[ Upstream commit fcd7c26901c83681532c6daac599e53d4df11738 ]
The two existing trusted key sources don't make use of the kernel RNG,
but instead let the hardware doing the sealing/unsealing also
generate the random key material. However, both users and future
backends may want to place less trust into the quality of the trust
source's random number generator and instead reuse the kernel entropy
pool, which can be seeded from multiple entropy sources.
Make this possible by adding a new trusted.rng parameter,
that will force use of the kernel RNG. In its absence, it's up
to the trust source to decide, which random numbers to use,
maintaining the existing behavior.
Suggested-by: Jarkko Sakkinen <jarkko@kernel.org>
Acked-by: Sumit Garg <sumit.garg@linaro.org>
Acked-by: Pankaj Gupta <pankaj.gupta@nxp.com>
Reviewed-by: David Gstir <david@sigma-star.at>
Reviewed-by: Pankaj Gupta <pankaj.gupta@nxp.com>
Reviewed-by: Jarkko Sakkinen <jarkko@kernel.org>
Tested-by: Pankaj Gupta <pankaj.gupta@nxp.com>
Tested-by: Michael Walle <michael@walle.cc> # on ls1028a (non-E and E)
Tested-by: John Ernberg <john.ernberg@actia.se> # iMX8QXP
Signed-off-by: Ahmad Fatoum <a.fatoum@pengutronix.de>
Signed-off-by: Jarkko Sakkinen <jarkko@kernel.org>
Stable-dep-of: 01bbafc63b65 ("KEYS: trusted: Remove redundant static calls usage")
Update documentation for Trusted and Encrypted Keys with TEE as a new
trust source. Following is brief description of updates:
- Add a section to demonstrate a list of supported devices along with
their security properties/guarantees.
- Add a key generation section.
- Updates for usage section including differences specific to a trust
source.
Co-developed-by: Elaine Palmer <erpalmer@us.ibm.com>
Signed-off-by: Elaine Palmer <erpalmer@us.ibm.com>
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
Modify the TPM2 key format blob output to export and import in the
ASN.1 form for TPM2 sealed object keys. For compatibility with prior
trusted keys, the importer will also accept two TPM2B quantities
representing the public and private parts of the key. However, the
export via keyctl pipe will only output the ASN.1 format.
The benefit of the ASN.1 format is that it's a standard and thus the
exported key can be used by userspace tools (openssl_tpm2_engine,
openconnect and tpm2-tss-engine). The format includes policy
specifications, thus it gets us out of having to construct policy
handles in userspace and the format includes the parent meaning you
don't have to keep passing it in each time.
This patch only implements basic handling for the ASN.1 format, so
keys with passwords but no policy.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Tested-by: Jarkko Sakkinen <jarkko@kernel.org>
The merged API doesn't use a watch_queue device, but instead relies on
pipes, so let the documentation reflect that.
Fixes: f7e47677e39a ("watch_queue: Add a key/keyring notification facility")
Signed-off-by: Gabriel Krisman Bertazi <krisman@collabora.com>
Acked-by: Jarkko Sakkinen <jarkko@kernel.org>
Reviewed-by: Ben Boeckel <mathstuf@gmail.com>
The parameters in command examples for tpm2_createprimary and
tpm2_evictcontrol are outdated, people (like me) are not able to create
trusted key by these command examples.
This patch updates the parameters of command example tpm2_createprimary
and tpm2_evictcontrol in trusted-encrypted.rst. With Linux kernel v5.8
and tpm2-tools-4.1, people can create a trusted key by following the
examples in this document.
Signed-off-by: Coly Li <colyli@suse.de>
Reviewed-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Reviewed-by: Stefan Berger <stefanb@linux.ibm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: James Bottomley <jejb@linux.ibm.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: Mimi Zohar <zohar@linux.ibm.com>
Cc: Peter Huewe <peterhuewe@gmx.de>
Link: https://lore.kernel.org/r/20200821135356.15737-1-colyli@suse.de
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Drop the doubled word "in".
Acked-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: linux-doc@vger.kernel.org
Cc: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
Cc: linux-integrity@vger.kernel.org
Cc: keyrings@vger.kernel.org
Link: https://lore.kernel.org/r/20200707180414.10467-19-rdunlap@infradead.org
This file is almost compatible with ReST. Just minor changes
were needed:
- Adjust document and titles markups;
- Adjust numbered list markups;
- Add a comments markup for the Contents section;
- Add markups for literal blocks.
