Below you will find an updated version from the original series bunching all patches into one big patch
updating broken web addresses that are located in Documentation/*
Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult,
the best way to deal with these is to use web.archive.org to locate these addresses that are outdated.
Now there are also some addresses pointing to .spec files some are located, but some(after searching
on the companies site)where still no where to be found. In this case I just changed the address
to the company site this way the users can contact the company and they can locate them for the users.
Signed-off-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Cc: Paulo Marques <pmarques@grupopie.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michael Neuling <mikey@neuling.org>
Fix obvious cases of "it's" being used when "its" was meant.
Signed-off-by: Francis Galiegue <fgaliegue@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Update status and URL for the "Gary's Encyclopedia" entry.
Signed-off-by: Paul Jackson <pj@sgi.com>
Most of these fixes were already submitted for old kernel versions, and were
approved, but for some reason they never made it into the releases.
Because this is a consolidation of a couple old missed patches, it touches both
Kconfigs and documentation texts.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Convert files within the Documentation directory to UTF-8.
Adrian Bunk:
small additional fixes
Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com>
Signed-off-by: James Nelson <james4765@gmail.com>
Now that devfs is removed, there's no longer any need to document how to
do this or that with devfs.
This patch includes some improvements by Joe Perches.
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups
and typo/spello fixes. Sadly there are still a lot of bad URLs remaining.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
infrastructure for it.
Let it rip!
