This is a update of Chinese documentation: Documentation/zh_CN/arm64/booting.txt
It is based on the modifications of Documentation/arm64/booting.txt in submission:
"a7f8de16".
Signed-off-by: Fu Wei <wefu@redhat.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Homepage url of git in HOWTO document was updated by commit
e234ebf7881c013b654113f0a208977ac3ce1d01 ("Documentation/HOWTO: update
git home URL") but not applied to several translations. This commit
updates them.
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
Obsolete info about regression postings were removed by commit
5645a717c6ee61e67d38aa9f15cb9db074e1e99d ("Documentation: HOWTO: remove
obsolete info about regression postings") but not applied to
translations. This commit applies the change to translations.
This is a Chinese translated version of Documentation/arm64/silicon-errata.txt
Reviewed-by: Weiwei Jia <harryxiyou@gmail.com>
"61bd93ce", "6c020ea8", "9d372c9f", "6d32ab2d".
And improve the format of documentation.
With the MC next gen rework, what's left for media_entity_init()
is to just initialize the PADs. However, certain devices, like
a FLASH led/light doesn't have any input or output PAD.
So, there's no reason why calling media_entity_init() would be
mandatory. Also, despite its name, what this function actually
does is to initialize the PADs data. So, rename it to
media_entity_pads_init() in order to reflect that.
The media entity actual init happens during entity register,
at media_device_register_entity(). We should move init of
num_links and num_backlinks to it.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Currently, media_entity_init() creates an array with the links,
allocated at init time. It provides a parameter (extra_links)
that would allocate more links than the current needs, but this
is not used by any driver.
As we want to be able to do dynamic link allocation/removal,
we'll need to change the implementation of the links. So,
before doing that, let's first remove that extra unused
parameter, in order to cleanup the interface first.
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
sysfs_dirent went away when kernfs was extracted from sysfs. The reference
to the kobject now lives in a kernfs_node (in the 'priv' member).
See commit 324a56e16e44 ("kernfs: s/sysfs_dirent/kernfs_node/ and rename
its friends accordingly").
Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com>
Pull documentation updates from Jonathan Corbet:
"The main thing here is Ingo's big subdirectory documenting feature
support for each architecture. Beyond that, it's the usual pile of
fixes, tweaks, and small additions"
* tag 'docs-for-linus' of git://git.lwn.net/linux-2.6: (79 commits)
doc:md: fix typo in md.txt.
Documentation/mic/mpssd: don't build x86 userspace when cross compiling
Documentation/prctl: don't build tsc tests when cross compiling
Documentation/vDSO: don't build tests when cross compiling
Doc:ABI/testing: Fix typo in sysfs-bus-fcoe
Doc: Docbook: Change wikipedia's URL from http to https in scsi.tmpl
Doc: Change wikipedia's URL from http to https
Documentation/kernel-parameters: add missing pciserial to the earlyprintk
Doc:pps: Fix typo in pps.txt
kbuild : Fix documentation of INSTALL_HDR_PATH
Documentation: filesystems: updated struct file_operations documentation in vfs.txt
kbuild: edit explanation of clean-files variable
Doc: ja_JP: Fix typo in HOWTO
Move freefall program from Documentation/ to tools/
Documentation: ARM: EXYNOS: Describe boot loaders interface
Doc:nfc: Fix typo in nfc-hci.txt
vfs: Minor documentation fix
Doc: networking: txtimestamp: fix printf format warning
Documentation, intel_pstate: Improve legacy mode internal governors description
Documentation: extend use case for EXPORT_SYMBOL_GPL()
The SCC_MAGIC define was removed in commit 1ec3ba93c5fad9dc ("Staging:
remove drivers/char/scc.h as it should have gone a while ago"), while
its actual last user was removed before in commit bb2a97e9ccd525dd
("Staging: delete generic_serial drivers").
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The SCI_MAGIC define was removed in commit f8e53553f452dcbf ("serial:
sh-sci: Kill off more unused defines.").
Its last user was the old drivers/char sh-sci driver, which was removed
in 2004.
Remove gpiod_sysfs_set_active_low (and gpio_sysfs_set_active_low) which
allowed code to change the polarity of a gpio line even after it had
been exported through sysfs.
