path: root/Documentation
2006-07-10[PATCH] checklist updateAndrew Morton
Update Documentation/SubmitChecklist. - Mention lockdep coverage - Describe documentation requirements - Number the various items to simplify the composition of caustic emails. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] remove the tasklist_lock exportChristoph Hellwig
As announced half a year ago this patch will remove the tasklist_lock export. The previous two patches got rid of the remaining modular users. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] Fix and enable EDAC sysfs operationDoug Thompson
When EDAC was first introduced into the kernel it had a sysfs interface, but due to some problems it was disabled in 2.6.16 and remained disabled in 2.6.17. With feedback, several of the control and attribute files of that interface had some good constructive feedback. PCI Blacklist/Whitelist was a major set which has design issues and it has been removed in this patch. Instead of storing PCI broken parity status in EDAC, it has been moved to the pci_dev structure itself by a previous PCI patch. A future patch will enable that feature in EDAC by utilizing the pci_dev info. The sysfs is now enabled in this patch, with a minimal set of control and attribute files for examining EDAC state and for enabling/disabling the memory and PCI operations. The Documentation for EDAC has also been updated to reflect the new state of EDAC operation. Signed-off-by:Doug Thompson <norsk5@xmisson.com> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] VFS documentation tweakJonathan Corbet
As I was looking over the get_sb() changes, I stumbled across a little mistake in the documentation updates. Unless we're getting into an interesting new object-oriented realm, I doubt that get_sb() should really return "struct int"... Signed-off-by: Jonathan Corbet <corbet@lwn.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] RCU Documentation fixUrs Thuermann
Updater should use _rcu variant of list_del(). Signed-off-by: Urs Thuermann <urs@isnogud.escape.de> Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] nfs: Update Documentation/nfsroot.txt to include dhcp, syslinux and ↵Horms
isolinux * Document the ip command a little differently to make the interaction between defaults and autoconfiguration a little clearer (I hope) * Update autoconfiguration the current set of options, including DHCP * Update the boot methods to add syslinux and isolinux, and remove dd of=/dev/fd0 which is no longer supported by linux * Add a referance to initramfs along side initrd. Should the latter and its document be removed some time soon? * Various cleanups to put the text consistently into the thrid person * Reformated a bit to fit into 80 columns a bit more nicely * Should the bootloaders documentation be removed or split into a separate documentation, it seems somewhat out of scope Signed-off-by: Horms <horms@verge.net.au> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [JFFS2][XATTR] Fix memory leak in POSIX-ACL support fs/jffs2/: make 2 functions static [MTD] NAND: Fix broken sharpsl driver [JFFS2][XATTR] Fix xd->refcnt race condition MTD: kernel-doc fixes + additions MTD: fix all kernel-doc warnings [MTD] DOC: Fixup read functions and do a little cleanup
2006-07-03Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) [Bluetooth] Add RFCOMM role switch support [Bluetooth] Allow disabling of credit based flow control [Bluetooth] Small cleanup of the L2CAP source code [Bluetooth] Use real devices for host controllers [Bluetooth] Add platform device for virtual and serial devices [Bluetooth] Add automatic sniff mode support [Bluetooth] Correct SCO buffer size on request [Bluetooth] Add suspend/resume support to the HCI USB driver [Bluetooth] Use raw mode for the Frontline sniffer device [BRIDGE]: br_dump_ifinfo index fix [ATM]: add+use poison defines [NET]: add+use poison defines [IOAT]: fix kernel-doc in source files [IOAT]: fix header file kernel-doc [TG3]: Add ipv6 TSO feature [IPV6]: Fix ipv6 GSO payload length [TIPC] Fixed sk_buff panic caused by tipc_link_bundle_buf (REVISED) [NET]: Verify gso_type too in gso_segment [IPVS]: Add sysctl documentation [ROSE]: Try all routes when establishing a ROSE connections. ...
