
- Two bcache fixes (Coly)
- Ensure that mq-deadline is selected if zoned block device is enabled,
as we need that to support them (Damien)
- Fix io_uring memory leak (Eric)
- ps3vram fallout from LBDAF removal (Geert)
- Redundant blk-mq debugfs debugfs_create return check cleanup (Greg)
- Extend NOPLM quirk for ST1000LM024 drives (Hans)
- Remove error path warning that can now trigger after the queue
removal/addition fixes (Ming)
* tag 'for-linus-20190614' of git://git.kernel.dk/linux-block:
block/ps3vram: Use %llu to format sector_t after LBDAF removal
libata: Extend quirks for the ST1000LM024 drives with NOLPM quirk
bcache: only set BCACHE_DEV_WB_RUNNING when cached device attached
bcache: fix stack corruption by PRECEDING_KEY()
blk-mq: remove WARN_ON(!q->elevator) from blk_mq_sched_free_requests
blkio-controller.txt: Remove references to CFQ
block/switching-sched.txt: Update to blk-mq schedulers
null_blk: remove duplicate check for report zone
blk-mq: no need to check return value of debugfs_create functions
io_uring: fix memory leak of UNIX domain socket inode
block: force select mq-deadline for zoned block devices
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Will Deacon:
"Here are some arm64 fixes for -rc5.
The only non-trivial change (in terms of the diffstat) is fixing our
SVE ptrace API for big-endian machines, but the majority of this is
actually the addition of much-needed comments and updates to the
documentation to try to avoid this mess biting us again in future.
There are still a couple of small things on the horizon, but nothing
major at this point.
Summary:
- Fix broken SVE ptrace API when running in a big-endian configuration
- Fix performance regression due to off-by-one in TLBI range checking
- Fix build regression when using Clang"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64/sve: Fix missing SVE/FPSIMD endianness conversions
arm64: tlbflush: Ensure start/end of address range are aligned to stride
arm64: Don't unconditionally add -Wno-psabi to KBUILD_CFLAGS
Like the RK3328, RK322x SoCs offer a Synopsis DesignWare HDMI transmitter
and an Innosilicon HDMI PHY.
Add a new dw_hdmi_plat_data struct, rk3228_hdmi_drv_data.
Assign a set of mostly generic rk3228_hdmi_phy_ops functions.
Add dw_hdmi_rk3228_setup_hpd() to enable the HDMI HPD and DDC lines.
Signed-off-by: Justin Swartz <justin.swartz@risingedge.co.za>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20190522224631.25164-1-justin.swartz@risingedge.co.za
git://anongit.freedesktop.org/drm/drm-misc into drm-next
drm-misc-next for v5.3:
UAPI Changes:
Cross-subsystem Changes:
- Add code to signal all dma-fences when freed with pending signals.
- Annotate reservation object access in CONFIG_DEBUG_MUTEXES
Core Changes:
- Assorted documentation fixes.
- Use irqsave/restore spinlock to add crc entry.
- Move code around to drm_client, for internal modeset clients.
- Make drm_crtc.h and drm_debugfs.h self-contained.
- Remove drm_fb_helper_connector.
- Add bootsplash to todo.
- Fix lock ordering in pan_display_legacy.
- Support pinning buffers to current location in gem-vram.
- Remove the now unused locking functions from gem-vram.
- Remove the now unused kmap-object argument from vram helpers.
- Stop checking return value of debugfs_create.
- Add atomic encoder enable/disable helpers.
- pass drm_atomic_state to atomic connector check.
- Add atomic support for bridge enable/disable.
- Add self refresh helpers to core.
Driver Changes:
- Add extra delay to make MTP SDM845 work.
- Small fixes to virtio, vkms, sii902x, sii9234, ast, mcde, analogix, rockchip.
- Add zpos and ?BGR8888 support to meson.
- More removals of drm_os_linux and drmP headers for amd, radeon, sti, r128, r128, savage, sis.
- Allow synopsis to unwedge the i2c hdmi bus.
- Add orientation quirks for GPD panels.
- Edid cleanups and fixing handling for edid < 1.2.
- Add runtime pm to stm.
- Handle s/r in dw-hdmi.
- Add hooks for power on/off to dsi for stm.
- Remove virtio dirty tracking code, done in drm core.
- Rework BO handling in ast and mgag200.
Tiny conflict in drivers/gpu/drm/amd/display/dc/clk_mgr/clk_mgr.c,
needed #include <linux/slab.h> to make it compile.
