path: root/Documentation/kernel-parameters.txt
2008-01-26[S390] cio: Dump ccw device information in case of timeout.Sebastian Ott
Information about a ccw device will be dumped in case of a ccw timeout. This can be enabled with the kernel parameter ccw_timeout_log. Signed-off-by: Sebastian Ott <sebott@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-01-26[S390] Cleanup in Documentation/kernel-parameters.txt.Sebastian Ott
2008-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (200 commits) [SCSI] usbstorage: use last_sector_bug flag universally [SCSI] libsas: abstract STP task status into a function [SCSI] ultrastor: clean up inline asm warnings [SCSI] aic7xxx: fix firmware build [SCSI] aacraid: fib context lock for management ioctls [SCSI] ch: remove forward declarations [SCSI] ch: fix device minor number management bug [SCSI] ch: handle class_device_create failure properly [SCSI] NCR5380: fix section mismatch [SCSI] sg: fix /proc/scsi/sg/devices when no SCSI devices [SCSI] IB/iSER: add logical unit reset support [SCSI] don't use __GFP_DMA for sense buffers if not required [SCSI] use dynamically allocated sense buffer [SCSI] scsi.h: add macro for enclosure bit of inquiry data [SCSI] sd: add fix for devices with last sector access problems [SCSI] fix pcmcia compile problem [SCSI] aacraid: add Voodoo Lite class of cards. [SCSI] aacraid: add new driver features flags [SCSI] qla2xxx: Update version number to 8.02.00-k7. [SCSI] qla2xxx: Issue correct MBC_INITIALIZE_FIRMWARE command. ...
2008-01-25[AVR32] NMI debuggingHaavard Skinnemoen
Change the NMI handler to use the die notifier chain to signal anyone who cares. Add a simple "nmi debugger" which hooks into this chain and that may dump registers, task state, etc. when it happens. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-11[SCSI] boot options: correct option name and tell where to find docs for itRandy Dunlap
Minor corrections and additions to 'scsi_logging_level', as pointed out by Chuck Ebbert. Also point out the IBM S390-tools 'scsi_logging_level' script. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-10Update kernel parameter document for libata DMA mode setting knobs.FD Cami
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-03Console is utf-8 by defaultSamuel Thibault
The console is now by default in UTF-8 mode. Fix the documentation on the default value, so that we can explain behaviour that otherwise causes bug-reports like this: http://bugzilla.kernel.org/show_bug.cgi?id=9319 Also add the needed "vt." prefix, so that the boot-time config options to switch back to the legacy 8-bit mode is actually documented correctly. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-29Pull alexey-fixes into release branchLen Brown
2007-10-25ACPI: EC: auto select interrupt modeAlexey Starikovskiy
Start in POLL mode, and if we receive confirmation GPE, switch to INT mode. If confirmations are not sent, switch back to POLL. Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-10-24sched: document profile=sleep requiring CONFIG_SCHEDSTATSMel Gorman
profile=sleep only works if CONFIG_SCHEDSTATS is set. This patch notes the limitation in Documentation/kernel-parameters.txt and prints a warning at boot-time if profile=sleep is used without CONFIG_SCHEDSTAT. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-23x86: Force enable HPET for CK804 (nForce 4) chipsetsCarlos Corbacho
This patch adds a quirk from LinuxBIOS to force enable HPET on the nVidia CK804 (nForce 4) chipset. This quirk can very likely support more than just nForce 4 (LinuxBIOS use the same code for nForce 5), and possibly nForce 3, but I don't have those chipsets, so cannot add and test them. Tested on an Abit KN9 (CK804). Signed-off-by: Carlos Corbacho <cathectic@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Documentation/kernel-parameters.txt | 3 +- arch/x86/kernel/quirks.c | 37 +++++++++++++++++++++++++++++++++++- 2 files changed, 38 insertions(+), 2 deletions(-)
2007-10-22Intel IOMMU: Intel iommu cmdline option - forcedacKeshavamurthy, Anil S
Introduce intel_iommu=forcedac commandline option. This option is helpful to verify the pci device capability of handling physical dma'able address greater than 4G. Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ashok Raj <ashok.raj@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Christoph Lameter <clameter@sgi.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22Intel IOMMU: Intel IOMMU driverKeshavamurthy, Anil S