2006-07-03Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (57 commits) [SCSI] fix error handling in scsi_io_completion [SCSI] qla1280: fix section mismatch warnings [SCSI] mptsas: eliminate ghost devices [SCSI] qla2xxx: make some more functions static [SCSI] small whitespace cleanup for qlogic driver [SCSI] mptbase: mpt_interrupt should return IRQ_NONE [SCSI] mptsas: make two functions static [SCSI] sg.c: Fix bad error handling in [SCSI] 53c700: fix breakage caused by the autosense update [SCSI] iscsi: add async notification of session events [SCSI] iscsi: pass target nr to session creation [SCSI] iscsi: break up session creation into two stages [SCSI] iscsi: rm channel usage from iscsi [SCSI] iscsi: fix session refcouting [SCSI] iscsi: convert iscsi_tcp to new set/get param fns [SCSI] iscsi: convert iser to new set/get param fns [SCSI] iscsi: fixup set/get param functions [SCSI] iscsi: add target discvery event to transport class [SCSI] st: remove unused st_buffer.in_use [SCSI] atp870u: reduce huge stack usage ...
2006-07-03[IPVS]: Add sysctl documentationHorms
* Derived from http://www.linuxvirtualserver.org/docs/sysctl.html, v1.4 maintained by Wensong Zhang * Adjusted preample to match ip-sysctl.txt * Sorted options into alphabetical order * Added expire_quiescent_template * Removed timeout_* which are no longer present * Incoporated doc/debug-levels.txt from IPVS source tree into description of ipvs_debug * Minor spelling fixes * Further editing more than welcome Signed-Off-By: Horms <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: powerpc: add defconfig for Freescale MPC8349E-mITX board powerpc: Add base support for the Freescale MPC8349E-mITX eval board Documentation: correct values in MPC8548E SEC example node [POWERPC] Actually copy over i8259.c to arch/ppc/syslib this time [POWERPC] Add new interrupt mapping core and change platforms to use it [POWERPC] Copy i8259 code back to arch/ppc [POWERPC] New device-tree interrupt parsing code [POWERPC] Use the genirq framework [PATCH] genirq: Allow fasteoi handler to retrigger disabled interrupts [POWERPC] Update the SWIM3 (powermac) floppy driver [POWERPC] Fix error handling in detecting legacy serial ports [POWERPC] Fix booting on Momentum "Apache" board (a Maple derivative) [POWERPC] Fix various offb and BootX-related issues [POWERPC] Add a default config for 32-bit CHRP machines [POWERPC] fix implicit declaration on cell. [POWERPC] change get_property to return void *
2006-07-03[PATCH] lockdep: design docsIngo Molnar
Lock validator design documentation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: locking API self testsIngo Molnar
Introduce DEBUG_LOCKING_API_SELFTESTS, which uses the generic lock debugging code's silent-failure feature to run a matrix of testcases. There are 210 testcases currently: +----------------------- | Locking API testsuite: +------------------------------+------+------+------+------+------+------+ | spin |wlock |rlock |mutex | wsem | rsem | -------------------------------+------+------+------+------+------+------+ A-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-A deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-A-B-C deadlock: ok | ok | ok | ok | ok | ok | A-B-B-C-C-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-D-D-A deadlock: ok | ok | ok | ok | ok | ok | A-B-C-D-B-C-D-A deadlock: ok | ok | ok | ok | ok | ok | double unlock: ok | ok | ok | ok | ok | ok | bad unlock order: ok | ok | ok | ok | ok | ok | --------------------------------------+------+------+------+------+------+ recursive read-lock: | ok | | ok | --------------------------------------+------+------+------+------+------+ non-nested unlock: ok | ok | ok | ok | --------------------------------------+------+------+------+ hard-irqs-on + irq-safe-A/12: ok | ok | ok | soft-irqs-on + irq-safe-A/12: ok | ok | ok | hard-irqs-on + irq-safe-A/21: ok | ok | ok | soft-irqs-on + irq-safe-A/21: ok | ok | ok | sirq-safe-A => hirqs-on/12: ok | ok | ok | sirq-safe-A => hirqs-on/21: ok | ok | ok | hard-safe-A + irqs-on/12: ok | ok | ok | soft-safe-A + irqs-on/12: ok | ok | ok | hard-safe-A + irqs-on/21: ok | ok | ok | soft-safe-A + irqs-on/21: ok | ok | ok | hard-safe-A + unsafe-B #1/123: ok | ok | ok | soft-safe-A + unsafe-B #1/123: ok | ok | ok | hard-safe-A + unsafe-B #1/132: ok | ok | ok | soft-safe-A + unsafe-B #1/132: ok | ok | ok | hard-safe-A + unsafe-B #1/213: ok | ok | ok | soft-safe-A + unsafe-B #1/213: ok | ok | ok | hard-safe-A + unsafe-B #1/231: ok | ok | ok | soft-safe-A + unsafe-B #1/231: ok | ok | ok | hard-safe-A + unsafe-B #1/312: ok | ok | ok | soft-safe-A + unsafe-B #1/312: ok | ok | ok | hard-safe-A + unsafe-B #1/321: ok | ok | ok | soft-safe-A + unsafe-B #1/321: ok | ok | ok | hard-safe-A + unsafe-B #2/123: ok | ok | ok | soft-safe-A + unsafe-B #2/123: ok | ok | ok | hard-safe-A + unsafe-B #2/132: ok | ok | ok | soft-safe-A + unsafe-B #2/132: ok | ok | ok | hard-safe-A + unsafe-B #2/213: ok | ok | ok | soft-safe-A + unsafe-B #2/213: ok | ok | ok | hard-safe-A + unsafe-B #2/231: ok | ok | ok | soft-safe-A + unsafe-B #2/231: ok | ok | ok | hard-safe-A + unsafe-B #2/312: ok | ok | ok | soft-safe-A + unsafe-B #2/312: ok | ok | ok | hard-safe-A + unsafe-B #2/321: ok | ok | ok | soft-safe-A + unsafe-B #2/321: ok | ok | ok | hard-irq lock-inversion/123: ok | ok | ok | soft-irq lock-inversion/123: ok | ok | ok | hard-irq lock-inversion/132: ok | ok | ok | soft-irq lock-inversion/132: ok | ok | ok | hard-irq lock-inversion/213: ok | ok | ok | soft-irq lock-inversion/213: ok | ok | ok | hard-irq lock-inversion/231: ok | ok | ok | soft-irq lock-inversion/231: ok | ok | ok | hard-irq lock-inversion/312: ok | ok | ok | soft-irq lock-inversion/312: ok | ok | ok | hard-irq lock-inversion/321: ok | ok | ok | soft-irq lock-inversion/321: ok | ok | ok | hard-irq read-recursion/123: ok | soft-irq read-recursion/123: ok | hard-irq read-recursion/132: ok | soft-irq read-recursion/132: ok | hard-irq read-recursion/213: ok | soft-irq read-recursion/213: ok | hard-irq read-recursion/231: ok | soft-irq read-recursion/231: ok | hard-irq read-recursion/312: ok | soft-irq read-recursion/312: ok | hard-irq read-recursion/321: ok | soft-irq read-recursion/321: ok | --------------------------------+-----+---------------- Good, all 210 testcases passed! | --------------------------------+ Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: irqtrace subsystem, docsIngo Molnar
Add Documentation/irqflags-tracing.txt. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] ZVC/zone_reclaim: Leave 1% of unmapped pagecache pages for file I/OChristoph Lameter
It turns out that it is advantageous to leave a small portion of unmapped file backed pages if all of a zone's pages (or almost all pages) are allocated and so the page allocator has to go off-node. This allows recently used file I/O buffers to stay on the node and reduces the times that zone reclaim is invoked if file I/O occurs when we run out of memory in a zone. The problem is that zone reclaim runs too frequently when the page cache is used for file I/O (read write and therefore unmapped pages!) alone and we have almost all pages of the zone allocated. Zone reclaim may remove 32 unmapped pages. File I/O will use these pages for the next read/write requests and the unmapped pages increase. After the zone has filled up again zone reclaim will remove it again after only 32 pages. This cycle is too inefficient and there are potentially too many zone reclaim cycles. With the 1% boundary we may still remove all unmapped pages for file I/O in zone reclaim pass. However. it will take a large number of read and writes to get back to 1% again where we trigger zone reclaim again. The zone reclaim 2.6.16/17 does not show this behavior because we have a 30 second timeout. [akpm@osdl.org: rename the /proc file and the variable] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Documentation: correct values in MPC8548E SEC example nodeKim Phillips
Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-07-03Merge ../scsi-misc-2.6James Bottomley
Conflicts: drivers/scsi/nsp32.c drivers/scsi/pcmcia/nsp_cs.c Removal of randomness flag conflicts with SA_ -> IRQF_ global replacement. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-02[PATCH] irq-flags: documentation: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: consolidate flags for request_irqThomas Gleixner
