path: root/Documentation/kernel-parameters.txt
2008-07-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (72 commits) Revert "x86/PCI: ACPI based PCI gap calculation" PCI: remove unnecessary volatile in PCIe hotplug struct controller x86/PCI: ACPI based PCI gap calculation PCI: include linux/pm_wakeup.h for device_set_wakeup_capable PCI PM: Fix pci_prepare_to_sleep x86/PCI: Fix PCI config space for domains > 0 Fix acpi_pm_device_sleep_wake() by providing a stub for CONFIG_PM_SLEEP=n PCI: Simplify PCI device PM code PCI PM: Introduce pci_prepare_to_sleep and pci_back_from_sleep PCI ACPI: Rework PCI handling of wake-up ACPI: Introduce new device wakeup flag 'prepared' ACPI: Introduce acpi_device_sleep_wake function PCI: rework pci_set_power_state function to call platform first PCI: Introduce platform_pci_power_manageable function ACPI: Introduce acpi_bus_power_manageable function PCI: make pci_name use dev_name PCI: handle pci_name() being const PCI: add stub for pci_set_consistent_dma_mask() PCI: remove unused arch pcibios_update_resource() functions PCI: fix pci_setup_device()'s sprinting into a const buffer ... Fixed up conflicts in various files (arch/x86/kernel/setup_64.c, arch/x86/pci/irq.c, arch/x86/pci/pci.h, drivers/acpi/sleep/main.c, drivers/pci/pci.c, drivers/pci/pci.h, include/acpi/acpi_bus.h) from x86 and ACPI updates manually.
2008-07-16ACPI : Create "idle=nomwait" bootparamZhao Yakui
"idle=nomwait" disables the use of the MWAIT instruction from both C1 (C1_FFH) and deeper (C2C3_FFH) C-states. When MWAIT is unavailable, the BIOS and OS generally negotiate to use the HALT instruction for C1, and use IO accesses for deeper C-states. This option is useful for power and performance comparisons, and also to work around BIOS bugs where broken MWAIT support is advertised. http://bugzilla.kernel.org/show_bug.cgi?id=10807 http://bugzilla.kernel.org/show_bug.cgi?id=10914 Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Li Shaohua <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16ACPI: Create "idle=halt" bootparamZhao Yakui
"idle=halt" limits the idle loop to using the halt instruction. No MWAIT, no IO accesses, no C-states deeper than C1. If something is broken in the idle code, "idle=halt" is a less severe workaround than "idle=poll" which disables all power savings. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (80 commits) ide-floppy: fix unfortunate function naming ide-tape: unify idetape_create_read/write_cmd ide: add ide_pc_intr() helper ide-{floppy,scsi}: read Status Register before stopping DMA engine ide-scsi: add more debugging to idescsi_pc_intr() ide-scsi: use pc->callback ide-floppy: add more debugging to idefloppy_pc_intr() ide-tape: always log debug info in idetape_pc_intr() if debugging is enabled ide-tape: add ide_tape_io_buffers() helper ide-tape: factor out DSC handling from idetape_pc_intr() ide-{floppy,tape}: move checking of ->failed_pc to ->callback ide: add ide_issue_pc() helper ide: add PC_FLAG_DRQ_INTERRUPT pc flag ide-scsi: move idescsi_map_sg() call out from idescsi_issue_pc() ide: add ide_transfer_pc() helper ide-scsi: set drive->scsi flag for devices handled by the driver ide-{cd,floppy,tape}: remove checking for drive->scsi ide: add PC_FLAG_ZIP_DRIVE pc flag ide-tape: factor out waiting for good ireason from idetape_transfer_pc() ide-tape: set PC_FLAG_DMA_IN_PROGRESS flag in idetape_transfer_pc() ...