Actual intel IOMMU driver. Hardware spec can be found at: http://www.intel.com/technology/virtualization This driver sets X86_64 'dma_ops', so hook into standard DMA APIs. In this way, PCI driver will get virtual DMA address. This change is transparent to PCI drivers. [akpm@linux-foundation.org: remove unneeded cast] [akpm@linux-foundation.org: build fix] [bunk@stusta.de: fix duplicate CONFIG_DMAR Makefile line] Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Ashok Raj <ashok.raj@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Christoph Lameter <clameter@sgi.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (74 commits) fix do_sys_open() prototype sysfs: trivial: fix sysfs_create_file kerneldoc spelling mistake Documentation: Fix typo in SubmitChecklist. Typo: depricated -> deprecated Add missing profile=kvm option to Documentation/kernel-parameters.txt fix typo about TBI in e1000 comment proc.txt: Add /proc/stat field small documentation fixes Fix compiler warning in smount example program from sharedsubtree.txt docs/sysfs: add missing word to sysfs attribute explanation documentation/ext3: grammar fixes Documentation/java.txt: typo and grammar fixes Documentation/filesystems/vfs.txt: typo fix include/asm-*/system.h: remove unused set_rmb(), set_wmb() macros trivial copy_data_pages() tidy up Fix typo in arch/x86/kernel/tsc_32.c file link fix for Pegasus USB net driver help remove unused return within void return function Typo fixes retrun -> return x86 hpet.h: remove broken links ...
2007-10-20Add missing profile=kvm option to Documentation/kernel-parameters.txtDave Jones
Whilst looking up what profile=sleep did, I noticed that we missed adding docs for the most recent addition to the profiler. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Documentation: Remove unreferenced "blkmtd_*" parmsRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Documentation: Remove reference to non-existent "unwind_debug" kernel parmRobert P. J. Day
2007-10-20Documentation: Fix erroneous "dmascc=" documentationRobert P. J. Day
2007-10-19Merge ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86Linus Torvalds
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86: (33 commits) x86: convert cpuinfo_x86 array to a per_cpu array x86: introduce frame_pointer() and stack_pointer() x86 & generic: change to __builtin_prefetch() i386: do not BUG_ON() when MSR is unknown x86: acpi use cpu_physical_id x86: convert cpu_llc_id to be a per cpu variable x86: convert cpu_to_apicid to be a per cpu variable i386: introduce "used_vectors" bitmap which can be used to reserve vectors. x86: use raw locks during oopses x86: honor _PAGE_PSE bit on page walks i386: do cpuid_device_create() in CPU_UP_PREPARE instead of CPU_ONLINE. x86: implement missing x86_64 function smp_call_function_mask() x86: use descriptor's functions instead of inline assembly i386: consolidate show_regs and show_registers for i386 i386: make callgraph use dump_trace() on i386/x86_64 x86: enable iommu_merge by default i386: i386 add AMD64 Barcelona PMU MSR definitions to msr.h x86: Unify i386 and x86-64 early quirks x86: enable HPET on ICH3 and ICH4 x86: force enable HPET on VT8235/8237 chipsets ... Manually fix trivial conflict with task pid container helper changes in arch/x86/kernel/process_32.c
2007-10-20Documentation: Remove references to dead "eda" and "edb" kernel parmsRobert P. J. Day
2007-10-20Documentation: Remove references to dead "cyclades=" boot optionRobert P. J. Day
2007-10-19Documentation: Remove reference to non-existent "applicom" kernel parmRobert P. J. Day
2007-10-19Documentation: Remove references to dead "noasync" kernel parmRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Remove reference to dead "lasi" kernel parmRobert P. J. Day
2007-10-19Documentation: Delete final reference to "sg_def_reserved_size" kernel parmRobert P. J. Day
given the following: $ grep -rw sg_def_reserved_size * Documentation/kernel-parameters.txt: sg_def_reserved_size= [SCSI] $ that kernel parameter looks exceedingly dead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Remove remaining useless reference to acpi_fake_ecdtRobert P. J. Day
