path: root/Documentation/i2c
2013-11-14i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCHJames Ralston
This patch adds the SMBus Device IDs for the Intel Wildcat Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-09-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "The usual trivial updates all over the tree -- mostly typo fixes and documentation updates" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (52 commits) doc: Documentation/cputopology.txt fix typo treewide: Convert retrun typos to return Fix comment typo for init_cma_reserved_pageblock Documentation/trace: Correcting and extending tracepoint documentation mm/hotplug: fix a typo in Documentation/memory-hotplug.txt power: Documentation: Update s2ram link doc: fix a typo in Documentation/00-INDEX Documentation/printk-formats.txt: No casts needed for u64/s64 doc: Fix typo "is is" in Documentations treewide: Fix printks with 0x%# zram: doc fixes Documentation/kmemcheck: update kmemcheck documentation doc: documentation/hwspinlock.txt fix typo PM / Hibernate: add section for resume options doc: filesystems : Fix typo in Documentations/filesystems scsi/megaraid fixed several typos in comments ppc: init_32: Fix error typo "CONFIG_START_KERNEL" treewide: Add __GFP_NOWARN to k.alloc calls with v.alloc fallbacks page_isolation: Fix a comment typo in test_pages_isolated() doc: fix a typo about irq affinity ...
2013-08-19Documentation: i2c: Fix example in instantiating-devicesSachin Kamat
__initdata should be placed between the variable name and equal sign for the variable to be placed in the intended section. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-08-15i2c: piix4: Add support for secondary SMBus on AMD SB800 and AMD FCH chipsetsRudolf Marek
Add support for the secondary SMBus controller on the AMD SB800 and AMD FCH chipsets. Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Tested-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-07-25doc: Fix typo in doucmentationsMasanari Iida
Correct typo (double words) in documentations. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-04Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: - new drivers: Kontron PLD, Wondermedia VT - mv64xxx driver gained sun4i support and a bigger cleanup - duplicate driver 'intel-mid' removed - added generic device tree binding for sda holding time (and designware driver already uses it) - we tried to allow driver probing with only device tree and no i2c ids, but I had to revert it because of side effects. Needs some rethinking. - driver bugfixes, cleanups... * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (34 commits) i2c-designware: use div_u64 to fix link i2c: Kontron PLD i2c bus driver i2c: iop3xxx: fix build failure after waitqueue changes i2c-designware: make SDA hold time configurable i2c: mv64xxx: Set bus frequency to 100kHz if clock-frequency is not provided i2c: imx: allow autoloading on dt ids i2c: mv64xxx: Fix transfer error code i2c: i801: SMBus patch for Intel Coleto Creek DeviceIDs i2c: omap: correct usage of the interrupt enable register i2c-pxa: prepare clock before use Revert "i2c: core: make it possible to match a pure device tree driver" i2c: nomadik: allocate adapter number dynamically i2c: nomadik: support elder Nomadiks i2c: mv64xxx: Add Allwinner sun4i compatible i2c: mv64xxx: make the registers offset configurable i2c: mv64xxx: Add macros to access parts of registers i2c: vt8500: Add support for I2C bus on Wondermedia SoCs i2c: designware: fix race between subsequent xfers i2c: bfin-twi: Read and write the FIFO in loop i2c: core: make it possible to match a pure device tree driver ...