From: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/0e01de30-9797-853c-732f-4a5bd6e61445@linux.intel.com
This patch adds a new drm helper library to help drivers implement
self refresh. Drivers choosing to use it will register crtcs and
will receive callbacks when it's time to enter or exit self refresh
mode.
In its current form, it has a timer which will trigger after a
driver-specified amount of inactivity. When the timer triggers, the
helpers will submit a new atomic commit to shut the refreshing pipe
off. On the next atomic commit, the drm core will revert the self
refresh state and bring everything back up to be actively driven.
From the driver's perspective, this works like a regular disable/enable
cycle. The driver need only check the 'self_refresh_active' state in
crtc_state. It should initiate self refresh mode on the panel and enter
an off or low-power state.
Changes in v2:
- s/psr/self_refresh/ (Daniel)
- integrated the psr exit into the commit that wakes it up (Jose/Daniel)
- made the psr state per-crtc (Jose/Daniel)
Changes in v3:
- Remove the self_refresh_(active|changed) from connector state (Daniel)
- Simplify loop in drm_self_refresh_helper_alter_state (Daniel)
- Improve self_refresh_aware comment (Daniel)
- s/self_refresh_state/self_refresh_data/ (Daniel)
Changes in v4:
- Move docbook location below panel (Daniel)
- Improve docbook with references and more detailed explanation (Daniel)
- Instead of register/unregister, use init/cleanup (Daniel)
Changes in v5:
- Resolved conflict in drm_atomic_helper.c #include block
- Resolved conflict in rst with HDCP helper docs
Changes in v6:
- Fix include ordering, clean up forward declarations (Sam)
Link to v1: https://patchwork.freedesktop.org/patch/msgid/20190228210939.83386-2-sean@poorly.run
Link to v2: https://patchwork.freedesktop.org/patch/msgid/20190326204509.96515-1-sean@poorly.run
Link to v3: https://patchwork.freedesktop.org/patch/msgid/20190502194956.218441-6-sean@poorly.run
Link to v4: https://patchwork.freedesktop.org/patch/msgid/20190508160920.144739-6-sean@poorly.run
Link to v5: https://patchwork.freedesktop.org/patch/msgid/20190611160844.257498-6-sean@poorly.run
Cc: Jose Souza <jose.souza@intel.com>
Cc: Zain Wang <wzz@rock-chips.com>
Cc: Tomasz Figa <tfiga@chromium.org>
Tested-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Daniel Vetter <daniel@ffwll.ch>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190612145026.191846-1-sean@poorly.run
The in-memory representation of SVE and FPSIMD registers is
different: the FPSIMD V-registers are stored as single 128-bit
host-endian values, whereas SVE registers are stored in an
endianness-invariant byte order.
This means that the two representations differ when running on a
big-endian host. But we blindly copy data from one representation
to another when converting between the two, resulting in the
register contents being unintentionally byteswapped in certain
situations. Currently this can be triggered by the first SVE
instruction after a syscall, for example (though the potential
trigger points may vary in future).
So, fix the conversion functions fpsimd_to_sve(), sve_to_fpsimd()
and sve_sync_from_fpsimd_zeropad() to swab where appropriate.
There is no common swahl128() or swab128() that we could use here.
Maybe it would be worth making this generic, but for now add a
simple local hack.
Since the byte order differences are exposed in ABI, also clarify
the documentation.
Cc: Alex Bennée <alex.bennee@linaro.org>
Cc: Peter Maydell <peter.maydell@linaro.org>
Cc: Alan Hayward <alan.hayward@arm.com>
Cc: Julien Grall <julien.grall@arm.com>
Fixes: bc0ee4760364 ("arm64/sve: Core task context handling")
Fixes: 8cd969d28fd2 ("arm64/sve: Signal handling support")
Fixes: 43d4da2c45b2 ("arm64/sve: ptrace and ELF coredump support")
Signed-off-by: Dave Martin <Dave.Martin@arm.com>
[will: Fix typos in comments and docs spotted by Julien]
CFQ is gone. No need anymore to document its "proportional weight time
based division of disk policy".
Signed-off-by: Andreas Herrmann <aherrmann@suse.com>
Remove references to CFQ and legacy block layer which are gone.
Update example with what's available under blk-mq.
Ease entry for anyone wanting to pick up the bootsplash work by providing
a couple of pointers.
v2: Add Sam as contact (Sam)
Signed-off-by: Noralf Trønnes <noralf@tronnes.org>
Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190608152657.36613-6-noralf@tronnes.org
All drivers add all their connectors so there's no need to keep around an
array of available connectors. Instead we just put the useable (not
writeback) connectors in a temporary array using
drm_client_for_each_connector_iter() everytime we probe the outputs.