>From commit cd8c93a4e04dce8f00d1ef3a476aac8bd65ae40b: "Similar functionality was turned on by acpi_fake_ecdt=1 command line before. Now it is on all the time." Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Delete dead OSS-related kernel parameter.Robert P. J. Day
Since the OSS-related "sb" kernel parameter doesn't seem to be supported, drop its reference from the kernel-parameters.txt file. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Documentation: Drop reference to dead "eicon" kernel paramter.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Armin Schindler <armin@melware.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Add documentation for extended crashkernel syntaxBernhard Walle
This adds the documentation for the extended crashkernel syntax into Documentation/kdump/kdump.txt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Andi Kleen <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Vivek Goyal <vgoyal@in.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19x86: add force_hpet boot optionThomas Gleixner
add force_hpet boot option. (this will be useful to make the forced-enable quirks depend on.) Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-18serial: turn serial console suspend a boot rather than compile time optionAndres Salomon
Currently, there's a CONFIG_DISABLE_CONSOLE_SUSPEND that allows one to stop the serial console from being suspended when the rest of the machine goes to sleep. This is incredibly useful for debugging power management-related things; however, having it as a compile-time option has proved to be incredibly inconvenient for us (OLPC). There are plenty of times that we want serial console to not suspend, but for the most part we'd like serial console to be suspended. This drops CONFIG_DISABLE_CONSOLE_SUSPEND, and replaces it with a kernel boot parameter (no_console_suspend). By default, the serial console will be suspended along with the rest of the system; by passing 'no_console_suspend' to the kernel during boot, serial console will remain alive during suspend. For now, this is pretty serial console specific; further fixes could be applied to make this work for things like netconsole. Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@suspend2.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17x86: clean up mce= argument parsing slightlyAndi Kleen
Move the = into the __setup line. Document the option in kernel-parameters.txt by adding a pointer to the x86-64 specific documentation. [ tglx: arch/x86 adaptation ] Pointed out by Robert Day Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17security: Convert LSM into a static interfaceJames Morris
Convert LSM into a static interface, as the ability to unload a security module is not required by in-tree users and potentially complicates the overall security architecture. Needlessly exported LSM symbols have been unexported, to help reduce API abuse. Parameters for the capability and root_plug modules are now specified at boot. The SECURITY_FRAMEWORK_VERSION macro has also been removed. In a nutshell, there is no safe way to unload an LSM. The modular interface is thus unecessary and broken infrastructure. It is used only by out-of-tree modules, which are often binary-only, illegal, abusive of the API and dangerous, e.g. silently re-vectoring SELinux. [akpm@linux-foundation.org: cleanups] [akpm@linux-foundation.org: USB Kconfig fix] [randy.dunlap@oracle.com: fix LSM kernel-doc] Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Chris Wright <chrisw@sous-sol.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Acked-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Remove final traces of long-deprecated "ramdisk" kernel parmRobert P. J. Day
Since the "ramdisk" kernel parameter has been officially deprecated since at least 2.6.18, might as well finally get rid of it. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbcon: logo: disable logo at bootRandy Dunlap
Add logo.nologo kernel boot option to disable the logo in order to provide more screen space for kernel messages; especially useful when debugging and screen space is more critical. newport_con driver changes are untested. [akpm@linux-foundation.org: cleanups, coding-style fixes] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16slow down printk during bootRandy Dunlap