2008-07-15ide: remove obsoleted "hdx=" kernel parametersBartlomiej Zolnierkiewicz
* Remove obsoleted "hdx=" kernel parameters. * Remove no longer used stridx() and match_parm(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-15Merge branch 'timers/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: add PCI ID for 6300ESB force hpet x86: add another PCI ID for ICH6 force-hpet kernel-paramaters: document pmtmr= command line option acpi_pm clccksource: fix printk format warning nohz: don't stop idle tick if softirqs are pending. pmtmr: allow command line override of ioport nohz: reduce jiffies polling overhead hrtimer: Remove unused variables in ktime_divns() hrtimer: remove warning in hres_timers_resume posix-timers: print RT watchdog message
2008-07-15Documentation: document debugpat commandline optionThomas Gleixner
2008-07-14Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits) [ARM] 5171/1: ep93xx: fix compilation of modules using clocks [ARM] 5133/2: at91sam9g20 defconfig file [ARM] 5130/4: Support for the at91sam9g20 [ARM] 5160/1: IOP3XX: gpio/gpiolib support [ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits. [ARM] 5084/1: zylonite: Register AC97 device [ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model [ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers [ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting [ARM] 5145/1: PXA2xx: provide api to control IrDA pins state [ARM] 5144/1: pxaficp_ir: cleanup includes [ARM] pxa: remove pxa_set_cken() [ARM] pxa: allow clk aliases [ARM] Feroceon: don't disable BPU on boot [ARM] Orion: LED support for HP mv2120 [ARM] Orion: add RD88F5181L-FXO support [ARM] Orion: add RD88F5181L-GE support [ARM] Orion: add Netgear WNR854T support [ARM] s3c2410_defconfig: update for current build [ARM] Acer n30: Minor style and indentation fixes. ...
2008-07-14Merge commit '900cfa46191a7d87cf1891924cb90499287fd235'; branches ↵Thomas Gleixner
'timers/nohz', 'timers/clocksource' and 'timers/posixtimers' into timers/for-linus
2008-07-12kernel-paramaters: document pmtmr= command line optionThomas Gleixner
2008-07-08x86 boot: only pick up additional EFI memmap if add_efi_memmap flagPaul Jackson
Applies on top of the previous patch: x86 boot: add code to add BIOS provided EFI memory entries to kernel Instead of always adding EFI memory map entries (if present) to the memory map after initially finding either E820 BIOS memory map entries and/or kernel command line memmap entries, -instead- only add such additional EFI memory map entries if the kernel boot option: add_efi_memmap is specified. Requiring this 'add_efi_memmap' option is backward compatible with kernels that didn't load such additional EFI memory map entries in the first place, and it doesn't override a configuration that tries to replace all E820 or EFI BIOS memory map entries with ones given entirely on the kernel command line. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: "Yinghai Lu" <yhlu.kernel@gmail.com> Cc: "Jack Steiner" <steiner@sgi.com> Cc: "Mike Travis" <travis@sgi.com> Cc: "Huang Cc: Ying" <ying.huang@intel.com> Cc: "Andi Kleen" <andi@firstfloor.org> Cc: "Andrew Morton" <akpm@linux-foundation.org> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'x86/mpparse' into x86/develIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/io_apic_32.c arch/x86/kernel/setup_64.c arch/x86/mm/init_32.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08Merge branch 'linus' into tmp.x86.mpparse.newIngo Molnar
2008-07-08Merge branches 'x86/mmio', 'x86/delay', 'x86/idle', 'x86/oprofile', ↵Ingo Molnar
'x86/debug', 'x86/ptrace' and 'x86/amd-iommu' into x86/devel
2008-07-07x86: clean up amd_iommu documentationFUJITA Tomonori
amd_iommu=off was replaced with a common parameter, iommu=off. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: joerg.roedel@amd.com Cc: iommu@lists.linux-foundation.org Cc: bhavna.sarathy@amd.com Cc: robert.richter@amd.com Cc: rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-04doc: document the relax_domain_level kernel boot argumentPaul Jackson
Document the kernel boot parameter: relax_domain_level=. Signed-off-by: Paul Jackson <pj@sgi.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04Doc*/kernel-parameters.txt: fix stale referencesPavel Machek
Fix stale references to source files in kernel-parameters.txt. Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03[ARM] JIVE: Initial machine support for Logitech JiveBen Dooks
This is the base machine support for the Logitech Jive machine. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-06-27x86, AMD IOMMU: add documentation for kernel parametersJoerg Roedel
Add documentation for the kernel parameters introduced with this driver. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: iommu@lists.linux-foundation.org Cc: bhavna.sarathy@amd.com Cc: Sebastian.Biemueller@amd.com Cc: robert.richter@amd.com Cc: joro@8bytes.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-12Suspend-related patches for 2.6.27Rafael J. Wysocki
