path: root/Documentation/video4linux
2012-07-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull second set of media updates from Mauro Carvalho Chehab: - radio API: add support to work with radio frequency bands - new AM/FM radio drivers: radio-shark, radio-shark2 - new Remote Controller USB driver: iguanair - conversion of several drivers to the v4l2 core control framework - new board additions at existing drivers - the remaining (and vast majority of the patches) are due to drivers/DocBook fixes/cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (154 commits) [media] radio-tea5777: use library for 64bits div [media] tlg2300: Declare MODULE_FIRMWARE usage [media] lgs8gxx: Declare MODULE_FIRMWARE usage [media] xc5000: Add MODULE_FIRMWARE statements [media] s2255drv: Add MODULE_FIRMWARE statement [media] dib8000: move dereference after check for NULL [media] Documentation: Update cardlists [media] bttv: add support for Aposonic W-DVR [media] cx25821: Remove bad strcpy to read-only char* [media] pms.c: remove duplicated include [media] smiapp-core.c: remove duplicated include [media] via-camera: pass correct format settings to sensor [media] rtl2832.c: minor cleanup [media] Add support for the IguanaWorks USB IR Transceiver [media] Minor cleanups for MCE USB [media] drivers/media/dvb/siano/smscoreapi.c: use list_for_each_entry [media] Use a named union in struct v4l2_ioctl_info [media] mceusb: Add Twisted Melon USB IDs [media] staging/media/solo6x10: use module_pci_driver macro [media] staging/media/dt3155v4l: use module_pci_driver macro ... Conflicts: Documentation/feature-removal-schedule.txt
2012-07-30[media] Documentation: Update cardlistsMauro Carvalho Chehab
2012-07-30[media] bttv: add support for Aposonic W-DVRTony Gentile
Forwarded-by: Gerd Hoffmann <kraxel@bytesex.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This is the first part of the media patches for v3.6. This patch series contain: - new DVB frontend: rtl2832 - new video drivers: adv7393 - some unused files got removed - a selection API cleanup between V4L2 and V4L2 subdev API's - a major redesign at v4l-ioctl2, in order to clean it up - several driver fixes and improvements." * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (174 commits) v4l: Export v4l2-common.h in include/linux/Kbuild media: Revert "[media] Terratec Cinergy S2 USB HD Rev.2" [media] media: Use pr_info not homegrown pr_reg macro [media] Terratec Cinergy S2 USB HD Rev.2 [media] v4l: Correct conflicting V4L2 subdev selection API documentation [media] Feature removal: V4L2 selections API target and flag definitions [media] v4l: Unify selection flags documentation [media] v4l: Unify selection flags [media] v4l: Common documentation for selection targets [media] v4l: Unify selection targets across V4L2 and V4L2 subdev interfaces [media] v4l: Remove "_ACTUAL" from subdev selection API target definition names [media] V4L: Remove "_ACTIVE" from the selection target name definitions [media] media: dvb-usb: print mac address via native %pM [media] s5p-tv: Use module_i2c_driver in sii9234_drv.c file [media] media: gpio-ir-recv: add allowed_protos for platform data [media] s5p-jpeg: Use module_platform_driver in jpeg-core.c file [media] saa7134: fix spelling of detach in label [media] cx88-blackbird: replace ioctl by unlocked_ioctl [media] cx88: don't use current_norm [media] cx88: fix a number of v4l2-compliance violations ...
