During the last media summit meeting it was decided to move this driver to
staging as the first step to removing it altogether.
Most webcams covered by this driver are now supported by gspca. Nobody has the
hardware to convert the remaining devices to gspca.
This driver needs a major overhaul to have it conform to the latest frameworks
and compliancy tests.
Without hardware, however, this is next to impossible. Given the fact that
this driver seems to be pretty much unused (it has been removed from Fedora
several versions ago and nobody complained about that), we decided to drop
this driver.
This patch moves it to staging. Some time in 2014 we will drop it completely.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Luca Risolia <luca.risolia@studio.unibo.it>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Fix some minor typos:
* informations => information
* there own => their own
* these => this
Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org>
corrections.
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Adds a new image sensor to the sn9c102 driver.
Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
- Add support for pair OV7630+SN9C120
- Better and safe locking mechanism of the device structure on open(),
close() and disconnect()
- Use kref for handling device deallocation
- Generic cleanups
* Default color improvements to the OV7660
@ Fix sn9c102_write_reg()
@ Fix sn9c102_i2c_try_raw_read()
@ Fix MI-0343
+ Add support for pair MI0360+SN9C120
+ Add more USB ids
@ Don't assume that SOF headers can't cross packets boundaries
@ Fix compression quality selection
+ Add support for MI-0360 image sensor
* Documentation updates
@ Fix sysfs
@ MI0343 rewritten
* HV7131R color fixes and add new ABLC control
* Rename the archive from "sn9c102" to "sn9c1xx"
* fix typos
* better support for TAS5110D
@ fix OV7630 wrong colors
@ Don't return an error if no input buffers are enqueued yet on VIDIOC_STREAMON
* Add informations about colorspaces
* More appropriate error codes in case of failure of some system calls
* More precise hardware detection
* Add more informations about supported hardware in the documentation
+ More supported devices
+ Add support for HV7131R image sensor
- Add support for SN9C105 and SN9C120
- Add some more USB device identifiers
- Add support for OV7660
- Implement audio ioctl's and VIDIOC_ENUM_FRAMESIZES
- Add preliminary support for 0x0c45/0x6007
- Documentation updates
- Generic improvements
This patch fixes typos in various Documentation txts. The patch addresses
some words starting with the letters 'H'-'M'.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
This patch fixes typos in various Documentation txts. This patch addresses some
words starting with the letters 'B'-'C'. There are also a few grammar fixes
thrown in for Randy. ;)
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
- Move documentation for usb v4l devices from
Documentation/usb to Documentation/video4linux.
- Removed trailing whitespace.
- Update Kconfig help text links to reflect the new file locations.