Drivers should not care, and generally does not know, about gpio-line
polarity which is a hardware feature that needs to be described by
firmware.
It is currently possible to define gpio-line polarity in device-tree and
acpi firmware or using platform data. Userspace can also change the
polarity through sysfs.
Note that drivers using the legacy gpio interface could still use
GPIOF_ACTIVE_LOW to change the polarity before exporting the gpio.
There are no in-kernel users of this interface.
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Harry Wei <harryxiyou@gmail.com>
Cc: linux-doc@vger.kernel.org
Cc: linux-kernel@zh-kernel.org
Signed-off-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
This is a update of Chinese documentation:Documentation/zh_CN/arm64/memory.txt
It is based on the modifications of Documentation/arm64/memory.txt in submission:
"08375198", "4edae01e", "a24637d5", "383c2799".
"a2c1d73b", "cdd78578", "c218bca7", "63f8344c".
Documentation/arm64/legacy_instructions.txt
Documentation/arm64/legacy_instructions.txt in submission: "587064b6",
"bd35a4ad", "2d888f48", "c852f320".
Pull trivial tree changes from Jiri Kosina:
"Summer edition of trivial tree updates"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
doc: fix two typos in watchdog-api.txt
irq-gic: remove file name from heading comment
MAINTAINERS: Add miscdevice.h to file list for char/misc drivers.
scsi: mvsas: mv_sas.c: Fix for possible null pointer dereference
doc: replace "practise" with "practice" in Documentation
befs: remove check for CONFIG_BEFS_RW
scsi: doc: fix 'SCSI_NCR_SETUP_MASTER_PARITY'
drivers/usb/phy/phy.c: remove a leading space
mfd: fix comment
cpuidle: fix comment
doc: hpfall.c: fix missing null-terminate after strncpy call
usb: doc: hotplug.txt code typos
kbuild: fix comment in Makefile.modinst
SH: add proper prompt to SH_MAGIC_PANEL_R2_VERSION
ARM: msm: Remove MSM_SCM
crypto: Remove MPILIB_EXTRA
doc: CN: remove dead link, kerneltrap.org no longer works
media: update reference, kerneltrap.org no longer works
hexagon: update reference, kerneltrap.org no longer works
doc: LSM: update reference, kerneltrap.org no longer works
The V4L2_FL_USE_FH_PRIO has been removed from the code, now remove it from the
documentation.
Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
kerneltrap.org no longer works, remove dead reference
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fixes from Greg KH:
"Here are some driver core fixes for 3.15-rc2. Also in here are some
documentation updates, as well as an API removal that had to wait for
after -rc1 due to the cleanups coming into you from multiple developer
trees (this one and the PPC tree.)
All have been in linux next successfully"
* tag 'driver-core-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
drivers/base/dd.c incorrect pr_debug() parameters
Documentation: Update stable address in Chinese and Japanese translations
topology: Fix compilation warning when not in SMP
Chinese: add translation of io_ordering.txt
stable_kernel_rules: spelling/word usage
sysfs, driver-core: remove unused {sysfs|device}_schedule_callback_owner()
kernfs: protect lazy kernfs_iattrs allocation with mutex
fs: Don't return 0 from get_anon_bdev
These serial drivers were removed in kernel v3.1, so we can drop their
documentation files and references to their magic numbers and
parameters.
There are still references to these old drivers in
Documentation/devices.txt but I'm afraid they can't be removed.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Rob Landley <rob@landley.net>
The English and Korean translations were updated, the Chinese and Japanese
weren't.
This is a Chinese translated version of Documentation/io_ordering.txt
Signed-off-by: Lin Yongting <linyongting@gmail.com>
The link to the tarball for Andrew Morton's patch scripts is dead.
These scripts don't seem to be used for kernel development these days
anyways so just rip out all references to them.
Signed-off-by: Mitchel Humpherys <mitchelh@codeaurora.org>
The links to "The perfect patch" and "NO!!!! No more huge patch
bombs..." have gone stale. Update them to some working locations.
"2475ff9d", "847264fb", "aa4a73a0", "e29a074b".
Update maintainer's Email address.
Acked-by: Harry Wei <harryxiyou@gmail.com>
"4d5e0b15", "4370eec0", "4fcd6e14".
