It seemed odd to say "since 4.17" in a 4.4 kernel. Consider
rewording the reference to indicate where in the stable series
it was introduced as well as where it originated.
Signed-off-by: Mark Rustad <mrustad@gmail.com>
commit 3e67f106f619dcfaf6f4e2039599bdb69848c714 upstream.
Some users are willing to provision huge amounts of memory to be able
to perform reassembly reasonnably well under pressure.
Current memory tracking is using one atomic_t and integers.
Switch to atomic_long_t so that 64bit arches can use more than 2GB,
without any cost for 32bit arches.
Note that this patch avoids an overflow error, if high_thresh was set
to ~2GB, since this test in inet_frag_alloc() was never true :
if (... || frag_mem_limit(nf) > nf->high_thresh)
Tested:
$ echo 16000000000 >/proc/sys/net/ipv4/ipfrag_high_thresh
<frag DDOS>
$ grep FRAG /proc/net/sockstat
FRAG: inuse 14705885 memory 16000002880
$ nstat -n ; sleep 1 ; nstat | grep Reas
IpReasmReqds 3317150 0.0
IpReasmFails 3317112 0.0
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 648700f76b03b7e8149d13cc2bdb3355035258a9 upstream.
Some applications still rely on IP fragmentation, and to be fair linux
reassembly unit is not working under any serious load.
It uses static hash tables of 1024 buckets, and up to 128 items per bucket (!!!)
A work queue is supposed to garbage collect items when host is under memory
pressure, and doing a hash rebuild, changing seed used in hash computations.
This work queue blocks softirqs for up to 25 ms when doing a hash rebuild,
occurring every 5 seconds if host is under fire.
Then there is the problem of sharing this hash table for all netns.
It is time to switch to rhashtables, and allocate one of them per netns
to speedup netns dismantle, since this is a critical metric these days.
Lookup is now using RCU. A followup patch will even remove
the refcount hold/release left from prior implementation and save
a couple of atomic operations.
Before this patch, 16 cpus (16 RX queue NIC) could not handle more
than 1 Mpps frags DDOS.
After the patch, I reach 9 Mpps without any tuning, and can use up to 2GB
of storage for the fragments (exact number depends on frags being evicted
after timeout)
FRAG: inuse 1966916 memory 2140004608
A followup patch will change the limits for 64bit arches.
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Florian Westphal <fw@strlen.de>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Alexander Aring <alex.aring@gmail.com>
Cc: Stefan Schmidt <stefan@osg.samsung.com>
[bwh: Backported to 4.4: adjust context]
commit 3d2c86e3057995270e08693231039d9d942871f0 upstream.
Remove networking from Documentation Makefile to move the test to
selftests. Update networking/timestamping Makefile to work under
selftests. These tests will not be run as part of selftests suite
and will not be included in install targets. They can be built and
run separately for now.
This is part of the effort to move runnable code from Documentation.
Acked-by: Jonathan Corbet <corbet@lwn.net>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[ added to 4.4.y stable to remove a build warning - gregkh]
[ Upstream commit 75d4e704fa8d2cf33ff295e5b441317603d7f9fd ]
Per discussion with David at netconf 2018, let's clarify
DaveM's position of handling stable backports in netdev-FAQ.
This is important for people relying on upstream -stable
releases.
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream.
mmapped netlink has a number of unresolved issues:
- TX zerocopy support had to be disabled more than a year ago via
commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.")
because the content of the mmapped area can change after netlink
attribute validation but before message processing.
- RX support was implemented mainly to speed up nfqueue dumping packet
payload to userspace. However, since commit ae08ce0021087a5d812d2
("netfilter: nfnetlink_queue: zero copy support") we avoid one copy
with the socket-based interface too (via the skb_zerocopy helper).
The other problem is that skbs attached to mmaped netlink socket
behave different from normal skbs:
- they don't have a shinfo area, so all functions that use skb_shinfo()
(e.g. skb_clone) cannot be used.
- reserving headroom prevents userspace from seeing the content as
it expects message to start at skb->head.
See for instance
commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump").
- skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we
crash because it needs the sk to check if a tx ring is attached.
Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359
("netfilter: nfnetlink: use original skbuff when acking batches").
mmaped netlink also didn't play nicely with the skb_zerocopy helper
used by nfqueue and openvswitch. Daniel Borkmann fixed this via
commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue
zero-copy")' but at the cost of also needing to provide remaining
length to the allocation function.
nfqueue also has problems when used with mmaped rx netlink:
- mmaped netlink doesn't allow use of nfqueue batch verdict messages.
Problem is that in the mmap case, the allocation time also determines
the ordering in which the frame will be seen by userspace (A
allocating before B means that A is located in earlier ring slot,
but this also means that B might get a lower sequence number then A
since seqno is decided later. To fix this we would need to extend the
spinlocked region to also cover the allocation and message setup which
isn't desirable.
- nfqueue can now be configured to queue large (GSO) skbs to userspace.
Queing GSO packets is faster than having to force a software segmentation
in the kernel, so this is a desirable option. However, with a mmap based
ring one has to use 64kb per ring slot element, else mmap has to fall back
to the socket path (NL_MMAP_STATUS_COPY) for all large packets.
To use the mmap interface, userspace not only has to probe for mmap netlink
support, it also has to implement a recv/socket receive path in order to
handle messages that exceed the size of an rx ring element.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shi Yuejie <shiyuejie@outlook.com>
Apparently the e100.txt document contained a "License" section left
over from days of old, which does not need to be in the kernel
documentation. So clean it up..
CC: John Ronciak <john.ronciak@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
Pull more documentation updates from Jon Corbet:
"A few more documentation patches that wandered in and have no reason
to wait; these include some improvements to the suggestions for email
clients and patch submission"
* tag '4.4-additional' of git://git.lwn.net/linux:
Documentation: Add minimal Mutt config for using Gmail
Documentation: Add note on sending files directly with Mutt
Documentation: dontdiff: remove media from dontdiff
Documentation/SubmittingPatches: discuss In-Reply-To
Remove email address from Documentation/filesystems/overlayfs.txt
can-doc: Add missing semicolon to example
The example code for CAN_BCM,
connect(s, (struct sockaddr *)&addr, sizeof(addr))
lacks a semicolon at the end of the line. This patch adds that
missing semicolon to ensure that the given code snippet actually
compiles.
Signed-off-by: Stefan Tatschner <rumpelsepp@sevenbyte.org>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Pull networking fixes from David Miller:
1) Fix null deref in xt_TEE netfilter module, from Eric Dumazet.
2) Several spots need to get to the original listner for SYN-ACK
packets, most spots got this ok but some were not. Whilst covering
the remaining cases, create a helper to do this. From Eric Dumazet.
3) Missiing check of return value from alloc_netdev() in CAIF SPI code,
from Rasmus Villemoes.
4) Don't sleep while != TASK_RUNNING in macvtap, from Vlad Yasevich.
5) Use after free in mvneta driver, from Justin Maggard.
6) Fix race on dst->flags access in dst_release(), from Eric Dumazet.
7) Add missing ZLIB_INFLATE dependency for new qed driver. From Arnd
Bergmann.
8) Fix multicast getsockopt deadlock, from WANG Cong.
9) Fix deadlock in btusb, from Kuba Pawlak.
10) Some ipv6_add_dev() failure paths were not cleaning up the SNMP6
counter state. From Sabrina Dubroca.
11) Fix packet_bind() race, which can cause lost notifications, from
Francesco Ruggeri.
12) Fix MAC restoration in qlcnic driver during bonding mode changes,
from Jarod Wilson.
13) Revert bridging forward delay change which broke libvirt and other
userspace things, from Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
Revert "bridge: Allow forward delay to be cfgd when STP enabled"
bpf_trace: Make dependent on PERF_EVENTS
qed: select ZLIB_INFLATE
net: fix a race in dst_release()
net: mvneta: Fix memory use after free.
