path: root/Documentation/kernel-parameters.txt
2008-02-08The scheduled 'time' option removalAdrian Bunk
The scheduled removal of the 'time' option. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Merge branches 'release' and 'dsdt-override' into releaseLen Brown
2008-02-07ACPI: Add "acpi_no_initrd_override" kernel parameterÉric Piel
The acpi_no_initrd_override parameter permits to disable the load of an ACPI table from the initramfs. Signed-off-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-07PM: documentation cleanupsPavel Machek
Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-06ide-pci-generic: kill the unused ifdef/endif/MODULE codeDenis Cheng
with module_param macro, the __setup code can be killed now: const __setup("all-generic-ide", ide_generic_all_on); and the module name "generic.ko" is not descriptive to its functionality, can be changed in Makefile, the "ide-pci-generic.ko" is better. the ide-pci-generic.all-generic-ide parameter also documented in Documentation/kernel-parameters.txt Signed-off-by: Denis Cheng <crquan@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-03Documentation: Remove references to dead "st0x" and "tmc8xx" parms.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Documentation: Update to refer to correct "rcupdate" module nameRobert P. J. Day
2008-02-03Documentation: "decnet=" should read "decnet.addr=".Robert P. J. Day
2008-02-01ACPI suspend: Call _PTS before suspending devicesRafael J. Wysocki
The ACPI 1.0 specification wants us to put devices into low power states after executing the _PTS global control method, while ACPI 2.0 and later want us to do that in the reverse order. The current suspend code follows ACPI 2.0 in that respect which causes some ACPI 1.0x systems to hang during suspend (ref. http://bugzilla.kernel.org/show_bug.cgi?id=9528). Make the suspend code execute _PTS before putting devices into low power states (ie. in accordance with ACPI 1.0x) and provide a command line option to override the default if need be. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-30x86: GEODE add the "mfgptfix" boot time option to fix MFGPT timersWilly Tarreau
The new "mfgptfix" boot command line option may be usd to fix MFGPT timers on AMD Geode platforms when the BIOS has incorrectly applied a workaround. TinyBIOS version 0.98 is known to be affected, 0.99 fixes the problem by letting the user disable the workaround. Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86_32: trim memory by updating e820Yinghai Lu
when MTRRs are not covering the whole e820 table, we need to trim the RAM and need to update e820. reuse some code on 64-bit as well. here need to add early_get_cap and use it in early_cpu_detect, and move mtrr_bp_init early. The code successfully trimmed the memory map on Justin's system: from: [ 0.000000] BIOS-e820: 0000000100000000 - 000000022c000000 (usable) to: [ 0.000000] modified: 0000000100000000 - 0000000228000000 (usable) [ 0.000000] modified: 0000000228000000 - 000000022c000000 (reserved) According to Justin it makes quite a difference: | When I boot the box without any trimming it acts like a 286 or 386, | takes about 10 minutes to boot (using raptor disks). Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Tested-by: Justin Piszcz <jpiszcz@lucidpixels.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: add generic clearcpuid=... optionAndi Kleen
Add a generic option to clear any cpuid bit. I added it because it was very easy to add with the new generic cpuid disable bitmap and perhaps it will be useful in the future. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: add noclflush optionAndi Kleen
To disable CLFLUSH usage, especially in change_page_attr(). Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86, 32-bit: trim memory not covered by wb mtrrsJesse Barnes
On some machines, buggy BIOSes don't properly setup WB MTRRs to cover all available RAM, meaning the last few megs (or even gigs) of memory will be marked uncached. Since Linux tends to allocate from high memory addresses first, this causes the machine to be unusably slow as soon as the kernel starts really using memory (i.e. right around init time). This patch works around the problem by scanning the MTRRs at boot and figuring out whether the current end_pfn value (setup by early e820 code) goes beyond the highest WB MTRR range, and if so, trimming it to match. A fairly obnoxious KERN_WARNING is printed too, letting the user know that not all of their memory is available due to a likely BIOS bug. Something similar could be done on i386 if needed, but the boot ordering would be slightly different, since the MTRR code on i386 depends on the boot_cpu_data structure being setup. This patch fixes a bug in the last patch that caused the code to run on non-Intel machines (AMD machines apparently don't need it and it's untested on other non-Intel machines, so best keep it off). Further enhancements and fixes from: Yinghai Lu <Yinghai.Lu@Sun.COM> Andi Kleen <ak@suse.de> Signed-off-by: Jesse Barnes <jesse.barnes@intel.com> Tested-by: Justin Piszcz <jpiszcz@lucidpixels.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: disable the GART early, 64-bitYinghai Lu
