path: root/Documentation/sched-design-CFS.txt
2008-02-07Documentation: create new scheduler/ subdirectoryJ. Bruce Fields
The top-level Documentation/ directory is unmanageably large, so we should take any obvious opportunities to move stuff into subdirectories. These sched-*.txt files seem an obvious easy case. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15sched: group scheduling, sysfs tunablesDhaval Giani
Add tunables in sysfs to modify a user's cpu share. A directory is created in sysfs for each new user in the system. /sys/kernel/uids/<uid>/cpu_share Reading this file returns the cpu shares granted for the user. Writing into this file modifies the cpu share for the user. Only an administrator is allowed to modify a user's cpu share. Ex: # cd /sys/kernel/uids/ # cat 512/cpu_share 1024 # echo 2048 > 512/cpu_share # cat 512/cpu_share 2048 # Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-09sched: mention CONFIG_SCHED_DEBUG in documentationThomas Voegtle
a little hint to switch on CONFIG_SCHED_DEBUG should be given. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-09sched: add CFS documentationIngo Molnar
add Documentation/sched-design-CFS.txt Signed-off-by: Ingo Molnar <mingo@elte.hu>