net: Documentation: Fix default value tcp_limit_output_bytes
macvtap: Resolve possible __might_sleep warning in macvtap_do_read()
mvneta: add FIXED_PHY dependency
net: caif: check return value of alloc_netdev
net: hisilicon: NET_VENDOR_HISILICON should depend on HAS_DMA
drivers: net: xgene: fix RGMII 10/100Mb mode
netfilter: nft_meta: use skb_to_full_sk() helper
net_sched: em_meta: use skb_to_full_sk() helper
sched: cls_flow: use skb_to_full_sk() helper
netfilter: xt_owner: use skb_to_full_sk() helper
smack: use skb_to_full_sk() helper
net: add skb_to_full_sk() helper and use it in selinux_netlbl_skbuff_setsid()
bpf: doc: correct arch list for supported eBPF JIT
dwc_eth_qos: Delete an unnecessary check before the function call "of_node_put"
bonding: fix panic on non-ARPHRD_ETHER enslave failure
Commit c39c4c6abb89 ("tcp: double default TSQ output bytes limit")
updated default value for tcp_limit_output_bytes
Signed-off-by: Niklas Cassel <niklas.cassel@axis.com>
aarch64 and s390x support eBPF JIT too, correct document to reflect this and
avoid any confusion.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Pull documentation update from Jon Corbet:
"There is a nice new document from Neil on how pathname lookups work
and some new CAN driver documentation. Beyond that, we have
kernel-doc fixes, a bit more work to support reproducible builds, and
the usual collection of small fixes"
* tag 'docs-for-linus' of git://git.lwn.net/linux: (34 commits)
Documentation: add new description of path-name lookup.
Documentation/vm/slub.txt: document slabinfo-gnuplot.sh
Doc: ABI/stable: Fix typo in ABI/stable
doc: Clarify that nmi_watchdog param is for hardlockups
Typo correction for description in gpio document.
DocBook: Fix kernel-doc to be case-insensitive for private:
kernel-docs.txt: update kernelnewbies reference
Doc:kvm: Fix typo in Doc/virtual/kvm
Documentation/Changes: Add bc in "Current Minimal Requirements" section
Documentation/email-clients.txt: remove trailing whitespace
DocBook: Use a fixed encoding for output
MAINTAINERS: The docs tree has moved
Docs/kernel-parameters: Add earlycon devicetree usage
SubmittingPatches: make Subject examples match the de facto standard
Documentation: gpio: mention that <function>-gpio has been deprecated
Documentation: cgroups: just fix a few typos
Documentation: Update kselftest.txt
Documentation: DMA API: Be more explicit that nents is always the same
Documentation: Update the default value of crashkernel low
zram: update documentation
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2015-10-30
1) The flow cache is limited by the flow cache limit which
depends on the number of cpus and the xfrm garbage collector
threshold which is independent of the number of cpus. This
leads to the fact that on systems with more than 16 cpus
we hit the xfrm garbage collector limit and refuse new
allocations, so new flows are dropped. On systems with 16
or less cpus, we hit the flowcache limit. In this case, we
shrink the flow cache instead of refusing new flows.
We increase the xfrm garbage collector threshold to INT_MAX
to get the same behaviour, independent of the number of cpus.
2) Fix some unaligned accesses on sparc systems.
From Sowmini Varadhan.
3) Fix some header checks in _decode_session4. We may call
pskb_may_pull with a negative value converted to unsigened
int from pskb_may_pull. This can lead to incorrect policy
lookups. We fix this by a check of the data pointer position
before we call pskb_may_pull.
4) Reload skb header pointers after calling pskb_may_pull
in _decode_session4 as this may change the pointers into
the packet.
5) Add a missing statistic counter on inner mode errors.
Please pull or let me know if there are problems.
In certain use cases it is not always desirable for the switch device to
flood traffic to CPU port. Instead, only certain packet types (e.g.
STP, LACP) should be trapped to it.
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Allow devices supporting this feature to control the flooding of unknown
unicast traffic, by making switchdev infrastructure propagate this setting
to the switch driver.
This patch implements the second half of RACK that uses the the most
recent transmit time among all delivered packets to detect losses.
tcp_rack_mark_lost() is called upon receiving a dubious ACK.
It then checks if an not-yet-sacked packet was sent at least
"reo_wnd" prior to the sent time of the most recently delivered.
If so the packet is deemed lost.
The "reo_wnd" reordering window starts with 1msec for fast loss
detection and changes to min-RTT/4 when reordering is observed.
