path: root/Documentation/filesystems/vfs.txt
2009-12-10kill wait_on_page_writeback_rangeChristoph Hellwig
All callers really want the more logical filemap_fdatawait_range interface, so convert them to use it and merge wait_on_page_writeback_range into filemap_fdatawait_range. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-16HWPOISON: Define a new error_remove_page address space op for async truncationAndi Kleen
Truncating metadata pages is not safe right now before we haven't audited all file systems. To enable truncation only for data address space define a new address_space callback error_remove_page. This is used for memory_failure.c memory error handling. This can be then set to truncate_inode_page() This patch just defines the new operation and adds documentation. Callers and users come in followon patches. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2009-04-20Documentation/filesystems: remove out of date reference to BKL being heldAdrian McMenamin
Documentation/filesystems/vfs.txt incorrectly states that the kernel is locked during the call to statfs (Documentation/filesystems/Locking correctly says it is not). This patch removes the offending sentence. remove reference to BKL being held in statfs Signed-off-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-09filesystem freeze: add error handling of write_super_lockfs/unlockfsTakashi Sato
Currently, ext3 in mainline Linux doesn't have the freeze feature which suspends write requests. So, we cannot take a backup which keeps the filesystem's consistency with the storage device's features (snapshot and replication) while it is mounted. In many case, a commercial filesystem (e.g. VxFS) has the freeze feature and it would be used to get the consistent backup. If Linux's standard filesystem ext3 has the freeze feature, we can do it without a commercial filesystem. So I have implemented the ioctls of the freeze feature. I think we can take the consistent backup with the following steps. 1. Freeze the filesystem with the freeze ioctl. 2. Separate the replication volume or create the snapshot with the storage device's feature. 3. Unfreeze the filesystem with the unfreeze ioctl. 4. Take the backup from the separated replication volume or the snapshot. This patch: VFS: Changed the type of write_super_lockfs and unlockfs from "void" to "int" so that they can return an error. Rename write_super_lockfs and unlockfs of the super block operation freeze_fs and unfreeze_fs to avoid a confusion. ext3, ext4, xfs, gfs2, jfs: Changed the type of write_super_lockfs and unlockfs from "void" to "int" so that write_super_lockfs returns an error if needed, and unlockfs always returns 0. reiserfs: Changed the type of write_super_lockfs and unlockfs from "void" to "int" so that they always return 0 (success) to keep a current behavior. Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Masayuki Hamaguchi <m-hamaguchi@ys.jp.nec.com> Cc: <xfs-masters@oss.sgi.com> Cc: <linux-ext4@vger.kernel.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Alasdair G Kergon <agk@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31kill ->dir_notify()Al Viro
Remove the hopelessly misguided ->dir_notify(). The only instance (cifs) has been broken by design from the very beginning; the objects it creates are never destroyed, keep references to struct file they can outlive, nothing that could possibly evict them exists on close(2) path *and* no locking whatsoever is done to prevent races with close(), should the previous, er, deficiencies someday be dealt with. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-31correct wrong function name of d_put in kernel document and source commentZhaolei
no function named d_put(), it should be dput(). Impact: fix document and comment, no functionality changed Signed-off-by: Zhao Lei <zhaolei@cn.fuijtsu.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-30fs: remove prepare_write/commit_writeNick Piggin
Nothing uses prepare_write or commit_write. Remove them from the tree completely. [akpm@linux-foundation.org: schedule simple_prepare_write() for unexporting] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-06[PATCH] kill ->put_inodeChristoph Hellwig
And with that last patch to affs killing the last put_inode instance we can finally, after many years of transition kill this racy and awkward interface. (It's kinda funny that even the description in Documentation/filesystems/vfs.txt was entirely wrong..) Also remove a very misleading comment above the defintion of struct super_operations. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08mount options: add documentationMiklos Szeredi
