The first bit/value table inside the document is very
hard to read and won't fit ReST format. Also, some columns aren't
properly aligned.
Convert it to a nice ascii artwork table with makes it easier to
read as plain text and is compatible with ReST format parser
on Sphinx.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
memory.stat and other files already consider subtrees in their output, and
we should too in order to not present an inconsistent interface.
The current situation is fairly confusing, because people interacting with
cgroups expect hierarchical behaviour in the vein of memory.stat,
cgroup.events, and other files. For example, this causes confusion when
debugging reclaim events under low, as currently these always read "0" at
non-leaf memcg nodes, which frequently causes people to misdiagnose breach
behaviour. The same confusion applies to other counters in this file when
debugging issues.
Aggregation is done at write time instead of at read-time since these
counters aren't hot (unlike memory.stat which is per-page, so it does it
at read time), and it makes sense to bundle this with the file
notifications.
After this patch, events are propagated up the hierarchy:
[root@ktst ~]# cat /sys/fs/cgroup/system.slice/memory.events
low 0
high 0
max 0
oom 0
oom_kill 0
[root@ktst ~]# systemd-run -p MemoryMax=1 true
Running as unit: run-r251162a189fb4562b9dabfdc9b0422f5.service
low 0
high 0
max 7
oom 1
oom_kill 1
As this is a change in behaviour, this can be reverted to the old
behaviour by mounting with the `memory_localevents' flag set. However, we
use the new behaviour by default as there's a lack of evidence that there
are any current users of memory.events that would find this change
undesirable.
akpm: this is a behaviour change, so Cc:stable. THis is so that
forthcoming distros which use cgroup v2 are more likely to pick up the
revised behaviour.
Link: http://lkml.kernel.org/r/20190208224419.GA24772@chrisdown.name
Signed-off-by: Chris Down <chris@chrisdown.name>
Reviewed-by: Shakeel Butt <shakeelb@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Roman Gushchin <guro@fb.com>
Cc: Dennis Zhou <dennis@kernel.org>
Cc: Suren Baghdasaryan <surenb@google.com>
Cc: <stable@vger.kernel.org>
Fix Sphinx warnings in Documentation/vm/hmm.rst by using "::" notation and
inserting a blank line. Also add a missing ';'.
Documentation/vm/hmm.rst:292: WARNING: Unexpected indentation.
Documentation/vm/hmm.rst:300: WARNING: Unexpected indentation.
Link: http://lkml.kernel.org/r/c5995359-7c82-4e47-c7be-b58a4dda0953@infradead.org
Fixes: 023a019a9b4e ("mm/hmm: add default fault flags to avoid the need to pre-fill pfns arrays")
Reviewed-by: Jérôme Glisse <jglisse@redhat.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some tiny USB fixes for a number of reported issues for
5.2-rc3.
Nothing huge here, just a small collection of xhci and other driver
bugs that syzbot has been finding in some drivers. There is also a
usbip fix and a fix for the usbip fix in here :)
All have been in linux-next with no reported issues"
* tag 'usb-5.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usbip: usbip_host: fix stub_dev lock context imbalance regression
media: smsusb: better handle optional alignment
xhci: Use %zu for printing size_t type
xhci: Convert xhci_handshake() to use readl_poll_timeout_atomic()
xhci: Fix immediate data transfer if buffer is already DMA mapped
usb: xhci: avoid null pointer deref when bos field is NULL
usb: xhci: Fix a potential null pointer dereference in xhci_debugfs_create_endpoint()
xhci: update bounce buffer with correct sg num
media: usb: siano: Fix false-positive "uninitialized variable" warning
USB: rio500: update Documentation
USB: rio500: simplify locking
USB: rio500: fix memory leak in close after disconnect
USB: rio500: refuse more than one device at a time
usbip: usbip_host: fix BUG: sleeping function called from invalid context
USB: sisusbvga: fix oops in error path of sisusb_probe
USB: Add LPM quirk for Surface Dock GigE adapter
media: usb: siano: Fix general protection fault in smsusb
usb: mtu3: fix up undefined reference to usb_debug_root
USB: Fix slab-out-of-bounds write in usb_get_bos_descriptor
Pull networking fixes from David Miller:
1) Fix OOPS during nf_tables rule dump, from Florian Westphal.
2) Use after free in ip_vs_in, from Yue Haibing.
3) Fix various kTLS bugs (NULL deref during device removal resync,
netdev notification ignoring, etc.) From Jakub Kicinski.
4) Fix ipv6 redirects with VRF, from David Ahern.
5) Memory leak fix in igmpv3_del_delrec(), from Eric Dumazet.
6) Missing memory allocation failure check in ip6_ra_control(), from
Gen Zhang. And likewise fix ip_ra_control().
7) TX clean budget logic error in aquantia, from Igor Russkikh.
8) SKB leak in llc_build_and_send_ui_pkt(), from Eric Dumazet.
9) Double frees in mlx5, from Parav Pandit.
