Pull ACPI fixes from Rafael Wysocki:
"These fix a system resume regression from the 4.13 cycle, clean up
device table handling in the ACPI core, update sysfs ABI documentation
of a couple of drivers and add an expected switch fall-through marker
to the SPCR table parsing code.
Specifics:
- Revert a problematic EC driver change from the 4.13 cycle that
introduced a system resume regression on Thinkpad X240 (Rafael
Wysocki).
- Clean up device tables handling in the ACPI core and the related
part of the device properties framework (Andy Shevchenko).
- Update the sysfs ABI documentatio of the dock and the INT3407
special device drivers (Aishwarya Pant).
- Add an expected switch fall-through marker to the SPCR table
parsing code (Gustavo Silva)"
* tag 'acpi-4.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI: dock: document sysfs interface
ACPI / DPTF: Document dptf_power sysfs atttributes
device property: Constify device_get_match_data()
ACPI / bus: Rename acpi_get_match_data() to acpi_device_get_match_data()
ACPI / bus: Remove checks in acpi_get_match_data()
ACPI / bus: Do not traverse through non-existed device table
ACPI: SPCR: Mark expected switch fall-through in acpi_parse_spcr
ACPI / EC: Restore polling during noirq suspend/resume phases
Pull power management fixes from Rafael Wysocki:
"These fix a recently introduced build issue related to cpuidle and two
bugs in the PM core, update cpuidle documentation and clean up memory
allocations in the operating performance points (OPP) framework.
Specifics:
- Fix a recently introduced build issue related to cpuidle by
covering all of the relevant combinations of Kconfig options
in its header (Rafael Wysocki).
- Add missing invocation of pm_runtime_drop_link() to the
!CONFIG_SRCU variant of __device_link_del() (Lukas Wunner).
- Fix unbalanced IRQ enable in the wakeup interrupts framework
(Tony Lindgren).
- Update cpuidle sysfs ABI documentation (Aishwarya Pant).
- Use GFP_KERNEL instead of GFP_ATOMIC for allocating memory
in dev_pm_opp_init_cpufreq_table() (Jia-Ju Bai)"
* tag 'pm-4.16-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM: cpuidle: Fix cpuidle_poll_state_init() prototype
PM / runtime: Update links_count also if !CONFIG_SRCU
PM / wakeirq: Fix unbalanced IRQ enable for wakeirq
Documentation/ABI: update cpuidle sysfs documentation
opp: cpu: Replace GFP_ATOMIC with GFP_KERNEL in dev_pm_opp_init_cpufreq_table
Pull scheduler fixes from Ingo Molnar:
"Misc fixes:
- fix rq->lock lockdep annotation bug
- fix/improve update_curr_rt() and update_curr_dl() accounting
- update documentation
- remove unused macro"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/cpufreq: Remove unused SUGOV_KTHREAD_PRIORITY macro
sched/core: Fix DEBUG_SPINLOCK annotation for rq->lock
sched/rt: Make update_curr_rt() more accurate
sched/deadline: Make update_curr_dl() more accurate
membarrier-sync-core: Document architecture support
Pull locking fixes from Ingo Molnar:
"This contains two qspinlock fixes and three documentation and comment
fixes"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
locking/semaphore: Update the file path in documentation
locking/atomic/bitops: Document and clarify ordering semantics for failed test_and_{}_bit()
locking/qspinlock: Ensure node->count is updated before initialising node
locking/qspinlock: Ensure node is initialised before updating prev->next
Documentation/locking/mutex-design: Update to reflect latest changes
* pm-cpuidle:
* pm-opp:
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips
Pull MIPS fix from James Hogan:
"A single change (and associated DT binding update) to allow the
address of the MIPS Cluster Power Controller (CPC) to be chosen by DT,
which allows SMP to work on generic MIPS kernels where the bootloader
hasn't configured the CPC address (i.e. the new Ranchu platform)"
* tag 'mips_4.16_2' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips:
MIPS: CPC: Map registers using DT in mips_cpc_default_phys_base()
dt-bindings: Document mti,mips-cpc binding
test_and_{}_bit()
A test_and_{}_bit() operation fails if the value of the bit is such that
the modification does not take place. For example, if test_and_set_bit()
returns 1. In these cases, follow the behaviour of cmpxchg and allow the
operation to be unordered. This also applies to test_and_set_bit_lock()
if the lock is found to be be taken already.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1518528619-20049-1-git-send-email-will.deacon@arm.com
Description has been collected from git commit history and reading
through code.
Signed-off-by: Aishwarya Pant <aishpant@gmail.com>
The descriptions have been collected from git commit logs and reading
through code.
Update cpuidle documentation using git logs and existing documentation
in Documentation/cpuidle/sysfs.txt. This might be useful for scripting
and tracking changes in the ABI.
Commit 3ca0ff571b09 ("locking/mutex: Rework mutex::owner") reworked the
basic mutex implementation to deal with several problems. Documentation
was however left unchanged and became stale.
Update mutex-design.txt to reflect changes introduced by the above commit.
Signed-off-by: Juri Lelli <juri.lelli@redhat.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: linux-doc@vger.kernel.org
Link: http://lkml.kernel.org/r/20180209160114.19980-1-juri.lelli@redhat.com
[ Small readability tweaks to the text. ]
Pull KVM updates from Radim Krčmář:
"ARM:
- icache invalidation optimizations, improving VM startup time
- support for forwarded level-triggered interrupts, improving
performance for timers and passthrough platform devices
- a small fix for power-management notifiers, and some cosmetic
changes
PPC:
- add MMIO emulation for vector loads and stores
- allow HPT guests to run on a radix host on POWER9 v2.2 CPUs without
requiring the complex thread synchronization of older CPU versions
- improve the handling of escalation interrupts with the XIVE
interrupt controller
- support decrement register migration
- various cleanups and bugfixes.