For K8 system: 4G RAM with memory hole remapping enabled, or more than 4G RAM installed. when try to use kexec second kernel, and the first doesn't include gart_shutdown. the second kernel could have different aper position than the first kernel. and second kernel could use that hole as RAM that is still used by GART set by the first kernel. esp. when try to kexec 2.6.24 with sparse mem enable from previous kernel (from RHEL 5 or SLES 10). the new kernel will use aper by GART (set by first kernel) for vmemmap. and after new kernel setting one new GART. the position will be real RAM. the _mapcount set is lost. Bad page state in process 'swapper' page:ffffe2000e600020 flags:0x0000000000000000 mapping:0000000000000000 mapcount:1 count:0 Trying to fix it up, but a reboot is needed Backtrace: Pid: 0, comm: swapper Not tainted 2.6.24-rc7-smp-gcdf71a10-dirty #13 Call Trace: [<ffffffff8026401f>] bad_page+0x63/0x8d [<ffffffff80264169>] __free_pages_ok+0x7c/0x2a5 [<ffffffff80ba75d1>] free_all_bootmem_core+0xd0/0x198 [<ffffffff80ba3a42>] numa_free_all_bootmem+0x3b/0x76 [<ffffffff80ba3461>] mem_init+0x3b/0x152 [<ffffffff80b959d3>] start_kernel+0x236/0x2c2 [<ffffffff80b9511a>] _sinittext+0x11a/0x121 and [ffffe2000e600000-ffffe2000e7fffff] PMD ->ffff81001c200000 on node 0 phys addr is : 0x1c200000 RHEL 5.1 kernel -53 said: PCI-DMA: aperture base @ 1c000000 size 65536 KB new kernel said: Mapping aperture over 65536 KB of RAM @ 3c000000 So could try to disable that GART if possible. According to Ingo > hm, i'm wondering, instead of modifying the GART, why dont we simply > _detect_ whatever GART settings we have inherited, and propagate that > into our e820 maps? I.e. if there's inconsistency, then punch that out > from the memory maps and just dont use that memory. > > that way it would not matter whether the GART settings came from a [old > or crashing] Linux kernel that has not called gart_iommu_shutdown(), or > whether it's a BIOS that has set up an aperture hole inconsistent with > the memory map it passed. (or the memory map we _think_ i tried to pass > us) > > it would also be more robust to only read and do a memory map quirk > based on that, than actively trying to change the GART so early in the > bootup. Later on we have to re-enable the GART _anyway_ and have to > punch a hole for it. > > and as a bonus, we would have shored up our defenses against crappy > BIOSes as well. add e820 modification for gart inconsistent setting. gart_fix_e820=off could be used to disable e820 fix. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: add the "print code before the trapping instruction" feature to 64 bitArjan van de Ven
The 32 bit x86 tree has a very useful feature that prints the Code: line for the code even before the trapping instrution (and the start of the trapping instruction is then denoted with a <>). Unfortunately, the 64 bit x86 tree does not yet have this feature, making diagnosing backtraces harder than needed. This patch adds this feature in the same was as the 32 bit tree has (including the same kernel boot parameter), and including a bugfix to make the code use probe_kernel_address() rarther than a buggy (deadlocking) __get_user. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: 32-bit EFI runtime service support: fixes in sync with 64-bit supportHuang, Ying
support according to fixes of x86_64 support. - Delete efi_rt_lock because it is used during system early boot, before SMP is initialized. - Change local_flush_tlb() to __flush_tlb_all() to flush global page mapping. - Clean up includes. - Revise Kconfig description. - Enable noefi kernel parameter on i386. Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86 vDSO: consolidate vdso32Roland McGrath
