path: root/Documentation
2007-02-09devres: device resource managementTejun Heo
Implement device resource management, in short, devres. A device driver can allocate arbirary size of devres data which is associated with a release function. On driver detach, release function is invoked on the devres data, then, devres data is freed. devreses are typed by associated release functions. Some devreses are better represented by single instance of the type while others need multiple instances sharing the same release function. Both usages are supported. devreses can be grouped using devres group such that a device driver can easily release acquired resources halfway through initialization or selectively release resources (e.g. resources for port 1 out of 4 ports). This patch adds devres core including documentation and the following managed interfaces. * alloc/free : devm_kzalloc(), devm_kzfree() * IO region : devm_request_region(), devm_release_region() * IRQ : devm_request_irq(), devm_free_irq() * DMA : dmam_alloc_coherent(), dmam_free_coherent(), dmam_declare_coherent_memory(), dmam_pool_create(), dmam_pool_destroy() * PCI : pcim_enable_device(), pcim_pin_device(), pci_is_managed() * iomap : devm_ioport_map(), devm_ioport_unmap(), devm_ioremap(), devm_ioremap_nocache(), devm_iounmap(), pcim_iomap_table(), pcim_iomap(), pcim_iounmap() Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: ieee1394: fix host device registering when nodemgr disabled ieee1394: video1394: DMA fix ieee1394: raw1394: prevent unloading of low-level driver ieee1394: dv1394: tidy up card removal ieee1394: dv1394: fix CardBus card ejection ieee1394: sbp2: lower block queue alignment requirement ieee1394: sbp2: remove bogus "emulated" host flag ieee1394: save one word in struct hpsb_host ieee1394: restore config ROM when resuming ieee1394: ohci1394: drop pcmcia-cs compatibility code ieee1394: nodemgr: check info_length in ROM header earlier the scheduled IEEE1394_OUI_DB removal the scheduled IEEE1394_EXPORT_FULL_API removal ieee1394: sbp2: use a better wildcard for blacklist Add PCI class ID for firewire OHCI controllers. ieee1394: modified csr1212_key_id_type_map to support lisight
2007-02-09Merge branch 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: (212 commits) [PATCH] Fix breakage with CONFIG_SYSFS_DEPRECATED [ALSA] version 1.0.14rc2 [ALSA] ASoC documentation updates [ALSA] ca0106 - Add missing sysfs device assignment [ALSA] aoa i2sbus: Stop Apple i2s DMA gracefully [ALSA] hda-codec - Add support for Fujitsu PI1556 Realtek ALC880 [ALSA] aoa: remove suspend/resume printks [ALSA] Fix possible deadlocks in sequencer at removal of ports [ALSA] emu10k1 - Fix STAC9758 front channel [ALSA] soc - Clean up with kmemdup() [ALSA] snd-ak4114: Fix two array overflows [ALSA] ac97_bus power management [ALSA] usbaudio - Add support for Edirol UA-101 [ALSA] hda-codec - Add ALC861VD/ALC660VD support [ALSA] soc - ASoC 0.13 Sharp poodle machine [ALSA] soc - ASoC 0.13 Sharp tosa machine [ALSA] soc - ASoC 0.13 spitz machine [ALSA] soc - ASoC Sharp corgi machine [ALSA] soc - ASoC 0.13 pxa2xx DMA [ALSA] soc - ASoC 0.13 pxa2xx AC97 driver ...