The recent interrupt rework introduced bit value conflicts with sparc. Instead of introducing new architecture flags mess, move the interrupt SA_ flags out of the signal namespace and replace them by interrupt related flags. This allows to remove the obsolete SA_INTERRUPT flag and clean up the bit field values. This patch: Move the interrupt related SA_ flags out of linux/signal.h and rename them to IRQF_ . This moves the interrupt related flags out of the signal namespace and allows to remove the architecture dependencies. SA_INTERRUPT is not needed by userspace and glibc so it can be removed safely. The existing SA_ constants are kept for easy transition and will be removed after a 6 month grace period. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Greg KH <greg@kroah.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeff Garzik <jeff@garzik.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Karsten Keil <kkeil@suse.de> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@debian.org> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Dave Airlie <airlied@linux.ie> Cc: Jens Axboe <axboe@suse.de> Cc: Chris Zankel <chris@zankel.net> Cc: Andi Kleen <ak@muc.de> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: David Howells <dhowells@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: Remove obsolete #include <linux/config.h> remove obsolete swsusp_encrypt arch/arm26/Kconfig typos Documentation/IPMI typos Kconfig: Typos in net/sched/Kconfig v9fs: do not include linux/version.h Documentation/DocBook/mtdnand.tmpl: typo fixes typo fixes: specfic -> specific typo fixes in Documentation/networking/pktgen.txt typo fixes: occuring -> occurring typo fixes: infomation -> information typo fixes: disadvantadge -> disadvantage typo fixes: aquire -> acquire typo fixes: mecanism -> mechanism typo fixes: bandwith -> bandwidth fix a typo in the RTC_CLASS help text smb is no longer maintained Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
2006-06-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6/Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6/: [PATCH] pcmcia: fix deadlock in pcmcia_parse_events [PATCH] com20020_cs: more device support [PATCH] au1xxx: pcmcia: fix __init called from non-init [PATCH] kill open-coded offsetof in cm4000_cs.c ZERO_DEV() [PATCH] pcmcia: convert pcmcia_cs to kthread [PATCH] pcmcia: fix kernel-doc function name [PATCH] pcmcia: hostap_cs.c - 0xc00f,0x0000 conflicts with pcnet_cs [PATCH] pcmcia: at91_cf suspend/resume/wakeup [PATCH] pcmcia: Make ide_cs work with the memory space of CF-Cards if IO space is not available [PATCH] pcmcia: TI PCIxx12 CardBus controller support [PATCH] pcmcia: warn if driver requests exclusive, but gets a shared IRQ [PATCH] pcmcia: expose tool in pcmcia/Documentation/pcmcia/ [PATCH] pcmcia: another ID for serial_cs.c [PATCH] yenta: fix hidden PCI bus numbers [PATCH] yenta: do power-up only after socket is configured
2006-06-30[PATCH] pcmcia: expose tool in pcmcia/Documentation/pcmcia/Randy Dunlap
Expose example and tool source files in the Documentation/ directory in their own files instead of being buried (almost hidden) in readme/txt files. This will make them more visible/usable to users who may need to use them, to developers who may need to test with them, and to janitors who would update them if they were more visible. Also, if any of these possibly should not be in the kernel tree at all, it will be clearer that they are here and we can discuss if they should be removed. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2006-06-30V4L/DVB (4285): Cx88: add support for Geniatech Digistar / Digiwave 103gSaqeb Akhter
This patch adds support for the Geniatech Digistar, aka Digiwave 103g DVB-S card. Acked-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Saqeb Akhter <johoja@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-30[PATCH] Documentation/IPMI typosMatt LaPlante
Two typos in Documentation/IPMI. Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30[PATCH] zoned vm counters: zone_reclaim: remove ↵Christoph Lameter
/proc/sys/vm/zone_reclaim_interval The zone_reclaim_interval was necessary because we were not able to determine how many unmapped pages exist in a zone. Therefore we had to scan in intervals to figure out if any pages were unmapped. With the zoned counters and NR_ANON_PAGES we now know the number of pagecache pages and the number of mapped pages in a zone. So we can simply skip the reclaim if there is an insufficient number of unmapped pages. We use SWAP_CLUSTER_MAX as the boundary. Drop all support for /proc/sys/vm/zone_reclaim_interval. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-30Documentation/IPMI typosMatt LaPlante
Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-30Documentation/DocBook/mtdnand.tmpl: typo fixesPatrick Pletscher
