path: root/Documentation/filesystems
2006-01-08[PATCH] drop-pagecacheAndrew Morton
Add /proc/sys/vm/drop_caches. When written to, this will cause the kernel to discard as much pagecache and/or reclaimable slab objects as it can. THis operation requires root permissions. It won't drop dirty data, so the user should run `sync' first. Caveats: a) Holds inode_lock for exorbitant amounts of time. b) Needs to be taught about NUMA nodes: propagate these all the way through so the discarding can be controlled on a per-node basis. This is a debugging feature: useful for getting consistent results between filesystem benchmarks. We could possibly put it under a config option, but it's less than 300 bytes. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-05Merge http://oss.oracle.com/git/ocfs2Linus Torvalds
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
dlmfs: A minimal dlm userspace interface implemented via a virtual file system. Most of the OCFS2 tools make use of this to take cluster locks when doing operations on the file system. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
2006-01-03[PATCH] configfs: User-driven configuration filesystemJoel Becker
Configfs, a file system for userspace-driven kernel object configuration. The OCFS2 stack makes extensive use of this for propagation of cluster configuration information into kernel. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2006-01-03Documentation/filesystems/00-INDEX: remove entry for fat_cvf.txtPaolo 'Blaisorblade' Giarrusso
Remove non-existing entry for fat_cvf.txt (was it ever supported?). Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-03Documentation/filesystems/vfs.txt: typo fixJim Cromie
This patch removes an extra occurrence of 'generic'. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-12-12[PATCH] ext3: fix mount options documentationAndreas Gruenbacher
Reported by Jacques de Mer and Daniel Drake <dsd@gentoo.org>. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-22[PATCH] kernel Doc/ URL correctionsRandy Dunlap
Correct lots of URLs in Documentation/ Also a few minor whitespace cleanups and typo/spello fixes. Sadly there are still a lot of bad URLs remaining. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] remove CONFIG_EXT{2,3}_CHECKAdrian Bunk
The CONFIG_EXT{2,3}_CHECK options where were never available, and all they did was to implement a subset of e2fsck in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] ramfs, rootfs, and initramfs docsRob Landley
Docs for ramfs, rootfs, and initramfs. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] VFS: split dentry locking documentationPekka Enberg
This patch splits dentry locking documentation from Documentation/filesystems/vfs.txt to a separate file. The dentry locking bits are useful but do not fit into the VFS overview document as is. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] VFS: update overview documentPekka Enberg
This patch updates the Documentation/filesystems/vfs.txt document. I rearranged and rewrote parts of the introduction chapter and added better headings for each section. I also added a description for the inode rename() operation which was missing and added links to some useful external VFS documentation. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] ksymoops related docs updateJesper Juhl
Update ksymoops related documentation to reflect current 2.6 reality. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-03[XFS] Update XFS documentation.Nathan Scott
Signed-off-by: Nathan Scott <nathans@sgi.com>
2005-10-11NTFS: The big ntfs write(2) rewrite has arrived. We now implement our ownAnton Altaparmakov
file operations ->write(), ->aio_write(), and ->writev() for regular files. This replaces the old use of generic_file_write(), et al and the address space operations ->prepare_write and ->commit_write. This means that both sparse and non-sparse (unencrypted and uncompressed) files can now be extended using the normal write(2) code path. There are two limitations at present and these are that we never create sparse files and that we only have limited support for highly fragmented files, i.e. ones whose data attribute is split across multiple extents. When such a case is encountered, EOPNOTSUPP is returned. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-17[PATCH] relayfs documentation typoMarcelo Tosatti
Small typo in relayfs documentation. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fuse: more flexible cachingMiklos Szeredi
Make data caching behavior selectable on a per-open basis instead of per-mount. Compatibility for the old mount options 'kernel_cache' and 'direct_io' is retained in the userspace library (version 2.4.0-pre1 or later). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] FUSE - device functionsMiklos Szeredi
This adds the FUSE device handling functions. This contains the following files: o dev.c - fuse device operations (read, write, release, poll) - registers misc device - support for sending requests to userspace Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] VFS: update documentationPekka J Enberg
