s/seperate/separate
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Fix obvious cases of "it's" being used when "its" was meant.
Signed-off-by: Francis Galiegue <fgaliegue@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
This patch adds documentation for new 9P options introduced in
2.6.34.
Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com>
Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (28 commits)
ceph: update discussion list address in MAINTAINERS
ceph: some documentations fixes
ceph: fix use after free on mds __unregister_request
ceph: avoid loaded term 'OSD' in documention
ceph: fix possible double-free of mds request reference
ceph: fix session check on mds reply
ceph: handle kmalloc() failure
ceph: propagate mds session allocation failures to caller
ceph: make write_begin wait propagate ERESTARTSYS
ceph: fix snap rebuild condition
ceph: avoid reopening osd connections when address hasn't changed
ceph: rename r_sent_stamp r_stamp
ceph: fix connection fault con_work reentrancy problem
ceph: prevent dup stale messages to console for restarting mds
ceph: fix pg pool decoding from incremental osdmap update
ceph: fix mds sync() race with completing requests
ceph: only release unused caps with mds requests
ceph: clean up handle_cap_grant, handle_caps wrt session mutex
ceph: fix session locking in handle_caps, ceph_check_caps
ceph: drop unnecessary WARN_ON in caps migration
New documentation should have an entry in the 00-INDEX. Correct git
urls.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Signed-off-by: Sage Weil <sage@newdream.net>
commit 3f226aa1c (mempolicy: support mpol=local tmpfs mount option) added
new mpol=local mount option. but it didn't add a documentation.
This patch does it.
Cc: Ravikiran Thirumalai <kiran@scalex86.org>
Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: <stable@kernel.org>
'OSD' means different things to different people; avoid it here to avoid
confusion.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits)
ceph: update for write_inode API change
ceph: reset osd after relevant messages timed out
ceph: fix flush_dirty_caps race with caps migration
ceph: include migrating caps in issued set
ceph: fix osdmap decoding when pools include (removed) snaps
ceph: return EBADF if waiting for caps on closed file
ceph: set osd request message front length correctly
ceph: reset front len on return to msgpool; BUG on mismatched front iov
ceph: fix snaptrace decoding on cap migration between mds
ceph: use single osd op reply msg
ceph: reset bits on connection close
ceph: remove bogus mds forward warning
ceph: remove fragile __map_osds optimization
ceph: fix connection fault STANDBY check
ceph: invalidate_authorizer without con->mutex held
ceph: don't clobber write return value when using O_SYNC
ceph: fix client_request_forward decoding
ceph: drop messages on unregistered mds sessions; cleanup
ceph: fix comments, locking in destroy_inode
ceph: move dereference after NULL test
Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
Typo fix for a filename in procfs documentation.
Signed-off-by: Rob Landley <rob@landley.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits)
doc: fix typo in comment explaining rb_tree usage
Remove fs/ntfs/ChangeLog
doc: fix console doc typo
doc: cpuset: Update the cpuset flag file
Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed
Remove drivers/parport/ChangeLog
Remove drivers/char/ChangeLog
doc: typo - Table 1-2 should refer to "status", not "statm"
tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments
No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h
devres/irq: Fix devm_irq_match comment
Remove reference to kthread_create_on_cpu
tree-wide: Assorted spelling fixes
tree-wide: fix 'lenght' typo in comments and code
drm/kms: fix spelling in error message
doc: capitalization and other minor fixes in pnp doc
devres: typo fix s/dev/devm/
Remove redundant trailing semicolons from macros
fix typo "definetly" -> "definitely" in comment
tree-wide: s/widht/width/g typo in comments
Fix trivial conflict in Documentation/laptops/00-INDEX
Make dnotify_test.c source file and add it to Makefile so that
bitrot can be prevented.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
* git://git.kernel.org/pub/scm/linux/kernel/git/joern/logfs:
[LogFS] Change magic number
[LogFS] Remove h_version field
[LogFS] Check feature flags
[LogFS] Only write journal if dirty
[LogFS] Fix bdev erases
[LogFS] Silence gcc
