Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
no remaining users
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
drivers/net/ethernet/mellanox/mlx4/cmd.c
net/core/fib_rules.c
net/ipv4/fib_frontend.c
The fib_rules.c and fib_frontend.c conflicts were locking adjustments
in 'net' overlapping addition and removal of code in 'net-next'.
The mlx4 conflict was a bug fix in 'net' happening in the same
place a constant was being replaced with a more suitable macro.
Pull networking fixes from David Miller:
1) In TCP, don't register an FRTO for cumulatively ACK'd data that was
previously SACK'd, from Neal Cardwell.
2) Need to hold RNL mutex in ipv4 multicast code namespace cleanup,
from Cong WANG.
3) Similarly we have to hold RNL mutex for fib_rules_unregister(), also
from Cong WANG.
4) Revert and rework netns nsid allocation fix, from Nicolas Dichtel.
5) When we encapsulate for a tunnel device, skb->sk still points to the
user socket. So this leads to cases where we retraverse the
ipv4/ipv6 output path with skb->sk being of some other address
family (f.e. AF_PACKET). This can cause things to crash since the
ipv4 output path is dereferencing an AF_PACKET socket as if it were
an ipv4 one.
The short term fix for 'net' and -stable is to elide these socket
checks once we've entered an encapsulation sequence by testing
xmit_recursion.
Longer term we have a better solution wherein we pass the tunnel's
socket down through the output paths, but that is way too invasive
for 'net' and -stable.
From Hannes Frederic Sowa.
6) l2tp_init() failure path forgets to unregister per-net ops, from
Cong WANG.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net/mlx4_core: Fix error message deprecation for ConnectX-2 cards
net: dsa: fix filling routing table from OF description
l2tp: unregister l2tp_net_ops on failure path
mvneta: dont call mvneta_adjust_link() manually
ipv6: protect skb->sk accesses from recursive dereference inside the stack
netns: don't allocate an id for dead netns
Revert "netns: don't clear nsid too early on removal"
ip6mr: call del_timer_sync() in ip6mr_free_table()
net: move fib_rules_unregister() under rtnl lock
ipv4: take rtnl_lock and mark mrt table as freed on namespace cleanup
tcp: fix FRTO undo on cumulative ACK of SACKed range
xen-netfront: transmit fully GSO-sized packets
According to description in 'include/net/dsa.h', in cascade switches
configurations where there are more than one interconnected devices,
'rtable' array in 'dsa_chip_data' structure is used to indicate which
port on this switch should be used to send packets to that are destined
for corresponding switch.
However, dsa_of_setup_routing_table() fills 'rtable' with port numbers
of the _target_ switch, but not current one.
This commit removes redundant devicetree parsing and adds needed port
number as a function argument. So dsa_of_setup_routing_table() now just
looks for target switch number by parsing parent of 'link' device node.
To remove possible misunderstandings with the way of determining target
switch number, a corresponding comment was added to the source code and
to the DSA device tree bindings documentation file.
This was tested on a custom board with two Marvell 88E6095 switches with
following corresponding routing tables: { -1, 10 } and { 8, -1 }.
Signed-off-by: Pavel Nakonechny <pavel.nakonechny@skitlab.ru>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input fixes from Dmitry Torokhov:
"Updates for the input subsystem - two more tweaks for ALPS driver to
work out kinks after splitting the touchpad, trackstick, and potential
external PS/2 mouse into separate input devices.
Changes to support ALPS SS4 devices (protocol V8) will be coming in
4.1..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: alps - document stick behavior for protocol V2
Input: alps - report V2 Dualpoint Stick events via the right evdev node
Input: alps - report interleaved bare PS/2 packets via dev3
Document that protocol V2 uses standard (bare) PS/2 mouse packets for the
DualPoint stick.
Acked-By: Pali Rohár <pali.rohar@gmail.com>
Pull input subsystem fixes from Dmitry Torokhov:
"A fix for ALPS driver for issue introduced in the latest update and a
tweak for yet another Lenovo box in Synaptics.