Optionally add a boot delay after each kernel printk() call, crudely measured in milliseconds, with a maximum delay of 10 seconds per printk. Enable CONFIG_BOOT_PRINTK_DELAY=y and then add (e.g.): "lpj=loops_per_jiffy boot_delay=100" to the kernel command line. It has been useful in cases like "during boot, my machine just reboots or the screen goes black" by slowing down printk, (and adding initcall_debug), we can usually see the last thing that happened before the lights went out which is usually a valuable clue. [akpm@linux-foundation.org: not all architectures implement CONFIG_HZ] [akpm@linux-foundation.org: fix lots of stuff] [bunk@stusta.de: kernel/printk.c: make 2 variables static] [heiko.carstens@de.ibm.com: fix slow down printk on boot compile error] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (40 commits) Input: use full RCU API Input: remove tsdev interface Input: add support for Blackfin BF54x Keypad controller Input: appletouch - another fix for idle reset logic HWMON: hdaps - switch to using input-polldev Input: add support for SEGA Dreamcast keyboard Input: omap-keyboard - don't pretend we support changing keymap Input: lifebook - fix X and Y axis range Input: usbtouchscreen - add support for GeneralTouch devices Input: fix open count handling in input interfaces Input: keyboard - add CapsShift lock Input: adbhid - produce all CapsLock key events Input: ALPS - add signature for ThinkPad R61 Input: jornada720_kbd - send MSC_SCAN events Input: add support for the HP Jornada 7xx (710/720/728) touchscreen Input: add support for HP Jornada 7xx onboard keyboard Input: add support for HP Jornada onboard keyboard (HP6XX) Input: ucb1400_ts - use schedule_timeout_uninterruptible Input: xpad - fix dependancy on LEDS class Input: auto-select INPUT for MAC_EMUMOUSEBTN option ... Resolved conflicts manually in drivers/hwmon/applesmc.c: converting from a class device to a device and converting to use input-polldev created a few apparently trivial clashes..
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-13Input: remove tsdev interfaceRichard Purdie
Remove the obsolete tsdev.c driver as scheduled. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-12Merge branch 'upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (119 commits) [libata] struct pci_dev related cleanups libata: use ata_exec_internal() for PMP register access libata: implement ATA_PFLAG_RESETTING libata: add @timeout to ata_exec_internal[_sg]() ahci: fix notification handling ahci: clean up PORT_IRQ_BAD_PMP enabling ahci: kill leftover from enabling NCQ over PMP libata: wrap schedule_timeout_uninterruptible() in loop libata: skip suppress reporting if ATA_EHI_QUIET libata: clear ehi description after initial host report pata_jmicron: match vendor and class code only libata: add ST9160821AS / 3.ALD to NCQ blacklist pata_acpi: ACPI driver support libata-core: Expose gtm methods for driver use libata: add HDT722516DLA380 to NCQ blacklist libata: blacklist NCQ on Seagate Barracuda ST380817AS [libata] Turn on ACPI by default libata_scsi: Fix ATAPI transfer lengths libata: correct handling of SRST reset sequences libata: Integrate ACPI-based PATA/SATA hotplug - version 5 ...
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (37 commits) PCI: merge almost all of pci_32.h and pci_64.h together PCI: X86: Introduce and enable PCI domain support PCI: Add 'nodomains' boot option, and pci_domains_supported global PCI: modify PCI bridge control ISA flag for clarity PCI: use _CRS for PCI resource allocation PCI: avoid P2P prefetch window for expansion ROMs PCI: skip ISA ioresource alignment on some systems PCI: remove transparent bridge sizing pci: write file size to inode on proc bus file write pci: use size stored in proc_dir_entry for proc bus files pci: implement "pci=noaer" PCI: fix IDE legacy mode resources MSI: Use correct data offset for 32-bit MSI in read_msi_msg() PCI: Fix incorrect argument order to list_add_tail() in PCI dynamic ID code PCI: i386: Compaq EVO N800c needs PCI bus renumbering PCI: Remove no longer correct documentation regarding MSI vector assignment PCI: re-enable onboard sound on "MSI K8T Neo2-FIR" PCI: quirk_vt82c586_acpi: Omit reading PCI revision ID PCI: quirk amd_8131_mmrbc: Omit reading pci revision ID cpqphp: Use PCI_CLASS_REVISION instead of PCI_REVISION_ID for read ...