ACPI PM: Add possibility to change suspend sequence There are some systems out there that don't work correctly with our current suspend/hibernation code ordering. Provide a workaround for these systems allowing them to pass 'acpi_sleep=old_ordering' in the kernel command line so that it will use the pre-ACPI 2.0 ("old") suspend code ordering. Unfortunately, this requires us to add a platform hook to the resuming of devices for recovering the platform in case one of the device drivers' .suspend() routines returns error code. Namely, ACPI 1.0 specifies that _PTS should be called before suspending devices, but _WAK still should be called before resuming them in order to undo the changes made by _PTS. However, if there is an error during suspending devices, they are automatically resumed without returning control to the PM core, so the _WAK has to be called from within device_resume() in that cases. The patch also reorders and refactors the ACPI suspend/hibernation code to avoid duplication as far as reasonably possible. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-06-10PCI: boot parameter to avoid expansion ROM memory allocationGary Hade
Contention for scarce PCI memory resources has been growing due to an increasing number of PCI slots in large multi-node systems. The kernel currently attempts by default to allocate memory for all PCI expansion ROMs so there has also been an increasing number of PCI memory allocation failures seen on these systems. This occurs because the BIOS either (1) provides insufficient PCI memory resource for all the expansion ROMs or (2) provides adequate PCI memory resource for expansion ROMs but provides the space in kernel unexpected BIOS assigned P2P non-prefetch windows. The resulting PCI memory allocation failures may be benign when related to memory requests for expansion ROMs themselves but in some cases they can occur when attempting to allocate space for more critical BARs. This can happen when a successful expansion ROM allocation request consumes memory resource that was intended for a non-ROM BAR. We have seen this happen during PCI hotplug of an adapter that contains a P2P bridge where successful memory allocation for an expansion ROM BAR on device behind the bridge consumed memory that was intended for a non-ROM BAR on the P2P bridge. In all cases the allocation failure messages can be very confusing for users. This patch provides a new 'pci=norom' kernel boot parameter that can be used to disable the default PCI expansion ROM memory resource allocation. This provides a way to avoid the above described issues on systems that do not contain PCI devices for which drivers or user-level applications depend on the default PCI expansion ROM memory resource allocation behavior. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-25x86: mtrr cleanup for converting continuous to discrete - auto detect v4Yinghai Lu
Loop through mtrr chunk_size and gran_size from 1M to 2G to find out the optimal value so user does not need to add mtrr_chunk_size and mtrr_gran_size to the kernel command line. If optimal value is not found, print out all list to help select less optimal value. Add mtrr_spare_reg_nr= so user could set 2 instead of 1, if the card need more entries. v2: find the one with more spare entries v3: fix hole_basek offset v4: tight the compare between range and range_new loop stop with 4g Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Gabriel C <nix.or.die@googlemail.com> Cc: Mika Fischer <mika.fischer@zoopnet.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-25x86: mtrr cleanup for converting continuous to discrete layout, v8Yinghai Lu
some BIOS like to use continus MTRR layout, and X driver can not add WB entries for graphical cards when 4g or more RAM installed. the patch will change MTRR to discrete. mtrr_chunk_size= could be used to have smaller continuous block to hold holes. default is 256m, could be set according to size of graphics card memory. mtrr_gran_size= could be used to send smallest mtrr block to avoid run out of MTRRs v2: fix -1 for UC checking v3: default to disable, and need use enable_mtrr_cleanup to enable this feature skip the var state change warning. remove next_basek in range_to_mtrr() v4: correct warning mask. v5: CONFIG_MTRR_SANITIZER v6: fix 1g, 2g, 512 aligment with extra hole v7: gran_sizek to prevent running out of MTRRs. v8: fix hole_basek caculation caused when removing next_basek gran_sizek using when basek is 0. need to apply [PATCH] x86: fix trimming e820 with MTRR holes. right after this one. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-15Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] fix personality(PER_LINUX32) performance issue [IA64] Properly unregister legacy interrupts [IA64] Remove NULL pointer check for argument never passed as NULL. [IA64] trivial cleanup for perfmon.c [IA64] trivial cleanup for entry.S [IA64] fix interrupt masking for pending works on kernel leave [IA64] allow user to force_pal_cache_flush [IA64] Don't reserve crashkernel memory > 4 GB [IA64] machvec support for SGI UV platform [IA64] Add header files for SGI UV platform