This patch brings the now out-of-date Documentation/filesystems/vfs.txt back to life. Thanks to Carsten Otte, Trond Myklebust, and Anton Altaparmakov for their help on updating this documentation. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] docs: fix misinformation about overcommit_memoryChuck Ebbert
Someone complained about the docs for vm_overcommit_memory being wrong. This patch copies the text from the vm documentation into procfs. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Documentation, Makefiles, ConfigurationEric Van Hensbergen
OVERVIEW V9FS is a distributed file system for Linux which provides an implementation of the Plan 9 resource sharing protocol 9P. It can be used to share all sorts of resources: static files, synthetic file servers (such as /proc or /sys), devices, and application file servers (such as FUSE). BACKGROUND Plan 9 (http://plan9.bell-labs.com/plan9) is a research operating system and associated applications suite developed by the Computing Science Research Center of AT&T Bell Laboratories (now a part of Lucent Technologies), the same group that developed UNIX , C, and C++. Plan 9 was initially released in 1993 to universities, and then made generally available in 1995. Its core operating systems code laid the foundation for the Inferno Operating System released as a product by Lucent Bell-Labs in 1997. The Inferno venture was the only commercial embodiment of Plan 9 and is currently maintained as a product by Vita Nuova (http://www.vitanuova.com). After updated releases in 2000 and 2002, Plan 9 was open-sourced under the OSI approved Lucent Public License in 2003. The Plan 9 project was started by Ken Thompson and Rob Pike in 1985. Their intent was to explore potential solutions to some of the shortcomings of UNIX in the face of the widespread use of high-speed networks to connect machines. In UNIX, networking was an afterthought and UNIX clusters became little more than a network of stand-alone systems. Plan 9 was designed from first principles as a seamless distributed system with integrated secure network resource sharing. Applications and services were architected in such a way as to allow for implicit distribution across a cluster of systems. Configuring an environment to use remote application components or services in place of their local equivalent could be achieved with a few simple command line instructions. For the most part, application implementations operated independent of the location of their actual resources. Commercial operating systems haven't changed much in the 20 years since Plan 9 was conceived. Network and distributed systems support is provided by a patchwork of middle-ware, with an endless number of packages supplying pieces of the puzzle. Matters are complicated by the use of different complicated protocols for individual services, and separate implementations for kernel and application resources. The V9FS project (http://v9fs.sourceforge.net) is an attempt to bring Plan 9's unified approach to resource sharing to Linux and other operating systems via support for the 9P2000 resource sharing protocol. V9FS HISTORY V9FS was originally developed by Ron Minnich and Maya Gokhale at Los Alamos National Labs (LANL) in 1997. In November of 2001, Greg Watson setup a SourceForge project as a public repository for the code which supported the Linux 2.4 kernel. About a year ago, I picked up the initial attempt Ron Minnich had made to provide 2.6 support and got the code integrated into a 2.6.5 kernel. I then went through a line-for-line re-write attempting to clean-up the code while more closely following the Linux Kernel style guidelines. I co-authored a paper with Ron Minnich on the V9FS Linux support including performance comparisons to NFSv3 using Bonnie and PostMark - this paper appeared at the USENIX/FREENIX 2005 conference in April 2005: ( http://www.usenix.org/events/usenix05/tech/freenix/hensbergen.html ). CALL FOR PARTICIPATION/REQUEST FOR COMMENTS Our 2.6 kernel support is stabilizing and we'd like to begin pursuing its integration into the official kernel tree. We would appreciate any review, comments, critiques, and additions from this community and are actively seeking people to join our project and help us produce something that would be acceptable and useful to the Linux community. STATUS The code is reasonably stable, although there are no doubt corner cases our regression tests haven't discovered yet. It is in regular use by several of the developers and has been tested on x86 and PowerPC (32-bit and 64-bit) in both small and large (LANL cluster) deployments. Our current regression tests include fsx, bonnie, and postmark. It was our intention to keep things as simple as possible for this release -- trying to focus on correctness within the core of the protocol support versus a rich set of features. For example: a more complete security model and cache layer are in the road map, but excluded from this release. Additionally, we have