10) Fix lost MAC address in r8169 during PCI D3, from Heiner Kallweit.
11) Fix botched register access in mvpp2, from Antoine Tenart.
12) Use after free in napi_gro_frags(), from Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (89 commits)
net: correct zerocopy refcnt with udp MSG_MORE
ethtool: Check for vlan etype or vlan tci when parsing flow_rule
net: don't clear sock->sk early to avoid trouble in strparser
net-gro: fix use-after-free read in napi_gro_frags()
net: dsa: tag_8021q: Create a stable binary format
net: dsa: tag_8021q: Change order of rx_vid setup
net: mvpp2: fix bad MVPP2_TXQ_SCHED_TOKEN_CNTR_REG queue value
ipv4: tcp_input: fix stack out of bounds when parsing TCP options.
mlxsw: spectrum: Prevent force of 56G
mlxsw: spectrum_acl: Avoid warning after identical rules insertion
net: dsa: mv88e6xxx: fix handling of upper half of STATS_TYPE_PORT
r8169: fix MAC address being lost in PCI D3
net: core: support XDP generic on stacked devices.
netvsc: unshare skb in VF rx handler
udp: Avoid post-GRO UDP checksum recalculation
net: phy: dp83867: Set up RGMII TX delay
net: phy: dp83867: do not call config_init twice
net: phy: dp83867: increase SGMII autoneg timer duration
net: phy: dp83867: fix speed 10 in sgmii mode
net: phy: marvell10g: report if the PHY fails to boot firmware
Pull documentation fixes from Jonathan Corbet:
"The Sphinx 2.0 release contained a few incompatible API changes that
broke our extensions and, thus, the documentation build in general.
Who knew that those deprecation warnings it was outputting actually
meant we should change something? This set of fixes makes the build
work again with Sphinx 2.0 and eliminates the warnings for 1.8. As
part of that, we also need a few fixes to the docs for places where
the new Sphinx is more strict.
It is a bit late in the cycle for this kind of change, but it does fix
problems that people are experiencing now.
There has been some talk of raising the minimum version of Sphinx we
support. I don't want to do that abruptly, though, so these changes
add some glue to continue to support versions back to 1.3. We will be
adding some infrastructure soon to nudge users of old versions
forward, with the idea of maybe increasing our minimum version (and
removing this glue) sometime in the future"
* tag 'docs-5.2-fixes2' of git://git.lwn.net/linux:
drm/i915: Maintain consistent documentation subsection ordering
scripts/sphinx-pre-install: make it handle Sphinx versions
docs: Fix conf.py for Sphinx 2.0
docs: fix multiple doc build warnings in enumeration.rst
lib/list_sort: fix kerneldoc build error
docs: fix numaperf.rst and add it to the doc tree
doc: Cope with the deprecation of AutoReporter
doc: Cope with Sphinx logging deprecations
Both sysfs-bus-mdio and sysfs-class-net-phydev contain the same
duplication information. There is not currently any MDIO bus specific
attribute, but there are PHY device (struct phy_device) specific
attributes. Use the more precise description from sysfs-bus-mdio and
carry that over to sysfs-class-net-phydev.
Fixes: 86f22d04dfb5 ("net: sysfs: Document PHY device sysfs attributes")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull Devicetree fixes from Rob Herring:
- Update checkpatch.pl to use DT vendor-prefixes.yaml
- Fix DT binding references to files converted to DT schema
- Clean-up Arm CPU binding examples to match schema
- Add Sifive block versioning scheme documentation
- Pass binding directory base to validation tools for reference lookups
* tag 'devicetree-fixes-for-5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
checkpatch.pl: Update DT vendor prefix check
dt: bindings: mtd: replace references to nand.txt with nand-controller.yaml
dt-bindings: interrupt-controller: arm,gic: Fix schema errors in example
dt-bindings: arm: Clean up CPU binding examples
dt: fix refs that were renamed to json with the same file name
dt-bindings: Pass binding directory to validation tools
dt-bindings: sifive: describe sifive-blocks versioning
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull more arm64 fixes from Will Deacon:
- Fix incorrect LDADD instruction encoding in our disassembly macros
- Disable the broken ARM64_PSEUDO_NMI support for now
- Add workaround for Cortex-A76 CPU erratum #1463225
- Handle Cortex-A76/Neoverse-N1 erratum #1418040 w/ existing workaround
- Fix IORT build failure if IOMMU_SUPPORT=n
- Fix place-relative module relocation range checking and its
interaction with KASLR
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: insn: Add BUILD_BUG_ON() for invalid masks
arm64: insn: Fix ldadd instruction encoding
arm64: Kconfig: Make ARM64_PSEUDO_NMI depend on BROKEN for now
arm64: Handle erratum 1418040 as a superset of erratum 1188873
arm64/module: deal with ambiguity in PRELxx relocation ranges
ACPI/IORT: Fix build error when IOMMU_SUPPORT is disabled
arm64/kernel: kaslr: reduce module randomization range to 2 GB
arm64: errata: Add workaround for Cortex-A76 erratum #1463225
arm64: Remove useless message during oops
Our version check in Documentation/conf.py never envisioned a world where
Sphinx moved beyond 1.x. Now that the unthinkable has happened, fix our
version check to handle higher version numbers correctly.