s390:
- Cornelia Huck passed maintainership to Janosch Frank
- exitless interrupts for emulated devices
- cleanup of cpuflag handling
- kvm_stat counter improvements
- VSIE improvements
- mm cleanup
x86:
- hypervisor part of SEV
- UMIP, RDPID, and MSR_SMI_COUNT emulation
- paravirtualized TLB shootdown using the new KVM_VCPU_PREEMPTED bit
- allow guests to see TOPOEXT, GFNI, VAES, VPCLMULQDQ, and more
AVX512 features
- show vcpu id in its anonymous inode name
- many fixes and cleanups
- per-VCPU MSR bitmaps (already merged through x86/pti branch)
- stable KVM clock when nesting on Hyper-V (merged through
x86/hyperv)"
* tag 'kvm-4.16-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (197 commits)
KVM: PPC: Book3S: Add MMIO emulation for VMX instructions
KVM: PPC: Book3S HV: Branch inside feature section
KVM: PPC: Book3S HV: Make HPT resizing work on POWER9
KVM: PPC: Book3S HV: Fix handling of secondary HPTEG in HPT resizing code
KVM: PPC: Book3S PR: Fix broken select due to misspelling
KVM: x86: don't forget vcpu_put() in kvm_arch_vcpu_ioctl_set_sregs()
KVM: PPC: Book3S PR: Fix svcpu copying with preemption enabled
KVM: PPC: Book3S HV: Drop locks before reading guest memory
kvm: x86: remove efer_reload entry in kvm_vcpu_stat
KVM: x86: AMD Processor Topology Information
x86/kvm/vmx: do not use vm-exit instruction length for fast MMIO when running nested
kvm: embed vcpu id to dentry of vcpu anon inode
kvm: Map PFN-type memory regions as writable (if possible)
x86/kvm: Make it compile on 32bit and with HYPYERVISOR_GUEST=n
KVM: arm/arm64: Fixup userspace irqchip static key optimization
KVM: arm/arm64: Fix userspace_irqchip_in_use counting
KVM: arm/arm64: Fix incorrect timer_is_pending logic
MAINTAINERS: update KVM/s390 maintainers
MAINTAINERS: add Halil as additional vfio-ccw maintainer
MAINTAINERS: add David as a reviewer for KVM/s390
Ensure we gather architecture requirements about each architecture
supporting the "sync_core" membarrier command in a single file under
Documentation/features.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Andrea Parri <parri.andrea@gmail.com>
Cc: Andrew Hunter <ahh@google.com>
Cc: Avi Kivity <avi@scylladb.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Dave Watson <davejwatson@fb.com>
Cc: David Sehr <sehr@google.com>
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Maged Michael <maged.michael@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: linux-api@vger.kernel.org
Link: http://lkml.kernel.org/r/1518208256-22034-1-git-send-email-mathieu.desnoyers@efficios.com
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Heiko Carstens:
"The main thing in this merge is the defense for the Spectre
vulnerabilities. But there are other updates as well, the changes in
more detail:
- An s390 specific implementation of the array_index_mask_nospec
function to the defense against spectre v1
- Two patches to utilize the new PPA-12/PPA-13 instructions to run
the kernel and/or user space with reduced branch predicton.
- The s390 variant of the 'retpoline' spectre v2 defense called
'expoline'. There is no return instruction for s390, instead an
indirect branch is used for function return
The s390 defense mechanism for indirect branches works by using an
execute-type instruction with the indirect branch as the target of
the execute. In effect that turns off the prediction for the
indirect branch.
- Scrub registers in entry.S that contain user controlled values to
prevent the speculative use of these values.
- Re-add the second parameter for the s390 specific runtime
instrumentation system call and move the header file to uapi. The
second parameter will continue to do nothing but older kernel
versions only accepted valid real-time signal numbers. The details
will be documented in the man-page for the system call.
- Corrections and improvements for the s390 specific documentation
- Add a line to /proc/sysinfo to display the CPU model dependent
license-internal-code identifier
- A header file include fix for eadm.
- An error message fix in the kprobes code.
- The removal of an outdated ARCH_xxx select statement"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/kconfig: Remove ARCH_WANTS_PROT_NUMA_PROT_NONE select
s390: introduce execute-trampolines for branches
s390: run user space and KVM guests with modified branch prediction
s390: add options to change branch prediction behaviour for the kernel
s390/alternative: use a copy of the facility bit mask
s390: add optimized array_index_mask_nospec
s390: scrub registers on kernel entry and KVM exit
s390/cio: fix kernel-doc usage
s390/runtime_instrumentation: re-add signum system call parameter
s390/cpum_cf: correct counter number of LAST_HOST_TRANSLATIONS
s390/kprobes: Fix %p uses in error messages
s390/runtime instrumentation: provide uapi header file
s390/sysinfo: add and display licensed internal code identifier
s390/docs: reword airq section
s390/docs: mention subchannel types
s390/cmf: fix kerneldoc
s390/eadm: fix CONFIG_BLOCK include dependency
Pull more ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups, a few new quirks, a couple of
updates related to the handling of ACPI tables and ACPICA copyrights
refreshment.
Specifics:
- Update the ACPICA kernel code to upstream revision 20180105
including:
* Assorted fixes (Jung-uk Kim)
* Support for X32 ABI compilation (Anuj Mittal)
* Update of ACPICA copyrights to 2018 (Bob Moore)
- Prepare for future modifications to avoid executing the _STA
control method too early (Hans de Goede)
- Make the processor performance control library code ignore _PPC
notifications if they cannot be handled and fix up the C1 idle
state definition when it is used as a fallback state (Chen Yu,
Yazen Ghannam)
- Make it possible to use the SPCR table on x86 and to replace the
original IORT table with a new one from initrd (Prarit Bhargava,
Shunyong Yang)
- Add battery-related quirks for Asus UX360UA and UX410UAK and add
quirks for table parsing on Dell XPS 9570 and Precision M5530 (Kai
Heng Feng)
- Address static checker warnings in the CPPC code (Gustavo Silva)
- Avoid printing a raw pointer to the kernel log in the smart battery
driver (Greg Kroah-Hartman)"
* tag 'acpi-part2-4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI: sbshc: remove raw pointer from printk() message
ACPI: SPCR: Make SPCR available to x86
ACPI / CPPC: Use 64-bit arithmetic instead of 32-bit
ACPI / tables: Add IORT to injectable table list
ACPI / bus: Parse tables as term_list for Dell XPS 9570 and Precision M5530
ACPICA: Update version to 20180105
ACPICA: All acpica: Update copyrights to 2018
ACPI / processor: Set default C1 idle state description
ACPI / battery: Add quirk for Asus UX360UA and UX410UAK
ACPI: processor_perflib: Do not send _PPC change notification if not ready
ACPI / scan: Use acpi_bus_get_status() to initialize ACPI_TYPE_DEVICE devs
ACPI / bus: Do not call _STA on battery devices with unmet dependencies
PCI: acpiphp_ibm: prepare for acpi_get_object_info() no longer returning status
ACPI: export acpi_bus_get_status_handle()
ACPICA: Add a missing pair of parentheses
ACPICA: Prefer ACPI_TO_POINTER() over ACPI_ADD_PTR()
ACPICA: Avoid NULL pointer arithmetic
ACPICA: Linux: add support for X32 ABI compilation
ACPI / video: Use true for boolean value
Pull more power management updates from Rafael Wysocki:
"These are mostly fixes and cleanups and removal of the no longer
needed at32ap-cpufreq driver.
Specifics:
- Drop the at32ap-cpufreq driver which is useless after the removal
of the corresponding arch (Corentin LABBE).
- Fix a regression from the 4.14 cycle in the APM idle driver by
making it initialize the polling state properly (Rafael Wysocki).
- Fix a crash on failing system suspend due to a missing check in the
cpufreq core (Bo Yan).
- Make the intel_pstate driver initialize the hardware-managed
P-state control (HWP) feature on CPU0 upon resume from system
suspend if HWP had been enabled before the system was suspended
(Chen Yu).
- Fix up the SCPI cpufreq driver after recent changes (Sudeep Holla,
Wei Yongjun).