2007-02-09[PATCH] mm: remove find_trylock_pageNick Piggin
Remove find_trylock_page as per the removal schedule. Signed-off-by: Nick Piggin <npiggin@suse.de> [ Let's see if anybody screams ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[ALSA] ASoC documentation updatesLiam Girdwood
This patch updates the documentation for ASoC to reflect the recent changes in API between 0.12.x and 0.13.x Changes:- o Removed all reference to old API's. o Removed references and examples of automatic DAI config and matching. o Fixed 80 char line length on some files. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for Fujitsu PI1556 Realtek ALC880Tobin Davis
This patch adds support for the Fujitsu PI1556 laptop. Issue: Volume knob on system maxes out lower than alsamixer (0x35 vs 0x40). Everything else works, and audio quality is good at 0x35. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add ALC861VD/ALC660VD supportJakub Schmidtke
o Added ALC861VD support to patch_realtek.c under hda-intel o Added ALC660VD as a model of 861VD o Added pci quirks for Asus G1 as well as for two devices found in Realtek's driver to point at ALC660VD model (3stack-660) o Added pci quirk for Lenovo 3000 C200 - although untested, it should work with ALC861VD 3stack model o Changed preset id = 0x10ec0660 to point at new patch_alc861vd instead of patch_861 o Organised the list of presets Signed-off-by: Jakub Schmidtke <sjakub@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add HP BPC-D7000 supportKailang Yang
Add HP BPC-D7000 support. Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add snd-portman2x4 driver for Midiman Portman 2x4 MIDI deviceMatthias Koenig
snd-portman2x4 driver supports Midiman Portman 2x4 parallel port MIDI device. Signed-off-by: Matthias Koenig <mkoenig@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Documentation/sound/alsa/DocBook: typosNicolas Kaiser
Some typos in Documentation/sound/alsa/DocBook. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Fix irq handler arguments in documentsTakashi Iwai
Fixed the irq handler arguments in documents (removing pt_regs). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for Samsung Q1 UltraTobin Davis
This adds support for the Samsung Q1 Ultra tablet pc. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for Sigmatel STAC9202/9250/9251 codecsTobin Davis
This patch adds support for Gateway laptops based on the Sigmatel STAC9250 codecs, as well as basic support for STAC9202/9250/9251 codecs. Some Gateway systems require probe_mask=1 to work. More work to be done prior to alsa 1.0.14 final. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Fix typo and add entry to documentationTobin Davis
This patch adds the macpro and fixes a typo in the ALC882 section of ALSA-Configuration.txt. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add description about spdif_aclink option for snd-intel8x0Takashi Iwai
Added a description about spdif_aclink option for snd-intel8x0 driver in ALSA-Configuration.txt. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Use snd_pci_quirk_lookup() for board config lookupTakashi Iwai
Use snd_pci_quirk_lookup() for looking up a board config table. The config table is sorted in numerical order of PCI SSIDs. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Fix documentation of ASoCTakashi Iwai
Fixed obsolete *_t typedefs in ASoC documentation. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add asus-laptop model for ALC861 (ALC660)Takashi Iwai
Added a new model 'asus-laptop' for ASUS F2*/F3* laptops with ALC861 (equivalent with ALC660) codec chip. Also fixed the model for PCI SSID 1043:1338. Corresponding to ALSA bug#2480. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] make sound/core/control.c:snd_ctl_new() staticAdrian Bunk
Now that everyone uses snd_ctl_new1() and noone is using snd_ctl_new() anymore, we can make it static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] atiixp - Add a parameter ac97_quirkDan Carpenter
Add an option to specify the AC'97 codec instead of probing. This is a fix for bugzilla #7467. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for Sony UX-90sTakashi Iwai
Added the model entry (model=hippo) for Sony UX-90s with ALC262 codec. Although the device has no SPDIF output, the hippo model adds a PCM output, but it must be harmless. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] Add Conexant audio support to the HD Audio driverTobin Davis
This driver adds limited support for the Conexant 5045 and 5047 HD Audio codecs. Some issues still need to be resolved. The code is based primarily on code from the Analog Devices AD1981 support and the Realtek ALC260 support. Some code came from the original code developed by Alex Pototskiy (see alsa bugtracker 2485). Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ice1724 - Add support of M-Audio Audiophile 192Takashi Iwai
Added the (experimental) support of M-Audio Audiophile 192 board. Currently, the analog and the digital playbacks seem working fine. The inputs seem not working as far as I've tested yet. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Clevo M540JE, M550JE laptops (Nvidia MCP51 chipset, ↵Andrew L. Neporada
ALC883 codec) We need to enable External Amplifier on this laptops. This patch basicly adds laptop-eapd model to ALC883 codec. Signed-off-by: Andrew L. Neporada <nepal@asplinux.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add asus model to ALC861 codecMariusz Domanski
This patch adds support for Asus laptops (for example: Asus A6Rp-AP002). Signed-off-by: Mariusz Domanski <mariook@wp.pl> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC: Add support for BCLK based on (Rate * Chn * Word Size)Liam Girdwood