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: (75 commits) PM: merge device power-management source files sysfs: add copyrights kobject: update the copyrights kset: add some kerneldoc to help describe what these strange things are Driver core: rename ktype_edd and ktype_efivar Driver core: rename ktype_driver Driver core: rename ktype_device Driver core: rename ktype_class driver core: remove subsystem_init() sysfs: move sysfs file poll implementation to sysfs_open_dirent sysfs: implement sysfs_open_dirent sysfs: move sysfs_dirent->s_children into sysfs_dirent->s_dir sysfs: make sysfs_root a regular directory dirent sysfs: open code sysfs_attach_dentry() sysfs: make s_elem an anonymous union sysfs: make bin attr open get active reference of parent too sysfs: kill unnecessary NULL pointer check in sysfs_release() sysfs: kill unnecessary sysfs_get() in open paths sysfs: reposition sysfs_dirent->s_mode. sysfs: kill sysfs_update_file() ...
2007-10-12PCI: Add 'nodomains' boot option, and pci_domains_supported globalJeff Garzik
* Introduce pci_domains_supported global, hardcoded to zero if !CONFIG_PCI_DOMAINS. * Introduce 'nodomains' boot option, which clears pci_domains_supported on platforms that enable it by default (x86, x86-64, and others when they are converted to use this). Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12PCI: use _CRS for PCI resource allocationGary Hade
Use _CRS for PCI resource allocation This patch resolves an issue where incorrect PCI memory and i/o ranges are being assigned to hotplugged PCI devices on some IBM systems. The resource mis-allocation not only makes the PCI device unuseable but often makes the entire system unuseable due to resulting machine checks. The hotplug capable PCI slots on the affected systems are not located under a standard P2P bridge but are instead located under PCI root bridges or subtractive decode P2P bridges. For example, the IBM x3850 contains 2 hotplug capable PCI-X slots and 4 hotplug capable PCIe slots with the PCI-X slots each located under a PCI root bridge and the PCIe slots each located under a subtractive decode P2P bridge. The current i386/x86_64 PCI resource allocation code does not use _CRS returned resource information. No other resource information source is available for slots that are not below a standard P2P bridge so incorrect ranges are being allocated from e820 hole causing the bad result. This patch causes the kernel to use _CRS returned resource info. It is roughly based on a change provided by Matthew Wilcox for the ia64 kernel in 2005. Due to possible buggy BIOS factor and possible yet to be discovered kernel issues the function is disabled by default and can be enabled with pci=use_crs. Signed-off-by: Gary Hade <gary.hade@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12pci: implement "pci=noaer"Randy Dunlap
For cases in which CONFIG_PCIEAER=y (such as distro kernels), allow users to disable PCIE Advanced Error Reporting by using "pci=noaer" on the kernel command line. This can be used to work around hardware or (kernel) software problems. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12PTY: add kernel parameter to overwrite legacy pty countKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12x86: Geode MFGPT clock event device supportAndres Salomon
Add support for an MFGPT clock event device; this allows us to use MFGPTs as the basis for high-resolution timers. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Andi Kleen <ak@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-12x86: Geode Multi-Function General Purpose Timers supportAndres Salomon
This adds support for Multi-Function General Purpose Timers. It detects the available timers during southbridge init, and provides an API for allocating and setting the timers. They're higher resolution than the standard PIT, so the MFGPTs come in handy for quite a few things. Note that we never clobber the timers that the BIOS might have opted to use; we just check for unused timers. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Andi Kleen <ak@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-12libata: correct kernel parameter in documentation.Dave Jones
'noacpi' isn't a standalone parameter, give it its prefix. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-09NFS: Add a boot parameter to disable 64 bit inode numbersTrond Myklebust
This boot parameter will allow legacy 32-bit applications which call stat() to continue to function even if the NFSv3/v4 server uses 64-bit inode numbers. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