- Avoid pointer subtractions during frequency table walks in cpufreq
(Dominik Brodowski).
- Avoid the check for ProcFeedback in ST/CZ in the cpufreq driver for
AMD processors and add a MODULE_ALIAS for cpufreq on ARM IMX (Akshu
Agrawal, Nicolas Chauvet).
- Fix the prototype of swsusp_arch_resume() on x86 (Arnd Bergmann).
- Fix up the parsing of power domains DT data (Ulf Hansson)"
* tag 'pm-part2-4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
arm: imx: Add MODULE_ALIAS for cpufreq
cpufreq: Add and use cpufreq_for_each_{valid_,}entry_idx()
cpufreq: intel_pstate: Enable HWP during system resume on CPU0
cpufreq: scpi: fix error return code in scpi_cpufreq_init()
x86: hibernate: fix swsusp_arch_resume() prototype
PM / domains: Fix up domain-idle-states OF parsing
cpufreq: scpi: fix static checker warning cdev isn't an ERR_PTR
cpufreq: remove at32ap-cpufreq
cpufreq: AMD: Ignore the check for ProcFeedback in ST/CZ
x86: PM: Make APM idle driver initialize polling state
cpufreq: Skip cpufreq resume if it's not suspended
Pull idr updates from Matthew Wilcox:
- test-suite improvements
- replace the extended API by improving the normal API
- performance improvement for IDRs which are 1-based rather than
0-based
- add documentation
* 'idr-2018-02-06' of git://git.infradead.org/users/willy/linux-dax:
idr: Add documentation
idr: Make 1-based IDRs more efficient
idr: Warn if old iterators see large IDs
idr: Rename idr_for_each_entry_ext
idr: Remove idr_alloc_ext
cls_u32: Convert to idr_alloc_u32
cls_u32: Reinstate cyclic allocation
cls_flower: Convert to idr_alloc_u32
cls_bpf: Convert to use idr_alloc_u32
cls_basic: Convert to use idr_alloc_u32
cls_api: Convert to idr_alloc_u32
net sched actions: Convert to use idr_alloc_u32
idr: Add idr_alloc_u32 helper
idr: Delete idr_find_ext function
idr: Delete idr_replace_ext function
idr: Delete idr_remove_ext function
IDR test suite: Check handling negative end correctly
idr test suite: Fix ida_test_random()
radix tree test suite: Remove ARRAY_SIZE
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull afs updates from David Howells:
"Four fixes:
- add a missing put
- two fixes to reset the address iteration cursor correctly
- fix setting up the fileserver iteration cursor.
Two cleanups:
- remove some dead code
- rearrange a function to be more logically laid out
And one new feature:
- Support AFS dynamic root.
With this one should be able to do, say:
mkdir /afs
mount -t afs none /afs -o dyn
to create a dynamic root and then, provided you have keyutils
installed, do:
ls /afs/grand.central.org
and:
ls /afs/umich.edu
to list the root volumes of both those organisations' AFS cells
without requiring any other setup (the kernel upcall to a program
in the keyutils package to do DNS access as does NFS)"
* tag 'afs-next-20180208' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
afs: Support the AFS dynamic root
afs: Rearrange afs_select_fileserver() a little
afs: Remove unused code
afs: Fix server list handling
afs: Need to clear responded flag in addr cursor
afs: Fix missing cursor clearance
afs: Add missing afs_put_cell()
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"This time there are not a lot of changes coming from the IOMMU side.
That is partly because I returned from my parental leave late in the
development process and probably partly because everyone was busy with
Spectre and Meltdown mitigation work and didn't find the time for
IOMMU work. So here are the few changes that queued up for this merge
window:
- 5-level page-table support for the Intel IOMMU.
- error reporting improvements for the AMD IOMMU driver
- additional DT bindings for ipmmu-vmsa (Renesas)
- small fixes and cleanups"
* tag 'iommu-updates-v4.16' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu: Clean up of_iommu_init_fn
iommu/ipmmu-vmsa: Remove redundant of_iommu_init_fn hook
iommu/msm: Claim bus ops on probe
iommu/vt-d: Enable 5-level paging mode in the PASID entry
iommu/vt-d: Add a check for 5-level paging support
iommu/vt-d: Add a check for 1GB page support
iommu/vt-d: Enable upto 57 bits of domain address width
iommu/vt-d: Use domain instead of cache fetching
iommu/exynos: Don't unconditionally steal bus ops
iommu/omap: Fix debugfs_create_*() usage
iommu/vt-d: clean up pr_irq if request_threaded_irq fails
iommu: Check the result of iommu_group_get() for NULL
iommu/ipmmu-vmsa: Add r8a779(70|95) DT bindings
iommu/ipmmu-vmsa: Add r8a7796 DT binding
iommu/amd: Set the device table entry PPR bit for IOMMU V2 devices
iommu/amd - Record more information about unknown events
Document a binding for the MIPS Cluster Power Controller (CPC) that
allows the device tree to specify where the CPC registers are located.
Signed-off-by: Paul Burton <paul.burton@mips.com>
Signed-off-by: Aleksandar Markovic <aleksandar.markovic@mips.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: devicetree@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/18512/
Signed-off-by: James Hogan <jhogan@kernel.org>
Pointer subtraction is slow and tedious. Therefore, replace all instances
where cpufreq_for_each_{valid_,}entry loops contained such substractions
with an iteration macro providing an index to the frequency_table entry.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Link: http://lkml.kernel.org/r/20180120020237.GM13338@ZenIV.linux.org.uk
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
git://www.linux-watchdog.org/linux-watchdog
Pull watchdog updates from Wim Van Sebroeck:
- new watchdog device drivers for Realtek RTD1295 and Spreadtrum SC9860
platform
- add support for the following devices: jz4780 SoC, AST25xx series SoC
and r8a77970 SoC
- convert to watchdog framework: i6300esb_wdt, xen_wdt and sp5100_tco
- several fixes for watchdog core
- remove at32ap700x and obsolete documentation
- gpio: Convert to use GPIO descriptors
- rename gemini into FTWDT010 as this IP block is generc from Faraday
Technology
- various clean-ups and small bugfixes
- add Guenter Roeck as co-maintainer
- change maintainers e-mail address
* tag 'linux-watchdog-4.16-rc1' of git://www.linux-watchdog.org/linux-watchdog: (74 commits)
documentation: watchdog: remove documentation of w83697hf_wdt/w83697ug_wdt
documentation: watchdog: remove documentation for ixp2000
documentation: watchdog: remove documentation of at32ap700x_wdt
watchdog: remove at32ap700x_wdt
watchdog: sp5100_tco: Add support for recent FCH versions
watchdog: sp5100-tco: Abort if watchdog is disabled by hardware
watchdog: sp5100_tco: Use bit operations
watchdog: sp5100_tco: Convert to use watchdog subsystem
watchdog: sp5100_tco: Clean up function and variable names
watchdog: sp5100_tco: Use dev_ print functions where possible
watchdog: sp5100_tco: Match PCI device early
watchdog: sp5100_tco: Clean up sp5100_tco_setupdevice
watchdog: sp5100_tco: Use standard error codes
watchdog: sp5100_tco: Use request_muxed_region where possible
watchdog: sp5100_tco: Fix watchdog disable bit
watchdog: sp5100_tco: Always use SP5100_IO_PM_{INDEX_REG,DATA_REG}
watchdog: core: make sure the watchdog_worker is not deferred
watchdog: mt7621: switch to using managed devm_watchdog_register_device()
watchdog: mt7621: set WDOG_HW_RUNNING bit when appropriate
watchdog: imx2_wdt: restore previous timeout after suspend+resume
Pull MIPS updates from James Hogan:
"These are the main MIPS changes for 4.16.