2008-05-15[S390] Remove last traces of cio_msg=.Cornelia Huck
cio_msg= is gone, also remove it from kernel-parameters.txt. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-14[IA64] allow user to force_pal_cache_flushAlex Chiang
The sequence executed in check_sal_cache_flush: - pend a timer interrupt - call SAL_CACHE_FLUSH - see if interrupt is still pending can hang HP machines with buggy SAL_CACHE_FLUSH implementations. Provide a kernel command-line argument to allow users skip this check if desired. Using this parameter will force ia64_sal_cache_flush to call ia64_pal_cache_flush() instead of SAL_CACHE_FLUSH. Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-05-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86 PCI: call dmi_check_pciprobe() x86/pci: add pci=skip_isa_align command lines. x86/pci: remove flag in pci_cfg_space_size_ext x86: fix section mismatch in pci_scan_bus
2008-05-05m68k: remove old mac_esp cruftFinn Thain
Remove the rest of the old mac_esp driver. Also ditch the rest of the machw mechanism, it needs to be replaced by a fake openfirmware tree. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-05x86/pci: add pci=skip_isa_align command lines.Yinghai Lu
so we don't align the io port start address for pci cards. also move out dmi check out acpi.c, because it has nothing to do with acpi. it could spare some calling when we have several peer root buses. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-30infrastructure to debug (dynamic) objectsThomas Gleixner
We can see an ever repeating problem pattern with objects of any kind in the kernel: 1) freeing of active objects 2) reinitialization of active objects Both problems can be hard to debug because the crash happens at a point where we have no chance to decode the root cause anymore. One problem spot are kernel timers, where the detection of the problem often happens in interrupt context and usually causes the machine to panic. While working on a timer related bug report I had to hack specialized code into the timer subsystem to get a reasonable hint for the root cause. This debug hack was fine for temporary use, but far from a mergeable solution due to the intrusiveness into the timer code. The code further lacked the ability to detect and report the root cause instantly and keep the system operational. Keeping the system operational is important to get hold of the debug information without special debugging aids like serial consoles and special knowledge of the bug reporter. The problems described above are not restricted to timers, but timers tend to expose it usually in a full system crash. Other objects are less explosive, but the symptoms caused by such mistakes can be even harder to debug. Instead of creating specialized debugging code for the timer subsystem a generic infrastructure is created which allows developers to verify their code and provides an easy to enable debug facility for users in case of trouble. The debugobjects core code keeps track of operations on static and dynamic objects by inserting them into a hashed list and sanity checking them on object operations and provides additional checks whenever kernel memory is freed. The tracked object operations are: - initializing an object - adding an object to a subsystem list - deleting an object from a subsystem list Each operation is sanity checked before the operation is executed and the subsystem specific code can provide a fixup function which allows to prevent the damage of the operation. When the sanity check triggers a warning message and a stack trace is printed. The list of operations can be extended if the need arises. For now it's limited to the requirements of the first user (timers). The core code enqueues the objects into hash buckets. The hash index is generated from the address of the object to simplify the lookup for the check on kfree/vfree. Each bucket has it's own spinlock to avoid contention on a global lock. The debug code can be compiled in without being active. The runtime overhead is minimal and could be optimized by asm alternatives. A kernel command line option enables the debugging code. Thanks to Ingo Molnar for review, suggestions and cleanup patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <greg@kroah.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Basic braille screen reader supportSamuel Thibault
This adds a minimalistic braille screen reader support. This is meant to be used by blind people e.g. on boot failures or when / cannot be mounted etc and thus the userland screen readers can not work. [akpm@linux-foundation.org: fix exports] Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Jiri Kosina <jikos@jikos.cz> Cc: Dmitry Torokhov <dtor@mail.ru> Acked-by: Alan Cox <alan@redhat.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29edd: add default mode CONFIG_EDD_OFF=n, override with edd={on,off}Tim Gardner