[LogFS] Prevent 64bit divisions in hash_index
[LogFS] Plug memory leak on error paths
[LogFS] Add MAINTAINERS entry
[LogFS] add new flash file system
Fixed up trivial conflict in lib/Kconfig, and a semantic conflict in
fs/logfs/inode.c introduced by write_inode() being changed to use
writeback_control' by commit a9185b41a4f84971b930c519f0c63bd450c4810d
("pass writeback_control to ->write_inode")
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: (22 commits)
nfsd4: fix minor memory leak
svcrpc: treat uid's as unsigned
nfsd: ensure sockets are closed on error
Revert "sunrpc: move the close processing after do recvfrom method"
Revert "sunrpc: fix peername failed on closed listener"
sunrpc: remove unnecessary svc_xprt_put
NFSD: NFSv4 callback client should use RPC_TASK_SOFTCONN
xfs_export_operations.commit_metadata
commit_metadata export operation replacing nfsd_sync_dir
lockd: don't clear sm_monitored on nsm_reboot_lookup
lockd: release reference to nsm_handle in nlm_host_rebooted
nfsd: Use vfs_fsync_range() in nfsd_commit
NFSD: Create PF_INET6 listener in write_ports
SUNRPC: NFS kernel APIs shouldn't return ENOENT for "transport not found"
SUNRPC: Bury "#ifdef IPV6" in svc_create_xprt()
NFSD: Support AF_INET6 in svc_addsock() function
SUNRPC: Use rpc_pton() in ip_map_parse()
nfsd: 4.1 has an rfc number
nfsd41: Create the recovery entry for the NFSv4.1 client
nfsd: use vfs_fsync for non-directories
Add documentation for /proc/pagetypeinfo.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
A frequent questions from users about memory management is what numbers of
swap ents are user for processes. And this information will give some
hints to oom-killer.
Besides we can count the number of swapents per a process by scanning
/proc/<pid>/smaps, this is very slow and not good for usual process
information handler which works like 'ps' or 'top'. (ps or top is now
enough slow..)
This patch adds a counter of swapents to mm_counter and update is at each
swap events. Information is exported via /proc/<pid>/status file as
[kamezawa@bluextal memory]$ cat /proc/self/status
State: R (running)
Tgid: 2910
Pid: 2910
PPid: 2823
TracerPid: 0
Uid: 500 500 500 500
Gid: 500 500 500 500
FDSize: 256
Groups: 500
VmPeak: 82696 kB
VmSize: 82696 kB
VmLck: 0 kB
VmHWM: 432 kB
VmRSS: 432 kB
VmData: 172 kB
VmStk: 84 kB
VmExe: 48 kB
VmLib: 1568 kB
VmPTE: 40 kB
VmSwap: 0 kB <=============== this.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Considering the nature of per mm stats, it's the shared object among
threads and can be a cache-miss point in the page fault path.
This patch adds per-thread cache for mm_counter. RSS value will be
counted into a struct in task_struct and synchronized with mm's one at
events.
Now, in this patch, the event is the number of calls to handle_mm_fault.
Per-thread value is added to mm at each 64 calls.
rough estimation with small benchmark on parallel thread (2threads) shows
[before]
4.5 cache-miss/faults
[after]
4.0 cache-miss/faults
Anyway, the most contended object is mmap_sem if the number of threads grows.
Cc: Minchan Kim <minchan.kim@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits)
quota: stop using QUOTA_OK / NO_QUOTA
dquot: cleanup dquot initialize routine
dquot: move dquot initialization responsibility into the filesystem
dquot: cleanup dquot drop routine
dquot: move dquot drop responsibility into the filesystem
dquot: cleanup dquot transfer routine
dquot: move dquot transfer responsibility into the filesystem
dquot: cleanup inode allocation / freeing routines
dquot: cleanup space allocation / freeing routines
ext3: add writepage sanity checks
ext3: Truncate allocated blocks if direct IO write fails to update i_size
quota: Properly invalidate caches even for filesystems with blocksize < pagesize
quota: generalize quota transfer interface
quota: sb_quota state flags cleanup
jbd: Delay discarding buffers in journal_unmap_buffer
ext3: quota_write cross block boundary behaviour
quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota
quota: split out compat_sys_quotactl support from quota.c
quota: split out netlink notification support from quota.c
quota: remove invalid optimization from quota_sync_all
Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
Get rid of the initialize dquot operation - it is now always called from
the filesystem and if a filesystem really needs it's own (which none
currently does) it can just call into it's own routine directly.