2012-07-30[media] Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-20Documentation: Add newline at end-of-file to files lacking oneJesper Juhl
This patch simply adds a newline character at end-of-file to those files in Documentation/ that currently lack one. This is done for a few different reasons: A) It's rather annoying when you do "cat some_file.txt" that your prompt/cursor ends up at the end of the last line of output rather than on a new line. B) Some tools that process files line-by-line may get confused by the lack of a newline on the last line. C) The "\ No newline at end of file" line in diffs annoys me for some reason. So, let's just add the missing newline once and for all. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-06[media] v4l2-framework.txt: Update the locking documentationHans Verkuil
This documents the new queue->lock and how to use it. It also removes the documentation of v4l2_disable_ioctl_locking: this is only used in gspca and will be removed once gspca has been converted to vb2. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - some V4L2 API updates needed by embedded devices - DVB API extensions for ATSC-MH delivery system, used in US for mobile TV - new tuners for fc0011/0012/0013 and tua9001 - a new dvb driver for af9033/9035 - a new ATSC-MH frontend (lg2160) - new remote controller keymaps - Removal of a few legacy webcam driver that got replaced by gspca on several kernel versions ago - a new driver for Exynos 4/5 webcams(s5pp fimc-lite) - a new webcam sensor driver (smiapp) - a new video input driver for embedded (sta2x1xx) - several improvements, fixes, cleanups, etc inside the drivers. Manually fix up conflicts due to err() -> dev_err() conversion in drivers/staging/media/easycap/easycap_main.c * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (484 commits) [media] saa7134-cards: Remove a PCI entry added by mistake [media] radio-sf16fmi: add support for SF16-FMD [media] rc-loopback: remove duplicate line [media] patch for Asus My Cinema PS3-100 (1043:48cd) [media] au0828: Move the Kconfig knob under V4L_USB_DRIVERS [media] em28xx: simple comment fix [media] [resend] radio-sf16fmr2: add PnP support for SF16-FMD2 [media] smiapp: Use v4l2_ctrl_new_int_menu() instead of v4l2_ctrl_new_custom() [media] smiapp: Add support for 8-bit uncompressed formats [media] smiapp: Allow generic quirk registers [media] smiapp: Use non-binning limits if the binning limit is zero [media] smiapp: Initialise rval in smiapp_read_nvm() [media] smiapp: Round minimum pre_pll up rather than down in ip_clk_freq check [media] smiapp: Use 8-bit reads only before identifying the sensor [media] smiapp: Quirk for sensors that only do 8-bit reads [media] smiapp: Pass struct sensor to register writing commands instead of i2c_client [media] smiapp: Allow using external clock from the clock framework [media] zl10353: change .read_snr() to report SNR as a 0.1 dB [media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300) [media] m88rs2000 - only flip bit 2 on reg 0x70 on 16th try ...
2012-05-20[media] media: add support to gspca/pac7302.c for 093a:2627 (Genius FaceCam 300)Jozsef Marton
gspca_pac7302 module supports the webcam with usb id: 093a:2627. It is a Genius FaceCam 300. The module does not need any changes but listing the usb id along with a vertical flip flag. The included patch adds this to the module source. Signed-off-by: Jozsef Marton <jmarton@users.sourceforge.net> Acked-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-dev: rename two functionsHans Verkuil
Rename the function v4l2_dont_use_lock to v4l2_disable_ioctl_locking, and rename v4l2_dont_use_cmd to v4l2_disable_ioctl. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-framework.txt: update the core lock documentationHans Verkuil
Thanks to Laurent Pinchart for pointing out that this information was missing. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] V4L: Add helper function for standard integer menu controlsSylwester Nawrocki
This patch adds v4l2_ctrl_new_int_menu() helper function which can be used in drivers for creating standard integer menu control with driver-specific menu item list. It is similar to v4l2_ctrl_new_std_menu(), except it doesn't have a mask parameter and an additional qmenu parameter allows passing an array of signed 64-bit integers as the menu item list. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Tested-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l2-framework.txt: document v4l2_dont_use_cmdHans Verkuil