Add a kernel parameter option to 'edd' to enable/disable BIOS Enhanced Disk Drive Services. CONFIG_EDD_OFF disables EDD while still compiling EDD into the kernel. Default behavior can be forced using 'edd=on' or 'edd=off' as a kernel parameter. [akpm@linux-foundation.org: fix kernel-parameters.txt] Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29x86: olpc: add One Laptop Per Child architecture supportAndres Salomon
This adds support for OLPC XO hardware. Open Firmware on XOs don't contain the VSA, so it is necessary to emulate the PCI BARs in the kernel. This also adds functionality for running EC commands, and a CONFIG_OLPC. A number of OLPC drivers depend upon CONFIG_OLPC. olpc_ec_timeout is a hack to work around Embedded Controller bugs. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: geode_has_vsa build fix] [akpm@linux-foundation.org: olpc_register_battery_callback doesn't exist] Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-27ide: remove obsoleted "idex=" kernel parametersBartlomiej Zolnierkiewicz
* Remove obsoleted "idex=" kernel parameters. * Make probe_* and cmd640_vlb variables static. Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: (42 commits) PCI: Change PCI subsystem MAINTAINER PCI: pci-iommu-iotlb-flushing-speedup PCI: pci_setup_bridge() mustn't be __devinit PCI: pci_bus_size_cardbus() mustn't be __devinit PCI: pci_scan_device() mustn't be __devinit PCI: pci_alloc_child_bus() mustn't be __devinit PCI: replace remaining __FUNCTION__ occurrences PCI: Hotplug: fakephp: Return success, not ENODEV, when bus rescan is triggered PCI: Hotplug: Fix leaks in IBM Hot Plug Controller Driver - ibmphp_init_devno() PCI: clean up resource alignment management PCI: aerdrv_acpi.c: remove unneeded NULL check PCI: Update VIA CX700 quirk PCI: Expose PCI VPD through sysfs PCI: iommu: iotlb flushing PCI: simplify quirk debug output PCI: iova RB tree setup tweak PCI: parisc: use generic pci_enable_resources() PCI: ppc: use generic pci_enable_resources() PCI: powerpc: use generic pci_enable_resources() PCI: ia64: use generic pci_enable_resources() ...
2008-04-21Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits) [POWERPC] Fix compile breakage for 64-bit UP configs [POWERPC] Define copy_siginfo_from_user32 [POWERPC] Add compat handler for PTRACE_GETSIGINFO [POWERPC] i2c: Fix build breakage introduced by OF helpers [POWERPC] Optimize fls64() on 64-bit processors [POWERPC] irqtrace support for 64-bit powerpc [POWERPC] Stacktrace support for lockdep [POWERPC] Move stackframe definitions to common header [POWERPC] Fix device-tree locking vs. interrupts [POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const [POWERPC] Remove unused __max_memory variable [POWERPC] Simplify xics direct/lpar irq_host setup [POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ() [POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade() [POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c [POWERPC] Use asm-generic/bitops/find.h in bitops.h [POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup [POWERPC] 85xx: Fix the size of qe muram for MPC8568E [POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier. [POWERPC] 86xx: mark functions static, other minor cleanups ...
2008-04-20PCI: iommu: iotlb flushingmark gross
This patch is for batching up the flushing of the IOTLB for the DMAR implementation found in the Intel VT-d hardware. It works by building a list of to be flushed IOTLB entries and a bitmap list of which DMAR engine they are from. After either a high water mark (250 accessible via debugfs) or 10ms the list of iova's will be reclaimed and the DMAR engines associated are IOTLB-flushed. This approach recovers 15 to 20% of the performance lost when using the IOMMU for my netperf udp stream benchmark with small packets. It can be disabled with a kernel boot parameter "intel_iommu=strict". Its use does weaken the IOMMU protections a bit. Signed-off-by: Mark Gross <mgross@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-20PCI: remove initial bios sort of PCI devices on x86Greg Kroah-Hartman
We currently keep 2 lists of PCI devices in the system, one in the driver core, and one all on its own. This second list is sorted at boot time, in "BIOS" order, to try to remain compatible with older kernels (2.2 and earlier days). There was also a "nosort" option to turn this sorting off, to remain compatible with even older kernel versions, but that just ends up being what we have been doing from 2.5 days... Unfortunately, the second list of devices is not really ever used to determine the probing order of PCI devices or drivers[1]. That is done using the driver core list instead. This change happened back in the early 2.5 days. Relying on BIOS ording for the binding of drivers to specific device names is problematic for many reasons, and userspace tools like udev exist to properly name devices in a persistant manner if that is needed, no reliance on the BIOS is needed. Matt Domsch and others at Dell noticed this back in 2006, and added a boot option