Rename the now static low-level dquot_initialize helper to __dquot_initialize
and vfs_dq_init to dquot_initialize to have a consistent namespace.
Get rid of the drop dquot operation - it is now always called from
Rename the now static low-level dquot_drop helper to __dquot_drop
and vfs_dq_drop to dquot_drop to have a consistent namespace.
Get rid of the transfer dquot operation - it is now always called from
Rename the now static low-level dquot_transfer helper to __dquot_transfer
and vfs_dq_transfer to dquot_transfer to have a consistent namespace,
and make the new dquot_transfer return a normal negative errno value
which all callers expect.
Get rid of the alloc_inode and free_inode dquot operations - they are
always called from the filesystem and if a filesystem really needs
their own (which none currently does) it can just call into it's
Also get rid of the vfs_dq_alloc/vfs_dq_free wrappers and always
call the lowlevel dquot_alloc_inode / dqout_free_inode routines
directly, which now lose the number argument which is always 1.
Get rid of the alloc_space, free_space, reserve_space, claim_space and
release_rsv dquot operations - they are always called from the filesystem
and if a filesystem really needs their own (which none currently does)
Move shared logic into the common __dquot_alloc_space,
dquot_claim_space_nodirty and __dquot_free_space low-level methods,
and rationalize the wrappers around it to move as much as possible
code into the common block for CONFIG_QUOTA vs not. Also rename
all these helpers to be named dquot_* instead of vfs_dq_*.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits)
init: Open /dev/console from rootfs
mqueue: fix typo "failues" -> "failures"
mqueue: only set error codes if they are really necessary
mqueue: simplify do_open() error handling
mqueue: apply mathematics distributivity on mq_bytes calculation
mqueue: remove unneeded info->messages initialization
mqueue: fix mq_open() file descriptor leak on user-space processes
fix race in d_splice_alias()
set S_DEAD on unlink() and non-directory rename() victims
vfs: add NOFOLLOW flag to umount(2)
get rid of ->mnt_parent in tomoyo/realpath
hppfs can use existing proc_mnt, no need for do_kern_mount() in there
Mirror MS_KERNMOUNT in ->mnt_flags
get rid of useless vfsmount_lock use in put_mnt_ns()
Take vfsmount_lock to fs/internal.h
get rid of insanity with namespace roots in tomoyo
take check for new events in namespace (guts of mounts_poll()) to namespace.c
Don't mess with generic_permission() under ->d_lock in hpfs
sanitize const/signedness for udf
nilfs: sanitize const/signedness in dealing with ->d_name.name
Fix up fairly trivial (famous last words...) conflicts in
drivers/infiniband/core/uverbs_main.c and security/tomoyo/realpath.c
* document locking
* add the missing part of data structure invariants (relationship
between mnt_share and mnt_slave lists in case of a peer group
among slaves).
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: add reader's lock for cno in nilfs_ioctl_sync
nilfs2: delete unnecessary condition in load_segment_summary
nilfs2: move iterator to write log into segment buffer
nilfs2: get rid of s_dirt flag use
nilfs2: get rid of nilfs_segctor_req struct
nilfs2: delete unnecessary condition in nilfs_dat_translate
nilfs2: fix potential hang in nilfs_error on errors=remount-ro
nilfs2: use mnt_want_write in ioctls where write access is needed
nilfs2: issue discard request after cleaning segments
Fixes a typo in proc.txt documentation. Table 1-2 should refer to
Signed-off-by: Mulyadi Santosa <mulyadi.santosa@gmail.com>
This adds a function to send discard requests for given array of
segment numbers, and calls the function when garbage collection
succeeded.