This series addresses the problem of showing mount options in /proc/mounts. Several filesystems which use mount options, have not implemented a .show_options superblock operation. Several others have implemented this callback, but have not kept it fully up to date with the parsed options. Q: Why do we need correct option showing in /proc/mounts? A: We want /proc/mounts to fully replace /etc/mtab. The reasons for this are: - unprivileged mounters won't be able to update /etc/mtab - /etc/mtab doesn't work with private mount namespaces - /etc/mtab can become out-of-sync with reality Q: Can't this be done, so that filesystems need not bother with implementing a .show_mounts callback, and keeping it up to date? A: Only in some cases. Certain filesystems allow modification of a subset of options in their remount_fs method. It is not possible to take this into account without knowing exactly how the filesystem handles options. For the simple case (no remount or remount resets all options) the patchset introduces two helpers: generic_show_options() save_mount_options() These can also be used to emulate the old /etc/mtab behavior, until proper support is added. Even if this is not 100% correct, it's still better than showing no options at all. The following patches fix up most in-tree filesystems, some have been compile tested only, some have been reviewed and acked by the maintainer. Table displaying status of all in-kernel filesystems: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - legend: none - fs has options, but doesn't define ->show_options() some - fs defines ->show_options(), but some only options are shown good - fs shows all options noopt - fs does not have options patch - a patch will be posted merged - a patch has been merged by subsystem maintainer 9p good adfs patch affs patch afs patch autofs patch autofs4 patch befs patch bfs noopt cifs some coda noopt configfs noopt cramfs noopt debugfs noopt devpts patch ecryptfs good efs noopt ext2 patch ext3 good ext4 merged fat patch freevxfs noopt fuse patch fusectl noopt gfs2 good gfs2meta noopt hfs good hfsplus good hostfs patch hpfs patch hppfs noopt hugetlbfs patch isofs patch jffs2 noopt jfs merged minix noopt msdos ->fat ncpfs patch nfs some nfsd noopt ntfs good ocfs2 good ocfs2/dlmfs noopt openpromfs noopt proc noopt qnx4 noopt ramfs noopt reiserfs patch romfs noopt smbfs good sysfs noopt sysv noopt udf patch ufs good vfat ->fat xfs good mm/shmem.c patch drivers/oprofile/oprofilefs.c noopt drivers/infiniband/hw/ipath/ipath_fs.c noopt drivers/misc/ibmasm/ibmasmfs.c noopt drivers/usb/core (usbfs) merged drivers/usb/gadget (gadgetfs) noopt drivers/isdn/capi/capifs.c patch kernel/cpuset.c noopt fs/binfmt_misc.c noopt net/sunrpc/rpc_pipe.c noopt arch/powerpc/platforms/cell/spufs patch arch/s390/hypfs good ipc/mqueue.c noopt security (securityfs) noopt security/selinux/selinuxfs.c noopt kernel/cgroup.c good security/smack/smackfs.c noopt in -mm: reiser4 some unionfs good - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - This patch: Document the rules for handling mount options in the .show_options super operation. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: remove iget() and the read_inode() super op as being obsoleteDavid Howells
Remove the old iget() call and the read_inode() superblock operation it uses as these are really obsolete, and the use of read_inode() does not produce proper error handling (no distinction between ENOMEM and EIO when marking an inode bad). Furthermore, this removes the temptation to use iget() to find an inode by number in a filesystem from code outside that filesystem. iget_locked() should be used instead. A new function is added in an earlier patch (iget_failed) that is to be called to mark an inode as bad, unlock it and release it should the get routine fail. Mark iget() and read_inode() as being obsolete and remove references to them from the documentation. Typically a filesystem will be modified such that the read_inode function becomes an internal iget function, for example the following: void thingyfs_read_inode(struct inode *inode) { ... } would be changed into something like: struct inode *thingyfs_iget(struct super_block *sp, unsigned long ino) { struct inode *inode; int ret; inode = iget_locked(sb, ino); if (!inode) return ERR_PTR(-ENOMEM); if (!(inode->i_state & I_NEW)) return inode; ... unlock_new_inode(inode); return inode; error: iget_failed(inode); return ERR_PTR(ret); } and then thingyfs_iget() would be called rather than iget(), for example: ret = -EINVAL; inode = iget(sb, ino); if (!inode || is_bad_inode(inode)) goto error; becomes: inode = thingyfs_iget(sb, ino); if (IS_ERR(inode)) { ret = PTR_ERR(inode); goto error; } Note that is_bad_inode() does not need to be called. The error returned by thingyfs_iget() should render it unnecessary. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20Documentation/filesystems/vfs.txt: typo fixShaun Zinck
Signed-off-by: Shaun Zinck <shaun.zinck@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16fs: remove some AOP_TRUNCATED_PAGENick Piggin