to sort the PCI device lists (both of them) in a breadth-first manner to help remain compatible with the 2.4 order, if needed for any reason. This option is not going away, as some systems rely on them. This patch removes the sorting of the internal PCI device list in "BIOS" mode, as it's not needed at all anymore, and hasn't for many years. I've also removed the PCI flags for this from some other arches that for some reason defined them, but never used them. This should not change the ordering of any drivers or device probing. [1] The old-style pci_get_device and pci_find_device() still used this sorting order, but there are very few drivers that use these functions, as they are deprecated for use in this manner. If for some reason, a driver rely on the order and uses these functions, the breadth-first boot option will resolve any problem. Cc: Matt Domsch <Matt_Domsch@dell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19x86: fix exec mappings commentsJiri Slaby
- noexec32 is on by default for years already - add noexec32 to kernel-parameters and fix noexec typo in there Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-19Security: Introduce security= boot parameterAhmed S. Darwish
Add the security= boot parameter. This is done to avoid LSM registration clashes in case of more than one bult-in module. User can choose a security module to enable at boot. If no security= boot parameter is specified, only the first LSM asking for registration will be loaded. An invalid security module name will be treated as if no module has been chosen. LSM modules must check now if they are allowed to register by calling security_module_enable(ops) first. Modify SELinux and SMACK to do so. Do not let SMACK register smackfs if it was not chosen on boot. Smackfs assumes that smack hooks are registered and the initial task security setup (swapper->security) is done. Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Acked-by: James Morris <jmorris@namei.org>
2008-04-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (27 commits) [IA64] kdump: Add crash_save_vmcoreinfo for INIT [IA64] Fix NUMA configuration issue [IA64] Itanium Spec updates [IA64] Untangle sync_icache_dcache() page size determination [IA64] arch/ia64/kernel/: use time_* macros [IA64] remove redundant display of free swap space in show_mem() [IA64] make IOMMU respect the segment boundary limits [IA64] kprobes: kprobe-booster for ia64 [IA64] fix getpid and set_tid_address fast system calls for pid namespaces [IA64] Replace explicit jiffies tests with time_* macros. [IA64] use goto to jump out do/while_each_thread [IA64] Fix unlock ordering in smp_callin [IA64] pgd_offset() constfication. [IA64] kdump: crash.c coding style fix [IA64] kdump: add kdump_on_fatal_mca [IA64] Minimize per_cpu reservations. [IA64] Correct pernodesize calculation. [IA64] Kernel parameter for max number of concurrent global TLB purges [IA64] Multiple outstanding ptc.g instruction support [IA64] Implement smp_call_function_mask for ia64 ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-kgdbLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-kgdb: kgdb: always use icache flush for sw breakpoints kgdb: fix SMP NMI kgdb_handle_exception exit race kgdb: documentation fixes kgdb: allow static kgdbts boot configuration kgdb: add documentation kgdb: Kconfig fix kgdb: add kgdb internal test suite kgdb: fix several kgdb regressions kgdb: kgdboc pl011 I/O module kgdb: fix optional arch functions and probe_kernel_* kgdb: add x86 HW breakpoints kgdb: print breakpoint removed on exception kgdb: clocksource watchdog kgdb: fix NMI hangs kgdb: fix kgdboc dynamic module configuration kgdb: document parameters x86: kgdb support consoles: polling support, kgdboc kgdb: core uaccess: add probe_kernel_write()
2008-04-18ide: remove obsoleted "idex=noprobe" kernel parameter (take 2)Bartlomiej Zolnierkiewicz
* Remove obsoleted "idex=noprobe" kernel parameter. * Remove no longer needed hwif->noprobe quirk from ide_hwif_configure() and hwif->noprobe checking from cmd640.c. v2: * "ide?=noprobe" -> "ide?=ata66" in Documentation/kernel-parameters.txt. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18IDE: remove ide=reverse IDE coreGreg Kroah-Hartman
This option is obsolete and can be removed safely. It allows us to remove the pci_get_device_reverse() function from the PCI core. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17kgdb: document parametersJason Wessel
document the kgdboc module/boot parameter. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Jan Kiszka <jan.kiszka@web.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17Pull nptcg into release branchTony Luck
Conflicts: arch/ia64/mm/tlb.c
2008-04-17x86: memtest bootparamYinghai Lu
2008-04-17x86 iommu: add more documentationPavel Machek
Fix coding style in pci-dma_64.c and add stubs for documentation. I hope someone fills the rest, I understand maybe off and soft... Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-14Merge branch 'linux-2.6'Paul Mackerras