We found 1msec accommodates well on tiny degree of reordering
(<3 pkts) on faster links. We use min-RTT instead of SRTT because
reordering is more of a path property but SRTT can be inflated by
self-inflicated congestion. The factor of 4 is borrowed from the
delayed early retransmit and seems to work reasonably well.
Since RACK is still experimental, it is now used as a supplemental
loss detection on top of existing algorithms. It is only effective
after the fast recovery starts or after the timeout occurs. The
fast recovery is still triggered by FACK and/or dupack threshold
instead of RACK.
We introduce a new sysctl net.ipv4.tcp_recovery for future
experiments of loss recoveries. For now RACK can be disabled by
setting it to 0.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Kathleen Nichols' algorithm for tracking the minimum RTT of a
data stream over some measurement window. It uses constant space
and constant time per update. Yet it almost always delivers
the same minimum as an implementation that has to keep all
the data in the window. The measurement window is tunable via
sysctl.net.ipv4.tcp_min_rtt_wlen with a default value of 5 minutes.
The algorithm keeps track of the best, 2nd best & 3rd best min
values, maintaining an invariant that the measurement time of
the n'th best >= n-1'th best. It also makes sure that the three
values are widely separated in the time window since that bounds
the worse case error when that data is monotonically increasing
over the window.
Upon getting a new min, we can forget everything earlier because
it has no value - the new min is less than everything else in the
window by definition and it's the most recent. So we restart fresh
on every new min and overwrites the 2nd & 3rd choices. The same
property holds for the 2nd & 3rd best.
Therefore we have to maintain two invariants to maximize the
information in the samples, one on values (1st.v <= 2nd.v <=
3rd.v) and the other on times (now-win <=1st.t <= 2nd.t <= 3rd.t <=
now). These invariants determine the structure of the code
The RTT input to the windowed filter is the minimum RTT measured
from ACK or SACK, or as the last resort from TCP timestamps.
The accessor tcp_min_rtt() returns the minimum RTT seen in the
window. ~0U indicates it is not available. The minimum is 1usec
even if the true RTT is below that.
Revert the commit e2ca690b657f ("ipv4/icmp: redirect messages
can use the ingress daddr as source"), which tried to introduce a more
suitable behaviour for ICMP redirect messages generated by VRRP routers.
However RFC 5798 section 8.1.1 states:
The IPv4 source address of an ICMP redirect should be the address
that the end-host used when making its next-hop routing decision.
while said commit used the generating packet destination
address, which do not match the above and in most cases leads to
no redirect packets to be generated.
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
Add ip commands with examples for creating VRF devics, enslaving interfaces
and dumping VRF-focused data (address, neighbors, routes).
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
This patch allows configuring how the source address of ICMP
redirect messages is selected; by default the old behaviour is
retained, while setting icmp_redirects_use_orig_daddr force the
usage of the destination address of the packet that caused the
redirect.
The new behaviour fits closely the RFC 5798 section 8.1.1, and fix the
following scenario:
Two machines are set up with VRRP to act as routers out of a subnet,
they have IPs x.x.x.1/24 and x.x.x.2/24, with VRRP holding on to
x.x.x.254/24.
If a host in said subnet needs to get an ICMP redirect from the VRRP
router, i.e. to reach a destination behind a different gateway, the
source IP in the ICMP redirect is chosen as the primary IP on the
interface that the packet arrived at, i.e. x.x.x.1 or x.x.x.2.
The host will then ignore said redirect, due to RFC 1122 section 3.2.2.2,
and will continue to use the wrong next-op.
To be aligned with obj.
Acked-by: Scott Feldman <sfeldma@gmail.com>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Suggested-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
The xfrm flowcache size is limited by the flowcache limit
(4096 * number of online cpus) and the xfrm garbage collector
threshold (2 * 32768), whatever is reached first. This means
that we can hit the garbage collector limit only on systems
with more than 16 cpus. On such systems we simply refuse
new allocations if we reach the limit, so new flows are dropped.
On syslems with 16 or less cpus, we hit the flowcache limit.
In this case, we shrink the flow cache instead of refusing new
flows.
The xfrm garbage collector threshold can still be set below
the flowcache limit to reduce the memory usage of the flowcache.