Rough overview:
(1) Basic support for the Ingenic JZ4770 based GCW Zero open-source
handheld video game console
(2) Support for the Ranchu board (used by Android emulator)
(3) Various cleanups and misc improvements
More detailed summary:
Fixes:
- Fix generic platform's USB_*HCI_BIG_ENDIAN selects (4.9)
- Fix vmlinuz default build when ZBOOT selected
- Fix clean up of vmlinuz targets
- Fix command line duplication (in preparation for Ingenic JZ4770)
Miscellaneous:
- Allow Processor ID reads to be to be optimised away by the compiler
(improves performance when running in guest)
- Push ARCH_MIGHT_HAVE_PC_SERIO/PARPORT down to platform level to
disable on generic platform with Ranchu board support
- Add helpers for assembler macro instructions for older assemblers
- Use assembler macro instructions to support VZ, XPA & MSA
operations on older assemblers, removing C wrapper duplication
- Various improvements to VZ & XPA assembly wrappers
- Add drivers/platform/mips/ to MIPS MAINTAINERS entry
Minor cleanups:
- Misc FPU emulation cleanups (removal of unnecessary include, moving
macros to common header, checkpatch and sparse fixes)
- Remove duplicate assignment of core in play_dead()
- Remove duplication in watchpoint handling
- Remove mips_dma_mapping_error() stub
- Use NULL instead of 0 in prepare_ftrace_return()
- Use proper kernel-doc Return keyword for
__compute_return_epc_for_insn()
- Remove duplicate semicolon in csum_fold()
Platform support:
Broadcom:
- Enable ZBOOT on BCM47xx
Generic platform:
- Add Ranchu board support, used by Android emulator
- Fix machine compatible string matching for Ranchu
- Support GIC in EIC mode
Ingenic platforms:
- Add DT, defconfig and other support for JZ4770 SoC and GCW Zero
- Support dynamnic machine types (i.e. JZ4740 / JZ4770 / JZ4780)
- Add Ingenic JZ4770 CGU clocks
- General Ingenic clk changes to prepare for JZ4770 SoC support
- Use common command line handling code
- Add DT vendor prefix to GCW (Game Consoles Worldwide)
Loongson:
- Add MAINTAINERS entry for Loongson2 and Loongson3 platforms
- Drop 32-bit support for Loongson 2E/2F devices
- Fix build failures due to multiple use of 'MEM_RESERVED'"
* tag 'mips_4.16' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/mips: (53 commits)
MIPS: Malta: Sanitize mouse and keyboard configuration.
MIPS: Update defconfigs after previous patch.
MIPS: Push ARCH_MIGHT_HAVE_PC_SERIO down to platform level
MIPS: Push ARCH_MIGHT_HAVE_PC_PARPORT down to platform level
MIPS: SMP-CPS: Remove duplicate assignment of core in play_dead
MIPS: Generic: Support GIC in EIC mode
MIPS: generic: Fix Makefile alignment
MIPS: generic: Fix ranchu_of_match[] termination
MIPS: generic: Fix machine compatible matching
MIPS: Loongson fix name confict - MEM_RESERVED
MIPS: bcm47xx: enable ZBOOT support
MIPS: Fix trailing semicolon
MIPS: Watch: Avoid duplication of bits in mips_read_watch_registers
MIPS: Watch: Avoid duplication of bits in mips_install_watch_registers.
MIPS: MSA: Update helpers to use new asm macros
MIPS: XPA: Standardise readx/writex accessors
MIPS: XPA: Allow use of $0 (zero) to MTHC0
MIPS: XPA: Use XPA instructions in assembly
MIPS: VZ: Pass GC0 register names in $n format
MIPS: VZ: Update helpers to use new asm macros
Pull more documentation updates from Jonathan Corbet:
"A few late-arriving fixes, along with Konstantin's PGP document that
had no reason to wait another cycle"
* tag 'docs-4.16-2' of git://git.lwn.net/linux:
Documentation/process: tweak pgp maintainer guide
Documentation/admin-guide: fixes for thunderbolt.rst
Documentation: mips: Update AU1xxx_IDE Kconfig dependencies
Fix broken link in Documentation/process/kernel-docs.rst
Documentation/process: kernel maintainer PGP guide
SPCR is currently only enabled or ARM64 and x86 can use SPCR to setup
an early console.
General fixes include updating Documentation & Kconfig (for x86),
updating comments, and changing parse_spcr() to acpi_parse_spcr(),
and earlycon_init_is_deferred to earlycon_acpi_spcr_enable to be
more descriptive.
On x86, many systems have a valid SPCR table but the table version is
not 2 so the table version check must be a warning.
On ARM64 when the kernel parameter earlycon is used both the early console
and console are enabled. On x86, only the earlycon should be enabled by
by default. Modify acpi_parse_spcr() to allow options for initializing
the early console and console separately.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Reviewed-by: Mark Salter <msalter@redhat.com>
Tested-by: Mark Salter <msalter@redhat.com>
Merge misc updates from Andrew Morton:
- kasan updates
- procfs
- lib/bitmap updates
- other lib/ updates
- checkpatch tweaks
- rapidio
- ubsan
- pipe fixes and cleanups
- lots of other misc bits
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (114 commits)
Documentation/sysctl/user.txt: fix typo
MAINTAINERS: update ARM/QUALCOMM SUPPORT patterns
MAINTAINERS: update various PALM patterns
MAINTAINERS: update "ARM/OXNAS platform support" patterns
MAINTAINERS: update Cortina/Gemini patterns
MAINTAINERS: remove ARM/CLKDEV SUPPORT file pattern
MAINTAINERS: remove ANDROID ION pattern
mm: docs: add blank lines to silence sphinx "Unexpected indentation" errors
mm: docs: fix parameter names mismatch
mm: docs: fixup punctuation
pipe: read buffer limits atomically
pipe: simplify round_pipe_size()
pipe: reject F_SETPIPE_SZ with size over UINT_MAX
pipe: fix off-by-one error when checking buffer limits
pipe: actually allow root to exceed the pipe buffer limits
pipe, sysctl: remove pipe_proc_fn()
pipe, sysctl: drop 'min' parameter from pipe-max-size converter
kasan: rework Kconfig settings
crash_dump: is_kdump_kernel can be boolean
kernel/mutex: mutex_is_locked can be boolean
Pull networking fixes from David Miller:
1) Fix error path in netdevsim, from Jakub Kicinski.