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
Link: https://lore.kernel.org/r/c2275ea94e0507a01b020ab66dfa824d8b1c2545.1592203650.git.mchehab+huawei@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull notification queue from David Howells:
"This adds a general notification queue concept and adds an event
source for keys/keyrings, such as linking and unlinking keys and
changing their attributes.
Thanks to Debarshi Ray, we do have a pull request to use this to fix a
problem with gnome-online-accounts - as mentioned last time:
https://gitlab.gnome.org/GNOME/gnome-online-accounts/merge_requests/47
Without this, g-o-a has to constantly poll a keyring-based kerberos
cache to find out if kinit has changed anything.
[ There are other notification pending: mount/sb fsinfo notifications
for libmount that Karel Zak and Ian Kent have been working on, and
Christian Brauner would like to use them in lxc, but let's see how
this one works first ]
LSM hooks are included:
- A set of hooks are provided that allow an LSM to rule on whether or
not a watch may be set. Each of these hooks takes a different
"watched object" parameter, so they're not really shareable. The
LSM should use current's credentials. [Wanted by SELinux & Smack]
- A hook is provided to allow an LSM to rule on whether or not a
particular message may be posted to a particular queue. This is
given the credentials from the event generator (which may be the
system) and the watch setter. [Wanted by Smack]
I've provided SELinux and Smack with implementations of some of these
hooks.
WHY
Key/keyring notifications are desirable because if you have your
kerberos tickets in a file/directory, your Gnome desktop will monitor
that using something like fanotify and tell you if your credentials
cache changes.
However, we also have the ability to cache your kerberos tickets in
the session, user or persistent keyring so that it isn't left around
on disk across a reboot or logout. Keyrings, however, cannot currently
be monitored asynchronously, so the desktop has to poll for it - not
so good on a laptop. This facility will allow the desktop to avoid the
need to poll.
DESIGN DECISIONS
- The notification queue is built on top of a standard pipe. Messages
are effectively spliced in. The pipe is opened with a special flag:
pipe2(fds, O_NOTIFICATION_PIPE);
The special flag has the same value as O_EXCL (which doesn't seem
like it will ever be applicable in this context)[?]. It is given up
front to make it a lot easier to prohibit splice&co from accessing
the pipe.
[?] Should this be done some other way? I'd rather not use up a new
O_* flag if I can avoid it - should I add a pipe3() system call
instead?
The pipe is then configured::
ioctl(fds[1], IOC_WATCH_QUEUE_SET_SIZE, queue_depth);
ioctl(fds[1], IOC_WATCH_QUEUE_SET_FILTER, &filter);
Messages are then read out of the pipe using read().
- It should be possible to allow write() to insert data into the
notification pipes too, but this is currently disabled as the
kernel has to be able to insert messages into the pipe *without*
holding pipe->mutex and the code to make this work needs careful
auditing.
- sendfile(), splice() and vmsplice() are disabled on notification
pipes because of the pipe->mutex issue and also because they
sometimes want to revert what they just did - but one or more
notification messages might've been interleaved in the ring.
- The kernel inserts messages with the wait queue spinlock held. This
means that pipe_read() and pipe_write() have to take the spinlock
to update the queue pointers.
- Records in the buffer are binary, typed and have a length so that
they can be of varying size.
This allows multiple heterogeneous sources to share a common
buffer; there are 16 million types available, of which I've used
just a few, so there is scope for others to be used. Tags may be
specified when a watchpoint is created to help distinguish the
sources.
- Records are filterable as types have up to 256 subtypes that can be
individually filtered. Other filtration is also available.
- Notification pipes don't interfere with each other; each may be
bound to a different set of watches. Any particular notification
will be copied to all the queues that are currently watching for it
- and only those that are watching for it.
- When recording a notification, the kernel will not sleep, but will
rather mark a queue as having lost a message if there's
insufficient space. read() will fabricate a loss notification
message at an appropriate point later.