This makes x86_64's ia32 emulation support share the sources used in the 32-bit kernel for the 32-bit vDSO and much of its setup code. The 32-bit vDSO mapping now behaves the same on x86_64 as on native 32-bit. The abi.syscall32 sysctl on x86_64 now takes the same values that vm.vdso_enabled takes on the 32-bit kernel. That is, 1 means a randomized vDSO location, 2 means the fixed old address. The CONFIG_COMPAT_VDSO option is now available to make this the default setting, the same meaning it has for the 32-bit kernel. (This does not affect the 64-bit vDSO.) The argument vdso32=[012] can be used on both 32-bit and 64-bit kernels to set this paramter at boot time. The vdso=[012] argument still does this same thing on the 32-bit kernel. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: various changes and cleanups to in_p/out_p delay detailsIngo Molnar
various changes to the in_p/out_p delay details: - add the io_delay=none method - make each method selectable from the kernel config - simplify the delay code a bit by getting rid of an indirect function call - add the /proc/sys/kernel/io_delay_type sysctl - change 'io_delay=standard|alternate' to io_delay=0x80 and io_delay=0xed - make the io delay config not depend on CONFIG_DEBUG_KERNEL Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: "David P. Reed" <dpreed@reed.com>
2008-01-30x86: provide a DMI based port 0x80 I/O delay override.Rene Herman
x86: provide a DMI based port 0x80 I/O delay override. Certain (HP) laptops experience trouble from our port 0x80 I/O delay writes. This patch provides for a DMI based switch to the "alternate diagnostic port" 0xed (as used by some BIOSes as well) for these. David P. Reed confirmed that port 0xed works for him and provides a proper delay. The symptoms of _not_ working are a hanging machine, with "hwclock" use being a direct trigger. Earlier versions of this attempted to simply use udelay(2), with the 2 being a value tested to be a nicely conservative upper-bound with help from many on the linux-kernel mailinglist but that approach has two problems. First, pre-loops_per_jiffy calibration (which is post PIT init while some implementations of the PIT are actually one of the historically problematic devices that need the delay) udelay() isn't particularly well-defined. We could initialise loops_per_jiffy conservatively (and based on CPU family so as to not unduly delay old machines) which would sort of work, but... Second, delaying isn't the only effect that a write to port 0x80 has. It's also a PCI posting barrier which some devices may be explicitly or implicitly relying on. Alan Cox did a survey and found evidence that additionally some drivers may be racy on SMP without the bus locking outb. Switching to an inb() makes the timing too unpredictable and as such, this DMI based switch should be the safest approach for now. Any more invasive changes should get more rigid testing first. It's moreover only very few machines with the problem and a DMI based hack seems to fit that situation. This also introduces a command-line parameter "io_delay" to override the DMI based choice again: io_delay=<standard|alternate> where "standard" means using the standard port 0x80 and "alternate" port 0xed. This retains the udelay method as a config (CONFIG_UDELAY_IO_DELAY) and command-line ("io_delay=udelay") choice for testing purposes as well. This does not change the io_delay() in the boot code which is using the same port 0x80 I/O delay but those do not appear to be a problem as David P. Reed reported the problem was already gone after using the udelay version. He moreover reported that booting with "acpi=off" also fixed things and seeing as how ACPI isn't touched until after this DMI based I/O port switch I believe it's safe to leave the ones in the boot code be. The DMI strings from David's HP Pavilion dv9000z are in there already and we need to get/verify the DMI info from other machines with the problem, notably the HP Pavilion dv6000z. This patch is partly based on earlier patches from Pavel Machek and David P. Reed. Signed-off-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-26[S390] cio: Dump ccw device information in case of timeout.Sebastian Ott
Information about a ccw device will be dumped in case of a ccw timeout. This can be enabled with the kernel parameter ccw_timeout_log. Signed-off-by: Sebastian Ott <sebott@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] Cleanup in Documentation/kernel-parameters.txt.Sebastian Ott
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-25[AVR32] NMI debuggingHaavard Skinnemoen
Change the NMI handler to use the die notifier chain to signal anyone who cares. Add a simple "nmi debugger" which hooks into this chain and that may dump registers, task state, etc. when it happens. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-24Merge branch 'linux-2.6'Paul Mackerras
2008-01-17[POWERPC] Add hugepagesz boot-time parameterJon Tollefson