2) Default values listed in tcp_wmem and tcp_rmem documentation were
inaccurate, from Tonghao Zhang.
3) Fix route leaks in SCTP, both for ipv4 and ipv6. From Alexey Kodanev
and Tommi Rantala.
4) Fix "MASK < Y" meant to be "MASK << Y" in xgbe driver, from Wolfram
Sang.
5) Use after free in u32_destroy_key(), from Paolo Abeni.
6) Fix two TX issues in be2net driver, from Suredh Reddy.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (25 commits)
be2net: Handle transmit completion errors in Lancer
be2net: Fix HW stall issue in Lancer
RDS: IB: Fix null pointer issue
nfp: fix kdoc warnings on nested structures
sample/bpf: fix erspan metadata
net: erspan: fix erspan config overwrite
net: erspan: fix metadata extraction
cls_u32: fix use after free in u32_destroy_key()
net: amd-xgbe: fix comparison to bitshift when dealing with a mask
net: phy: Handle not having GPIO enabled in the kernel
ibmvnic: fix empty firmware version and errors cleanup
sctp: fix dst refcnt leak in sctp_v4_get_dst
sctp: fix dst refcnt leak in sctp_v6_get_dst()
dwc-xlgmac: remove Jie Deng as co-maintainer
doc: Change the min default value of tcp_wmem/tcp_rmem.
samples/bpf: use bpf_set_link_xdp_fd
libbpf: add missing SPDX-License-Identifier
libbpf: add error reporting in XDP
libbpf: add function to setup XDP
tools: add netlink.h and if_link.h in tools uapi
Fix 'documetation' to 'documentation'
Link: http://lkml.kernel.org/r/CAKW4uUxRPZz59aWAX8ytaCB5=Qh6d_CvAnO7rYq-6NRAnQJbDA@mail.gmail.com
Signed-off-by: Kangmin Park <l4stpr0gr4m@gmail.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Jiri Kosina <trivial@kernel.org>
Based on the feedback provided:
- Uniformly use lowercase k in "Linux kernel"
- Give a one-sentence explanation of what subkeys are
- Explain what signed commits might be useful for even if upstream
developers do not use them for much of anything
- Admonish to set up gpg-agent if signed commits are turned on in
git config
- Fix a typo reported by Luc Van Oostenryck
Signed-off-by: Konstantin Ryabitsev <konstantin@linuxfoundation.org>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform-driver updates from Darren Hart:
"New model support added for Dell, Ideapad, Acer, Asus, Thinkpad, and
GPD laptops. Improvements to the common intel-vbtn driver, including
tablet mode, rotate, and front button support. Intel CPU support added
for Cannonlake and platform support for Dollar Cove power button.
Overhaul of the mellanox platform driver, creating a new
platform/mellanox directory for the newly multi-architecture regmap
interface.
Significant Intel PMC update with CannonLake support, Coffeelake
update, CPUID enumeration, module support, new read64 API, refactoring
and cleanups.
Revert the apple-gmux iGP IO lock, addressing reported issues with
non-binary drivers, leaving Nvidia binary driver users to comment out
conflicting code.
Miscellaneous fixes and cleanups"
* tag 'platform-drivers-x86-v4.16-1' of git://git.infradead.org/linux-platform-drivers-x86: (81 commits)
platform/x86: mlx-platform: Fix an ERR_PTR vs NULL issue
platform/x86: intel_pmc_core: Special case for Coffeelake
platform/x86: intel_pmc_core: Add CannonLake PCH support
x86/cpu: Add Cannonlake to Intel family
platform/x86: intel_pmc_core: Read base address from LPIT
ACPI / LPIT: Export lpit_read_residency_count_address()
platform/x86: intel-vbtn: Replace License by SDPX identifier
platform/x86: intel-vbtn: Remove redundant inclusions
platform/x86: intel-vbtn: Support tablet mode switch
platform/x86: dell-laptop: Allocate buffer on heap rather than globally
platform/x86: intel_pmc_core: Remove unused header file
platform/x86: mlx-platform: Add hotplug device unregister to error path
platform/x86: mlx-platform: fix module aliases
platform/mellanox: mlxreg-hotplug: Add check for negative adapter number
platform/x86: mlx-platform: Add IO access verification callbacks
platform/x86: mlx-platform: Document pdev_hotplug field
platform/x86: mlx-platform: Allow compilation for 32 bit arch
platform/mellanox: mlxreg-hotplug: Enable building for ARM
platform/mellanox: mlxreg-hotplug: Modify to use a regmap interface
platform/mellanox: Group create/destroy with attribute functions
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
- fix a race condition issue in power allocator governor (Yi Zeng).
- add support for AP806 and CP110 in armada thermal driver, together
with several improvements (Baruch Siach, Miquel Raynal)
- add support for r8z7743 in rcar thermal driver (Biju Das)
- convert thermal core to use new hwmon API to avoid warning (Fabio
Estevam)
- small fixes and cleanups in thermal core and x86_pkg_thermal,
int3400_thermal, hisi_thermal, mtk_thermal and imx_thermal drivers
(Pravin Shedge, Geert Uytterhoeven, Alexey Khoroshilov, Brian Bian,
Matthias Brugger, Nicolin Chen, Uwe Kleine-König)
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (25 commits)
thermal: thermal_hwmon: Convert to hwmon_device_register_with_info()
thermal/x86 pkg temp: Remove debugfs_create_u32() casts
thermal: int3400_thermal: fix error handling in int3400_thermal_probe()
thermal/drivers/hisi: Remove bogus const from function return type
thermal: armada: Give meaningful names to the thermal zones
thermal: armada: Wait sensors validity before exiting the init callback
thermal: armada: Change sensors trim default value
thermal: armada: Update Kconfig and module description
thermal: armada: Add support for Armada CP110
thermal: armada: Add support for Armada AP806
thermal: armada: Use real status register name
thermal: armada: Clarify control registers accesses
thermal: armada: Simplify the check of the validity bit
thermal: armada: Use msleep for long delays
dt-bindings: thermal: Describe Armada AP806 and CP110
dt-bindings: thermal: rcar: Add device tree support for r8a7743
thermal: mtk: Cleanup unused defines
thermal: imx: update to new formula according to NXP AN5215
thermal: imx: use consistent style to write temperatures
thermal: imx: improve comments describing algorithm for temp calculation
Move the idr kernel-doc to its own idr.rst file and add a few
paragraphs about how to use it. Also add some more kernel-doc.