- The notification pipe is created and then watchpoints are attached
to it, using one of:
keyctl_watch_key(KEY_SPEC_SESSION_KEYRING, fds[1], 0x01);
watch_mount(AT_FDCWD, "/", 0, fd, 0x02);
watch_sb(AT_FDCWD, "/mnt", 0, fd, 0x03);
where in both cases, fd indicates the queue and the number after is
a tag between 0 and 255.
- Watches are removed if either the notification pipe is destroyed or
the watched object is destroyed. In the latter case, a message will
be generated indicating the enforced watch removal.
Things I want to avoid:
- Introducing features that make the core VFS dependent on the
network stack or networking namespaces (ie. usage of netlink).
- Dumping all this stuff into dmesg and having a daemon that sits
there parsing the output and distributing it as this then puts the
responsibility for security into userspace and makes handling
namespaces tricky. Further, dmesg might not exist or might be
inaccessible inside a container.
- Letting users see events they shouldn't be able to see.
TESTING AND MANPAGES
- The keyutils tree has a pipe-watch branch that has keyctl commands
for making use of notifications. Proposed manual pages can also be
found on this branch, though a couple of them really need to go to
the main manpages repository instead.
If the kernel supports the watching of keys, then running "make
test" on that branch will cause the testing infrastructure to spawn
a monitoring process on the side that monitors a notifications pipe
for all the key/keyring changes induced by the tests and they'll
all be checked off to make sure they happened.
https://git.kernel.org/pub/scm/linux/kernel/git/dhowells/keyutils.git/log/?h=pipe-watch
- A test program is provided (samples/watch_queue/watch_test) that
can be used to monitor for keyrings, mount and superblock events.
Information on the notifications is simply logged to stdout"
* tag 'notifications-20200601' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
smack: Implement the watch_key and post_notification hooks
selinux: Implement the watch_key security hook
keys: Make the KEY_NEED_* perms an enum rather than a mask
pipe: Add notification lossage handling
pipe: Allow buffers to be marked read-whole-or-error for notifications
Add sample notification program
security: Add hooks to rule on setting a watch
pipe: Add general notification queue support
pipe: Add O_NOTIFICATION_PIPE
security: Add a hook for the point of notification insertion
uapi: General notification queue definitions
This argument was just never documented in the first place.
Signed-off-by: Ben Boeckel <mathstuf@gmail.com>
Add a key/keyring change notification facility whereby notifications about
changes in key and keyring content and attributes can be received.
Firstly, an event queue needs to be created:
ioctl(fds[1], IOC_WATCH_QUEUE_SET_SIZE, 256);
then a notification can be set up to report notifications via that queue:
struct watch_notification_filter filter = {
.nr_filters = 1,
.filters = {
[0] = {
.type = WATCH_TYPE_KEY_NOTIFY,
.subtype_filter[0] = UINT_MAX,
After that, records will be placed into the queue when events occur in
which keys are changed in some way. Records are of the following format:
struct key_notification {
struct watch_notification watch;
__u32 key_id;
__u32 aux;
} *n;
Where:
n->watch.type will be WATCH_TYPE_KEY_NOTIFY.
n->watch.subtype will indicate the type of event, such as
NOTIFY_KEY_REVOKED.
n->watch.info & WATCH_INFO_LENGTH will indicate the length of the
record.
n->watch.info & WATCH_INFO_ID will be the second argument to
keyctl_watch_key(), shifted.
n->key will be the ID of the affected key.
n->aux will hold subtype-dependent information, such as the key
being linked into the keyring specified by n->key in the case of
NOTIFY_KEY_LINKED.
Note that it is permissible for event records to be of variable length -
or, at least, the length may be dependent on the subtype. Note also that
the queue can be shared between multiple notifications of various types.
Reviewed-by: James Morris <jamorris@linux.microsoft.com>
Fix warnings due to missing markup, no change in content otherwise.
Signed-off-by: Daniel W. S. Almeida <dwlsalmeida@gmail.com>
Link: https://lore.kernel.org/r/20191122041806.68650-1-dwlsalmeida@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs"
This reverts merge 0f75ef6a9cff49ff612f7ce0578bced9d0b38325 (and thus
effectively commits
7a1ade847596 ("keys: Provide KEYCTL_GRANT_PERMISSION")
2e12256b9a76 ("keys: Replace uid/gid/perm permissions checking with an ACL")
that the merge brought in).
