After commit cf65a0f6f6ff ("dma-mapping: move all DMA mapping code to
kernel/dma") some of the files are referring to outdated information,
i.e. old file names of DMA mapping sources. Fix it here.
Note, the lines with "Glue code for..." have been removed completely.
Now that the latex_documents are handled automatically, we can
remove those extra conf.py files.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
There are lots of documents that belong to the admin-guide but
are on random places (most under Documentation root dir).
Move them to the admin guide.
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Those files belong to the admin guide, so add them.
Those two docs belong to the x86 architecture:
Documentation/Intel-IOMMU.txt -> Documentation/x86/intel-iommu.rst
Documentation/intel_txt.txt -> Documentation/x86/intel_txt.rst
Pull Documentation updates from Jonathan Corbet:
"It's been a relatively busy cycle for docs:
- A fair pile of RST conversions, many from Mauro. These create more
than the usual number of simple but annoying merge conflicts with
other trees, unfortunately. He has a lot more of these waiting on
the wings that, I think, will go to you directly later on.
- A new document on how to use merges and rebases in kernel repos,
and one on Spectre vulnerabilities.
- Various improvements to the build system, including automatic
markup of function() references because some people, for reasons I
will never understand, were of the opinion that
:c:func:``function()`` is unattractive and not fun to type.
- We now recommend using sphinx 1.7, but still support back to 1.4.
- Lots of smaller improvements, warning fixes, typo fixes, etc"
* tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits)
docs: automarkup.py: ignore exceptions when seeking for xrefs
docs: Move binderfs to admin-guide
Disable Sphinx SmartyPants in HTML output
doc: RCU callback locks need only _bh, not necessarily _irq
docs: format kernel-parameters -- as code
Doc : doc-guide : Fix a typo
platform: x86: get rid of a non-existent document
Add the RCU docs to the core-api manual
Documentation: RCU: Add TOC tree hooks
Documentation: RCU: Rename txt files to rst
Documentation: RCU: Convert RCU UP systems to reST
Documentation: RCU: Convert RCU linked list to reST
Documentation: RCU: Convert RCU basic concepts to reST
docs: filesystems: Remove uneeded .rst extension on toctables
scripts/sphinx-pre-install: fix out-of-tree build
docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/
Documentation: PGP: update for newer HW devices
Documentation: Add section about CPU vulnerabilities for Spectre
Documentation: platform: Delete x86-laptop-drivers.txt
docs: Note that :c:func: should no longer be used
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
"Documentation updates and the addition of cgroup_parse_float() which
will be used by new controllers including blk-iocost"
* 'for-5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
docs: cgroup-v1: convert docs to ReST and rename to *.rst
cgroup: Move cgroup_parse_float() implementation out of CONFIG_SYSFS
cgroup: add cgroup_parse_float()
Pull x86 topology updates from Ingo Molnar:
"Implement multi-die topology support on Intel CPUs and expose the die
topology to user-space tooling, by Len Brown, Kan Liang and Zhang Rui.
These changes should have no effect on the kernel's existing
understanding of topologies, i.e. there should be no behavioral impact
on cache, NUMA, scheduler, perf and other topologies and overall
system performance"
* 'x86-topology-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/rapl: Cosmetic rename internal variables in response to multi-die/pkg support
perf/x86/intel/uncore: Cosmetic renames in response to multi-die/pkg support
hwmon/coretemp: Cosmetic: Rename internal variables to zones from packages
thermal/x86_pkg_temp_thermal: Cosmetic: Rename internal variables to zones from packages
perf/x86/intel/cstate: Support multi-die/package
perf/x86/intel/rapl: Support multi-die/package
perf/x86/intel/uncore: Support multi-die/package
topology: Create core_cpus and die_cpus sysfs attributes
topology: Create package_cpus sysfs attribute
hwmon/coretemp: Support multi-die/package
powercap/intel_rapl: Update RAPL domain name and debug messages
thermal/x86_pkg_temp_thermal: Support multi-die/package
powercap/intel_rapl: Support multi-die/package
powercap/intel_rapl: Simplify rapl_find_package()
x86/topology: Define topology_logical_die_id()
x86/topology: Define topology_die_id()
cpu/topology: Export die_id
x86/topology: Create topology_max_die_per_package()
x86/topology: Add CPUID.1F multi-die/package support
These are all obvious typos.
Signed-off-by: James Morse <james.morse@arm.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
"If the MBA is specified in MB then user can enter the max b/w in MB"
is a tautology. How can the user know if the schemata takes a percentage
or a MB/s value?
This is referring to whether the software controller is interpreting
the schemata's value. Make this clear.