2006-06-30typo fixes in Documentation/networking/pktgen.txtAdrian Bunk
Three typos in only one line... Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-30typo fixes: occuring -> occurringAdrian Bunk
2006-06-30typo fixes: disadvantadge -> disadvantageAdrian Bunk
2006-06-30typo fixes: aquire -> acquireAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-29Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: ocfs2: remove redundant NULL checks in ocfs2_direct_IO_get_blocks() ocfs2: clean up some osb fields ocfs2: fix init of uuid_net_key ocfs2: silence a debug print ocfs2: silence ENOENT during lookup of broken links ocfs2: Cleanup message prints ocfs2: silence -EEXIST from ocfs2_extent_map_insert/lookup [PATCH] fs/ocfs2/dlm/dlmrecovery.c: make dlm_lockres_master_requery() static ocfs2: warn the user on a dead timeout mismatch ocfs2: OCFS2_FS must depend on SYSFS ocfs2: Compile-time disabling of ocfs2 debugging output. configfs: Clear up a few extra spaces where there should be TABs. configfs: Release memory in configfs_example.
2006-06-29configfs: Release memory in configfs_example.Joel Becker
The configfs_example module was missing a ->release(). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-29Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (33 commits) [MIPS] Add missing backslashes to macro definitions. [MIPS] Death list of board support to be removed after 2.6.18. [MIPS] Remove BSD and Sys V compat data types. [MIPS] ioc3.h: Uses u8, so include <linux/types.h>. [MIPS] 74K: Assume it will also have an AR bit in config7 [MIPS] Treat CPUs with AR bit as physically indexed. [MIPS] Oprofile: Support VSMP on 34K. [MIPS] MIPS32/MIPS64 S-cache fix and cleanup [MIPS] excite: PCI makefile needs to use += if it wants a chance to work. [MIPS] excite: plat_setup -> plat_mem_setup. [MIPS] au1xxx: export dbdma functions [MIPS] au1xxx: dbdma, no sleeping under spin_lock [MIPS] au1xxx: fix PSC_SMBTXRX_RSR. [MIPS] Early printk for IP27. [MIPS] Fix handling of 0 length I & D caches. [MIPS] Typo fixes. [MIPS] MIPS32/MIPS64 secondary cache management [MIPS] Fix FIXADDR_TOP for TX39/TX49. [MIPS] Remove first timer interrupt setup in wrppmc_timer_setup() [MIPS] Fix configuration of R2 CPU features and multithreading. ...
2006-06-29[MIPS] Death list of board support to be removed after 2.6.18.Ralf Baechle
As usual fixes would be prefered. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29Remove au1x00_uart from feature-removal-schedule.txt.Ralf Baechle
The driver has been removed a while ago already. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: [ALSA] echoaudio - Remove kfree_nocheck() [ALSA] echoaudio - Fix Makefile [ALSA] Add Intel D965 board support [ALSA] Fix/add support of Realtek ALC883 / ALC888 and ALC861 codecs [ALSA] Fix a typo in echoaudio/midi.c [ALSA] snd-aoa: enable dual-edge in GPIOs [ALSA] snd-aoa: support iMac G5 iSight [ALSA] snd-aoa: not experimental [ALSA] Add echoaudio sound drivers [ALSA] ak4xxx-adda - Code clean-up [ALSA] Remove CONFIG_EXPERIMENTAL from intel8x0m driver [ALSA] Stereo controls for M-Audio Revolution cards [ALSA] Fix misuse of __list_add() in seq_ports.c [ALSA] hda-codec - Add model entry for Samsung X60 Chane [ALSA] make CONFIG_SND_DYNAMIC_MINORS non-experimental [ALSA] Fix wrong dependencies of snd-aoa driver [ALSA] fix build failure due to snd-aoa [ALSA] AD1888 mixer controls for DC mode [ALSA] Suppress irq handler mismatch messages in ALSA ISA drivers [ALSA] usb-audio support for Turtle Beach Roadie
2006-06-29Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (28 commits) [S390] rework of channel measurement facility. [S390] appldata enhancements. [S390] Add vmpanic parameter. [S390] add PAV support to the dasd driver. [S390] remove export of sys_call_table [S390] remove unused macros from binfmt_elf32.c [S390] fix duplicate export of overflow{ug}id [S390] cio chpid offline. [S390] avenrun export in appdata_base.c Convert s390_collect_crw_info() in s390mach.c from being started [S390] dasd eer data format. [S390] preempt_count initialization. [S390] head.S code moving. [S390] dasd whitespace and other cosmetics. [S390] virtual cpu accounting vs. machine checks. [S390] add __cpuinit to appldata cpu hotplug notifier. [S390] dasd_eckd_dump_sense bug. [S390] missing check in dasd_eer_open. [S390] modular 3270 driver. [S390] console_unblank woes. ...