This adds the hugepagesz boot-time parameter for ppc64. It lets one pick the size for huge pages. The choices available are 64K and 16M when the base page size is 4k. It defaults to 16M (previously the only only choice) if nothing or an invalid choice is specified. Tested 64K huge pages successfully with the libhugetlbfs 1.2. Signed-off-by: Jon Tollefson <kniht@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-01-11[SCSI] boot options: correct option name and tell where to find docs for itRandy Dunlap
Minor corrections and additions to 'scsi_logging_level', as pointed out by Chuck Ebbert. Also point out the IBM S390-tools 'scsi_logging_level' script. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-10Update kernel parameter document for libata DMA mode setting knobs.FD Cami
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-03Console is utf-8 by defaultSamuel Thibault
The console is now by default in UTF-8 mode. Fix the documentation on the default value, so that we can explain behaviour that otherwise causes bug-reports like this: http://bugzilla.kernel.org/show_bug.cgi?id=9319 Also add the needed "vt." prefix, so that the boot-time config options to switch back to the legacy 8-bit mode is actually documented correctly. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29Pull alexey-fixes into release branchLen Brown
2007-10-25ACPI: EC: auto select interrupt modeAlexey Starikovskiy
Start in POLL mode, and if we receive confirmation GPE, switch to INT mode. If confirmations are not sent, switch back to POLL. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-24sched: document profile=sleep requiring CONFIG_SCHEDSTATSMel Gorman
profile=sleep only works if CONFIG_SCHEDSTATS is set. This patch notes the limitation in Documentation/kernel-parameters.txt and prints a warning at boot-time if profile=sleep is used without CONFIG_SCHEDSTAT. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-23x86: Force enable HPET for CK804 (nForce 4) chipsetsCarlos Corbacho
This patch adds a quirk from LinuxBIOS to force enable HPET on the nVidia CK804 (nForce 4) chipset. This quirk can very likely support more than just nForce 4 (LinuxBIOS use the same code for nForce 5), and possibly nForce 3, but I don't have those chipsets, so cannot add and test them. Tested on an Abit KN9 (CK804). Signed-off-by: Carlos Corbacho <cathectic@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Documentation/kernel-parameters.txt | 3 +- arch/x86/kernel/quirks.c | 37 +++++++++++++++++++++++++++++++++++- 2 files changed, 38 insertions(+), 2 deletions(-)
2007-10-22Intel IOMMU: Intel iommu cmdline option - forcedacKeshavamurthy, Anil S
Introduce intel_iommu=forcedac commandline option. This option is helpful to verify the pci device capability of handling physical dma'able address greater than 4G. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ashok Raj <ashok.raj@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Christoph Lameter <clameter@sgi.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22Intel IOMMU: Intel IOMMU driverKeshavamurthy, Anil S
Actual intel IOMMU driver. Hardware spec can be found at: http://www.intel.com/technology/virtualization This driver sets X86_64 'dma_ops', so hook into standard DMA APIs. In this way, PCI driver will get virtual DMA address. This change is transparent to PCI drivers. [akpm@linux-foundation.org: remove unneeded cast] [akpm@linux-foundation.org: build fix] [bunk@stusta.de: fix duplicate CONFIG_DMAR Makefile line] Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ashok Raj <ashok.raj@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Christoph Lameter <clameter@sgi.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (74 commits) fix do_sys_open() prototype sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistake Documentation: Fix typo in SubmitChecklist. Typo: depricated -> deprecated Add missing profile=kvm option to Documentation/kernel-parameters.txt fix typo about TBI in e1000 comment proc.txt: Add /proc/stat field small documentation fixes Fix compiler warning in smount example program from sharedsubtree.txt docs/sysfs: add missing word to sysfs attribute explanation documentation/ext3: grammar fixes Documentation/java.txt: typo and grammar fixes Documentation/filesystems/vfs.txt: typo fix include/asm-*/system.h: remove unused set_rmb(), set_wmb() macros trivial copy_data_pages() tidy up Fix typo in arch/x86/kernel/tsc_32.c file link fix for Pegasus USB net driver help remove unused return within void return function Typo fixes retrun -> return x86 hpet.h: remove broken links ...