Signed-off-by: Jiro SEKIBA <jir@unicus.jp>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
No need to refer to an internet draft; there's an RFC now.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Add expedited functions. Review documentation and update
obsolete verbiage. Also fix the advice for the RCU CPU-stall
kernel configuration parameter, and document RCU CPU-stall
warnings.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
LKML-Reference: <12635142581866-git-send-email->
Commit d899bf7b (procfs: provide stack information for threads) introduced
to show stack information in /proc/{pid}/status. But it cause large
performance regression. Unfortunately /proc/{pid}/status is used ps
command too and ps is one of most important component. Because both to
take mmap_sem and page table walk are heavily operation.
If many process run, the ps performance is,
[before d899bf7b]
% perf stat ps >/dev/null
Performance counter stats for 'ps':
4090.435806 task-clock-msecs # 0.032 CPUs
229 context-switches # 0.000 M/sec
0 CPU-migrations # 0.000 M/sec
234 page-faults # 0.000 M/sec
8587565207 cycles # 2099.425 M/sec
9866662403 instructions # 1.149 IPC
3789415411 cache-references # 926.409 M/sec
30419509 cache-misses # 7.437 M/sec
128.859521955 seconds time elapsed
[after d899bf7b]
% perf stat ps > /dev/null
4305.081146 task-clock-msecs # 0.028 CPUs
480 context-switches # 0.000 M/sec
2 CPU-migrations # 0.000 M/sec
237 page-faults # 0.000 M/sec
9021211334 cycles # 2095.480 M/sec
10605887536 instructions # 1.176 IPC
3612650999 cache-references # 839.160 M/sec
23917502 cache-misses # 5.556 M/sec
152.277819582 seconds time elapsed
Thus, this patch revert it. Fortunately /proc/{pid}/task/{tid}/smaps
provide almost same information. we can use it.
Commit d899bf7b introduced two features:
1) Add the annotattion of [thread stack: xxxx] mark to
/proc/{pid}/task/{tid}/maps.
2) Add StackUsage field to /proc/{pid}/status.
I only revert (2), because I haven't seen (1) cause regression.
Cc: Stefani Seibold <stefani@seibold.net>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
nilfs2: update mailing list address
nilfs2: Storage class should be before const qualifier
nilfs2: trivial coding style fix
This replaces the list address for nilfs discussion to linux-nilfs at
vger.kernel.org from users at nilfs.org.
Per commit 240799cd, the option name for readahead should be
inode_readahead_blks, not inode_readahead.
Signed-off-by: Fang Wenqi <antonf@turbolinux.com.cn>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Many struct driver_attribute descriptors are purely read-only
structures, and there's no need to change them. Therefore make
the promise not to, which will let those descriptors be put in
a ro section.
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Most device_attributes are const, and are begging to be
put in a ro section. However, the create and remove
file interfaces were failing to propagate the const promise
which the only functions they call offer.
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits)
nfsd: remove pointless paths in file headers
nfsd: move most of nfsfh.h to fs/nfsd
nfsd: remove unused field rq_reffh
nfsd: enable V4ROOT exports
nfsd: make V4ROOT exports read-only
nfsd: restrict filehandles accepted in V4ROOT case
nfsd: allow exports of symlinks
nfsd: filter readdir results in V4ROOT case
nfsd: filter lookup results in V4ROOT case
nfsd4: don't continue "under" mounts in V4ROOT case
nfsd: introduce export flag for v4 pseudoroot
nfsd: let "insecure" flag vary by pseudoflavor
nfsd: new interface to advertise export features
nfsd: Move private headers to source directory
vfs: nfsctl.c un-used nfsd #includes
lockd: Remove un-used nfsd headers #includes
s390: remove un-used nfsd #includes
sparc: remove un-used nfsd #includes
parsic: remove un-used nfsd #includes
compat.c: Remove dependence on nfsd private headers
Using create_proc_entry() + ->proc_fops assignment is racy because
->proc_fops will be NULL for some time, use proc_create() to avoid race.