Cc: stable@vger.kernel.org
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
The conversion of acpi/enumeration.txt to RST included one markup error,
leading to many warnings like:
.../firmware-guide/acpi/enumeration.rst:430: WARNING: Unexpected indentation.
Add the missing colon and create some peace.
Fixes: c24bc66e8157 ("Documentation: ACPI: move enumeration.txt to firmware-guide/acpi and convert to reST")
Cc: Changbin Du <changbin.du@gmail.com>
Commit 13bac55ef7ae ("doc/mm: New documentation for memory performance")
added numaperf.rst, but did not add it to the TOC tree. There was also an
incorrectly marked literal block leading to this warning sequence:
numaperf.rst:24: WARNING: Unexpected indentation.
numaperf.rst:24: WARNING: Inline substitution_reference start-string without end-string.
numaperf.rst:25: WARNING: Block quote ends without a blank line; unexpected unindent.
Fix the block and add the file to the document tree.
Fixes: 13bac55ef7ae ("doc/mm: New documentation for memory performance")
Cc: Keith Busch <keith.busch@intel.com>
AutoReporter is going away; recent versions of sphinx emit a warning like:
Documentation/sphinx/kerneldoc.py:125:
RemovedInSphinx20Warning: AutodocReporter is now deprecated.
Use sphinx.util.docutils.switch_source_input() instead.
Make the switch. But switch_source_input() only showed up in 1.7, so we
have to do ugly version checks to keep things working in older versions.
Recent versions of sphinx will emit messages like:
Documentation/sphinx/kerneldoc.py:103:
RemovedInSphinx20Warning: app.warning() is now deprecated.
Use sphinx.util.logging instead.
Switch to sphinx.util.logging to make this unsightly message go away.
Alas, that interface was only added in version 1.6, so we have to add a
version check to keep things working with older sphinxes.
"A handful of fixes for a docs build problem, along with catching the
spdxcheck.py script up with the current state of affairs"
* tag 'docs-5.2-fixes' of git://git.lwn.net/linux:
Documentation: kdump: fix minor typo
scripts/spdxcheck.py: Add dual license subdirectory
scripts/spdxcheck.py: Fix path to deprecated licenses
counter: fix Documentation build error due to incorrect source file name
We already mitigate erratum 1188873 affecting Cortex-A76 and
Neoverse-N1 r0p0 to r2p0. It turns out that revisions r0p0 to
r3p1 of the same cores are affected by erratum 1418040, which
has the same workaround as 1188873.
Let's expand the range of affected revisions to match 1418040,
and repaint all occurences of 1188873 to 1418040. Whilst we're
there, do a bit of reformating in silicon-errata.txt and drop
a now unnecessary dependency on ARM_ARCH_TIMER_OOL_WORKAROUND.
Revisions of the Cortex-A76 CPU prior to r4p0 are affected by an erratum
that can prevent interrupts from being taken when single-stepping.
This patch implements a software workaround to prevent userspace from
effectively being able to disable interrupts.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Describe existing kernel TLS offload (added back in Linux 4.19) -
the mechanism, the expected behavior and the notable corner cases.
This documentation is mostly targeting hardware vendors who want
to implement offload, to ensure consistency between implementations.
v2:
- add emphasis around TLS_SW/TLS_HW/TLS_HW_RECORD;
- remove mentions of ongoing work (Boris);
- split the flow of data in SW vs. HW cases in TX overview
(Boris);
- call out which fields are updated by the device and which
are filled by the stack (Boris);
- move error handling into it's own section (Boris);
- add more words about fallback (Boris);
- note that checksum validation is required (Alexei);
- note that drivers shouldn't pay attention to the TLS
device features.
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Acked-by: Dave Watson <davejwatson@fb.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Boris Pismenny <borisp@mellanox.com>
Convert the TLS doc to RST. Use C code blocks for the code
samples, and mark hyperlinks.
Some of the device drivers have really long document titles
making the networking table of contents hard to look through.
Place vendor drivers under a submenu.
1) Clear up some recent tipc regressions because of registration
ordering. Fix from Junwei Hu.
2) tipc's TLV_SET() can read past the end of the supplied buffer during
the copy. From Chris Packham.
3) ptp example program doesn't match the kernel, from Richard Cochran.
4) Outgoing message type fix in qrtr, from Bjorn Andersson.
5) Flow control regression in stmmac, from Tan Tee Min.
6) Fix inband autonegotiation in phylink, from Russell King.
7) Fix sk_bound_dev_if handling in rawv6_bind(), from Mike Manning.