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- videobuf2 was moved to a media/common dir, as it is now used by the
DVB subsystem too
- Digital TV core memory mapped support interface
- new sensor driver: ov7740
- several improvements at ddbridge driver
- new V4L2 driver: IPU3 CIO2 CSI-2 receiver unit, found on some Intel
SoCs
- new tuner driver: tda18250
- finally got rid of all LIRC staging drivers
- as we don't have old lirc drivers anymore, restruct the lirc device
code
- add support for UVC metadata
- add a new staging driver for NVIDIA Tegra Video Decoder Engine
- DVB kAPI headers moved to include/media
- synchronize the kAPI and uAPI for the DVB subsystem, removing the gap
for non-legacy APIs
- reduce the kAPI gap for V4L2
- lots of other driver enhancements, cleanups, etc.
* tag 'media/v4.16-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (407 commits)
media: v4l2-compat-ioctl32.c: make ctrl_is_pointer work for subdevs
media: v4l2-compat-ioctl32.c: refactor compat ioctl32 logic
media: v4l2-compat-ioctl32.c: don't copy back the result for certain errors
media: v4l2-compat-ioctl32.c: drop pr_info for unknown buffer type
media: v4l2-compat-ioctl32.c: copy clip list in put_v4l2_window32
media: v4l2-compat-ioctl32.c: fix ctrl_is_pointer
media: v4l2-compat-ioctl32.c: copy m.userptr in put_v4l2_plane32
media: v4l2-compat-ioctl32.c: avoid sizeof(type)
media: v4l2-compat-ioctl32.c: move 'helper' functions to __get/put_v4l2_format32
media: v4l2-compat-ioctl32.c: fix the indentation
media: v4l2-compat-ioctl32.c: add missing VIDIOC_PREPARE_BUF
media: v4l2-ioctl.c: don't copy back the result for -ENOTTY
media: v4l2-ioctl.c: use check_fmt for enum/g/s/try_fmt
media: vivid: fix module load error when enabling fb and no_error_inj=1
media: dvb_demux: improve debug messages
media: dvb_demux: Better handle discontinuity errors
media: cxusb, dib0700: ignore XC2028_I2C_FLUSH
media: ts2020: avoid integer overflows on 32 bit machines
media: i2c: ov7740: use gpio/consumer.h instead of gpio.h
media: entity: Add a nop variant of media_entity_cleanup
Pull more rdma updates from Doug Ledford:
"Items of note:
- two patches fix a regression in the 4.15 kernel. The 4.14 kernel
worked fine with NVMe over Fabrics and mlx5 adapters. That broke in
4.15. The fix is here.
- one of the patches (the endian notation patch from Lijun) looks
like a lot of lines of change, but it's mostly mechanical in
nature. It amounts to the biggest chunk of change in it (it's about
2/3rds of the overall pull request).
Summary:
- Clean up some function signatures in rxe for clarity
- Tidy the RDMA netlink header to remove unimplemented constants
- bnxt_re driver fixes, one is a regression this window.
- Minor hns driver fixes
- Various fixes from Dan Carpenter and his tool
- Fix IRQ cleanup race in HFI1
- HF1 performance optimizations and a fix to report counters in the right units
- Fix for an IPoIB startup sequence race with the external manager
- Oops fix for the new kabi path
- Endian cleanups for hns
- Fix for mlx5 related to the new automatic affinity support"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (38 commits)
net/mlx5: increase async EQ to avoid EQ overrun
mlx5: fix mlx5_get_vector_affinity to start from completion vector 0
RDMA/hns: Fix the endian problem for hns
IB/uverbs: Use the standard kConfig format for experimental
IB: Update references to libibverbs
IB/hfi1: Add 16B rcvhdr trace support
IB/hfi1: Convert kzalloc_node and kcalloc to use kcalloc_node
IB/core: Avoid a potential OOPs for an unused optional parameter
IB/core: Map iWarp AH type to undefined in rdma_ah_find_type
IB/ipoib: Fix for potential no-carrier state
IB/hfi1: Show fault stats in both TX and RX directions
IB/hfi1: Remove blind constants from 16B update
IB/hfi1: Convert PortXmitWait/PortVLXmitWait counters to flit times
IB/hfi1: Do not override given pcie_pset value
IB/hfi1: Optimize process_receive_ib()
IB/hfi1: Remove unnecessary fecn and becn fields
IB/hfi1: Look up ibport using a pointer in receive path
IB/hfi1: Optimize packet type comparison using 9B and bypass code paths
IB/hfi1: Compute BTH only for RDMA_WRITE_LAST/SEND_LAST packet
IB/hfi1: Remove dependence on qp->s_hdrwords
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- skip AER driver error recovery callbacks for correctable errors
reported via ACPI APEI, as we already do for errors reported via the
native path (Tyler Baicar)
- fix DPC shared interrupt handling (Alex Williamson)
- print full DPC interrupt number (Keith Busch)
- enable DPC only if AER is available (Keith Busch)
- simplify DPC code (Bjorn Helgaas)
- calculate ASPM L1 substate parameter instead of hardcoding it (Bjorn
Helgaas)
- enable Latency Tolerance Reporting for ASPM L1 substates (Bjorn
Helgaas)
- move ASPM internal interfaces out of public header (Bjorn Helgaas)
- allow hot-removal of VGA devices (Mika Westerberg)
- speed up unplug and shutdown by assuming Thunderbolt controllers
don't support Command Completed events (Lukas Wunner)
- add AtomicOps support for GPU and Infiniband drivers (Felix Kuehling,
Jay Cornwall)
- expose "ari_enabled" in sysfs to help NIC naming (Stuart Hayes)
- clean up PCI DMA interface usage (Christoph Hellwig)
- remove PCI pool API (replaced with DMA pool) (Romain Perier)
- deprecate pci_get_bus_and_slot(), which assumed PCI domain 0 (Sinan
Kaya)
- move DT PCI code from drivers/of/ to drivers/pci/ (Rob Herring)
- add PCI-specific wrappers for dev_info(), etc (Frederick Lawler)
- remove warnings on sysfs mmap failure (Bjorn Helgaas)
- quiet ROM validation messages (Alex Deucher)
- remove redundant memory alloc failure messages (Markus Elfring)
- fill in types for compile-time VGA and other I/O port resources
(Bjorn Helgaas)
- make "pci=pcie_scan_all" work for Root Ports as well as Downstream
Ports to help AmigaOne X1000 (Bjorn Helgaas)
- add SPDX tags to all PCI files (Bjorn Helgaas)
- quirk Marvell 9128 DMA aliases (Alex Williamson)
- quirk broken INTx disable on Ceton InfiniTV4 (Bjorn Helgaas)
- fix CONFIG_PCI=n build by adding dummy pci_irqd_intx_xlate() (Niklas
Cassel)
- use DMA API to get MSI address for DesignWare IP (Niklas Cassel)
- fix endpoint-mode DMA mask configuration (Kishon Vijay Abraham I)
- fix ARTPEC-6 incorrect IS_ERR() usage (Wei Yongjun)
- add support for ARTPEC-7 SoC (Niklas Cassel)
- add endpoint-mode support for ARTPEC (Niklas Cassel)
- add Cadence PCIe host and endpoint controller driver (Cyrille
Pitchen)
- handle multiple INTx status bits being set in dra7xx (Vignesh R)