Other places where it's necessary to look at the connectors, we just
iterate over them using the same iterator function.
Rename functions which signature is changed since they will be moved to
drm_client in a later patch.
v6: Improve commit message (Sam Ravnborg)
Link: https://patchwork.freedesktop.org/patch/msgid/20190608152657.36613-2-noralf@tronnes.org
drm-next
R-Car DU changes for v5.3:
- R8A774A1 SoC support
- LVDS dual-link mode support
- Support for additional formats
- Misc fixes
From: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190608134652.GE4786@pendragon.ideasonboard.com
Add a new optional renesas,companion property to point to the companion
LVDS encoder. This is used to support dual-link operation where the main
LVDS encoder splits even-numbered and odd-numbered pixels between the
two LVDS encoders.
The new property doesn't control the mode of operation, it only
describes the relationship between the master and companion LVDS
encoders.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Reviewed-by: Jacopo Mondi <jacopo@jmondi.org>
Tested-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
The THC63LVD1024 LVDS decoder can operate in two modes, single-link or
dual-link. In dual-link mode both input ports are used to carry even-
and odd-numbered pixels separately. Document this in the DT bindings,
along with the related rules governing port and usage.
Reviewed-by: Jacopo Mondi <jacopo+renesas@jmondi.org>
Document the RZ/G2M (R8A774A1) LVDS bindings.
Signed-off-by: Biju Das <biju.das@bp.renesas.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Document the RZ/G2M (R8A774A1) SoC in the R-Car DU bindings.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs fixes from Miklos Szeredi:
"Here's one fix for a class of bugs triggered by syzcaller, and one
that makes xfstests fail less"
* tag 'ovl-fixes-5.2-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ovl: doc: add non-standard corner cases
ovl: detect overlapping layers
ovl: support the FS_IOC_FS[SG]ETXATTR ioctls
Just a straightforward bag of fixes for a clean htmldocs build.
Reviewed-by: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190605095657.23601-2-jani.nikula@intel.com
The error messages could be more descriptive, but fix these caused by
file moves:
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -internal
./drivers/gpu/drm/i915/i915_gem_shrinker.c' failed with return code 2
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -function
User command execution ./drivers/gpu/drm/i915/i915_gem_execbuffer.c'
failed with return code 1
./drivers/gpu/drm/i915/i915_gem_tiling.c' failed with return code 2
buffer object tiling ./drivers/gpu/drm/i915/i915_gem_tiling.c'
Fixes: 10be98a77c55 ("drm/i915: Move more GEM objects under gem/")
Cc: Mika Kuoppala <mika.kuoppala@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190605095657.23601-1-jani.nikula@intel.com
into drm-next
amdgpu:
- Revert timeline support until KHR is ready
- Various driver reload fixes
- Refactor clock handling in DC
- Aux fixes for DC
- Bandwidth calculation updates for DC
- Fix documentation due to file rename
- RAS fix
- Fix race in late_init
ttm:
- Allow for better forward progress when there is heavy memory contention
Link: https://patchwork.freedesktop.org/patch/msgid/20190606032537.6939-1-alexander.deucher@amd.com
This file was renamed, but docs weren't updated accordingly.
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -function PRIME Buffer Sharing ./drivers/gpu/drm/amd/amdgpu/amdgpu_prime.c' failed with return code 1
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -internal ./drivers/gpu/drm/amd/amdgpu/amdgpu_prime.c' failed with return code 2
Fixes: 2fbd6f94accdbb223a ("drm/amdgpu: rename amdgpu_prime.[ch] into amdgpu_dma_buf.[ch]")
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
UAPI Changes:
- Add devicetree bindings for new panels.
- Convert allwinner's DT bindings to a schema.
- Drop video/hdmi static functions from kernel docs.
- Discard old fence when reserving space in reservation_object_get_fences_rcu.
Core Changes:
- Add missing -ENOMEM handling in edid loading.
- Fix null pointer deref in scheduler.
- Header cleanups, making them self-contained.
- Remove drmP.h inclusion from core.
- Fix make htmldocs warning in scheduler and HDR metadata.
- Fix a few warnings in the uapi header and add a doc section for it.
- Small MST sideband error handling fix.
- Clarify userspace review requirements.
- Clarify implicit/explicit fencing in docs.
- Flush output polling on shutdown.
Driver Changes:
- Small cleanups to stm.
- Add new driver for ST-Ericsson MCDE
- Kconfig fix for meson HDMI.
- Add support for Armadeus ST0700 Adapt panel.
- Add KOE tx14d24vm1bpa panel.