removed support for mmap operations at Al Viro's request. PERFORMANCE Detailed performance numbers and analysis are included in the FREENIX paper, but we show comparable performance to NFSv3 for large file operations based on the Bonnie benchmark, and superior performance for many small file operations based on the PostMark benchmark. Somewhat preliminary graphs (from the FREENIX paper) are available (http://v9fs.sourceforge.net/perf/index.html). RESOURCES The source code is available in a few different forms: tarballs: http://v9fs.sf.net CVSweb: http://cvs.sourceforge.net/viewcvs.py/v9fs/linux-9p/ CVS: :pserver:anonymous@cvs.sourceforge.net:/cvsroot/v9fs/linux-9p Git: rsync://v9fs.graverobber.org/v9fs (webgit: http://v9fs.graverobber.org) 9P: tcp!v9fs.graverobber.org!6564 The user-level server is available from either the Plan 9 distribution or from http://v9fs.sf.net Other support applications are still being developed, but preliminary version can be downloaded from sourceforge. Documentation on the protocol has historically been the Plan 9 Man pages (http://plan9.bell-labs.com/sys/man/5/INDEX.html), but there is an effort under way to write a more complete Internet-Draft style specification (http://v9fs.sf.net/rfc). There are a couple of mailing lists supporting v9fs, but the most used is v9fs-developer@lists.sourceforge.net -- please direct/cc your comments there so the other v9fs contibutors can participate in the conversation. There is also an IRC channel: irc://freenode.net/#v9fs This part of the patch contains Documentation, Makefiles, and configuration file changes. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: files locking docDipankar Sarma
Add documentation describing the new locking scheme for file descriptor table. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08NTFS: 2.1.24 release and some minor final fixes.Anton Altaparmakov
2005-09-07[PATCH] relayfsTom Zanussi
Here's the latest version of relayfs, against linux-2.6.11-mm2. I'm hoping you'll consider putting this version back into your tree - the previous rounds of comment seem to have shaken out all the API issues and the number of comments on the code itself have also steadily dwindled. This patch is essentially the same as the relayfs redux part 5 patch, with some minor changes based on reviewer comments. Thanks again to Pekka Enberg for those. The patch size without documentation is now a little smaller at just over 40k. Here's a detailed list of the changes: - removed the attribute_flags in relay open and changed it to a boolean specifying either overwrite or no-overwrite mode, and removed everything referencing the attribute flags. - added a check for NULL names in relayfs_create_entry() - got rid of the unnecessary multiple labels in relay_create_buf() - some minor simplification of relay_alloc_buf() which got rid of a couple params - updated the Documentation In addition, this version (through code contained in the relay-apps tarball linked to below, not as part of the relayfs patch) tries to make it as easy as possible to create the cooperating kernel/user pieces of a typical and common type of logging application, one where kernel logging is kicked off when a user space data collection app starts and stops when the collection app exits, with the data being automatically logged to disk in between. To create this type of application, you basically just include a header file (relay-app.h, included in the relay-apps tarball) in your kernel module, define a couple of callbacks and call an initialization function, and on the user side call a single function that sets up and continuously monitors the buffers, and writes data to files as it becomes available. Channels are created when the collection app is started and destroyed when it exits, not when the kernel module is inserted, so different channel buffer sizes can be specified for each separate run via command-line options. See the README in the relay-apps tarball for details. Also included in the relay-apps tarball are a couple examples demonstrating how you can use this to create quick and dirty kernel logging/debugging applications. They are: - tprintk, short for 'tee printk', which temporarily puts a kprobe on printk() and writes a duplicate stream of printk output to a relayfs channel. This could be used anywhere there's printk() debugging code in the kernel which you'd like to exercise, but would rather not have your system logs cluttered with debugging junk. You'd probably want to kill klogd while you do this, otherwise there wouldn't be much point (since putting a kprobe on printk() doesn't change the output of printk()). I've used this method to temporarily divert the packet logging output of the iptables LOG target from the system logs to relayfs files instead, for instance. - klog, which just provides a printk-like formatted logging function on top of relayfs. Again, you can use this to keep stuff out of your system logs if used in place of printk. The example applications can be found here: http://prdownloads.sourceforge.net/dprobes/relay-apps.tar.gz?download From: Christoph Hellwig <hch@lst.de> avoid lookup_hash usage in relayfs Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] Driver core: Documentation: use S_IRUSR | ... in stead of 0644Jan Veldeman