2013-06-20i2c: i801: SMBus patch for Intel Coleto Creek DeviceIDsSeth Heasley
This patch adds the i801 SMBus Controller DeviceIDs for the Intel Coleto Creek PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-06-03i2c-piix4: Add AMD CZ SMBus device IDShane Huang
To add AMD CZ SMBus controller device ID. [bhelgaas: drop pci_ids.h update] Signed-off-by: Shane Huang <shane.huang@amd.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jean Delvare <khali@linux-fr.org> Cc: stable@vger.kernel.org
2013-03-22i2c: Fix my e-mail address in drivers and documentationGuenter Roeck
My old e-mail address is no longer working. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-02-15i2c: i801: Add Device IDs for Intel Wellsburg PCHJames Ralston
This patch adds the SMBus Device IDs for the Intel Wellsburg PCH Signed-off-by: James Ralston <james.d.ralston@intel.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
2013-02-11i2c: sis630: Add SIS964 supportAmaury Decrême
Signed-off-by: Amaury Decrême <amaury.decreme@gmail.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
2013-02-10i2c: Adding support for Intel iSMT SMBus 2.0 host controllerNeil Horman
The iSMT (Intel SMBus Message Transport) supports multi-master I2C/SMBus, as well as IPMI. It's operation is DMA-based and utilizes descriptors to initiate transactions on the bus. The iSMT hardware can act as both a master and a target, although this driver only supports being a master. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Bill Brown <bill.e.brown@intel.com> Tested-by: Seth Heasley <seth.heasley@intel.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <wolfram@the-dreams.de>
2013-02-08i2c: i801: SMBus patch for Intel Avoton DeviceIDsSeth Heasley
This patch adds the PCU SMBus DeviceID for the Intel Avoton SOC. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Reviewed-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2013-01-28i2c: core: Remove definition of i2c_smbus_process_callTushar Behera
i2c_smbus_process_call has no users in the kernel, so this can be removed. Documentation for the same has been updated accordingly. Fixes following sparse warning. drivers/i2c/i2c-core.c:1871:5: warning: symbol 'i2c_smbus_process_call' was not declared. Should it be static? [wsa: updated the documentation] Signed-off-by: Tushar Behera <tushar.behera@linaro.org> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2013-01-03Documentation: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from the kernel documentation. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-16i2c: Mention functionality flags in SMBus protocol documentationJean Delvare
While the mapping between I2C adapter functionality flags and i2c_smbus_*() helper functions is rather obvious, let's still document it for clarity. Also drop the reference to 2 command byte I2C block reads, there is no support for that in the kernel at the moment. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-10-05i2c-mux-gpio: Update documentationJean Delvare
* Document the possibility to pass relative GPIO pin numbers. * Document what platform device IDs to use, so that they do not collide. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Peter Korsgaard <peter.korsgaard@barco.com>
2012-10-05i2c-viapro: Add VIA VX900 device IDJean Delvare
The SMBus controller in the VIA VX900 appears to be compatible with the VIA VX855, so just add the device ID. This closes kernel bug #43096. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-09-10i2c-i801: Add Device IDs for Intel Lynx Point-LP PCHJames Ralston
Add the SMBus Device IDs for the Intel Lynx Point-LP PCH. Signed-off-by: James Ralston <james.d.ralston@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24i2c-i801: Enable IRQ for SMBus transactionsDaniel Kurtz
Add a new 'feature' to i2c-i801 to enable using PCI interrupts. When the feature is enabled, then an isr is installed for the device's PCI IRQ. An I2C/SMBus transaction is always terminated by one of the following interrupt sources: FAILED, BUS_ERR, DEV_ERR, or on success: INTR. When the isr fires for one of these cases, it sets the ->status variable and wakes up the waitq. The waitq then saves off the status code, and clears ->status (in preparation for some future transaction). The SMBus controller generates an INTR irq at the end of each transaction where INTREN was set in the HST_CNT register. No locking is needed around accesses to priv->status since all writes to it are serialized: it is only ever set once in the isr at the end of a transaction, and cleared while no interrupts can occur. In addition, the I2C adapter lock guarantees that entire I2C transactions for a single adapter are always serialized. For this patch, the INTREN bit is set only for SMBus block, byte and word transactions, but not for I2C reads or writes. The use of the DS (BYTE_DONE) interrupt with byte-by-byte I2C transactions is implemented in a subsequent patch. The interrupt feature has only been enabled for COUGARPOINT hardware. In addition, it is disabled if SMBus is using the SMI# interrupt. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-07-24i2c/writing-clients: Mention module_i2c_driver()Jean Delvare