- translate dra7xx hwirq range to fix INTD handling (Vignesh R)
- remove deprecated Exynos PHY initialization code (Jaehoon Chung)
- fix MSI erratum workaround for HiSilicon Hip06/Hip07 (Dongdong Liu)
- fix NULL pointer dereference in iProc BCMA driver (Ray Jui)
- fix Keystone interrupt-controller-node lookup (Johan Hovold)
- constify qcom driver structures (Julia Lawall)
- rework Tegra config space mapping to increase space available for
endpoints (Vidya Sagar)
- simplify Tegra driver by using bus->sysdata (Manikanta Maddireddy)
- remove PCI_REASSIGN_ALL_BUS usage on Tegra (Manikanta Maddireddy)
- add support for Global Fabric Manager Server (GFMS) event to
Microsemi Switchtec switch driver (Logan Gunthorpe)
- add IDs for Switchtec PSX 24xG3 and PSX 48xG3 (Kelvin Cao)
* tag 'pci-v4.16-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (140 commits)
PCI: cadence: Add EndPoint Controller driver for Cadence PCIe controller
dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe endpoint controller
PCI: endpoint: Fix EPF device name to support multi-function devices
PCI: endpoint: Add the function number as argument to EPC ops
PCI: cadence: Add host driver for Cadence PCIe controller
dt-bindings: PCI: cadence: Add DT bindings for Cadence PCIe host controller
PCI: Add vendor ID for Cadence
PCI: Add generic function to probe PCI host controllers
PCI: generic: fix missing call of pci_free_resource_list()
PCI: OF: Add generic function to parse and allocate PCI resources
PCI: Regroup all PCI related entries into drivers/pci/Makefile
PCI/DPC: Reformat DPC register definitions
PCI/DPC: Add and use DPC Status register field definitions
PCI/DPC: Squash dpc_rp_pio_get_info() into dpc_process_rp_pio_error()
PCI/DPC: Remove unnecessary RP PIO register structs
PCI/DPC: Push dpc->rp_pio_status assignment into dpc_rp_pio_get_info()
PCI/DPC: Squash dpc_rp_pio_print_error() into dpc_rp_pio_get_info()
PCI/DPC: Make RP PIO log size check more generic
PCI/DPC: Rename local "status" to "dpc_status"
PCI/DPC: Squash dpc_rp_pio_print_tlp_header() into dpc_rp_pio_print_error()
Support the AFS dynamic root which is a pseudo-volume that doesn't connect
to any server resource, but rather is just a root directory that
dynamically creates mountpoint directories where the name of such a
directory is the name of the cell.
Such a mount can be created thus:
Dynamic root superblocks aren't shared except by bind mounts and
propagation. Cell root volumes can then be mounted by referring to them by
name, e.g.:
ls /afs/grand.central.org/
ls /afs/.grand.central.org/
The kernel will upcall to consult the DNS if the address wasn't supplied
directly.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs updates from Miklos Szeredi:
"This work from Amir adds NFS export capability to overlayfs. NFS
exporting an overlay filesystem is a challange because we want to keep
track of any copy-up of a file or directory between encoding the file
handle and decoding it.
This is achieved by indexing copied up objects by lower layer file
handle. The index is already used for hard links, this patchset
extends the use to NFS file handle decoding"
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: (51 commits)
ovl: check ERR_PTR() return value from ovl_encode_fh()
ovl: fix regression in fsnotify of overlay merge dir
ovl: wire up NFS export operations
ovl: lookup indexed ancestor of lower dir
ovl: lookup connected ancestor of dir in inode cache
ovl: hash non-indexed dir by upper inode for NFS export
ovl: decode pure lower dir file handles
ovl: decode indexed dir file handles
ovl: decode lower file handles of unlinked but open files
ovl: decode indexed non-dir file handles
ovl: decode lower non-dir file handles
ovl: encode lower file handles
ovl: copy up before encoding non-connectable dir file handle
ovl: encode non-indexed upper file handles
ovl: decode connected upper dir file handles
ovl: decode pure upper file handles
ovl: encode pure upper file handles
ovl: document NFS export
vfs: factor out helpers d_instantiate_anon() and d_alloc_anon()
ovl: store 'has_upper' and 'opaque' as bit flags
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"The Meson PWM controller driver gains support for the AXG series and a
minor bug is fixed for the STMPE driver.
To round things off, the class is now set for PWM channels exported
via sysfs which allows non-root access, provided that the system has
been configured accordingly"
* tag 'pwm/for-4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm:
pwm: meson: Add clock source configuration for Meson-AXG
dt-bindings: pwm: Update bindings for the Meson-AXG
pwm: stmpe: Fix wrong register offset for hwpwm=2 case
pwm: Set class for exported channels in sysfs
The SK_MEM_QUANTUM was changed from PAGE_SIZE to 4096. And the
tcp_wmem/tcp_rmem min default values are 4096.
Fixes: bd68a2a854ad ("net: set SK_MEM_QUANTUM to 4096")
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Tonghao Zhang <xiangxia.m.yue@gmail.com>
Alexei Starovoitov says:
pull-request: bpf 2018-02-02
The following pull-request contains BPF updates for your *net* tree.
The main changes are:
1) support XDP attach in libbpf, from Eric.
2) minor fixes, from Daniel, Jakub, Yonghong, Alexei.
Pull spectre/meltdown updates from Thomas Gleixner:
"The next round of updates related to melted spectrum:
- The initial set of spectre V1 mitigations:
- Array index speculation blocker and its usage for syscall,
fdtable and the n180211 driver.
- Speculation barrier and its usage in user access functions
- Make indirect calls in KVM speculation safe
- Blacklisting of known to be broken microcodes so IPBP/IBSR are not
touched.
- The initial IBPB support and its usage in context switch
- The exposure of the new speculation MSRs to KVM guests.
- A fix for a regression in x86/32 related to the cpu entry area
- Proper whitelisting for known to be safe CPUs from the mitigations.
- objtool fixes to deal proper with retpolines and alternatives
- Exclude __init functions from retpolines which speeds up the boot
process.
- Removal of the syscall64 fast path and related cleanups and
simplifications
- Removal of the unpatched paravirt mode which is yet another source
of indirect unproteced calls.
- A new and undisputed version of the module mismatch warning
- A couple of cleanup and correctness fixes all over the place
Yet another step towards full mitigation. There are a few things still
missing like the RBS underflow mitigation for Skylake and other small
details, but that's being worked on.