It turns out that it breaks booting with an encrypted volume, and Eric
biggers reports that it also breaks the fscrypt tests [1] and loading of
in-kernel X.509 certificates [2].
The root cause of all the breakage is likely the same, but David Howells
is off email so rather than try to work it out it's getting reverted in
order to not impact the rest of the merge window.
[1] https://lore.kernel.org/lkml/20190710011559.GA7973@sol.localdomain/
[2] https://lore.kernel.org/lkml/20190710013225.GB7973@sol.localdomain/
Link: https://lore.kernel.org/lkml/CAHk-=wjxoeMJfeBahnWH=9zShKp2bsVy527vo3_y8HfOdhwAAw@mail.gmail.com/
Reported-by: Eric Biggers <ebiggers@kernel.org>
Pull Documentation updates from Jonathan Corbet:
"It's been a relatively busy cycle for docs:
- A fair pile of RST conversions, many from Mauro. These create more
than the usual number of simple but annoying merge conflicts with
other trees, unfortunately. He has a lot more of these waiting on
the wings that, I think, will go to you directly later on.
- A new document on how to use merges and rebases in kernel repos,
and one on Spectre vulnerabilities.
- Various improvements to the build system, including automatic
markup of function() references because some people, for reasons I
will never understand, were of the opinion that
:c:func:``function()`` is unattractive and not fun to type.
- We now recommend using sphinx 1.7, but still support back to 1.4.
- Lots of smaller improvements, warning fixes, typo fixes, etc"
* tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits)
docs: automarkup.py: ignore exceptions when seeking for xrefs
docs: Move binderfs to admin-guide
Disable Sphinx SmartyPants in HTML output
doc: RCU callback locks need only _bh, not necessarily _irq
docs: format kernel-parameters -- as code
Doc : doc-guide : Fix a typo
platform: x86: get rid of a non-existent document
Add the RCU docs to the core-api manual
Documentation: RCU: Add TOC tree hooks
Documentation: RCU: Rename txt files to rst
Documentation: RCU: Convert RCU UP systems to reST
Documentation: RCU: Convert RCU linked list to reST
Documentation: RCU: Convert RCU basic concepts to reST
docs: filesystems: Remove uneeded .rst extension on toctables
scripts/sphinx-pre-install: fix out-of-tree build
docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/
Documentation: PGP: update for newer HW devices
Documentation: Add section about CPU vulnerabilities for Spectre
Documentation: platform: Delete x86-laptop-drivers.txt
docs: Note that :c:func: should no longer be used
Replace the uid/gid/perm permissions checking on a key with an ACL to allow
the SETATTR and SEARCH permissions to be split. This will also allow a
greater range of subjects to represented.
WHY DO THIS?
The problem is that SETATTR and SEARCH cover a slew of actions, not all of
which should be grouped together.
For SETATTR, this includes actions that are about controlling access to a
key:
(1) Changing a key's ownership.
(2) Changing a key's security information.
(3) Setting a keyring's restriction.
And actions that are about managing a key's lifetime:
(4) Setting an expiry time.
(5) Revoking a key.
and (proposed) managing a key as part of a cache:
(6) Invalidating a key.
Managing a key's lifetime doesn't really have anything to do with
controlling access to that key.
Expiry time is awkward since it's more about the lifetime of the content
and so, in some ways goes better with WRITE permission. It can, however,
be set unconditionally by a process with an appropriate authorisation token
for instantiating a key, and can also be set by the key type driver when a
key is instantiated, so lumping it with the access-controlling actions is
probably okay.
As for SEARCH permission, that currently covers:
(1) Finding keys in a keyring tree during a search.
(2) Permitting keyrings to be joined.
(3) Invalidation.
But these don't really belong together either, since these actions really
need to be controlled separately.
Finally, there are number of special cases to do with granting the
administrator special rights to invalidate or clear keys that I would like
to handle with the ACL rather than key flags and special checks.
WHAT IS CHANGED
The SETATTR permission is split to create two new permissions:
(1) SET_SECURITY - which allows the key's owner, group and ACL to be
changed and a restriction to be placed on a keyring.
(2) REVOKE - which allows a key to be revoked.