8) Fix usbnet crash after disconnect, from Kloetzke Jan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (21 commits)
usbnet: fix kernel crash after disconnect
selftests: fib_rule_tests: use pre-defined DEV_ADDR
net-next: net: Fix typos in ip-sysctl.txt
ipv6: Consider sk_bound_dev_if when binding a raw socket to an address
net: phylink: ensure inband AN works correctly
usbnet: ipheth: fix racing condition
net: stmmac: dma channel control register need to be init first
net: stmmac: fix ethtool flow control not able to get/set
net: qrtr: Fix message type of outgoing packets
networking: : fix typos in code comments
ptp: Fix example program to match kernel.
fddi: fix typos in code comments
selftests: fib_rule_tests: enable forwarding before ipv4 from/iif test
selftests: fib_rule_tests: fix local IPv4 address typo
tipc: Avoid copying bytes beyond the supplied data
2/2] net: xilinx_emaclite: use readx_poll_timeout() in mdio wait function
1/2] net: axienet: use readx_poll_timeout() in mdio wait function
vlan: Mark expected switch fall-through
macvlan: Mark expected switch fall-through
net/mlx4_en: ethtool, Remove unsupported SFP EEPROM high pages query
nand-controller.yaml replaced nand.txt however the references to it were
not updated. This change updates these references wherever it appears in
bindings documentation.
Fixes: 212e49693592 ("dt-bindings: mtd: Add YAML schemas for the generic NAND options")
Signed-off-by: Kamal Dasu <kdasu.kdev@gmail.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Validating the examples against the schema have a few errors:
arm,gic.example.dt.yaml: 'ranges' does not match any of the regexes: '^v2m@[0-9a-f]+$', 'pinctrl-[0-9]+'
arm,gic.example.dt.yaml: #address-cells:0:0: 2 is not one of [0, 1]
arm,gic.example.dt.yaml: #size-cells:0:0: 1 was expected
'ranges' is valid, but missing from the schema, so add it. The reg
addresses and sizes don't match the schema requirements and the example
template. We could just override the example template to use 64-bit
addresses, but there's not really any value showing that in the example.
Cc: Jason Cooper <jason@lakedaemon.net>
Following commit 31af04cd60d3 ("arm64: dts: Remove inconsistent use of
'arm,armv8' compatible string"), clean up these binding examples in case
anyone is tempted to copy them.
CC: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
These files were converted to json-schema, but the references weren't
renamed.
Fixes: 66ed144f147a ("dt-bindings: interrupt-controller: Convert ARM GIC to json-schema")
(and other similar commits)
In order to have $ref's to schema files within the kernel, we need to
pass the base path of bindings to the schema validation tools.
Cc: Michal Marek <michal.lkml@markovi.net>
Cc: devicetree@vger.kernel.org
Cc: linux-kbuild@vger.kernel.org
For IP blocks that are generated from the public, open-source
sifive-blocks repository, describe the version numbering policy
that its maintainers intend to use, upon request from Rob
Herring <robh@kernel.org>.
Signed-off-by: Paul Walmsley <paul.walmsley@sifive.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Megan Wachs <megan@sifive.com>
Cc: Wesley Terpstra <wesley@sifive.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: linux-riscv@lists.infradead.org
This patch fixes some spelling typos found in ip-sysctl.txt
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
kdump.txt had a minor typo.
Signed-off-by: Cengiz Can <cengizc@gmail.com>
Added the newly added limit and updated the text a bit
Signed-off-by: Oliver Neukum <oneukum@suse.com>
fix accelleration to acceleration
Signed-off-by: Weitao Hou <houweitaoo@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild fixes from Masahiro Yamada:
- remove unused cc-ldoption
- do not check the name uniquness of builtin modules to avoid false
positives
* tag 'kbuild-fixes-v5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: do not check name uniqueness of builtin modules
kbuild: drop support for cc-ldoption
Fix kernel-doc build error in Documentation/driver-api/generic-counter.rst
of incorrect source file name.
Fixes this warning and error:
Error: Cannot open file ../drivers/counter/generic-counter.c
WARNING: kernel-doc '../scripts/kernel-doc -rst -enable-lineno -export ../drivers/counter/generic-counter.c' failed with return code 2
Fixes: 09e7d4ed8991 ("docs: Add Generic Counter interface documentation")
Acked-by: William Breathitt Gray <vilhelm.gray@gmail.com>
Pull networking fixes from David Miller:1) Use after free in __dev_map_entry_free(), from Eric Dumazet.
2) Fix TCP retransmission timestamps on passive Fast Open, from Yuchung
Cheng.
3) Orphan NFC, we'll take the patches directly into my tree. From
Johannes Berg.
4) We can't recycle cloned TCP skbs, from Eric Dumazet.
5) Some flow dissector bpf test fixes, from Stanislav Fomichev.
6) Fix RCU marking and warnings in rhashtable, from Herbert Xu.
7) Fix some potential fib6 leaks, from Eric Dumazet.
8) Fix a _decode_session4 uninitialized memory read bug fix that got
lost in a merge. From Florian Westphal.
9) Fix ipv6 source address routing wrt. exception route entries, from
Wei Wang.