Tested-by: Dan Streetman <dan.streetman@canonical.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
net/ipv4/arp.c
The net/ipv4/arp.c conflict was one commit adding a new
local variable while another commit was deleting one.
No longer need explicit modprobe's and update to use ip instead
of deprecated ifconfig command.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Now, the memory allocation in prepare/commit state is done separatelly
in each driver (rocker). Introduce the similar mechanism in generic
switchdev code, in form of queue. That can be used not only for memory
allocations, but also for different items. Abort item destruction
is handled as well.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
Pablo Neira Ayuso says:
Netfilter/IPVS updates for net-next
The following patchset contains Netfilter/IPVS updates for your net-next tree
in this 4.4 development cycle, they are:
1) Schedule ICMP traffic to IPVS instances, this introduces a new schedule_icmp
proc knob to enable/disable it. By default is off to retain the old
behaviour. Patchset from Alex Gartrell.
I'm also including what Alex originally said for the record:
"The configuration of ipvs at Facebook is relatively straightforward. All
ipvs instances bgp advertise a set of VIPs and the network prefers the
nearest one or uses ECMP in the event of a tie. For the uninitiated, ECMP
deterministically and statelessly load balances by hashing the packet
(usually a 5-tuple of protocol, saddr, daddr, sport, and dport) and using
that number as an index (basic hash table type logic).
The problem is that ICMP packets (which contain really important
information like whether or not an MTU has been exceeded) will get a
different hash value and may end up at a different ipvs instance. With no
information about where to route these packets, they are dropped, creating
ICMP black holes and breaking Path MTU discovery. Suddenly, my mom's
pictures can't load and I'm fielding midday calls that I want nothing to do
with.
To address this, this patch set introduces the ability to schedule icmp
packets which is gated by a sysctl net.ipv4.vs.schedule_icmp. If set to 0,
the old behavior is maintained -- otherwise ICMP packets are scheduled."
2) Add another proc entry to ignore tunneled packets to avoid routing loops
from IPVS, also from Alex.
3) Fifteen patches from Eric Biederman to:
* Stop passing nf_hook_ops as parameter to the hook and use the state hook
object instead all around the netfilter code, so only the private data
pointer is passed to the registered hook function.
* Now that we've got state->net, propagate the netns pointer to netfilter hook
clients to avoid its computation over and over again. A good example of how
this has been simplified is the former TEE target (now nf_dup infrastructure)
since it has killed the ugly pick_net() function.
There's another round of netns updates from Eric Biederman making the line. To
avoid the patchbomb again to almost all the networking mailing list (that is 84
patches) I'd suggest we send you a pull request with no patches or let me know
if you prefer a better way.
https://git.kernel.org/pub/scm/linux/kernel/git/horms/ipvs-next
Simon Horman says:
IPVS Updates for v4.4
please consider these IPVS Updates for v4.4.
The updates include the following from Alex Gartrell:
* Scheduling of ICMP
* Sysctl to ignore tunneled packets; and hence some packet-looping scenarios
With Linux 3.15 the infrastructure for CAN FD hardware drivers had been
introduced into the kernel. Now the M_CAN driver and the peak_usb driver
support CAN FD. Update the documentation to show the latest CAN related
configuration options of 'ip' from iproute2 and describe the CAN FD specific
options to set the data bitrate and protocol version (ISO/non-ISO).
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Stefan Schmidt <stefan@osg.samsung.com>
Acked-by: Alexander Aring <alex.aring@gmail.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
This is a way to avoid nasty routing loops when multiple ipvs instances can
forward to eachother.
Signed-off-by: Alex Gartrell <agartrell@fb.com>
Signed-off-by: Simon Horman <horms@verge.net.au>
Pull networking updates from David Miller:
"Another merge window, another set of networking changes. I've heard
rumblings that the lightweight tunnels infrastructure has been voted
networking change of the year. But what do I know?
1) Add conntrack support to openvswitch, from Joe Stringer.
2) Initial support for VRF (Virtual Routing and Forwarding), which
allows the segmentation of routing paths without using multiple
devices. There are some semantic kinks to work out still, but
this is a reasonably strong foundation. From David Ahern.