2012-05-14[media] v4l2-dev: make it possible to skip locking for selected ioctlsHans Verkuil
Using the V4L2 core lock is a very robust method that is usually very good at doing the right thing. But some drivers, particularly USB drivers, may want to prevent the core from taking the lock for specific ioctls, particularly buffer queuing ioctls. The reason is that certain commands like S_CTRL can take a long time to process over USB and all the time the core has the lock, preventing VIDIOC_DQBUF from proceeding, even though a frame may be ready in the queue. This introduces unwanted latency. Since the buffer queuing commands often have their own internal lock it is often not necessary to take the core lock. Drivers can now say that they don't want the core to take the lock for specific ioctls. As it is a specific opt-out it makes it clear to the reviewer that those ioctls will need more care when reviewing. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Implement v4l2_subdev_link_validate()Sakari Ailus
v4l2_subdev_link_validate() is the default op for validating a link. In V4L2 subdev context, it is used to call a pad op which performs the proper link check without much extra work. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Improve sub-device documentation for pad opsSakari Ailus
Document that format related configuration is done through pad ops in case the driver does use the media framework. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-14[media] v4l: Document raw bayer 4CC codesSakari Ailus
Document guidelines how 4CC codes should be named. Only raw bayer is included currently. Other formats should be documented later on. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-05-07[media] v4l2-event: Add v4l2_subscribed_event_opsHans de Goede
Just like with ctrl events, drivers may want to get called back on listener add / remove for other event types too. Rather then special casing all of this in subscribe / unsubscribe event it is better to use ops for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-19[media] V4L: fix incorrect refcountingHans Verkuil
Both radio-keene and dsbr100 did one v4l2_device_get too many. Thus the refcount never became 0 and that causes a memory leak. Also updated the V4L2 framework documentation accordingly. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-05doc: fix a few typosMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - V4L2 API additions to better support JPEG compression control - media API additions to properly support MPEG decoders - V4L2 API additions for image crop/scaling - a few other V4L2 API DocBook fixes/improvements - two new DVB frontend drivers: m88rs2000 and rtl2830 - two new DVB drivers: az6007 and rtl28xxu - a framework for ISA drivers, that removed lots of common code found at the ISA radio drivers - a new FM transmitter driver (radio-keene) - a GPIO-based IR receiver driver - a new sensor driver: mt9m032 - some new video drivers: adv7183, blackfin, mx2_emmaprp, sii9234_drv, vs6624 - several new board additions, driver fixes, improvements and cleanups. * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (295 commits) [media] update CARDLIST.em28xx [media] partially reverts changeset fa5527c [media] stb0899: fix the limits for signal strength values [media] em28xx: support for 2304:0242 PCTV QuatroStick (510e) [media] em28xx: support for 2013:0251 PCTV QuatroStick nano (520e) [media] -EINVAL -> -ENOTTY [media] gspca - sn9c20x: Cleanup source [media] gspca - sn9c20x: Simplify register write for capture start/stop [media] gspca - sn9c20x: Add automatic JPEG compression mechanism [media] gspca - sn9c20x: Greater delay in case of sensor no response [media] gspca - sn9c20x: Optimize the code of write sequences [media] gspca - sn9c20x: Add the JPEG compression quality control [media] gspca - sn9c20x: Add a delay after Omnivision sensor reset [media] gspca - sn9c20x: Propagate USB errors to higher level [media] gspca - sn9c20x: Use the new video control mechanism [media] gspca - sn9c20x: Fix loss of frame start [media] gspca - zc3xx: Lack of register 08 value for sensor cs2102k [media] gspca - ov534_9: Add brightness to OmniVision 5621 sensor [media] gspca - zc3xx: Add V4L2_CID_JPEG_COMPRESSION_QUALITY control support [media] pvrusb2: fix 7MHz & 8MHz DVB-T tuner support for HVR1900 rev D1F5 ...