10) The netdev_xmit_more() conversion was not done %100 properly in mlx5
driver, fix from Tariq Toukan.
11) Clean up botched merge on netfilter kselftest, from Florian
Westphal.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (74 commits)
of_net: fix of_get_mac_address retval if compiled without CONFIG_OF
net: fix kernel-doc warnings for socket.c
net: Treat sock->sk_drops as an unsigned int when printing
kselftests: netfilter: fix leftover net/net-next merge conflict
mlxsw: core: Prevent reading unsupported slave address from SFP EEPROM
mlxsw: core: Prevent QSFP module initialization for old hardware
vsock/virtio: Initialize core virtio vsock before registering the driver
net/mlx5e: Fix possible modify header actions memory leak
net/mlx5e: Fix no rewrite fields with the same match
net/mlx5e: Additional check for flow destination comparison
net/mlx5e: Add missing ethtool driver info for representors
net/mlx5e: Fix number of vports for ingress ACL configuration
net/mlx5e: Fix ethtool rxfh commands when CONFIG_MLX5_EN_RXNFC is disabled
net/mlx5e: Fix wrong xmit_more application
net/mlx5: Fix peer pf disable hca command
net/mlx5: E-Switch, Correct type to u16 for vport_num and int for vport_index
net/mlx5: Add meaningful return codes to status_to_err function
net/mlx5: Imply MLXFW in mlx5_core
Revert "tipc: fix modprobe tipc failed after switch order of device registration"
vsock/virtio: free packets during the socket release
If you want to see if your linker supports a certain flag, then ask the
linker directly with ld-option (not the compiler with cc-ldoption).
Checking for linker flag support is an antipattern that complicates the
usage of various linkers other than bfd via -fuse-ld={bfd|gold|lld}.
Cc: clang-built-linux@googlegroups.com
Suggested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Merge yet more updates from Andrew Morton:
"A few final bits:
- large changes to vmalloc, yielding large performance benefits
- tweak the console-flush-on-panic code
- a few fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
panic: add an option to replay all the printk message in buffer
initramfs: don't free a non-existent initrd
fs/writeback.c: use rcu_barrier() to wait for inflight wb switches going into workqueue when umount
mm/compaction.c: correct zone boundary handling when isolating pages from a pageblock
mm/vmap: add DEBUG_AUGMENT_LOWEST_MATCH_CHECK macro
mm/vmap: add DEBUG_AUGMENT_PROPAGATE_CHECK macro
mm/vmalloc.c: keep track of free blocks for vmap allocation
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Some I2C core API additions which are kind of simple but enhance error
checking for users a lot, especially by returning errno now.
There are wrappers to still support the old API but it will be removed
once all users are converted"
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: core: add device-managed version of i2c_new_dummy
i2c: core: improve return value handling of i2c_new_device and i2c_new_dummy
Pull clocksource updates from Ingo Molnar:
"Misc clocksource/clockevent driver updates that came in a bit late but
are ready for v5.2"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
misc: atmel_tclib: Do not probe already used TCBs
clocksource/drivers/timer-atmel-tcb: Convert tc_clksrc_suspend|resume() to static
clocksource/drivers/tcb_clksrc: Rename the file for consistency
clocksource/drivers/timer-atmel-pit: Rework Kconfig option
clocksource/drivers/tcb_clksrc: Move Kconfig option
ARM: at91: Implement clocksource selection
clocksource/drivers/tcb_clksrc: Use tcb as sched_clock
clocksource/drivers/tcb_clksrc: Stop depending on atmel_tclib
ARM: at91: move SoC specific definitions to SoC folder
clocksource/drivers/timer-milbeaut: Cleanup common register accesses
clocksource/drivers/timer-milbeaut: Add shutdown function
clocksource/drivers/timer-milbeaut: Fix to enable one-shot timer
clocksource/drivers/tegra: Rework for compensation of suspend time
clocksource/drivers/sp804: Add COMPILE_TEST to CONFIG_ARM_TIMER_SP804
clocksource/drivers/sun4i: Add a compatible for suniv
dt-bindings: timer: Add Allwinner suniv timer
Pull IRQ chip updates from Ingo Molnar:
"A late irqchips update:
- New TI INTR/INTA set of drivers
- Rewrite of the stm32mp1-exti driver as a platform driver
- Update the IOMMU MSI mapping API to be RT friendly
- A number of cleanups and other low impact fixes"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits)
iommu/dma-iommu: Remove iommu_dma_map_msi_msg()
irqchip/gic-v3-mbi: Don't map the MSI page in mbi_compose_m{b, s}i_msg()
irqchip/ls-scfg-msi: Don't map the MSI page in ls_scfg_msi_compose_msg()
irqchip/gic-v3-its: Don't map the MSI page in its_irq_compose_msi_msg()
irqchip/gicv2m: Don't map the MSI page in gicv2m_compose_msi_msg()
iommu/dma-iommu: Split iommu_dma_map_msi_msg() in two parts
genirq/msi: Add a new field in msi_desc to store an IOMMU cookie
arm64: arch_k3: Enable interrupt controller drivers
irqchip/ti-sci-inta: Add msi domain support
soc: ti: Add MSI domain bus support for Interrupt Aggregator
irqchip/ti-sci-inta: Add support for Interrupt Aggregator driver
dt-bindings: irqchip: Introduce TISCI Interrupt Aggregator bindings
irqchip/ti-sci-intr: Add support for Interrupt Router driver
dt-bindings: irqchip: Introduce TISCI Interrupt router bindings
gpio: thunderx: Use the default parent apis for {request,release}_resources
genirq: Introduce irq_chip_{request,release}_resource_parent() apis
firmware: ti_sci: Add helper apis to manage resources
firmware: ti_sci: Add RM mapping table for am654
firmware: ti_sci: Add support for IRQ management
firmware: ti_sci: Add support for RM core ops
Pull ARM SoC late updates from Olof Johansson:
"This is some material that we picked up into our tree late. Most of it
are smaller fixes and additions, some defconfig updates due to recent
development, etc.