2007-10-20Add missing profile=kvm option to Documentation/kernel-parameters.txtDave Jones
Whilst looking up what profile=sleep did, I noticed that we missed adding docs for the most recent addition to the profiler. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Documentation: Remove unreferenced "blkmtd_*" parmsRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Documentation: Remove reference to non-existent "unwind_debug" kernel parmRobert P. J. Day
2007-10-20Documentation: Fix erroneous "dmascc=" documentationRobert P. J. Day
2007-10-19Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86Linus Torvalds
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86: (33 commits) x86: convert cpuinfo_x86 array to a per_cpu array x86: introduce frame_pointer() and stack_pointer() x86 & generic: change to __builtin_prefetch() i386: do not BUG_ON() when MSR is unknown x86: acpi use cpu_physical_id x86: convert cpu_llc_id to be a per cpu variable x86: convert cpu_to_apicid to be a per cpu variable i386: introduce "used_vectors" bitmap which can be used to reserve vectors. x86: use raw locks during oopses x86: honor _PAGE_PSE bit on page walks i386: do cpuid_device_create() in CPU_UP_PREPARE instead of CPU_ONLINE. x86: implement missing x86_64 function smp_call_function_mask() x86: use descriptor's functions instead of inline assembly i386: consolidate show_regs and show_registers for i386 i386: make callgraph use dump_trace() on i386/x86_64 x86: enable iommu_merge by default i386: i386 add AMD64 Barcelona PMU MSR definitions to msr.h x86: Unify i386 and x86-64 early quirks x86: enable HPET on ICH3 and ICH4 x86: force enable HPET on VT8235/8237 chipsets ... Manually fix trivial conflict with task pid container helper changes in arch/x86/kernel/process_32.c
2007-10-20Documentation: Remove references to dead "eda" and "edb" kernel parmsRobert P. J. Day
2007-10-20Documentation: Remove references to dead "cyclades=" boot optionRobert P. J. Day
2007-10-19Documentation: Remove reference to non-existent "applicom" kernel parmRobert P. J. Day
2007-10-19Documentation: Remove references to dead "noasync" kernel parmRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Remove reference to dead "lasi" kernel parmRobert P. J. Day
2007-10-19Documentation: Delete final reference to "sg_def_reserved_size" kernel parmRobert P. J. Day
given the following: $ grep -rw sg_def_reserved_size * Documentation/kernel-parameters.txt: sg_def_reserved_size= [SCSI] $ that kernel parameter looks exceedingly dead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Remove remaining useless reference to acpi_fake_ecdtRobert P. J. Day
>From commit cd8c93a4e04dce8f00d1ef3a476aac8bd65ae40b: "Similar functionality was turned on by acpi_fake_ecdt=1 command line before. Now it is on all the time." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Delete dead OSS-related kernel parameter.Robert P. J. Day
Since the OSS-related "sb" kernel parameter doesn't seem to be supported, drop its reference from the kernel-parameters.txt file. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