The SEARCH permission is split to create:
(1) SEARCH - which allows a keyring to be search and a key to be found.
(2) JOIN - which allows a keyring to be joined as a session keyring.
(3) INVAL - which allows a key to be invalidated.
The WRITE permission is also split to create:
(1) WRITE - which allows a key's content to be altered and links to be
added, removed and replaced in a keyring.
(2) CLEAR - which allows a keyring to be cleared completely. This is
split out to make it possible to give just this to an administrator.
(3) REVOKE - see above.
Keys acquire ACLs which consist of a series of ACEs, and all that apply are
unioned together. An ACE specifies a subject, such as:
(*) Possessor - permitted to anyone who 'possesses' a key
(*) Owner - permitted to the key owner
(*) Group - permitted to the key group
(*) Everyone - permitted to everyone
Note that 'Other' has been replaced with 'Everyone' on the assumption that
you wouldn't grant a permit to 'Other' that you wouldn't also grant to
everyone else.
Further subjects may be made available by later patches.
The ACE also specifies a permissions mask. The set of permissions is now:
VIEW Can view the key metadata
READ Can read the key content
WRITE Can update/modify the key content
SEARCH Can find the key by searching/requesting
LINK Can make a link to the key
SET_SECURITY Can change owner, ACL, expiry
INVAL Can invalidate
REVOKE Can revoke
JOIN Can join this keyring
CLEAR Can clear this keyring
The KEYCTL_SETPERM function is then deprecated.
The KEYCTL_SET_TIMEOUT function then is permitted if SET_SECURITY is set,
or if the caller has a valid instantiation auth token.
The KEYCTL_INVALIDATE function then requires INVAL.
The KEYCTL_REVOKE function then requires REVOKE.
The KEYCTL_JOIN_SESSION_KEYRING function then requires JOIN to join an
existing keyring.
The JOIN permission is enabled by default for session keyrings and manually
created keyrings only.
BACKWARD COMPATIBILITY
To maintain backward compatibility, KEYCTL_SETPERM will translate the
permissions mask it is given into a new ACL for a key - unless
KEYCTL_SET_ACL has been called on that key, in which case an error will be
returned.
It will convert possessor, owner, group and other permissions into separate
ACEs, if each portion of the mask is non-zero.
SETATTR permission turns on all of INVAL, REVOKE and SET_SECURITY. WRITE
permission turns on WRITE, REVOKE and, if a keyring, CLEAR. JOIN is turned
on if a keyring is being altered.
The KEYCTL_DESCRIBE function translates the ACL back into a permissions
mask to return depending on possessor, owner, group and everyone ACEs.
It will make the following mappings:
(1) INVAL, JOIN -> SEARCH
(2) SET_SECURITY -> SETATTR
(3) REVOKE -> WRITE if SETATTR isn't already set
(4) CLEAR -> WRITE
Note that the value subsequently returned by KEYCTL_DESCRIBE may not match
the value set with KEYCTL_SETATTR.
TESTING
This passes the keyutils testsuite for all but a couple of tests:
(1) tests/keyctl/dh_compute/badargs: The first wrong-key-type test now
returns EOPNOTSUPP rather than ENOKEY as READ permission isn't removed
if the type doesn't have ->read(). You still can't actually read the
key.
(2) tests/keyctl/permitting/valid: The view-other-permissions test doesn't
work as Other has been replaced with Everyone in the ACL.
Create a request_key_net() function and use it to pass the network
namespace domain tag into DNS revolver keys and rxrpc/AFS keys so that keys
for different domains can coexist in the same keyring.
cc: netdev@vger.kernel.org
cc: linux-nfs@vger.kernel.org
cc: linux-cifs@vger.kernel.org
cc: linux-afs@lists.infradead.org
Add a 'recurse' flag for keyring searches so that the flag can be omitted
and recursion disabled, thereby allowing just the nominated keyring to be
searched and none of the children.
Kill off request_key_async{,_with_auxdata}() as they're not currently used.
If a filesystem uses keys to hold authentication tokens, then it needs a
token for each VFS operation that might perform an authentication check -
either by passing it to the server, or using to perform a check based on
authentication data cached locally.
For open files this isn't a problem, since the key should be cached in the
file struct since it represents the subject performing operations on that
file descriptor.