Change filemode to use defines in stead of 0644, based on suggestions by Walter Harms and Domen Puncer. Signed-off-by: Jan Veldeman <Jan.Veldeman@advalvas.be> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] Driver core: Documentation: fix whitespace between parametersJan Veldeman
Fix whitespace after comma between parameters. Signed-off-by: Jan Veldeman <Jan.Veldeman@advalvas.be> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] add /proc/pid/smapsMauricio Lin
Add a "smaps" entry to /proc/pid: show howmuch memory is resident in each mapping. People that want to perform a memory consumption analysing can use it mainly if someone needs to figure out which libraries can be reduced for embedded systems. So the new features are the physical size of shared and clean [or dirty]; private and clean [or dirty]. Take a look the example below: # cat /proc/4576/smaps 08048000-080dc000 r-xp /bin/bash Size: 592 KB Rss: 500 KB Shared_Clean: 500 KB Shared_Dirty: 0 KB Private_Clean: 0 KB Private_Dirty: 0 KB 080dc000-080e2000 rw-p /bin/bash Size: 24 KB Rss: 24 KB Shared_Clean: 0 KB Shared_Dirty: 0 KB Private_Clean: 0 KB Private_Dirty: 24 KB 080e2000-08116000 rw-p Size: 208 KB Rss: 208 KB Shared_Clean: 0 KB Shared_Dirty: 0 KB Private_Clean: 0 KB Private_Dirty: 208 KB b7e2b000-b7e34000 r-xp /lib/tls/libnss_files-2.3.2.so Size: 36 KB Rss: 12 KB Shared_Clean: 12 KB Shared_Dirty: 0 KB Private_Clean: 0 KB Private_Dirty: 0 KB ... (Includes a cleanup from "Richard Purdie" <rpurdie@rpsys.net>) From: Torsten Foertsch <torsten.foertsch@gmx.net> show_smap calls first show_map and then prints its additional information to the seq_file. show_map checks if all it has to print fits into the buffer and if yes marks the current vma as written. While that is correct for show_map it is not for show_smap. Here the vma should be marked as written only after the additional information is also written. The attached patch cures the problem. It moves the functionality of the show_map function to a new function show_map_internal that is called with an additional struct mem_size_stats* argument. Then show_map calls show_map_internal with NULL as struct mem_size_stats* whereas show_smap calls it with a real pointer. Now the final if (m->count < m->size) /* vma is copied successfully */ m->version = (vma != get_gate_vma(task))? vma->vm_start: 0; is done only if the whole entry fits into the buffer. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-16Merge master.kernel.org:/pub/scm/linux/kernel/git/aia21/ntfs-2.6Linus Torvalds
2005-07-15[PATCH] inotify: documentation updateRobert Love
Clean up and expand some of the inotify documentation. Signed-off-by: Robert Love <rml@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-13Automatic merge with /usr/src/ntfs-2.6.git.Anton Altaparmakov
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-26NTFS: Fix a nasty deadlock that appeared in recent kernels.Anton Altaparmakov
The situation: VFS inode X on a mounted ntfs volume is dirty. For same inode X, the ntfs_inode is dirty and thus corresponding on-disk inode, i.e. mft record, which is in a dirty PAGE_CACHE_PAGE belonging to the table of inodes, i.e. $MFT, inode 0. What happens: Process 1: sys_sync()/umount()/whatever... calls __sync_single_inode() for $MFT -> do_writepages() -> write_page for the dirty page containing the on-disk inode X, the page is now locked -> ntfs_write_mst_block() which clears PageUptodate() on the page to prevent anyone else getting hold of it whilst it does the write out. This is necessary as the on-disk inode needs "fixups" applied before the write to disk which are removed again after the write and PageUptodate is then set again. It then analyses the page looking for dirty on-disk inodes and when it finds one it calls ntfs_may_write_mft_record() to see if it is safe to write this on-disk inode. This then calls ilookup5() to check if the corresponding VFS inode is in icache(). This in turn calls ifind() which waits on the inode lock via wait_on_inode whilst holding the global inode_lock. Process 2: pdflush results in a call to __sync_single_inode for the same VFS inode X on the ntfs volume. This locks the inode (I_LOCK) then calls write-inode -> ntfs_write_inode -> map_mft_record() -> read_cache_page() for the page (in page cache of table of inodes $MFT, inode 0) containing the on-disk inode. This page has PageUptodate() clear because of Process 1 (see above) so read_cache_page() blocks when it tries to take the page lock for the page so it can call ntfs_read_page(). Thus Process 1 is holding the page lock on the page containing the on-disk inode X and it is waiting on the inode X to be unlocked in ifind() so it can write the page out and then unlock the page. And Process 2 is holding the inode lock on inode X and is waiting for the page to be unlocked so it can call ntfs_readpage() or discover that Process 1 set PageUptodate() again and use the page. Thus we have a deadlock due to ifind() waiting on the inode lock. The solution: The fix is to use the newly introduced ilookup5_nowait() which does not wait on the inode's lock and hence avoids the deadlock. This is safe as we do not care about the VFS inode and only use the fact that it is in the VFS inode cache and the fact that the vfs and ntfs inodes are one struct in memory to find the ntfs inode in memory if present. Also, the ntfs inode has its own locking so it does not matter if the vfs inode is locked. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-06-25NTFS: Prepare for 2.1.23 release: Update documentation and bump version.Anton Altaparmakov
2005-06-25Automerge with /usr/src/ntfs-2.6.git.Anton Altaparmakov
2005-06-24[PATCH] xip: descriptionCarsten Otte
Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23Automatic merge with /usr/src/ntfs-2.6.git.Anton Altaparmakov
2005-06-21[PATCH] isofs: show hidden files, add granularity for assoc/hidden files flagsJeremy White
The current isofs treatment of hidden files is flawed in two ways. First, it does not provide sufficient granularity; it hides both 'hidden' files and 'associated' files (resource fork for Mac files). Second, the default behavior to completely strip hidden files, while an admirable implementation of the spec, is a poor choice given the real world use of hidden files as a poor mans copy protection scheme for MSDOS and Windows based systems. A longer description of this is available here: http://www.uwsg.iu.edu/hypermail/linux/kernel/0205.3/0267.html This patch was originally built after a few private conversations with Alan Cox; I shamefully failed to persist in seeing it go forward, I hope to make amends now. This patch introduces granularity by allowing explicit control for both hidden and associated files. It also reverses the default so that by default, hidden files are treated as regular files on the iso9660 file system. This allow Wine to process Windows CDs, including those that are hybrid Mac/Windows CDs properly and completely, without our having to go muck up peoples fstabs as we do now. (I have tested this with such a hybrid + hidden CD and have verified that this patch works as claimed). Signed-off-by: Jeremy White <jwhite@codeweavers.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] shmem: restore superblock infoHugh Dickins
To improve shmem scalability, we allowed tmpfs instances which don't need their blocks or inodes limited not to count them, and not to allocate any sbinfo. Which was okay when the only use for the sbinfo was accounting blocks and inodes; but since then a couple of unrelated projects extending tmpfs want to store other data in the sbinfo. Whether either extension reaches mainline is beside the point: I'm guilty of a bad design decision, and should restore sbinfo to make any such future extensions easier. So, once again allocate a shmem_sb_info for every shmem/tmpfs instance, and now let max_blocks 0 indicate unlimited blocks, and max_inodes 0 unlimited inodes. Brent Casavant verified (many months ago) that this does not perceptibly impact the scalability (since the unlimited sbinfo cacheline is repeatedly accessed but only once dirtied). And merge shmem_set_size into its sole caller shmem_remount_fs. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver core: Documentation: update device attribute callbacksYani Ioannou
Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-21Merge with /usr/src/ntfs-2.6.gitAnton Altaparmakov
2005-05-17[PATCH] Driver Core: remove driver model detach_stateDavid Brownell
The driver model has a "detach_state" mechanism that: - Has never been used by any in-kernel drive; - Is superfluous, since driver remove() methods can do the same thing; - Became buggy when the suspend() parameter changed semantics and type; - Could self-deadlock when called from certain suspend contexts; - Is effectively wasted documentation, object code, and headspace. This removes that "detach_state" mechanism; net code shrink, as well as a per-device saving in the driver model and sysfs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-05-05NTFS: - Add disable_sparse mount option together with a per volume sparseAnton Altaparmakov
enable bit which is set appropriately and a per inode sparse disable bit which is preset on some system file inodes as appropriate. - Enforce that sparse support is disabled on NTFS volumes pre 3.0. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-01[PATCH] Documentation: remove super-{nr, max} to reflect fs/super.cCosmin Nicolaescu
The patch updates the documentation for /proc. super-nr and super-max have been dropped from the kernel since 2.4.9 due to minor numbering issues. This change was not documented in the documentation. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] doc: Locking updateNikita Danilov
Make the Locking document truer. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