3) Remove spinlock fro act_bpf fast path, from Alexei Starovoitov.
4) Ignore route nexthops with a link down state in ipv6, just like
ipv4. From Andy Gospodarek.
5) Remove spinlock from fast path of act_gact and act_mirred, from
Eric Dumazet.
6) Document the DSA layer, from Florian Fainelli.
7) Add netconsole support to bcmgenet, systemport, and DSA. Also
8) Add Mellanox Switch Driver and core infrastructure, from Jiri
Pirko.
9) Add support for "light weight tunnels", which allow for
encapsulation and decapsulation without bearing the overhead of a
full blown netdevice. From Thomas Graf, Jiri Benc, and a cast of
others.
10) Add Identifier Locator Addressing support for ipv6, from Tom
Herbert.
11) Support fragmented SKBs in iwlwifi, from Johannes Berg.
12) Allow perf PMUs to be accessed from eBPF programs, from Kaixu Xia.
13) Add BQL support to 3c59x driver, from Loganaden Velvindron.
14) Stop using a zero TX queue length to mean that a device shouldn't
have a qdisc attached, use an explicit flag instead. From Phil
Sutter.
15) Use generic geneve netdevice infrastructure in openvswitch, from
Pravin B Shelar.
16) Add infrastructure to avoid re-forwarding a packet in software
that was already forwarded by a hardware switch. From Scott
Feldman.
17) Allow AF_PACKET fanout function to be implemented in a bpf
program, from Willem de Bruijn"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1458 commits)
netfilter: nf_conntrack: make nf_ct_zone_dflt built-in
netfilter: nf_dup{4, 6}: fix build error when nf_conntrack disabled
net: fec: clear receive interrupts before processing a packet
ipv6: fix exthdrs offload registration in out_rt path
xen-netback: add support for multicast control
bgmac: Update fixed_phy_register()
sock, diag: fix panic in sock_diag_put_filterinfo
flow_dissector: Use 'const' where possible.
flow_dissector: Fix function argument ordering dependency
ixgbe: Resolve "initialized field overwritten" warnings
ixgbe: Remove bimodal SR-IOV disabling
ixgbe: Add support for reporting 2.5G link speed
ixgbe: fix bounds checking in ixgbe_setup_tc for 82598
ixgbe: support for ethtool set_rxfh
ixgbe: Avoid needless PHY access on copper phys
ixgbe: cleanup to use cached mask value
ixgbe: Remove second instance of lan_id variable
ixgbe: use kzalloc for allocating one thing
flow: Move __get_hash_from_flowi{4,6} into flow_dissector.c
ixgbe: Remove unused PCI bus types
An SFP module may have a link up/down status pin which can be
connection to a GPIO line of the host. Add support for reading such an
GPIO in the fixed_phy driver.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Document the addition of a new sysctl variable which controls the
generation of IGMP reports for link local multicast groups in the
224.0.0.X range.
IGMP reports for local multicast groups can now be optionally
inhibited by setting the value to zero e.g.:
echo 0 > /proc/sys/net/ipv4/igmp_link_local_mcast_reports
To retain backwards compatibility the previous behaviour is retained
by default on system boot or reverted by setting the value back to
non-zero.
Signed-off-by: Philip Downey <pdowney@brocade.com>
Add a document describing the Broadcom Starfigther 2 switch hardware,
its specifics, and how the driver is implemented and its specifics.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Describe how the DSA subsystem works, its design principles,
limitations, and describe in details how to implement a DSA switch
driver.
Acked-by: Andrew Lunn <andrew@lunn.ch>
When TCP pacing was added back in linux-3.12, we chose
to apply a fixed ratio of 200 % against current rate,
to allow probing for optimal throughput even during
slow start phase, where cwnd can be doubled every other gRTT.
At Google, we found it was better applying a different ratio
while in Congestion Avoidance phase.
This ratio was set to 120 %.
We've used the normal tcp_in_slow_start() helper for a while,
then tuned the condition to select the conservative ratio
as soon as cwnd >= ssthresh/2 :
- After cwnd reduction, it is safer to ramp up more slowly,
as we approach optimal cwnd.