This patch adds support for the DAI BCLK to be generated by multiplying Rate * Channels * Word Size (RCW). This now gives 3 options for BCLK clocking and synchronisation :- 1. BCLK = Rate * x 2. BCLK = MCLK / x 3. BCLK = Rate * Chn * Word Size. (New) Changes:- o Add support for RCW generation of BCLK o Update Documentation to include RCW. o Update DAI documentation for label = value DAI modes. o Add RCW support to wm8731, wm8750 and pxa2xx-i2s drivers. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add new modesl for Realtek codecsKailang Yang
Changes from Realtek driver: - New models hippo and hippo_1 for ALC262 - New models tagra-dig and tagra-2ch-dig for ALC883 - New id for ALC660 codec chip Signed-off-by: Kailang Yang <kailang@realtek.com.tw> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add toshiba model to ALC861 codecTobin Davis
This patch adds support for Toshiba laptops. Code is from RealTek's alsa-driver-1.0.12-4.05b tree. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] hda-codec - Add support for Medion laptopsTobin Davis
This patch adds audio support for Medion's line of laptops, based on code shipped with the laptops. Microphone support is still being explored. Signed-off-by: Tobin Davis <tdavis@dsl-only.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-09[ALSA] ASoC: documentation & maintainerLiam Girdwood
This patch adds documentation describing the ASoC architecture and a maintainer entry for ASoC. The documentation includes the following files:- codec.txt: Codec driver internals. DAI.txt: Description of Digital Audio Interface standards and how to configure a DAI within your codec and CPU DAI drivers. dapm.txt: Dynamic Audio Power Management. platform.txt: Platform audio DMA and DAI. machine.txt: Machine driver internals. pop_clicks.txt: How to minimise audio artifacts. clocking.txt: ASoC clocking for best power performance. Signed-off-by: Liam Girdwood <liam.girdwood@wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-02-08Merge branch 'HEAD' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/herbert/crypto-2.6 Conflicts: crypto/Kconfig
2007-02-08the scheduled IEEE1394_OUI_DB removalAdrian Bunk
This patch contains the scheduled IEEE1394_OUI_DB removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Update: Also remove drivers/ieee1394/.gitignore. Remove now unused struct members in drivers/ieee1394/nodemgr.h. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-02-08the scheduled IEEE1394_EXPORT_FULL_API removalAdrian Bunk
This patch contains the scheduled IEEE1394_EXPORT_FULL_API removal. Signed-off-by: Adrian Bunk <bunk@stusta.de> Update: Pull proper portion of feature-removal-schedule.txt. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: (70 commits) USB: remove duplicate device id from zc0301 USB: remove duplicate device id from usb_storage USB: remove duplicate device id from keyspan USB: remove duplicate device id from ftdi_sio USB: remove duplicate device id from visor USB: a bit more coding style cleanup usbcore: trivial whitespace fixes usb-storage: use first bulk endpoints, not last EHCI: fix interrupt-driven remote wakeup USB: switch ehci-hcd to new polling scheme USB: autosuspend for usb printer driver USB Input: Added kernel module to support all GTCO CalComp USB InterWrite School products USB: Sierra Wireless auto set D0 USB: usb ethernet gadget recognizes HUSB2DEV USB: list atmel husb2_udc gadget controller USB: gadgetfs AIO tweaks USB: gadgetfs behaves better on userspace init bug USB: gadgetfs race fix USB: gadgetfs simplifications USB: gadgetfs cleanups ...
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (28 commits) sysfs: Shadow directory support Driver Core: Increase the default timeout value of the firmware subsystem Driver core: allow to delay the uevent at device creation time Driver core: add device_type to struct device Driver core: add uevent vars for devices of a class SYSFS: Fix missing include of list.h in sysfs.h HOWTO: Add a reference to Harbison and Steele sysfs: error handling in sysfs, fill_read_buffer() kobject: kobject_put cleanup sysfs: kobject_put cleanup sysfs: suppress lockdep warnings Driver core: fix race in sysfs between sysfs_remove_file() and read()/write() driver core: Change function call order in device_bind_driver(). driver core: Don't stop probing on ->probe errors. driver core fixes: device_register() retval check in platform.c driver core fixes: make_class_name() retval checks /sys/modules/*/holders USB: add the sysfs driver name to all modules SERIO: add the sysfs driver name to all modules PCI: add the sysfs driver name to all modules ...
2007-02-07Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: (116 commits) sk98lin: planned removal AT91: MACB support sky2: version 1.12 sky2: add new chip ids sky2: Yukon Extreme support sky2: safer transmit timeout sky2: TSO support for EC_U sky2: use dev_err for error reports sky2: add Wake On Lan support fix unaligned exception in /drivers/net/wireless/orinoco.c Remove unused kernel config option DLCI_COUNT z85230: spinlock logic mips: declance: Driver model for the PMAD-A Spidernet: Rework RX linked list NET: turn local_save_flags() + local_irq_disable() into local_irq_save() NET-3c59x: turn local_save_flags() + local_irq_disable() into local_irq_save() hp100: convert pci_module_init() to pci_register_driver() NetXen: Added ethtool support for user level tools. NetXen: Firmware crb init changes. maintainers: add atl1 maintainers ...
