Declare myself the maintainer of the lm78 driver. I still have a
running system with one of these chips.
Also count myself as a co-author of the driver. With 34 commits over
6 years, it seems fair.
Add chassis intrusion detection support for all supported devices,
using the standard interface.
This patch adds a new driver for SMSC SCH5636 Super I/O chips.
The chips include an embedded microcontroller for hardware monitoring
solutions, allowing motherboard manufacturers to create their own
custom hwmon solution based upon the SCH5636.
Currently the sch5636 driver only supports the Fujitsu Theseus SCH5636
based hwmon solution. The sch5636 driver runs a sanity check on
loading to ensure it is dealing with a Fujitsu Theseus and not with
another custom SCH5636 based hwmon solution.
Add some CPU series IDs and links to the Fam12h datasheets.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
The F71869A is almost the same as the F71869F/E, except that it has
the normal number of temp and pwm zones for a F71882FG derived chip,
rather then the limited number of the F71869F/E.
Tested-by: Max Baldwin <archerseven@gmail.com>
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
This is a new driver for the SMSC EMC6W201 hardware monitoring device.
The device is functionally close to the EMC6D100 series, but is
register-incompatible.
Tested-by: Harry G McGavran Jr <w5pny@arrl.net>
Tested-by: Jeff Rickman <jrickman@myamigos.us>
The MAX6650 has only one fan input.
Acked-by: "Hans J. Koch" <hjk@hansjkoch.de>
MAX6650 device detection is unreliable, we got reports of false
positives. We now have many ways to let users instantiate the devices
explicitly, so unreliable detection should be dropped.
This CPU family provides NB register values to gather following
TDP information
* ProcessorPwrWatts: Specifies in Watts the maximum amount of power
the processor can support.
* CurrPwrWatts: Specifies in Watts the current amount of power being
consumed by the processor.
This driver provides
* power1_crit (ProcessorPwrWatts)
* power1_input (CurrPwrWatts)
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
AMDs upcoming CPUs use the same mechanism for the internal
temperature reporting as the Fam10h CPUs, so we just needed to add
the appropriate PCI-ID to the list.
This allows to use the k10temp driver on those CPUs.
While at it change the Kconfig entry to be more generic.
Signed-off-by: Andre Przywara <andre.przywara@amd.com>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
After the merge of pkgtemp functionality into the coretemp driver,
the pkgtemp driver is no longer necessary. Remove it.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
This patch merges the pkgtemp with coretemp driver.
The sysfs interfaces for all cores in the same pkg
are shown under one directory, in hwmon. It also
supports CONFIG_HOTPLUG_CPU. So, the sysfs interfaces
are created when each core comes online and are
removed when it goes offline.
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
[guenter.roeck@ericsson.com: Fixed section reference errors]
Add support for Analog Devices ADM1275 Hot-Swap Controller and Digital Power
Monitor
Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
Controllers
Hardware monitoring support for TI UCD90120, UCD90124, UCD9090, and UCD90910
Sequencer and System Health Controllers.
This patch adds hardware monitoring support for TI UCD9220, UCD9222, UCD9224,
UCD9240, UCD9244, UCD9246, and UCD9248 Digital PWM System Controllers.
This patch adds hardware monitoring support for Maxim MAX16065, MAX16066,
MAX16067, MAX16068, MAX16070, and MAX16071 flash-configurable system managers
with nonvolatile fault registers.
Reviewed-by: Jean Delvare <khali@linux-fr.org>
The sht15 sensor allows validating exchanges to and from the device
using a crc8 function. An utility function to reverse a byte has also
been added.
Signed-off-by: Jerome Oufella <jerome.oufella@savoirfairelinux.com>
Acked-by: Jonathan Cameron <jic23@cam.ac.uk>
* Add support for:
- Heater.
- End of battery notice.
- Ability not to reload from OTP.
- Low resolution (12bit temp, 8bit humidity).
* Add an utility function to read individual bytes from the device.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
* Add a documentation file for the device.
* Respect a bit more the kernel-doc syntax.
* Rename some variables for clarity.
* Use bool type for flags.
* Use an enum for states (actions being done).
MAX6642 is a SMBus-Compatible Remote/Local Temperature Sensor with
Overtemperature Alarm from Maxim.
Signed-off-by: Per Dalen <per.dalen@appeartv.com>
Recent Xeon processor thermal sensors are supported by the coretemp
driver and not the adm1021 driver. Only one old generation of Xeon
processors (the first Netburst ones) are supported by the adm1021
driver.