Based on a previous patch from Peter Meerwald. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Peter Meerwald <p.meerwald@bct-electronic.com>
2012-07-24i2c-piix4: Support AMD auxiliary SMBus controllerAndrew Armenia
Some AMD chipsets, such as the SP5100, have an auxiliary SMBus controller with a second set of registers. This patch adds support for this auxiliary controller. Tested on ASUS KCMA-D8 motherboard. Signed-off-by: Andrew Armenia <andrew@asquaredlabs.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-05-30i2c: Split I2C_M_NOSTART support out of I2C_FUNC_PROTOCOL_MANGLINGMark Brown
Since there are uses for I2C_M_NOSTART which are much more sensible and standard than most of the protocol mangling functionality (the main one being gather writes to devices where something like a register address needs to be inserted before a block of data) create a new I2C_FUNC_NOSTART for this feature and update all the users to use it. Also strengthen the disrecommendation of the protocol mangling while we're at it. In the case of regmap-i2c we remove the requirement for mangling as I2C_M_NOSTART is the only mangling feature which is being used. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-05-12i2c: Rename last mux driver to standard patternJean Delvare
Update the MAINTAINERS entry and all other references accordingly. Based on an original patch by Wolfram Sang. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> [wsa: fixed merge conflict due to rework in i2c_add_mux_adapter()] Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-26i2c-i801: Add device IDs for Intel Lynx PointSeth Heasley
Add the SMBus controller device IDs for the Intel Lynx Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2012-03-13USB: ohci-nxp: Rename symbols from pnx4008 to nxpRoland Stigge
Since this driver is compatible with several NXP devices, the driver was renamed accordingly. This patch also changes the respective symbol names. Signed-off-by: Roland Stigge <stigge@antcom.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-11-23i2c: Fix device name for 10-bit slave addressJean Delvare
10-bit addresses overlap with traditional 7-bit addresses, leading in device name collisions. Add an arbitrary offset to 10-bit addresses to prevent this collision. The offset was chosen so that the address is still easily recognizable. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2011-10-30i2c: Functions for byte-swapped smbus_write/read_word_dataJonathan Cameron
Reimplemented at least 17 times discounting error mangling cases where it could be used. Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24i2c-i801: SMBus patch for Intel Panther Point DeviceIDsSeth Heasley
This patch adds the SMBus controller DeviceID for the Intel Panther Point PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-05-24i2c/writing-clients: Fix foo_driver.id_tableVikram Narayanan
The i2c_device_id structure variable's name is not used in the i2c_driver structure. Signed-off-by: Vikram Narayanan <vikram186@gmail.com> Cc: stable@kernel.org Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-22Merge branch 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linux: i2c-pxa2xx: Don't clear isr bits too early i2c-pxa2xx: Fix register offsets i2c-pxa2xx: pass of_node from platform driver to adapter and publish i2c-pxa2xx: check timeout correctly i2c-pxa2xx: add support for shared IRQ handler i2c-pxa2xx: Add PCI support for PXA I2C controller ARM: pxa2xx: reorganize I2C files i2c-pxa2xx: use dynamic register layout i2c-mxs: set controller to pio queue mode after reset i2c-eg20t: support new device OKI SEMICONDUCTOR ML7213 IOH i2c/busses: Add support for Diolan U2C-12 USB-I2C adapter
2011-03-20i2c-i801: SMBus patch for Intel DH89xxCC DeviceIDsSeth Heasley
Add the SMBus Controller DeviceIDs for the Intel DH89xxCC PCH. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-20i2c: Minor fixes to upgrading-clients documentJean Delvare
* Typical legacy drivers implemented method .detach_client, not .detach_adapter. * Drop all references to __devexit, as i2c drivers shouldn't use it. Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-20i2c: Fix typo in instantiating-devices documentRoman Fietze
The struct i2c_board_info member holding the name is "type", not "name". Signed-off-by: Roman Fietze <roman.fietze@telemotive.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org