There will be more ALPS tweaks coming.."
Input: define INPUT_PROP_ACCELEROMETER behavior
Input: synaptics - fix min-max quirk value for E440
Input: synaptics - add quirk for Thinkpad E440
Input: ALPS - fix max coordinates for v5 and v7 protocols
Input: add MT_TOOL_PALM
The CAN_RAW socket can set multiple CAN identifier specific filters that lead
to multiple filters in the af_can.c filter processing. These filters are
indenpendent from each other which leads to logical OR'ed filters when applied.
This socket option joines the given CAN filters in the way that only CAN frames
are passed to user space that matched *all* given CAN filters. The semantic for
the applied filters is therefore changed to a logical AND.
This is useful especially when the filterset is a combination of filters where
the CAN_INV_FILTER flag is set in order to notch single CAN IDs or CAN ID
ranges from the incoming traffic.
As the raw_rcv() function is executed from NET_RX softirq the introduced
variables are implemented as per-CPU variables to avoid extensive locking at
CAN frame reception time.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Spell out what this property means to userspace. If the property is set, all
directional axes must be accelerometer axes, any other axes are left as-is.
This allows an accelerometer device to e.g. have an ABS_WHEEL.
It is not permitted to mix normal directional axes and accelerometer axes on
the same device node.
Signed-off-by: Peter Hutterer <peter.hutterer@who-t.net>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Reviewed-by: Bastien Nocera <hadess@hadess.net>
Signed-off-by: Iyappan Subramanian <isubramanian@apm.com>
Signed-off-by: Keyur Chudgar <kchudgar@apm.com>
If vlan offloading takes place then vlan header is removed from frame
and its contents, both vlan_tci and vlan_proto, is available to user
space via TPACKET interface. However, only vlan_tci can be used in BPF
filters.
This commit introduces a new BPF extension. It makes possible to load
the value of vlan_proto (vlan TPID) to register A. Support for classic
BPF and eBPF is being added, analogous to skb->protocol.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Cc: Jiri Pirko <jpirko@redhat.com>
Signed-off-by: Michal Sekletar <msekleta@redhat.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
Cc: Erik Kline <ek@google.com>
Cc: Fernando Gont <fgont@si6networks.com>
Cc: Lorenzo Colitti <lorenzo@google.com>
Cc: YOSHIFUJI Hideaki/吉藤英明 <hideaki.yoshifuji@miraclelinux.com>
Introduce TP_STATUS_CSUM_VALID tp_status flag to tell the
af_packet user that at least the transport header checksum
has been already validated.
For now, the flag may be set for incoming packets only.
Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com>
Cc: Willem de Bruijn <willemb@google.com>
NetCP 1.5 available on newer K2 SoCs such as K2E and K2L introduced 3
variants of the ethss subsystem, 9 port, 5 port and 2 port. These have
one host port towards the CPU and N external slave ports.
To customize the driver for these new ethss sub systems, multiple
compatibility strings are introduced. Currently some of parameters that
are different on different variants such as number of ALE ports, stats
modules and number of ports are defined through constants. These are now
changed to variables in gbe_priv data that get set based on the
compatibility string. This is required as there are no hardware
identification registers available to distinguish among the variants
of NetCP 1.5 ethss. However there is identification register available
to differentiate between NetCP 1.4 vs NetCP 1.5 and the same is made use
of in the code to differentiate them.