2007-02-07sk98lin: planned removalStephen Hemminger
Document planned removal of sk98lin driver. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-07USB: add binary API to usbmonPete Zaitcev
This patch adds a new, "binary" API in addition to the old, text API usbmon had before. The new API allows for less CPU use, and it allows to capture all data from a packet where old API only captured 32 bytes at most. There are some limitations and conditions to this, e.g. in case someone constructs a URB with 1GB of data, it's not likely to be captured, because even the huge buffers of the new reader are finite. Nonetheless, I expect this new capability to capture all data for all real life scenarios. The downside is, a special user mode application is required where cat(1) worked before. I have sample code at http://people.redhat.com/zaitcev/linux/ and Paolo Abeni is working on patching libpcap. This patch was initially written by Paolo and later I tweaked it, and we had a little back-and-forth. So this is a jointly authored patch, but I am submitting this I am responsible for the bugs. Signed-off-by: Paolo Abeni <paolo.abeni@email.it> Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: indicate active altsetting in proc/bus/usb/devices fileDavid Brownell
Update /proc/bus/usb/devices output to report active altsettings. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (140 commits) ACPICA: reduce table header messages to fit within 80 columns asus-laptop: merge with ACPICA table update ACPI: bay: Convert ACPI Bay driver to be compatible with sysfs update. ACPI: bay: new driver is EXPERIMENTAL ACPI: bay: make drive_bays static ACPI: bay: make bay a platform driver ACPI: bay: remove prototype procfs code ACPI: bay: delete unused variable ACPI: bay: new driver adding removable drive bay support ACPI: dock: check if parent is on dock ACPICA: fix gcc build warnings Altix: Add ACPI SSDT PCI device support (hotplug) Altix: ACPI SSDT PCI device support ACPICA: reduce conflicts with Altix patch series ACPI_NUMA: fix HP IA64 simulator issue with extended memory domain ACPI: fix HP RX2600 IA64 boot ACPI: build fix for IBM x440 - CONFIG_X86_SUMMIT ACPICA: Update version to 20070126 ACPICA: Fix for incorrect parameter passed to AcpiTbDeleteTable during table load. ACPICA: Update copyright to 2007. ...
2007-02-07HOWTO: Add a reference to Harbison and SteeleRobert P. J. Day
Add a reference to Harbison and Steele's C book. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07[CRYPTO] doc: added the developer of Camellia cipherNoriaki TAKAMIYA
This patch adds the developer of Camellia cipher algorithm. Signed-off-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-02-05[S390] Fix register usage description.Heiko Carstens
Fix description of register usage as pointed out by Andreas Krebbel. Since this document is completely outdated and would need a lot of fixing, it might be worth considering to get rid of it... Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-02-03Pull output-switch into test branchLen Brown
2007-02-03Pull sysfs into test branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt include/acpi/acpi_drivers.h Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-01[PATCH] sysrq: showBlockedTasks is sysrq-WRandy Dunlap
Change SysRq showBlockedTasks from sysrq-X to sysrq-W and show that in the Help message. It was previously done via X, but X is already used for Xmon on ppc & powerpc platforms and this collision needs to be avoided. All callers of register_sysrq_key() are now marked in the sysrq op/key table. I didn't mark 'h' as Help because Help is just printed for any unknown key, such as '?'. Added some omitted sysrq key entries in the sysrq.txt file. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-28ACPI: add a Kconfig option for ACPI procfs interfaceZhang Rui
Add a kconfig option CONFIG_ACPI_PROCFS to make procfs interface a configurable attribute of ACPI. No procfs interface is actually deprecated, and no sysfs interface is added in this patch. CONGI_ACPI_PROCFS is used to mark procfs interface as deprecated once the same function is duplicated in sysfs. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-26[PATCH] Boot loader ID for GujinH. Peter Anvin
Add an official boot loader ID for Gujin. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] 9p: update documentation regarding server applicationsEric Van Hensbergen
Update the documentation to cover using Inferno as a server for 9p and to include information about spfs (a stable single-threaded stand-alone 9p server). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23Change Linus' email address tooLinus Torvalds
This changes a few mentions of my email address to point to the new one, leaving things like old copyright messages alone. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