During pathwalk, however, there isn't anywhere to cache the key, except
perhaps in the nameidata struct - but that isn't exposed to the
filesystems. Further, a pathwalk can incur a lot of operations, calling
one or more of the following, for instance:
->lookup()
->permission()
->d_revalidate()
->d_automount()
->get_acl()
->getxattr()
on each dentry/inode it encounters - and each one may need to call
request_key(). And then, at the end of pathwalk, it will call the actual
operation:
->mkdir()
->mknod()
->getattr()
->open()
which may need to go and get the token again.
However, it is very likely that all of the operations on a single
dentry/inode - and quite possibly a sequence of them - will all want to use
the same authentication token, which suggests that caching it would be a
good idea.
To this end:
(1) Make it so that a positive result of request_key() and co. that didn't
require upcalling to userspace is cached temporarily in task_struct.
(2) The cache is 1 deep, so a new result displaces the old one.
(3) The key is released by exit and by notify-resume.
(4) The cache is cleared in a newly forked process.
Provide a request_key_rcu() function that can be used to request a key
under RCU conditions. It can only search and check permissions; it cannot
allocate a new key, upcall or wait for an upcall to complete. It may
return a partially constructed key.
Move the RCU locks outwards from the keyring search functions so that it
will become possible to provide an RCU-capable partial request_key()
function in a later commit.
The request_key() syscall allows a process to gain access to the 'possessor'
permits of any key that grants it Search permission by virtue of request_key()
not checking whether a key it finds grants Link permission to the caller.
Multi-line literal markups only work when they're idented at the
same level, with is not the case here:
Documentation/security/keys/core.rst:1597: WARNING: Inline literal start-string without end-string.
Documentation/security/keys/core.rst:1597: WARNING: Inline emphasis start-string without end-string.
Documentation/security/keys/core.rst:1598: WARNING: Inline emphasis start-string without end-string.
Documentation/security/keys/core.rst:1600: WARNING: Inline literal start-string without end-string.
Documentation/security/keys/core.rst:1600: WARNING: Inline emphasis start-string without end-string.
Documentation/security/keys/core.rst:1666: WARNING: Inline literal start-string without end-string.
Documentation/security/keys/core.rst:1666: WARNING: Inline emphasis start-string without end-string.
Fix it by using a code-block instead.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
The code-block tag is at the wrong place, causing those
warnings:
Documentation/security/keys/trusted-encrypted.rst:112: WARNING: Literal block expected; none found.
Documentation/security/keys/trusted-encrypted.rst:121: WARNING: Unexpected indentation.
Documentation/security/keys/trusted-encrypted.rst:122: WARNING: Block quote ends without a blank line; unexpected unindent.
Documentation/security/keys/trusted-encrypted.rst:123: WARNING: Block quote ends without a blank line; unexpected unindent.
Acked-by: James Morris <jamorris@linux.microsoft.com>
Add a keyctl to atomically move a link to a key from one keyring to
another. The key must exist in "from" keyring and a flag can be given to
cause the operation to fail if there's a matching key already in the "to"
keyring.
This can be done with:
keyctl(KEYCTL_MOVE,
key_serial_t key,
key_serial_t from_keyring,
key_serial_t to_keyring,
unsigned int flags);
The key being moved must grant Link permission and both keyrings must grant
Write permission.
flags should be 0 or KEYCTL_MOVE_EXCL, with the latter preventing
displacement of a matching key from the "to" keyring.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull integrity updates from James Morris:
"In Linux 4.19, a new LSM hook named security_kernel_load_data was
upstreamed, allowing LSMs and IMA to prevent the kexec_load syscall.
Different signature verification methods exist for verifying the
kexec'ed kernel image. This adds additional support in IMA to prevent
loading unsigned kernel images via the kexec_load syscall,
independently of the IMA policy rules, based on the runtime "secure
boot" flag. An initial IMA kselftest is included.
In addition, this pull request defines a new, separate keyring named
".platform" for storing the preboot/firmware keys needed for verifying
the kexec'ed kernel image's signature and includes the associated IMA
kexec usage of the ".platform" keyring.