For more reading on the details of this peripheral, please refer to the
User Guide available at http://www.ti.com/lit/pdf/spruhz3
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: WingMan Kwok <w-kwok2@ti.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: Mugunthan V N <mugunthanvnm@ti.com>
CC: "Lad, Prabhakar" <prabhakar.csengg@gmail.com>
CC: Grygorii Strashko <grygorii.strashko@ti.com>
CC: Christoph Jaeger <cj@linux.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Markus Pargmann <mpa@pengutronix.de>
CC: Kumar Gala <galak@codeaurora.org>
CC: Ian Campbell <ijc+devicetree@hellion.org.uk>
CC: Mark Rutland <mark.rutland@arm.com>
CC: Pawel Moll <pawel.moll@arm.com>
CC: Rob Herring <robh+dt@kernel.org>
Ethss has multiple modules within the sub system
- switch sub system
- sgmii
- mdio
- switch module
NetCP driver re-uses existing davinci mdio driver. It requires to
have its own register region to map the reg space. So restructure
the code to use separate reg region for the individual modules it
manages. Use range property to define register space of NetCP and
use reg property to define individual reg spaces. So MDIO will have
its own reg space to map. This is a pre-requisite to enable MDIO
driver for NetCP.
Signed-off-by: YOSHIFUJI Hideaki <hideaki.yoshifuji@miraclelinux.com>
drivers/net/ethernet/emulex/benet/be_main.c
net/core/sysctl_net_core.c
net/ipv4/inet_diag.c
The be_main.c conflict resolution was really tricky. The conflict
hunks generated by GIT were very unhelpful, to say the least. It
split functions in half and moved them around, when the real actual
conflict only existed solely inside of one function, that being
be_map_pci_bars().
So instead, to resolve this, I checked out be_main.c from the top
of net-next, then I applied the be_main.c changes from 'net' since
the last time I merged. And this worked beautifully.
The inet_diag.c and sysctl_net_core.c conflicts were simple
overlapping changes, and were easily to resolve.
Currently there are only two "tools" that can be specified by a multi-touch
driver: MT_TOOL_FINGER and MT_TOOL_PEN. In working with Elan (The touch
vendor) and discussing their next-gen devices it seems that it will be
useful to have more tools so that their devices can give the upper layers
of the stack hints as to what is touching the sensor.
In particular they have new experimental firmware that can better
differentiate between palms vs fingertips and would like to plumb a patch
so that we can use their hints in higher-level gesture soft- ware. The
firmware on the device can reasonably do a better job of palm detection
because it has access to all of the raw sensor readings as opposed to just
the width/pressure/etc that are exposed by the driver. As such, the
firmware can characterize what a palm looks like in much finer-grained
detail and this change would allow such a device to share its findings with
the kernel.
Signed-off-by: Charlie Mooney <charliemooney@chromium.org>
Acked-by: Peter Hutterer <peter.hutterer@who-t.net>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-03-19
This wont the last 4.1 bluetooth-next pull request, but we've piled up
enough patches in less than a week that I wanted to save you from a
single huge "last-minute" pull somewhere closer to the merge window.
The main changes are:
- Simultaneous LE & BR/EDR discovery support for HW that can do it
- Complete LE OOB pairing support
- More fine-grained mgmt-command access control (normal user can now do
harmless read-only operations).
- Added RF power amplifier support in cc2520 ieee802154 driver
- Some cleanups/fixes in ieee802154 code
Please let me know if there are any issues pulling. Thanks.
Similar to port id allow netdevices to specify port names and export
the name via sysfs. Drivers can implement the netdevice operation to
assist udev in having sane default names for the devices using the
rule:
$ cat /etc/udev/rules.d/80-net-setup-link.rules
SUBSYSTEM=="net", ACTION=="add", ATTR{phys_port_name}!="",
NAME="$attr{phys_port_name}"
Use of phys_name versus phys_id was suggested-by Jiri Pirko.
Signed-off-by: David Ahern <dsahern@gmail.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Acked-by: Scott Feldman <sfeldma@gmail.com>
This adds a tx_maxrate attribute to the tx queue sysfs entry allowing
for max-rate limiting. Along with DCB-ETS and BQL this provides another
knob to tune queue performance. The limit units are Mbps.