- Update timings for st7701.
- Fix compile error in mcde.
- Big series of tc358767 fixes, and enabling support for IRQ and HPD handling.
- Assorted fixes to sii902x, and implementing HDMI audio support.
- Enable HDR metadata support on amdgpu.
- Assorted fixes to atmel-hlcdc, and add sam9x60 LCD controller support.
Link: https://patchwork.freedesktop.org/patch/msgid/6c43ffa9-11ff-5354-d772-c20fd4d1e3d9@linux.intel.com
In certain situations it was seen that we could wedge up the DDC bus
on the HDMI adapter on rk3288. The only way to unwedge was to mux one
of the pins over to GPIO output-driven-low temporarily and then
quickly mux back. Full details can be found in the patch
("drm/bridge/synopsys: dw-hdmi: Add "unwedge" for ddc bus").
Since unwedge requires remuxing the pins, we first need to add to the
bindings so that we can specify what state the pins should be in for
unwedging.
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20190502225336.206885-1-dianders@chromium.org
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -function Hardware workarounds ./drivers/gpu/drm/i915/intel_workarounds.c' failed with return code 1
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -function Logical Rings, Logical Ring Contexts and Execlists ./drivers/gpu/drm/i915/intel_lrc.c' failed with return code 1
WARNING: kernel-doc './scripts/kernel-doc -rst -enable-lineno -internal ./drivers/gpu/drm/i915/intel_lrc.c' failed with return code 2
Fixes: 112ed2d31a46 ("drm/i915: Move GraphicsTechnology files under gt/")
Link: https://patchwork.freedesktop.org/patch/msgid/bd7dd29b9fb2101c954c8cfb2c3b4efc7d277045.1559656538.git.mchehab+samsung@kernel.org
Add a new section for UAPI structure and helper definitions
in kernel docbook.
Suggested-by: Daniel Vetter <daniel@ffwll.ch>
Signed-off-by: Uma Shankar <uma.shankar@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/1559567330-25182-2-git-send-email-uma.shankar@intel.com
struct drm_fb_helper_crtc is now just a wrapper around drm_mode_set so
use that directly instead and attach it as a modeset array onto
drm_client_dev. drm_fb_helper will use this array to store its modesets
which means it will always initialize a drm_client, but it will not
register the client (callbacks) unless it's the generic fbdev emulation.
Code will later be moved to drm_client, so add code there in a new file
drm_client_modeset.c with MIT license to match drm_fb_helper.c.
The modeset connector array size is hardcoded for the cloned case to avoid
having to pass in a value from the driver. A value of 8 is chosen to err
on the safe side. This means that the max connector argument for
drm_fb_helper_init() and drm_fb_helper_fbdev_setup() isn't used anymore,
a todo entry for this is added.
In pan_display_atomic() restore_fbdev_mode_force() is used instead of
restore_fbdev_mode_atomic() because that one will later become internal
to drm_client_modeset.
Locking order:
1. drm_fb_helper->lock
2. drm_master_internal_acquire
3. drm_client_dev->modeset_mutex
v3:
- Use full drm_client_init/release for the modesets (Daniel Vetter)
- drm_client_for_each_modeset: use lockdep_assert_held (Daniel Vetter)
- Hook up to Documentation/gpu/drm-client.rst (Daniel Vetter)
v2:
- Add modesets array to drm_client (Daniel Vetter)
- Use a new file for the modeset code (Daniel Vetter)
- File has to be MIT licensed (Emmanuel Vadot)
- Add copyrights from drm_fb_helper.c
Link: https://patchwork.freedesktop.org/patch/msgid/20190531140117.37751-3-noralf@tronnes.org
With Eric's patch
commit ba6e798ecf320716780bb6a6088a8d17dcba1d49
Author: Eric Anholt <eric@anholt.net>
Date: Wed Apr 24 11:56:17 2019 -0700
drm/doc: Document expectation that userspace review looks at kernel uAPI.
there's been concerns raised that we expect userspace people to do
in-depth kernel patch review. That's not reasonable, same way kernel
people can't review all the userspace we have. Try to clarify
expectations a bit more.
Cc: Pekka Paalanen <ppaalanen@gmail.com>
Cc: contact@emersion.fr
Cc: wayland-devel@lists.freedesktop.org
Acked-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Simon Ser <contact@emersion.fr>
Reviewed-by: Pekka Paalanen <pekka.paalanen@collabora.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20190521084849.27452-1-daniel.vetter@ffwll.ch
memory.stat and other files already consider subtrees in their output, and
we should too in order to not present an inconsistent interface.