(David Howell's and Josh Boyer's patches for reading the
preboot/firmware keys, which were previously posted for a different
use case scenario, are included here)"
* 'next-integrity' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
integrity: Remove references to module keyring
ima: Use inode_is_open_for_write
ima: Support platform keyring for kernel appraisal
efi: Allow the "db" UEFI variable to be suppressed
efi: Import certificates from UEFI Secure Boot
efi: Add an EFI signature blob parser
efi: Add EFI signature data types
integrity: Load certs to the platform keyring
integrity: Define a trusted platform keyring
selftests/ima: kexec_load syscall test
ima: don't measure/appraise files on efivarfs
x86/ima: retry detecting secure boot mode
docs: Extend trusted keys documentation for TPM 2.0
x86/ima: define arch_get_ima_policy() for x86
ima: add support for arch specific policies
ima: refactor ima_init_policy()
ima: prevent kexec_load syscall based on runtime secureboot flag
x86/ima: define arch_ima_get_secureboot
integrity: support new struct public_key_signature encoding field
Pull documentation update from Jonathan Corbet:
"A fairly normal cycle for documentation stuff. We have a new document
on perf security, more Italian translations, more improvements to the
memory-management docs, improvements to the pathname lookup
documentation, and the usual array of smaller fixes.
As is often the case, there are a few reaches outside of
Documentation/ to adjust kerneldoc comments"
* tag 'docs-5.0' of git://git.lwn.net/linux: (38 commits)
docs: improve pathname-lookup document structure
configfs: fix wrong name of struct in documentation
docs/mm-api: link slab_common.c to "The Slab Cache" section
slab: make kmem_cache_create{_usercopy} description proper kernel-doc
doc:process: add links where missing
docs/core-api: make mm-api.rst more structured
x86, boot: documentation whitespace fixup
Documentation: devres: note checking needs when converting
doc:it: add some process/* translations
doc:it: fixes in process/1.Intro
Documentation: convert path-lookup from markdown to resturctured text
Documentation/admin-guide: update admin-guide index.rst
Documentation/admin-guide: introduce perf-security.rst file
scripts/kernel-doc: Fix struct and struct field attribute processing
Documentation: dev-tools: Fix typos in index.rst
Correct gen_init_cpio tool's documentation
Document /proc/pid PID reuse behavior
Documentation: update path-lookup.md for parallel lookups
Documentation: Use "while" instead of "whilst"
dmaengine: Add mailing list address to the documentation
Adding nvdimm key format type to encrypted keys in order to limit the size
of the key to 32bytes.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Acked-by: Mimi Zohar <zohar@linux.ibm.com>
Extend the documentation for trusted keys with documentation for how to
set up a key for a TPM 2.0 so it can be used with a TPM 2.0 as well.
Signed-off-by: Stefan Berger <stefanb@linux.ibm.com>
Reviewed-by: Mimi Zohar <zohar@linux.ibm.com>
Reviewed-by: Dave Jiang <dave.jiang@intel.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Acked-by: Jerry Snitselaar <jsnitsel@redhat.com>
Signed-off-by: Mimi Zohar <zohar@linux.ibm.com>
Whilst making an unrelated change to some Documentation, Linus sayeth:
| Afaik, even in Britain, "whilst" is unusual and considered more
| formal, and "while" is the common word.
| Can we just admit that we work with computers, and we don't need to
| use þe eald Englisc spelling of words that most of the world never
| uses?
dictionary.com refers to the word as "Chiefly British", which is
probably an undesirable attribute for technical documentation.
Replace all occurrences under Documentation/ with "while".
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Michael Halcrow <mhalcrow@google.com>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Provide five keyctl functions that permit userspace to make use of the new
key type ops for accessing and driving asymmetric keys.
(*) Query an asymmetric key.
long keyctl(KEYCTL_PKEY_QUERY,
key_serial_t key, unsigned long reserved,
struct keyctl_pkey_query *info);
Get information about an asymmetric key. The information is returned
in the keyctl_pkey_query struct:
__u32 supported_ops;
A bit mask of flags indicating which ops are supported. This is
constructed from a bitwise-OR of:
KEYCTL_SUPPORTS_{ENCRYPT,DECRYPT,SIGN,VERIFY}
__u32 key_size;
The size in bits of the key.