That said, I'm taking a belated christmas vacation for a week and hope
that everything is magically solved when I'm back on Feb 12th"
* 'x86-pti-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits)
KVM/SVM: Allow direct access to MSR_IA32_SPEC_CTRL
KVM/VMX: Allow direct access to MSR_IA32_SPEC_CTRL
KVM/VMX: Emulate MSR_IA32_ARCH_CAPABILITIES
KVM/x86: Add IBPB support
KVM/x86: Update the reverse_cpuid list to include CPUID_7_EDX
x86/speculation: Fix typo IBRS_ATT, which should be IBRS_ALL
x86/pti: Mark constant arrays as __initconst
x86/spectre: Simplify spectre_v2 command line parsing
x86/retpoline: Avoid retpolines for built-in __init functions
x86/kvm: Update spectre-v1 mitigation
KVM: VMX: make MSR bitmaps per-VCPU
x86/paravirt: Remove 'noreplace-paravirt' cmdline option
x86/speculation: Use Indirect Branch Prediction Barrier in context switch
x86/cpuid: Fix up "virtual" IBRS/IBPB/STIBP feature bits on Intel
x86/spectre: Fix spelling mistake: "vunerable"-> "vulnerable"
x86/spectre: Report get_user mitigation for spectre_v1
nl80211: Sanitize array index in parse_txq_params
vfs, fdtable: Prevent bounds-check bypass via speculative execution
x86/syscall: Sanitize syscall table de-references under speculation
x86/get_user: Use pointer masking to limit speculation
git://git.linaro.org/landing-teams/working/fujitsu/integration
Pull mailbox updates from Jassi Brar:
"Misc driver changes only:
- TI-MsgMgr: Fix print format for a printk
- TI-MSgMgr: SPDX license switch for the driver
- QCOM-IPC: Convert driver to use regmap
- QCOM-IPC: Spawn sibling clock device from mailbox driver"
* tag 'mailbox-v4.16' of git://git.linaro.org/landing-teams/working/fujitsu/integration:
dt-bindings: mailbox: qcom: Document the APCS clock binding
mailbox: qcom: Create APCS child device for clock controller
mailbox: qcom: Convert APCS IPC driver to use regmap
mailbox: ti-msgmgr: Use %zu for size_t print format
mailbox: ti-msgmgr: Switch to SPDX Licensing
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"I2C has the following changes for you:
- new flag to mark DMA safe buffers in i2c_msg. Also, some
infrastructure around it. And docs.
- huge refactoring of the at24 driver led by the new maintainer
Bartosz
- update I2C bus recovery to send STOP after recovery
- conversion from gpio to gpiod for I2C bus recovery
- adding a fault-injector to the i2c-gpio driver
- lots of small driver improvements, and bigger ones to
i2c-sh_mobile"
* 'i2c/for-4.16' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (99 commits)
i2c: mv64xxx: Add myself as maintainer for this driver
i2c: mv64xxx: Fix clock resource by adding an optional bus clock
i2c: mv64xxx: Remove useless test before clk_disable_unprepare
i2c: mxs: use true and false for boolean values
i2c: meson: update doc description to fix build warnings
i2c: meson: add configurable divider factors
dt-bindings: i2c: update documentation for the Meson-AXG
i2c: imx-lpi2c: add runtime pm support
i2c: rcar: fix some trivial typos in comments
i2c: davinci: fix the cpufreq transition
i2c: rk3x: add proper kerneldoc header
i2c: rk3x: account for const type of of_device_id.data
i2c: acorn: remove outdated path from file header
i2c: acorn: add MODULE_LICENSE tag
i2c: rcar: implement bus recovery
i2c: send STOP after successful bus recovery
i2c: ensure SDA is released in recovery if SDA is controllable
i2c: add 'set_sda' to bus_recovery_info
i2c: add identifier in declarations for i2c_bus_recovery
i2c: make kerneldoc about bus recovery more precise
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/fscrypt
Pull fscrypt updates from Ted Ts'o:
"Refactor support for encrypted symlinks to move common code to fscrypt"
Ted also points out about the merge:
"This makes the f2fs symlink code use the fscrypt_encrypt_symlink()
from the fscrypt tree. This will end up dropping the kzalloc() ->
f2fs_kzalloc() change, which means the fscrypt-specific allocation
won't get tested by f2fs's kmalloc error injection system; which is
fine"
* tag 'fscrypt_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/fscrypt: (26 commits)
fscrypt: fix build with pre-4.6 gcc versions
fscrypt: remove 'ci' parameter from fscrypt_put_encryption_info()
fscrypt: document symlink length restriction
fscrypt: fix up fscrypt_fname_encrypted_size() for internal use
fscrypt: define fscrypt_fname_alloc_buffer() to be for presented names
fscrypt: calculate NUL-padding length in one place only
fscrypt: move fscrypt_symlink_data to fscrypt_private.h
fscrypt: remove fscrypt_fname_usr_to_disk()
ubifs: switch to fscrypt_get_symlink()
ubifs: switch to fscrypt ->symlink() helper functions
ubifs: free the encrypted symlink target
f2fs: switch to fscrypt_get_symlink()
f2fs: switch to fscrypt ->symlink() helper functions
ext4: switch to fscrypt_get_symlink()
ext4: switch to fscrypt ->symlink() helper functions
fscrypt: new helper function - fscrypt_get_symlink()
fscrypt: new helper functions for ->symlink()
fscrypt: trim down fscrypt.h includes
fscrypt: move fscrypt_is_dot_dotdot() to fs/crypto/fname.c
fscrypt: move fscrypt_valid_enc_modes() to fscrypt_private.h
These days the userspace comes from rdma-core, revise references
in the kernel to point to the current repository.
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
Update the binding documentation for APCS to mention that the APCS
hardware block also expose a clock controller functionality.
The APCS clock controller is a mux and half-integer divider. It has the
main CPU PLL as an input and provides the clock for the application CPU.
Signed-off-by: Georgi Djakov <georgi.djakov@linaro.org>
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Only miscellaneous cleanups and bug fixes for ext4 this cycle"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: create ext4_kset dynamically
ext4: create ext4_feat kobject dynamically
ext4: release kobject/kset even when init/register fail
ext4: fix incorrect indentation of if statement
ext4: correct documentation for grpid mount option
ext4: use 'sbi' instead of 'EXT4_SB(sb)'
ext4: save error to disk in __ext4_grp_locked_error()
jbd2: fix sphinx kernel-doc build warnings
ext4: fix a race in the ext4 shutdown path
mbcache: make sure c_entry_count is not decremented past zero
ext4: no need flush workqueue before destroying it
ext4: fixed alignment and minor code cleanup in ext4.h
ext4: fix ENOSPC handling in DAX page fault handler
dax: pass detailed error code from dax_iomap_fault()
mbcache: revert "fs/mbcache.c: make count_objects() more robust"
mbcache: initialize entry->e_referenced in mb_cache_entry_create()
ext4: fix up remaining files with SPDX cleanups
Since w83697hf_wdt/w83697ug_wdt watchdogs drivers were removed
in commit 7285fae9345e ("watchdog: Remove drivers for W83697HF and W83697UG")
There are no need to keep their documentation
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
The ixp2000 watchdog driver was removed in commit 065e8238302b ("watchdog: remove ixp2000 driver")
No need to keep its documentation, so remove it.
Since at32ap700x_wdt is gone, no need to keep its documentation