The current situation is fairly confusing, because people interacting with
cgroups expect hierarchical behaviour in the vein of memory.stat,
cgroup.events, and other files. For example, this causes confusion when
debugging reclaim events under low, as currently these always read "0" at
non-leaf memcg nodes, which frequently causes people to misdiagnose breach
behaviour. The same confusion applies to other counters in this file when
debugging issues.
Aggregation is done at write time instead of at read-time since these
counters aren't hot (unlike memory.stat which is per-page, so it does it
at read time), and it makes sense to bundle this with the file
notifications.
After this patch, events are propagated up the hierarchy:
[root@ktst ~]# cat /sys/fs/cgroup/system.slice/memory.events
low 0
high 0
max 0
oom 0
oom_kill 0
[root@ktst ~]# systemd-run -p MemoryMax=1 true
Running as unit: run-r251162a189fb4562b9dabfdc9b0422f5.service
low 0
high 0
max 7
oom 1
oom_kill 1
As this is a change in behaviour, this can be reverted to the old
behaviour by mounting with the `memory_localevents' flag set. However, we
use the new behaviour by default as there's a lack of evidence that there
are any current users of memory.events that would find this change
undesirable.
akpm: this is a behaviour change, so Cc:stable. THis is so that
forthcoming distros which use cgroup v2 are more likely to pick up the
revised behaviour.
Link: http://lkml.kernel.org/r/20190208224419.GA24772@chrisdown.name
Signed-off-by: Chris Down <chris@chrisdown.name>
Reviewed-by: Shakeel Butt <shakeelb@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Roman Gushchin <guro@fb.com>
Cc: Dennis Zhou <dennis@kernel.org>
Cc: Suren Baghdasaryan <surenb@google.com>
Cc: <stable@vger.kernel.org>
Fix Sphinx warnings in Documentation/vm/hmm.rst by using "::" notation and
inserting a blank line. Also add a missing ';'.
Documentation/vm/hmm.rst:292: WARNING: Unexpected indentation.
Documentation/vm/hmm.rst:300: WARNING: Unexpected indentation.
Link: http://lkml.kernel.org/r/c5995359-7c82-4e47-c7be-b58a4dda0953@infradead.org
Fixes: 023a019a9b4e ("mm/hmm: add default fault flags to avoid the need to pre-fill pfns arrays")
Reviewed-by: Jérôme Glisse <jglisse@redhat.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some tiny USB fixes for a number of reported issues for
5.2-rc3.
Nothing huge here, just a small collection of xhci and other driver
bugs that syzbot has been finding in some drivers. There is also a
usbip fix and a fix for the usbip fix in here :)
All have been in linux-next with no reported issues"
* tag 'usb-5.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usbip: usbip_host: fix stub_dev lock context imbalance regression
media: smsusb: better handle optional alignment
xhci: Use %zu for printing size_t type
xhci: Convert xhci_handshake() to use readl_poll_timeout_atomic()
xhci: Fix immediate data transfer if buffer is already DMA mapped
usb: xhci: avoid null pointer deref when bos field is NULL
usb: xhci: Fix a potential null pointer dereference in xhci_debugfs_create_endpoint()
xhci: update bounce buffer with correct sg num
media: usb: siano: Fix false-positive "uninitialized variable" warning
USB: rio500: update Documentation
USB: rio500: simplify locking
USB: rio500: fix memory leak in close after disconnect
USB: rio500: refuse more than one device at a time
usbip: usbip_host: fix BUG: sleeping function called from invalid context
USB: sisusbvga: fix oops in error path of sisusb_probe
USB: Add LPM quirk for Surface Dock GigE adapter
media: usb: siano: Fix general protection fault in smsusb
usb: mtu3: fix up undefined reference to usb_debug_root
USB: Fix slab-out-of-bounds write in usb_get_bos_descriptor
The sii902x chip family supports also HDMI audio. Add binding for
describing the necessary i2s and mclk wiring for it.
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Link: https://patchwork.freedesktop.org/patch/msgid/f790277fabc45f987f90075dd842368705226a84.1558964241.git.jsarha@ti.com
Remove trailing white space from sii902x display bridge binding.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Link: https://patchwork.freedesktop.org/patch/msgid/f1f2ef82c4e8ecea920c408bd4e569f5ed27d20a.1558964241.git.jsarha@ti.com
Add DT property for defining the pin used for HPD.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: devicetree@vger.kernel.org
Link: https://patchwork.freedesktop.org/patch/msgid/20190528082747.3631-25-tomi.valkeinen@ti.com
While most corner cases have already been dealt with, some remain and
should be documented.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