Code-wise the largest portion is a series of PM updates for the at91
platform, and those have been in linux-next a while through the at91
tree before we picked them up"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (29 commits)
arm64: dts: sprd: Add clock properties for serial devices
Opt out of scripts/get_maintainer.pl
ARM: ixp4xx: Remove duplicated include from common.c
soc: ixp4xx: qmgr: Fix an NULL vs IS_ERR() check in probe
arm64: tegra: Disable XUSB support on Jetson TX2
arm64: tegra: Enable SMMU translation for PCI on Tegra186
arm64: tegra: Fix insecure SMMU users for Tegra186
arm64: tegra: Select ARM_GIC_PM
amba: tegra-ahb: Mark PM functions as __maybe_unused
ARM: dts: logicpd-som-lv: Fix MMC1 card detect
ARM: mvebu: drop return from void function
ARM: mvebu: prefix coprocessor operand with p
ARM: mvebu: drop unnecessary label
ARM: mvebu: fix a leaked reference by adding missing of_node_put
ARM: socfpga_defconfig: enable LTC2497
ARM: mvebu: kirkwood: remove error message when retrieving mac address
ARM: at91: sama5: make ov2640 as a module
ARM: OMAP1: ams-delta: fix early boot crash when LED support is disabled
ARM: at91: remove HAVE_FB_ATMEL for sama5 SoC as they use DRM
soc/fsl/qe: Fix an error code in qe_pin_request()
git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux
Pull RISC-V updates from Palmer Dabbelt:
"This contains an assortment of RISC-V related patches that I'd like to
target for the 5.2 merge window. Most of the patches are cleanups, but
there are a handful of user-visible changes:
- The nosmp and nr_cpus command-line arguments are now supported,
which work like normal.
- The SBI console no longer installs itself as a preferred console,
we rely on standard mechanisms (/chosen, command-line, hueristics)
instead.
- sfence_remove_sfence_vma{,_asid} now pass their arguments along to
the SBI call.
- Modules now support BUG().
- A missing sfence.vma during boot has been added. This bug only
manifests during boot.
- The arch/riscv support for SiFive's L2 cache controller has been
merged, which should un-block the EDAC framework work.
I've only tested this on QEMU again, as I didn't have time to get
things running on the Unleashed. The latest master from this morning
merges in cleanly and passes the tests as well"
* tag 'riscv-for-linus-5.2-mw2' of git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux: (31 commits)
riscv: fix locking violation in page fault handler
RISC-V: sifive_l2_cache: Add L2 cache controller driver for SiFive SoCs
RISC-V: Add DT documentation for SiFive L2 Cache Controller
RISC-V: Avoid using invalid intermediate translations
riscv: Support BUG() in kernel module
riscv: Add the support for c.ebreak check in is_valid_bugaddr()
riscv: support trap-based WARN()
riscv: fix sbi_remote_sfence_vma{,_asid}.
riscv: move switch_mm to its own file
riscv: move flush_icache_{all,mm} to cacheflush.c
tty: Don't force RISCV SBI console as preferred console
RISC-V: Access CSRs using CSR numbers
RISC-V: Add interrupt related SCAUSE defines in asm/csr.h
RISC-V: Use tabs to align macro values in asm/csr.h
RISC-V: Fix minor checkpatch issues.
RISC-V: Support nr_cpus command line option.
RISC-V: Implement nosmp commandline option.
RISC-V: Add RISC-V specific arch_match_cpu_phys_id
riscv: vdso: drop unnecessary cc-ldoption
riscv: call pm_power_off from machine_halt / machine_power_off
Currently on panic, kernel will lower the loglevel and print out pending
printk msg only with console_flush_on_panic().
Add an option for users to configure the "panic_print" to replay all
dmesg in buffer, some of which they may have never seen due to the
loglevel setting, which will help panic debugging .
