This patch fixes typos in various Documentation txts.
This patch addresses some words starting with the letter 'A'.
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Alan Cox <alan@redhat.com>
We removed 8250_acpi in 2.6.17. If we don't have PNPACPI turned on, we
won't find any ACPI serial devices, so mention this requirement in the
troubleshooting part of the documentation.
CONFIG_PNPACPI is already turned on in all the relevant defconfigs.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: "Luck, Tony" <tony.luck@intel.com>
This closes a couple holes in our attribute aliasing avoidance scheme:
- The current kernel fails mmaps of some /dev/mem MMIO regions because
they don't appear in the EFI memory map. This keeps X from working
on the Intel Tiger box.
- The current kernel allows UC mmap of the 0-1MB region of
/sys/.../legacy_mem even when the chipset doesn't support UC
access. This causes an MCA when starting X on HP rx7620 and rx8620
boxes in the default configuration.
There's more detail in the Documentation/ia64/aliasing.txt file this
adds, but the general idea is that if a region might be covered by
a granule-sized kernel identity mapping, any access via /dev/mem or
mmap must use the same attribute as the identity mapping.
Otherwise, we fall back to using an attribute that is supported
according to the EFI memory map, or to using UC if the EFI memory
map doesn't mention the region.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Add Documentation/ia64/mca.txt, an ad-hoc collection of notes on IA64
MCA and INIT processing.
Signed-off-by: Keith Owens <kaos@sgi.com>
infrastructure for it.
Let it rip!