"L2 cache does not support code and data prioritization". This isn't
true, elsewhere the document says it can be enabled with the cdpl2
mount option.
While we're here, these sample strings have lower-case code/data,
which isn't how the kernel exports them.
Since commit 4d05bf71f157 ("x86/resctrl: Introduce AMD QOS feature")
resctrl has supported non-contiguous cache bit masks. The interface
for this is currently try-it-and-see.
Update the documentation to say Intel CPUs have this requirement,
instead of X86.
Cc: Babu Moger <Babu.Moger@amd.com>
Convert the cgroup-v1 files to ReST format, in order to
allow a later addition to the admin-guide.
The conversion is actually:
- add blank lines and identation in order to identify paragraphs;
- fix tables markups;
- add some lists markups;
- mark literal blocks;
- adjust title markups.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Acked-by: Tejun Heo <tj@kernel.org>
Mostly due to x86 and acpi conversion, several documentation
links are still pointing to the old file. Fix them.
Reviewed-by: Wolfram Sang <wsa@the-dreams.de>
Reviewed-by: Sven Van Asbroeck <TheSven73@gmail.com>
Reviewed-by: Bhupesh Sharma <bhsharma@redhat.com>
Acked-by: Mark Brown <broonie@kernel.org>
This document is used by multiple architectures:
$ echo $(git grep -l pkey_mprotect arch|cut -d'/' -f 2|sort|uniq)
alpha arm arm64 ia64 m68k microblaze mips parisc powerpc s390 sh sparc x86 xtensa
So, let's move it to the core book and adjust the links to it
accordingly.
Signed-off-by: Ira Weiny <ira.weiny@intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: linux-doc@vger.kernel.org
Link: http://lkml.kernel.org/r/20190520205253.23762-1-ira.weiny@intel.com
[ Adjusted the patch to the RST conversion. ]
Some new systems have multiple software-visible die within each package.
Update Linux parsing of the Intel CPUID "Extended Topology Leaf" to handle
either CPUID.B, or the new CPUID.1F.
Add cpuinfo_x86.die_id and cpuinfo_x86.max_dies to store the result.
die_id will be non-zero only for multi-die/package systems.
Signed-off-by: Len Brown <len.brown@intel.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lkml.kernel.org/r/7b23d2d26d717b8e14ba137c94b70943f1ae4b5c.1557769318.git.len.brown@intel.com
On x86_64, all returns to usermode go through
prepare_exit_to_usermode(), with the sole exception of do_nmi().
This even includes machine checks -- this was added several years
ago to support MCE recovery. Update the documentation.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Frederic Weisbecker <frederic@kernel.org>
Cc: Jon Masters <jcm@redhat.com>
Cc: stable@vger.kernel.org
Fixes: 04dcbdb80578 ("x86/speculation/mds: Clear CPU buffers on exit to user")
Link: http://lkml.kernel.org/r/999fa9e126ba6a48e9d214d2f18dbde5c62ac55c.1557865329.git.luto@kernel.org
The double fault ESPFIX path doesn't return to user mode at all --
it returns back to the kernel by simulating a #GP fault.
prepare_exit_to_usermode() will run on the way out of
general_protection before running user code.
Link: http://lkml.kernel.org/r/ac97612445c0a44ee10374f6ea79c222fe22a5c4.1557865329.git.luto@kernel.org
Pull x86 MDS mitigations from Thomas Gleixner:
"Microarchitectural Data Sampling (MDS) is a hardware vulnerability
which allows unprivileged speculative access to data which is
available in various CPU internal buffers. This new set of misfeatures
has the following CVEs assigned:
CVE-2018-12126 MSBDS Microarchitectural Store Buffer Data Sampling
CVE-2018-12130 MFBDS Microarchitectural Fill Buffer Data Sampling
CVE-2018-12127 MLPDS Microarchitectural Load Port Data Sampling
CVE-2019-11091 MDSUM Microarchitectural Data Sampling Uncacheable Memory
MDS attacks target microarchitectural buffers which speculatively
forward data under certain conditions. Disclosure gadgets can expose
this data via cache side channels.
Contrary to other speculation based vulnerabilities the MDS
vulnerability does not allow the attacker to control the memory target
address. As a consequence the attacks are purely sampling based, but
as demonstrated with the TLBleed attack samples can be postprocessed
successfully.
The mitigation is to flush the microarchitectural buffers on return to
user space and before entering a VM. It's bolted on the VERW
instruction and requires a microcode update. As some of the attacks
exploit data structures shared between hyperthreads, full protection
requires to disable hyperthreading. The kernel does not do that by
default to avoid breaking unattended updates.