Cc: Jonathan Corbet <corbet@lwn.net>
Setting a thread's comm to be something unique is a very useful ability
and is helpful for debugging complicated threaded applications. However
currently the only way to set a thread name is for the thread to name
itself via the PR_SET_NAME prctl.
However, there may be situations where it would be advantageous for a
thread dispatcher to be naming the threads its managing, rather then
having the threads self-describe themselves. This sort of behavior is
available on other systems via the pthread_setname_np() interface.
This patch exports a task's comm via proc/pid/comm and
proc/pid/task/tid/comm interfaces, and allows thread siblings to write to
these values.
[akpm@linux-foundation.org: cleanups]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Mike Fulton <fultonm@ca.ibm.com>
Cc: Sean Foley <Sean_Foley@ca.ibm.com>
Cc: Darren Hart <dvhltc@us.ibm.com>
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (21 commits)
ext3: PTR_ERR return of wrong pointer in setup_new_group_blocks()
ext3: Fix data / filesystem corruption when write fails to copy data
ext4: Support for 64-bit quota format
ext3: Support for vfsv1 quota format
quota: Implement quota format with 64-bit space and inode limits
quota: Move definition of QFMT_OCFS2 to linux/quota.h
ext2: fix comment in ext2_find_entry about return values
ext3: Unify log messages in ext3
ext2: clear uptodate flag on super block I/O error
ext2: Unify log messages in ext2
ext3: make "norecovery" an alias for "noload"
ext3: Don't update the superblock in ext3_statfs()
ext3: journal all modifications in ext3_xattr_set_handle
ext2: Explicitly assign values to on-disk enum of filetypes
quota: Fix WARN_ON in lookup_one_len
const: struct quota_format_ops
ubifs: remove manual O_SYNC handling
afs: remove manual O_SYNC handling
kill wait_on_page_writeback_range
vfs: Implement proper O_SYNC semantics
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: (49 commits)
nilfs2: separate wait function from nilfs_segctor_write
nilfs2: add iterator for segment buffers
nilfs2: hide nilfs_write_info struct in segment buffer code
nilfs2: relocate io status variables to segment buffer
nilfs2: do not return io error for bio allocation failure
nilfs2: use list_splice_tail or list_splice_tail_init
nilfs2: replace mark_inode_dirty as nilfs_mark_inode_dirty
nilfs2: delete mark_inode_dirty in nilfs_delete_entry
nilfs2: delete mark_inode_dirty in nilfs_commit_chunk
nilfs2: change return type of nilfs_commit_chunk
nilfs2: split nilfs_unlink as nilfs_do_unlink and nilfs_unlink
nilfs2: delete redundant mark_inode_dirty
nilfs2: expand inode_inc_link_count and inode_dec_link_count
nilfs2: delete mark_inode_dirty from nilfs_set_link
nilfs2: delete mark_inode_dirty in nilfs_new_inode
nilfs2: add norecovery mount option
nilfs2: add helper to get if volume is in a valid state
nilfs2: move recovery completion into load_nilfs function
nilfs2: apply readahead for recovery on mount
nilfs2: clean up get/put function of a segment usage
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (47 commits)
ext4: Fix potential fiemap deadlock (mmap_sem vs. i_data_sem)
ext4: Do not override ext2 or ext3 if built they are built as modules
jbd2: Export jbd2_log_start_commit to fix ext4 build
ext4: Fix insufficient checks in EXT4_IOC_MOVE_EXT
ext4: Wait for proper transaction commit on fsync
ext4: fix incorrect block reservation on quota transfer.