[feng.tang@intel.com: keep the original console_flush_on_panic() inside panic()]
Link: http://lkml.kernel.org/r/1556199137-14163-1-git-send-email-feng.tang@intel.com
[feng.tang@intel.com: use logbuf lock to protect the console log index]
Link: http://lkml.kernel.org/r/1556269868-22654-1-git-send-email-feng.tang@intel.com
Link: http://lkml.kernel.org/r/1556095872-36838-1-git-send-email-feng.tang@intel.com
Signed-off-by: Feng Tang <feng.tang@intel.com>
Reviewed-by: Petr Mladek <pmladek@suse.com>
Cc: Aaro Koskinen <aaro.koskinen@nokia.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: Borislav Petkov <bp@suse.de>
Pull KVM updates from Paolo Bonzini:
"ARM:
- support for SVE and Pointer Authentication in guests
- PMU improvements
POWER:
- support for direct access to the POWER9 XIVE interrupt controller
- memory and performance optimizations
x86:
- support for accessing memory not backed by struct page
- fixes and refactoring
Generic:
- dirty page tracking improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (155 commits)
kvm: fix compilation on aarch64
Revert "KVM: nVMX: Expose RDPMC-exiting only when guest supports PMU"
kvm: x86: Fix L1TF mitigation for shadow MMU
KVM: nVMX: Disable intercept for FS/GS base MSRs in vmcs02 when possible
KVM: PPC: Book3S: Remove useless checks in 'release' method of KVM device
KVM: PPC: Book3S HV: XIVE: Fix spelling mistake "acessing" -> "accessing"
KVM: PPC: Book3S HV: Make sure to load LPID for radix VCPUs
kvm: nVMX: Set nested_run_pending in vmx_set_nested_state after checks complete
tests: kvm: Add tests for KVM_SET_NESTED_STATE
KVM: nVMX: KVM_SET_NESTED_STATE - Tear down old EVMCS state before setting new state
tests: kvm: Add tests for KVM_CAP_MAX_VCPUS and KVM_CAP_MAX_CPU_ID
tests: kvm: Add tests to .gitignore
KVM: Introduce KVM_CAP_MANUAL_DIRTY_LOG_PROTECT2
KVM: Fix kvm_clear_dirty_log_protect off-by-(minus-)one
KVM: Fix the bitmap range to copy during clear dirty
KVM: arm64: Fix ptrauth ID register masking logic
KVM: x86: use direct accessors for RIP and RSP
KVM: VMX: Use accessors for GPRs outside of dedicated caching logic
KVM: x86: Omit caching logic for always-available GPRs
kvm, x86: Properly check whether a pfn is an MMIO or not
i2c_new_dummy is typically called from the probe function of the
driver for the primary i2c client. It requires calls to
i2c_unregister_device in the error path of the probe function and
in the remove function.
This can be simplified by introducing a device-managed version.
Note the changed error case return value type: i2c_new_dummy returns
NULL whilst devm_i2c_new_dummy_device returns an ERR_PTR.
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
[wsa: rename new functions and fix minor kdoc issues]
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Peter Rosin <peda@axentia.se>
Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com>
Reviewed-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Add device tree bindings for SiFive FU540 L2 cache controller driver
Signed-off-by: Yash Shah <yash.shah@sifive.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Palmer Dabbelt <palmer@sifive.com>
Pull Devicetree vendor prefix conversion from Rob Herring:
"Conversion of vendor-prefixes.txt to json-schema"
* tag 'devicetree-for-5.2-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
dt-bindings: Convert vendor prefixes to json-schema
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull misc AFS fixes from David Howells:
"This fixes a set of miscellaneous issues in the afs filesystem,
including:
- leak of keys on file close.
- broken error handling in xattr functions.
- missing locking when updating VL server list.
- volume location server DNS lookup whereby preloaded cells may not
ever get a lookup and regular DNS lookups to maintain server lists
consume power unnecessarily.
- incorrect error propagation and handling in the fileserver
iteration code causes operations to sometimes apparently succeed.
- interruption of server record check/update side op during
fileserver iteration causes uninterruptible main operations to fail
unexpectedly.
- callback promise expiry time miscalculation.
- over invalidation of the callback promise on directories.
- double locking on callback break waking up file locking waiters.
- double increment of the vnode callback break counter.
Note that it makes some changes outside of the afs code, including:
- an extra parameter to dns_query() to allow the dns_resolver key
just accessed to be immediately invalidated. AFS is caching the
results itself, so the key can be discarded.
- an interruptible version of wait_var_event().
- an rxrpc function to allow the maximum lifespan to be set on a
call.