By default it is disabled. To disable the rate limitation after it
has been set for a queue, it should be set to zero.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
The TI CC2521 is an RF power amplifier that is designed to interface
with the CC2520. Conveniently, it directly interfaces with the CC2520
and does not require any pins to be connected to a
microcontroller/processor. Adding a CC2591 increases the CC2520's range,
which is useful for border router and other wall-powered applications.
Using the CC2591 with the CC2520 requires configuring the CC2520 GPIOs
that are connected to the CC2591 to correctly set the CC2591 into TX and
RX modes. Further, TI recommends that the CC2520_TXPOWER and
CC2520_AGCCTRL1 registers are set differently to maximize the CC2591's
performance. These settings are covered in TI Application Note AN065.
This patch adds an optional `amplified` field to the cc2520 entry in the
device tree. If present, the CC2520 will be configured to operate with a
CC2591.
The expected pin mapping is:
CC2520 GPIO0 --> CC2591 EN
CC2520 GPIO5 --> CC2591 PAEN
Signed-off-by: Brad Campbell <bradjc5@gmail.com>
Acked-by: Varka Bhadram <varkabhadram@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Pull ARM SoC fixes from Arnd Bergmann:
"This is a rather unpleasantly large set of bug fixes for arm-soc, Most
of them because of cross-tree dependencies for Exynos where we should
have figured out the right path to merge things before the merge
window, and then the maintainer being unable to sort things out in
time during a business trip.
The other changes contained here are the usual collection:
MAINTAINERS file updates
- Gregory Clement is now a co-maintainer for the legacy Marvell EBU
platforms
- A MAINTAINERS entry for the Freescale Vybrid platform that was
added last year
- Matt Porter no longer works as a maintainer on Broadcom SoCs
Build-time issues
- A compile-time error for at91
- Several minor DT fixes on at91, imx, exynos, socfpga, and omap
- The new digicolor platform was not correctly enabled at all
Configuration issues
- Two defconfig fix for regressions using USB on versatile express
and on OMAP3
- Enabling all 8 CPUs on Allwinner/SUNxi
- Enabling the new STiH410 platform to be usable
Bug fixes in platform code
- A missing barrier for socfpga
- Fixing LPDDR1 self-refresh mode on at91
- Fixing RTC interrupt numbers on Exynos3250
- Fixing a cache-coherency issues in CPU power-down on Exynos5
- Multiple small OMAP power management fixes"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (69 commits)
MAINTAINERS: Add myself as co-maintainer to the legacy support of the mvebu SoCs
ARM: at91: pm_slowclock: fix the compilation error
ARM: at91/dt: fix USB high-speed clock to select UTMI
ARM: at91/dt: fix at91 udc compatible strings
ARM: at91/dt: declare matrix node as a syscon device
ARM: vexpress: update CONFIG_USB_ISP1760 option
ARM: digicolor: add the machine directory to Makefile
ARM: STi: Add STiH410 SoC support
MAINTAINERS: add Freescale Vybrid SoC
MAINTAINERS: Remove self as ARM mach-bcm co-maintainer
ARM: imx6sl-evk: set swbst_reg as vbus's parent reg
ARM: imx6qdl-sabresd: set swbst_reg as vbus's parent reg
ARM: at91/dt: at91sam9261: fix clocks and clock-names in udc definition
ARM: OMAP2+: Fix wl12xx on dm3730-evm with mainline u-boot
ARM: OMAP: enable TWL4030_USB in omap2plus_defconfig
ARM: dts: dra7x-evm: avoid possible contention while muxing on CAN lines
ARM: dts: dra7x-evm: Don't use dcan1_rx.gpio1_15 in DCAN pinctrl
ARM: dts: am43xx: fix SLEWCTRL_FAST pinctrl binding
ARM: dts: am33xx: fix SLEWCTRL_FAST pinctrl binding
ARM: dts: OMAP5: fix polling intervals for thermal zones
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fixes from Rob Herring:
- fix for stdout-path option parsing with added unittest
- fix for stdout-path interaction with earlycon
- several DT unittest fixes
- fix Sparc allmodconfig build error on of_platform_register_reconfig_notifier
- several DT overlay kconfig and build warning fixes
- several DT binding documentation updates
* tag 'devicetree-fixes-for-4.0' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of/platform: Fix sparc:allmodconfig build
of: unittest: Add options string testcase variants
of: fix handling of '/' in options for of_find_node_by_path()
of/unittest: Fix the wrong expected value in of_selftest_property_string
of/unittest: remove the duplicate of_changeset_init
dt: submitting-patches: clarify that DT maintainers are to be cced on bindings
of: unittest: fix I2C dependency
of/overlay: Remove unused variable
Documentation: DT: Renamed of-serial.txt to 8250.txt
of: Fix premature bootconsole disable with 'stdout-path'
serial: add device tree binding documentation for ETRAX FS UART
of/overlay: Directly include idr.h
of: Drop superfluous dependance for OF_OVERLAY
of: Add vendor prefix for Arasan
of: Add prompt for OF_OVERLAY config
This patch adds support to STiH410 SoC.