The mitigation set comes with documentation for administrators and a
deeper technical view"
* 'x86-mds-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
x86/speculation/mds: Fix documentation typo
Documentation: Correct the possible MDS sysfs values
x86/mds: Add MDSUM variant to the MDS documentation
x86/speculation/mds: Add 'mitigations=' support for MDS
x86/speculation/mds: Print SMT vulnerable on MSBDS with mitigations off
x86/speculation/mds: Fix comment
x86/speculation/mds: Add SMT warning message
x86/speculation: Move arch_smt_update() call to after mitigation decisions
x86/speculation/mds: Add mds=full,nosmt cmdline option
Documentation: Add MDS vulnerability documentation
Documentation: Move L1TF to separate directory
x86/speculation/mds: Add mitigation mode VMWERV
x86/speculation/mds: Add sysfs reporting for MDS
x86/speculation/mds: Add mitigation control for MDS
x86/speculation/mds: Conditionally clear CPU buffers on idle entry
x86/kvm/vmx: Add MDS protection when L1D Flush is not active
x86/speculation/mds: Add mds_clear_cpu_buffers()
x86/kvm: Expose X86_FEATURE_MD_CLEAR to guests
x86/speculation/mds: Add BUG_MSBDS_ONLY
Pull more documentation updates from Jonathan Corbet:
"Some late arriving documentation changes. In particular, this contains
the conversion of the x86 docs to RST, which has been in the works for
some time but needed a couple of final tweaks"
* tag 'docs-5.2a' of git://git.lwn.net/linux: (29 commits)
Documentation: x86: convert x86_64/machinecheck to reST
Documentation: x86: convert x86_64/cpu-hotplug-spec to reST
Documentation: x86: convert x86_64/fake-numa-for-cpusets to reST
Documentation: x86: convert x86_64/5level-paging.txt to reST
Documentation: x86: convert x86_64/mm.txt to reST
Documentation: x86: convert x86_64/uefi.txt to reST
Documentation: x86: convert x86_64/boot-options.txt to reST
Documentation: x86: convert i386/IO-APIC.txt to reST
Documentation: x86: convert usb-legacy-support.txt to reST
Documentation: x86: convert orc-unwinder.txt to reST
Documentation: x86: convert resctrl_ui.txt to reST
Documentation: x86: convert microcode.txt to reST
Documentation: x86: convert pti.txt to reST
Documentation: x86: convert amd-memory-encryption.txt to reST
Documentation: x86: convert intel_mpx.txt to reST
Documentation: x86: convert protection-keys.txt to reST
Documentation: x86: convert pat.txt to reST
Documentation: x86: convert mtrr.txt to reST
Documentation: x86: convert tlb.txt to reST
Documentation: x86: convert zero-page.txt to reST
This converts the plain text documentation to reStructuredText format and
add it to Sphinx TOC tree. No essential content change.
Signed-off-by: Changbin Du <changbin.du@gmail.com>
Reviewed-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Cc: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Add a index.rst for x86 support. More docs will be added later.
Pull documentation updates from Jonathan Corbet:
"A reasonably busy cycle for docs, including:
- Lots of work on the Chinese and Italian translations
- Some license-rules clarifications from Christoph
- Various build-script fixes
- A new document on memory models
- RST conversion of the live-patching docs
- The usual collection of typo fixes and corrections"
* tag 'docs-5.2' of git://git.lwn.net/linux: (140 commits)
docs/livepatch: Unify style of livepatch documentation in the ReST format
docs: livepatch: convert docs to ReST and rename to *.rst
scripts/documentation-file-ref-check: detect broken :doc:`foo`
scripts/documentation-file-ref-check: don't parse Next/ dir
LICENSES: Rename other to deprecated
LICENSES: Clearly mark dual license only licenses
docs: Don't reference the ZLib license in license-rules.rst
docs/vm: Minor editorial changes in the THP and hugetlbfs
docs/vm: add documentation of memory models
doc:it_IT: translation alignment
doc: fix typo in PGP guide
dontdiff: update with Kconfig build artifacts
docs/zh_CN: fix typos in 1.Intro.rst file
docs/zh_CN: redirect CoC docs to Chinese version
doc: mm: migration doesn't use FOLL_SPLIT anymore
docs: doc-guide: remove the extension from .rst files
doc: kselftest: Fix KBUILD_OUTPUT usage instructions
docs: trace: fix some Sphinx warnings
docs: speculation.txt: mark example blocks as such
docs: ntb.txt: add blank lines to clean up some Sphinx warnings
Fix a minor typo in the MDS documentation: "eanbled" -> "enabled".
Reported-by: Jeff Bastian <jbastian@redhat.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