2012-03-19[media] update CARDLIST.em28xxMauro Carvalho Chehab
Add the new DRX-K based devices there. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-08[media] Documentation: Update some card listsMauro Carvalho Chehab
2012-03-08[media] gspca - pac7302: Add new webcam 06f8:301bJean-François Moine
Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-01[media] s5p-fimc: Add driver documentationSylwester Nawrocki
Add short documentation providing the driver usage details. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-16[media] V4L2 Spec: fix extended control documentationHans Verkuil
Update the spec to the behavior implemented by the control framework. This should have been documented long ago but for some reason it was never done. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-06[media] gspca: Add jl2005bcd sub driverTheodore Kilgore
Written by Theodore Kilgore With minor changes by Hans de Goede: -Code style fixes -Correct the verbose level on various PDEBUG messages -Make error messages use pr_err instead of PDEBUG -Document the jl20 pixel format Signed-off-by: Theodore Kilgore <kilgota@auburn.edu> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-01-06[media] gspca - ov534_9: New sensor ov5621 and webcam 05a9:1550Jose Alberto Reguero
This path add support to "OmniVision Technologies, Inc. VEHO Filmscanner". Signed-off-by: Jose Alberto Reguero <jareguero@telefonica.net> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-12-30[media] update Documentation/video4linux/CARDLIST.*Mauro Carvalho Chehab
2011-11-25[media] v4l2 framework doc: clarify lockingHans Verkuil
high-latency devices. Thanks to Hans de Goede for our discussions on this topic. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Thanks-to: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-16[media] em28xx: Fix some Terratec entries (H5 and XS)Mauro Carvalho Chehab
As reported by Andreas Oberritter <obi@linuxtv.org>, changeset 33ba28eebc3e1758e6adc1fcec9e1e3151bac453 did the wrong thing. Fix it to properly reflect the entries for Terratec H5 revs 1 and 2, and restore Terratec XS entry. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-07[media] Update some CARDLIST'sMauro Carvalho Chehab
Re-run the cardlist script, in order to update the cardlists for a few drivers, to sync with the driver changes. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-07[media] bttv: adding Sensoray 611 board to driversensoray-dev
commit affebd4db94b459f676a14d9bb696c3c2b73643d [media] bttv: adding Sensoray 611 board to bttv driver Signed-off-by: Dean Anderson <linux-dev@sensoray.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-11-07[media] saa7134: adding Sensoray boards to saa7134 driversensoray-dev
commit cf5886c3dd2f65c817cb6ca5e7202fa3a3bdc872 Signed-off-by: Dean Anderson <linux-dev@sensoray.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-23[media] gspca - zc3xx: New webcam 03f0:1b07 HP Premium Starter CamWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-23[media] gspca - topro: New subdriver for Topro webcamsJean-François Moine
This driver is based on Anders Blomdell's source proposed in april 2009. It has been extended to handle the tp6810 bridge and the soi763a sensor. Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-23[media] move tm6000 to drivers/media/videoMauro Carvalho Chehab
The serious bugs got fixed already. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-21[media] v4l2-controls.txt: update auto cluster documentationHans Verkuil
2011-09-21[media] v4l2-ctrls: replace is_volatile with V4L2_CTRL_FLAG_VOLATILEHans Verkuil
With the new flag there is no need anymore to have a separate is_volatile field. Modify all users to use the new flag. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] gspca - ov534_9: New sensor ov9712 and new webcam 05a9:8065Jean-François Moine
The webcam is build from an Omnivision test kit which contains a OV538 bridge and a OV9712 sensor. Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-08-29[media] omap3isp: ccdc: Use generic frame sync event instead of private ↵Sakari Ailus
HS_VS event The ccdc block in the omap3isp produces events whenever it starts receiving a new frame. A private HS_VS event was used for this previously. Now, the generic V4L2_EVENT_FRAME_SYNC event is being used for the purpose. This patch also provides the frame sequence number to user space. Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-framework.txt: update v4l2_event sectionHans Verkuil
2011-07-27[media] v4l2-framework.txt: updated v4l2_fh_init documentationHans Verkuil
v4l2_fh_init now returns void instead of int, updated the doc. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] Documentation: Improve cluster documentation and document the new ↵Hans Verkuil
autoclusters Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] v4l2-controls.txt: update to latest v4l2-ctrl.c changesHans Verkuil
2011-07-27[media] davinci vpbe: Readme text for Dm6446 vpbeManjunath Hadli
Please refer to this file for detailed documentation of davinci vpbe v4l2 driver. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Acked-by: Muralidharan Karicheri <m-karicheri2@ti.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27[media] V4L1 API has been moved into "legacy" on the linuxtv.org siteBjørn Mork
Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