2011-01-27i2c/busses: Add support for Diolan U2C-12 USB-I2C adapterGuenter Roeck
This patch adds support for the Diolan U2C-12 USB-I2C adapter. It also updates MAINTAINERS to list the author as maintainer. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-01-10i2c: Add generic I2C multiplexer using GPIO APIPeter Korsgaard
Add an i2c mux driver providing access to i2c bus segments using a hardware MUX sitting on a master bus and controlled through gpio pins. E.G. something like: ---------- ---------- Bus segment 1 - - - - - | | SCL/SDA | |-------------- | | | |------------| | | | | | Bus segment 2 | | | Linux | GPIO 1..N | MUX |--------------- Devices | |------------| | | | | | | | Bus segment M | | | |---------------| | ---------- ---------- - - - - - SCL/SDA of the master I2C bus is multiplexed to bus segment 1..M according to the settings of the GPIO pins 1..N. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-31i2c-i801: Add PCI idents for Patsburg 'IDF' SMBus controllersDavid Woodhouse
These are the extra 'Integrated Device Function' SMBus controllers found on the Patsburg chipset. Mention the absence of slave mode support. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-10-31i2c-i801: Add Intel Patsburg device IDSeth Heasley
Add support for the Intel Patsburg PCH SMBus Controller. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-11i2c: Add support for custom probe functionJean Delvare
The probe method used by i2c_new_probed_device() may not be suitable for all cases. Let the caller provide its own, optional probe function. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-03Documentation/i2c: Checkpatch cleanupAndrea Gelmini
Remove all trailing whitespace in Documentation/i2c. Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-21i2c-i801: Let the user disable selected driver featuresJean Delvare
Let the user disable selected features normally supported by the device. This makes it possible to work around possible driver or hardware bugs if the feature in question doesn't work as intended for whatever reason. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Felix Rubinstein <felixru@gmail.com>
2010-05-04i2c-core: Erase pointer to clientdata on removalWolfram Sang
After discovering that a lot of i2c-drivers leave the pointer to their clientdata dangling, it was decided to let the core handle this issue. It is assumed that the core may access the private data after remove() as there are no guarantees for the lifetime of such pointers anyhow (see thread starting at http://lkml.org/lkml/2010/3/21/68) Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-02i2c: Document the message size limitZhangfei Gao
i2c_master_send & i2c_master_recv do not support more than 64 kb transfer, since msg.len is u16. Signed-off-by: Zhangfei Gao <zgao6@marvell.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-02i2c-parport-light: Add SMBus alert supportJean Delvare
Add support for the SMBus alert mechanism to the i2c-parport-light driver. The ADM1032 evaluation board at least is properly wired for this. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-02i2c-parport: Add SMBus alert supportJean Delvare
Add support for the SMBus alert mechanism to the i2c-parport driver. The ADM1032 evaluation board at least is properly wired for this. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-02i2c: Add SMBus alert supportJean Delvare
SMBus alert support. The SMBus alert protocol allows several SMBus slave devices to share a single interrupt pin on the SMBus master, while still allowing the master to know which slave triggered the interrupt. This is based on preliminary work by David Brownell. The key difference between David's implementation and mine is that his was part of i2c-core, while mine is split into a separate, standalone module named i2c-smbus. The i2c-smbus module is meant to include support for all SMBus extensions to the I2C protocol in the future. The benefit of this approach is a zero cost for I2C bus segments which do not need SMBus alert support. Where David's implementation increased the size of struct i2c_adapter by 7% (40 bytes on i386), mine doesn't touch it. Where David's implementation added over 150 lines of code to i2c-core (+10%), mine doesn't touch it. The only change that touches all the users of the i2c subsystem is a new callback in struct i2c_driver (common to both implementations.) I seem to remember Trent was worried about the footprint of David'd implementation, hopefully mine addresses the issue. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-02i2c-i801: Add Intel Cougar Point device IDsSeth Heasley
Add the Intel Cougar Point (PCH) SMBus controller device IDs. Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