ext4: quota macros cleanup
ext4: ext4_get_reserved_space() must return bytes instead of blocks
ext4: remove blocks from inode prealloc list on failure
ext4: wait for log to commit when umounting
ext4: Avoid data / filesystem corruption when write fails to copy data
ext4: Use ext4 file system driver for ext2/ext3 file system mounts
ext4: Return the PTR_ERR of the correct pointer in setup_new_group_blocks()
jbd2: Add ENOMEM checking in and for jbd2_journal_write_metadata_buffer()
ext4: remove unused parameter wbc from __ext4_journalled_writepage()
ext4: remove encountered_congestion trace
ext4: move_extent_per_page() cleanup
ext4: initialize moved_len before calling ext4_move_extents()
ext4: Fix double-free of blocks with EXT4_IOC_MOVE_EXT
ext4: use ext4_data_block_valid() in ext4_free_blocks()
Users on the list recently complained about differences across
filesystems w.r.t. how to mount without a journal replay.
In the discussion it was noted that xfs's "norecovery" option is
perhaps more descriptively accurate than "noload," so let's make
that an alias for ext3.
Also show this status in /proc/mounts
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
All callers really want the more logical filemap_fdatawait_range interface,
so convert them to use it and merge wait_on_page_writeback_range into
filemap_fdatawait_range.
Add exofs.txt to filesystems Documentation index and fix some typos,
identation and grammar.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
the description in Documentation/filesystems/proc.txt of the
procs_running entry in /proc/stat is confusing (according to that
description, it looks as if procs_running could only be a number
between 0 and the number of CPUs).
Changed it to a more accurate description in the patch attached.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (35 commits)
sched, cputime: Introduce thread_group_times()
sched, cputime: Cleanups related to task_times()
Revert "sched, x86: Optimize branch hint in __switch_to()"
sched: Fix isolcpus boot option
sched: Revert 498657a478c60be092208422fefa9c7b248729c2
sched, time: Define nsecs_to_jiffies()
sched: Remove task_{u,s,g}time()
sched: Introduce task_times() to replace task_{u,s}time() pair
sched: Limit the number of scheduler debug messages
sched.c: Call debug_show_all_locks() when dumping all tasks
sched: Optimize branch hint in context_switch()
sched: Optimize branch hint in pick_next_task_fair()
sched_feat_write(): Update ppos instead of file->f_pos
sched: Sched_rt_periodic_timer vs cpu hotplug
sched, kvm: Fix race condition involving sched_in_preempt_notifers
sched: More generic WAKE_AFFINE vs select_idle_sibling()
sched: Cleanup select_task_rq_fair()
sched: Fix granularity of task_u/stime()
sched: Fix/add missing update_rq_clock() calls
* git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-fscache: (31 commits)
FS-Cache: Provide nop fscache_stat_d() if CONFIG_FSCACHE_STATS=n
SLOW_WORK: Fix GFS2 to #include <linux/module.h> before using THIS_MODULE
SLOW_WORK: Fix CIFS to pass THIS_MODULE to slow_work_register_user()
CacheFiles: Don't log lookup/create failing with ENOBUFS
CacheFiles: Catch an overly long wait for an old active object
CacheFiles: Better showing of debugging information in active object problems
CacheFiles: Mark parent directory locks as I_MUTEX_PARENT to keep lockdep happy
CacheFiles: Handle truncate unlocking the page we're reading
CacheFiles: Don't write a full page if there's only a partial page to cache
FS-Cache: Actually requeue an object when requested
FS-Cache: Start processing an object's operations on that object's death
FS-Cache: Make sure FSCACHE_COOKIE_LOOKING_UP cleared on lookup failure
FS-Cache: Add a retirement stat counter
FS-Cache: Handle pages pending storage that get evicted under OOM conditions
FS-Cache: Handle read request vs lookup, creation or other cache failure
FS-Cache: Don't delete pending pages from the page-store tracking tree
FS-Cache: Fix lock misorder in fscache_write_op()
FS-Cache: The object-available state can't rely on the cookie to be available
FS-Cache: Permit cache retrieval ops to be interrupted in the initial wait phase
FS-Cache: Use radix tree preload correctly in tracking of pages to be stored
Merge reason: Pick up fixes that did not make it into .32.0