- a way for an rxrpc call to be marked as non-interruptible"
* tag 'afs-fixes-20190516' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
afs: Fix double inc of vnode->cb_break
afs: Fix lock-wait/callback-break double locking
afs: Don't invalidate callback if AFS_VNODE_DIR_VALID not set
afs: Fix calculation of callback expiry time
afs: Make dynamic root population wait uninterruptibly for proc_cells_lock
afs: Make some RPC operations non-interruptible
rxrpc: Allow the kernel to mark a call as being non-interruptible
afs: Fix error propagation from server record check/update
afs: Fix the maximum lifespan of VL and probe calls
rxrpc: Provide kernel interface to set max lifespan on a call
afs: Fix "kAFS: AFS vnode with undefined type 0"
afs: Fix cell DNS lookup
Add wait_var_event_interruptible()
dns_resolver: Allow used keys to be invalidated
afs: Fix afs_cell records to always have a VL server list record
afs: Fix missing lock when replacing VL server list
afs: Fix afs_xattr_get_yfs() to not try freeing an error value
afs: Fix incorrect error handling in afs_xattr_get_acl()
afs: Fix key leak in afs_release() and afs_evict_inode()
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper updates from Mike Snitzer:
- Improve DM snapshot target's scalability by using finer grained
locking. Requires some list_bl interface improvements.
- Add ability for DM integrity to use a bitmap mode, that tracks
regions where data and metadata are out of sync, instead of using a
journal.
- Improve DM thin provisioning target to not write metadata changes to
disk if the thin-pool and associated thin devices are merely
activated but not used. This avoids metadata corruption due to
concurrent activation of thin devices across different OS instances
(e.g. split brain scenarios, which ultimately would be avoided if
proper device filters were used -- but not having proper filtering
has proven a very common configuration mistake)
- Fix missing call to path selector type->end_io in DM multipath. This
fixes reported performance problems due to inaccurate path selector
IO accounting causing an imbalance of IO (e.g. avoiding issuing IO to
particular path due to it seemingly being heavily used).
- Fix bug in DM cache metadata's loading of its discard bitset that
could lead to all cache blocks being discarded if the very first
cache block was discarded (thankfully in practice the first cache
block is generally in use; be it FS superblock, partition table, disk
label, etc).
- Add testing-only DM dust target which simulates a device that has
failing sectors and/or read failures.
- Fix a DM init error path reference count hang that caused boot hangs
if user supplied malformed input on kernel commandline.
- Fix a couple issues with DM crypt target's logging being overly
verbose or lacking context.
- Various other small fixes to DM init, DM multipath, DM zoned, and DM
crypt.
* tag 'for-5.2/dm-changes-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: (42 commits)
dm: fix a couple brace coding style issues
dm crypt: print device name in integrity error message
dm crypt: move detailed message into debug level
dm ioctl: fix hang in early create error condition
dm integrity: whitespace, coding style and dead code cleanup
dm integrity: implement synchronous mode for reboot handling
dm integrity: handle machine reboot in bitmap mode
dm integrity: add a bitmap mode
dm integrity: introduce a function add_new_range_and_wait()
dm integrity: allow large ranges to be described
dm ingerity: pass size to dm_integrity_alloc_page_list()
dm integrity: introduce rw_journal_sectors()
dm integrity: update documentation
dm integrity: don't report unused options
dm integrity: don't check null pointer before kvfree and vfree
dm integrity: correctly calculate the size of metadata area
dm dust: Make dm_dust_init and dm_dust_exit static
dm dust: remove redundant unsigned comparison to less than zero
dm mpath: always free attached_handler_name in parse_path()
dm init: fix max devices/targets checks
Convert the vendor prefix registry to a schema. This will enable checking
that new vendor prefixes are added (in addition to the less than perfect
checkpatch.pl check) and will also check against adding other prefixes
which are not vendors.
Converted vendor-prefixes.txt using the following sed script:
sed -e 's/\([a-zA-Z0-9\-]*\)[[:space:]]*\([a-zA-Z0-9].*\)/ "^\1,\.\*\":\n description: \2/'
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Some fixes for some platform drivers (rockchip, atmel, omap, daVinci,
tegra-cec, coda and rcar).
Also includes a fix on one of the V4L2 uAPI doc, explaining a border
case"
* tag 'media/v5.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
media: rockchip/vpu: Fix/re-order probe-error/remove path
media: rockchip/vpu: Initialize mdev->bus_info
media: rockchip/vpu: Get vdev from the file arg in vidioc_querycap()
media: rockchip/vpu: Add missing dont_use_autosuspend() calls
media: rockchip/vpu: Do not request id 0 for our video device
media: tegra-cec: fix cec_notifier_parse_hdmi_phandle return check
media: davinci/vpbe: array underflow in vpbe_enum_outputs()
media: field-order.rst: clarify FIELD_ANY and FIELD_NONE
media: staging/imx: add media device to capture register
media: rcar-csi2: Propagate the FLD signal for NTSC and PAL
media: rcar-csi2: restart CSI-2 link if error is detected
media: omap_vout: potential buffer overflow in vidioc_dqbuf()
media: coda: fix unset field and fail on invalid field in buf_prepare
media: atmel: atmel-isc: fix asd memory allocation
media: atmel: atmel-isc: fix INIT_WORK misplacement
media: atmel: atmel-isc: limit incoming pixels per frame