__u16 max_data_size;
__u16 max_sig_size;
__u16 max_enc_size;
__u16 max_dec_size;
The maximum sizes in bytes of a blob of data to be signed, a signature
blob, a blob to be encrypted and a blob to be decrypted.
reserved must be set to 0. This is intended for future use to hand
over one or more passphrases needed unlock a key.
If successful, 0 is returned. If the key is not an asymmetric key,
EOPNOTSUPP is returned.
(*) Encrypt, decrypt, sign or verify a blob using an asymmetric key.
long keyctl(KEYCTL_PKEY_ENCRYPT,
const struct keyctl_pkey_params *params,
const char *info,
const void *in,
void *out);
long keyctl(KEYCTL_PKEY_DECRYPT,
const char *info,
const void *in,
void *out);
long keyctl(KEYCTL_PKEY_SIGN,
const char *info,
const void *in,
void *out);
long keyctl(KEYCTL_PKEY_VERIFY,
const char *info,
const void *in,
const void *in2);
Use an asymmetric key to perform a public-key cryptographic operation
a blob of data.
The parameter block pointed to by params contains a number of integer
values:
__s32 key_id;
__u32 in_len;
__u32 out_len;
__u32 in2_len;
For a given operation, the in and out buffers are used as follows:
Operation ID in,in_len out,out_len in2,in2_len
KEYCTL_PKEY_ENCRYPT Raw data Encrypted data -
KEYCTL_PKEY_DECRYPT Encrypted data Raw data -
KEYCTL_PKEY_SIGN Raw data Signature -
KEYCTL_PKEY_VERIFY Raw data - Signature
info is a string of key=value pairs that supply supplementary
information.
The __spare space in the parameter block must be set to 0. This is
intended, amongst other things, to allow the passing of passphrases
required to unlock a key.
If successful, encrypt, decrypt and sign all return the amount of data
written into the output buffer. Verification returns 0 on success.
Tested-by: Marcel Holtmann <marcel@holtmann.org>
Reviewed-by: Marcel Holtmann <marcel@holtmann.org>
Reviewed-by: Denis Kenzior <denkenz@gmail.com>
Tested-by: Denis Kenzior <denkenz@gmail.com>
Signed-off-by: James Morris <james.morris@microsoft.com>
Provide five new operations in the key_type struct that can be used to
provide access to asymmetric key operations. These will be implemented for
the asymmetric key type in a later patch and may refer to a key retained in
RAM by the kernel or a key retained in crypto hardware.
int (*asym_query)(const struct kernel_pkey_params *params,
struct kernel_pkey_query *info);
int (*asym_eds_op)(struct kernel_pkey_params *params,
const void *in, void *out);
int (*asym_verify_signature)(struct kernel_pkey_params *params,
const void *in, const void *in2);
Since encrypt, decrypt and sign are identical in their interfaces, they're
rolled together in the asym_eds_op() operation and there's an operation ID
in the params argument to distinguish them.
Verify is different in that we supply the data and the signature instead
and get an error value (or 0) as the only result on the expectation that
this may well be how a hardware crypto device may work.
"FEFEK" was incorrectly used as acronym for "File Encryption Key
Encryption Key". This replaces all occurences with "FEKEK".
Signed-off-by: Felix Eckhofer <felix@eckhofer.com>
When keyctl_read() is passed a buffer that is too small, the behavior is
inconsistent. Some key types will fill as much of the buffer as
possible, while others won't copy anything. Moreover, the in-kernel
documentation contradicted the man page on this point.
Update the in-kernel documentation to say that this point is
unspecified.
Make security document refs valid.
Signed-off-by: Tom Saeger <tom.saeger@oracle.com>
Sphinx will now generate the table of contents automatically, which
avoids having the ToC getting out of sync with the rest of the document.
Signed-off-by: Josh Holland <anowlcalledjosh@gmail.com>
Several paths in the security/keys documentation were incorrect.
Provide more specific examples of keyring restrictions as applied to
X.509 signature chain verification.
Signed-off-by: Mat Martineau <mathew.j.martineau@linux.intel.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
The white space in the big enumerated list was inconsistent, leading to
some strange formatting artifacts.
Adjusts for ReST markup and moves under keys security devel index.
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
Cc: Tyler Hicks <tyhicks@canonical.com>
This creates a new section in the security development index for kernel
keys, and adjusts for ReST markup.