Reported-by: Darren Hart <dvhart@linux.intel.com>
The lm90 driver's attribute update interval is configurable.
Reflect this information in the driver documentation.
This patch adds support for ADT7461A and NCT1008 to the lm90 driver.
Both chips have identical functionality and report the same manufacturing ID
and device ID values.
MAX34440 and MAX34441 have their own driver, thus there should be explicit
documentation instead of mentioning the chips in the generic PMBus driver
documentation.
MAX16064 has its own driver, thus should have its own documentation instead of
being mentioned in the generic PMBus driver documentation.
MAX8688 has its own driver, thus should have its own documentation instead of
Fix spelling, correct label name error, and add missing attribute to PMBus
tempererature may sound interesting, but temperature is still preferred.
When writing hardware monitoring drivers, there are some common pitfalls which
keep coming up in code reviews. This patch provides a document describing all
those pitfalls and how to avoid them.
Add support for the Fintek F81865F. It's essentially compatible with
the F71882FG, but has fewer inputs: 7 voltage, 2 temperature and 2 fan
inputs only.
Acked-by: Hans de Goede <hdegoede@redhat.com>
The list of supported devices was not always well documented in all
places. Clarify and list all devices in documentation, Kconfig and
the driver itself.
This driver exposes the sysfs nodes of the TWL4030 MADC module.
All the voltage channel values are expressed in terms of mV. Channel 13
and channel 14 are reserved. There are channels which represent
temperature and current the output is represented by celcius
and mA respectively.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Configuration for ads1015 gain and datarate is possible via
devicetree or platform data.
This is a followup patch to previous ads1015 patches on Jean Delvares
tree.
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
SMSC SCH5627 Super I/O chips include complete hardware monitoring
capabilities. They can monitor up to 5 voltages, 4 fans and 8
temperatures.
The hardware monitoring part of the SMSC SCH5627 is accessed by talking
through an embedded microcontroller. An application note describing the
protocol for communicating with the microcontroller is available upon
request. Please mail me if you want a copy.
Add support for detection of the National Semiconductor LM75A using the ID
register value.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't
belong to drivers/hwmon. Move them to drivers/misc, short of a better
home.
Acked-by: Eric Piel <eric.piel@tremplin-utc.net>
Tested-by: Eric Piel <eric.piel@tremplin-utc.net>
Tested-by: Takashi Iwai <tiwai@suse.de>
The hp_accel driver isn't a hardware monitoring driver, so it doesn't
belong to drivers/hwmon. Move it to drivers/platform/x86, assuming HP
doesn't ship non-x86 laptops.
Apparently users are interested in this information, so let's provide
it.
Note that these 2 are register compatible and report the same superio id,
but they are 2 distinct chips / models!
Tested-by: Thomas Faber <thfabba@gmx.de>
Tested-by: Alexey Sychev <owl@umail.ru>
Tested-by: Dieter Bloms <dieter@bloms.de>
Note that this patch also makes 2 changes to the code paths for the f71889fg
to keep the code unified between the 2 (for simplicities sake). Both of these
are harmless for then f71889fg:
1) The first change is to always set the FAN_PROG_SEL bit to 0. This influences
accesses to some banked fan / pwm registers. On the f71889fg no registers
which we use are banked. On the f71889ed however some more fan registers
have been banked including one which we use, by making the FAN_PROG_SEL bit
0, address 0x96 will point to the right register.
2) The second change is to see a FANx_TEMP_SEL value of 0 as pointing to
a PECI / AMDSI value, and thus disable our pwm related sysfs attr.
This is correct for the f71889ed and on the f71889fg 0 is a reserved
value, so we should never see it and if we do, disabling the pwm related
sysfs attr is a sane thing to do.
Tested-by: Thomas Greve <tg42@gmx.net>
Tested-by: Sander Eikelenboom <linux@eikelenboom.it>
This patch adds support for NCT6775F and NCT6776F to the w83627ehf driver.
Tested-by: Ian Dobson <i.dobson@planet-ian.com> (NCT6776F)
Tested-by: Zachary Marzec <zmarzec@gmail.com> (ASUS P8P67 PRO/NCT6776F)
Acked-by: Ian Dobson <i.dobson@planet-ian.com>
Add support for 4th temperature sensor on W83677HG-B.
Display temperature labels on W83677HG-B to report temperature sources.
Some fan control chips support a configuration register to set the number of
tachometer pulses per fan revolution. Add an ABI attribute to support this
configuration register.
LTC4151 is High Voltage I2C Current and Voltage Monitor from Linear
Technology.