Please note "st,stih410" is already present in device tree.
The problem is that it is missing the entry in the match table,
and so the L2 cache and other cpus than 0 don't get initialized.
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Tested-by: Maxime Coquelin <maxime.coquelin@st.com>
Acked-by: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
The exact steps provided for submitting binding patches can be read
as requiring the bindings to be sent only to the devicetree@vger.kernel.org
list. Since the DT maintainers would like to be Cced on any binding
submissions, make this requirement explicit in step 2.
Signed-off-by: Matt Porter <mporter@konsulko.com>
Signed-off-by: Rob Herring <robh@kernel.org>
The file of-serial.txt was only for 8250 compatible UART implementations,
so renamed it to 8250.txt to avoid confusing other persons.
This is suggested by Arnd, see:
http://lists.infradead.org/pipermail/linux-arm-kernel/2014-September/291455.html
Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Linux 4.0-rc3
Merging in v4.0-rc3 because commit 30a22c215a00 (console: Fix
console name size mismatch) is a dependency.
drivers/net/ethernet/cadence/macb.c
Overlapping changes in macb driver, mostly fixes and cleanups
in 'net' overlapping with the integration of at91_ether into
macb in 'net-next'.
1) nft_compat accidently truncates ethernet protocol to 8-bits, from
Arturo Borrero.
2) Memory leak in ip_vs_proc_conn(), from Julian Anastasov.
3) Don't allow the space required for nftables rules to exceed the
maximum value representable in the dlen field. From Patrick
McHardy.
4) bcm63xx_enet can accidently leave interrupts permanently disabled
due to errors in the NAPI polling exit logic. Fix from Nicolas
Schichan.
5) Fix OOPSes triggerable by the ping protocol module, due to missing
address family validations etc. From Lorenzo Colitti.
6) Don't use RCU locking in sleepable context in team driver, from Jiri
Pirko.
7) xen-netback miscalculates statistic offset pointers when reporting
the stats to userspace. From David Vrabel.
8) Fix a leak of up to 256 pages per VIF destroy in xen-netaback, also
from David Vrabel.
9) ip_check_defrag() cannot assume that skb_network_offset(),
particularly when it is used by the AF_PACKET fanout defrag code.
From Alexander Drozdov.
10) gianfar driver doesn't query OF node names properly when trying to
determine the number of hw queues available. Fix it to explicitly
check for OF nodes named queue-group. From Tobias Waldekranz.
11) MID field in macb driver should be 12 bits, not 16. From Punnaiah
Choudary Kalluri.
12) Fix unintentional regression in traceroute due to timestamp socket
option changes. Empty ICMP payloads should be allowed in
non-timestamp cases. From Willem de Bruijn.