This is a Chinese translated version of Documentation/arm64/tagged-pointers.txt
It is based on the modifications of Documentation/arm64/tagged-pointers.txt in submission:
"d50240a5", "374ed9d1".
Links for 'The Perfect Patch' which described on HOWTO document is
broken. Change those links to the copy at ozlabs.
Corrected the word MAITAINERS to MAINTAINERS.
Signed-off-by: Stefan Huber <steffhip@gmail.com>
Signed-off-by: Matthias Schid <aircrach115@gmail.com>
Signed-off-by: Simon Puels <simon.puels@gmail.com>
The framework documentation used the g_chip_ident op as an example. This
op has been removed, so replace its use in the examples by the g_std op.
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Since the GENERIC_GPIO has been removed and the documentation of it
has been modified, this patch updates the corresponding documentation of
gpio in Chinese.
Signed-off-by: Chen Baozi <baozich@gmail.com>
Acked-by: Alexandre Courbot <acourbot@nvidia.com>
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
The original suggestion to delete wanrouter started earlier
with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc
("net/wanrouter: Deprecate and schedule for removal") in May 2012.
More importantly, Dan Carpenter found[1] that the driver had a
fundamental breakage introduced back in 2008, with commit
7be6065b39c3 ("netdevice wanrouter: Convert directly reference of
netdev->priv"). So we know with certainty that the code hasn't been
used by anyone willing to at least take the effort to send an e-mail
report of breakage for at least 4 years.
This commit does a decouple of the wanrouter subsystem, by going
after the Makefile/Kconfig and similar files, so that these mainline
files that we are keeping do not have the big wanrouter file/driver
deletion commit tied into their history.
Once this commit is in place, we then can remove the obsolete cyclomx
drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS.
[1] http://www.spinics.net/lists/netdev/msg218670.html
Originally-by: Joe Perches <joe@perches.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Rob Landley <rob@landley.net>
CC: Jiri Kosina <jkosina@suse.cz>
CC: Masanari Iida <standby24x7@gmail.com>
CC: Jason Wessel <jason.wessel@windriver.com>
CC: Richard L Maliszewski <richard.l.maliszewski@intel.com>
CC: Gang Wei <gang.wei@intel.com>
CC: Shane Wang <shane.wang@intel.com>
CC: Harry Wei <harryxiyou@gmail.com>
Acked-by: Jason Wessel <jason.wessel@windriver.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
__devinitconst, and __devexit from the kernel documentation.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
submission :"e3978cde".
Signed-off-by: Fu Wei <tekkamanninja@gmail.com>
Documentation/arm/kernel_user_helpers.txt
Fixes a term's translation in Documentation/zh_CN/arm64/memory.txt
The modification is based on Catalin Marinas <catalin.marinas@arm.com>'s
suggestion:
"memory" in "ffffffc000000000 ffffffffffffffff 256GB memory"
should be treated as "kernel logical memory map",
so the translation should be "内核逻辑内存映射".
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Documentation/IRQ.txt
Fixes some translation error in Documentation/zh_CN/gpio.txt
The modification is based on Dong Aisheng <b29396@freescale.com>'s
corrections:
1.Two "OUTPUT" is incorrectly translated as "输入";
2.five improvement of translation;
3.Delete a redundant paragraph,
Acked-by: Dong Aisheng <b29396@freescale.com>
Documentation/zh_CN/arm/booting
Remove 3 byte redundant code at the head of
the Documentation/zh_CN/arm/booting
When I see the file Documentation/zh_CN/arm/booting using
Bless(binary Viewer),I find 3 byte redundant in it. So I
make a patch to correcting that error made by me.
This is a Chinese translated version of Documentation/video4linux/omap3isp.txt
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
This is a Chinese translated version of Documentation/basic_profiling.txt
Signed-off-by: Liang Xie <xieliang007@gmail.com>
This is a Chinese translated version of Documentation/arm/Booting
Documentation/video4linux/v4l2-framework.txt
This is a Chinese translated version of Documentation/filesystems/sysfs.txt
This is a Chinese translated version of Documentation/gpio.txt
This is a patch for correcting a mistake sentence in the file
Documentation/zh_CN/magic-number.txt.
signed-off-by: Harry Wei <harryxiyou@gmail.com>
Reported-by: Zhang Shuanglong <zhangsl16@gmail.com>