prepare/commit_write no longer returns AOP_TRUNCATED_PAGE since OCFS2 and GFS2 were converted to the new aops, so we can make some simplifications for that. [michal.k.k.piotrowski@gmail.com: fix warning] Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: introduce write_begin, write_end, and perform_write aopsNick Piggin
These are intended to replace prepare_write and commit_write with more flexible alternatives that are also able to avoid the buffered write deadlock problems efficiently (which prepare_write is unable to do). [mark.fasheh@oracle.com: API design contributions, code review and fixes] [akpm@linux-foundation.org: various fixes] [dmonakhov@sw.ru: new aop block_write_begin fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16update Documentation/filesystems/vfs.txtBorislav Petkov
Update Documentation/filesystems/vfs.txt Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16update description in Documentation/filesystems/vfs.txtBorislav Petkov
Update the description of struct file_system_type and get_sb() in Documentation/filesystems/vfs.txt to match the current code. Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08VFS: delay the dentry name generation on sockets and pipesEric Dumazet
1) Introduces a new method in 'struct dentry_operations'. This method called d_dname() might be called from d_path() to build a pathname for special filesystems. It is called without locks. Future patches (if we succeed in having one common dentry for all pipes/sockets) may need to change prototype of this method, but we now use : char *d_dname(struct dentry *dentry, char *buffer, int buflen); 2) Adds a dynamic_dname() helper function that eases d_dname() implementations 3) Defines d_dname method for sockets : No more sprintf() at socket creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... 4) Defines d_dname method for pipes : No more sprintf() at pipe creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... A benchmark consisting of 1.000.000 calls to pipe()/close()/close() gives a *nice* speedup on my Pentium(M) 1.6 Ghz : 3.090 s instead of 3.450 s Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Christoph Hellwig <hch@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] fs: fix libfs data leakNick Piggin
simple_prepare_write leaks uninitialised kernel data. This happens because the it leaves an uninitialised "hole" over the part of the page that the write is expected to go to. This is fine, but it then marks the page uptodate, which means a concurrent read can come in and copy the uninitialised memory into userspace before it written to. Fix it by simply marking it uptodate in simple_commit_write instead, after the hole has been filled in. This could theoretically break an fs that uses simple_prepare_write and not simple_commit_write, and that relies on the incorrect simple_prepare_write behaviour. Luckily, none of those exists in the tree. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] VFS documentation tweakJonathan Corbet
As I was looking over the get_sb() changes, I stumbled across a little mistake in the documentation updates. Unless we're getting into an interesting new object-oriented realm, I doubt that get_sb() should really return "struct int"... Signed-off-by: Jonathan Corbet <corbet@lwn.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] vfs: add splice_write and splice_read to documentationPekka J Enberg
This patch adds the new splice_write and splice_read file operations to Documentation/filesystems/vfs.txt. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-25[PATCH] More corrections to vfs.txt updateNeilBrown
Thanks "Randy.Dunlap" <rdunlap@xenotime.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] Update some VFS documentationNeilBrown
Flesh out the description of the address_space operations. Signed-off-by: Neil Brown <neilb@suse.de> Cc: Avishay Traeger <atraeger@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03Documentation/filesystems/vfs.txt: typo fixJim Cromie
This patch removes an extra occurrence of 'generic'. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-07[PATCH] VFS: split dentry locking documentationPekka Enberg
This patch splits dentry locking documentation from Documentation/filesystems/vfs.txt to a separate file. The dentry locking bits are useful but do not fit into the VFS overview document as is. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] VFS: update overview documentPekka Enberg
This patch updates the Documentation/filesystems/vfs.txt document. I rearranged and rewrote parts of the introduction chapter and added better headings for each section. I also added a description for the inode rename() operation which was missing and added links to some useful external VFS documentation. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] VFS: update documentationPekka J Enberg
This patch brings the now out-of-date Documentation/filesystems/vfs.txt back to life. Thanks to Carsten Otte, Trond Myklebust, and Anton Altaparmakov for their help on updating this documentation. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