- Initial ramp up (ssthresh == INFINITY) still allows doubling
cwnd every other RTT.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth-next
Johan Hedberg says:
pull request: bluetooth-next 2015-08-16
Here's what's likely the last bluetooth-next pull request for 4.3:
- 6lowpan/802.15.4 refactoring, cleanups & fixes
- Document 6lowpan netdev usage in Documentation/networking/6lowpan.txt
- Support for UART based QCA Bluetooth controllers
- Power management support for Broeadcom Bluetooth controllers
- Change LE connection initiation to always use passive scanning first
- Support for new Silicon Wave USB ID
Please let me know if there are any issues pulling. Thanks.
pull request (net-next): ipsec-next 2015-08-17
1) Fix IPv6 ECN decapsulation for IPsec interfamily tunnels.
From Thomas Egerer.
2) Use kmemdup instead of duplicating it in xfrm_dump_sa().
From Andrzej Hajda.
3) Pass oif to the xfrm lookups so that it gets set on the flow
and the resolver routines can match based on oif.
From David Ahern.
4) Add documentation for the new xfrm garbage collector threshold.
From Alexander Duyck.
Rocker driver tracks arp_tbl neighs to resolve IPv4 route nexthops. The
driver uses NETEVENT_NEIGH_UPDATE for neigh adds and updates, but there is
no event when the neigh is removed from the device (such as when the device
goes admin down). This patches hooks ndo_neigh_destroy so the driver can
know when a neigh is removed from the device. In response, the driver will
purge the neigh entry from its internal tbl.
I didn't find an in-tree users of ndo_neigh_destroy, so I'm not sure if
this ndo is vestigial or if there are out-of-tree users. In any case, it
does what I need here. An alternative design would be to generate
NETEVENT_NEIGH_UPDATE event when neigh is being destroyed, setting state to
NUD_NONE so driver knows neigh entry is dead.
A few things have changed since the previous version of the vxlan
documentation was written, so update it and correct some grammar and
such while we are at it.
Signed-off-by: Rick Jones <rick.jones2@hp.com>
This change adds documentation for xfrm4_gc_thresh and xfrm6_gc_thresh
based on the comments in commit eeb1b73378b56 ("xfrm: Increase the garbage
collector threshold").
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
This patch adds a 6lowpan.txt into the networking documentation
directory. Currently this documentation describes how the lowpan
private data of net devices will be handled.
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: linux-doc@vger.kernel.org
Suggested-by: Jukka Rissanen <jukka.rissanen@linux.intel.com>
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
Initialize auto_flowlabels to one. This enables automatic flow labels,
individual socket may disable them using the IPV6_AUTOFLOWLABEL socket
option.
Signed-off-by: Tom Herbert <tom@herbertland.com>
Change the meaning of net.ipv6.auto_flowlabels to provide a mode for
automatic flow labels generation. There are four modes:
0: flow labels are disabled
1: flow labels are enabled, sockets can opt-out
2: flow labels are allowed, sockets can opt-in
3: flow labels are enabled and enforced, no opt-out for sockets
np->autoflowlabel is initialized according to the sysctl value.
Commit 6fd99094de2b ("ipv6: Don't reduce hop limit for an interface")
disabled accept hop limit from RA if it is smaller than the current hop
limit for security stuff. But this behavior kind of break the RFC definition.
RFC 4861, 6.3.4. Processing Received Router Advertisements
A Router Advertisement field (e.g., Cur Hop Limit, Reachable Time,
and Retrans Timer) may contain a value denoting that it is
unspecified. In such cases, the parameter should be ignored and the
host should continue using whatever value it is already using.
If the received Cur Hop Limit value is non-zero, the host SHOULD set
its CurHopLimit variable to the received value.
So add sysctl option accept_ra_min_hop_limit to let user choose the minimum
hop limit value they can accept from RA. And set default to 1 to meet RFC
standards.
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Acked-by: YOSHIFUJI Hideaki <hideaki.yoshifuji@miraclelinux.com>
As all dwmac-* drivers have been converted to have a proper probe
function the setup callback can now be removed. Also remove the
free callback that wasn't used by any driver.
New dwmac-* drivers should implement standard probe and remove
functions to preform any needed setup and teardown.
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