13) When devices are unregistered, we have to get rid of AF_PACKET
multicast list entries that point to it via ifindex. Fix from
Francesco Ruggeri.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits)
tipc: fix bug in link failover handling
net: delete stale packet_mclist entries
net: macb: constify macb configuration data
MAINTAINERS: add Marc Kleine-Budde as co maintainer for CAN networking layer
MAINTAINERS: linux-can moved to github
can: kvaser_usb: Read all messages in a bulk-in URB buffer
can: kvaser_usb: Avoid double free on URB submission failures
can: peak_usb: fix missing ctrlmode_ init for every dev
can: add missing initialisations in CAN related skbuffs
ip: fix error queue empty skb handling
bgmac: Clean warning messages
tcp: align tcp_xmit_size_goal() on tcp_tso_autosize()
net: fec: fix unbalanced clk disable on driver unbind
net: macb: Correct the MID field length value
net: gianfar: correctly determine the number of queue groups
ipv4: ip_check_defrag should not assume that skb_network_offset is zero
net: bcmgenet: properly disable password matching
net: eth: xgene: fix booting with devicetree
bnx2x: Force fundamental reset for EEH recovery
xen-netback: refactor xenvif_handle_frag_list()
Add missing "cdns,at91sam9260-macb", "atmel,sama5d3-gem" and
"atmel,sama5d4-gem" compatible strings.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reviewed-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Remove reference to obsolete ifconfig command.
MTU can be changed with ip command instead.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are some tty and serial driver fixes for 4.0-rc3.
Along with the atime fix that you know about, here are some other
serial driver bugfixes as well. Most notable is a wait_until_sent
bugfix that was traced back to being around since before 2.6.12 that
Johan has fixed up.
All have been in linux-next successfully"
* tag 'tty-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: fix tty_wait_until_sent maximum timeout
TTY: fix tty_wait_until_sent on 64-bit machines
USB: serial: fix infinite wait_until_sent timeout
TTY: bfin_jtag_comm: remove incorrect wait_until_sent operation
net: irda: fix wait_until_sent poll timeout
serial: uapi: Declare all userspace-visible io types
serial: core: Fix iotype userspace breakage
serial: sprd: Fix missing spin_unlock in sprd_handle_irq()
console: Fix console name size mismatch
tty: fix up atime/mtime mess, take four
serial: 8250_dw: Fix get_mctrl behaviour
serial:8250:8250_pci: delete unneeded quirk entries
serial:8250:8250_pci: fix redundant entry report for WCH_CH352_2S
Change email address for 8250_pci
serial: 8250: Revert "tty: serial: 8250_core: read only RX if there is something in the FIFO"
Revert "tty/serial: of_serial: add DT alias ID handling"
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull "code of conflict" from Greg KH:
"This file tries to set the rational basis for our code reviews, gives
some advice on how to conduct them, and provides an excalation channel
for any kernel developers if they so desire it"
[ Let's see how this works ]
* tag 'cc-4.0-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Code of Conflict
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"A set of updates and bugfixes for the new designware-baytrail driver.
And a documentation bugfix"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: imx: add required clocks property to binding
i2c: designware-baytrail: baytrail_i2c_acquire() might sleep
i2c: designware-baytrail: cross-check lock functions
i2c: designware-baytrail: fix sparse warnings
i2c: designware-baytrail: fix typo in error path
i2c: designware-baytrail: describe magic numbers
Fixed behaviour of get_mctrl() serial driver function as documented in:
https://www.kernel.org/doc/Documentation/serial/driver
Added device-tree properties 'dcd-override', 'dsr-override',
'cts-override', and 'ri-override' specific to the Synopsis 8250
DesignWare UART driver. Allows one to force Data Carrier Detect,
Clear To Send, and Data Set Ready signals to permanently be reported as
active. The Ring indicator can be forced to be reported as inactive.
It is possible that if modem control signalling is enabled on a port
that doesn't have these pins (e.g. - a simple two wire Tx/Rx port), the
driver can hang indefinitely waiting for the state to change. The new
DT properties allow the driver to ignore the state of these pins on
serial ports that don't support them, as recommended in the kernel
documentation.