2006-06-29[PATCH] genirq: irq: document what an IRQ isEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Rajesh Shah <rajesh.shah@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: "Protasevich, Natalie" <Natalie.Protasevich@UNISYS.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: doc: add design documentationThomas Gleixner
Add docbook file - includes API documentation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] Keys: Allow in-kernel key requestor to pass auxiliary data to upcallerDavid Howells
The proposed NFS key type uses its own method of passing key requests to userspace (upcalling) rather than invoking /sbin/request-key. This is because the responsible userspace daemon should already be running and will be contacted through rpc_pipefs. This patch permits the NFS filesystem to pass auxiliary data to the upcall operation (struct key_type::request_key) so that the upcaller can use a pre-existing communications channel more easily. Signed-off-by: David Howells <dhowells@redhat.com> Acked-By: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[S390] Add vmpanic parameter.Peter Oberparleiter
Implementation of new kernel parameter vmpanic that provides a means to perform a z/VM CP command after a kernel panic occurred. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-06-29MTD: kernel-doc fixes + additionsRandy Dunlap
Fix some kernel-doc typos/spellos. Use kernel-doc syntax in places where it was almost used. Correct/add struct, struct field, and function param names where needed. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-29MTD: fix all kernel-doc warningsRandy Dunlap
Fix all kernel-doc warnings in MTD headers and source files: - add some missing struct fields; - correct some function parameter names; - use kernel-doc format for function doc. headers; - nand_ecc.c contains only exported interfaces, no internal ones; Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-28Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] Documentation/watchdog update [WATCHDOG] convert AT91RM9200 watchdog to platform driver [WATCHDOG] add WDIOC_GETTIMELEFT ioctl [WATCHDOG] Pre-Timeout flags
2006-06-28[PATCH] Add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPLArjan van de Ven
Temporarily add EXPORT_UNUSED_SYMBOL and EXPORT_UNUSED_SYMBOL_GPL. These will be used as a transition measure for symbols that aren't used in the kernel and are on the way out. When a module uses such a symbol, a warning is printk'd at modprobe time. The main reason for removing unused exports is size: eacho export takes roughly between 100 and 150 bytes of kernel space in the binary. This patch gives users the option to immediately get this size gain via a config option. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[WATCHDOG] Documentation/watchdog updateRandy Dunlap
Documentation/watchdog/: Expose example and tool source files in the Documentation/ directory in their own files instead of being buried (almost hidden) in readme/txt files. This will make them more visible/usable to users who may need to use them, to developers who may need to test with them, and to janitors who would update them if they were more visible. Also, if any of these possibly should not be in the kernel tree at all, it will be clearer that they are here and we can discuss if they should be removed. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-06-28Merge ../linux-2.6/James Bottomley
Conflicts: drivers/scsi/aacraid/comminit.c Fixed up by removing the now renamed CONFIG_IOMMU option from aacraid Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-28[ALSA] Fix/add support of Realtek ALC883 / ALC888 and ALC861 codecsTakashi Iwai
Patch from Realtek: - Fix ALC883 support code - Add support of ALC888 codec - Add ALC660 support (ALC861-compatible) - Add HP xw4400/6400/8400/9400 support (model=hp-bpc) - Code clean-up: fix spaces and indentation Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
