path: root/Documentation/tracers
2009-04-09tracing: consolidate documentsLi Zefan
Move kmemtrace.txt, tracepoints.txt, ftrace.txt and mmiotrace.txt to the new trace/ directory. I didnt find any references to those documents in both source files and documents, so no extra work needs to be done. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> LKML-Reference: <49DD6E2B.6090200@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-15doc: mmiotrace.txt, buffer size control changePekka Paalanen
Impact: prevents confusing the user when buffer size is inadequate The tracing framework offers a resizeable buffer, which mmiotrace uses to record events. If the buffer is full, the following events will be lost. Events should not be lost, so the documentation instructs the user to increase the buffer size. The buffer size is set via a debugfs file. Mmiotrace documentation was not updated the same time the debugfs file was changed. The old file was tracing/trace_entries and first contained the number of entries the buffer had space for, per cpu. Nowadays this file is replaced with the file tracing/buffer_size_kb, which tells the amount of memory reserved for the buffer, per cpu, in kilobytes. Previously, a flag had to be toggled via the debugfs file tracing/tracing_enabled when the buffer size was changed. This is no longer necessary. The mmiotrace documentation is updated to reflect the current state of the tracing framework. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23tracing, doc: update mmiotrace documentationPekka Paalanen
Impact: update documentation Update to reflect the current state of the tracing framework: - "none" tracer has been replaced by "nop" tracer - tracing_enabled must be toggled when changing buffer size Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: inject markers via trace_marker filePekka Paalanen
Allow a user to inject a marker (TRACE_PRINT entry) into the trace ring buffer. The related file operations are derived from code by Frédéric Weisbecker <fweisbec@gmail.com>. Signed-off-by: Pekka Paalanen <pq@iki.fi> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-24doc: update mmiotrace doc to current statusPekka Paalanen
2008-05-24mmiotrace: add user documentationPekka Paalanen
Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