Reviewed-by: JD (Jiandong) Zheng <jdzheng@broadcom.com>
Signed-off-by: Jonathan Richardson <jonathar@broadcom.com>
A clock specifier is required for i.MX I2C and is
provided in all DTS implementations. Add this to the
list of required properties in the binding.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Namely tcp_probe_interval to control how often to restart
a probe. And tcp_probe_threshold to control when stop the
probing in respect to the width of search range in bytes
Signed-off-by: Fan Du <fan.du@intel.com>
Pull power management and ACPI fixes from Rafael Wysocki:
"These are fixes for recent regressions (ACPI resources management,
suspend-to-idle), stable-candidate fixes (ACPI backlight), fixes
related to the wakeup IRQ management changes made in v3.18, other
fixes (suspend-to-idle, cpufreq ppc driver) and a couple of cleanups
(suspend-to-idle, generic power domains, ACPI backlight).
Specifics:
- Fix ACPI resources management problems introduced by the recent
rework of the code in question (Jiang Liu) and a build issue
introduced by those changes (Joachim Nilsson).
- Fix a recent suspend-to-idle regression on systems where entering
idle states causes local timers to stop, prevent suspend-to-idle
from crashing in restricted configurations (no cpuidle driver,
cpuidle disabled etc.) and clean up the idle loop somewhat while at
it (Rafael J Wysocki).
- Fix build problem in the cpufreq ppc driver (Geert Uytterhoeven).
- Allow the ACPI backlight driver module to be loaded if ACPI is
disabled which helps the i915 driver in those configurations
(stable-candidate) and change the code to help debug unusual use
cases (Chris Wilson).
- Wakeup IRQ management changes in v3.18 caused some drivers on the
at91 platform to trigger a warning from the IRQ core related to an
unexpected combination of interrupt action handler flags. However,
on at91 a timer IRQ is shared with some other devices (including
system wakeup ones) and that leads to the unusual combination of
flags in question.
To make it possible to avoid the warning introduce a new interrupt
action handler flag (which can be used by drivers to indicate the
special case to the core) and rework the problematic at91 drivers
to use it and work as expected during system suspend/resume. From
Boris Brezillon, Rafael J Wysocki and Mark Rutland.
- Clean up the generic power domains subsystem's debugfs interface
(Kevin Hilman)"
* tag 'pm+acpi-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
genirq / PM: describe IRQF_COND_SUSPEND
tty: serial: atmel: rework interrupt and wakeup handling
watchdog: at91sam9: request the irq with IRQF_NO_SUSPEND
cpuidle / sleep: Use broadcast timer for states that stop local timer
clk: at91: implement suspend/resume for the PMC irqchip
rtc: at91rm9200: rework wakeup and interrupt handling
rtc: at91sam9: rework wakeup and interrupt handling
PM / wakeup: export pm_system_wakeup symbol
genirq / PM: Add flag for shared NO_SUSPEND interrupt lines
ACPI / video: Propagate the error code for acpi_video_register
ACPI / video: Load the module even if ACPI is disabled
PM / Domains: cleanup: rename gpd -> genpd in debugfs interface
cpufreq: ppc: Add missing #include <asm/smp.h>
x86/PCI/ACPI: Relax ACPI resource descriptor checks to work around BIOS bugs
x86/PCI/ACPI: Ignore resources consumed by host bridge itself
cpuidle: Clean up fallback handling in cpuidle_idle_call()
cpuidle / sleep: Do sanity checks in cpuidle_enter_freeze() too
idle / sleep: Avoid excessive disabling and enabling interrupts
PCI: versatile: Update for list_for_each_entry() API change
genirq / PM: better describe IRQF_NO_SUSPEND semantics
* irq-pm:
With certain restrictions it is possible for a wakeup device to share
an IRQ with an IRQF_NO_SUSPEND user, and the warnings introduced by
commit cab303be91dc47942bc25de33dc1140123540800 are spurious. The new
IRQF_COND_SUSPEND flag allows drivers to tell the core when these
restrictions are met, allowing spurious warnings to be silenced.
