path: root/Documentation/kobject.txt
2009-01-06kobject: Make Documentation/kobject.txt a little more coherent.Rusty Russell
While reading Documentation/kobject.txt: Note kobject_rename does perform any locking or have a solid notion of what names are valid so the provide must provide their own sanity checking and serialization. I expect better: You never see me hard with time word making sentence coherent stuff. Ever. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-16kobject: Fix kobject_rename and !CONFIG_SYSFSEric W. Biederman
When looking at kobject_rename I found two bugs with that exist when sysfs support is disabled in the kernel. kobject_rename does not change the name on the kobject when sysfs support is not compiled in. kobject_rename without locking attempts to check the validity of a rename operation, which the kobject layer simply does not have the infrastructure to do. This patch documents the previously unstated requirement of kobject_rename that is the responsibility of the caller to provide mutual exclusion and to be certain that the new_name for the kobject is valid. This patch modifies sysfs_rename_dir in !CONFIG_SYSFS case to call kobject_set_name to actually change the kobject_name. This patch removes the bogus and misleading check in kobject_rename that attempts to see if a rename is valid. The check is bogus because we do not have the proper locking. The check is misleading because it looks like we can and do perform checking at the kobject level that we don't. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-11kobject: Documentation Spelling PatchDavid Brigada
Signed-off-by: David Brigada <brigad@rpi.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: update the kobject/kset documentationGreg Kroah-Hartman
This provides a much-needed kobject and kset documentation update. Thanks to Kay Sievers, Alan Stern, Jonathan Corbet, Randy Dunlap, Jan Engelhardt, and others for reviewing and providing help with this document. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove old, outdated documentation.Greg Kroah-Hartman
As we are replacing the documentation, it's easier to do this in a two stage pass, delete the old file and add the new one. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12driver core: remove subsystem_init()Greg Kroah-Hartman
There is only one user of it, and it is only a wrapper for kset_init(). Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: clean up removed functions from the documentationCornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-30kobject: update documentationCornelia Huck
Update kobject documentation: - Update structure definitions. - Remove documentation of removed struct subsystem. (First shot, uevent_ops probably need some documentation as well.) Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-11genhd.c reference in Documentation/kobjects.txtBrandon Philips
block/genhd.c no longer in drivers/. Update Documentation/kobjects.txt Signed-off-by: Brandon Philips <brandon@ifup.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