This patch documents how IRQF_COND_SUSPEND is expected to be used,
updating some of the text now made invalid by its addition.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Langsdorf <mlangsdo@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91 into fixes
Merge "First fixes batch for AT91 on 4.0" from Nicolas Ferre:
- PM slowclock fixes for DDR and timeouts
- fix some DT entries
- little defconfig updates
- the removal of a harmful watchdog option + its detailed documentation
* tag 'at91-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91:
ARM: at91/dt: keep watchdog running in idle mode
dts: Documentation: AT91 Watchdog, explain what atmel,idle-halt property really do
ARM: at91/defconfig: add at91rm9200 ethernet support
ARM: at91/defconfig: remove CONFIG_SYSFS_DEPRECATED
ARM: at91/dt: at91sam9260: fix usart pinctrl
ARM: at91/dt: sama5d4: add missing alias for i2c0
ARM: at91/dt: at91sam9263: Fixup sram1 device tree node
ARM: at91: pm: fix SRAM allocation
ARM: at91: pm: fix at91rm9200 standby
pm: at91: Workaround DDRSDRC self-refresh bug with LPDDR1 memories.
pm: at91: pm_slowclock: fix suspend/resume hang up in timeouts
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
Merge "Samsung tmu and hdmi regression fixes for v4.0" from Kukjin Kim:
- The thermal management unit and HDMI (drm mixer driver) related
reworks have been merged in v4.0 merge window. So if this DT changes
are missed for v4.0, we regressions in v4.0 release for exynos
platforms such as exynos5250, exynos5420, exynos4 SoCs.
- Note since there was a dependency with driver side, this cannot
be sent to upstream during preivous merge window and now it has been
resolved.
* tag 'samsung-fixes-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: dts: add display power domain for exynos5250
ARM: dts: add 'hdmi' clock to mixer nodes for exynos5250 and exynos5420
ARM: dts: enable hdmi support for exynos4210-universal_c210
ARM: dts: enable hdmi support for exynos4412-odroid-common
ARM: dts: add dependency between TV and LCD0 power domains for exynos4
ARM: dts: add hdmi related nodes for exynos4 SoCs
ARM: EXYNOS: add support for sub-power domains
dt-bindings: document a note about power domain subdomains
ARM: dts: Provide dt bindings identical for Exynos TMU
ARM: dts: Trip points and sensor configuration data for exynos5440
ARM: dts: define default thermal-zones for exynos4
ARM: dts: default trip points definition for exynos5420
ARM: dts: add TMU default definitions for exynos4412
ARM: dts: Adding CPU cooling binding for Exynos SoCs
ARM: dts: Enable TMU for exynos4412-odriod-common
ARM: dts: Add LDO10 for TMU for exynos4412-odroid-common
ARM: dts: Enable TMU for exynos4210-trats
really do
atmel,idle-halt property should be used with care, it actually makes the
watchdog not counting when the CPU is in idle state, therefore the
watchdog reset time depends on mean CPU usage and will not reset at all
of the CPU stop working while it is in idle state, which is probably not
what you want.
Signed-off-by: Sylvain Rochet <sylvain.rochet@finsecur.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This sysctl gives two benefits. By defaulting the table size to 0
mpls even when compiled in and enabled defaults to not forwarding
any packets. This prevents unpleasant surprises for users.
The other benefit is that as mpls labels are allocated locally a dense
table a small dense label table may be used which saves memory and
is extremely simple and efficient to implement.
This sysctl allows userspace to choose the restrictions on the label
table size userspace applications need to cope with.
drivers/net/ethernet/rocker/rocker.c
The rocker commit was two overlapping changes, one to rename
the ->vport member to ->pport, and another making the bitmask
expression use '1ULL' instead of plain '1'.
